  4. Teilweise über 200% CPU Auslastung im Docker
21 Beiträge 5 Kommentatoren 1.3k Aufrufe 5 Beobachtet
  • DJMarc75D DJMarc75
    @dr-pie sagte in Teilweise über 200% CPU Auslastung im Docker:
    iob diag läuft schon
    und die Ausgabe in Codetags wäre interessant zu sehen ;)
    Dr.PieD Offline
    Dr.PieD Offline
    Dr.Pie
    @djmarc75 ```
    Copy text starting here:
                            v.2023-10-10
    model name      : Intel(R) Celeron(R) CPU J3455 @ 1.50GHz
    Kernel          : x86_64
    Userland        : amd64
    Docker          : v8.0.1
    Installation:           Docker
    Kernel:                 x86_64
    Userland:               amd64
    Timezone:               Etc/UTC
    User-ID:                0
    X-Server:               false
    Pending OS-Updates:     28
    /opt/iobroker/node_modules/standard-as-callback/built/index.js:6
            throw e;
    Error: Connection is closed.
        at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25)
        at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20)
        at Object.onceWrapper (node:events:629:26)
        at Socket.emit (node:events:514:28)
        at TCP.<anonymous> (node:net:323:12)
    Emitted 'error' event on ScanStream instance at:
        at /opt/iobroker/node_modules/ioredis/built/ScanStream.js:38:22
        at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:12:23)
        at /opt/iobroker/node_modules/standard-as-callback/built/index.js:33:51
        at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
    Node.js v18.17.1
    Pending iob updates:    0
    Nodejs-Installation:    /usr/bin/nodejs         v18.17.1
                            /usr/bin/node           v18.17.1
                            /usr/bin/npm            9.6.7
                            /usr/bin/npx            9.6.7
                            /usr/bin/corepack       0.18.0
    Recommended versions are nodejs 18.19.1 and npm 10.2.4
    MEMORY:
    Mem:            7.8G        5.4G        539M        119M        1.9G        2.0G
    Swap:           6.7G         34M        6.7G
    Total:           14G        5.4G        7.2G
    Uncaught Rejection: Error: Objects DB is not allowed to start in the current Multihost environment
        at Redis.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-objects-redis/build/lib/objects/objectsInRedisClient.js:493:23)
    Active iob-Instances:   0
     Unable to subscribe to meta namespace "meta." changes: Connection is closed.
    ioBroker Core:          js-controller           5.0.17
                            admin                   6.13.16
    ioBroker Status:         Connection is closed.
     Unable to subscribe to evicted Keyspace events from Redis Server: Connection is closed.
    Objects:                0
    States:                 0
    Size of iob-Database:
    26M     /opt/iobroker/iobroker-data/objects.jsonl
    4.5M    /opt/iobroker/iobroker-data/states.jsonl
    Die lange Version ginge natürlich auch ... hab ich aber verpasst 😊
    • Dr.PieD Dr.Pie
      @djmarc75 ```
                              v.2023-10-10
      Kernel          : x86_64
      Userland        : amd64
      Docker          : v8.0.1
      Kernel:                 x86_64
      Userland:               amd64
      Timezone:               Etc/UTC
      User-ID:                0
      X-Server:               false
              throw e;
      Node.js v18.17.1
                              /usr/bin/npm            9.6.7
                              /usr/bin/npx            9.6.7
      MEMORY:
      Swap:           6.7G         34M        6.7G
                              admin                   6.13.16
      Objects:                0
      States:                 0
      DJMarc75D Offline
      DJMarc75D Offline
      DJMarc75
      und die wäre schön zu sehen ;)
      Mach halt nochmal - und am Ende keine Taste drücken
      Lehrling seit 1975 !!!
      Dr.PieD 1 Antwort Letzte Antwort
      • Dr.PieD Dr.Pie
        @djmarc75 sagte in Teilweise über 200% CPU Auslastung im Docker:
        @dr-pie Sind da Skripte im Amokmodus ?
        Zeige bitte
        iob diag
        Das ist eine gute Frage. iob diag läuft schon 👍
        @codierknecht sagte in Teilweise über 200% CPU Auslastung im Docker:
        @dr-pie
        Zusätzlich zu dem was @DJMarc75 schreibt:
        Was ist das für eine Synology?
        Wie ist die ausgestattet? Was läuft da sonst noch?
        Hier die Daten:
        DSM 7.2.1-69057 Update 3
        DS1019+
        INTEL Celeron J3455
        1.5 GHz
        @oliverio sagte in Teilweise über 200% CPU Auslastung im Docker:
        @dr-pie
        Schaue einmal in den Container mit top, welche Prozesse da mit Volllast laufen.
        Wie komme ich dort hin ?
        OliverIOO Offline
        OliverIOO Offline
        OliverIO
        @dr-pie
        Du kannst top auch auf der console aufrufen.
        Also dort wo du auch iob diag eingegeben hast
        Meine Adapter und Widgets
        Links im Profil
        • OliverIOO OliverIO
          @dr-pie
          Dr.PieD Offline
          Dr.PieD Offline
          Dr.Pie
          @dr-pie
          top - 15:47:27 up 20:46,  0 users,  load average: 2,47, 2,94, 2,96
          Tasks:  25 total,   2 running,  23 sleeping,   0 stopped,   0 zombie
          %Cpu(s): 51,3 us,  5,0 sy,  0,0 ni, 42,9 id,  0,0 wa,  0,0 hi,  0,8 si,  0,0 st
          MiB Mem :   7802,0 total,    408,3 free,   5502,6 used,   1891,1 buff/cache
          MiB Swap:   6731,9 total,   6697,0 free,     34,9 used.   1883,2 avail Mem
            PID USER      PR  NI    VIRT    RES    SHR S  %CPU  %MEM     TIME+ COMMAND
            174 iobroker  20   0   11,6g 804244  46096 R  96,3  10,1   1261:46 iobroker.js-con
            679 iobroker  20   0 1944184   1,1g  40092 S  94,0  14,8 717:46.89 io.device-watch
            450 iobroker  20   0 1718048 887868  39948 S   9,3  11,1 156:07.51 io.shelly.1
            366 iobroker  20   0 1002892 147496  39836 S   8,0   1,8  52:05.24 io.shelly.0
            224 iobroker  20   0 1184844 346172  45832 S   3,7   4,3  53:28.79 io.javascript.0
            262 iobroker  20   0  967956 113200  39712 S   1,7   1,4  21:30.92 io.influxdb.0
            196 iobroker  20   0 1089088 215252  46868 S   0,7   2,7  10:16.87 iobroker.js-con
          29287 iobroker  20   0  948668  85048  45784 S   0,7   1,1   0:05.22 io.fullybrowser
            243 iobroker  20   0  991452 104484  38776 S   0,3   1,3   4:07.28 io.sql.0
            492 iobroker  20   0   20,9g 104416  46372 S   0,3   1,3   0:37.12 io.backitup.0
            565 iobroker  20   0  955132  89356  39968 S   0,3   1,1   2:52.76 io.denon.0
            610 iobroker  20   0   10,9g 108868  39816 S   0,3   1,4   6:46.13 io.heos.0
            668 iobroker  20   0   10,9g 122508  40756 S   0,3   1,5   9:36.75 io.fb-checkpres
              1 root      20   0    7364   3120   3120 S   0,0   0,0   0:00.04 bash
            381 iobroker  20   0   10,9g 103092  40088 S   0,0   1,3   1:24.17 io.synology.1
            392 iobroker  20   0   10,9g 102880  40320 S   0,0   1,3   1:26.84 io.synology.2
            407 iobroker  20   0  831736 103904  45672 S   0,0   1,3   7:35.23 io.tr-064.0
            435 iobroker  20   0  832248 106664  45752 S   0,0   1,3  19:54.27 io.tr-064.1
            465 iobroker  20   0  821636  82804  39872 S   0,0   1,0   0:34.42 io.discovery.0
            507 iobroker  20   0 1024264 164200  40988 S   0,0   2,1   8:10.61 io.web.0
            595 iobroker  20   0  960016  84900  39880 S   0,0   1,1   0:51.34 io.harmony.0
            634 iobroker  20   0 1088292 235916  40952 S   0,0   3,0   1:17.81 io.tankerkoenig
            653 iobroker  20   0  971976 116388  45876 S   0,0   1,5   1:43.31 io.wled.0
          32314 root      20   0    7496   3840   3408 S   0,0   0,0   0:00.00 bash
          32329 root      20   0   10296   3584   3112 R   0,0   0,0   0:00.03 top
            Dr.PieD Offline
            Dr.PieD Offline
            Dr.Pie
            Skript v.2023-10-10
            *** BASE SYSTEM ***
            Hardware Vendor : Synology
            Kernel          : x86_64
            Userland        : amd64
            Docker          : v8.0.1
            Virtualization  : Docker
            Kernel          : x86_64
            Userland        : amd64
            Systemuptime and Load:
             15:50:36 up 20:49,  0 users,  load average: 3.28, 3.01, 2.98
            CPU threads: 4
            *** Time and Time Zones ***
            Thu Feb 22 14:50:36 UTC 2024
            Thu Feb 22 15:50:36 CET 2024
            CET +0100
            Etc/UTC
            *** User and Groups ***
            root
            /root
            root
            *** X-Server-Setup ***
            X-Server:       false
            Desktop:
            Terminal:
            *** MEMORY ***
            Mem:            7.8G        5.3G        590M        120M        1.9G        2.1G
            Swap:           6.7G         34M        6.7G
            Total:           14G        5.4G        7.3G
                     7802 M total memory
                     5319 M used memory
                     4777 M active memory
                     1528 M inactive memory
                      590 M free memory
                       38 M buffer memory
                     1854 M swap cache
                     6731 M total swap
                       34 M used swap
                     6697 M free swap
            *** FILESYSTEM ***
            Filesystem             Type   Size  Used Avail Use% Mounted on
            /dev/mapper/cachedev_4 btrfs  3.5T  2.0T  1.6T  56% /
            tmpfs                  tmpfs   64M     0   64M   0% /dev
            tmpfs                  tmpfs  3.9G     0  3.9G   0% /sys/fs/cgroup
            shm                    tmpfs   64M     0   64M   0% /dev/shm
            /dev/mapper/cachedev_4 btrfs  3.5T  2.0T  1.6T  56% /opt/iobroker
            /dev/mapper/cachedev_4 btrfs  3.5T  2.0T  1.6T  56% /etc/hosts
            tmpfs                  tmpfs  3.9G     0  3.9G   0% /proc/acpi
            tmpfs                  tmpfs  3.9G     0  3.9G   0% /proc/scsi
            tmpfs                  tmpfs  3.9G     0  3.9G   0% /sys/firmware
            sudo: unable to resolve host iobroker: Name or service not known
            [Wed Feb 21 19:01:19 2024] EXT4-fs (md0): couldn't mount as ext3 due to feature incompatibilities
            [Wed Feb 21 19:01:19 2024] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts: (null)
            [Wed Feb 21 19:01:19 2024] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts: barrier=1
            [Wed Feb 21 19:01:25 2024] EXT4-fs (md0): couldn't mount as ext3 due to feature incompatibilities
            [Wed Feb 21 19:01:25 2024] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts: (null)
            [Wed Feb 21 19:01:25 2024] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts: barrier=1
            TARGET             SOURCE        FSTYPE OPTIONS
            /                  /dev/mapper/cachedev_4[/@syno/@docker/btrfs/subvolumes/2082bc39f93f33f788e3c7fa290317a1b738ac8cf85a4217a83d22a38aceec36]       btrfs  rw,nodev,relatime,relatime_period=30,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,syno_allocator,subvolid=724572,subvol=/@syno/@docker/btrfs/subvolumes/2082bc39f93f33f788e3c7fa290317a1b738ac8cf85a4217a83d22a38aceec36
            |-/opt/iobroker    /dev/mapper/cachedev_4[/@syno/docker/iobroker]        btrfs  rw,nodev,relatime,relatime_period=30,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,syno_allocator,subvolid=724400,subvol=/@syno/docker
            |-/etc/resolv.conf /dev/mapper/cachedev_4[/@syno/@docker/containers/0450185fc3ce5afab5101aa2eabbba0a1f80981592975fc06d13c4fc7271dbd6/resolv.conf] btrfs  rw,nodev,relatime,relatime_period=30,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,syno_allocator,subvolid=257,subvol=/@syno
            |-/etc/hostname    /dev/mapper/cachedev_4[/@syno/@docker/containers/0450185fc3ce5afab5101aa2eabbba0a1f80981592975fc06d13c4fc7271dbd6/hostname]    btrfs  rw,nodev,relatime,relatime_period=30,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,syno_allocator,subvolid=257,subvol=/@syno
            `-/etc/hosts       /dev/mapper/cachedev_4[/@syno/@docker/containers/0450185fc3ce5afab5101aa2eabbba0a1f80981592975fc06d13c4fc7271dbd6/hosts]       btrfs  rw,nodev,relatime,relatime_period=30,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,syno_allocator,subvolid=257,subvol=/@syno
            /var:
            33M     /var/
            31M     /var/lib
            18M     /var/lib/apt/lists
            18M     /var/lib/apt
            13M     /var/lib/dpkg
            /opt/iobroker/backups:
            3.2G    /opt/iobroker/backups/
            /opt/iobroker/iobroker-data:
            498M    /opt/iobroker/iobroker-data/
            363M    /opt/iobroker/iobroker-data/files
            137M    /opt/iobroker/iobroker-data/files/vis-2
            94M     /opt/iobroker/iobroker-data/backup-objects
            78M     /opt/iobroker/iobroker-data/files/vis-2/static
            22M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.c05ba1d3.js.map
            18M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.e642d05b.js.map
            18M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.2b7aff38.js.map
            18M     /opt/iobroker/iobroker-data/files/vis-2/customWidgets.js.map
            USB-Devices by-id:
            find: '/dev/serial/by-id/': No such file or directory
            *** NodeJS-Installation ***
            /usr/bin/npm            9.6.7
            /usr/bin/npx            9.6.7
            nodejs:
              Installed: 18.17.1-deb-1nodesource1
              Candidate: 18.17.1-deb-1nodesource1
              Version table:
             *** 18.17.1-deb-1nodesource1 500
                    500 https://deb.nodesource.com/node_18.x bullseye/main amd64 Packages
                 12.22.12~dfsg-1~deb11u4 500
                    500 http://deb.debian.org/debian bullseye/main amd64 Packages
                    500 http://deb.debian.org/debian-security bullseye-security/main amd64 Packages
            No problems detected
            Errors in npm tree:
            *** ioBroker-Installation ***
            ioBroker Status
             Cannot determine Lua scripts strategy: Connection is closed. ["cfg.o.system.host.iobroker"]
            No connection to databases possible ...
            Core adapters versions
            js-controller:  5.0.17
            admin:          6.13.16
            javascript:     7.8.0
            Adapters from github:   3
            Adapter State
                    throw e;
            Node.js v18.17.1
            ioBroker-Repositories
                    throw e;
            Node.js v18.17.1
            Installed ioBroker-Instances
            Objects and States
            Objects:        3
            States:         3
            Hit:1 http://deb.debian.org/debian bullseye InRelease
            Hit:2 http://deb.debian.org/debian-security bullseye-security InRelease
            Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
            Hit:4 https://deb.nodesource.com/node_18.x bullseye InRelease
            Reading package lists...
            Pending Updates: 28
            *** Listening Ports ***
            tcp        0      0 192.168.178.203:8081    0.0.0.0:*               LISTEN      1000       134867     -
            tcp        0      0 127.0.0.1:32401         0.0.0.0:*               LISTEN      297536     82661      -
            tcp        0      0 192.168.178.203:8082    0.0.0.0:*               LISTEN      1000       145247     -
            tcp        0      0 172.17.0.1:53           0.0.0.0:*               LISTEN      115492     103340     -
            tcp        0      0 172.17.0.1:53           0.0.0.0:*               LISTEN      115492     103339     -
            tcp        0      0 172.17.0.1:53           0.0.0.0:*               LISTEN      115492     103338     -
            tcp        0      0 172.17.0.1:53           0.0.0.0:*               LISTEN      115492     103337     -
            tcp        0      0 169.254.241.18:53       0.0.0.0:*               LISTEN      115492     76525      -
            tcp        0      0 169.254.241.18:53       0.0.0.0:*               LISTEN      115492     76524      -
            tcp        0      0 169.254.241.18:53       0.0.0.0:*               LISTEN      115492     76523      -
            tcp        0      0 169.254.241.18:53       0.0.0.0:*               LISTEN      115492     76522      -
            tcp        0      0 192.168.178.203:53      0.0.0.0:*               LISTEN      115492     76517      -
            tcp        0      0 192.168.178.203:53      0.0.0.0:*               LISTEN      115492     76516      -
            tcp        0      0 192.168.178.203:53      0.0.0.0:*               LISTEN      115492     76515      -
            tcp        0      0 192.168.178.203:53      0.0.0.0:*               LISTEN      115492     76514      -
            tcp        0      0 127.0.0.1:53            0.0.0.0:*               LISTEN      115492     78686      -
            tcp        0      0 127.0.0.1:53            0.0.0.0:*               LISTEN      115492     78688      -
            tcp        0      0 127.0.0.1:53            0.0.0.0:*               LISTEN      115492     78687      -
            tcp        0      0 127.0.0.1:53            0.0.0.0:*               LISTEN      115492     78685      -
            tcp        0      0 0.0.0.0:21              0.0.0.0:*               LISTEN      0          54769      -
            tcp        0      0 0.0.0.0:662             0.0.0.0:*               LISTEN      0          36461      -
            tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          31027      -
            tcp        0      0 127.0.0.1:40247         0.0.0.0:*               LISTEN      297536     97536      -
            tcp        0      0 0.0.0.0:631             0.0.0.0:*               LISTEN      0          59416      -
            tcp        0      0 127.0.0.1:38008         0.0.0.0:*               LISTEN      0          110742     -
            tcp        0      0 127.0.0.1:32600         0.0.0.0:*               LISTEN      297536     98173      -
            tcp        0      0 127.0.0.1:5432          0.0.0.0:*               LISTEN      55         71637      -
            tcp        0      0 127.0.0.1:33304         0.0.0.0:*               LISTEN      0          34158      -
            tcp        0      0 127.0.0.1:953           0.0.0.0:*               LISTEN      115492     78695      -
            tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1000       145106     -
            tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      0          47395      -
            tcp        0      0 0.0.0.0:892             0.0.0.0:*               LISTEN      0          36195      -
            tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN      0          53837      -
            tcp        0      0 127.0.0.1:512           0.0.0.0:*               LISTEN      0          114413     -
            tcp        0      0 0.0.0.0:2049            0.0.0.0:*               LISTEN      0          55954      -
            tcp        0      0 127.0.0.1:161           0.0.0.0:*               LISTEN      0          45472      -
            tcp        0      0 0.0.0.0:6690            0.0.0.0:*               LISTEN      0          106312     -
            tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       135803     -
            tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       131823     -
            tcp        0      0 0.0.0.0:873             0.0.0.0:*               LISTEN      0          54571      -
            tcp        0      0 0.0.0.0:5001            0.0.0.0:*               LISTEN      0          47391      -
            tcp        0      0 127.0.0.1:38443         0.0.0.0:*               LISTEN      0          110744     -
            tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN      0          53838      -
            tcp        0      0 0.0.0.0:5003            0.0.0.0:*               LISTEN      0          47389      -
            tcp        0      0 0.0.0.0:4045            0.0.0.0:*               LISTEN      0          55976      -
            tcp        0      0 0.0.0.0:5357            0.0.0.0:*               LISTEN      0          49341      -
            tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          22207      -
            tcp        0      0 0.0.0.0:32400           0.0.0.0:*               LISTEN      297536     82659      -
            tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      0          47393      -
            tcp6       0      0 2a02:8109:2740:2e30::53 :::*                    LISTEN      115492     172337     -
            tcp6       0      0 2a02:8109:2740:2e30::53 :::*                    LISTEN      115492     172336     -
            tcp6       0      0 2a02:8109:2740:2e30::53 :::*                    LISTEN      115492     172335     -
            tcp6       0      0 2a02:8109:2740:2e30::53 :::*                    LISTEN      115492     172334     -
            tcp6       0      0 fe80::211:32ff:fe9b::53 :::*                    LISTEN      115492     78692      -
            tcp6       0      0 fe80::211:32ff:fe9b::53 :::*                    LISTEN      115492     78691      -
            tcp6       0      0 fe80::211:32ff:fe9b::53 :::*                    LISTEN      115492     78690      -
            tcp6       0      0 fe80::211:32ff:fe9b::53 :::*                    LISTEN      115492     78689      -
            tcp6       0      0 ::1:53                  :::*                    LISTEN      115492     76533      -
            tcp6       0      0 ::1:53                  :::*                    LISTEN      115492     76532      -
            tcp6       0      0 ::1:53                  :::*                    LISTEN      115492     76531      -
            tcp6       0      0 ::1:53                  :::*                    LISTEN      115492     76530      -
            tcp6       0      0 :::21                   :::*                    LISTEN      0          54770      -
            tcp6       0      0 :::8086                 :::*                    LISTEN      1000       130412     -
            tcp6       0      0 :::662                  :::*                    LISTEN      0          36466      -
            tcp6       0      0 :::22                   :::*                    LISTEN      0          31034      -
            tcp6       0      0 :::631                  :::*                    LISTEN      0          59417      -
            tcp6       0      0 :::3000                 :::*                    LISTEN      472        124181     -
            tcp6       0      0 ::1:38008               :::*                    LISTEN      0          110743     -
            tcp6       0      0 :::443                  :::*                    LISTEN      0          47396      -
            tcp6       0      0 :::892                  :::*                    LISTEN      0          36199      -
            tcp6       0      0 :::445                  :::*                    LISTEN      0          53835      -
            tcp6       0      0 :::3261                 :::*                    LISTEN      0          48771      -
            tcp6       0      0 :::5566                 :::*                    LISTEN      0          77124      -
            tcp6       0      0 :::3263                 :::*                    LISTEN      0          49871      -
            tcp6       0      0 :::3264                 :::*                    LISTEN      0          49873      -
            tcp6       0      0 :::2049                 :::*                    LISTEN      0          55966      -
            tcp6       0      0 :::3265                 :::*                    LISTEN      0          51895      -
            tcp6       0      0 :::6690                 :::*                    LISTEN      0          106313     -
            tcp6       0      0 :::515                  :::*                    LISTEN      0          58487      -
            tcp6       0      0 :::61991                :::*                    LISTEN      1000       148897     -
            tcp6       0      0 :::6281                 :::*                    LISTEN      0          90992      -
            tcp6       0      0 :::873                  :::*                    LISTEN      0          54572      -
            tcp6       0      0 :::5001                 :::*                    LISTEN      0          47392      -
            tcp6       0      0 ::1:38443               :::*                    LISTEN      0          110745     -
            tcp6       0      0 :::139                  :::*                    LISTEN      0          53836      -
            tcp6       0      0 :::5003                 :::*                    LISTEN      0          47390      -
            tcp6       0      0 :::4045                 :::*                    LISTEN      0          55978      -
            tcp6       0      0 :::5357                 :::*                    LISTEN      0          49342      -
            tcp6       0      0 :::111                  :::*                    LISTEN      0          22210      -
            tcp6       0      0 :::80                   :::*                    LISTEN      0          47394      -
            udp        0      0 0.0.0.0:55696           0.0.0.0:*                           1000       151886     -
            udp        0      0 127.0.0.1:55957         0.0.0.0:*                           297536     96010      -
            udp        0      0 0.0.0.0:56016           0.0.0.0:*                           1000       142224     -
            udp        0      0 0.0.0.0:56346           0.0.0.0:*                           0          22206      -
            udp        0      0 0.0.0.0:44094           0.0.0.0:*                           1000       141012     -
            udp        0      0 0.0.0.0:56769           0.0.0.0:*                           1000       136498     -
            udp        0      0 0.0.0.0:3702            0.0.0.0:*                           99         36872      -
            udp        0      0 0.0.0.0:32410           0.0.0.0:*                           297536     96004      -
            udp        0      0 0.0.0.0:32412           0.0.0.0:*                           297536     96005      -
            udp        0      0 0.0.0.0:32413           0.0.0.0:*                           297536     96006      -
            udp        0      0 0.0.0.0:32414           0.0.0.0:*                           297536     96003      -
            udp        0      0 0.0.0.0:44880           0.0.0.0:*                           1000       138310     -
            udp        0      0 0.0.0.0:53169           0.0.0.0:*                           0          35295      -
            udp        0      0 0.0.0.0:4045            0.0.0.0:*                           0          55975      -
            udp        0      0 0.0.0.0:49146           0.0.0.0:*                           1000       135059     -
            udp        0      0 172.17.0.1:53           0.0.0.0:*                           115492     103335     -
            udp        0      0 172.17.0.1:53           0.0.0.0:*                           115492     103336     -
            udp        0      0 172.17.0.1:53           0.0.0.0:*                           115492     103334     -
            udp        0      0 172.17.0.1:53           0.0.0.0:*                           115492     103333     -
            udp        0      0 169.254.241.18:53       0.0.0.0:*                           115492     76521      -
            udp        0      0 169.254.241.18:53       0.0.0.0:*                           115492     76520      -
            udp        0      0 169.254.241.18:53       0.0.0.0:*                           115492     76519      -
            udp        0      0 169.254.241.18:53       0.0.0.0:*                           115492     76518      -
            udp        0      0 192.168.178.203:53      0.0.0.0:*                           115492     76513      -
            udp        0      0 192.168.178.203:53      0.0.0.0:*                           115492     76512      -
            udp        0      0 192.168.178.203:53      0.0.0.0:*                           115492     76511      -
            udp        0      0 192.168.178.203:53      0.0.0.0:*                           115492     76510      -
            udp        0      0 127.0.0.1:53            0.0.0.0:*                           115492     78684      -
            udp        0      0 127.0.0.1:53            0.0.0.0:*                           115492     78683      -
            udp        0      0 127.0.0.1:53            0.0.0.0:*                           115492     78682      -
            udp        0      0 127.0.0.1:53            0.0.0.0:*                           115492     78681      -
            udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          29720      -
            udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          22205      -
            udp        0      0 0.0.0.0:123             0.0.0.0:*                           0          36521      -
            udp        0      0 192.168.178.255:137     0.0.0.0:*                           0          170893     -
            udp        0      0 192.168.178.203:137     0.0.0.0:*                           0          170892     -
            udp        0      0 0.0.0.0:137             0.0.0.0:*                           0          171950     -
            udp        0      0 192.168.178.255:138     0.0.0.0:*                           0          170895     -
            udp        0      0 192.168.178.203:138     0.0.0.0:*                           0          170894     -
            udp        0      0 0.0.0.0:138             0.0.0.0:*                           0          171951     -
            udp        0      0 127.0.0.1:161           0.0.0.0:*                           0          45471      -
            udp        0      0 127.0.0.1:323           0.0.0.0:*                           0          36519      -
            udp        0      0 192.168.178.203:49483   0.0.0.0:*                           297536     96008      -
            udp        0      0 0.0.0.0:41316           0.0.0.0:*                           1000       145040     -
            udp        0      0 0.0.0.0:49618           0.0.0.0:*                           1000       145934     -
            udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1000       148908     -
            udp        0      0 169.254.241.18:49723    0.0.0.0:*                           297536     96015      -
            udp        0      0 127.0.0.1:619           0.0.0.0:*                           0          36388      -
            udp        0      0 0.0.0.0:41620           0.0.0.0:*                           1000       149081     -
            udp        0      0 0.0.0.0:662             0.0.0.0:*                           0          36457      -
            udp        0      0 0.0.0.0:892             0.0.0.0:*                           0          36193      -
            udp        0      0 169.254.241.18:37759    0.0.0.0:*                           297536     96009      -
            udp        0      0 192.168.178.203:33717   0.0.0.0:*                           297536     96014      -
            udp        0      0 0.0.0.0:41941           0.0.0.0:*                           1000       149120     -
            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       151729     -
            udp        0      0 192.168.178.203:5353    0.0.0.0:*                           1000       143158     -
            udp        0      0 192.168.178.203:5353    0.0.0.0:*                           1000       143641     -
            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           0          35293      -
            udp        0      0 127.0.0.1:54514         0.0.0.0:*                           297536     96007      -
            udp        0      0 0.0.0.0:58694           0.0.0.0:*                           1000       146404     -
            udp        0      0 0.0.0.0:38214           0.0.0.0:*                           1000       135736     -
            udp        0      0 0.0.0.0:42386           0.0.0.0:*                           1000       131903     -
            udp        0      0 0.0.0.0:42458           0.0.0.0:*                           1000       147997     -
            udp        0      0 0.0.0.0:54762           0.0.0.0:*                           1000       144365     -
            udp        0      0 0.0.0.0:42518           0.0.0.0:*                           1000       139000     -
            udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1000       141042     -
            udp        0      0 0.0.0.0:54877           0.0.0.0:*                           1000       150072     -
            udp        0      0 0.0.0.0:34406           0.0.0.0:*                           1000       134738     -
            udp        0      0 0.0.0.0:34425           0.0.0.0:*                           1000       151824     -
            udp        0      0 0.0.0.0:38577           0.0.0.0:*                           1000       148893     -
            udp        0      0 0.0.0.0:34528           0.0.0.0:*                           1000       6247571    -
            udp        0      0 192.168.178.203:46830   0.0.0.0:*                           297536     96011      -
            udp        0      0 0.0.0.0:9997            0.0.0.0:*                           0          29938      -
            udp        0      0 0.0.0.0:9998            0.0.0.0:*                           0          29937      -
            udp        0      0 0.0.0.0:9999            0.0.0.0:*                           0          29936      -
            udp        0      0 0.0.0.0:1900            0.0.0.0:*                           0          49219      -
            udp        0      0 0.0.0.0:1901            0.0.0.0:*                           297536     96013      -
            udp        0      0 0.0.0.0:51087           0.0.0.0:*                           1000       139389     -
            udp        0      0 169.254.241.18:42991    0.0.0.0:*                           297536     96012      -
            udp        0      0 0.0.0.0:2049            0.0.0.0:*                           0          55965      -
            udp        0      0 0.0.0.0:51385           0.0.0.0:*                           1000       141194     -
            udp        0      0 0.0.0.0:55516           0.0.0.0:*                           1000       154626     -
            udp        0      0 0.0.0.0:43312           0.0.0.0:*                           1000       142990     -
            udp6       0      0 :::3702                 :::*                                99         36874      -
            udp6       0      0 :::4045                 :::*                                0          55977      -
            udp6       0      0 2a02:8109:2740:2e30::53 :::*                                115492     172333     -
            udp6       0      0 2a02:8109:2740:2e30::53 :::*                                115492     172332     -
            udp6       0      0 2a02:8109:2740:2e30::53 :::*                                115492     172331     -
            udp6       0      0 2a02:8109:2740:2e30::53 :::*                                115492     172330     -
            udp6       0      0 fe80::211:32ff:fe9b::53 :::*                                115492     76537      -
            udp6       0      0 fe80::211:32ff:fe9b::53 :::*                                115492     76536      -
            udp6       0      0 fe80::211:32ff:fe9b::53 :::*                                115492     76535      -
            udp6       0      0 fe80::211:32ff:fe9b::53 :::*                                115492     76534      -
            udp6       0      0 ::1:53                  :::*                                115492     76529      -
            udp6       0      0 ::1:53                  :::*                                115492     76528      -
            udp6       0      0 ::1:53                  :::*                                115492     76527      -
            udp6       0      0 ::1:53                  :::*                                115492     76526      -
            udp6       0      0 :::111                  :::*                                0          22208      -
            udp6       0      0 :::123                  :::*                                0          36522      -
            udp6       0      0 ::1:323                 :::*                                0          36520      -
            udp6       0      0 :::37315                :::*                                0          35296      -
            udp6       0      0 :::662                  :::*                                0          36464      -
            udp6       0      0 :::892                  :::*                                0          36197      -
            udp6       0      0 :::5353                 :::*                                0          35294      -
            udp6       0      0 :::58682                :::*                                0          22209      -
            udp6       0      0 :::2049                 :::*                                0          55967      -
            2024-02-22 15:53:42.856  - info: shelly.1 (450) [MQTT] Device with client id "shellyplus1pm-0cdc7ef62c9c" connected!
            2024-02-22 15:53:47.028  - info: shelly.1 (450) [MQTT] Device with client id "shellyplus1pm-0cdc7ef5afd0" connected!
            2024-02-22 15:53:49.586  - info: shelly.1 (450) [MQTT] Client Close:  (shellyplus1pm / shellyplus1pm-4855199c1ee8 / shellyplus1pm#4855199c1ee8#1) (false)
            2024-02-22 15:53:52.654  - info: shelly.1 (450) [MQTT] Client Close:  (shellyplus1pm / shellyplus1pm-0cdc7ef6696c / shellyplus1pm#0cdc7ef6696c#1) (false)
            2024-02-22 15:53:52.679  - info: shelly.1 (450) [MQTT] Device with client id "shellyplus1pm-4855199d205c" connected!
            2024-02-22 15:53:52.854  - info: shelly.1 (450) [MQTT] Client Close:  (shellyplus1pm / shellyplus1pm-0cdc7ef62c9c / shellyplus1pm#0cdc7ef62c9c#1) (false)
            2024-02-22 15:53:54.229  - info: shelly.1 (450) [MQTT] Device with client id "shellyplus1pm-4855199d1ee8" connected!
            2024-02-22 15:53:56.551  - info: shelly.1 (450) [MQTT] Device with client id "shellyplus1pm-0cdc7ef62910" connected!
            2024-02-22 15:53:57.025  - info: shelly.1 (450) [MQTT] Client Close:  (shellyplus1pm / shellyplus1pm-0cdc7ef5afd0 / shellyplus1pm#0cdc7ef5afd0#1) (false)
            2024-02-22 15:53:57.950  - info: shelly.1 (450) [MQTT] Device with client id "shellyplus1pm-0cdc7ef5a954" connected!
            2024-02-22 15:54:01.850  - info: shelly.1 (450) [MQTT] Device with client id "shellyplus1pm-0cdc7ef62cbc" connected!
            2024-02-22 15:54:02.131  - info: shelly.1 (450) [MQTT] Device with client id "shellyplus1pm-4855199cfa60" connected!
            2024-02-22 15:54:02.670  - info: shelly.1 (450) [MQTT] Client Close:  (shellyplus1pm / shellyplus1pm-4855199d205c / shellyplus1pm#4855199d205c#1) (false)
            • Dr.PieD Dr.Pie
              @dr-pie
              OliverIOO Offline
              OliverIOO Offline
              OliverIO
              @dr-pie
              Ich tippe mal ein Problem mit dem device watcher.
              Lese mal hier.
              https://github.com/ciddi89/ioBroker.device-watcher/issues/283
              Stoppe mal den Adapter ob sich dann die Auslastung normalisiert.
              Links im Profil
              Dr.PieD 2 Antworten Letzte Antwort
                @dr-pie
                Lese mal hier.
                Dr.PieD Offline
                Dr.PieD Offline
                Dr.Pie
                @dr-pie
                Lese mal hier.
                Ich komme ja nicht auf die iob-Oberfläche.
                Der Editor funktioniert nach ca. 15 Minuten. Auch die Vis ist verfügbar.Jeder klick in der Vis bedeutet aber waaaaarten
                  @dr-pie
                  Lese mal hier.
                  Dr.PieD Offline
                  Dr.PieD Offline
                  Dr.Pie
                  @dr-pie
                  In einer Millisekunde konnte ich auf den iob kommen.
                  Habe dann den "device watcher" angehalten ... und siehe da ...die CPU Auslastung normalisierte sich wieder.
                  • Dr.PieD Dr.Pie
                    @dr-pie
                    OliverIOO Offline
                    OliverIOO Offline
                    OliverIO
                    @dr-pie
                    Man kann Adapter auch über console Befehle starten und stoppen
                    Links im Profil
                      @dr-pie
                      Dr.PieD Offline
                      Dr.PieD Offline
                      Dr.Pie
                      @dr-pie
                      Hab ich gerade raus gefunden. 👍 👍 👍
                      • GlasfaserG Offline
                        GlasfaserG Offline
                        Docker : v8.0.1
                        /usr/bin/npm 9.6.7
                        /usr/bin/npx 9.6.7
                        nodejs:
                        Docker Image ist alt und du bleibst auf der nodejs Version stehen .
                        • GlasfaserG Glasfaser
                          Docker : v8.0.1
                          /usr/bin/npm 9.6.7
                          /usr/bin/npx 9.6.7
                          nodejs:
                          Dr.PieD Offline
                          Dr.PieD Offline
                          Dr.Pie
                          @glasfaser sagte in Teilweise über 200% CPU Auslastung im Docker:
                          Docker : v8.0.1
                          /usr/bin/npm 9.6.7
                          /usr/bin/npx 9.6.7
                          nodejs:
                          Liegt vielleicht daran dass ich nicht wirklich weiss wie :man-bowing:
                          OliverIOO GlasfaserG 2 Antworten Letzte Antwort
                          • Dr.PieD Dr.Pie
                            Docker : v8.0.1
                            /usr/bin/npm 9.6.7
                            /usr/bin/npx 9.6.7
                            nodejs:
                            OliverIOO Offline
                            OliverIOO Offline
                            OliverIO
                            @dr-pie
                            hach, wenn es nur eine beschreibung dafür geben würde, wo das alles genauch beschrieben ist.
                            huch
                            https://docs.buanet.de/de/iobroker-docker-image/docs/#hochrustung-upgrade
                            oder alternativ die ältere doku für portainer
                            https://smarthome.buanet.de/2020/10/iobroker-docker-container-updates-upgrades/
                            Links im Profil
                            • Dr.PieD Dr.Pie
                              Docker : v8.0.1
                              /usr/bin/npm 9.6.7
                              /usr/bin/npx 9.6.7
                              nodejs:
                              GlasfaserG Offline
                              GlasfaserG Offline
                              Jein ...
                              Aber @OliverIO hat dir schon ein Tip zur Auslastung von einem bestimmten Adapter genannt , der hier bei vielen Probleme macht !
                              Und das mit der Synology Anzeige / Diagramm ist ein Schätzeisen ...
                              aber das Thema haben ich und @OliverIO schon mehrmals hier im Forum durchgekaut .
