  3. Off Topic
  4. Raspy update "Schlüssel" nicht verfügbar
    6.0k
22 Beiträge 3 Kommentatoren 3.2k Aufrufe 3 Beobachtet
  • U UncleB
    pi@raspberrypi:~ $ ls -lAh /etc/apt/sources.list.d/
    insgesamt 36K
    -rw-r--r-- 1 root root   94  1. Feb 16:28 debmatic.list
    -rw-r--r-- 1 root root   84  1. Feb 17:07 grafana.list
    -rw-r--r-- 1 root root  117  1. Feb 17:01 influxdata.list
    -rw-r--r-- 1 root root   55  1. Feb 16:28 influxdb.list
    -rw-r--r-- 1 root root  100  1. Feb 17:29 nodesource.list
    -rw-r--r-- 1 root root  191  1. Feb 16:28 raspi.list
    -rw-r--r-- 1 root root 9,0K 17. Sep 2021  siduction-archive-keyring_2021.09.16_all.deb
    @uncleb
    sudo rm /etc/apt/sources.list.d/influxd*
    wget -q https://repos.influxdata.com/influxdata-archive_compat.key
    echo '393e8779c89ac8d958f81f942f9ad7fb82a25e133faddaf92e15b16e6ac9ce4c influxdata-archive_compat.key' | sha256sum -c && cat influxdata-archive_compat.key | gpg --dearmor | sudo tee /usr/share/keyrings/influxdata-archive_compat.gpg > /dev/null
    echo 'deb [signed-by=/usr/share/keyrings/influxdata-archive_compat.gpg] https://repos.influxdata.com/debian stable main' | sudo tee /etc/apt/sources.list.d/influxdata.list
    rm influxdata-archive_compat.key
    sudo rm /etc/apt/sources.list.d/siduction*
    Die Ausgabe von
    sudo apt update
    danach nochmal zeigen.
    U 1 Antwort Letzte Antwort
      @uncleb
      Die Ausgabe von
      sudo apt update
      U Offline
      U Offline
      UncleB
      @thomas-braun said in Raspy update "Schlüssel" nicht verfügbar:
      sudo apt update
      pi@raspberrypi:~ $ sudo rm /etc/apt/sources.list.d/influxd*
      pi@raspberrypi:~ $ wget -q https://repos.influxdata.com/influxdata-archive_compat.key
      pi@raspberrypi:~ $ echo '393e8779c89ac8d958f81f942f9ad7fb82a25e133faddaf92e15b16e6ac9ce4c influxdata-archive_compat.key' | sha256sum -c && cat influxdata-archive_compat.key | gpg --dearmor | sudo tee /usr/share/keyrings/influxdata-archive_compat.gpg > /dev/null
      influxdata-archive_compat.key: OK
      pi@raspberrypi:~ $ echo 'deb [signed-by=/usr/share/keyrings/influxdata-archive_compat.gpg] https://repos.influxdata.com/debian stable main' | sudo tee /etc/apt/sources.list.d/influxdata.list
      pi@raspberrypi:~ $ rm influxdata-archive_compat.key
      pi@raspberrypi:~ $ sudo rm /etc/apt/sources.list.d/siduction*
      pi@raspberrypi:~ $ sudo apt update
      Holen:1 http://deb.debian.org/debian stable InRelease [151 kB]
      OK:2 http://archive.raspberrypi.org/debian bullseye InRelease
      Holen:3 http://raspbian.raspberrypi.org/raspbian bullseye InRelease [15,0 kB]
      OK:4 https://apt.grafana.com stable InRelease
      OK:5 https://repos.influxdata.com/debian stable InRelease
      OK:6 https://apt.debmatic.de/debmatic stable InRelease
      OK:7 https://deb.nodesource.com/node_18.x nodistro InRelease
      Fehl:1 http://deb.debian.org/debian stable InRelease
        Die folgenden Signaturen konnten nicht überprüft werden, weil ihr öffentlicher Schlüssel nicht verfügbar ist: NO_PUBKEY 0E98404D386FA1D9 NO_PUBKEY 6ED0E7B82643E131 NO_PUBKEY F8D2585B8783D481
      W: GPG-Fehler: http://deb.debian.org/debian stable InRelease: Die folgenden Signaturen konnten nicht überprüft werden, weil ihr öffentlicher Schlüssel nicht verfügbar ist: NO_PUBKEY 0E98404D386FA1D9 NO_PUBKEY 6ED0E7B82643E131 NO_PUBKEY F8D2585B8783D481
      E: Das Depot »http://deb.debian.org/debian stable InRelease« ist nicht signiert.
      N: Eine Aktualisierung von solch einem Depot kann nicht auf eine sichere Art durchgeführt werden, daher ist es standardmäßig deaktiviert.
      N: Weitere Details zur Erzeugung von Paketdepots sowie zu deren Benutzerkonfiguration finden Sie in der Handbuchseite apt-secure(8).
      pi@raspberrypi:~ $
      • U UncleB
        sudo apt update
        pi@raspberrypi:~ $
        @uncleb
        Lösch die letzte Zeile aus der sources.list heraus.
        Also diese:
        deb http://deb.debian.org/debian/ stable main
          @uncleb
          Also diese:
          U Offline
          U Offline
          UncleB
          sources.list
          Top, das hat funktioniert, vielen Dank Thomas..
          Hast du noch ne Idee wieso sich der js-controller nicht updaten lässt?
          Ein iob stop - iob update - iob upgrade -self bringt leider nichts.
          Stoß ich über den Admin das Update an, passiert auch nichts
          • U UncleB
            sources.list
            @uncleb
            Zeig jetzt nochmal ein
            sudo apt-update
              @uncleb
              sudo apt-update
              U Offline
              U Offline
              UncleB
              schrieb am zuletzt editiert von UncleB
              sudo apt-update
              OK:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
              OK:3 https://repos.influxdata.com/debian stable InRelease
              OK:5 https://deb.nodesource.com/node_18.x nodistro InRelease
              Alle Pakete sind aktuell.
              pi@raspberrypi:~ $
              • U UncleB
                sudo apt-update
                pi@raspberrypi:~ $
                @uncleb
                Gut.
                iob update
                iob stop
                iob upgrade self
                iob restart
                Ist das ganze ein Multi-Host-Verbund?
                • U Offline
                  U Offline
                  UncleB
                  iob restart
                  Ja genau,
                  Master ist Synology Docker,
                  Slave der PI.
                  JS-Controller ist jetzt auch auf 5.0.19, vielen dank :)
                  Kann es daran liegen das ich beim vorherigen versuch erst iob beendet habe, und dann ein iob update gemacht habe?
                  pi@raspberrypi:~ $ iob update
                  Used repository: Beta (latest)
                  Adapter    "admin"        : 6.13.16  , installed 6.13.16
                  Adapter    "backitup"     : 2.10.9   , installed 2.10.9
                  Adapter    "discovery"    : 4.2.0    , installed 4.2.0
                  Controller "js-controller": 5.0.19   , installed 4.0.23 [Updatable]
                  Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
                  Adapter    "zigbee"       : 1.10.2   , installed 1.10.2
                  pi@raspberrypi:~ $ iob stop
                  pi@raspberrypi:~ $ iob upgrade self
                  Update js-controller from @4.0.23 to @5.0.19
                  Stopped Objects DB
                  Stopped States DB
                  NPM version: 10.2.3
                  Installing iobroker.js-controller@5.0.19... (System call)
                  added 11 packages, removed 37 packages, and changed 44 packages in 53s
                  60 packages are looking for funding
                    run `npm fund` for details
                  pi@raspberrypi:~ $ iob restart
                  Der JavaScript Adapter haut mir noch n paar Fehler rein, liegt wohl an der Node?
                  avascript.0
                  2024-02-01 21:24:32.513	error	deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
                  javascript.0
                  2024-02-01 21:24:32.511	error	npm WARN
                  javascript.0
                  2024-02-01 21:24:32.447	error	WARN deprecated uuid@3.4.0: Please upgrade to version 7 or higher. Older versions may use Math.random() in certain circumstances, which is known to be problematic. See https://v8.dev/blog/math-random for details.
                  javascript.0
                  2024-02-01 21:24:32.445	error	npm
                  javascript.0
                  2024-02-01 21:24:32.371	error	WARN deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained.
                  javascript.0
                  2024-02-01 21:24:32.369	error	npm
                  javascript.0
                  2024-02-01 21:24:32.216	error	WARN deprecated har-validator@5.1.5: this library is no longer supported
                  javascript.0
                  2024-02-01 21:24:32.214	error	npm
                  • U UncleB
                    iob restart
                    Ja genau,
                    Slave der PI.
                    Stopped Objects DB
                    Stopped States DB
                    NPM version: 10.2.3
                    avascript.0
                    javascript.0
                    javascript.0
                    javascript.0
                    javascript.0
                    javascript.0
                    javascript.0
                    javascript.0
                    @uncleb sagte in Raspy update "Schlüssel" nicht verfügbar:
                    Sind nur Hinweise für den Maintainer.
                      U Offline
                      U Offline
                      UncleB
                      Top läuft wieder alles..
                      Bis auf den Yeelight Adapter, der hat wohl Probleme mit der aktuellen NodeJS..
                      Mist das war eigentlich der wichtigste Adapter :(
                      • U UncleB
                        Versuch es da mal mit der Beta oder gar der github-Version. Ich meine da ist was im Busch.
                        • U UncleB
                          @uncleb
                          Und hier reinlesen:
                          https://github.com/iobroker-community-adapters/ioBroker.yeelight-2/issues/227
                            @uncleb
                            Und hier reinlesen:
                            U Offline
                            U Offline
                            UncleB
                            @thomas-braun den Thread hab ich gelesen, Adapter ist auch auf der aktuellesten Github Version, wenn alle Lampen Online sind gehts, sobald eine Offline ist, is vorbei.
                            Naja anscheinend ist da jemand am werkeln.
                            Hab das Script vom Pittini getestet, kann zwar damit dimmen usw, aber die Lampen nicht ausschalten, und ausgerechnet um das gehts mir in erster Linie :)
                            • U Offline
                              U Offline
                              UncleB
                              @Thomas-Braun
                              Wie aufwendig wäre ein downgrade des Nodje.ja auf dem PI?
                              Die Yeelight Adapter laufen auf 18 nicht, ich hab mich zu sehr an die Bewegungsmelder & den "Alles Aus" Taster an der Wohungstür gewöhnt
                              • U UncleB
                                @Thomas-Braun
                                Gar nicht.
                                iob nodejs-update 16
                                und du wärst da. Bringt dir nur insgesamt nicht viel, da nodejs@16 bereits abgekündigt ist und auch einige Adapter nodejs@18 voraussetzen. Das ist also ein totes Gleis.
                                Funktioniert es nicht wie bei den anderen die Leuchtmittel einfach dauerhaft am Strom zu halten?
                                  Gar nicht.
                                  U Offline
                                  U Offline
                                  UncleB
                                  Naja auf den Raspy läuft nicht viel, die Hauptinstanz läuft im Dockercontainer
                                  Das funktioniert ja, aber in 3 Räumen ist noch kein Shelly verbaut, bzw. ist das verbauen hier sehr aufwendig wegen Wechselschaltung.
                                  Und die Freundin betätigt halt immer wieder den normalen Schalter, somit is die Lampe natürlich Offline, keine Lösung..
                                  Ich denke ein Downgrade des PIs und Hoffen auf ein Adapter Update is aktuell die beste Lösung
