  5. Merkwürdiges Typ-Problem
    6.7k
24 Beiträge 4 Kommentatoren 1.1k Aufrufe 2 Beobachtet
  • MartinPM MartinP
    Heute habe ich folgende zwei Warnungen im Logging entdeckt, nachdem ich die Fehlpuls-Korrektur meiner Pulszähler-Mimik am Gaszähler durchgeführt habe.
    2024-02-14 07:52:30.311 - warn: javascript.0 (63494) You are assigning a string to the state "0_userdata.0.Adjustments.Gaszaehler.LastKubikmeter" which expects a number. Please fix your code to use a number or change the state type to string. This warning might become an error in future versions.
    2024-02-14 07:52:30.315 - warn: javascript.0 (63494) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1740:20)
    2024-02-14 07:52:30.316 - warn: javascript.0 (63494) at Object. (script.js.Energiezaehler.Gaszaehler:27:5)
    2024-02-14 07:52:30.316 - warn: javascript.0 (63494) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1266:38)
    2024-02-14 07:52:30.316 - warn: javascript.0 (63494) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:645:29)
    2024-02-14 07:52:30.316 - warn: javascript.0 (63494) at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11229:62)
    2024-02-14 07:52:30.316 - warn: javascript.0 (63494) at processImmediate (node:internal/timers:476:21)
    2024-02-14 07:52:30.317 - warn: javascript.0 (63494) You are assigning a string to the state "0_userdata.0.Adjustments.Gaszaehler.VerbrauchTotal" which expects a number. Please fix your code to use a number or change the state type to string. This warning might become an error in future versions.
    2024-02-14 07:52:30.319 - warn: javascript.0 (63494) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1740:20)
    2024-02-14 07:52:30.319 - warn: javascript.0 (63494) at Object. (script.js.Energiezaehler.Gaszaehler:29:5)
    2024-02-14 07:52:30.319 - warn: javascript.0 (63494) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1266:38)
    2024-02-14 07:52:30.320 - warn: javascript.0 (63494) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:645:29)
    2024-02-14 07:52:30.320 - warn: javascript.0 (63494) at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11229:62)
    2024-02-14 07:52:30.320 - warn: javascript.0 (63494) at processImmediate (node:internal/timers:476:21)
    Heilen konnte ich das im Blockly der Korrekturprozedur durch eingefügte "Nach Zahl" Blöcke...
    Merkwürdigerweise ist aber NullKubikWork gar kein String ...
    Hat da jemand eine Idee, was das sein könnte?
    Javascript Code mit "nach Zahl"
    on({ id: '0_userdata.0.Adjustments.Gaszaehler.NullKubikSet' /* NullKubikSet */, change: 'ne' }, async (obj) => {
      let value = obj.state.val;
      let oldValue = obj.oldState.val;
      if ((obj.state ? obj.state.val : "") == 0 && (obj.state ? obj.state.from : "") != 'system.adapter.javascript.0') {
        setState('0_userdata.0.Adjustments.Gaszaehler.NulKubikWork' /* NulKubikWork */, getState('0_userdata.0.Adjustments.Gaszaehler.VerbrauchTotal').val, true);
        console.log('State 0');
      } else if ((obj.state ? obj.state.val : "") == 2) {
        console.log('State 2');
        setState('0_userdata.0.Adjustments.Gaszaehler.LastKubikmeter' /* LastKubikmeter */, parseFloat(getState('0_userdata.0.Adjustments.Gaszaehler.NulKubikWork').val), true);
        setState('0_userdata.0.Adjustments.Gaszaehler.NullKubikmeter' /* NullKubikmeter */, Math.round((getState('0_userdata.0.Adjustments.Gaszaehler.NulKubikWork').val - 0.01 * getState('alias.0.Zaehler.Gas.Pulse').val) * 1000) / 1000, true);
        setState('0_userdata.0.Adjustments.Gaszaehler.VerbrauchTotal' /* VerbrauchTotal */, parseFloat(getState('0_userdata.0.Adjustments.Gaszaehler.NulKubikWork').val), true);
        setStateDelayed('0_userdata.0.Adjustments.Gaszaehler.NullKubikSet' /* NullKubikSet */, 0, true, 1000, false);
    Hier ohne "nach Zahl"
        setState('0_userdata.0.Adjustments.Gaszaehler.LastKubikmeter' /* LastKubikmeter */, getState('0_userdata.0.Adjustments.Gaszaehler.NulKubikWork').val, true);
        setState('0_userdata.0.Adjustments.Gaszaehler.VerbrauchTotal' /* VerbrauchTotal */, getState('0_userdata.0.Adjustments.Gaszaehler.NulKubikWork').val, true);
    Gibt getState() nicht automatisch eine Returnwert mit dem Typ des abgefragen Objekts zurück? ...
    EDIT: Bevor am Userdata Datenpunkt "NullKubikWork" gekrittelt wird - mir ist schon selber aufgefallen, dass die Verwendung von userdata da unnötig wäre, und es eine Variable im Script auch getan hätte ...
    haus-automatisierungH Offline
    @martinp sagte in Merkwürdiges Typ-Problem:
    Es wird sich ja auch über den Typ von
    • '0_userdata.0.Adjustments.Gaszaehler.LastKubikmeter' und
    • '0_userdata.0.Adjustments.Gaszaehler.VerbrauchTotal' beschwert.
    Nicht von '0_userdata.0.Adjustments.Gaszaehler.NullKubikmeter'
    Edit: Ach Du kopierst da States hin und her. Verstehe das Script nicht so richtig. Was gibt denn ein
    console.log(typeof getState('0_userdata.0.Adjustments.Gaszaehler.NulKubikWork').val);
    📚 Meine Dokumentation
    HomoranH MartinPM 2 Antworten Letzte Antwort
      @haus-automatisierung und genau das konnte ich nicht genau entziffern, aber ich glaube es geht anscheinend um die Stelle im Blockly, die den Wert aus einem DP Typ Number nimmt und dort hineinschreibt.
      Dann müsste der geschriebene Wert doch gar nicht gewandelt werden
      auch EDIT:
      ja, das ist es
        auch EDIT:
        ja, das ist es
        @homoran sagte in Merkwürdiges Typ-Problem:
        Na das kommt drauf an, was wirklich in dem State steht. Nur weil der definierte Typ auf dem Objekt number ist, heißt es ja nicht, dass da auch wirklich mal ein numerischer State gespeichert worden ist.
        Eventuell wurde ja mal ein String gespeichert (auch mit einer Warnung) und jetzt wird der String da zurückgeliefert...
        Nur weil man den Typ auf dem Objekt umstellt, findet AFAIK kein automatischer Cast des State-Wertes auf den neuen Typ statt.
          MartinPM Offline
          MartinPM Offline
          MartinP
          Ich lese den Gaszähler mit einem induktiven Näherungssensor aus (1 Puls pro 10 Liter Gas), und der schickt manchmal überzählige Pulse.
          Um diese zu korrigieren habe ich einen Vis 1.x View provisorisch gebastelt, bei dem man durch Eintippen des realen Zählerstandes eine Korrektur auslösen kann...
          Womöglich kommt da durch die "kalte Küche" ein String in den "Zahl" Userdata - Punkt...
          Wäre aber merkwürdig... Widget ist vom Typ "jqui - input"
          • MartinPM MartinP
            Könnte man jetzt raten, oder man schaut einfach in dem State nach :)
            Aber "Zeichen nach Komma" klingt ja schon nach String.
            MartinPM HomoranH 2 Antworten Letzte Antwort
              MartinPM Offline
              MartinPM Offline
              MartinP
              @haus-automatisierung Wie kann man das "typeof" als Blockly formulieren? - stehe da gerade auf dem Schlauch...
              EDIT
              Habe nach "T" gesucht, nicht nach "O" ;-)
              haus-automatisierungH paul53P 2 Antworten Letzte Antwort
              • MartinPM MartinP
                EDIT
                Nimm doch einfach kurz ein neues JavaScript. Der Block von Dir nimmt type des Objektes (und nicht den "echten" Datentyp des verknüpften States).
                Den kennst Du ja schon. Da kommt state raus.
                • MartinPM MartinP
                  EDIT
                  @martinp sagte: Wie kann man das "typeof" als Blockly formulieren?
                    MartinPM Offline
                    MartinPM Offline
                    MartinP
                    "script.js.Energiezaehler.Gaszaehler: NulKubikWork ist vom Typ string"
                    Aber merkwürdig - Wieso hat der nicht gesetzte Haken "als String" nicht dazu geführt, dass da eine Float-Zahl aus dem Vis View übertragen wurde?
                    • MartinPM MartinP
                      @martinp sagte: Wieso hat der nicht gesetzte Haken "als String" nicht dazu geführt, dass da eine Float-Zahl aus dem Vis View übertragen wurde?
                      Vermutung: Komma anstelle Punkt eingegeben?
                        @haus-automatisierung sagte in Merkwürdiges Typ-Problem:
                        reingefallen 😁
                        ist Zeichen nach Punkt. und nur für die Darstellung
                          reingefallen 😁
                          Alleine der Begriff "Zeichen" lässt doch schon einen String vermuten. Oder die Option hat nur eine Wirkung, wenn man auch "als String" anhakt. Fragen über Fragen. Da müsste man wohl das Widget genauer anschauen um das zu verstehen.
                            MartinPM Offline
                            MartinPM Offline
                            MartinP
                            @paul53 said in Merkwürdiges Typ-Problem:
                            Das scheint der Fall zu sein - wenn ich im Datenpunkt den Typ auf "Zahl" ändere, ist das auch nur von kurzer Dauer, dann wird das wieder nach String geändert ...
                            Vielleicht liegt es am jqui-input control, was unbedingt einen Dezimalpunkt nutzen will ...
                              da kennst du die Historie und den Entwickler wohl nicht ;-)
                                MartinPM Offline
                                MartinPM Offline
                                MartinP
                                @homoran Das ist eine merkwürdige Geschichte, irgendwie im Dunstkreis des üblichen Punkt/Komma Ärgers ...
                                dieses Jqui - input Control scheint da bei unverändertem Zurückschreiben des Wertes aus der Maske den Typ auf "Number" zu belassen, und sobald man die letze Nachpunktstelle editiert wird der Typ auf String geändert ...
                                Editiert man auch den Dezimalpunkt, und ersetzt ihn durch ein Komma, werden alle Nachkommastelle auf Null gesetzt ...
                                Das Control scheint unbrauchbar oder zumindest "sperrig" bei deutscher Lokalisierung ...
                                paul53P haus-automatisierungH 2 Antworten Letzte Antwort
                                • MartinPM MartinP
                                  @martinp sagte: Das Control scheint unbrauchbar
                                  Gerade getestet: Das Widget liefert immer einen String - egal ob mit Punkt oder Komma.
                                    MartinPM Offline
                                    MartinPM Offline
                                    MartinP
                                    @paul53 Ich habe jetzt erstmal aus der Not an dieser Stelle auf String umgestellt ...
                                    Userdata Variable auf Typ "String" umgestellt, und "als String" im Control angehakt - dann weiß man wenigstens dass nicht in irgendwelchen Situationen doch eine Zahl geschrieben wird ....
                                    Wäre wirklich interessant, ob das bei Vis.2 besser wird ...
                                    • MartinPM MartinP
                                      Da gibt es keinen Ärger. Ganz einfache Regel: Immer mit Punkt und der US-Schreibweise arbeiten. Also dem richtigen Datentypen. Und das Frontend (Admin-Adapter, VIS, Grafana, …) formatiert den Wert entsprechend der Locale des Nutzers. Alles andere führt nur zu Problemen und ständigen Typkonvertierungen.
                                      Dann hat man auch keine Probleme mit Scripts, Berechnungen, in JSON, InfluxDB/Datenbanken usw.
                                        MartinPM Offline
                                        MartinPM Offline
                                        MartinP
                                        @haus-automatisierung Das wäre schön - und dann gibt es irgendein Widget, das sagt LOCAL=DE, also Dezimalzeichen AUSSCHLIESSLICH Komma... wenn ich einen Punkt sehe, ist das also ein String ....
                                        • MartinPM MartinP
                                          MartinPM Offline
                                          MartinPM Offline
                                          MartinP
                                          Jetzt muss ich erstmal meine Influx-DB "frisieren" und einen Fehlschuss durch die Experimente mit der Kalibrierung der Gaszählermessung entfernen ....
