  3. Einsteigerfragen
  4. Adapter rot umrandet?
    5.5k
24 Beiträge 6 Kommentatoren 1.4k Aufrufe 6 Beobachtet
  • mcm1957M mcm1957
    @wendy2702
    Hab ich eh im ersten Sstz geschrieben. :-)
    sailor_2011
    @mcm57
    Ich bin leider kein Experte, da weiss man manchmal nicht, was man tut :-)
    Im Prinzip läuft alles, bislang war ich immer der Ansicht "do no disturb a running system" - aber die Sonoff-Thermostate hätte ich schon geren eingebunden - ohne mir das ganze System zu zerschießen :-)
    *** BASE SYSTEM ***
       Static hostname: raspberrypi
             Icon name: computer
      Operating System: Raspbian GNU/Linux 10 (buster)
                Kernel: Linux 5.10.103-v7l+
          Architecture: arm
    Model           : Raspberry Pi 4 Model B Rev 1.4
    Docker          : false
    Virtualization  : none
    Kernel          : armv7l
    Userland        : armhf
    Systemuptime and Load:
     12:21:49 up 96 days, 17:44,  1 user,  load average: 0.39, 0.37, 0.44
    CPU threads: 4
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** Time and Time Zones ***
                   Local time: Mon 2024-02-26 12:21:50 CET
               Universal time: Mon 2024-02-26 11:21:50 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:           1.9G        1.2G        194M         30M        483M        662M
    Swap:           99M         99M        0.0K
    Total:         2.0G        1.3G        195M
             1871 M total memory
             1192 M used memory
              411 M active memory
             1162 M inactive memory
              194 M free memory
               82 M buffer memory
              401 M swap cache
               99 M total swap
               99 M used swap
                0 M free swap
    Raspberry only:
    oom events: 0
    *** FAILED SERVICES ***
    0 loaded units listed. Pass --all to see loaded but inactive units, too.
    To show all installed unit files use 'systemctl list-unit-files'.
    *** FILESYSTEM ***
    /dev/root      ext4       59G  3.6G   53G   7% /
    devtmpfs       devtmpfs  775M     0  775M   0% /dev
    tmpfs          tmpfs     936M     0  936M   0% /dev/shm
    tmpfs          tmpfs     936M   64M  873M   7% /run
    tmpfs          tmpfs     936M     0  936M   0% /sys/fs/cgroup
    /dev/sda1      vfat      253M   49M  204M  20% /boot
    tmpfs          tmpfs     188M     0  188M   0% /run/user/1000
    [Tue Nov 21 18:37:19 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=E4:5F:01:1E:BF:C7 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=341e5e98-02 rootfstype=ext4 fsck.repair=yes rootwait
    [Tue Nov 21 18:37:21 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
    [Tue Nov 21 18:37:21 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
    [Tue Nov 21 18:37:23 2023] EXT4-fs (sda2): re-mounted. Opts: (null)
    TARGET        SOURCE    FSTYPE OPTIONS
    /             /dev/sda2 ext4   rw,noatime
    |-/sys/fs/bpf none      bpf    rw,nosuid,nodev,noexec,relatime,mode=700
    `-/boot       /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    322M    /var/
    128M    /var/cache
    123M    /var/cache/apt
    92M     /var/lib
    69M     /var/lib/apt/lists
    Archived and active journals take up 62.7M in the file system.
    /opt/iobroker/backups:
    448M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    269M    /opt/iobroker/iobroker-data/
    201M    /opt/iobroker/iobroker-data/files
    78M     /opt/iobroker/iobroker-data/files/icons-open-icon-library-png
    51M     /opt/iobroker/iobroker-data/files/javascript.admin
    49M     /opt/iobroker/iobroker-data/backup-objects
    17M     /opt/iobroker/iobroker-data/objects.jsonl
    6.9M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/610.de0231c9.chunk.js.map
    6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
    4.9M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/848.7424922d.chunk.js.map
    4.6M    /opt/iobroker/iobroker-data/files/javascript.admin/vs/language/typescript/tsWorker.js
    USB-Devices by-id:
    /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0
    *** NodeJS-Installation ***
    /home/iobroker/.diag.sh: line 277: nodejs: command not found
    /usr/bin/node           v16.19.0
    /usr/bin/npm            8.19.3
    /usr/bin/npx            8.19.3
    /usr/bin/corepack       0.15.1
    /home/iobroker/.diag.sh: line 288: nodejs: command not found
    *** nodejs is NOT correctly installed ***
    nodejs:
      Installed: 16.19.0-deb-1nodesource1
      Candidate: 16.20.2-deb-1nodesource1
      Version table:
         16.20.2-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_16.x buster/main armhf Packages
     *** 16.19.0-deb-1nodesource1 100
         10.24.0~dfsg-1~deb10u3 500
    No problems detected
    Errors in npm tree:
    npm ERR! code ELSPROBLEMS
    npm ERR! invalid: @types/node@14.18.36 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/node
    npm ERR!     /home/pi/.npm/_logs/2024-02-26T11_21_57_808Z-debug-0.log
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  4.0.23
    admin:          6.3.5
    javascript:     6.1.4
    Adapters from github:   1
    Adapter State
    + system.adapter.cloud.0                  : cloud                 : raspberrypi                              -  enabled
    + system.adapter.fb-checkpresence.0       : fb-checkpresence      : raspberrypi                              -  enabled
    + system.adapter.fritzdect.0              : fritzdect             : raspberrypi                              -  enabled
      system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
      system.adapter.icons-icons8.0           : icons-icons8          : raspberrypi                              -  enabled
      system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: raspberrypi                              -  enabled
    + system.adapter.mihome.0                 : mihome                : raspberrypi                              -  enabled, port: 9898, bind: 0.0.0.0
    + system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              -  enabled, port: 1886, bind: 0.0.0.0
    + system.adapter.mqtt.1                   : mqtt                  : raspberrypi                              -  enabled, port: 8883, bind: 0.0.0.0
      system.adapter.netatmo-crawler.0        : netatmo-crawler       : raspberrypi                              -  enabled
    + system.adapter.ping.0                   : ping                  : raspberrypi                              -  enabled
    + system.adapter.pushover.0               : pushover              : raspberrypi                              -  enabled
    + system.adapter.radar2.0                 : radar2                : raspberrypi                              -  enabled
    + system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              -  enabled
    + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.shelly.1                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 192.168.178.21
    + system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              -  enabled
      system.adapter.vis-bars.0               : vis-bars              : raspberrypi                              -  enabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              -  enabled
      system.adapter.vis-metro.0              : vis-metro             : raspberrypi                              -  enabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              -  enabled
    + system.adapter.yeelight-2.0             : yeelight-2            : raspberrypi                              -  enabled
    + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/ttyUSB0
      system.adapter.zigbee2mqtt.0            : zigbee2mqtt           : raspberrypi                              - disabled
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 6.13.16  , installed 6.3.5  [Updatable]
    Adapter    "backitup"     : 2.10.11  , installed 2.8.1  [Updatable]
    Adapter    "cloud"        : 4.4.1    , installed 4.2.1  [Updatable]
    Adapter    "discovery"    : 4.2.0    , installed 3.1.0  [Updatable]
    Adapter    "fb-checkpresence": 1.2.3 , installed 1.1.20 [Updatable]
    Adapter    "fritzdect"    : 2.5.9    , installed 2.3.1  [Updatable]
    Adapter    "ical"         : 1.13.3   , installed 1.13.2 [Updatable]
    Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
    Adapter    "javascript"   : 7.8.0    , installed 6.1.4  [Updatable]
    Controller "js-controller": 5.0.19   , installed 4.0.23 [Updatable]
    Adapter    "mihome"       : 1.4.0    , installed 1.4.0
    Adapter    "mqtt"         : 5.2.0    , installed 4.0.7  [Updatable]
    Adapter    "netatmo-crawler": 0.8.1  , installed 0.8.1
    Adapter    "ping"         : 1.6.2    , installed 1.5.3  [Updatable]
    Adapter    "pushover"     : 3.0.6    , installed 2.0.5  [Updatable]
    Adapter    "radar2"       : 2.1.0    , installed 2.0.3  [Updatable]
    Adapter    "shelly"       : 6.6.1    , installed 6.6.1
    Adapter    "socketio"     : 6.6.0    , installed 4.2.0  [Updatable]
    Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
    Adapter    "trashschedule": 2.3.0    , installed 2.3.0
    Adapter    "vis"          : 1.5.4    , installed 1.4.15 [Updatable]
    Adapter    "vis-hqwidgets": 1.4.0    , installed 1.3.0  [Updatable]
    Adapter    "web"          : 6.2.3    , installed 4.3.0  [Updatable]
    Adapter    "ws"           : 2.5.10   , installed 1.3.0  [Updatable]
    Adapter    "yeelight-2"   : 1.2.1    , installed 1.1.2  [Updatable]
    Adapter    "zigbee"       : 1.10.1   , installed 1.8.23 [Updatable]
    Adapter    "zigbee2mqtt"  : 2.13.4   , installed 2.13.4
    Objects and States
    Objects:        6065
    States:         5112
    Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
    Hit:2 http://archive.raspberrypi.org/debian buster InRelease
    Hit:3 https://deb.nodesource.com/node_16.x buster InRelease
    Reading package lists...
    Pending Updates: 112
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          17550      594/sshd
    tcp        0      0 192.168.178.21:1882     0.0.0.0:*               LISTEN      1001       43812454   5087/io.shelly.1
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       73054069   19612/io.sonoff.0
    tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1001       66740610   21120/io.mqtt.0
    tcp        0      0 0.0.0.0:1887            0.0.0.0:*               LISTEN      1001       66740611   21120/io.mqtt.0
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       16219      588/iobroker.js-con
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       17638      588/iobroker.js-con
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       15206      667/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       21512      1054/io.web.0
    tcp6       0      0 :::22                   :::*                    LISTEN      0          17552      594/sshd
    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       42229772   28958/io.shelly.0
    udp        0      0 0.0.0.0:67              0.0.0.0:*                           1001       3494084    23479/io.radar2.0
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14855      586/dhcpcd
    udp        0      0 0.0.0.0:9898            0.0.0.0:*                           1001       48542939   721/io.mihome.0
    udp        0      0 0.0.0.0:59611           0.0.0.0:*                           108        16515      336/avahi-daemon: r
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        16513      336/avahi-daemon: r
    udp6       0      0 :::546                  :::*                                0          52230902   586/dhcpcd
    udp6       0      0 :::5353                 :::*                                108        16514      336/avahi-daemon: r
    udp6       0      0 :::55601                :::*                                108        16516      336/avahi-daemon: r
    2024-02-26 12:22:34.604  - warn: shelly.0 (28958) [authEnabled] 192.168.178.43 (ShellyBulbDuo / ShellyBulbDuo-8CAAB55F70E3 / SHBDUO-1#8CAAB55F70E3#1): This device is not protected via restricted login (see adapter documentation for details)
    2024-02-26 12:22:36.535  - warn: shelly.0 (28958) [authEnabled] 192.168.178.35 (shellyplug-s / shellyplug-s-6F3F63 / SHPLG-S#6F3F63#1): This device is not protected via restricted login (see adapter documentation for details)
    2024-02-26 12:22:36.664  - warn: shelly.0 (28958) [authEnabled] 192.168.178.75 (shellyplug-s / shellyplug-s-284864 / SHPLG2-1#284864#1): This device is not protected via restricted login (see adapter documentation for details)
    2024-02-26 12:22:39.063  - info: mqtt.1 (23232) Reconnected to localhost
    2024-02-26 12:22:39.065  - error: mqtt.1 (23232) Client error:Error: connect ECONNREFUSED 127.0.0.1:8883
    2024-02-26 12:22:39.066  - info: mqtt.1 (23232) Disconnected from localhost
    2024-02-26 12:22:39.135  - warn: shelly.0 (28958) [authEnabled] 192.168.178.68 (shellyplug-s / shellyplug-s-2CC717 / SHPLG2-1#2CC717#1): This device is not protected via restricted login (see adapter documentation for details)
    2024-02-26 12:22:39.857  - warn: shelly.0 (28958) [authEnabled] 192.168.178.106 (shellyplug-s / shellyplug-s-3CE90ED7C056 / SHPLG-S#3CE90ED7C056#1): This device is not protected via restricted login (see adapter documentation for details)
    2024-02-26 12:22:41.309  - warn: shelly.0 (28958) [authEnabled] 192.168.178.37 (shelly1 / shelly1-BCDDC277BD38 / SHSW-1#BCDDC277BD38#1): This device is not protected via restricted login (see adapter documentation for details)
    2024-02-26 12:22:41.422  - warn: shelly.0 (28958) [authEnabled] 192.168.178.45 (shellyplug-s / shellyplug-s-2842C8 / SHPLG2-1#2842C8#1): This device is not protected via restricted login (see adapter documentation for details)
    2024-02-26 12:22:46.458  - warn: shelly.0 (28958) [authEnabled] 192.168.178.63 (shellyswitch25 / shellyswitch25-98CDAC24B972 / SHSW-25#98CDAC24B972#1): This device is not protected via restricted login (see adapter documentation for details)
    2024-02-26 12:22:47.146  - warn: shelly.0 (28958) [authEnabled] 192.168.178.95 (shellycolorbulb / shellycolorbulb-3494546B07F2 / SHCB-1#3494546B07F2#1): This device is not protected via restricted login (see adapter documentation for details)
    2024-02-26 12:22:49.068  - info: mqtt.1 (23232) Reconnected to localhost
    2024-02-26 12:22:49.070  - error: mqtt.1 (23232) Client error:Error: connect ECONNREFUSED 127.0.0.1:8883
    2024-02-26 12:22:49.070  - info: mqtt.1 (23232) Disconnected from localhost
    2024-02-26 12:22:49.694  - warn: shelly.0 (28958) [authEnabled] 192.168.178.43 (ShellyBulbDuo / ShellyBulbDuo-8CAAB55F70E3 / SHBDUO-1#8CAAB55F70E3#1): This device is not protected via restricted login (see adapter documentation for details)
    2024-02-26 12:22:51.642  - warn: shelly.0 (28958) [authEnabled] 192.168.178.35 (shellyplug-s / shellyplug-s-6F3F63 / SHPLG-S#6F3F63#1): This device is not protected via restricted login (see adapter documentation for details)
    2024-02-26 12:22:51.799  - warn: shelly.0 (28958) [authEnabled] 192.168.178.75 (shellyplug-s / shellyplug-s-284864 / SHPLG2-1#284864#1): This device is not protected via restricted login (see adapter documentation for details)
    2024-02-26 12:22:54.270  - warn: shelly.0 (28958) [authEnabled] 192.168.178.68 (shellyplug-s / shellyplug-s-2CC717 / SHPLG2-1#2CC717#1): This device is not protected via restricted login (see adapter documentation for details)
    2024-02-26 12:22:54.969  - warn: shelly.0 (28958) [authEnabled] 192.168.178.106 (shellyplug-s / shellyplug-s-3CE90ED7C056 / SHPLG-S#3CE90ED7C056#1): This device is not protected via restricted login (see adapter documentation for details)
    2024-02-26 12:22:56.551  - warn: shelly.0 (28958) [authEnabled] 192.168.178.45 (shellyplug-s / shellyplug-s-2842C8 / SHPLG2-1#2842C8#1): This device is not protected via restricted login (see adapter documentation for details)
    2024-02-26 12:22:56.628  - warn: shelly.0 (28958) [authEnabled] 192.168.178.37 (shelly1 / shelly1-BCDDC277BD38 / SHSW-1#BCDDC277BD38#1): This device is not protected via restricted login (see adapter documentation for details)
    2024-02-26 12:22:59.072  - info: mqtt.1 (23232) Reconnected to localhost
    2024-02-26 12:22:59.073  - error: mqtt.1 (23232) Client error:Error: connect ECONNREFUSED 127.0.0.1:8883
    2024-02-26 12:22:59.074  - info: mqtt.1 (23232) Disconnected from localhost
    MOD EDIT: LOG in CODE TAGS
    • S sailor_2011
      @mcm57
      *** BASE SYSTEM ***
               Icon name: computer
            Architecture: arm
      Docker          : false
      Kernel          : armv7l
      Userland        : armhf
      CPU threads: 4
      Current issues:
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      pi
      /home/pi
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Swap:           99M         99M        0.0K
               1871 M total memory
               1192 M used memory
                411 M active memory
                194 M free memory
                 82 M buffer memory
                401 M swap cache
                 99 M total swap
                 99 M used swap
                  0 M free swap
      Raspberry only:
      oom events: 0
      *** FILESYSTEM ***
      /var:
      322M    /var/
      128M    /var/cache
      123M    /var/cache/apt
      92M     /var/lib
      USB-Devices by-id:
      /usr/bin/npm            8.19.3
      /usr/bin/npx            8.19.3
      nodejs:
        Version table:
      Errors in npm tree:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      admin:          6.3.5
      javascript:     6.1.4
      Adapter State
      + instance is alive
      Objects and States
      Objects:        6065
      States:         5112
      @sailor_2011 sagte in Adapter rot umrandet?:
      Falsche Ansicht.
      Bring das Ding in Gänze auf Stand. Buster/Raspberry OS 10 ist abgekündigt.
      Installier da NEU ein Raspberry OS 12 'Bookworm' in der 64Bit-Lite-Version.
      nodejs ist auch veraltet und wird nicht mehr unterstützt. Update auf v18.
      Die ganzen Adapter bringst du auch auf einen aktuellen Stand, inkl. js-controller.
        Falsche Ansicht.
        sailor_2011
        Ok, danke. Das klingt nach ner Menge Arbeit :-)
        • S sailor_2011
          sailor_2011
          @sailor_2011
          Bookworm ist jetzt drauf.
          Aber den Zigbee-Adapter bekomme ich nicht zum Laufen.
          Mit ls -l /dev/serial/by-id habe ich mir die Daten für den com-Anschluss für den Adapter geholt.
          Der Zigbee-Stick ist von Sonoff.
          zigbee.0
          2024-02-26 18:34:21.559 info Installed Version: iobroker.zigbee@1.10.1
          zigbee.0
          2024-02-26 18:34:21.519 error Error herdsman start
          zigbee.0
          2024-02-26 18:34:21.518 error Failed to start Zigbee
          zigbee.0
          2024-02-26 18:34:21.514 error Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_c0501f1070d8ed11a2f76f6162c613ac-if00-port0'"
          Ich werd´hier noch irre - oder bin ich es schon?
          Helft mir bitte mal auf die Sprünge...
          • S sailor_2011
            @sailor_2011
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            Marc BergM Offline
            Marc BergM Offline
            Marc Berg
            Da muss der gesamte Pfad rein:
            /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_c0501f1070d8ed11a2f76f6162c613ac-if00-port0
            S 2 Antworten Letzte Antwort
            • crunchipC Abwesend
              crunchipC Abwesend
              @mcm57 sagte in Adapter rot umrandet?:
              Bist du ev noch auf node 16?
              Ab 1.9.irgendwas ist node 18 erforderlich
              schließ mich hier mal mit an, allerdings
              mario@IoBroker:~$ nodejs -v
              v18.19.1
              • Marc BergM Marc Berg
                sailor_2011
                @marc-berg
                Danke - das hab ich geändert.
                Aber nun kommt dies hier:
                zigbee.0
                2024-02-26 20:03:57.911 error Error herdsman start
                zigbee.0
                2024-02-26 20:03:57.910 error Failed to start Zigbee
                zigbee.0
                2024-02-26 20:03:57.906 error Starting zigbee-herdsman problem : "network commissioning timed out - most likely network with the same panId or extendedPanId already exists nearby"
                zigbee.0
                2024-02-26 20:02:52.122 info Installed Version: iobroker.zigbee@1.10.1
                zigbee.0
                2024-02-26 20:02:51.833 info Starting Zigbee npm ...
                zigbee.0
                2024-02-26 20:02:51.732 info starting. Version 1.10.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.19.1, js-controller: 5.0.19
                Diese PAN ID als auch die Erweiterte PAN ID habe ich geändert - trotzdem bleibt der Adapter "gelb"
                  sailor_2011
                  @marc-berg
                  zigbee.0
                  2024-02-26 20:10:13.055 error Error herdsman start
                  zigbee.0
                  2024-02-26 20:10:13.054 error Failed to start Zigbee
                  zigbee.0
                  2024-02-26 20:10:13.053 error Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
                  • S sailor_2011
                    @mcm57
                    *** BASE SYSTEM ***
                             Icon name: computer
                          Architecture: arm
                    Docker          : false
                    Kernel          : armv7l
                    Userland        : armhf
                    CPU threads: 4
                    Current issues:
                                     RTC time: n/a
                                  NTP service: active
                              RTC in local TZ: no
                    pi
                    /home/pi
                    X-Server:       false
                    Desktop:
                    Terminal:       tty
                    *** MEMORY ***
                    Swap:           99M         99M        0.0K
                             1871 M total memory
                             1192 M used memory
                              411 M active memory
                              194 M free memory
                               82 M buffer memory
                              401 M swap cache
                               99 M total swap
                               99 M used swap
                                0 M free swap
                    Raspberry only:
                    oom events: 0
                    *** FILESYSTEM ***
                    /var:
                    322M    /var/
                    128M    /var/cache
                    123M    /var/cache/apt
                    92M     /var/lib
                    USB-Devices by-id:
                    /usr/bin/npm            8.19.3
                    /usr/bin/npx            8.19.3
                    nodejs:
                      Version table:
                    Errors in npm tree:
                    ioBroker Status
                    Objects type: jsonl
                    States  type: jsonl
                    admin:          6.3.5
                    javascript:     6.1.4
                    Adapter State
                    + instance is alive
                    Objects and States
                    Objects:        6065
                    States:         5112
                    crunchipC Abwesend
                    crunchipC Abwesend
                    zigbee.0
                    verstehe ich irgendwie nicht so ganz
                    S 4 Antworten Letzte Antwort
                      zigbee.0
                      sailor_2011
                      @crunchip
                      Weiss auch nicht, wie es vorhin bei der Installation zu 10.1 kam - hab erst jetrzt gesehen, dass man noch mal updaten konnte - Resultat:
                      Adapter ist G R Ü N :-)
                      Daaaanke euch allen! 👍 👍 👍
                        zigbee.0
                        sailor_2011
                        @crunchip
                        ups - er w a r "Grün" - aber nur kurz
                          zigbee.0
                          sailor_2011
                          @crunchip
                          zigbee.0
                          2024-02-26 20:18:37.564 error Error herdsman start
                          zigbee.0
                          2024-02-26 20:18:37.564 error Failed to start Zigbee
                          zigbee.0
                          2024-02-26 20:18:37.563 error Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
                          zigbee.0
                          2024-02-26 20:18:37.350 info Installed Version: iobroker.zigbee@1.10.2
                          Das ist ein Ding ohne Ende... 😖
                            zigbee.0
                            sailor_2011
                            @crunchip
                            zigbee.0
                            2024-02-26 20:26:42.021 error Error herdsman start
                            zigbee.0
                            2024-02-26 20:26:42.020 error Failed to start Zigbee
                            zigbee.0
                            2024-02-26 20:26:42.019 error Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
                            zigbee.0
                            2024-02-26 20:26:41.818 info Installed Version: iobroker.zigbee@1.10.2
                            zigbee.0
                            2024-02-26 20:26:41.805 info Starting Zigbee npm ...
                            zigbee.0
                            2024-02-26 20:26:41.804 info Try to reconnect. 1 attempts left
                            zigbee.0
                            2024-02-26 20:26:31.800 error Error herdsman start
                            zigbee.0
                            2024-02-26 20:26:31.800 error Failed to start Zigbee
                            zigbee.0
                            2024-02-26 20:26:31.799 error Starting zigbee-herdsman problem : "startup failed - configuration-adapter mismatch - see logs above for more information"
                            zigbee.0
                            2024-02-26 20:26:31.686 error Re-commissioning your network will require re-pairing of all devices!
                            zigbee.0
                            2024-02-26 20:26:31.686 error If you wish to re-commission your network, please remove coordinator backup at /opt/iobroker/iobroker-data/zigbee_0/nvbackup.json.
                            zigbee.0
                            2024-02-26 20:26:31.685 error Please update configuration to prevent further issues.
                            zigbee.0
                            2024-02-26 20:26:31.684 error - Channel List: configured=11, adapter=11
                            zigbee.0
                            2024-02-26 20:26:31.684 error - Network Key: configured=01030507090b0d0f00020406080a0c0d, adapter=01030507090b0d0f00020406080a0c0d
                            zigbee.0
                            2024-02-26 20:26:31.683 error - Extended PAN ID: configured=00124b002c3ae63d, adapter=00124b002c3ae63d
                            zigbee.0
                            2024-02-26 20:26:31.682 error - PAN ID: configured=1419, adapter=1417
                            zigbee.0
                            2024-02-26 20:26:31.681 error Configuration is not consistent with adapter state/backup!
                            If you wish to re-commission your network, please remove coordinator backup at /opt/iobroker/iobroker-data/zigbee_0/nvbackup.json. - das hab ich eben gemacht...
                            Und jetzt... bleibt das Lämpchen auf G R Ü N - meine Güte, was für eine Wissenschaft...
                            Vielen Dank nochmals Euch allen :-)
                            • S sailor_2011
                              @crunchip
                              zigbee.0
                              zigbee.0
                              zigbee.0
                              zigbee.0
                              zigbee.0
                              zigbee.0
                              zigbee.0
                              zigbee.0
                              zigbee.0
                              zigbee.0
                              zigbee.0
                              zigbee.0
                              zigbee.0
                              zigbee.0
                              zigbee.0
                              zigbee.0
                              zigbee.0
                              Die muss übereinstimmen. Also im Adapter entsprechend ändern.
                                sailor_2011
                                Hallo Gemeinde.
                                Ich wollte mich noch mal (abschließend) melden.
                                Hatte noch mal einen neuen Post bez. des Zigbee-Adapters, Adapter war "Grün", trotzdem ließ sich nichts einbinden, auch keine Meldungen im Protololl.
                                Viel (mit eurer Hilfe) ausprobiert, irgendwie führte nichts zum Erfolg.
                                Nun habe ich einen letzten Schritt/Versuch gemacht: Sonoff-Stick zurück gesandt, Conbee bestellt - und nun läuft es - da gab es überhaupt keine Huddelei beim Einbinden, keine Fehlermeldungen, nichts dergleichen.
                                  sailor_2011
                                  Auch die Signalwerte sind bei dem Conbee höher. Bei dem Sonoff-Stick kam es nicht höher, als ca. 125
