  4. Zigbee-Adapter zickt. Flashen lassen oder tauschen?
    5.1k
50 Beiträge 7 Kommentatoren 5.4k Aufrufe 6 Beobachtet
  • D dexic
    @arteck
    iobroker.2024-02-24.log
    Danke für deine Unterstützung!
    arteckA Offline
    arteckA Offline
    arteck
    @dexic von debug Einstellung war nicht die rede...
    also noch mal... und nochmal 50 Zeilen pi mal auge NACH ADAPTER START.. nicht das komplette LOG
    • arteckA arteck
      dexic
      @arteck
      Ich hoffe, das passt jetzt. Sorry für das Missverständnis.
      zigbee.0
      	2024-02-24 09:38:53.568	warn	DeviceAvailability:Failed to ping 0xa4c13872a43d86fd TS011F
      zigbee.0
      	2024-02-24 09:38:53.553	warn	DeviceAvailability:Failed to ping 0xa4c1381cbfd11d66 TS011F
      zigbee.0
      	2024-02-24 09:38:53.537	warn	DeviceAvailability:Failed to ping 0xa4c138867bdf42a2 TS011F
      zigbee.0
      	2024-02-24 09:38:53.520	warn	DeviceAvailability:Failed to ping 0xa4c138de74061d48 TS011F
      zigbee.0
      	2024-02-24 09:38:53.504	warn	DeviceAvailability:Failed to ping 0xa4c1386363b09d42 TS011F
      zigbee.0
      	2024-02-24 09:38:53.488	warn	DeviceAvailability:Failed to ping 0xa4c1389f9914931e TS011F
      zigbee.0
      	2024-02-24 09:38:53.472	warn	DeviceAvailability:Failed to ping 0xa4c138e7c52b7d7f TS011F
      zigbee.0
      	2024-02-24 09:38:53.429	warn	DeviceAvailability:Failed to ping 0xa4c138d046d9d5ae TS011F
      zigbee.0
      	2024-02-24 09:38:47.367	info	debug devices set to []
      zigbee.0
      	2024-02-24 09:38:47.031	info	Zigbee started
      zigbee.0
      	2024-02-24 09:38:47.030	info	0xa4c13872a43d86fd (addr 47187): A1Z - Nous Smart plug (with power monitoring) (Router)
      zigbee.0
      	2024-02-24 09:38:47.027	info	0xa4c1381cbfd11d66 (addr 50830): A1Z - Nous Smart plug (with power monitoring) (Router)
      zigbee.0
      	2024-02-24 09:38:47.024	info	0xa4c138867bdf42a2 (addr 22255): A1Z - Nous Smart plug (with power monitoring) (Router)
      zigbee.0
      	2024-02-24 09:38:47.021	info	0xa4c138de74061d48 (addr 32429): A1Z - Nous Smart plug (with power monitoring) (Router)
      zigbee.0
      	2024-02-24 09:38:47.018	info	0x00158d000949a629 (addr 29713): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
      zigbee.0
      	2024-02-24 09:38:47.016	info	0x00158d0009451e5b (addr 13394): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
      zigbee.0
      	2024-02-24 09:38:47.013	info	0x00158d0008746aee (addr 58357): DJT11LM - Xiaomi Aqara vibration sensor (EndDevice)
      zigbee.0
      	2024-02-24 09:38:47.009	info	0x00158d0008dffe7e (addr 56436): SJCGQ11LM - Xiaomi Aqara water leak sensor (EndDevice)
      zigbee.0
      	2024-02-24 09:38:47.006	info	0x00158d0008d02230 (addr 31821): WXKG11LM - Xiaomi Aqara wireless switch (EndDevice)
      zigbee.0
      	2024-02-24 09:38:47.002	info	0x00158d00094651c7 (addr 29657): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
      zigbee.0
      	2024-02-24 09:38:46.999	info	0x00158d00091b229a (addr 43507): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
      zigbee.0
      	2024-02-24 09:38:46.997	info	0xa4c1386363b09d42 (addr 37503): TS011F_plug_1 - TuYa Smart plug (with power monitoring) (Router)
      zigbee.0
      	2024-02-24 09:38:46.994	info	0xa4c1389f9914931e (addr 51274): TS011F_plug_1 - TuYa Smart plug (with power monitoring) (Router)
      zigbee.0
      	2024-02-24 09:38:46.991	info	0x00158d00094651a4 (addr 60844): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
      zigbee.0
      	2024-02-24 09:38:46.989	info	0x003c84fffed660a9 (addr 62062): BRT-100-TRV - Moes Thermostatic radiator valve (EndDevice)
      zigbee.0
      	2024-02-24 09:38:46.975	info	0xa4c138e7c52b7d7f (addr 38827): TS011F_plug_1 - TuYa Smart plug (with power monitoring) (Router)
      zigbee.0
      	2024-02-24 09:38:46.967	info	0xa4c138d046d9d5ae (addr 102): TS011F_plug_1 - TuYa Smart plug (with power monitoring) (Router)
      zigbee.0
      	2024-02-24 09:38:46.888	info	Currently 17 devices are joined:
      zigbee.0
      	2024-02-24 09:38:46.869	info	--> transmitPower : high+
      zigbee.0
      	2024-02-24 09:38:46.848	info	Unable to disable LED, unsupported function.
      zigbee.0
      	2024-02-24 09:38:46.831	info	Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20221226}}
      zigbee.0
      	2024-02-24 09:38:42.086	info	Installed Version: iobroker.zigbee@1.10.1
      zigbee.0
      	2024-02-24 09:38:41.795	info	Starting Zigbee npm ...
      zigbee.0
      	2024-02-24 09:38:41.793	info	delete old Backup files. keep only last 10
      zigbee.0
      	2024-02-24 09:38:41.693	info	starting. Version 1.10.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.19.0, js-controller: 5.0.19
      host.raspberrypi
      	2024-02-24 09:38:37.278	info	instance system.adapter.zigbee.0 started with pid 5548
      host.raspberrypi
      	2024-02-24 09:38:37.234	info	"system.adapter.zigbee.0" enabled
      host.raspberrypi
      	2024-02-24 09:38:34.825	info	instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      zigbee.0
      	2024-02-24 09:38:34.250	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      zigbee.0
      	2024-02-24 09:38:34.248	info	terminating
      host.raspberrypi
      	2024-02-24 09:38:33.830	info	stopInstance system.adapter.zigbee.0 send kill signal
      zigbee.0
      	2024-02-24 09:38:33.751	info	Zigbee: disabling joining new devices.
      zigbee.0
      	2024-02-24 09:38:33.747	info	cleaned everything up...
      zigbee.0
      	2024-02-24 09:38:33.744	info	Got terminate signal TERMINATE_YOURSELF
      host.raspberrypi
      	2024-02-24 09:38:33.732	info	stopInstance system.adapter.zigbee.0 (force=false, process=true)
      • D dexic
        @arteck
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        host.raspberrypi
        host.raspberrypi
        host.raspberrypi
        zigbee.0
        zigbee.0
        host.raspberrypi
        zigbee.0
        zigbee.0
        zigbee.0
        host.raspberrypi
        arteckA Offline
        arteckA Offline
        arteck
        @dexic sagte in Zigbee-Adapter zickt. Flashen lassen oder tauschen?:
        TS011F
        sieht doch gut aus...
        musst nur die
        neu anlernen
        • arteckA arteck
          TS011F
          musst nur die
          neu anlernen
          dexic
          schrieb am zuletzt editiert von dexic
          @arteck
          Das sieht bei mir auf dem Schirm anders aus ...
          Und wenn ich es dann versuche:
          • D dexic
            @arteck
            arteckA Offline
            arteckA Offline
            arteck
            @dexic mach erstmal.. wenn die Router im netz sind kann sein dass der rest dann von sich aus rein kommt.
            machmal bitte
            https://github.com/ioBroker/ioBroker.zigbee/wiki/GIT-install
            und schau nochmal.. kein plan warum der pairing modus nicht startet
            • arteckA arteck
              machmal bitte
              dexic
              @arteck said in Zigbee-Adapter zickt. Flashen lassen oder tauschen?:
              Den USB-Adapter habe ich am RPi schon getauscht. Jetzt kommt beim Einschalten des Kopplungsmodus dieser komische Fehler im Schirm.
              GIT-Install habe ich durchgeführt mit exit code = 0, also problemlos. Das ist das Ergebnis:
              Leider bleiben die Geräte alle weiterhin unverbunden. Das Protokoll sagt jetzt:
              zigbee.0
              	2024-02-24 11:03:40.839	warn	DeviceAvailability:Failed to ping 0xa4c13872a43d86fd TS011F
              zigbee.0
              	2024-02-24 11:03:40.820	warn	DeviceAvailability:Failed to ping 0xa4c1381cbfd11d66 TS011F
              zigbee.0
              	2024-02-24 11:03:40.805	warn	DeviceAvailability:Failed to ping 0xa4c138867bdf42a2 TS011F
              zigbee.0
              	2024-02-24 11:03:40.789	warn	DeviceAvailability:Failed to ping 0xa4c138de74061d48 TS011F
              zigbee.0
              	2024-02-24 11:03:40.753	warn	DeviceAvailability:Failed to ping 0xa4c1386363b09d42 TS011F
              zigbee.0
              	2024-02-24 11:03:40.734	warn	DeviceAvailability:Failed to ping 0xa4c1389f9914931e TS011F
              zigbee.0
              	2024-02-24 11:03:40.718	warn	DeviceAvailability:Failed to ping 0xa4c138e7c52b7d7f TS011F
              zigbee.0
              	2024-02-24 11:03:40.702	warn	DeviceAvailability:Failed to ping 0xa4c138d046d9d5ae TS011F
              zigbee.0
              	2024-02-24 11:03:34.022	info	debug devices set to []
              zigbee.0
              	2024-02-24 11:03:33.886	info	Zigbee started
              zigbee.0
              	2024-02-24 11:03:33.885	info	0xa4c13872a43d86fd (addr 47187): A1Z - Nous Smart plug (with power monitoring) (Router)
              zigbee.0
              	2024-02-24 11:03:33.883	info	0xa4c1381cbfd11d66 (addr 50830): A1Z - Nous Smart plug (with power monitoring) (Router)
              zigbee.0
              	2024-02-24 11:03:33.880	info	0xa4c138867bdf42a2 (addr 22255): A1Z - Nous Smart plug (with power monitoring) (Router)
              zigbee.0
              	2024-02-24 11:03:33.877	info	0xa4c138de74061d48 (addr 32429): A1Z - Nous Smart plug (with power monitoring) (Router)
              zigbee.0
              	2024-02-24 11:03:33.873	info	0x00158d000949a629 (addr 29713): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
              zigbee.0
              	2024-02-24 11:03:33.871	info	0x00158d0009451e5b (addr 13394): WSDCGQ11LM - Aqara Temperature and humidity sensor (EndDevice)
              zigbee.0
              	2024-02-24 11:03:33.868	info	0x00158d0008746aee (addr 58357): DJT11LM - Aqara Vibration sensor (EndDevice)
              zigbee.0
              	2024-02-24 11:03:33.865	info	0x00158d0008dffe7e (addr 56436): SJCGQ11LM - Aqara Water leak sensor (EndDevice)
              zigbee.0
              	2024-02-24 11:03:33.861	info	0x00158d0008d02230 (addr 31821): WXKG11LM - Aqara Wireless mini switch (EndDevice)
              zigbee.0
              	2024-02-24 11:03:33.857	info	0x00158d00094651c7 (addr 29657): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
              zigbee.0
              	2024-02-24 11:03:33.855	info	0x00158d00091b229a (addr 43507): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
              zigbee.0
              	2024-02-24 11:03:33.852	info	0xa4c1386363b09d42 (addr 37503): TS011F_plug_1 - TuYa Smart plug (with power monitoring) (Router)
              zigbee.0
              	2024-02-24 11:03:33.850	info	0xa4c1389f9914931e (addr 51274): TS011F_plug_1 - TuYa Smart plug (with power monitoring) (Router)
              zigbee.0
              	2024-02-24 11:03:33.847	info	0x00158d00094651a4 (addr 60844): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
              zigbee.0
              	2024-02-24 11:03:33.844	info	0x003c84fffed660a9 (addr 62062): BRT-100-TRV - Moes Thermostatic radiator valve (EndDevice)
              zigbee.0
              	2024-02-24 11:03:33.830	info	0xa4c138e7c52b7d7f (addr 38827): TS011F_plug_1 - TuYa Smart plug (with power monitoring) (Router)
              zigbee.0
              	2024-02-24 11:03:33.822	info	0xa4c138d046d9d5ae (addr 102): TS011F_plug_1 - TuYa Smart plug (with power monitoring) (Router)
              zigbee.0
              	2024-02-24 11:03:33.742	info	Currently 17 devices are joined:
              zigbee.0
              	2024-02-24 11:03:33.718	info	--> transmitPower : high+
              zigbee.0
              	2024-02-24 11:03:33.693	info	Unable to disable LED, unsupported function.
              zigbee.0
              	2024-02-24 11:03:33.669	info	Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20221226}}
              zigbee.0
              	2024-02-24 11:03:29.107	info	Installed Version: ioBroker/ioBroker.zigbee#789c70c588651e4a06ba495ddf572adb8d9a1b7c
              zigbee.0
              	2024-02-24 11:03:28.741	info	Starting Zigbee npm ...
              zigbee.0
              	2024-02-24 11:03:28.739	info	delete old Backup files. keep only last 10
              zigbee.0
              	2024-02-24 11:03:28.637	info	starting. Version 1.10.2 (non-npm: ioBroker/ioBroker.zigbee#789c70c588651e4a06ba495ddf572adb8d9a1b7c) in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.19.0, js-controller: 5.0.19
              host.raspberrypi
              	2024-02-24 11:03:23.952	info	instance system.adapter.zigbee.0 started with pid 5990
              host.raspberrypi
              	2024-02-24 11:03:23.876	info	"system.adapter.zigbee.0" enabled
              host.raspberrypi
              	2024-02-24 11:03:22.208	info	instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
              • D dexic
                zigbee.0
                zigbee.0
                zigbee.0
                zigbee.0
                zigbee.0
                zigbee.0
                zigbee.0
                zigbee.0
                zigbee.0
                zigbee.0
                zigbee.0
                zigbee.0
                zigbee.0
                zigbee.0
                zigbee.0
                zigbee.0
                zigbee.0
                zigbee.0
                zigbee.0
                zigbee.0
                zigbee.0
                zigbee.0
                zigbee.0
                zigbee.0
                zigbee.0
                zigbee.0
                zigbee.0
                zigbee.0
                zigbee.0
                zigbee.0
                zigbee.0
                zigbee.0
                zigbee.0
                zigbee.0
                zigbee.0
                host.raspberrypi
                host.raspberrypi
                host.raspberrypi
                arteckA Offline
                arteckA Offline
                arteck
                @dexic kannst du jetzt das pairing starten ?
                • arteckA arteck
                  dexic
                  @arteck
                  Nein, noch immer nicht. :-( Ich bin ratlos...
                  D arteckA 2 Antworten Letzte Antwort
                  • D dexic
                    @arteck
                    dexic
                    @dexic
                    Soll ich mal einen Sonoff testen?
                      Warum "definitiv" tauschen?
                      Weil der Chipsatz veraltet ist und auch arg limitiert.
                      GarganoG Offline
                      GarganoG Offline
                      Gargano
                      Was ist denn ein brauchbarer Zigbee Stick ? (CC2652P, Sonoff...?)
                      • D dexic
                        @arteck
                        arteckA Offline
                        arteckA Offline
                        arteck
                        @dexic poste mal den fehler ..nachdem du auf pairing gedrückt hast
                        • arteckA arteck
                          dexic
                          @arteck
                          Das passiert mit dem CC2652P, den ich als Ersatz für den 2531 genommen habe. Den Sonoff habe ich noch nicht ausprobiert.
                          Error: Failed to open the network: Error: SREQ '--> ZDO - mgmtPermitJoinReq - {"addrmode":15,"dstaddr":65532,"duration":254,"tcsignificance":0}' failed with status '(0xc2: NWK_INVALID_REQUEST)' (expected '(0x00: SUCCESS)')
                              at /opt/iobroker/node_modules/zigbee-herdsman/src/adapter/z-stack/znp/znp.ts:320:27
                              at Queue.execute (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/queue.ts:35:20)
                              at /opt/iobroker/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:206:13
                              at ZStackAdapter.permitJoin (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:203:9)
                              at Controller.permitJoinInternal (/opt/iobroker/node_modules/zigbee-herdsman/src/controller/controller.ts:246:13)
                              at Controller.permitJoin (/opt/iobroker/node_modules/zigbee-herdsman/src/controller/controller.ts:234:9)
                              at ZigbeeController.permitJoin (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:521:17). undefined
                          Pairing started
                          • D dexic
                            @arteck
                            Pairing started
                            arteckA Offline
                            arteckA Offline
                            arteck
                            @dexic installier nochmal von GIT
                            • arteckA arteck
                              dexic
                              @arteck
                              Kurzer Kommentar: Der Fehler war vor und nach der Installation von GIT der gleiche. Ich wiederhole jetzt die Installation und prüfe dann die Fehlermeldung.
                              1. Installation von GIT
                                Exit code 0
                              2. Neustart des RPi
                                Laut Protokoll konnten nur die TS011F Steckdosen nicht angepingt werden
                              3. Prüfung der Fehlermeldung beim Koppeln
                                Die gleiche Fehlermeldung wie sonst auch.
                              Ich werde morgen mal den Sonoff auspacken und testen.
                                dexic
                                So, Zwischenstand. Der Sonoff 3.0 scheint halbwegs durchzukommen. Ich bekomme Stück um Stück immer mehr alte Verbindungen erneuert. Mal sehen, ob morgen noch mehr Verbindungen dazu kommen, dann lasse ich es weiterlaufen.
                                  dexic
                                  Liebe Gemeinde,
                                  wie gehe ich jetzt mit den letzten vier Zigbee-Geräten um, die sich noch nicht ans Netz gehängt haben? Den Außentemperatursensor (https://www.zigbee2mqtt.io/devices/WSDCGQ11LM.html) ich in den Kopplungsmodus gebracht (Taste lange halten, blaue LED blinkt) und das Pairing gestartet, jedoch ohne Erfolg. Direkt ein Stockwerk unten drunter sind zwei Zigbee-Steckdosen, die die Verbindung herstellen sollten, oder denke ich da falsch? Muss ich mit den Geräten zurück zum RasPi und dort neu koppeln? Was ist in so einem Fall die empfohlene Vorgehensweise?
                                  Vielen Dank! :-)
                                  • D dexic
                                    Liebe Gemeinde,
                                    Vielen Dank! :-)
                                    arteckA Offline
                                    arteckA Offline
                                    arteck
                                    @dexic welche Steckdosen sind das.. und sind die schon im Netz ??
                                      dexic
                                      Nachdem mir bis gestern niemand geantwortet hat, habe ich die Geräte in der Nähe des RasPi einfach aus Trotz und mangels besserer Lösung in den Kopplungsmodus versetzt und es hat dann schlussendlich doch geklappt, sie zu verbinden. Der Außentemperatursensor nervte, daher habe ich ihn jetzt in die Nähe der Steckdose gelegt, die später im Stockwerk direkt unter ihm sein wird. Ich gehe davon aus, dass diese Verbindung nachher funktionieren sollte, wenn sie sich "kennen".
                                      Danke allen für die Ratschläge und Einsichten!
                                      • arteckA arteck
                                        dexic
                                        @arteck A1Z und ja, sie waren schon im Netz. https://www.zigbee2mqtt.io/devices/A1Z.html
                                        • R Offline
                                          RikDRS
                                          Guten Morgen zusammen!
                                          Ich habe ein ähnliches / selbe Problem. Habe gestern zwei Steckdosen neu angelernt, dieses ohne Probleme. Heute war eine Steckdose nicht mehr erreichbar. Habe verschiedene Varianten ausprobiert um sie neu zu koppeln bzw die Verbindung wieder herzustellen - nun bekomme ich bei einem erneuten Koppelversuch diese Fehlermeldung:
                                          Error: Failed to open the network: Error: SREQ '--> AF - dataRequestExt - {"dstaddrmode":2,"dstaddr":"0x000000000000fffd","destendpoint":242,"dstpanid":0,"srcendpoint":242,"clusterid":33,"transid":11,"options":0,"radius":30,"len":6,"data":{"type":"Buffer","data":[25,8,2,11,254,0]}}' failed with status '(0x10: MEM_ERROR)' (expected '(0x00: SUCCESS)')
                                              at ZStackAdapter.dataRequestExtended (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:997:9)
                                              at /opt/iobroker/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:557:13
                                              at GreenPower.permitJoin (/opt/iobroker/node_modules/zigbee-herdsman/src/controller/greenPower.ts:237:13)
                                              at Controller.permitJoinInternal (/opt/iobroker/node_modules/zigbee-herdsman/src/controller/controller.ts:247:13)
                                              at ZigbeeController.permitJoin (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:525:17). undefined
                                          Pairing started
                                          Meldung tritt sowohl bei Version 1.10.1 als auch 1.10.2 auf
                                          Die Steckdose welche die Verbindung verloren hat wird unter meinen Objekten nicht mehr angezeigt. Aktiv gelöscht habe ich diese aber nicht.
                                          Irgendwelche Tips zur Behebung dieses Problems?
