  3. Off Topic
  4. Maria DB Config kein Zugriff
    6.0k
22 Beiträge 5 Kommentatoren 3.2k Aufrufe 2 Beobachtet
  • F frankyboy73
    @codierknecht Ok, habe MariaDb und Iobroker beendet, habe aber trotzdem keinen Zugriff auf die Config Datei. Leider gleiche Meldung.
    E325: ATTENTION
    Found a swap file by the name "/etc/mysql/mariadb.conf.d/.50-server.cnf.swp"
              owned by: root   dated: Tue Aug 16 18:51:27 2022
             file name: /etc/mysql/mariadb.conf.d/50-server.cnf
              modified: YES
             user name: root   host name: raspberrypi
            process ID: 29917
    While opening file "/etc/mysql/mariadb.conf.d/50-server.cnf"
                 dated: Sun Feb 20 02:40:11 2022
    (1) Another program may be editing the same file.  If this is the case,
        be careful not to end up with two different instances of the same
        file when making changes.  Quit, or continue with caution.
    (2) An edit session for this file crashed.
        If this is the case, use ":recover" or "vim -r /etc/mysql/mariadb.conf.d/50-
    server.cnf"
        to recover the changes (see ":help recovery").
        If you did this already, delete the swap file "/etc/mysql/mariadb.conf.d/.50
    -server.cnf.swp"
        to avoid this message.
    "/etc/mysql/mariadb.conf.d/50-server.cnf" 117 lines, 3666 bytes
    Press ENTER or type command to continue
    dimaiv
    schrieb am zuletzt editiert von dimaiv
    @frankyboy73
    Mit welchem Befehl versuchst du es aufmachen?
    Update:
    Ganz oben gesehen "vi"
    Probier mal mit "nano"
    ioBroker- NUC8i3 / Proxmox / VM
    Node.js v22.21.0
    NPM v10.9.4
    JS controller 7.1.0
    Admin 7.7.20
    ZigBee Adapter 3.3.1alpha.0
    Zigbee LAN Gateway CC2652P
    Zigbee Firmware 20250321
    CodierknechtC F 2 Antworten Letzte Antwort
    • D dimaiv
      @frankyboy73
      Update:
      CodierknechtC Offline
      Codierknecht
      @dimaiv
      pi@raspberrypi:~ $ sudo vi /etc/mysql/mariadb.conf.d/50-server.cnf
      siehe Eingangspost
      HmIP|ZigBee|Tasmota|Unifi
      Zabbix Certified Specialist
      • D dimaiv
        @frankyboy73
        Update:
        frankyboy73
        @dimaiv Hi, so.
        Genau so habe ich es bei der ersten Installation auch gemacht. Video von hausautomatisierung.
        Schöne Grüße Frank
        • F frankyboy73
          @dimaiv Hi, so.
          dimaiv
          @frankyboy73
          Node.js v22.21.0
          NPM v10.9.4
          JS controller 7.1.0
          Admin 7.7.20
          • D dimaiv
            @frankyboy73
            frankyboy73
            @dimaiv
            Schöne Grüße Frank
            • F frankyboy73
              @dimaiv
              Codierknecht
              @frankyboy73
              Da klemmt wohl ein früherer Editierversuch.
              Aber durch root ???
              Dass der Kram aber einen Reboot überlebt, wundert micht etwas.
              • F frankyboy73
                Hi, ich komme leider nich mehr per Windows Rechner und Heidi SQL an meine Datenbanken dran, obwohl ich mir sicher bin das meine Benutzerdaten stimmen. Der Iobroker kann aber noch auf die Datenbank zugreifen, das passiert ja auch lokal, da beides auf einem Raspi läuft. Nun wollte ich in der Maria Config schauen was da nicht stimmt bzw, einen neuen Benutzer anlegen. Leider kann ich darauf nicht zugreifen und weiß nicht wie ich hier weiterkommen. Kennt jemand das Problem? Kann ich da noch was retten.
                E325: ATTENTION
                          modified: YES
                        process ID: 29917
                server.cnf"
                -server.cnf.swp"
                Ro75R Offline
                Ro75R Offline
                Ro75
                @frankyboy73 du hast auf deinem Raspi aber nicht zufällig
                aktiviert?
                Ro75.
                • D dimaiv
                  @frankyboy73
                  frankyboy73
                  schrieb am zuletzt editiert von frankyboy73
                  @dimaiv Hi, habe die Datei jetzt mit yes (open anyway) geöffnet. Jetzt konnte ich sie bearbeiten. Super. Warum ich die mit nano jetzt bearbeiten konnte und mit vi nicht erschließt sich mir nicht. Ich konnte sie zwar auch mit vi öffnen, aber ändern ging nicht.
                  Das binding war nicht mehr auskommentiert und daurch konnte ich nicht mehr von einem anderen Rechner auf die Database kommen.
                  Jetzt nach dem speichern und neustarten, kann ich die Config auch ohne Fehlermeldung öffen, auch mit vi, und wieder auf die Datenbank zugreifen.
                  Vielen Dank, ich weiß zwar nicht wie sich das von selbst geändert hat, aber ich bin froh das ich wieder drauf komme.
                  Auch an @Codierknecht und @Ro75 vielen Dank für eure Unterstützung.
                  Edit: @Codierknecht das mit root wundert mich auch, ich habe auf diesem System noch nie den root user benutzt.
                  Schöne Grüße Frank
                  • CodierknechtC Codierknecht
                    @frankyboy73
                    Dann bin ich mit meinem Latein am Ende.
                    Vielleicht hat @Thomas-Braun hier einen Rat?
                    @codierknecht
                    Nein. Von Datenbanken hab ich keine Ahnung.
                      @codierknecht
                      Codierknecht
                      @thomas-braun sagte in Maria DB Config kein Zugriff:
                      Ich meinte eher das hier:
                      E325: ATTENTION
                                modified: YES
                              process ID: 29917
                      Hat mit der DB selbst wenig zu tun.
                      Würde mich weiterhin interessieren, woher das Problem mit dem Editor kommt.
                      F 1 Antwort Letzte Antwort
                        E325: ATTENTION
                                  modified: YES
                                process ID: 29917
                        frankyboy73
                        @codierknecht sagte in Maria DB Config kein Zugriff:
                        Mich auch
                        Schöne Grüße Frank
