  3. Einsteigerfragen
  4. Fehlermeldung vom WS-adapter
    5.5k
51 Beiträge 5 Kommentatoren 7.7k Aufrufe 4 Beobachtet
  • H hejosta
    oder das hier
    <======== Start marking the full check here =========
    Skript v.2023-10-10
    *** BASE SYSTEM ***
     Static hostname: iobroker
           Icon name: computer
              Kernel: Linux 6.1.0-rpi7-rpi-v8
        Architecture: arm64
    Model		: Raspberry Pi 4 Model B Rev 1.5
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : arm64
    Systemuptime and Load:
     14:33:16 up 6 days, 19:54,  2 users,  load average: 0.02, 0.07, 0.09
    CPU threads: 4
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** Time and Time Zones ***
                   Local time: Mon 2024-01-29 14:33:16 CET
               Universal time: Mon 2024-01-29 13:33:16 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    hstark
    /home/hstark
    hstark adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server: 	false
    Desktop:
    Terminal: 	tty
    Boot Target: 	multi-user.target
    *** MEMORY ***
    Mem:            1.9G        1.3G        254M         57K        502M        677M
    Swap:           104M        1.6M        103M
    Total:          2.0G        1.3G        358M
             1848 M total memory
             1202 M used memory
             1240 M active memory
              219 M inactive memory
              243 M free memory
               72 M buffer memory
              406 M swap cache
               99 M total swap
                1 M used swap
               98 M free swap
    Raspberry only:
    oom events: 0
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** FILESYSTEM ***
    udev           devtmpfs  661M     0  661M   0% /dev
    tmpfs          tmpfs     185M  1.2M  184M   1% /run
    /dev/mmcblk0p2 ext4       29G  3.9G   24G  15% /
    tmpfs          tmpfs     925M     0  925M   0% /dev/shm
    tmpfs          tmpfs     5.0M   16K  5.0M   1% /run/lock
    /dev/mmcblk0p1 vfat      510M   61M  450M  12% /boot/firmware
    tmpfs          tmpfs     185M     0  185M   0% /run/user/1000
    [Mon Jan 22 18:38:31 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=D8:3A:DD:70:03:81 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=tty1 root=PARTUUID=c2e517b8-02 rootfstype=ext4 fsck.repair=yes rootwait cfg80211.ieee80211_regdom=GE
    [Mon Jan 22 18:38:33 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
    [Mon Jan 22 18:38:35 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
    TARGET           SOURCE         FSTYPE OPTIONS
    /                /dev/mmcblk0p2 ext4   rw,noatime
    `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    594M	/var/
    211M	/var/cache
    205M	/var/cache/apt
    166M	/var/lib
    132M	/var/lib/apt/lists
    Archived and active journals take up 115.4M in the file system.
    /opt/iobroker/backups:
    25M	/opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    223M	/opt/iobroker/iobroker-data/
    177M	/opt/iobroker/iobroker-data/files
    67M	/opt/iobroker/iobroker-data/files/javascript.admin
    48M	/opt/iobroker/iobroker-data/files/javascript.admin/static
    47M	/opt/iobroker/iobroker-data/files/javascript.admin/static/js
    21M	/opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
    9.0M	/opt/iobroker/iobroker-data/objects.jsonl
    8.3M	/opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js
    7.5M	/opt/iobroker/iobroker-data/files/javascript.admin/static/js/691.26ff76ce.chunk.js.map
    7.1M	/opt/iobroker/iobroker-data/files/javascript.admin/static/js/610.d3cce782.chunk.js.map
    USB-Devices by-id:
    /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2400350-if00
    *** NodeJS-Installation ***
    /usr/bin/nodejs 	v18.19.0
    /usr/bin/node 		v18.19.0
    /usr/bin/npm 		10.2.3
    /usr/bin/npx 		10.2.3
    /usr/bin/corepack 	0.22.0
    nodejs:
      Installed: 18.19.0-1nodesource1
      Candidate: 18.19.0-1nodesource1
      Version table:
         18.19.0+dfsg-6~deb12u1 500
            500 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages
     *** 18.19.0-1nodesource1 1001
            500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages
         18.18.2-1nodesource1 1001
         18.18.1-1nodesource1 1001
         18.18.0-1nodesource1 1001
         18.17.1-1nodesource1 1001
         18.17.0-1nodesource1 1001
         18.16.1-1nodesource1 1001
         18.16.0-1nodesource1 1001
         18.15.0-1nodesource1 1001
         18.14.2-1nodesource1 1001
         18.14.1-1nodesource1 1001
         18.14.0-1nodesource1 1001
         18.13.0+dfsg1-1 500
            500 http://deb.debian.org/debian bookworm/main arm64 Packages
         18.13.0-1nodesource1 1001
         18.12.0-1nodesource1 1001
         18.11.0-1nodesource1 1001
         18.10.0-1nodesource1 1001
         18.9.1-1nodesource1 1001
         18.9.0-1nodesource1 1001
         18.8.0-1nodesource1 1001
         18.7.0-1nodesource1 1001
         18.6.0-1nodesource1 1001
         18.5.0-1nodesource1 1001
         18.4.0-1nodesource1 1001
         18.3.0-1nodesource1 1001
         18.2.0-1nodesource1 1001
         18.1.0-1nodesource1 1001
         18.0.0-1nodesource1 1001
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller: 	5.0.17
    admin: 		6.12.0
    javascript: 	7.1.6
    Adapters from github: 	0
    Adapter State
    + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
    + system.adapter.deconz.0                 : deconz                : iobroker                                 -  enabled, port: 80
    + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
    + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
    + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 12001
    + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 12010
      system.adapter.icons-material-png.0     : icons-material-png    : iobroker                                 - disabled
      system.adapter.icons-material-svg.0     : icons-material-svg    : iobroker                                 -  enabled
      system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker                                 -  enabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 - disabled
    + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
    + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1884, bind: 0.0.0.0
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 - disabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 - disabled
    + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 - disabled
      system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
    + system.adapter.ws.0                     : ws                    : iobroker                                 -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 6.12.0   , installed 6.12.0
    Adapter    "backitup"     : 2.9.8    , installed 2.9.8
    Adapter    "deconz"       : 1.3.23   , installed 1.3.23
    Adapter    "discovery"    : 4.2.0    , installed 4.2.0
    Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
    Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
    Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
    Adapter    "javascript"   : 7.1.6    , installed 7.1.6
    Controller "js-controller": 5.0.17   , installed 5.0.17
    Adapter    "mqtt"         : 5.1.0    , installed 5.1.0
    Adapter    "socketio"     : 6.6.0    , installed 6.6.0
    Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
    Adapter    "vis"          : 1.5.4    , installed 1.5.4
    Adapter    "vis-icontwo"  : 1.3.0    , installed 1.3.0
    Adapter    "web"          : 6.1.10   , installed 6.1.10
    Adapter    "ws"           : 2.5.8    , installed 2.5.8
    Objects and States
    Objects: 	1451
    States: 	1081
    W: http://phoscon.de/apt/deconz/dists/bookworm/InRelease: Key is stored in legacy trusted.gpg keyring (/etc/apt/trusted.gpg), see the DEPRECATION section in apt-key(8) for details.
    Hit:1 http://archive.raspberrypi.com/debian bookworm InRelease
    Hit:2 http://phoscon.de/apt/deconz bookworm InRelease
    Hit:3 http://deb.debian.org/debian bookworm InRelease
    Hit:4 http://deb.debian.org/debian-security bookworm-security InRelease
    Hit:5 http://deb.debian.org/debian bookworm-updates InRelease
    Hit:6 https://deb.nodesource.com/node_18.x nodistro InRelease
    Reading package lists...
    Pending Updates: 16
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       1685428    844777/io.sonoff.0
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       1688667    844764/io.mqtt.0
    tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      1000       17592      464/deCONZ
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       1895       701/iobroker.js-con
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       15622      701/iobroker.js-con
    tcp        0      0 192.168.0.22:12010      0.0.0.0:*               LISTEN      1001       2116906    1061311/io.hm-rpc.1
    tcp        0      0 192.168.0.22:12001      0.0.0.0:*               LISTEN      1001       2114199    1061304/io.hm-rpc.0
    tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      1000       16530      464/deCONZ
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          16597      725/sshd: /usr/sbin
    tcp6       0      0 :::8084                 :::*                    LISTEN      1001       1688671    844822/io.ws.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       1688657    844798/io.web.0
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       1685391    844682/io.admin.0
    tcp6       0      0 :::22                   :::*                    LISTEN      0          16599      725/sshd: /usr/sbin
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       1687211    844698/io.deconz.0
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       1687208    844698/io.deconz.0
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       15606      464/deCONZ
    udp        0      0 0.0.0.0:56259           0.0.0.0:*                           104        15328      457/avahi-daemon: r
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        15326      457/avahi-daemon: r
    udp6       0      0 fe80::690a:a09e:56d:546 :::*                                0          2114352    592/NetworkManager
    udp6       0      0 fe80::5ea8:b27d:a30:546 :::*                                0          2114350    592/NetworkManager
    udp6       0      0 :::1900                 :::*                                1001       1687213    844698/io.deconz.0
    udp6       0      0 :::1900                 :::*                                1001       1687212    844698/io.deconz.0
    udp6       0      0 :::1900                 :::*                                1001       1687210    844698/io.deconz.0
    udp6       0      0 :::1900                 :::*                                1001       1687209    844698/io.deconz.0
    udp6       0      0 :::5353                 :::*                                104        15327      457/avahi-daemon: r
    udp6       0      0 :::54702                :::*                                104        15329      457/avahi-daemon: r
    2024-01-29 14:10:03.329  - error: ws.0 (844822) Error: "error" - No sid found from ::ffff:192.168.0.22
    2024-01-29 14:11:03.334  - error: ws.0 (844822) Error: "error" - No sid found from ::ffff:192.168.0.22
    2024-01-29 14:12:03.339  - error: ws.0 (844822) Error: "error" - No sid found from ::ffff:192.168.0.22
    2024-01-29 14:13:03.344  - error: ws.0 (844822) Error: "error" - No sid found from ::ffff:192.168.0.22
    2024-01-29 14:14:03.351  - error: ws.0 (844822) Error: "error" - No sid found from ::ffff:192.168.0.22
    2024-01-29 14:15:03.358  - error: ws.0 (844822) Error: "error" - No sid found from ::ffff:192.168.0.22
    2024-01-29 14:16:03.367  - error: ws.0 (844822) Error: "error" - No sid found from ::ffff:192.168.0.22
    2024-01-29 14:17:03.375  - error: ws.0 (844822) Error: "error" - No sid found from ::ffff:192.168.0.22
    2024-01-29 14:18:03.382  - error: ws.0 (844822) Error: "error" - No sid found from ::ffff:192.168.0.22
    2024-01-29 14:19:03.387  - error: ws.0 (844822) Error: "error" - No sid found from ::ffff:192.168.0.22
    2024-01-29 14:20:03.394  - error: ws.0 (844822) Error: "error" - No sid found from ::ffff:192.168.0.22
    2024-01-29 14:21:03.404  - error: ws.0 (844822) Error: "error" - No sid found from ::ffff:192.168.0.22
    2024-01-29 14:22:03.412  - error: ws.0 (844822) Error: "error" - No sid found from ::ffff:192.168.0.22
    2024-01-29 14:23:03.419  - error: ws.0 (844822) Error: "error" - No sid found from ::ffff:192.168.0.22
    2024-01-29 14:24:03.427  - error: ws.0 (844822) Error: "error" - No sid found from ::ffff:192.168.0.22
    2024-01-29 14:25:03.434  - error: ws.0 (844822) Error: "error" - No sid found from ::ffff:192.168.0.22
    2024-01-29 14:26:03.442  - error: ws.0 (844822) Error: "error" - No sid found from ::ffff:192.168.0.22
    2024-01-29 14:27:03.449  - error: ws.0 (844822) Error: "error" - No sid found from ::ffff:192.168.0.22
    2024-01-29 14:28:03.457  - error: ws.0 (844822) Error: "error" - No sid found from ::ffff:192.168.0.22
    2024-01-29 14:29:03.461  - error: ws.0 (844822) Error: "error" - No sid found from ::ffff:192.168.0.22
    2024-01-29 14:30:03.466  - error: ws.0 (844822) Error: "error" - No sid found from ::ffff:192.168.0.22
    2024-01-29 14:31:03.470  - error: ws.0 (844822) Error: "error" - No sid found from ::ffff:192.168.0.22
    2024-01-29 14:32:03.475  - error: ws.0 (844822) Error: "error" - No sid found from ::ffff:192.168.0.22
    2024-01-29 14:33:03.482  - error: ws.0 (844822) Error: "error" - No sid found from ::ffff:192.168.0.22
    2024-01-29 14:34:03.487  - error: ws.0 (844822) Error: "error" - No sid found from ::ffff:192.168.0.22
    @hejosta sagte in Fehlermeldung vom WS-adapter:
    192.168.0.22
    Wessen IP ist das? Die vom ioBroker-Host? Oder irgendwas externes?
    H 1 Antwort Letzte Antwort
      192.168.0.22
      hejosta
      Das ist der ioBroker!
      pi 4 B 2G
      iobroker V6.12.0
      Plattform: linux
      RAM: 1.8 GB
      Node.js: v18.19.0
      NPM: 10.2.3
        @hejosta
        Hat zwar nichts mit deinem Fehler zu tun, ich würde aber dennoch das deconz-Repo richtig aufsetzen:
        sudo rm /etc/apt/sources.list.d/dec*
        wget -qO- http://phoscon.de/apt/deconz.pub.key | sudo gpg --dearmor -o /usr/share/keyrings/deconz.gpg > /dev/null
        sudo sh -c "echo 'deb [signed-by=/usr/share/keyrings/deconz.gpg] http://phoscon.de/apt/deconz $(lsb_release -cs) main' > /etc/apt/sources.list.d/deconz.list"
        sudo apt update
        sudo apt full-upgrade
        sudo reboot
        hejosta
        @thomas-braun said in Fehlermeldung vom WS-adapter:
        sudo apt-fullupgrade
        das funktioniert nicht bei mir
        <@iobroker:~ $ sudo apt-fullupgrade
        @iobroker:~ $ sudo apt-upgrade
        sudo: apt-upgrade: command not found
        pi 4 B 2G
        iobroker V6.12.0
        Plattform: linux
        RAM: 1.8 GB
        Node.js: v18.19.0
        NPM: 10.2.3
        • H hejosta
          @hejosta
          Mein Fehler.
          Muss so lauten:
          sudo apt update
          sudo reboot
            @hejosta
            Mein Fehler.
            Muss so lauten:
            sudo apt update
            sudo reboot
            hejosta
            Danke..
            pi 4 B 2G
            iobroker V6.12.0
            Plattform: linux
            RAM: 1.8 GB
            Node.js: v18.19.0
            NPM: 10.2.3
            • H hejosta
              hejosta
              @hejosta
              Mein problem ist leider mit den zusätzliche Aktionen nicht gelöst, was kann ich machen um diesen minütlichen error auf meiner logdatei zu eliminieren.. kostet Performance!!!
              pi 4 B 2G
              iobroker V6.12.0
              Plattform: linux
              RAM: 1.8 GB
              Node.js: v18.19.0
              NPM: 10.2.3
              • H hejosta
                @hejosta
                Das hat auch niemand behauptet...
                Hast du irgendein Skript laufen, welches im Minutentakt auf irgendwas zugreift?
                  hejosta
                  Guten morgen,
                  nein es läuft kein Skript. Ich habe zusätzlich den MQTT und SONOFF Adapter gestoppt da diese im mom nicht benötigt werden, Geräte sind noch nicht wieder aufgebaut.
                  Hejosta
                  pi 4 B 2G
                  iobroker V6.12.0
                  Plattform: linux
                  RAM: 1.8 GB
                  Node.js: v18.19.0
                  NPM: 10.2.3
                  • H hejosta
                    Guten morgen,
                    Hejosta
                    hejosta
                    Guten morgen,
                    Hejosta
                    leider habe ich bis Heute keine weitere info zu meinem Fehler Bekommen! Ich kann den Adapter auch nicht abschalten. Wenn ich das tue, habe ich den gleichen Fehler im Web 0
                    web.0
                    2024-02-19 09:49:30.022 error Error: "error" - No sid found from ::ffff:192.168.0.22>
                    Des weitern müllt dieser Fehler mir meine SD voll, so Skripte mit zeitschleifen nicht mehr laufen!
                    pi 4 B 2G
                    iobroker V6.12.0
                    Plattform: linux
                    RAM: 1.8 GB
                    Node.js: v18.19.0
                    NPM: 10.2.3
                    • H hejosta
                      Guten morgen,
                      Hejosta
                      web.0
                      wendy2702W Online
                      wendy2702W Online
                      Benutzt du Jarvis ?
                      Gibt hier was dazu: https://github.com/Zefau/ioBroker.jarvis/issues/2438
                      https://213.136.68.177/post/1069788
                      HomoranH H 2 Antworten Letzte Antwort
                      • wendy2702W wendy2702
                        Benutzt du Jarvis ?
                        @wendy2702 sagte in Fehlermeldung vom WS-adapter:
                        Benutzt du Jarvis ?
                        laut iob diag nicht
                          Benutzt du Jarvis ?
                          hejosta
                          Benutzt du Jarvis ?
                          Nein, ich benutze es nicht! Wenn ich deconz ausschalte ist der Fehler weg, ich glaube ich werde mal diesen Adapter überprüfen. Ich habe da mehrere schaltsteckdosen und einen Temperatursensor und einen IKEA Rangeextender laufen.
                          MfG
                          HejoSta
                          pi 4 B 2G
                          iobroker V6.12.0
                          Plattform: linux
                          RAM: 1.8 GB
                          Node.js: v18.19.0
                          NPM: 10.2.3
                          • H hejosta
                            Benutzt du Jarvis ?
                            MfG
                            HejoSta
                            hejosta
                            @hejosta
                            leider hat meine ganze aktion nichts gebracht! Habe alle Zigbee-Geräte gelöscht! Den Adapter gelöscht und neu installiert!
                            Den Phoscon Stick zurückgesezt! Raspi neugestartet! und alles wieder neu eingerichtet. schon nur den Deconz-Adapter brachte den Fehler! Was kann ich noch tun?
                            HejoSta
                            pi 4 B 2G
                            iobroker V6.12.0
                            Plattform: linux
                            RAM: 1.8 GB
                            Node.js: v18.19.0
                            NPM: 10.2.3
                            • H hejosta
                              @hejosta
                              HejoSta
                              Alternativ den zigbee-Adapter verwenden.
                                hejosta
                                den bekomm ich nicht ans laufen, er will irgendwie den Stick nicht sehen, ( tty(usb)
                                HejoSta
                                pi 4 B 2G
                                iobroker V6.12.0
                                Plattform: linux
                                RAM: 1.8 GB
                                Node.js: v18.19.0
                                NPM: 10.2.3
                                • H hejosta
                                  HejoSta
                                  ( tty(usb)
                                  Ist ja auch... Irgendwas...
                                  Falsches, vermutlich...
                                  • H hejosta
                                    oder das hier
                                    Skript v.2023-10-10
                                    *** BASE SYSTEM ***
                                           Icon name: computer
                                        Architecture: arm64
                                    Docker          : false
                                    Kernel          : aarch64
                                    Userland        : arm64
                                    CPU threads: 4
                                    Current issues:
                                                     RTC time: n/a
                                                  NTP service: active
                                              RTC in local TZ: no
                                    hstark
                                    /home/hstark
                                    X-Server: 	false
                                    Desktop:
                                    Terminal: 	tty
                                    *** MEMORY ***
                                             1848 M total memory
                                             1202 M used memory
                                              243 M free memory
                                               72 M buffer memory
                                              406 M swap cache
                                               99 M total swap
                                                1 M used swap
                                               98 M free swap
                                    Raspberry only:
                                    oom events: 0
                                    *** FILESYSTEM ***
                                    /var:
                                    594M	/var/
                                    211M	/var/cache
                                    205M	/var/cache/apt
                                    166M	/var/lib
                                    USB-Devices by-id:
                                    /usr/bin/npm 		10.2.3
                                    /usr/bin/npx 		10.2.3
                                    nodejs:
                                      Version table:
                                         18.13.0+dfsg1-1 500
                                    Errors in npm tree:
                                    ioBroker Status
                                    Objects type: jsonl
                                    States  type: jsonl
                                    admin: 		6.12.0
                                    javascript: 	7.1.6
                                    Adapter State
                                    + instance is alive
                                    Objects and States
                                    Objects: 	1451
                                    States: 	1081
                                    Pending Updates: 16
                                    das wäre dein Stick
                                      das wäre dein Stick
                                      hejosta
                                      @homoran sagte in Fehlermeldung vom WS-adapter:
                                      das wäre dein Stick
                                      ja, das hab ich auch drin, aber er startet nicht richtig. Steht auf 115200 Baud
                                      Hejosta
                                      pi 4 B 2G
                                      iobroker V6.12.0
                                      Plattform: linux
                                      RAM: 1.8 GB
                                      Node.js: v18.19.0
                                      NPM: 10.2.3
                                      • H hejosta
                                        das wäre dein Stick
                                        Hejosta
                                        Und das tut der nicht ohne Einträge im Logfile.
                                        • H hejosta
                                          das wäre dein Stick
                                          Hejosta
                                          wo?
                                          bitte zeigen
