  4. Update js-Controller 3.x auf 5.x funktioniert nicht
67 Beiträge 7 Kommentatoren 10.8k Aufrufe 5 Beobachtet
  • F Frank-KNX
    Und hier noch das Summary:
                            v.2023-10-10
       Static hostname: raspberrypi
             Icon name: computer
      Operating System: Raspbian GNU/Linux 10 (buster)
                Kernel: Linux 5.10.103-v7l+
          Architecture: arm
    Kernel:                 armv7l
    Userland:               armhf
    Timezone:               Europe/Berlin (CET, +0100)
    User-ID:                1000
    X-Server:               true
    Pending OS-Updates:     0
    Pending iob updates:    14
    Nodejs-Installation:    /usr/bin/nodejs         v18.19.0
                            /usr/bin/node           v18.19.0
                            /usr/bin/npm            10.2.3
                            /usr/bin/npx            10.2.3
                            /usr/bin/corepack       0.22.0
    Recommended versions are nodejs  and npm
    MEMORY:
    Mem:           7.9G        1.1G        6.1G         39M        755M        6.6G
    Swap:           99M          0B         99M
    Total:         8.0G        1.1G        6.2G
    Active iob-Instances:   26
    Active repo: Stable (default)
    ioBroker Core:          js-controller           3.1.6
                            admin                   4.1.11
    At least one iobroker host is running.
    Objects type: file
    States  type: file
    + system.adapter.admin.0                 : admin                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.web.0                   : web                   -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    Objects:                3504
    States:                 2438
    Size of iob-Database:
    6.3M    /opt/iobroker/iobroker-data/objects.json.bak
    656K    /opt/iobroker/iobroker-data/states.json.bak
    @frank-knx
    iob update
    iob upgrade
    iob stop
    iob upgrade self
    iob start
    F 1 Antwort Letzte Antwort
      @frank-knx
      iob update
      iob upgrade
      iob stop
      iob upgrade self
      iob start
      Frank-KNX
      Hallo Thomas,
      also bei upgrade self bleibt er wieder hängen.
      Nachfolgend die Fehlermeldung:
      pi@raspberrypi:~ $ iob upgrade self
      Update js-controller from @3.1.6 to @5.0.17
      NPM version: 10.2.3
      npm install iobroker.js-controller@5.0.17 --loglevel error --unsafe-perm --prefix "/opt/iobroker" (System call)
       Objects 127.0.0.1:36630 Error from InMemDB: Error: CONFIG-UNSUPPORTED for ["SET","lua-time-limit","10000"]
       States 127.0.0.1:43550 Error from InMemDB: Error: CONFIG-UNSUPPORTED for ["SET","notify-keyspace-events","Exe"]
       Objects 127.0.0.1:36630 Error from InMemDB: Error: GET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.features.useSets"]
       States 127.0.0.1:43550 Error from InMemDB: Error: GET-UNSUPPORTED for namespace meta.: Data=["meta.states.protocolVersion"]
       Objects 127.0.0.1:36630 Error from InMemDB: Error: GET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.protocolVersion"]
       Objects 127.0.0.1:36630 Error from InMemDB: Error: scan NOT SUPPORTED
      npm ERR! code 1
      npm ERR! path /opt/iobroker/node_modules/iobroker.js-controller
      npm ERR! command failed
      npm ERR! command sh -c node iobroker.js setup first
      npm ERR! Unable to increase LUA script timeout: Error CONFIG-UNSUPPORTED for ["SET","lua-time-limit","10000"]
      npm ERR!  Unable to enable Expiry Keyspace events from Redis Server: Error CONFIG-UNSUPPORTED for ["SET","notify-keyspace-events","Exe"]
      npm ERR! /opt/iobroker/node_modules/standard-as-callback/built/index.js:6
      npm ERR!         throw e;
      npm ERR!         ^
      npm ERR!
      npm ERR! ReplyError: Error scan NOT SUPPORTED
      npm ERR!     at parseError (/opt/iobroker/node_modules/redis-parser/lib/parser.js:179:12)
      npm ERR!     at parseType (/opt/iobroker/node_modules/redis-parser/lib/parser.js:302:14)
      npm ERR! Emitted 'error' event on ScanStream instance at:
      npm ERR!     at /opt/iobroker/node_modules/ioredis/built/ScanStream.js:38:22
      npm ERR!     at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:12:23)
      npm ERR!     at /opt/iobroker/node_modules/standard-as-callback/built/index.js:33:51
      npm ERR!     at process.processTicksAndRejections (node:internal/process/task_queues:95:5) {
      npm ERR!   command: {
      npm ERR!     name: 'scan',
      npm ERR!     args: [ '0', 'MATCH', 'cfg.o.system.host.*', 'COUNT', '250' ]
      npm ERR!   }
      npm ERR! }
      npm ERR!
      npm ERR! Node.js v18.19.0
      npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-02-03T00_01_36_505Z-debug-0.log
      Starting node restart.js
      pi@raspberrypi:~ $
      • F Frank-KNX
        Hallo Thomas,
        NPM version: 10.2.3
        npm ERR! code 1
        npm ERR!         throw e;
        npm ERR!         ^
        npm ERR!
        npm ERR!   command: {
        npm ERR!   }
        npm ERR! }
        npm ERR!
        pi@raspberrypi:~ $
        @frank-knx
        Die Adapter-Updates sind durch?
        iob update
        sagt?
          @frank-knx
          iob update
          sagt?
          Frank-KNX
          Ja, Updates sind ohne Fehlermeldung durchgelaufen. Auch das iob upgrade.
          Erst nach iob stop und dann upgrade self die Fehlermeldung.
          • F Frank-KNX
            Frank-KNX
            Muss noch ergänzen..
            Nachfolgend upgrade...
            Alles nicht instalierten Adapter werden angezeigt.. aber die installierten meldet er, als nicht upgedated, weil die JS-Controller Version ja bekanntlich zu alt ist => Das will ich ja gerade ändern...
            Adapter "accuweather"    is not installed.
            Adapter "acme"           is not installed.
            Adapter "adb"            is not installed.
            Adapter "adguard"        is not installed.
            Invalid version of "js-controller". Installed "3.1.6", required ">=3.3.22
            Adapter "aio"            is not installed.
            Adapter "airconwithme"   is not installed.
            Adapter "airzone"        is not installed.
            Adapter "alarm"          is not installed.
            Adapter "alexa-shoppinglist" is not installed.
            Adapter "alexa-timer-vis" is not installed.
            Adapter "alexa2"         is not installed.
            Adapter "alias-manager"  is not installed.
            Adapter "alpha-ess"      is not installed.
            Adapter "alpha2"         is not installed.
            Adapter "amazon-dash"    is not installed.
            Adapter "amtronwallbox"  is not installed.
            Adapter "anelhut"        is not installed.
            Adapter "apcups"         is not installed.
            Adapter "apg-info"       is not installed.
            Adapter "artnet"         is not installed.
            Adapter "artnet-recorder" is not installed.
            Adapter "asterisk"       is not installed.
            Adapter "asuswrt"        is not installed.
            Adapter "atlas-scientific-ezo-i2c" is not installed.
            Adapter "awattar"        is not installed.
            Adapter "awtrix-light"   is not installed.
            Adapter "b-control-em"   is not installed.
            Invalid version of "js-controller". Installed "3.1.6", required ">=4.0.0
            Adapter "beckhoff"       is not installed.
            Adapter "benchmark"      is not installed.
            Adapter "benq"           is not installed.
            Adapter "bestway"        is not installed.
            Adapter "bidirectional-counter" is not installed.
            Adapter "birthdays"      is not installed.
            Adapter "ble"            is not installed.
            Adapter "blebox"         is not installed.
            Adapter "bluelink"       is not installed.
            Adapter "bmw"            is not installed.
            Adapter "bosch-ebike"    is not installed.
            Adapter "bosesoundtouch" is not installed.
            Adapter "botslab360"     is not installed.
            Adapter "botvac"         is not installed.
            Adapter "bring"          is not installed.
            Adapter "broadlink2"     is not installed.
            Adapter "bsblan"         is not installed.
            Adapter "bshb"           is not installed.
            Adapter "bwt"            is not installed.
            Adapter "bydbatt"        is not installed.
            Adapter "bydhvs"         is not installed.
            Adapter "canbus"         is not installed.
            Adapter "cec2"           is not installed.
            Adapter "chromecast"     is not installed.
            Adapter "cleveron"       is not installed.
            Adapter "cloud"          is not installed.
            Adapter "cloudflare"     is not installed.
            Adapter "comfoair"       is not installed.
            Adapter "contactid"      is not installed.
            Adapter "coronavirus-statistics" is not installed.
            Adapter "countdown"      is not installed.
            Adapter "cul"            is not installed.
            Adapter "daikin"         is not installed.
            Adapter "daikin-cloud"   is not installed.
            Adapter "daswetter"      is not installed.
            Adapter "deconz"         is not installed.
            Adapter "denon"          is not installed.
            Adapter "device-reminder" is not installed.
            Adapter "device-watcher" is not installed.
            Adapter "devices"        is not installed.
            Adapter "deyeidc"        is not installed.
            Adapter "digitalstrom"   is not installed.
            Adapter "discord"        is not installed.
            Adapter "discovergy"     is not installed.
            Adapter "discovery"      is up to date.
            Adapter "divera247"      is not installed.
            Adapter "doorbird"       is not installed.
            Adapter "doorio"         is not installed.
            Adapter "drag-indicator" is not installed.
            Adapter "ds18b20"        is not installed.
            Adapter "dwd"            is not installed.
            Adapter "dysonairpurifier" is not installed.
            Adapter "e3dc-rscp"      is not installed.
            Adapter "easee"          is not installed.
            Adapter "ebus"           is not installed.
            Adapter "echarts"        is not installed.
            Adapter "ecovacs-deebot" is not installed.
            Adapter "egigeozone"     is not installed.
            Adapter "ekey"           is not installed.
            Adapter "elero-usb-transmitter" is not installed.
            Adapter "email"          is not installed.
            Adapter "emby"           is not installed.
            Adapter "emporia"        is not installed.
            Adapter "ems-esp"        is not installed.
            Adapter "energiefluss"   is not installed.
            Adapter "energymanager"  is not installed.
            Adapter "enet"           is not installed.
            Adapter "enigma2"        is not installed.
            Adapter "envertech-pv"   is not installed.
            Adapter "epson_ecotank_et_2750" is not installed.
            Adapter "epson_stylus_px830" is not installed.
            Adapter "eusec"          is not installed.
            Adapter "evcc"           is not installed.
            Adapter "eventlist"      is not installed.
            Adapter "exchangerates"  is not installed.
            Adapter "fahrplan"       is not installed.
            Adapter "fakeroku"       is not installed.
            Adapter "fb-checkpresence" is not installed.
            Adapter "feiertage"      is not installed.
            Adapter "fhem"           is not installed.
            Adapter "fiat"           is not installed.
            Adapter "firetv"         is not installed.
            Adapter "fitbit-fitness" is not installed.
            Adapter "flot"           is not installed.
            Adapter "followthesun"   is not installed.
            Adapter "foobar2000"     is not installed.
            Adapter "ford"           is not installed.
            Adapter "frigate"        is not installed.
            Adapter "fritzbox"       is not installed.
            Adapter "fritzdect"      is not installed.
            Adapter "froeling"       is not installed.
            Adapter "fronius"        is not installed.
            Adapter "fronius-solarweb" is not installed.
            Adapter "fronius-wattpilot" is not installed.
            Adapter "frontier_silicon" is not installed.
            Adapter "fuelpricemonitor" is not installed.
            Adapter "fullcalendar"   is not installed.
            Adapter "fullybrowser"   is not installed.
            Adapter "g-homa"         is not installed.
            Adapter "garmin"         is not installed.
            Adapter "geofency"       is not installed.
            Adapter "gigaset-elements" is not installed.
            Adapter "gira-iot"       is not installed.
            Adapter "go-e"           is not installed.
            Adapter "govee-local"    is not installed.
            Adapter "growatt"        is not installed.
            Adapter "gruenbeck"      is not installed.
            Adapter "gsmsms"         is not installed.
            Adapter "haassohn"       is not installed.
            Adapter "habpanel"       is not installed.
            Adapter "haier"          is not installed.
            Adapter "ham"            is not installed.
            Adapter "ham-wemo"       is not installed.
            Adapter "harmony"        is not installed.
            Adapter "hass"           is not installed.
            Adapter "hausbus_de"     is not installed.
            Adapter "heatingcontrol" is not installed.
            Adapter "heizoel"        is not installed.
            Adapter "heizungssteuerung" is not installed.
            Adapter "hekr"           is not installed.
            Adapter "helios"         is not installed.
            Adapter "heos"           is not installed.
            Adapter "heytech"        is not installed.
            Adapter "hid-community"  is not installed.
            Adapter "hikvision-alarmserver" is not installed.
            Adapter "history"        is not installed.
            Adapter "hm-rega"        is not installed.
            Adapter "hm-rpc"         is not installed.
            Adapter "hmip"           is not installed.
            Adapter "homeconnect"    is not installed.
            Adapter "homee"          is not installed.
            Adapter "homekit-controller" is not installed.
            Adapter "homenet"        is not installed.
            Adapter "homepilot"      is not installed.
            Adapter "hoover"         is not installed.
            Adapter "hp-ilo"         is not installed.
            Adapter "hs100"          is not installed.
            Adapter "hue"            is not installed.
            Adapter "huum-sauna"     is not installed.
            Adapter "i2c"            is not installed.
            Invalid version of "admin". Installed "4.1.11", required ">=5.3.2
            Adapter "iceroad"        is not installed.
            Adapter "ico-cloud"      is not installed.
            Adapter "icons-addictive-flavour-png" is not installed.
            Adapter "icons-eclipse-smarthome-classic" is not installed.
            Adapter "icons-fatcow-hosting" is not installed.
            Adapter "icons-freepic"  is not installed.
            Adapter "icons-icons8"   is not installed.
            Adapter "icons-material-png" is not installed.
            Adapter "icons-material-svg" is not installed.
            Adapter "icons-mfd-png"  is up to date.
            Adapter "icons-mfd-svg"  is not installed.
            Adapter "icons-open-icon-library-png" is not installed.
            Adapter "icons-smarthome" is not installed.
            Adapter "icons-ultimate-png" is not installed.
            Adapter "ikettle2"       is not installed.
            Adapter "imap"           is not installed.
            Adapter "imow"           is not installed.
            Invalid version of "js-controller". Installed "3.1.6", required ">=3.3.0
            Update info from @1.7.10 to @2.0.0
            NPM version: 10.2.3
            npm install iobroker.info@2.0.0 --loglevel error --prefix "/opt/iobroker" (System call)
            Adapter "system.adapter.vis.0" restarted.
            Update "system.adapter.info.0"
            upload [90] info.admin /opt/iobroker/node_modules/iobroker.info/admin/tab_m.html tab_m.html text/html
            upload [80] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/helper.js lib/js/helper.js application/javascript
            upload [70] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/bootbox.min.js lib/js/bootbox.min.js application/javascript
            upload [60] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/logos/redhat.png lib/img/logos/redhat.png image/png
            upload [50] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/logos/mandriva.png lib/img/logos/mandriva.png image/png
            upload [40] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/logos/centos.png lib/img/logos/centos.png image/png
            upload [30] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/icons/graphics.png lib/img/icons/graphics.png image/png
            upload [20] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/clock/clockface.png lib/img/clock/clockface.png image/png
            upload [19] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/fonts/fontawesome-webfont.svg lib/fonts/fontawesome-webfont.svg image/svg+xml
            upload [18] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/data/infoData.json lib/data/infoData.json application/json
            upload [17] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/css/simplemde.min.css lib/css/simplemde.min.css text/css
            upload [16] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/css/info.css lib/css/info.css text/css
            upload [15] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/css/font-awesome.min.css lib/css/font-awesome.min.css text/css
            upload [14] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/css/chartist.min.css lib/css/chartist.min.css text/css
            upload [13] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/css/bootstrap.min.css lib/css/bootstrap.min.css text/css
            upload [12] info.admin /opt/iobroker/node_modules/iobroker.info/admin/info.png info.png image/png
            upload [11] info.admin /opt/iobroker/node_modules/iobroker.info/admin/index_m.html index_m.html text/html
            upload [10] info.admin /opt/iobroker/node_modules/iobroker.info/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
            upload [9] info.admin /opt/iobroker/node_modules/iobroker.info/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
            upload [8] info.admin /opt/iobroker/node_modules/iobroker.info/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
            upload [7] info.admin /opt/iobroker/node_modules/iobroker.info/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
            upload [6] info.admin /opt/iobroker/node_modules/iobroker.info/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
            upload [5] info.admin /opt/iobroker/node_modules/iobroker.info/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
            upload [4] info.admin /opt/iobroker/node_modules/iobroker.info/admin/i18n/it/translations.json i18n/it/translations.json application/json
            upload [3] info.admin /opt/iobroker/node_modules/iobroker.info/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
            upload [2] info.admin /opt/iobroker/node_modules/iobroker.info/admin/i18n/es/translations.json i18n/es/translations.json application/json
            upload [1] info.admin /opt/iobroker/node_modules/iobroker.info/admin/i18n/en/translations.json i18n/en/translations.json application/json
            upload [0] info.admin /opt/iobroker/node_modules/iobroker.info/admin/i18n/de/translations.json i18n/de/translations.json application/json
            Adapter "info" updated
            Adapter "innogy-smarthome" is not installed.
            Adapter "innoxel"        is not installed.
            Adapter "intex"          is not installed.
            Adapter "iot"            is not installed.
            Adapter "iqontrol"       is not installed.
            Adapter "iwg-vpn"        is not installed.
            Adapter "janitza-gridvis" is not installed.
            Adapter "jarvis"         is not installed.
            Invalid version of "admin". Installed "4.1.11", required ">=5.1.28
            Adapter "jeelink"        is not installed.
            Adapter "judoisoft"      is not installed.
            Adapter "kecontact"      is not installed.
            Adapter "klf200"         is not installed.
            Adapter "knmi-weather"   is not installed.
            Adapter "kodi"           is not installed.
            Adapter "kostal-piko-ba" is not installed.
            Adapter "lametric"       is not installed.
            Adapter "lcn"            is not installed.
            Adapter "legrand-ecocompteur" is not installed.
            Adapter "letrika_comgw"  is not installed.
            Adapter "lg-ess-home"    is not installed.
            Adapter "lg-thinq"       is not installed.
            Adapter "lgtv"           is not installed.
            Adapter "lgtv-rs"        is not installed.
            Adapter "lgtv11"         is not installed.
            Adapter "libre"          is not installed.
            Adapter "lifx"           is not installed.
            Adapter "lightcontrol"   is not installed.
            Adapter "lightify"       is not installed.
            Adapter "link"           is not installed.
            Adapter "link2home"      is not installed.
            Adapter "linkeddevices"  is not installed.
            Adapter "linktap"        is not installed.
            Update linux-control from @1.1.2 to @1.1.5
            NPM version: 10.2.3
            npm install iobroker.linux-control@1.1.5 --loglevel error --prefix "/opt/iobroker" (System call)
            upload [20] linux-control.admin /opt/iobroker/node_modules/iobroker.linux-control/admin/words.js words.js application/javascript
            Update "system.adapter.linux-control.0"
            upload [19] linux-control.admin /opt/iobroker/node_modules/iobroker.linux-control/admin/style.css style.css text/css
            upload [18] linux-control.admin /opt/iobroker/node_modules/iobroker.linux-control/admin/linux-control.png linux-control.png image/png
            upload [17] linux-control.admin /opt/iobroker/node_modules/iobroker.linux-control/admin/lib/updates.json lib/updates.json application/json
            upload [16] linux-control.admin /opt/iobroker/node_modules/iobroker.linux-control/admin/lib/services.json lib/services.json application/json
            upload [15] linux-control.admin /opt/iobroker/node_modules/iobroker.linux-control/admin/lib/needrestart.json lib/needrestart.json application/json
            upload [14] linux-control.admin /opt/iobroker/node_modules/iobroker.linux-control/admin/lib/jquery.fancytree.dnd5.js lib/jquery.fancytree.dnd5.js application/javascript
            upload [13] linux-control.admin /opt/iobroker/node_modules/iobroker.linux-control/admin/lib/info.json lib/info.json application/json
            upload [12] linux-control.admin /opt/iobroker/node_modules/iobroker.linux-control/admin/lib/distribution.json lib/distribution.json application/json
            upload [11] linux-control.admin /opt/iobroker/node_modules/iobroker.linux-control/admin/lib/control.json lib/control.json application/json
            upload [10] linux-control.admin /opt/iobroker/node_modules/iobroker.linux-control/admin/index_m.js index_m.js application/javascript
            upload [9] linux-control.admin /opt/iobroker/node_modules/iobroker.linux-control/admin/index_m.html index_m.html text/html
            upload [8] linux-control.admin /opt/iobroker/node_modules/iobroker.linux-control/admin/img/state.png img/state.png image/png
            upload [7] linux-control.admin /opt/iobroker/node_modules/iobroker.linux-control/admin/img/menu_right.svg img/menu_right.svg image/svg+xml
            upload [6] linux-control.admin /opt/iobroker/node_modules/iobroker.linux-control/admin/img/menu_down.svg img/menu_down.svg image/svg+xml
            upload [5] linux-control.admin /opt/iobroker/node_modules/iobroker.linux-control/admin/img/info-big.png img/info-big.png image/png
            upload [4] linux-control.admin /opt/iobroker/node_modules/iobroker.linux-control/admin/img/folder.png img/folder.png image/png
            upload [3] linux-control.admin /opt/iobroker/node_modules/iobroker.linux-control/admin/img/checkbox_marked.svg img/checkbox_marked.svg image/svg+xml
            upload [2] linux-control.admin /opt/iobroker/node_modules/iobroker.linux-control/admin/img/checkbox_intermediate.svg img/checkbox_intermediate.svg image/svg+xml
            upload [1] linux-control.admin /opt/iobroker/node_modules/iobroker.linux-control/admin/img/checkbox.svg img/checkbox.svg image/svg+xml
            upload [0] linux-control.admin /opt/iobroker/node_modules/iobroker.linux-control/admin/admin.d.ts admin.d.ts video/mp2t
            Adapter "linux-control" updated
            Adapter "logparser"      is not installed.
            Adapter "loqed"          is not installed.
            Adapter "lovelace"       is not installed.
            Adapter "lowpass-filter" is not installed.
            Adapter "loxone"         is not installed.
            Adapter "luftdaten"      is not installed.
            Adapter "lupusec"        is not installed.
            Adapter "luxtronik1"     is not installed.
            Adapter "material"       is not installed.
            Adapter "matrix-org"     is not installed.
            Adapter "maveo"          is not installed.
            Adapter "maxcube"        is not installed.
            Adapter "maxcul"         is not installed.
            Adapter "mbus"           is not installed.
            Adapter "mclighting"     is not installed.
            Adapter "meater"         is not installed.
            Adapter "mediola-gateway" is not installed.
            Adapter "megad"          is not installed.
            Adapter "megadd"         is not installed.
            Adapter "megaesp"        is not installed.
            Adapter "melcloud"       is not installed.
            Adapter "mercedesme"     is not installed.
            Adapter "mercury"        is not installed.
            Adapter "meross"         is not installed.
            Adapter "meteoalarm"     is not installed.
            Adapter "micronova"      is not installed.
            Adapter "midea"          is not installed.
            Adapter "miele"          is not installed.
            Adapter "mielecloudservice" is not installed.
            Adapter "mihome"         is not installed.
            Adapter "mihome-cloud"   is not installed.
            Adapter "mihome-lamp"    is not installed.
            Adapter "mihome-plug"    is not installed.
            Adapter "mihome-vacuum"  is not installed.
            Adapter "mikrotik"       is not installed.
            Adapter "milight"        is not installed.
            Adapter "milight-smart-light" is not installed.
            Adapter "minuvis"        is not installed.
            Adapter "mobile"         is not installed.
            Adapter "modbus"         is not installed.
            Adapter "moma"           is not installed.
            Adapter "mpd"            is not installed.
            Adapter "mqtt"           is not installed.
            Adapter "mqtt-client"    is not installed.
            Adapter "musiccast"      is not installed.
            Adapter "mydlink"        is not installed.
            Adapter "myenergi"       is not installed.
            Adapter "mysensors"      is not installed.
            Adapter "mystrom"        is not installed.
            Adapter "myvbus"         is not installed.
            Adapter "nanoleaf-lightpanels" is not installed.
            Adapter "net-tools"      is not installed.
            Adapter "netatmo"        is not installed.
            Adapter "netatmo-crawler" is not installed.
            Adapter "netatmo-energy" is not installed.
            Adapter "nibeuplink"     is not installed.
            Adapter "nina"           is not installed.
            Adapter "nissan"         is not installed.
            Adapter "niu"            is not installed.
            Adapter "notification-manager" is not installed.
            Adapter "nsclient"       is not installed.
            Adapter "nuki"           is not installed.
            Adapter "nuki-extended"  is not installed.
            Adapter "nut"            is not installed.
            Adapter "ocpp"           is not installed.
            Adapter "octoprint"      is not installed.
            Adapter "odl"            is not installed.
            Adapter "oekofen-json"   is not installed.
            Adapter "oilfox"         is not installed.
            Adapter "omnicomm-lls"   is not installed.
            Adapter "onkyo"          is not installed.
            Adapter "onvif"          is not installed.
            Adapter "opendtu"        is not installed.
            Adapter "openhab"        is not installed.
            Adapter "openknx"        is not installed.
            Adapter "openligadb"     is not installed.
            Adapter "openweathermap" is not installed.
            Adapter "operating-hours" is not installed.
            Adapter "opi"            is not installed.
            Adapter "oppoplayer"     is not installed.
            Adapter "owfs"           is not installed.
            Adapter "owntracks"      is not installed.
            Adapter "panasonic-comfort-cloud" is not installed.
            Adapter "panasonic-viera" is not installed.
            Adapter "parcel"         is not installed.
            Adapter "parser"         is not installed.
            Adapter "paw"            is not installed.
            Adapter "pegelalarm"     is not installed.
            Adapter "ph803w"         is not installed.
            Adapter "phantomjs"      is not installed.
            Adapter "philips-air"    is not installed.
            Adapter "philips-tv"     is not installed.
            Adapter "pi-hole"        is not installed.
            Adapter "piface"         is not installed.
            Adapter "pimatic"        is not installed.
            Adapter "ping"           is not installed.
            Adapter "pixelit"        is not installed.
            Adapter "places"         is not installed.
            Adapter "plenticore"     is not installed.
            Adapter "plex"           is not installed.
            Adapter "plexconnect"    is not installed.
            Adapter "pollenflug"     is not installed.
            Adapter "porsche"        is not installed.
            Adapter "powerfox2"      is not installed.
            Adapter "procon-ip"      is not installed.
            Adapter "proxmox"        is not installed.
            Adapter "proxy"          is not installed.
            Adapter "psa"            is not installed.
            Adapter "puppeteer"      is not installed.
            Adapter "pushbullet"     is not installed.
            Adapter "pushover"       is not installed.
            Adapter "pushsafer"      is not installed.
            Adapter "pvforecast"     is not installed.
            Adapter "pvoutputorg"    is not installed.
            Adapter "pylontech"      is not installed.
            Adapter "radar2"         is not installed.
            Adapter "radiohead"      is not installed.
            Adapter "rct"            is not installed.
            Adapter "renacidc"       is not installed.
            Adapter "renault"        is not installed.
            Adapter "reolink"        is not installed.
            Adapter "residents"      is not installed.
            Adapter "resol"          is not installed.
            Adapter "rest-api"       is not installed.
            Adapter "rflink"         is not installed.
            Adapter "rickshaw"       is not installed.
            Adapter "ring"           is not installed.
            Adapter "robonect"       is not installed.
            Adapter "roborock"       is not installed.
            Adapter "roomba"         is not installed.
            Adapter "rpi2"           is not installed.
            Adapter "rssfeed"        is not installed.
            Adapter "s7"             is not installed.
            Adapter "sainlogic"      is not installed.
            Adapter "samsung"        is not installed.
            Adapter "samsung_tizen"  is not installed.
            Adapter "sanext"         is not installed.
            Adapter "sayit"          is not installed.
            Adapter "sbfspot"        is not installed.
            Adapter "scenes"         is not installed.
            Adapter "scheduler"      is not installed.
            Adapter "schoolfree"     is not installed.
            Adapter "schwoerer-ventcube" is not installed.
            Adapter "seko"           is not installed.
            Adapter "selverf"        is not installed.
            Adapter "semp"           is not installed.
            Adapter "seq"            is not installed.
            Adapter "shelly"         is not installed.
            Adapter "shuttercontrol" is not installed.
            Adapter "sia"            is not installed.
            Adapter "siegenia"       is not installed.
            Adapter "signal-cmb"     is not installed.
            Adapter "signifylights"  is not installed.
            Adapter "simple-api"     is up to date.
            Adapter "sma-em"         is not installed.
            Adapter "smappee"        is not installed.
            Adapter "smart-eq"       is not installed.
            Adapter "smartcontrol"   is not installed.
            Adapter "smartgarden"    is not installed.
            Adapter "smartmeter"     is not installed.
            Adapter "smartthings"    is not installed.
            Adapter "snips"          is not installed.
            Adapter "snmp"           is not installed.
            Invalid version of "admin". Installed "4.1.11", required ">=5.0.0
            Adapter "solarlog"       is not installed.
            Adapter "solarmanpv"     is not installed.
            Adapter "solarviewdatareader" is not installed.
            Adapter "solarwetter"    is not installed.
            Adapter "solax"          is not installed.
            Adapter "sonnen"         is not installed.
            Adapter "sonoff"         is not installed.
            Adapter "sonos"          is not installed.
            Adapter "sony-bravia"    is not installed.
            Adapter "spotify-premium" is not installed.
            Adapter "sprinklecontrol" is not installed.
            Adapter "sql"            is not installed.
            Adapter "squeezeboxrpc"  is not installed.
            Adapter "starline"       is not installed.
            Adapter "stiebel-isg"    is not installed.
            Adapter "sureflap"       is not installed.
            Adapter "swiss-weather-api" is not installed.
            Adapter "synochat"       is not installed.
            Adapter "synology"       is not installed.
            Adapter "systeminfo"     is not installed.
            Adapter "tado"           is not installed.
            Adapter "tahoma"         is not installed.
            Adapter "tankerkoenig"   is not installed.
            Adapter "tapo"           is not installed.
            Adapter "telegram"       is not installed.
            Adapter "telegram-menu"  is not installed.
            Adapter "terminal"       is not installed.
            Adapter "tesla-motors"   is not installed.
            Adapter "text2command"   is not installed.
            Adapter "tibberlink"     is not installed.
            Adapter "tinker"         is not installed.
            Adapter "tinymqttbroker" is not installed.
            Adapter "toyota"         is not installed.
            Adapter "tr-064"         is up to date.
            Adapter "traccar"        is not installed.
            Adapter "tractive-gps"   is not installed.
            Adapter "tradfri"        is not installed.
            Invalid version of "js-controller". Installed "3.1.6", required ">=4.0.15
            Adapter "trivum"         is not installed.
            Adapter "tronity"        is not installed.
            Adapter "tunnelbroker-endpoint-updater" is not installed.
            Adapter "tuya"           is not installed.
            Adapter "tvprogram"      is not installed.
            Adapter "tvspielfilm"    is not installed.
            Adapter "twinkly"        is not installed.
            Adapter "unifi"          is not installed.
            Adapter "uv-protect"     is not installed.
            Adapter "vaillant"       is not installed.
            Adapter "valloxmv"       is not installed.
            Adapter "valuetrackerovertime" is not installed.
            Adapter "vcard"          is not installed.
            Adapter "vds2465-server" is not installed.
            Adapter "velux"          is not installed.
            Adapter "vesync"         is not installed.
            Adapter "viessmann"      is not installed.
            Adapter "viessmannapi"   is not installed.
            Adapter "virtualpowermeter" is not installed.
            Update vis from @1.3.4 to @1.5.4
            NPM version: 10.2.3
            npm install iobroker.vis@1.5.4 --loglevel error --prefix "/opt/iobroker" (System call)
            upload [0] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/vis.png vis.png image/png
            upload [600] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/timeandweather/img/clock/6-1.png widgets/timeandweather/img/clock/6-1.png image/png
            upload [550] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/timeandweather/img/clock/01-1.png widgets/timeandweather/img/clock/01-1.png image/png
            upload [500] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/jqui-mfd/img/sani_valve_60.png widgets/jqui-mfd/img/sani_valve_60.png image/png
            upload [450] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/jqui-mfd/img/fts_window_roof.svg widgets/jqui-mfd/img/fts_window_roof.svg image/svg+xml
            upload [400] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/jqui-mfd/img/authors.txt widgets/jqui-mfd/img/authors.txt text/plain
            upload [350] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/hqwidgets/css/glossy.css widgets/hqwidgets/css/glossy.css text/css
            upload [300] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/basic/img/pin_red5.svg widgets/basic/img/pin_red5.svg image/svg+xml
            upload [250] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/bars/js/jquery.sidebar.js widgets/bars/js/jquery.sidebar.js application/javascript
            upload [200] vis /opt/iobroker/node_modules/iobroker.vis/www/lib/js/jquery-ui-timepicker-addon-1.6.3.js lib/js/jquery-ui-timepicker-addon-1.6.3.js application/javascript
            upload [150] vis /opt/iobroker/node_modules/iobroker.vis/www/js/visEditExt.js js/visEditExt.js application/javascript
            upload [100] vis /opt/iobroker/node_modules/iobroker.vis/www/js/fm/icon/actions/back.png js/fm/icon/actions/back.png image/png
            upload [90] vis /opt/iobroker/node_modules/iobroker.vis/www/img/zip.png img/zip.png image/png
            upload [80] vis /opt/iobroker/node_modules/iobroker.vis/www/img/faviconEdit.png img/faviconEdit.png image/png
            upload [70] vis /opt/iobroker/node_modules/iobroker.vis/www/img/bulbOn.png img/bulbOn.png image/png
            upload [60] vis /opt/iobroker/node_modules/iobroker.vis/www/img/back/oblique-line-bk.png img/back/oblique-line-bk.png image/png
            upload [50] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/timestamp.png icon/timestamp.png image/png
            upload [40] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/ok.png icon/ok.png image/png
            upload [30] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/distribute-vertical-equal.png icon/distribute-vertical-equal.png image/png
            upload [20] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/align-width.png icon/align-width.png image/png
            upload [19] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/align-vertical-top-2.png icon/align-vertical-top-2.png image/png
            upload [18] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/align-vertical-center-2.png icon/align-vertical-center-2.png image/png
            upload [17] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/align-vertical-bottom-2.png icon/align-vertical-bottom-2.png image/png
            upload [16] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/align-horizontal-right-2.png icon/align-horizontal-right-2.png image/png
            upload [15] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/align-horizontal-left.png icon/align-horizontal-left.png image/png
            upload [14] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/align-horizontal-center-2.png icon/align-horizontal-center-2.png image/png
            upload [13] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/align-height.png icon/align-height.png image/png
            upload [12] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/add.png icon/add.png image/png
            upload [11] vis /opt/iobroker/node_modules/iobroker.vis/www/edit.src.html edit.src.html text/html
            upload [10] vis /opt/iobroker/node_modules/iobroker.vis/www/edit.html edit.html text/html
            upload [9] vis /opt/iobroker/node_modules/iobroker.vis/www/css/vis.css css/vis.css text/css
            upload [8] vis /opt/iobroker/node_modules/iobroker.vis/www/css/vis-editor.css css/vis-editor.css text/css
            upload [7] vis /opt/iobroker/node_modules/iobroker.vis/www/css/styles.css css/styles.css text/css
            upload [6] vis /opt/iobroker/node_modules/iobroker.vis/www/css/montserrat-regular-webfont.woff css/montserrat-regular-webfont.woff font/woff
            upload [5] vis /opt/iobroker/node_modules/iobroker.vis/www/css/doc.css css/doc.css text/css
            upload [4] vis /opt/iobroker/node_modules/iobroker.vis/www/css/backgrounds.css css/backgrounds.css text/css
            upload [3] vis /opt/iobroker/node_modules/iobroker.vis/www/css/app.css css/app.css text/css
            upload [2] vis /opt/iobroker/node_modules/iobroker.vis/www/css/add_kian.css css/add_kian.css text/css
            upload [1] vis /opt/iobroker/node_modules/iobroker.vis/www/cordova.js cordova.js application/javascript
            upload [0] vis /opt/iobroker/node_modules/iobroker.vis/www/cache.manifest cache.manifest text/cache-manifest
            Update "system.adapter.vis.0"
            Adapter "vis" updated
            Adapter "vis-2"          is not installed.
            Adapter "vis-2-widgets-energy" is not installed.
            Adapter "vis-2-widgets-gauges" is not installed.
            Adapter "vis-2-widgets-jaeger-design" is not installed.
            Adapter "vis-2-widgets-material" is not installed.
            Adapter "vis-bars"       is up to date.
            Adapter "vis-canvas-gauges" is not installed.
            Adapter "vis-colorpicker" is up to date.
            Adapter "vis-fancyswitch" is up to date.
            Adapter "vis-google-fonts" is not installed.
            Adapter "vis-history"    is not installed.
            Adapter "vis-hqwidgets"  is up to date.
            Adapter "vis-icontwo"    is not installed.
            Adapter "vis-inventwo"   is not installed.
            Adapter "vis-jqui-mfd"   is up to date.
            Adapter "vis-justgage"   is not installed.
            Adapter "vis-keyboard"   is not installed.
            Adapter "vis-lcars"      is not installed.
            Adapter "vis-map"        is not installed.
            Adapter "vis-material"   is not installed.
            Adapter "vis-material-advanced" is not installed.
            Adapter "vis-materialdesign" is not installed.
            Adapter "vis-metro"      is not installed.
            Adapter "vis-players"    is not installed.
            Adapter "vis-plumb"      is not installed.
            Adapter "vis-rgraph"     is not installed.
            Adapter "vis-timeandweather" is up to date.
            Adapter "vis-weather"    is not installed.
            Adapter "voltoplus"      is not installed.
            Adapter "volumio"        is not installed.
            Adapter "volvo"          is not installed.
            Adapter "vr200"          is not installed.
            Adapter "vw-connect"     is not installed.
            Adapter "wallpanel"      is not installed.
            Adapter "warp"           is not installed.
            Adapter "weather-warnings" is not installed.
            Adapter "weatherflow_udp" is not installed.
            Adapter "weatherunderground" is not installed.
            Invalid version of "admin". Installed "4.1.11", required ">=5.1.0
            Adapter "webcal"         is not installed.
            Adapter "webui"          is not installed.
            Adapter "webuntis"       is not installed.
            Adapter "weishaupt-wem"  is not installed.
            Adapter "welcome"        is not installed.
            Adapter "whatsapp-cmb"   is not installed.
            Adapter "wiegand-tcpip"  is not installed.
            Adapter "wiffi-wz"       is not installed.
            Adapter "wifilight"      is not installed.
            Adapter "windows-control" is not installed.
            Adapter "wiobrowser"     is not installed.
            Adapter "wireguard"      is not installed.
            Adapter "wireless-mbus"  is not installed.
            Adapter "withings"       is not installed.
            Adapter "wlanthermo-nano" is not installed.
            Adapter "wled"           is not installed.
            Adapter "wmswebcontrol"  is not installed.
            Adapter "wolf"           is not installed.
            Adapter "wolf-smartset"  is not installed.
            Adapter "worx"           is not installed.
            Adapter "ws"             is not installed.
            Adapter "x-touch"        is not installed.
            Adapter "xbox"           is not installed.
            Adapter "xs1"            is not installed.
            Adapter "xterm"          is not installed.
            Adapter "yahka"          is not installed.
            Adapter "yahoo-stock-market" is not installed.
            Adapter "yamaha"         is not installed.
            Adapter "yeelight-2"     is not installed.
            Adapter "youtube"        is not installed.
            Adapter "yr"             is not installed.
            Adapter "zehnder-cloud"  is not installed.
            Adapter "zendure-solarflow" is not installed.
            Adapter "zigbee"         is not installed.
            Adapter "zigbee2mqtt"    is not installed.
            Adapter "zont"           is not installed.
            Adapter "zwave2"         is not installed.
            pi@raspberrypi:~ $ iob stop
            • F Frank-KNX
              NPM version: 10.2.3
              NPM version: 10.2.3
              NPM version: 10.2.3
              @frank-knx
              Muss ich mir morgen anschauen. N8
                @frank-knx
                Frank-KNX
                OK ich halte mich bereit und mache vor deiner Rückmeldung keine Aktionen (um nichts zu Verschlimmern).
                • F Frank-KNX
                  @frank-knx
                  Versuch mal:
                  iob stop
                  cd /opt/iobroker
                  sudo -H -u iobroker npm install iobroker.js-controller
                  iob update
                  iob upgrade admin
                  iob upgrade all
                  iob start
                    @frank-knx
                    Versuch mal:
                    iob stop
                    cd /opt/iobroker
                    iob update
                    iob upgrade admin
                    iob upgrade all
                    iob start
                    Frank-KNX
                    Alle Befehle sind erfolgreich und ohne Fehlermeldung durchgelaufen.
                    Im iobroker selbst unter Info erscheint die Meldung, dass alle Adapter aktuell sind.
                    ich habe "iob diag" nochmal gestartet und nachfolgend der Report.
                    Habe ich es nun mit deiner Hilfe erfolgreich geschafft oder ist noch etwas zu fixen ?
                    Skript v.2023-10-10
                    *** BASE SYSTEM ***
                             Icon name: computer
                          Architecture: arm
                    Model           : Raspberry Pi 4 Model B Rev 1.4
                    Docker          : false
                    Virtualization  : none
                    Kernel          : armv7l
                    Userland        : armhf
                    Systemuptime and Load:
                     17:40:21 up 16:57,  3 users,  load average: 0.81, 1.75, 1.33
                    CPU threads: 4
                    *** RASPBERRY THROTTLING ***
                    Current issues:
                    Previously detected issues:
                    *** Time and Time Zones ***
                                   Local time: Sat 2024-02-03 17:40:21 CET
                               Universal time: Sat 2024-02-03 16:40:21 UTC
                                     RTC time: n/a
                                  NTP service: active
                              RTC in local TZ: no
                    *** User and Groups ***
                    pi
                    /home/pi
                    pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin gpio i2c spi iobroker
                    *** X-Server-Setup ***
                    X-Server:       true
                    Desktop:
                    Terminal:       tty
                    *** MEMORY ***
                    Mem:           7.9G        1.2G        4.9G         39M        1.7G        6.5G
                    Swap:           99M          0B         99M
                    Total:         8.0G        1.2G        5.0G
                             7898 M total memory
                             1209 M used memory
                              531 M active memory
                             2209 M inactive memory
                             4942 M free memory
                              158 M buffer memory
                             1589 M swap cache
                               99 M total swap
                                0 M used swap
                               99 M free swap
                    Raspberry only:
                    oom events: 0
                    *** FAILED SERVICES ***
                      UNIT                  LOAD   ACTIVE SUB    DESCRIPTION
                    * bthelper@hci0.service loaded failed failed Raspberry Pi bluetooth helper
                    1 loaded units listed. Pass --all to see loaded but inactive units, too.
                    To show all installed unit files use 'systemctl list-unit-files'.
                    *** FILESYSTEM ***
                    /dev/root      ext4      117G   11G  102G  10% /
                    devtmpfs       devtmpfs  3.7G     0  3.7G   0% /dev
                    tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
                    tmpfs          tmpfs     3.9G  8.7M  3.9G   1% /run
                    tmpfs          tmpfs     3.9G     0  3.9G   0% /sys/fs/cgroup
                    /dev/mmcblk0p1 vfat      253M   49M  204M  20% /boot
                    tmpfs          tmpfs     790M  4.0K  790M   1% /run/user/1000
                    [Sat Feb  3 00:42:27 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 video=HDMI-A-1:1920x1080M@60 smsc95xx.macaddr=DC:A6:32:D3:7A:A7 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=def5eda3-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
                    [Sat Feb  3 00:42:28 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
                    [Sat Feb  3 00:42:28 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                    [Sat Feb  3 00:42:31 2024] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
                    TARGET                SOURCE         FSTYPE          OPTIONS
                    /                     /dev/mmcblk0p2 ext4            rw,noatime
                    |-/sys/fs/bpf         none           bpf             rw,nosuid,nodev,noexec,relatime,mode=700
                    |-/run/user/1000/gvfs gvfsd-fuse     fuse.gvfsd-fuse rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
                    `-/boot               /dev/mmcblk0p1 vfat            rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                    /var:
                    1.5G    /var/
                    1.1G    /var/cache/apt/archives
                    1.1G    /var/cache/apt
                    1.1G    /var/cache
                    250M    /var/lib
                    Archived and active journals take up 8.0M in the file system.
                    /opt/iobroker/backups:
                    101M    /opt/iobroker/backups/
                    /opt/iobroker/iobroker-data:
                    256M    /opt/iobroker/iobroker-data/
                    169M    /opt/iobroker/iobroker-data/files
                    67M     /opt/iobroker/iobroker-data/files/javascript.admin
                    50M     /opt/iobroker/iobroker-data/backup-objects
                    48M     /opt/iobroker/iobroker-data/files/javascript.admin/static
                    22M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.c05ba1d3.js.map
                    16M     /opt/iobroker/iobroker-data/objects.jsonl
                    8.3M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.c05ba1d3.js
                    7.5M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/691.26ff76ce.chunk.js.map
                    7.1M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/610.d3cce782.chunk.js.map
                    USB-Devices by-id:
                    find: '/dev/serial/by-id/': No such file or directory
                    *** NodeJS-Installation ***
                    /usr/bin/npm            10.2.3
                    /usr/bin/npx            10.2.3
                    nodejs:
                      Installed: 18.19.0-1nodesource1
                      Candidate: 18.19.0-1nodesource1
                      Version table:
                     *** 18.19.0-1nodesource1 1001
                            500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
                         18.18.2-1nodesource1 1001
                         18.18.1-1nodesource1 1001
                         18.18.0-1nodesource1 1001
                         18.17.1-1nodesource1 1001
                         18.17.0-1nodesource1 1001
                         18.16.1-1nodesource1 1001
                         18.16.0-1nodesource1 1001
                         18.15.0-1nodesource1 1001
                         18.14.2-1nodesource1 1001
                         18.14.1-1nodesource1 1001
                         18.14.0-1nodesource1 1001
                         18.13.0-1nodesource1 1001
                         18.12.0-1nodesource1 1001
                         18.11.0-1nodesource1 1001
                         18.10.0-1nodesource1 1001
                         18.9.1-1nodesource1 1001
                         18.9.0-1nodesource1 1001
                         18.8.0-1nodesource1 1001
                         18.7.0-1nodesource1 1001
                         18.6.0-1nodesource1 1001
                         18.5.0-1nodesource1 1001
                         18.4.0-1nodesource1 1001
                         18.3.0-1nodesource1 1001
                         18.2.0-1nodesource1 1001
                         18.1.0-1nodesource1 1001
                         18.0.0-1nodesource1 1001
                         10.24.0~dfsg-1~deb10u3 500
                    No problems detected
                    Errors in npm tree:
                    *** ioBroker-Installation ***
                    ioBroker Status
                    Objects type: jsonl
                    States  type: jsonl
                    Core adapters versions
                    js-controller:  5.0.17
                    admin:          6.13.15
                    javascript:     7.1.6
                    Adapters from github:   0
                    Adapter State
                      system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
                      system.adapter.icons-mfd-png.0          : icons-mfd-png         : raspberrypi                              -  enabled
                    + system.adapter.influxdb.0               : influxdb              : raspberrypi                              -  enabled, port: 8086
                    + system.adapter.knx.0                    : knx                   : raspberrypi                              -  enabled, bind: 192.168.2.98
                      system.adapter.linux-control.0          : linux-control         : raspberrypi                              -  enabled
                    + system.adapter.meldungsliste.0          : meldungsliste         : raspberrypi                              -  enabled
                      system.adapter.meldungsliste.1          : meldungsliste         : raspberrypi                              -  enabled
                    + system.adapter.meldungsliste.10         : meldungsliste         : raspberrypi                              -  enabled
                    + system.adapter.meldungsliste.11         : meldungsliste         : raspberrypi                              -  enabled
                    + system.adapter.meldungsliste.12         : meldungsliste         : raspberrypi                              -  enabled
                    + system.adapter.meldungsliste.13         : meldungsliste         : raspberrypi                              -  enabled
                    + system.adapter.meldungsliste.2          : meldungsliste         : raspberrypi                              -  enabled
                    + system.adapter.meldungsliste.3          : meldungsliste         : raspberrypi                              -  enabled
                    + system.adapter.meldungsliste.4          : meldungsliste         : raspberrypi                              -  enabled
                    + system.adapter.meldungsliste.5          : meldungsliste         : raspberrypi                              -  enabled
                    + system.adapter.meldungsliste.6          : meldungsliste         : raspberrypi                              -  enabled
                    + system.adapter.meldungsliste.7          : meldungsliste         : raspberrypi                              -  enabled
                      system.adapter.meldungsliste.8          : meldungsliste         : raspberrypi                              -  enabled
                    + system.adapter.meldungsliste.9          : meldungsliste         : raspberrypi                              -  enabled
                    + system.adapter.node-red.0               : node-red              : raspberrypi                              -  enabled, port: 1880, bind: 192.168.2.98
                    + system.adapter.statistics.0             : statistics            : raspberrypi                              -  enabled
                      system.adapter.tr-064.0                 : tr-064                : raspberrypi                              - disabled
                    + system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              -  enabled
                      system.adapter.upnp.0                   : upnp                  : raspberrypi                              - disabled
                      system.adapter.vis-bars.0               : vis-bars              : raspberrypi                              -  enabled
                      system.adapter.vis-colorpicker.0        : vis-colorpicker       : raspberrypi                              -  enabled
                      system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : raspberrypi                              -  enabled
                      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              -  enabled
                      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspberrypi                              -  enabled
                      system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              -  enabled
                    + instance is alive
                    ioBroker-Repositories
                    Stable (default): http://download.iobroker.net/sources-dist.json
                    Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
                    Installed ioBroker-Instances
                    Adapter    "admin"        : 6.13.15  , installed 6.13.15
                    Adapter    "backitup"     : 2.9.8    , installed 2.9.8
                    Adapter    "discovery"    : 4.2.0    , installed 4.2.0
                    Adapter    "ical"         : 1.13.3   , installed 1.13.3
                    Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
                    Adapter    "info"         : 2.0.0    , installed 2.0.0
                    Adapter    "javascript"   : 7.1.6    , installed 7.1.6
                    Controller "js-controller": 5.0.17   , installed 5.0.17
                    Adapter    "knx"          : 2.0.24   , installed 2.0.24
                    Adapter    "linux-control": 1.1.5    , installed 1.1.5
                    Adapter    "node-red"     : 5.1.0    , installed 5.1.0
                    Adapter    "socketio"     : 6.6.0    , installed 6.6.0
                    Adapter    "statistics"   : 2.4.0    , installed 2.4.0
                    Adapter    "trashschedule": 2.3.0    , installed 2.3.0
                    Adapter    "upnp"         : 1.0.21   , installed 1.0.21
                    Adapter    "vis"          : 1.5.4    , installed 1.5.4
                    Adapter    "web"          : 6.2.3    , installed 6.2.3
                    Adapter    "ws"           : 2.5.10   , installed 2.5.10
                    Objects and States
                    Objects:        3877
                    States:         2729
                    Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
                    Hit:2 http://archive.raspberrypi.org/debian buster InRelease
                    Hit:3 https://repos.influxdata.com/debian stable InRelease
                    Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
                    Reading package lists...
                    Pending Updates: 1
                    *** Listening Ports ***
                    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          17021      555/sshd
                    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          17841      420/cupsd
                    tcp        0      0 192.168.2.98:1880       0.0.0.0:*               LISTEN      1001       49471      9582/node-red
                    tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      999        19766      482/influxd
                    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       48023      9500/iobroker.js-co
                    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       48016      9500/iobroker.js-co
                    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       48066      9521/io.admin.0
                    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       53319      9865/io.web.0
                    tcp6       0      0 :::8086                 :::*                    LISTEN      999        20061      482/influxd
                    tcp6       0      0 :::22                   :::*                    LISTEN      0          17031      555/sshd
                    tcp6       0      0 ::1:631                 :::*                    LISTEN      0          17840      420/cupsd
                    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          17159      484/dhcpcd
                    udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          18593      532/cups-browsed
                    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        16137      413/avahi-daemon: r
                    udp        0      0 0.0.0.0:59135           0.0.0.0:*                           1001       49473      9582/node-red
                    udp        0      0 0.0.0.0:42781           0.0.0.0:*                           108        16139      413/avahi-daemon: r
                    udp        0      0 192.168.2.98:39748      0.0.0.0:*                           1001       53569      10234/io.knx.0
                    udp        0      0 192.168.2.98:46929      0.0.0.0:*                           1001       51070      10234/io.knx.0
                    udp6       0      0 :::546                  :::*                                0          20302      484/dhcpcd
                    udp6       0      0 :::52887                :::*                                108        16140      413/avahi-daemon: r
                    udp6       0      0 :::5353                 :::*                                108        16138      413/avahi-daemon: r
                    2024-02-03 17:41:57.874  - info: knx.0 (10234) WRITE : mappedName : Temperatur Wasser Teich    dest : 4/3/3  val: 6.4   (DPT9.001) Temperatur_Wasser_Teich
                    2024-02-03 17:41:57.874  - info: knx.0 (10234) Change state from STATE_READY(7) to STATE_TUNNELLING_REQUEST(13)
                    2024-02-03 17:41:57.875  - info: knx.0 (10234) Change state from STATE_TUNNELLING_REQUEST(13) to STATE_TUNNELLING_ACK(14)
                    2024-02-03 17:41:57.875  - info: knx.0 (10234) =====> STATE_TUNNELING_ACK
                    2024-02-03 17:41:57.876  - info: knx.0 (10234) ( 4 ) Sending Tunnel_Request ACK  : 06 10 04 21 00 0a 04 55 87 00   ChID : 85 SeqCntIN : 135 SeqCntOUT : 25 queue length : 0
                    2024-02-03 17:41:57.877  - info: knx.0 (10234) ( 4.b ) return to STATE_READY, processing : false
                    2024-02-03 17:41:57.877  - info: knx.0 (10234) Change state from STATE_TUNNELLING_ACK(14) to STATE_READY(7)
                    2024-02-03 17:41:56.303  - info: influxdb.0 (9607) Influx DB Version used: 1.x
                    2024-02-03 17:41:56.503  - error: influxdb.0 (9607) Error: authorization failed
                    2024-02-03 17:41:58.728  - info: knx.0 (10234) ( 3.2 ) Received TUNNEL_REQUEST (WRITE - send ACK )         :    06 10 04 20 00 19 04 55 88 00 29 00 bc c0 12 3c 28 03 05 00 80 00 00 01 c4   ChID: 85
                    2024-02-03 17:41:58.729  - info: knx.0 (10234) WRITE : mappedName : Energie kWh    dest : 5/0/3  val: 452   (DPT13.013) Energie_kWh
                    2024-02-03 17:41:58.730  - info: knx.0 (10234) Change state from STATE_READY(7) to STATE_TUNNELLING_REQUEST(13)
                    2024-02-03 17:41:58.730  - info: knx.0 (10234) Change state from STATE_TUNNELLING_REQUEST(13) to STATE_TUNNELLING_ACK(14)
                    2024-02-03 17:41:58.731  - info: knx.0 (10234) =====> STATE_TUNNELING_ACK
                    2024-02-03 17:41:58.733  - info: knx.0 (10234) ( 4 ) Sending Tunnel_Request ACK  : 06 10 04 21 00 0a 04 55 88 00   ChID : 85 SeqCntIN : 136 SeqCntOUT : 25 queue length : 0
                    2024-02-03 17:41:58.733  - info: knx.0 (10234) ( 4.b ) return to STATE_READY, processing : false
                    2024-02-03 17:41:58.733  - info: knx.0 (10234) Change state from STATE_TUNNELLING_ACK(14) to STATE_READY(7)
                    2024-02-03 17:41:58.751  - info: knx.0 (10234) ( 3.2 ) Received TUNNEL_REQUEST (WRITE - send ACK )         :    06 10 04 20 00 19 04 55 89 00 29 00 bc c0 12 3c 28 02 05 00 80 00 06 e9 02   ChID: 85
                    2024-02-03 17:41:58.753  - info: knx.0 (10234) WRITE : mappedName : Energie Wh    dest : 5/0/2  val: 452866   (DPT13.010) Energie_Wh
                    2024-02-03 17:41:58.754  - info: knx.0 (10234) Change state from STATE_READY(7) to STATE_TUNNELLING_REQUEST(13)
                    2024-02-03 17:41:58.754  - info: knx.0 (10234) Change state from STATE_TUNNELLING_REQUEST(13) to STATE_TUNNELLING_ACK(14)
                    2024-02-03 17:41:58.755  - info: knx.0 (10234) =====> STATE_TUNNELING_ACK
                    2024-02-03 17:41:58.756  - info: knx.0 (10234) ( 4 ) Sending Tunnel_Request ACK  : 06 10 04 21 00 0a 04 55 89 00   ChID : 85 SeqCntIN : 137 SeqCntOUT : 25 queue length : 0
                    2024-02-03 17:41:58.756  - info: knx.0 (10234) ( 4.b ) return to STATE_READY, processing : false
                    2024-02-03 17:41:58.757  - info: knx.0 (10234) Change state from STATE_TUNNELLING_ACK(14) to STATE_READY(7)
                    • F Frank-KNX
                      Skript v.2023-10-10
                      *** BASE SYSTEM ***
                               Icon name: computer
                            Architecture: arm
                      Docker          : false
                      Kernel          : armv7l
                      Userland        : armhf
                      CPU threads: 4
                      Current issues:
                                       RTC time: n/a
                                    NTP service: active
                                RTC in local TZ: no
                      pi
                      /home/pi
                      X-Server:       true
                      Desktop:
                      Terminal:       tty
                      *** MEMORY ***
                      Swap:           99M          0B         99M
                               7898 M total memory
                               1209 M used memory
                                531 M active memory
                               4942 M free memory
                                158 M buffer memory
                               1589 M swap cache
                                 99 M total swap
                                  0 M used swap
                                 99 M free swap
                      Raspberry only:
                      oom events: 0
                      *** FILESYSTEM ***
                      /var:
                      1.5G    /var/
                      1.1G    /var/cache/apt
                      1.1G    /var/cache
                      250M    /var/lib
                      USB-Devices by-id:
                      /usr/bin/npm            10.2.3
                      /usr/bin/npx            10.2.3
                      nodejs:
                        Version table:
                      Errors in npm tree:
                      ioBroker Status
                      Objects type: jsonl
                      States  type: jsonl
                      admin:          6.13.15
                      javascript:     7.1.6
                      Adapter State
                      + instance is alive
                      Objects and States
                      Objects:        3877
                      States:         2729
                      Pending Updates: 1
                      @frank-knx sagte in Update js-Controller 3.x auf 5.x funktioniert nicht:
                      Schaut jetzt wohl soweit i. O. aus.
                      Aber was ist denn das für ein Adapter? Der dann auch ein Dutzend Instanzen anschleppt?
                      Backup ziehen und das Betriebssystem auf einen aktuellen Stand bringen. Dein 'Buster' ist tot.
                        Frank-KNX
                        Hallo Thomas,
                        herzlichen Dank für deine professionelle Unterstützung.
                        Jetzt muss ich in meiner VIS nur noch schauen, ob durch die Updates am Verhalten eine Änderung aufgetreten ist.
                        Diesen Adapter Meldungsliste nutze ich in der VIS für alle Beleuchtungen und Co, die ich über KNX abgreife. Damit generiere ich auf der Hauptseite dann Meldungen, wie "Licht im Haus an", wenn eines der Lichter an ist oder "Fenster offen". Ich habe dort so viele Gruppen, dass ich jedes Mal einen Adapter benötige. Die laufen aber "bisher" sehr stabil und zuverlässig.
                        Jetzt werde ich das System nochmal genau anschauen, ob alle bisherigen Funktionen laufen und dann werde ich das nächste Projekt mit dem von dir angesprochenen Update in Angriff nehmen.
                        Da werde ich sicher nochmal auf euch Fachleute aus dem Forum zurückkommen, bevor ich als "Halbwissender" hier falsche Dinge mache und am Ende nichts mehr läuft.
                        Besten Dank
                        FRANK
                        • Thomas BraunT Online
                          @frank-knx
                          Ich würde den knx auf ein weniger gesprächiges LogLevel setzten.
                          Und bei
                          Pending Updates: 1
                          Kannst du gleich trainieren, wie mal die Kiste aktuell hält.
                          sudo apt update
                          sudo apt full-upgrade
                            @frank-knx
                            Und bei
                            Pending Updates: 1
                            sudo apt update
                            Frank579
                            #66
                            @thomas-braun sagte in Update js-Controller 3.x auf 5.x funktioniert nicht:
                            sudo full-upgrade
                            fehlt da nicht ein apt ? oder geht das jetzt auch so?
                            • F Frank579
                              sudo full-upgrade
                              #67
                              @frank579 sagte in Update js-Controller 3.x auf 5.x funktioniert nicht:
                              Gut aufgepasst. Ich hab es korrigiert.
