  3. Einsteigerfragen
  4. Einbindung von Geräten
  5. Shelly Adapterinstanz bleibt gelb
    2.8k
    4.9k
    4.1k
30 Beiträge 6 Kommentatoren 3.3k Aufrufe 4 Beobachtet
  • haselchenH haselchen
    @chriz
    Jetzt noch die Langfassung davon :)
    ChrizC Offline
    ChrizC Offline
    Chriz
    schrieb am zuletzt editiert von Chriz
    @haselchen
    ua, tut mir Leid 🤦
    Skript v.2023-10-10
    *** BASE SYSTEM ***
    Hardware Vendor : To Be Filled By O.E.M.
    Kernel          : x86_64
    Userland        : amd64
    Docker          : v9.1.1
    Virtualization  : Docker
    Kernel          : x86_64
    Userland        : amd64
    Systemuptime and Load:
     18:06:16 up 60 days,  2:37,  0 user,  load average: 10.21, 9.20, 7.21
    CPU threads: 8
    *** Time and Time Zones ***
    Wed Feb 28 17:06:16 UTC 2024
    Wed Feb 28 18:06:16 CET 2024
    CET +0100
    Etc/UTC
    *** User and Groups ***
    root
    /root
    root
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:
    *** MEMORY ***
    Mem:             12G        5.5G        306M        554M        7.6G        7.0G
    Swap:            10G        733M         10G
    Total:           23G        6.2G         10G
            11915 M total memory
             5260 M used memory
             3617 M active memory
             6264 M inactive memory
              292 M free memory
                1 M buffer memory
             7202 M swap cache
            10239 M total swap
              699 M used swap
             9540 M free swap
    *** FILESYSTEM ***
    Filesystem     Type       Size  Used Avail Use% Mounted on
    /dev/loop2     btrfs       25G  7.0G   18G  29% /
    tmpfs          tmpfs       64M     0   64M   0% /dev
    shm            tmpfs       64M     0   64M   0% /dev/shm
    shfs           fuse.shfs  932G  267G  665G  29% /opt/iobroker
    /dev/loop2     btrfs       25G  7.0G   18G  29% /etc/hosts
    tmpfs          tmpfs      5.9G     0  5.9G   0% /proc/acpi
    tmpfs          tmpfs      5.9G     0  5.9G   0% /sys/firmware
    dmesg: read kernel buffer failed: Operation not permitted
    TARGET             SOURCE        FSTYPE    OPTIONS
    /                  /dev/loop2[/btrfs/subvolumes/5322bd356013345d50636c8434e2e273c4ab5d4b4738c2d12790a6eb3c1c2d59]       btrfs     rw,noatime,ssd,space_cache=v2,subvolid=949,subvol=/btrfs/subvolumes/5322bd356013345d50636c8434e2e273c4ab5d4b4738c2d12790a6eb3c1c2d59
    |-/opt/iobroker    shfs[/appdata/iobroker/data]        fuse.shfs rw,nosuid,nodev,noatime,user_id=0,group_id=0,default_permissions,allow_other
    |-/opt/userscripts shfs[/appdata/iobroker/scripts]        fuse.shfs rw,nosuid,nodev,noatime,user_id=0,group_id=0,default_permissions,allow_other
    |-/etc/resolv.conf /dev/loop2[/containers/22646d536096c5b460e9e9871d278aeec6ba4c324f924b103e2617abcc5650f9/resolv.conf] btrfs     rw,noatime,ssd,space_cache=v2,subvolid=5,subvol=/
    |-/etc/hostname    /dev/loop2[/containers/22646d536096c5b460e9e9871d278aeec6ba4c324f924b103e2617abcc5650f9/hostname]    btrfs     rw,noatime,ssd,space_cache=v2,subvolid=5,subvol=/
    `-/etc/hosts       /dev/loop2[/containers/22646d536096c5b460e9e9871d278aeec6ba4c324f924b103e2617abcc5650f9/hosts]       btrfs     rw,noatime,ssd,space_cache=v2,subvolid=5,subvol=/
    /var:
    34M     /var/
    32M     /var/lib
    19M     /var/lib/apt/lists
    19M     /var/lib/apt
    13M     /var/lib/dpkg
    /opt/iobroker/backups:
    9.6M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    403M    /opt/iobroker/iobroker-data/
    199M    /opt/iobroker/iobroker-data/files
    128M    /opt/iobroker/iobroker-data/backup-objects
    57M     /opt/iobroker/iobroker-data/files/javascript.admin
    43M     /opt/iobroker/iobroker-data/files/iot.admin
    33M     /opt/iobroker/iobroker-data/objects.jsonl
    33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
    22M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.c05ba1d3.js.map
    15M     /opt/iobroker/iobroker-data/states.jsonl
    13M     /opt/iobroker/iobroker-data/objects.json.migrated
    USB-Devices by-id:
    /dev/serial/by-id/usb-Silicon_Labs_CP2102N_USB_to_UART_Bridge_Controller_3a866a46ae89eb118f103dc07d11dc1e-if00-port0
    /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_de4ef275ea5fec118396325f25bfaa52-if00-port0
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.19.1
    /usr/bin/node           v18.19.1
    /usr/bin/npm            10.2.4
    /usr/bin/npx            10.2.4
    /usr/bin/corepack       0.22.0
    nodejs:
      Installed: 18.19.1-1nodesource1
      Candidate: 18.19.1-1nodesource1
      Version table:
     *** 18.19.1-1nodesource1 1001
           1001 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
         18.19.0+dfsg-6~deb12u1 500
            500 http://deb.debian.org/debian-security bookworm-security/main amd64 Packages
         18.19.0-1nodesource1 1001
         18.18.2-1nodesource1 1001
         18.18.1-1nodesource1 1001
         18.18.0-1nodesource1 1001
         18.17.1-1nodesource1 1001
         18.17.0-1nodesource1 1001
         18.16.1-1nodesource1 1001
         18.16.0-1nodesource1 1001
         18.15.0-1nodesource1 1001
         18.14.2-1nodesource1 1001
         18.14.1-1nodesource1 1001
         18.14.0-1nodesource1 1001
         18.13.0+dfsg1-1 500
            500 http://deb.debian.org/debian bookworm/main amd64 Packages
         18.13.0-1nodesource1 1001
         18.12.0-1nodesource1 1001
         18.11.0-1nodesource1 1001
         18.10.0-1nodesource1 1001
         18.9.1-1nodesource1 1001
         18.9.0-1nodesource1 1001
         18.8.0-1nodesource1 1001
         18.7.0-1nodesource1 1001
         18.6.0-1nodesource1 1001
         18.5.0-1nodesource1 1001
         18.4.0-1nodesource1 1001
         18.3.0-1nodesource1 1001
         18.2.0-1nodesource1 1001
         18.1.0-1nodesource1 1001
         18.0.0-1nodesource1 1001
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  5.0.19
    admin:          6.13.16
    javascript:     7.8.0
    Adapters from github:   1
    Adapter State
    + system.adapter.admin.0                  : admin                 : 22646d536096                             -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.alexa2.0                 : alexa2                : 22646d536096                             -  enabled
    + system.adapter.backitup.0               : backitup              : 22646d536096                             -  enabled
    + system.adapter.denon.0                  : denon                 : 22646d536096                             -  enabled
    + system.adapter.discovery.0              : discovery             : 22646d536096                             -  enabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : 22646d536096                             -  enabled
    + system.adapter.influxdb.0               : influxdb              : 22646d536096                             -  enabled, port: 8086
    + system.adapter.info.0                   : info                  : 22646d536096                             -  enabled
    + system.adapter.iot.0                    : iot                   : 22646d536096                             -  enabled
    + system.adapter.javascript.0             : javascript            : 22646d536096                             -  enabled
    + system.adapter.lgtv.0                   : lgtv                  : 22646d536096                             -  enabled
    + system.adapter.loxone.0                 : loxone                : 22646d536096                             -  enabled, port: 80
    + system.adapter.luxtronik2.0             : luxtronik2            : 22646d536096                             -  enabled, port: 8214
    + system.adapter.mqtt.0                   : mqtt                  : 22646d536096                             -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.nuki-extended.0          : nuki-extended         : 22646d536096                             -  enabled
    + system.adapter.octoprint.0              : octoprint             : 22646d536096                             -  enabled
    + system.adapter.shelly.0                 : shelly                : 22646d536096                             -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.signal-cmb.0             : signal-cmb            : 22646d536096                             -  enabled
    + system.adapter.simple-api.0             : simple-api            : 22646d536096                             -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
    + system.adapter.smartmeter.0             : smartmeter            : 22646d536096                             -  enabled
    + system.adapter.tr-064.0                 : tr-064                : 22646d536096                             -  enabled
      system.adapter.vis-history.0            : vis-history           : 22646d536096                             -  enabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : 22646d536096                             -  enabled
    + system.adapter.vis-inventwo.0           : vis-inventwo          : 22646d536096                             -  enabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : 22646d536096                             -  enabled
      system.adapter.vis-justgage.0           : vis-justgage          : 22646d536096                             -  enabled
      system.adapter.vis-material-advanced.0  : vis-material-advanced : 22646d536096                             -  enabled
      system.adapter.vis-metro.0              : vis-metro             : 22646d536096                             -  enabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : 22646d536096                             -  enabled
      system.adapter.vis-weather.0            : vis-weather           : 22646d536096                             -  enabled
      system.adapter.vis.0                    : vis                   : 22646d536096                             -  enabled
      system.adapter.vw-connect.1             : vw-connect            : 22646d536096                             - disabled
      system.adapter.weatherunderground.0     : weatherunderground    : 22646d536096                             -  enabled
    + system.adapter.web.0                    : web                   : 22646d536096                             -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.zigbee.0                 : zigbee                : 22646d536096                             -  enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_de4ef275ea5fec118396325f25bfaa52-if00-port0
    + instance is alive
    ioBroker-Repositories
    Stable (default): http://download.iobroker.net/sources-dist.json
    Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
    Installed ioBroker-Instances
    Adapter    "admin"        : 6.13.16  , installed 6.13.16
    Adapter    "alexa2"       : 3.26.4   , installed 3.26.4
    Adapter    "backitup"     : 2.10.11  , installed 2.10.11
    Adapter    "denon"        : 1.15.5   , installed 1.15.5
    Adapter    "discovery"    : 4.2.0    , installed 4.2.0
    Adapter    "iot"          : 2.0.11   , installed 2.0.11
    Adapter    "javascript"   : 7.8.0    , installed 7.8.0
    Controller "js-controller": 5.0.19   , installed 5.0.19
    Adapter    "lgtv"         : 2.1.2    , installed 2.1.2
    Adapter    "loxone"       : 3.0.1    , installed 3.0.1
    Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
    Adapter    "nuki-extended": 2.6.5    , installed 2.6.5
    Adapter    "octoprint"    : 5.1.0    , installed 5.1.0
    Adapter    "ring"         : 5.0.10   , installed 5.0.10
    Adapter    "shelly"       : 6.6.1    , installed 6.6.1
    Adapter    "signal-cmb"   : 0.3.0    , installed 0.3.0
    Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
    Adapter    "socketio"     : 6.6.0    , installed 6.6.0
    Adapter    "vis"          : 1.5.4    , installed 1.5.4
    Adapter    "vis-justgage" : 2.1.0    , installed 2.1.0
    Adapter    "vis-weather"  : 2.5.9    , installed 2.5.9
    Adapter    "weatherunderground": 3.6.0, installed 3.6.0
    Adapter    "web"          : 6.2.3    , installed 6.2.3
    Adapter    "ws"           : 2.5.10   , installed 2.5.10
    Adapter    "zigbee"       : 1.10.1   , installed 1.10.1
    Objects and States
    Objects:        15099
    States:         15252
    Hit:2 http://deb.debian.org/debian bookworm-updates InRelease
    Hit:3 http://deb.debian.org/debian-security bookworm-security InRelease
    Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      99         538520712  -
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      99         538521626  -
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      99         538524912  -
    tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      99         538678861  -
    tcp6       0      0 :::8082                 :::*                    LISTEN      99         538556277  -
    tcp6       0      0 :::8081                 :::*                    LISTEN      99         538520745  -
    tcp6       0      0 :::8087                 :::*                    LISTEN      99         538559721  -
    2024-02-28 17:54:19.665  - info: smartmeter.0 (321) Received 9 values, 6 updated
    2024-02-28 17:54:50.675  - info: smartmeter.0 (321) Received 9 values, 6 updated
    2024-02-28 17:55:21.671  - info: smartmeter.0 (321) Received 9 values, 6 updated
    2024-02-28 17:55:52.663  - info: smartmeter.0 (321) Received 9 values, 6 updated
    2024-02-28 17:56:23.667  - info: smartmeter.0 (321) Received 9 values, 6 updated
    2024-02-28 17:56:54.668  - info: smartmeter.0 (321) Received 9 values, 6 updated
    2024-02-28 17:57:25.667  - info: smartmeter.0 (321) Received 9 values, 6 updated
    2024-02-28 17:57:56.666  - info: smartmeter.0 (321) Received 9 values, 6 updated
    2024-02-28 17:58:27.664  - info: smartmeter.0 (321) Received 9 values, 6 updated
    2024-02-28 17:58:58.706  - info: smartmeter.0 (321) Received 9 values, 6 updated
    2024-02-28 17:59:29.667  - info: smartmeter.0 (321) Received 9 values, 6 updated
    2024-02-28 18:00:00.676  - info: smartmeter.0 (321) Received 9 values, 6 updated
    2024-02-28 18:00:31.662  - info: smartmeter.0 (321) Received 9 values, 6 updated
    2024-02-28 18:01:02.663  - info: smartmeter.0 (321) Received 9 values, 6 updated
    2024-02-28 18:01:33.674  - info: smartmeter.0 (321) Received 9 values, 6 updated
    2024-02-28 18:02:04.658  - info: smartmeter.0 (321) Received 9 values, 6 updated
    2024-02-28 18:02:35.658  - info: smartmeter.0 (321) Received 9 values, 6 updated
    2024-02-28 18:03:06.657  - info: smartmeter.0 (321) Received 9 values, 6 updated
    2024-02-28 18:03:37.662  - info: smartmeter.0 (321) Received 9 values, 6 updated
    2024-02-28 18:04:08.656  - info: smartmeter.0 (321) Received 9 values, 6 updated
    2024-02-28 18:04:39.654  - info: smartmeter.0 (321) Received 9 values, 6 updated
    2024-02-28 18:05:10.672  - info: smartmeter.0 (321) Received 9 values, 6 updated
    2024-02-28 18:05:41.654  - info: smartmeter.0 (321) Received 9 values, 6 updated
    2024-02-28 18:06:12.654  - info: smartmeter.0 (321) Received 9 values, 6 updated
    2024-02-28 18:06:43.657  - info: smartmeter.0 (321) Received 9 values, 6 updated
    ich hoffe da steht nix drin, was nicht im Netz stehen sollte :/
    melde mich morgen wieder dazu, muss leider noch weg, jetzt.
    Schonmal jetzt vielen Dank an euch, ich hoffe ich kann morgenw ieder auf euch zählen :)
    • ChrizC Chriz
      @haselchen
      ua, tut mir Leid 🤦
      Skript v.2023-10-10
      *** BASE SYSTEM ***
      Kernel          : x86_64
      Userland        : amd64
      Docker          : v9.1.1
      Kernel          : x86_64
      Userland        : amd64
      CPU threads: 8
      CET +0100
      Etc/UTC
      root
      /root
      root
      X-Server:       false
      Desktop:
      Terminal:
      *** MEMORY ***
      Swap:            10G        733M         10G
      Total:           23G        6.2G         10G
               5260 M used memory
                292 M free memory
                  1 M buffer memory
               7202 M swap cache
              10239 M total swap
                699 M used swap
               9540 M free swap
      *** FILESYSTEM ***
      /var:
      34M     /var/
      32M     /var/lib
      19M     /var/lib/apt
      13M     /var/lib/dpkg
      USB-Devices by-id:
      /usr/bin/npm            10.2.4
      /usr/bin/npx            10.2.4
      nodejs:
        Version table:
           18.13.0+dfsg1-1 500
      Errors in npm tree:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      admin:          6.13.16
      javascript:     7.8.0
      Adapter State
      + instance is alive
      Objects and States
      Objects:        15099
      States:         15252
      Pending Updates: 0
      DJMarc75D Offline
      DJMarc75D Offline
      DJMarc75
      @chriz
      User ROOT schonmal mehr als falsch ;)
      @chriz sagte in Shelly Adapterinstanz bleibt gelb:
      heiliges Blechle 🤕
      Da läuft was mehr als aus dem Ruder
      Lehrling seit 1975 !!!
      ChrizC 1 Antwort Letzte Antwort
      • DJMarc75D DJMarc75
        @chriz
        heiliges Blechle 🤕
        ChrizC Offline
        ChrizC Offline
        Chriz
        @djmarc75
        Was ist denn falsch bzw. schlimm?
        • ChrizC Chriz
          @djmarc75
          DJMarc75D Offline
          DJMarc75D Offline
          DJMarc75
          Na wie geschrieben meldet man sich nicht als root auf der Kiste an sondern mit einem gescheiten User ;)
          Dann sind die loads über dem Limit, bei 8 Kernen. Laufen da vll ein paar Skripte bei Dir Amok ?
          iob fix
          auch mal machen.
            iob fix
            auch mal machen.
            ChrizC Offline
            ChrizC Offline
            Chriz
            @djmarc75
            Wieso nicht als root anmelden?
            Läuft bei mir seit Jahren so ohne Probleme..
            Um ehrlich zu sein wüsste ich nicht mal das ich mich überhaupt irgendwo anmelden müsste... 😕
            Scripte habe ich 3 Stück wovon eines nur läuft. Und das macht nix weiter als eine Nachricht zu schicken wenn sich ein bestimmter Datenpunkt verändert. Passiert aber nur alle paar Monate mal.
            Mein System ist eigentlich gar nicht ausgelastet. CPU Auslastung liegt immer zwischen 20 und 50%, je nachdem was gerade an Surveillance so codiert wird...
            Magst du mir mal erklären woher deine Annahme kommt? Ich verstehe die Werte nicht die du da geschrieben hast. 😢
            • ChrizC Chriz
              @djmarc75
              CodierknechtC Offline
              Codierknecht
              Weil man ja auch keine Dampframme nimmt, um einen Nagel in die Wand zu schlagen.
              Der User root hat viel zu viele Rechte. Da hat man schneller was verbogen als einem lieb ist.
              Auf einem vernünftig aufgesetzten System darf root sich nicht mal in der Konsole anmelden.
              HmIP|ZigBee|Tasmota|Unifi
              Zabbix Certified Specialist
              ChrizC HomoranH 2 Antworten Letzte Antwort
              • CodierknechtC Codierknecht
                ChrizC Offline
                ChrizC Offline
                Chriz
                @codierknecht
                okay verstehe.
                Bei mir läuft das alles aber seit Jahren so und da ist nie was "schlimmes" passiert.
                Ich gehe davon aus, das jetzt zu ändern würde zu sehr vielen Anpassungen im System führen.
                Wie gesagt ich wüsste auch nicht mal wie man sowas ändert.
                Als Programmierlaie würde ich erwarten das man beim ersten Systemstart auf sowas hingewiesen wird.
                Vielleicht habt ihr ja ein kleines laienverständliches Tutorial was ich mir bei Gelegenheit mal angucken kann?
                Aber zurück zum Problem, hat noch jemand eine Ahnung was mit dem Adapter sein kann?
                  @codierknecht
                  Installation: Docker
                  ChrizC CodierknechtC 2 Antworten Letzte Antwort
                    @codierknecht
                    ChrizC Offline
                    ChrizC Offline
                    Chriz
                    ich vermute dein Quote bedeutet, das im Dockercontainer alles unter root läuft?
                    Hatte sowas ähnliches im Sinn, aber hab mich nicht getraut das zu erwähnen, da ich da leider zu wenig Ahnung von habe.
                    Aber das mit dem Adapter kann da nicht dran liegen?
                    Ich vermute es hat was mit dem Shelly zu tun das der Adapter nicht grün wird.
                    Er findet halt keine Geräte, obwohl das Log ja zeigt das er "zuhört" (listening)...
                    Kann ich irgendwie überprüfen ob mein Shelly kommuniziert?
                      @codierknecht
                      Codierknecht
                      @homoran sagte in Shelly Adapterinstanz bleibt gelb:
                      Glatt überlesen :-(
                      Ob das unter Docker grundsätzlich so ist, kann ich nicht sagen.
                      Falls das auf einer Synology läuft, hast Du Recht. Da geht das gar nicht anders.
                      @Chriz Welche Hardware läuft da?
                      • ChrizC Chriz
                        Samson71S Offline
                        Samson71S Offline
                        Samson71
                        @chriz
                        Bei Docker bin ich auch weitestgehend raus, aber passen die Ports? Die müssen doch unter Docker ggf. gemappt werden?
                        Für Docker haben wir eigene "Spezialisten". Evtl. können da @Glasfaser oder @Marc-Berg besser weiterhelfen.
                        Markus
                        Bitte beachten:
                        CodierknechtC ChrizC 2 Antworten Letzte Antwort
                        • Samson71S Samson71
                          @chriz
                          Codierknecht
                          @samson71 sagte in Shelly Adapterinstanz bleibt gelb:
                          Betreibe das auf der Synology nur noch für eines meiner Testsysteme.
                          @Chriz
                          Betreibst Du den Container im Bridge-Mode? Wenn ja: Sind die benötigten Ports in den Container durchgereicht?
                            @chriz
                            ChrizC Offline
                            ChrizC Offline
                            Chriz
                            @samson71 said in Shelly Adapterinstanz bleibt gelb:
                            @chriz
                            Samson DU BIST DER BESTE und ich bin so ein Idiot!
                            Ich habe vergessen den Port zu mappen 😠
                            Sorry das ich euch alle bemühen musste, wegen diesem trivialen Thema :(
                              @Chriz
                              ChrizC Offline
                              ChrizC Offline
                              Chriz
                              @codierknecht
                              Samsung hat ja bereits das gleiche geschrieben, das war tatsächlöich das Problem.
                              Ist mir ein wenig peinlich.
                              Am liebsten wäre mir, wir löschen den ganzen Thread 🙄
                              Aber vielleicht vergisst es nochmal der ein oder andere und denkt dann daran.
                              PS: Kann man aus den DIag Infos und Screenshots irgendwas rauslesen, was man besser nicht im Netz stehen haben sollte?
                              Wenn ja, darf ich den inhalt der Diags und die Screenshots löschen, oder spricht da was gegen?
                              • ChrizC Chriz
                                @chriz
                                Codierknecht
                                @chriz
                                Hauptsache, das Problem konnte gelöst werden.
                                Dazu ist ja das Forum da. Und wenn die Diskussion nur dazu dient, den Schubs in die richtige Richtung zu geben.
                                Mein Produktivsystem hatte ich aus genau diesem Grund im Host-Mode betrieben.
                                Solange keine Konflikte bzgl. Ports drohen, ist das wesentlich stressfreier.
                                Ich sehe da nix verfängliches. Lass mal ruhig stehen.
