  5. Merkwürdiges Typ-Problem
    6.7k
24 Beiträge 4 Kommentatoren 1.1k Aufrufe 2 Beobachtet
  • MartinPM Offline
    MartinPM Offline
    MartinP
    Heute habe ich folgende zwei Warnungen im Logging entdeckt, nachdem ich die Fehlpuls-Korrektur meiner Pulszähler-Mimik am Gaszähler durchgeführt habe.
    2024-02-14 07:52:30.311 - warn: javascript.0 (63494) You are assigning a string to the state "0_userdata.0.Adjustments.Gaszaehler.LastKubikmeter" which expects a number. Please fix your code to use a number or change the state type to string. This warning might become an error in future versions.
    2024-02-14 07:52:30.315 - warn: javascript.0 (63494) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1740:20)
    2024-02-14 07:52:30.316 - warn: javascript.0 (63494) at Object. (script.js.Energiezaehler.Gaszaehler:27:5)
    2024-02-14 07:52:30.316 - warn: javascript.0 (63494) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1266:38)
    2024-02-14 07:52:30.316 - warn: javascript.0 (63494) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:645:29)
    2024-02-14 07:52:30.316 - warn: javascript.0 (63494) at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11229:62)
    2024-02-14 07:52:30.316 - warn: javascript.0 (63494) at processImmediate (node:internal/timers:476:21)
    2024-02-14 07:52:30.317 - warn: javascript.0 (63494) You are assigning a string to the state "0_userdata.0.Adjustments.Gaszaehler.VerbrauchTotal" which expects a number. Please fix your code to use a number or change the state type to string. This warning might become an error in future versions.
    2024-02-14 07:52:30.319 - warn: javascript.0 (63494) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1740:20)
    2024-02-14 07:52:30.319 - warn: javascript.0 (63494) at Object. (script.js.Energiezaehler.Gaszaehler:29:5)
    2024-02-14 07:52:30.319 - warn: javascript.0 (63494) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1266:38)
    2024-02-14 07:52:30.320 - warn: javascript.0 (63494) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:645:29)
    2024-02-14 07:52:30.320 - warn: javascript.0 (63494) at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11229:62)
    2024-02-14 07:52:30.320 - warn: javascript.0 (63494) at processImmediate (node:internal/timers:476:21)
    Heilen konnte ich das im Blockly der Korrekturprozedur durch eingefügte "Nach Zahl" Blöcke...
    Merkwürdigerweise ist aber NullKubikWork gar kein String ...
    Hat da jemand eine Idee, was das sein könnte?
    Javascript Code mit "nach Zahl"
    on({ id: '0_userdata.0.Adjustments.Gaszaehler.NullKubikSet' /* NullKubikSet */, change: 'ne' }, async (obj) => {
      let value = obj.state.val;
      let oldValue = obj.oldState.val;
      if ((obj.state ? obj.state.val : "") == 0 && (obj.state ? obj.state.from : "") != 'system.adapter.javascript.0') {
        setState('0_userdata.0.Adjustments.Gaszaehler.NulKubikWork' /* NulKubikWork */, getState('0_userdata.0.Adjustments.Gaszaehler.VerbrauchTotal').val, true);
        console.log('State 0');
      } else if ((obj.state ? obj.state.val : "") == 2) {
        console.log('State 2');
        setState('0_userdata.0.Adjustments.Gaszaehler.LastKubikmeter' /* LastKubikmeter */, parseFloat(getState('0_userdata.0.Adjustments.Gaszaehler.NulKubikWork').val), true);
        setState('0_userdata.0.Adjustments.Gaszaehler.NullKubikmeter' /* NullKubikmeter */, Math.round((getState('0_userdata.0.Adjustments.Gaszaehler.NulKubikWork').val - 0.01 * getState('alias.0.Zaehler.Gas.Pulse').val) * 1000) / 1000, true);
        setState('0_userdata.0.Adjustments.Gaszaehler.VerbrauchTotal' /* VerbrauchTotal */, parseFloat(getState('0_userdata.0.Adjustments.Gaszaehler.NulKubikWork').val), true);
        setStateDelayed('0_userdata.0.Adjustments.Gaszaehler.NullKubikSet' /* NullKubikSet */, 0, true, 1000, false);
    Hier ohne "nach Zahl"
        setState('0_userdata.0.Adjustments.Gaszaehler.LastKubikmeter' /* LastKubikmeter */, getState('0_userdata.0.Adjustments.Gaszaehler.NulKubikWork').val, true);
        setState('0_userdata.0.Adjustments.Gaszaehler.VerbrauchTotal' /* VerbrauchTotal */, getState('0_userdata.0.Adjustments.Gaszaehler.NulKubikWork').val, true);
    Gibt getState() nicht automatisch eine Returnwert mit dem Typ des abgefragen Objekts zurück? ...
    EDIT: Bevor am Userdata Datenpunkt "NullKubikWork" gekrittelt wird - mir ist schon selber aufgefallen, dass die Verwendung von userdata da unnötig wäre, und es eine Variable im Script auch getan hätte ...
    HomoranH haus-automatisierungH 2 Antworten Letzte Antwort
    • MartinPM MartinP
      @martinp kannst du bitte das log als Text in code-tags posten.
        MartinPM Offline
        MartinPM Offline
        MartinP
        @homoran Mache ich gleich oben in Eröffnungspost ... finde aber dass das was man als Text bekommt, wenn man aus dem "Protokolle" Fenster im Browser koplert manchmal etwas komisch formatiernn
        • MartinPM MartinP
          @martinp sagte in Merkwürdiges Typ-Problem:
          nöö! das sollst du ja auch nicht :-)
          das entsprechende log über den Button herunterladen und dort heraus kopieren
          • MartinPM MartinP
            haus-automatisierungH Offline
            Es wird sich ja auch über den Typ von
            • '0_userdata.0.Adjustments.Gaszaehler.LastKubikmeter' und
            • '0_userdata.0.Adjustments.Gaszaehler.VerbrauchTotal' beschwert.
            Nicht von '0_userdata.0.Adjustments.Gaszaehler.NullKubikmeter'
            Edit: Ach Du kopierst da States hin und her. Verstehe das Script nicht so richtig. Was gibt denn ein
            console.log(typeof getState('0_userdata.0.Adjustments.Gaszaehler.NulKubikWork').val);
            📚 Meine Dokumentation
            HomoranH MartinPM 2 Antworten Letzte Antwort
              @haus-automatisierung und genau das konnte ich nicht genau entziffern, aber ich glaube es geht anscheinend um die Stelle im Blockly, die den Wert aus einem DP Typ Number nimmt und dort hineinschreibt.
              Dann müsste der geschriebene Wert doch gar nicht gewandelt werden
              auch EDIT:
              ja, das ist es
                auch EDIT:
                ja, das ist es
                @homoran sagte in Merkwürdiges Typ-Problem:
                Na das kommt drauf an, was wirklich in dem State steht. Nur weil der definierte Typ auf dem Objekt number ist, heißt es ja nicht, dass da auch wirklich mal ein numerischer State gespeichert worden ist.
                Eventuell wurde ja mal ein String gespeichert (auch mit einer Warnung) und jetzt wird der String da zurückgeliefert...
                Nur weil man den Typ auf dem Objekt umstellt, findet AFAIK kein automatischer Cast des State-Wertes auf den neuen Typ statt.
                  MartinPM Offline
                  MartinPM Offline
                  MartinP
                  Ich lese den Gaszähler mit einem induktiven Näherungssensor aus (1 Puls pro 10 Liter Gas), und der schickt manchmal überzählige Pulse.
                  Um diese zu korrigieren habe ich einen Vis 1.x View provisorisch gebastelt, bei dem man durch Eintippen des realen Zählerstandes eine Korrektur auslösen kann...
                  Womöglich kommt da durch die "kalte Küche" ein String in den "Zahl" Userdata - Punkt...
                  Wäre aber merkwürdig... Widget ist vom Typ "jqui - input"
                  • MartinPM MartinP
                    Könnte man jetzt raten, oder man schaut einfach in dem State nach :)
                    Aber "Zeichen nach Komma" klingt ja schon nach String.
                    MartinPM HomoranH 2 Antworten Letzte Antwort
                      MartinPM Offline
                      MartinPM Offline
                      MartinP
                      @haus-automatisierung Wie kann man das "typeof" als Blockly formulieren? - stehe da gerade auf dem Schlauch...
                      EDIT
                      Habe nach "T" gesucht, nicht nach "O" ;-)
                      haus-automatisierungH paul53P 2 Antworten Letzte Antwort
                      • MartinPM MartinP
                        EDIT
                        Nimm doch einfach kurz ein neues JavaScript. Der Block von Dir nimmt type des Objektes (und nicht den "echten" Datentyp des verknüpften States).
                        Den kennst Du ja schon. Da kommt state raus.
                        • MartinPM MartinP
                          EDIT
                          @martinp sagte: Wie kann man das "typeof" als Blockly formulieren?
                            MartinPM Offline
                            MartinPM Offline
                            MartinP
                            "script.js.Energiezaehler.Gaszaehler: NulKubikWork ist vom Typ string"
                            Aber merkwürdig - Wieso hat der nicht gesetzte Haken "als String" nicht dazu geführt, dass da eine Float-Zahl aus dem Vis View übertragen wurde?
                            • MartinPM MartinP
                              @martinp sagte: Wieso hat der nicht gesetzte Haken "als String" nicht dazu geführt, dass da eine Float-Zahl aus dem Vis View übertragen wurde?
                              Vermutung: Komma anstelle Punkt eingegeben?
                                @haus-automatisierung sagte in Merkwürdiges Typ-Problem:
                                reingefallen 😁
                                ist Zeichen nach Punkt. und nur für die Darstellung
                                  reingefallen 😁
                                  Alleine der Begriff "Zeichen" lässt doch schon einen String vermuten. Oder die Option hat nur eine Wirkung, wenn man auch "als String" anhakt. Fragen über Fragen. Da müsste man wohl das Widget genauer anschauen um das zu verstehen.
                                    MartinPM Offline
                                    MartinPM Offline
                                    MartinP
                                    @paul53 said in Merkwürdiges Typ-Problem:
                                    Das scheint der Fall zu sein - wenn ich im Datenpunkt den Typ auf "Zahl" ändere, ist das auch nur von kurzer Dauer, dann wird das wieder nach String geändert ...
                                    Vielleicht liegt es am jqui-input control, was unbedingt einen Dezimalpunkt nutzen will ...
                                      da kennst du die Historie und den Entwickler wohl nicht ;-)
                                        MartinPM Offline
                                        MartinPM Offline
                                        MartinP
                                        @homoran Das ist eine merkwürdige Geschichte, irgendwie im Dunstkreis des üblichen Punkt/Komma Ärgers ...
                                        dieses Jqui - input Control scheint da bei unverändertem Zurückschreiben des Wertes aus der Maske den Typ auf "Number" zu belassen, und sobald man die letze Nachpunktstelle editiert wird der Typ auf String geändert ...
                                        Editiert man auch den Dezimalpunkt, und ersetzt ihn durch ein Komma, werden alle Nachkommastelle auf Null gesetzt ...
                                        Das Control scheint unbrauchbar oder zumindest "sperrig" bei deutscher Lokalisierung ...
                                        paul53P haus-automatisierungH 2 Antworten Letzte Antwort
                                        • MartinPM MartinP
                                          @martinp sagte: Das Control scheint unbrauchbar
                                          Gerade getestet: Das Widget liefert immer einen String - egal ob mit Punkt oder Komma.
