  3. Off Topic
  4. Raspy update "Schlüssel" nicht verfügbar
    6.0k
22 Beiträge 3 Kommentatoren 3.2k Aufrufe 3 Beobachtet
    @uncleb
    Siduction? Wtf?
    ls -lAh /etc/apt/sources.list.d/
    zeigen
    U Offline
    U Offline
    UncleB
    pi@raspberrypi:~ $ ls -lAh /etc/apt/sources.list.d/
    insgesamt 36K
    -rw-r--r-- 1 root root   94  1. Feb 16:28 debmatic.list
    -rw-r--r-- 1 root root   84  1. Feb 17:07 grafana.list
    -rw-r--r-- 1 root root  117  1. Feb 17:01 influxdata.list
    -rw-r--r-- 1 root root   55  1. Feb 16:28 influxdb.list
    -rw-r--r-- 1 root root  100  1. Feb 17:29 nodesource.list
    -rw-r--r-- 1 root root  191  1. Feb 16:28 raspi.list
    -rw-r--r-- 1 root root 9,0K 17. Sep 2021  siduction-archive-keyring_2021.09.16_all.deb
    • U UncleB
      insgesamt 36K
      @uncleb
      sudo rm /etc/apt/sources.list.d/influxd*
      wget -q https://repos.influxdata.com/influxdata-archive_compat.key
      echo '393e8779c89ac8d958f81f942f9ad7fb82a25e133faddaf92e15b16e6ac9ce4c influxdata-archive_compat.key' | sha256sum -c && cat influxdata-archive_compat.key | gpg --dearmor | sudo tee /usr/share/keyrings/influxdata-archive_compat.gpg > /dev/null
      echo 'deb [signed-by=/usr/share/keyrings/influxdata-archive_compat.gpg] https://repos.influxdata.com/debian stable main' | sudo tee /etc/apt/sources.list.d/influxdata.list
      rm influxdata-archive_compat.key
      sudo rm /etc/apt/sources.list.d/siduction*
      Die Ausgabe von
      sudo apt update
      danach nochmal zeigen.
      U 1 Antwort Letzte Antwort
        @uncleb
        Die Ausgabe von
        sudo apt update
        U Offline
        U Offline
        UncleB
        @thomas-braun said in Raspy update "Schlüssel" nicht verfügbar:
        sudo apt update
        pi@raspberrypi:~ $ sudo rm /etc/apt/sources.list.d/influxd*
        pi@raspberrypi:~ $ wget -q https://repos.influxdata.com/influxdata-archive_compat.key
        pi@raspberrypi:~ $ echo '393e8779c89ac8d958f81f942f9ad7fb82a25e133faddaf92e15b16e6ac9ce4c influxdata-archive_compat.key' | sha256sum -c && cat influxdata-archive_compat.key | gpg --dearmor | sudo tee /usr/share/keyrings/influxdata-archive_compat.gpg > /dev/null
        influxdata-archive_compat.key: OK
        pi@raspberrypi:~ $ echo 'deb [signed-by=/usr/share/keyrings/influxdata-archive_compat.gpg] https://repos.influxdata.com/debian stable main' | sudo tee /etc/apt/sources.list.d/influxdata.list
        pi@raspberrypi:~ $ rm influxdata-archive_compat.key
        pi@raspberrypi:~ $ sudo rm /etc/apt/sources.list.d/siduction*
        pi@raspberrypi:~ $ sudo apt update
        Holen:1 http://deb.debian.org/debian stable InRelease [151 kB]
        OK:2 http://archive.raspberrypi.org/debian bullseye InRelease
        Holen:3 http://raspbian.raspberrypi.org/raspbian bullseye InRelease [15,0 kB]
        OK:4 https://apt.grafana.com stable InRelease
        OK:5 https://repos.influxdata.com/debian stable InRelease
        OK:6 https://apt.debmatic.de/debmatic stable InRelease
        OK:7 https://deb.nodesource.com/node_18.x nodistro InRelease
        Fehl:1 http://deb.debian.org/debian stable InRelease
          Die folgenden Signaturen konnten nicht überprüft werden, weil ihr öffentlicher Schlüssel nicht verfügbar ist: NO_PUBKEY 0E98404D386FA1D9 NO_PUBKEY 6ED0E7B82643E131 NO_PUBKEY F8D2585B8783D481
        W: GPG-Fehler: http://deb.debian.org/debian stable InRelease: Die folgenden Signaturen konnten nicht überprüft werden, weil ihr öffentlicher Schlüssel nicht verfügbar ist: NO_PUBKEY 0E98404D386FA1D9 NO_PUBKEY 6ED0E7B82643E131 NO_PUBKEY F8D2585B8783D481
        E: Das Depot »http://deb.debian.org/debian stable InRelease« ist nicht signiert.
        N: Eine Aktualisierung von solch einem Depot kann nicht auf eine sichere Art durchgeführt werden, daher ist es standardmäßig deaktiviert.
        N: Weitere Details zur Erzeugung von Paketdepots sowie zu deren Benutzerkonfiguration finden Sie in der Handbuchseite apt-secure(8).
        pi@raspberrypi:~ $
        • U UncleB
          sudo apt update
          pi@raspberrypi:~ $
          @uncleb
          Lösch die letzte Zeile aus der sources.list heraus.
          Also diese:
          deb http://deb.debian.org/debian/ stable main
            @uncleb
            Also diese:
            U Offline
            U Offline
            UncleB
            sources.list
            Top, das hat funktioniert, vielen Dank Thomas..
            Hast du noch ne Idee wieso sich der js-controller nicht updaten lässt?
            Ein iob stop - iob update - iob upgrade -self bringt leider nichts.
            Stoß ich über den Admin das Update an, passiert auch nichts
            • U UncleB
              sources.list
              @uncleb
              Zeig jetzt nochmal ein
              sudo apt-update
                @uncleb
                sudo apt-update
                U Offline
                U Offline
                UncleB
                schrieb am zuletzt editiert von UncleB
                sudo apt-update
                OK:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                OK:3 https://repos.influxdata.com/debian stable InRelease
                OK:5 https://deb.nodesource.com/node_18.x nodistro InRelease
                Alle Pakete sind aktuell.
                pi@raspberrypi:~ $
                • U UncleB
                  sudo apt-update
                  pi@raspberrypi:~ $
                  @uncleb
                  Gut.
                  iob update
                  iob stop
                  iob upgrade self
                  iob restart
                  Ist das ganze ein Multi-Host-Verbund?
                  • U Offline
                    U Offline
                    UncleB
                    iob restart
                    Ja genau,
                    Master ist Synology Docker,
                    Slave der PI.
                    JS-Controller ist jetzt auch auf 5.0.19, vielen dank :)
                    Kann es daran liegen das ich beim vorherigen versuch erst iob beendet habe, und dann ein iob update gemacht habe?
                    pi@raspberrypi:~ $ iob update
                    Used repository: Beta (latest)
                    Adapter    "admin"        : 6.13.16  , installed 6.13.16
                    Adapter    "backitup"     : 2.10.9   , installed 2.10.9
                    Adapter    "discovery"    : 4.2.0    , installed 4.2.0
                    Controller "js-controller": 5.0.19   , installed 4.0.23 [Updatable]
                    Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
                    Adapter    "zigbee"       : 1.10.2   , installed 1.10.2
                    pi@raspberrypi:~ $ iob stop
                    pi@raspberrypi:~ $ iob upgrade self
                    Update js-controller from @4.0.23 to @5.0.19
                    Stopped Objects DB
                    Stopped States DB
                    NPM version: 10.2.3
                    Installing iobroker.js-controller@5.0.19... (System call)
                    added 11 packages, removed 37 packages, and changed 44 packages in 53s
                    60 packages are looking for funding
                      run `npm fund` for details
                    pi@raspberrypi:~ $ iob restart
                    Der JavaScript Adapter haut mir noch n paar Fehler rein, liegt wohl an der Node?
                    avascript.0
                    2024-02-01 21:24:32.513	error	deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
                    javascript.0
                    2024-02-01 21:24:32.511	error	npm WARN
                    javascript.0
                    2024-02-01 21:24:32.447	error	WARN deprecated uuid@3.4.0: Please upgrade to version 7 or higher. Older versions may use Math.random() in certain circumstances, which is known to be problematic. See https://v8.dev/blog/math-random for details.
                    javascript.0
                    2024-02-01 21:24:32.445	error	npm
                    javascript.0
                    2024-02-01 21:24:32.371	error	WARN deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained.
                    javascript.0
                    2024-02-01 21:24:32.369	error	npm
                    javascript.0
                    2024-02-01 21:24:32.216	error	WARN deprecated har-validator@5.1.5: this library is no longer supported
                    javascript.0
                    2024-02-01 21:24:32.214	error	npm
                    • U UncleB
                      iob restart
                      Ja genau,
                      Slave der PI.
                      Stopped Objects DB
                      Stopped States DB
                      NPM version: 10.2.3
                      avascript.0
                      javascript.0
                      javascript.0
                      javascript.0
                      javascript.0
                      javascript.0
                      javascript.0
                      javascript.0
                      @uncleb sagte in Raspy update "Schlüssel" nicht verfügbar:
                      Sind nur Hinweise für den Maintainer.
                        U Offline
                        U Offline
                        UncleB
                        Top läuft wieder alles..
                        Bis auf den Yeelight Adapter, der hat wohl Probleme mit der aktuellen NodeJS..
                        Mist das war eigentlich der wichtigste Adapter :(
                        • U UncleB
                          Versuch es da mal mit der Beta oder gar der github-Version. Ich meine da ist was im Busch.
                          • U UncleB
                            @uncleb
                            Und hier reinlesen:
                            https://github.com/iobroker-community-adapters/ioBroker.yeelight-2/issues/227
                              @uncleb
                              Und hier reinlesen:
                              U Offline
                              U Offline
                              UncleB
                              @thomas-braun den Thread hab ich gelesen, Adapter ist auch auf der aktuellesten Github Version, wenn alle Lampen Online sind gehts, sobald eine Offline ist, is vorbei.
                              Naja anscheinend ist da jemand am werkeln.
                              Hab das Script vom Pittini getestet, kann zwar damit dimmen usw, aber die Lampen nicht ausschalten, und ausgerechnet um das gehts mir in erster Linie :)
                              • U Offline
                                U Offline
                                UncleB
                                @Thomas-Braun
                                Wie aufwendig wäre ein downgrade des Nodje.ja auf dem PI?
                                Die Yeelight Adapter laufen auf 18 nicht, ich hab mich zu sehr an die Bewegungsmelder & den "Alles Aus" Taster an der Wohungstür gewöhnt
                                • U UncleB
                                  @Thomas-Braun
                                  Gar nicht.
                                  iob nodejs-update 16
                                  und du wärst da. Bringt dir nur insgesamt nicht viel, da nodejs@16 bereits abgekündigt ist und auch einige Adapter nodejs@18 voraussetzen. Das ist also ein totes Gleis.
                                  Funktioniert es nicht wie bei den anderen die Leuchtmittel einfach dauerhaft am Strom zu halten?
                                    Gar nicht.
                                    U Offline
                                    U Offline
                                    UncleB
                                    Naja auf den Raspy läuft nicht viel, die Hauptinstanz läuft im Dockercontainer
                                    Das funktioniert ja, aber in 3 Räumen ist noch kein Shelly verbaut, bzw. ist das verbauen hier sehr aufwendig wegen Wechselschaltung.
                                    Und die Freundin betätigt halt immer wieder den normalen Schalter, somit is die Lampe natürlich Offline, keine Lösung..
                                    Ich denke ein Downgrade des PIs und Hoffen auf ein Adapter Update is aktuell die beste Lösung
