  4. eBus Adapter Vaillant
    6.3k
ebusebus adapterproblemerrorerste schritte
395 Beiträge 50 Kommentatoren 166.4k Aufrufe 51 Beobachtet
  • H Hump
    Ein kleiner Fortschritt ...
    Der Ebus Adapter 5 ist auf den Raspi 4 aufgesteckt und der ebusd scheint zu laufen. e4ab790a-77fb-404c-9c66-f2c0c29f20b6-image.png
    Konfiguriert ist er mit:
    EBUSD_OPTS="-d /dev/ttyAMA0 --scanconfig --configpath=http://ebusd.eu/config/ --htmlpath=/var/ebusd/html"
    Leider bekomme ich hier kein Signal:
    version: ebusd 23.2.23.2
    update check: OK
    device: /dev/ttyAMA0
    signal: no signal
    reconnects: 0
    masters: 1
    conditional: 0
    poll: 0
    update: 4
    address 31: master #8, ebusd
    address 36: slave #8, ebusd
    Gleiches mit
    EBUSD_OPTS="-d /dev/ttyebus --scanconfig --configpath=http://ebusd.eu/config/ --htmlpath=/var/ebusd/html"
    device: /dev/ttyebus, invalid
    signal: no signal
    reconnects: 0
    masters: 1
    conditional: 0
    poll: 0
    update: 4
    Kann mir bitte jemand helfen ein Signal zu bekommen? Danke!
    ebusWo
    #355
    @hump Eine Lösung gefunden ?
    Bei mir sieht es so aus:
    2023-12-30 10:46:43.096 [bus notice] device status: transport opened
    2023-12-30 10:46:43.096 [bus error] device status: transport closed
    2023-12-30 10:46:43.096 [bus error] unable to open /dev/ttyAMA0: ERR: generic device error
    2023-12-30 10:46:43.097 [main notice] ebusd 23.3.23.3 started with broadcast scan on device: /dev/ttyAMA0, serial high speed, enhanced
    2023-12-30 10:46:43.625 [bus notice] bus started with own address 31/36
    2023-12-30 10:46:43.625 [bus notice] device invalid
    2023-12-30 10:46:48.626 [bus notice] device status: transport opened
    2023-12-30 10:46:48.626 [bus error] device status: transport closed
    2023-12-30 10:46:48.633 [bus error] unable to open /dev/ttyAMA0: ERR: generic device error
    2023-12-30 10:46:48.633 [bus notice] device invalid
    2023-12-30 10:46:53.633 [bus notice] device status: transport opened
    2023-12-30 10:46:53.633 [bus error] device status: transport closed
    2023-12-30 10:46:53.633 [bus error] unable to open /dev/ttyAMA0: ERR: generic device error
    2023-12-30 10:46:53.633 [bus notice] device invalid
    Nutze RPi4, GPIO und bekomme nur device invalid ?!?
    a200A 1 Antwort Letzte Antwort
    • H Hump
      update check: OK
      signal: no signal
      reconnects: 0
      masters: 1
      conditional: 0
      poll: 0
      update: 4
      Gleiches mit
      signal: no signal
      reconnects: 0
      masters: 1
      conditional: 0
      poll: 0
      update: 4
      gmx99
      schrieb am zuletzt editiert von gmx99
      #356
      @hump ich nutze den Adapter per USB aber meine Config sieht so aus, damit habe ich Verbindung bekommen und Adapter startet sauber.
      EBUSD_OPTS="--scanconfig=full -d ens:/dev/ttyACM0 --configpath=https://cfg.ebusd.eu -p 8888 --httpport=8889 --htmlpath=/var/ebusd/html --accesslevel=*"
      Eigentlich musst du nur den Punkt -d abändern in deinen Port..
      • E ebusWo
        a200A Offline
        a200A Offline
        a200
        schrieb am zuletzt editiert von a200
        #357
        @ebuswo sagte in eBus Adapter Vaillant:
        Offensichtlich wird dein Gerät nicht auf der erwarteten USB Schnittstelle gefunden. führe mal
        lsusb
        und
        usb-devices
        aus und poste mal die Ergebnisse
        IoBroker auf QNAP TS-451, Raspi und NUC
        • a200A a200
          lsusb
          und
          usb-devices
          #358
          @a200 @ebusWo
          ls -lAh /dev/serial/by-id/
          anschauen könnte auch helfen.
            Thomas0807
            #359
            Hallo Gemeinde,
            da das Update von Mulitmatic auf die MyVaillant app sehr ernüchternd ist, ich kann weder Druck noch Temperaturen auslesen. Hoffe ich das es vielleicht mit EBUS mehr Daten gibt. Wenigstens die, die es in der Multimatic auch gab. Aktuell ist ein VR921 Modul von Vaillant verbaut. So wie ich das hier gelesen habe brauch ich noch einen EBUS-Koppler?!. wird der dann parallel angeschlossen oder wird das VR921 entfernt?
            Thomas
            • T Thomas0807
              Hallo Gemeinde,
              Thomas
              #360
              @thomas0807
              Bei mir ;
              Parallel und VR 921 als letztes Gerät
              Heizung -> Koppler -> VR921
              Koppler Esera. Die Koppler von John funktionieren bei mir (!) alle nicht. Bin wohl zu doof.
              ebusd sendet Daten als MQTT JSON
                @thomas0807
                Bei mir ;
                Thomas0807
                #361
                @dreistein Ok, Danke für deine Antwort, dann werde ich mir mal so einen Koppler bestellen. habe gesehen, dass es die nicht als WLAN Variante gibt. werd ich wohl eine Kabel ziehen müssen, aber halb so wild. Bekomme ich dann mehr Daten ausgelesen als mit der myVaillant app? Damit bekomme ich ja nur die eingestellte Temperatur ausgelesen. Ich hätte aber gern so wie bei der Multimatic die Vorlauftemperatur, Wassertemperatur, den Druck und die dazugehörigen Aussentemperatur.
                Thomas
                • T Thomas0807
                  Thomas
                  Dan.Master
                  #362
                  @thomas0807
                  Hi Thomas das kommt bei mir alles an:
                  700
                  messages
                  AdaptHeatCurve
                  name	"AdaptHeatCurve"
                  passive	false
                  write	false
                  lastup	0
                  BankHolidayEndPeriod
                  name	"BankHolidayEndPeriod"
                  passive	false
                  write	false
                  lastup	0
                  BankHolidayStartPeriod
                  name	"BankHolidayStartPeriod"
                  passive	false
                  write	false
                  lastup	0
                  ccTimer.Friday
                  name	"ccTimer.Friday"
                  passive	false
                  write	false
                  lastup	1706534086
                  zz	21
                  fields
                  name	"from"
                  value	"04:40"
                  name	"to"
                  value	"23:00"
                  name	"from"
                  value	"00:00"
                  name	"to"
                  value	"00:00"
                  name	"from"
                  value	"00:00"
                  name	"to"
                  value	"00:00"
                  ccTimer.Monday
                  name	"ccTimer.Monday"
                  passive	false
                  write	false
                  lastup	1706534085
                  zz	21
                  fields
                  name	"from"
                  value	"04:40"
                  name	"to"
                  value	"23:00"
                  name	"from"
                  value	"00:00"
                  name	"to"
                  value	"00:00"
                  name	"from"
                  value	"00:00"
                  name	"to"
                  value	"00:00"
                  ccTimer.Saturday
                  name	"ccTimer.Saturday"
                  passive	false
                  write	false
                  lastup	1706534086
                  zz	21
                  fields
                  name	"from"
                  value	"07:00"
                  name	"to"
                  value	"23:00"
                  name	"from"
                  value	"00:00"
                  name	"to"
                  value	"00:00"
                  name	"from"
                  value	"00:00"
                  name	"to"
                  value	"00:00"
                  ccTimer.Sunday
                  name	"ccTimer.Sunday"
                  passive	false
                  write	false
                  lastup	1706534086
                  zz	21
                  fields
                  name	"from"
                  value	"07:00"
                  name	"to"
                  value	"23:00"
                  name	"from"
                  value	"00:00"
                  name	"to"
                  value	"00:00"
                  name	"from"
                  value	"00:00"
                  name	"to"
                  value	"00:00"
                  ccTimer.Thursday
                  name	"ccTimer.Thursday"
                  passive	false
                  write	false
                  lastup	1706534086
                  zz	21
                  fields
                  name	"from"
                  value	"04:40"
                  name	"to"
                  value	"23:00"
                  name	"from"
                  value	"00:00"
                  name	"to"
                  value	"00:00"
                  name	"from"
                  value	"00:00"
                  name	"to"
                  value	"00:00"
                  ccTimer.Tuesday
                  name	"ccTimer.Tuesday"
                  passive	false
                  write	false
                  lastup	1706534085
                  zz	21
                  fields
                  name	"from"
                  value	"04:40"
                  name	"to"
                  value	"23:00"
                  name	"from"
                  value	"00:00"
                  name	"to"
                  value	"00:00"
                  name	"from"
                  value	"00:00"
                  name	"to"
                  value	"00:00"
                  ccTimer.Wednesday
                  name	"ccTimer.Wednesday"
                  passive	false
                  write	false
                  lastup	1706534086
                  zz	21
                  fields
                  name	"from"
                  value	"04:40"
                  name	"to"
                  value	"23:00"
                  name	"from"
                  value	"00:00"
                  name	"to"
                  value	"00:00"
                  name	"from"
                  value	"00:00"
                  name	"to"
                  value	"00:00"
                  ContinuosHeating
                  name	"ContinuosHeating"
                  passive	false
                  write	false
                  lastup	0
                  currenterror
                  name	"currenterror"
                  passive	false
                  write	false
                  lastup	1706533894
                  zz	21
                  fields
                  name	"error"
                  value	null
                  name	"error"
                  value	null
                  name	"error"
                  value	null
                  name	"error"
                  value	null
                  name	"error"
                  value	null
                  CylinderChargeHyst
                  name	"CylinderChargeHyst"
                  passive	false
                  write	false
                  lastup	0
                  CylinderChargeOffset
                  name	"CylinderChargeOffset"
                  passive	false
                  write	false
                  lastup	0
                  Date
                  name	"Date"
                  passive	false
                  write	false
                  lastup	1706534050
                  zz	21
                  fields
                  date
                  value	"29.01.2024"
                  DisplayedOutsideTemp
                  name	"DisplayedOutsideTemp"
                  passive	false
                  write	false
                  lastup	1706534051
                  zz	21
                  fields
                  tempv
                  value	8.5625
                  errorhistory
                  name	"errorhistory"
                  passive	false
                  write	false
                  lastup	0
                  FrostOverRideTime
                  name	"FrostOverRideTime"
                  passive	false
                  write	false
                  lastup	0
                  GlobalSystemOff
                  name	"GlobalSystemOff"
                  passive	false
                  write	false
                  lastup	1706534049
                  zz	21
                  fields
                  yesno
                  value	"no"
                  Hc1ActualFlowTempDesired
                  name	"Hc1ActualFlowTempDesired"
                  passive	false
                  write	false
                  lastup	0
                  Hc1AutoOffMode
                  name	"Hc1AutoOffMode"
                  passive	false
                  write	false
                  lastup	1706534054
                  zz	21
                  fields
                  offmode
                  value	"eco"
                  Hc1CircuitType
                  name	"Hc1CircuitType"
                  passive	false
                  write	false
                  lastup	1706534053
                  zz	21
                  fields
                  mctype
                  value	"mixer"
                  Hc1ExcessTemp
                  name	"Hc1ExcessTemp"
                  passive	false
                  write	false
                  lastup	0
                  Hc1FlowTemp
                  name	"Hc1FlowTemp"
                  passive	false
                  write	false
                  lastup	1706534053
                  zz	21
                  fields
                  tempv
                  value	29
                  Hc1HeatCurve
                  name	"Hc1HeatCurve"
                  passive	false
                  write	false
                  lastup	0
                  Hc1HeatCurveAdaption
                  name	"Hc1HeatCurveAdaption"
                  passive	false
                  write	false
                  lastup	0
                  Hc1MaxFlowTempDesired
                  name	"Hc1MaxFlowTempDesired"
                  passive	false
                  write	false
                  lastup	0
                  Hc1MinFlowTempDesired
                  name	"Hc1MinFlowTempDesired"
                  passive	false
                  write	false
                  lastup	0
                  Hc1MixerMovement
                  name	"Hc1MixerMovement"
                  passive	false
                  write	false
                  lastup	0
                  Hc1PumpStatus
                  name	"Hc1PumpStatus"
                  passive	false
                  write	false
                  lastup	1706534053
                  zz	21
                  fields
                  name	""
                  value	1
                  Hc1RoomTempSwitchOn
                  name	"Hc1RoomTempSwitchOn"
                  passive	false
                  write	false
                  lastup	0
                  Hc1Status
                  name	"Hc1Status"
                  passive	false
                  write	false
                  lastup	0
                  Hc1SummerTempLimit
                  name	"Hc1SummerTempLimit"
                  passive	false
                  write	false
                  lastup	0
                  Hc2ActualFlowTempDesired
                  name	"Hc2ActualFlowTempDesired"
                  passive	false
                  write	false
                  lastup	0
                  Hc2AutoOffMode
                  name	"Hc2AutoOffMode"
                  passive	false
                  write	false
                  lastup	0
                  Hc2CircuitType
                  name	"Hc2CircuitType"
                  passive	false
                  write	false
                  lastup	0
                  Hc2ExcessTemp
                  name	"Hc2ExcessTemp"
                  passive	false
                  write	false
                  lastup	0
                  Hc2FlowTemp
                  name	"Hc2FlowTemp"
                  passive	false
                  write	false
                  lastup	0
                  Hc2HeatCurve
                  name	"Hc2HeatCurve"
                  passive	false
                  write	false
                  lastup	0
                  Hc2HeatCurveAdaption
                  name	"Hc2HeatCurveAdaption"
                  passive	false
                  write	false
                  lastup	0
                  Hc2MaxFlowTempDesired
                  name	"Hc2MaxFlowTempDesired"
                  passive	false
                  write	false
                  lastup	0
                  Hc2MinFlowTempDesired
                  name	"Hc2MinFlowTempDesired"
                  passive	false
                  write	false
                  lastup	0
                  Hc2MixerMovement
                  name	"Hc2MixerMovement"
                  passive	false
                  write	false
                  lastup	0
                  Hc2PumpStatus
                  name	"Hc2PumpStatus"
                  passive	false
                  write	false
                  lastup	0
                  Hc2RoomTempSwitchOn
                  name	"Hc2RoomTempSwitchOn"
                  passive	false
                  write	false
                  lastup	0
                  Hc2Status
                  name	"Hc2Status"
                  passive	false
                  write	false
                  lastup	0
                  Hc2SummerTempLimit
                  name	"Hc2SummerTempLimit"
                  passive	false
                  write	false
                  lastup	0
                  Hc3ActualFlowTempDesired
                  name	"Hc3ActualFlowTempDesired"
                  passive	false
                  write	false
                  lastup	0
                  Hc3AutoOffMode
                  name	"Hc3AutoOffMode"
                  passive	false
                  write	false
                  lastup	0
                  Hc3CircuitType
                  name	"Hc3CircuitType"
                  passive	false
                  write	false
                  lastup	0
                  Hc3ExcessTemp
                  name	"Hc3ExcessTemp"
                  passive	false
                  write	false
                  lastup	0
                  Hc3FlowTemp
                  name	"Hc3FlowTemp"
                  passive	false
                  write	false
                  lastup	0
                  Hc3HeatCurve
                  name	"Hc3HeatCurve"
                  passive	false
                  write	false
                  lastup	0
                  Hc3HeatCurveAdaption
                  name	"Hc3HeatCurveAdaption"
                  passive	false
                  write	false
                  lastup	0
                  Hc3MaxFlowTempDesired
                  name	"Hc3MaxFlowTempDesired"
                  passive	false
                  write	false
                  lastup	0
                  Hc3MinFlowTempDesired
                  name	"Hc3MinFlowTempDesired"
                  passive	false
                  write	false
                  lastup	0
                  Hc3MixerMovement
                  name	"Hc3MixerMovement"
                  passive	false
                  write	false
                  lastup	0
                  Hc3PumpStatus
                  name	"Hc3PumpStatus"
                  passive	false
                  write	false
                  lastup	0
                  Hc3RoomTempSwitchOn
                  name	"Hc3RoomTempSwitchOn"
                  passive	false
                  write	false
                  lastup	0
                  Hc3Status
                  name	"Hc3Status"
                  passive	false
                  write	false
                  lastup	0
                  Hc3SummerTempLimit
                  name	"Hc3SummerTempLimit"
                  passive	false
                  write	false
                  lastup	0
                  HcStorageTempBottom
                  name	"HcStorageTempBottom"
                  passive	false
                  write	false
                  lastup	0
                  HcStorageTempTop
                  name	"HcStorageTempTop"
                  passive	false
                  write	false
                  lastup	0
                  HolidayEndPeriod
                  name	"HolidayEndPeriod"
                  passive	false
                  write	false
                  lastup	1706534049
                  zz	21
                  fields
                  hto
                  value	"01.01.2015"
                  HolidayStartPeriod
                  name	"HolidayStartPeriod"
                  passive	false
                  write	false
                  lastup	1706534049
                  zz	21
                  fields
                  hfrom
                  value	"01.01.2015"
                  HolidayTemp
                  name	"HolidayTemp"
                  passive	false
                  write	false
                  lastup	1706534050
                  zz	21
                  fields
                  tempv
                  value	15
                  HwcBankHolidayEndPeriod
                  name	"HwcBankHolidayEndPeriod"
                  passive	false
                  write	false
                  lastup	0
                  HwcBankHolidayStartPeriod
                  name	"HwcBankHolidayStartPeriod"
                  passive	false
                  write	false
                  lastup	0
                  HwcFlowTemp
                  name	"HwcFlowTemp"
                  passive	false
                  write	false
                  lastup	0
                  HwcHolidayEndPeriod
                  name	"HwcHolidayEndPeriod"
                  passive	false
                  write	false
                  lastup	0
                  HwcHolidayStartPeriod
                  name	"HwcHolidayStartPeriod"
                  passive	false
                  write	false
                  lastup	0
                  HwcLockTime
                  name	"HwcLockTime"
                  passive	false
                  write	false
                  lastup	0
                  HwcMaxFlowTempDesired
                  name	"HwcMaxFlowTempDesired"
                  passive	false
                  write	false
                  lastup	0
                  HwcOpMode
                  name	"HwcOpMode"
                  passive	false
                  write	false
                  lastup	1706534056
                  zz	21
                  fields
                  opmode
                  value	"auto"
                  HwcParallelLoading
                  name	"HwcParallelLoading"
                  passive	false
                  write	false
                  lastup	0
                  HwcSFMode
                  name	"HwcSFMode"
                  passive	false
                  write	false
                  lastup	1706534055
                  zz	21
                  fields
                  sfmode
                  value	"auto"
                  HwcStorageTemp
                  name	"HwcStorageTemp"
                  passive	false
                  write	false
                  lastup	1706534055
                  zz	21
                  fields
                  tempv
                  value	47.5
                  HwcStorageTempBottom
                  name	"HwcStorageTempBottom"
                  passive	false
                  write	false
                  lastup	0
                  HwcStorageTempTop
                  name	"HwcStorageTempTop"
                  passive	false
                  write	false
                  lastup	0
                  HwcTempDesired
                  name	"HwcTempDesired"
                  passive	false
                  write	false
                  lastup	1706534080
                  zz	21
                  fields
                  tempv
                  value	50
                  hwcTimer.Friday
                  name	"hwcTimer.Friday"
                  passive	false
                  write	false
                  lastup	1706534082
                  zz	21
                  fields
                  name	"from"
                  value	"04:30"
                  name	"to"
                  value	"23:00"
                  name	"from"
                  value	"00:00"
                  name	"to"
                  value	"00:00"
                  name	"from"
                  value	"00:00"
                  name	"to"
                  value	"00:00"
                  hwcTimer.Monday
                  name	"hwcTimer.Monday"
                  passive	false
                  write	false
                  lastup	1706534081
                  zz	21
                  fields
                  name	"from"
                  value	"04:30"
                  name	"to"
                  value	"23:00"
                  name	"from"
                  value	"00:00"
                  name	"to"
                  value	"00:00"
                  name	"from"
                  value	"00:00"
                  name	"to"
                  value	"00:00"
                  hwcTimer.Saturday
                  name	"hwcTimer.Saturday"
                  passive	false
                  write	false
                  lastup	1706534082
                  zz	21
                  fields
                  name	"from"
                  value	"07:00"
                  name	"to"
                  value	"23:00"
                  name	"from"
                  value	"00:00"
                  name	"to"
                  value	"00:00"
                  name	"from"
                  value	"00:00"
                  name	"to"
                  value	"00:00"
                  hwcTimer.Sunday
                  name	"hwcTimer.Sunday"
                  passive	false
                  write	false
                  lastup	1706534082
                  zz	21
                  fields
                  name	"from"
                  value	"06:00"
                  name	"to"
                  value	"23:00"
                  name	"from"
                  value	"00:00"
                  name	"to"
                  value	"00:00"
                  name	"from"
                  value	"00:00"
                  name	"to"
                  value	"00:00"
                  hwcTimer.Thursday
                  name	"hwcTimer.Thursday"
                  passive	false
                  write	false
                  lastup	1706534082
                  zz	21
                  fields
                  name	"from"
                  value	"04:30"
                  name	"to"
                  value	"23:00"
                  name	"from"
                  value	"00:00"
                  name	"to"
                  value	"00:00"
                  name	"from"
                  value	"00:00"
                  name	"to"
                  value	"00:00"
                  hwcTimer.Tuesday
                  name	"hwcTimer.Tuesday"
                  passive	false
                  write	false
                  lastup	1706534081
                  zz	21
                  fields
                  name	"from"
                  value	"04:30"
                  name	"to"
                  value	"23:00"
                  name	"from"
                  value	"00:00"
                  name	"to"
                  value	"00:00"
                  name	"from"
                  value	"00:00"
                  name	"to"
                  value	"00:00"
                  hwcTimer.Wednesday
                  name	"hwcTimer.Wednesday"
                  passive	false
                  write	false
                  lastup	1706534081
                  zz	21
                  fields
                  name	"from"
                  value	"04:30"
                  name	"to"
                  value	"23:00"
                  name	"from"
                  value	"00:00"
                  name	"to"
                  value	"00:00"
                  name	"from"
                  value	"00:00"
                  name	"to"
                  value	"00:00"
                  HydraulicScheme
                  name	"HydraulicScheme"
                  passive	false
                  write	false
                  lastup	0
                  Installer1
                  name	"Installer1"
                  passive	false
                  write	false
                  lastup	0
                  Installer2
                  name	"Installer2"
                  passive	false
                  write	false
                  lastup	0
                  KeyCodeforConfigMenu
                  name	"KeyCodeforConfigMenu"
                  passive	false
                  write	false
                  lastup	0
                  MaintenanceDate
                  name	"MaintenanceDate"
                  passive	false
                  write	false
                  lastup	0
                  MaintenanceDue
                  name	"MaintenanceDue"
                  passive	false
                  write	false
                  lastup	0
                  ManualCooling
                  name	"ManualCooling"
                  passive	false
                  write	false
                  lastup	1706534051
                  zz	21
                  fields
                  name	""
                  value	0
                  MaxCylinderChargeTime
                  name	"MaxCylinderChargeTime"
                  passive	false
                  write	false
                  lastup	0
                  MaxRoomHumidity
                  name	"MaxRoomHumidity"
                  passive	false
                  write	false
                  lastup	0
                  MultiRelaySetting
                  name	"MultiRelaySetting"
                  passive	false
                  write	false
                  lastup	0
                  noiseReductionTimer.Friday
                  name	"noiseReductionTimer.Friday"
                  passive	false
                  write	false
                  lastup	0
                  noiseReductionTimer.Monday
                  name	"noiseReductionTimer.Monday"
                  passive	false
                  write	false
                  lastup	1706534080
                  zz	21
                  fields
                  name	"from"
                  value	"06:00"
                  name	"to"
                  value	"22:00"
                  name	"from"
                  value	"-:-"
                  name	"to"
                  value	"-:-"
                  name	"from"
                  value	"-:-"
                  name	"to"
                  value	"-:-"
                  noiseReductionTimer.Saturday
                  name	"noiseReductionTimer.Saturday"
                  passive	false
                  write	false
                  lastup	0
                  noiseReductionTimer.Sunday
                  name	"noiseReductionTimer.Sunday"
                  passive	false
                  write	false
                  lastup	0
                  noiseReductionTimer.Thursday
                  name	"noiseReductionTimer.Thursday"
                  passive	false
                  write	false
                  lastup	0
                  noiseReductionTimer.Tuesday
                  name	"noiseReductionTimer.Tuesday"
                  passive	false
                  write	false
                  lastup	0
                  noiseReductionTimer.Wednesday
                  name	"noiseReductionTimer.Wednesday"
                  passive	false
                  write	false
                  lastup	0
                  OpMode
                  name	"OpMode"
                  passive	false
                  write	false
                  lastup	0
                  OpModeCooling
                  name	"OpModeCooling"
                  passive	false
                  write	false
                  lastup	0
                  OpModeEffect
                  name	"OpModeEffect"
                  passive	false
                  write	false
                  lastup	1706534048
                  zz	21
                  fields
                  zonesel
                  value	"alle"
                  OpModeVentilation
                  name	"OpModeVentilation"
                  passive	false
                  write	false
                  lastup	1706534048
                  zz	21
                  fields
                  opmode
                  value	"auto"
                  OutsideTempAvg
                  name	"OutsideTempAvg"
                  passive	false
                  write	false
                  lastup	0
                  PhoneNumber1
                  name	"PhoneNumber1"
                  passive	false
                  write	false
                  lastup	0
                  PhoneNumber2
                  name	"PhoneNumber2"
                  passive	false
                  write	false
                  lastup	0
                  PrEnergySum
                  name	"PrEnergySum"
                  passive	false
                  write	false
                  lastup	0
                  PrEnergySumHc
                  name	"PrEnergySumHc"
                  passive	false
                  write	false
                  lastup	0
                  PrEnergySumHcLastMonth
                  name	"PrEnergySumHcLastMonth"
                  passive	false
                  write	false
                  lastup	0
                  PrEnergySumHcThisMonth
                  name	"PrEnergySumHcThisMonth"
                  passive	false
                  write	false
                  lastup	0
                  PrEnergySumHwc
                  name	"PrEnergySumHwc"
                  passive	false
                  write	false
                  lastup	0
                  PrEnergySumHwcLastMonth
                  name	"PrEnergySumHwcLastMonth"
                  passive	false
                  write	false
                  lastup	0
                  PrEnergySumHwcThisMonth
                  name	"PrEnergySumHwcThisMonth"
                  passive	false
                  write	false
                  lastup	0
                  PrFuelSum
                  name	"PrFuelSum"
                  passive	false
                  write	false
                  lastup	0
                  PrFuelSumHc
                  name	"PrFuelSumHc"
                  passive	false
                  write	false
                  lastup	0
                  PrFuelSumHcLastMonth
                  name	"PrFuelSumHcLastMonth"
                  passive	false
                  write	false
                  lastup	0
                  PrFuelSumHcThisMonth
                  name	"PrFuelSumHcThisMonth"
                  passive	false
                  write	false
                  lastup	0
                  PrFuelSumHwc
                  name	"PrFuelSumHwc"
                  passive	false
                  write	false
                  lastup	0
                  PrFuelSumHwcLastMonth
                  name	"PrFuelSumHwcLastMonth"
                  passive	false
                  write	false
                  lastup	0
                  PrFuelSumHwcThisMonth
                  name	"PrFuelSumHwcThisMonth"
                  passive	false
                  write	false
                  lastup	0
                  PumpAdditionalTime
                  name	"PumpAdditionalTime"
                  passive	false
                  write	false
                  lastup	0
                  SFMode
                  name	"SFMode"
                  passive	false
                  write	false
                  lastup	1706534052
                  zz	21
                  fields
                  sfmode
                  value	"auto"
                  SolarYieldTotal
                  name	"SolarYieldTotal"
                  passive	false
                  write	false
                  lastup	0
                  SystemFlowTemp
                  name	"SystemFlowTemp"
                  passive	false
                  write	false
                  lastup	1706534052
                  zz	21
                  fields
                  tempv
                  value	null
                  tariffTimer.Friday
                  name	"tariffTimer.Friday"
                  passive	false
                  write	false
                  lastup	0
                  tariffTimer.Monday
                  name	"tariffTimer.Monday"
                  passive	false
                  write	false
                  lastup	0
                  tariffTimer.Saturday
                  name	"tariffTimer.Saturday"
                  passive	false
                  write	false
                  lastup	0
                  tariffTimer.Sunday
                  name	"tariffTimer.Sunday"
                  passive	false
                  write	false
                  lastup	0
                  tariffTimer.Thursday
                  name	"tariffTimer.Thursday"
                  passive	false
                  write	false
                  lastup	0
                  tariffTimer.Tuesday
                  name	"tariffTimer.Tuesday"
                  passive	false
                  write	false
                  lastup	0
                  tariffTimer.Wednesday
                  name	"tariffTimer.Wednesday"
                  passive	false
                  write	false
                  lastup	0
                  Time
                  name	"Time"
                  passive	false
                  write	false
                  lastup	1706534049
                  zz	21
                  fields
                  name	""
                  value	"14:14:21"
                  VentilationDay
                  name	"VentilationDay"
                  passive	false
                  write	false
                  lastup	1706534079
                  zz	21
                  fields
                  name	""
                  value	0
                  VentilationNight
                  name	"VentilationNight"
                  passive	false
                  write	false
                  lastup	1706534080
                  zz	21
                  fields
                  name	""
                  value	0
                  ventilationTimer.Friday
                  name	"ventilationTimer.Friday"
                  passive	false
                  write	false
                  lastup	0
                  ventilationTimer.Monday
                  name	"ventilationTimer.Monday"
                  passive	false
                  write	false
                  lastup	0
                  ventilationTimer.Saturday
                  name	"ventilationTimer.Saturday"
                  passive	false
                  write	false
                  lastup	0
                  ventilationTimer.Sunday
                  name	"ventilationTimer.Sunday"
                  passive	false
                  write	false
                  lastup	0
                  ventilationTimer.Thursday
                  name	"ventilationTimer.Thursday"
                  passive	false
                  write	false
                  lastup	0
                  ventilationTimer.Tuesday
                  name	"ventilationTimer.Tuesday"
                  passive	false
                  write	false
                  lastup	0
                  ventilationTimer.Wednesday
                  name	"ventilationTimer.Wednesday"
                  passive	false
                  write	false
                  lastup	0
                  WaterPressure
                  name	"WaterPressure"
                  passive	false
                  write	false
                  lastup	1706534051
                  zz	21
                  fields
                  pressv
                  value	1.7
                  YieldTotal
                  name	"YieldTotal"
                  passive	false
                  write	false
                  lastup	0
                  z1ActualRoomTempDesired
                  name	"z1ActualRoomTempDesired"
                  passive	false
                  write	false
                  lastup	1706534062
                  zz	21
                  fields
                  tempv
                  value	22
                  z1BankHolidayEndPeriod
                  name	"z1BankHolidayEndPeriod"
                  passive	false
                  write	false
                  lastup	0
                  z1BankHolidayStartPeriod
                  name	"z1BankHolidayStartPeriod"
                  passive	false
                  write	false
                  lastup	0
                  z1CoolingTemp
                  name	"z1CoolingTemp"
                  passive	false
                  write	false
                  lastup	1706534077
                  zz	21
                  fields
                  tempv
                  value	22.5
                  z1CoolingTimer.Friday
                  name	"z1CoolingTimer.Friday"
                  passive	false
                  write	false
                  lastup	1706534079
                  zz	21
                  fields
                  name	"from"
                  value	"11:30"
                  name	"to"
                  value	"16:30"
                  name	"from"
                  value	"00:00"
                  name	"to"
                  value	"00:00"
                  name	"from"
                  value	"00:00"
                  name	"to"
                  value	"00:00"
                  z1CoolingTimer.Monday
                  name	"z1CoolingTimer.Monday"
                  passive	false
                  write	false
                  lastup	1706534078
                  zz	21
                  fields
                  name	"from"
                  value	"11:30"
                  name	"to"
                  value	"16:30"
                  name	"from"
                  value	"00:00"
                  name	"to"
                  value	"00:00"
                  name	"from"
                  value	"00:00"
                  name	"to"
                  value	"00:00"
                  z1CoolingTimer.Saturday
                  name	"z1CoolingTimer.Saturday"
                  passive	false
                  write	false
                  lastup	1706534079
                  zz	21
                  fields
                  name	"from"
                  value	"11:30"
                  name	"to"
                  value	"16:30"
                  name	"from"
                  value	"00:00"
                  name	"to"
                  value	"00:00"
                  name	"from"
                  value	"00:00"
                  name	"to"
                  value	"00:00"
                  z1CoolingTimer.Sunday
                  name	"z1CoolingTimer.Sunday"
                  passive	false
                  write	false
                  lastup	1706534079
                  zz	21
                  fields
                  name	"from"
                  value	"11:30"
                  name	"to"
                  value	"17:00"
                  name	"from"
                  value	"00:00"
                  name	"to"
                  value	"00:00"
                  name	"from"
                  value	"00:00"
                  name	"to"
                  value	"00:00"
                  z1CoolingTimer.Thursday
                  name	"z1CoolingTimer.Thursday"
                  passive	false
                  write	false
                  lastup	1706534078
                  zz	21
                  fields
                  name	"from"
                  value	"11:30"
                  name	"to"
                  value	"16:30"
                  name	"from"
                  value	"00:00"
                  name	"to"
                  value	"00:00"
                  name	"from"
                  value	"00:00"
                  name	"to"
                  value	"00:00"
                  z1CoolingTimer.Tuesday
                  name	"z1CoolingTimer.Tuesday"
                  passive	false
                  write	false
                  lastup	1706534078
                  zz	21
                  fields
                  name	"from"
                  value	"11:30"
                  name	"to"
                  value	"16:30"
                  name	"from"
                  value	"00:00"
                  name	"to"
                  value	"00:00"
                  name	"from"
                  value	"00:00"
                  name	"to"
                  value	"00:00"
                  z1CoolingTimer.Wednesday
                  name	"z1CoolingTimer.Wednesday"
                  passive	false
                  write	false
                  lastup	1706534078
                  zz	21
                  fields
                  name	"from"
                  value	"11:30"
                  name	"to"
                  value	"16:30"
                  name	"from"
                  value	"00:00"
                  name	"to"
                  value	"00:00"
                  name	"from"
                  value	"00:00"
                  name	"to"
                  value	"00:00"
                  z1DayTemp
                  name	"z1DayTemp"
                  passive	false
                  write	false
                  lastup	1706534075
                  zz	21
                  fields
                  tempv
                  value	22
                  z1HolidayEndPeriod
                  name	"z1HolidayEndPeriod"
                  passive	false
                  write	false
                  lastup	0
                  z1HolidayStartPeriod
                  name	"z1HolidayStartPeriod"
                  passive	false
                  write	false
                  lastup	0
                  z1HolidayTemp
                  name	"z1HolidayTemp"
                  passive	false
                  write	false
                  lastup	0
                  z1Name1
                  name	"z1Name1"
                  passive	false
                  write	false
                  lastup	1706534077
                  zz	21
                  fields
                  zname
                  value	"Wohnu"
                  z1Name2
                  name	"z1Name2"
                  passive	false
                  write	false
                  lastup	1706534077
                  zz	21
                  decodeerror	"ERR: invalid position"
                  z1NightTemp
                  name	"z1NightTemp"
                  passive	false
                  write	false
                  lastup	1706534075
                  zz	21
                  fields
                  tempv
                  value	19.5
                  z1OpMode
                  name	"z1OpMode"
                  passive	false
                  write	false
                  lastup	1706534057
                  zz	21
                  fields
                  opmode
                  value	"auto"
                  z1OpModeCooling
                  name	"z1OpModeCooling"
                  passive	false
                  write	false
                  lastup	1706534058
                  zz	21
                  fields
                  opmode
                  value	"off"
                  z1QuickVetoTemp
                  name	"z1QuickVetoTemp"
                  passive	false
                  write	false
                  lastup	1706534065
                  zz	21
                  fields
                  tempv
                  value	22
                  z1RoomTemp
                  name	"z1RoomTemp"
                  passive	false
                  write	false
                  lastup	1706534066
                  zz	21
                  fields
                  tempv
                  value	20.75
                  z1RoomZoneMapping
                  name	"z1RoomZoneMapping"
                  passive	false
                  write	false
                  lastup	0
                  z1SFMode
                  name	"z1SFMode"
                  passive	false
                  write	false
                  lastup	1706534065
                  zz	21
                  fields
                  sfmode
                  value	"auto"
                  z1Shortname
                  name	"z1Shortname"
                  passive	false
                  write	false
                  lastup	0
                  z1Timer.Friday
                  name	"z1Timer.Friday"
                  passive	false
                  write	false
                  lastup	1706534076
                  zz	21
                  fields
                  name	"from"
                  value	"05:10"
                  name	"to"
                  value	"22:00"
                  name	"from"
                  value	"22:10"
                  name	"to"
                  value	"22:10"
                  name	"from"
                  value	"22:10"
                  name	"to"
                  value	"22:10"
                  z1Timer.Monday
                  name	"z1Timer.Monday"
                  passive	false
                  write	false
                  lastup	1706534075
                  zz	21
                  fields
                  name	"from"
                  value	"05:10"
                  name	"to"
                  value	"22:00"
                  name	"from"
                  value	"22:10"
                  name	"to"
                  value	"22:10"
                  name	"from"
                  value	"22:10"
                  name	"to"
                  value	"22:10"
                  z1Timer.Saturday
                  name	"z1Timer.Saturday"
                  passive	false
                  write	false
                  lastup	1706534076
                  zz	21
                  fields
                  name	"from"
                  value	"06:30"
                  name	"to"
                  value	"22:00"
                  name	"from"
                  value	"00:00"
                  name	"to"
                  value	"00:00"
                  name	"from"
                  value	"00:00"
                  name	"to"
                  value	"00:00"
                  z1Timer.Sunday
                  name	"z1Timer.Sunday"
                  passive	false
                  write	false
                  lastup	1706534077
                  zz	21
                  fields
                  name	"from"
                  value	"06:30"
                  name	"to"
                  value	"22:00"
                  name	"from"
                  value	"00:00"
                  name	"to"
                  value	"00:00"
                  name	"from"
                  value	"00:00"
                  name	"to"
                  value	"00:00"
                  z1Timer.Thursday
                  name	"z1Timer.Thursday"
                  passive	false
                  write	false
                  lastup	1706534076
                  zz	21
                  fields
                  name	"from"
                  value	"05:10"
                  name	"to"
                  value	"22:00"
                  name	"from"
                  value	"22:10"
                  name	"to"
                  value	"22:10"
                  name	"from"
                  value	"22:10"
                  name	"to"
                  value	"22:10"
                  z1Timer.Tuesday
                  name	"z1Timer.Tuesday"
                  passive	false
                  write	false
                  lastup	1706534075
                  zz	21
                  fields
                  name	"from"
                  value	"05:10"
                  name	"to"
                  value	"22:00"
                  name	"from"
                  value	"22:10"
                  name	"to"
                  value	"22:10"
                  name	"from"
                  value	"22:10"
                  name	"to"
                  value	"22:10"
                  z1Timer.Wednesday
                  name	"z1Timer.Wednesday"
                  passive	false
                  write	false
                  lastup	1706534076
                  zz	21
                  fields
                  name	"from"
                  value	"05:10"
                  name	"to"
                  value	"22:00"
                  name	"from"
                  value	"22:10"
                  name	"to"
                  value	"22:10"
                  name	"from"
                  value	"22:10"
                  name	"to"
                  value	"22:10"
                  z1ValveStatus
                  name	"z1ValveStatus"
                  passive	false
                  write	false
                  lastup	0
                  z2ActualRoomTempDesired
                  name	"z2ActualRoomTempDesired"
                  passive	false
                  write	false
                  lastup	0
                  z2BankHolidayEndPeriod
                  name	"z2BankHolidayEndPeriod"
                  passive	false
                  write	false
                  lastup	0
                  z2BankHolidayStartPeriod
                  name	"z2BankHolidayStartPeriod"
                  passive	false
                  write	false
                  lastup	0
                  z2CoolingTemp
                  name	"z2CoolingTemp"
                  passive	false
                  write	false
                  lastup	0
                  z2CoolingTimer.Friday
                  name	"z2CoolingTimer.Friday"
                  passive	false
                  write	false
                  lastup	0
                  z2CoolingTimer.Monday
                  name	"z2CoolingTimer.Monday"
                  passive	false
                  write	false
                  lastup	0
                  z2CoolingTimer.Saturday
                  name	"z2CoolingTimer.Saturday"
                  passive	false
                  write	false
                  lastup	0
                  z2CoolingTimer.Sunday
                  name	"z2CoolingTimer.Sunday"
                  passive	false
                  write	false
                  lastup	0
                  z2CoolingTimer.Thursday
                  name	"z2CoolingTimer.Thursday"
                  passive	false
                  write	false
                  lastup	0
                  z2CoolingTimer.Tuesday
                  name	"z2CoolingTimer.Tuesday"
                  passive	false
                  write	false
                  lastup	0
                  z2CoolingTimer.Wednesday
                  name	"z2CoolingTimer.Wednesday"
                  passive	false
                  write	false
                  lastup	0
                  z2DayTemp
                  name	"z2DayTemp"
                  passive	false
                  write	false
                  lastup	0
                  z2HolidayEndPeriod
                  name	"z2HolidayEndPeriod"
                  passive	false
                  write	false
                  lastup	0
                  z2HolidayStartPeriod
                  name	"z2HolidayStartPeriod"
                  passive	false
                  write	false
                  lastup	0
                  z2HolidayTemp
                  name	"z2HolidayTemp"
                  passive	false
                  write	false
                  lastup	0
                  z2Name1
                  name	"z2Name1"
                  passive	false
                  write	false
                  lastup	0
                  z2Name2
                  name	"z2Name2"
                  passive	false
                  write	false
                  lastup	0
                  z2NightTemp
                  name	"z2NightTemp"
                  passive	false
                  write	false
                  lastup	0
                  z2OpMode
                  name	"z2OpMode"
                  passive	false
                  write	false
                  lastup	0
                  z2OpModeCooling
                  name	"z2OpModeCooling"
                  passive	false
                  write	false
                  lastup	0
                  z2QuickVetoTemp
                  name	"z2QuickVetoTemp"
                  passive	false
                  write	false
                  lastup	0
                  z2RoomTemp
                  name	"z2RoomTemp"
                  passive	false
                  write	false
                  lastup	0
                  z2RoomZoneMapping
                  name	"z2RoomZoneMapping"
                  passive	false
                  write	false
                  lastup	0
                  z2SFMode
                  name	"z2SFMode"
                  passive	false
                  write	false
                  lastup	0
                  z2Shortname
                  name	"z2Shortname"
                  passive	false
                  write	false
                  lastup	0
                  z2Timer.Friday
                  name	"z2Timer.Friday"
                  passive	false
                  write	false
                  lastup	0
                  z2Timer.Monday
                  name	"z2Timer.Monday"
                  passive	false
                  write	false
                  lastup	0
                  z2Timer.Saturday
                  name	"z2Timer.Saturday"
                  passive	false
                  write	false
                  lastup	0
                  z2Timer.Sunday
                  name	"z2Timer.Sunday"
                  passive	false
                  write	false
                  lastup	0
                  z2Timer.Thursday
                  name	"z2Timer.Thursday"
                  passive	false
                  write	false
                  lastup	0
                  z2Timer.Tuesday
                  name	"z2Timer.Tuesday"
                  passive	false
                  write	false
                  lastup	0
                  z2Timer.Wednesday
                  name	"z2Timer.Wednesday"
                  passive	false
                  write	false
                  lastup	0
                  z2ValveStatus
                  name	"z2ValveStatus"
                  passive	false
                  write	false
                  lastup	0
                  z3ActualRoomTempDesired
                  name	"z3ActualRoomTempDesired"
                  passive	false
                  write	false
                  lastup	0
                  z3BankHolidayEndPeriod
                  name	"z3BankHolidayEndPeriod"
                  passive	false
                  write	false
                  lastup	0
                  z3BankHolidayStartPeriod
                  name	"z3BankHolidayStartPeriod"
                  passive	false
                  write	false
                  lastup	0
                  z3CoolingTemp
                  name	"z3CoolingTemp"
                  passive	false
                  write	false
                  lastup	0
                  z3DayTemp
                  name	"z3DayTemp"
                  passive	false
                  write	false
                  lastup	0
                  z3HolidayEndPeriod
                  name	"z3HolidayEndPeriod"
                  passive	false
                  write	false
                  lastup	0
                  z3HolidayStartPeriod
                  name	"z3HolidayStartPeriod"
                  passive	false
                  write	false
                  lastup	0
                  z3HolidayTemp
                  name	"z3HolidayTemp"
                  passive	false
                  write	false
                  lastup	0
                  z3Name1
                  name	"z3Name1"
                  passive	false
                  write	false
                  lastup	0
                  z3Name2
                  name	"z3Name2"
                  passive	false
                  write	false
                  lastup	0
                  z3NightTemp
                  name	"z3NightTemp"
                  passive	false
                  write	false
                  lastup	0
                  z3OpMode
                  name	"z3OpMode"
                  passive	false
                  write	false
                  lastup	0
                  z3OpModeCooling
                  name	"z3OpModeCooling"
                  passive	false
                  write	false
                  lastup	0
                  z3QuickVetoTemp
                  name	"z3QuickVetoTemp"
                  passive	false
                  write	false
                  lastup	0
                  z3RoomTemp
                  name	"z3RoomTemp"
                  passive	false
                  write	false
                  lastup	0
                  z3RoomZoneMapping
                  name	"z3RoomZoneMapping"
                  passive	false
                  write	false
                  lastup	0
                  z3SFMode
                  name	"z3SFMode"
                  passive	false
                  write	false
                  lastup	0
                  z3Shortname
                  name	"z3Shortname"
                  passive	false
                  write	false
                  lastup	0
                  z3ValveStatus
                  name	"z3ValveStatus"
                  passive	false
                  write	false
                  lastup	0
                  broadcast
                  messages
                  datetime
                  name	"datetime"
                  passive	true
                  write	false
                  lastup	0
                  error
                  name	"error"
                  passive	true
                  write	false
                  lastup	0
                  hwcStatus
                  name	"hwcStatus"
                  passive	true
                  write	false
                  lastup	0
                  id-u
                  name	"id"
                  passive	true
                  write	false
                  lastup	0
                  load
                  name	"load"
                  passive	true
                  write	false
                  lastup	0
                  outsidetemp
                  name	"outsidetemp"
                  passive	true
                  write	false
                  lastup	1706534057
                  zz	254
                  fields
                  temp2
                  value	8.562
                  signoflife
                  name	"signoflife"
                  passive	true
                  write	false
                  lastup	0
                  vdatetime
                  name	"vdatetime"
                  passive	true
                  write	false
                  lastup	1706534056
                  zz	254
                  fields
                  time
                  value	"14:14:26"
                  date
                  value	"29.01.2024"
                  hmu
                  messages
                  ConsumptionThisYear10
                  name	"ConsumptionThisYear10"
                  passive	false
                  write	false
                  lastup	0
                  ConsumptionThisYear11
                  name	"ConsumptionThisYear11"
                  passive	false
                  write	false
                  lastup	0
                  ConsumptionThisYear12
                  name	"ConsumptionThisYear12"
                  passive	false
                  write	false
                  lastup	0
                  name	"ConsumptionThisYear1"
                  passive	false
                  write	false
                  lastup	0
                  ConsumptionThisYear2
                  name	"ConsumptionThisYear2"
                  passive	false
                  write	false
                  lastup	0
                  ConsumptionThisYear3
                  name	"ConsumptionThisYear3"
                  passive	false
                  write	false
                  lastup	0
                  ConsumptionThisYear4
                  name	"ConsumptionThisYear4"
                  passive	false
                  write	false
                  lastup	0
                  ConsumptionThisYear5
                  name	"ConsumptionThisYear5"
                  passive	false
                  write	false
                  lastup	0
                  ConsumptionThisYear6
                  name	"ConsumptionThisYear6"
                  passive	false
                  write	false
                  lastup	0
                  ConsumptionThisYear7
                  name	"ConsumptionThisYear7"
                  passive	false
                  write	false
                  lastup	0
                  ConsumptionThisYear8
                  name	"ConsumptionThisYear8"
                  passive	false
                  write	false
                  lastup	0
                  ConsumptionThisYear9
                  name	"ConsumptionThisYear9"
                  passive	false
                  write	false
                  lastup	0
                  ConsumptionTotal
                  name	"ConsumptionTotal"
                  passive	false
                  write	false
                  lastup	0
                  CurrentCompressorUtil
                  name	"CurrentCompressorUtil"
                  passive	false
                  write	false
                  lastup	0
                  CurrentConsumedPower
                  name	"CurrentConsumedPower"
                  passive	false
                  write	false
                  lastup	0
                  currenterror
                  name	"currenterror"
                  passive	false
                  write	false
                  lastup	1706533889
                  zz	8
                  fields
                  name	"error"
                  value	null
                  name	"error"
                  value	null
                  name	"error"
                  value	null
                  name	"error"
                  value	null
                  name	"error"
                  value	null
                  CurrentYieldPower
                  name	"CurrentYieldPower"
                  passive	false
                  write	false
                  lastup	0
                  DateTime
                  name	"DateTime"
                  passive	false
                  write	false
                  lastup	1706534056
                  zz	8
                  fields
                  dcfstate
                  value	"nosignal"
                  btime
                  value	"-:-:-"
                  bdate
                  value	"-.-.-"
                  temp2
                  value	8.812
                  EnergyCool
                  name	"EnergyCool"
                  passive	false
                  write	false
                  lastup	0
                  EnergyHc
                  name	"EnergyHc"
                  passive	false
                  write	false
                  lastup	0
                  EnergyIntegral
                  name	"EnergyIntegral"
                  passive	false
                  write	false
                  lastup	1706533833
                  zz	8
                  fields
                  integral
                  value	-222
                  errorhistory
                  name	"errorhistory"
                  passive	false
                  write	false
                  lastup	0
                  Hours
                  name	"Hours"
                  passive	false
                  write	false
                  lastup	0
                  HoursCool
                  name	"HoursCool"
                  passive	false
                  write	false
                  lastup	0
                  HoursHc
                  name	"HoursHc"
                  passive	false
                  write	false
                  lastup	0
                  SetMode
                  name	"SetMode"
                  passive	true
                  write	true
                  lastup	1706534097
                  zz	8
                  fields
                  hcmode
                  value	"auto"
                  flowtempdesired
                  value	25.5
                  hwctempdesired
                  value	null
                  hwcflowtempdesired
                  value	null
                  disablehc
                  value	0
                  disablehwctapping
                  value	1
                  disablehwcload
                  value	1
                  remoteControlHcPump
                  value	0
                  releaseBackup
                  value	0
                  releaseCooling
                  value	0
                  State
                  name	"State"
                  passive	false
                  write	false
                  lastup	0
                  Status01
                  name	"Status01"
                  passive	false
                  write	false
                  lastup	1706534094
                  zz	8
                  fields
                  name	"temp1"
                  value	29
                  name	"temp1"
                  value	24
                  name	"temp2"
                  value	8.812
                  name	"temp1"
                  value	null
                  name	"temp1"
                  value	47.5
                  name	"pumpstate"
                  value	"on"
                  Status02
                  name	"Status02"
                  passive	false
                  write	false
                  lastup	0
                  Status16
                  name	"Status16"
                  passive	false
                  write	false
                  lastup	0
                  Status
                  name	"Status"
                  passive	false
                  write	false
                  lastup	0
                  StatusCirPump
                  name	"StatusCirPump"
                  passive	true
                  write	true
                  lastup	1706533877
                  zz	8
                  fields
                  name	""
                  value	"on"
                  WaterThroughput
                  name	"WaterThroughput"
                  passive	false
                  write	false
                  lastup	0
                  YieldThisYear10
                  name	"YieldThisYear10"
                  passive	false
                  write	false
                  lastup	0
                  YieldThisYear11
                  name	"YieldThisYear11"
                  passive	false
                  write	false
                  lastup	0
                  YieldThisYear12
                  name	"YieldThisYear12"
                  passive	false
                  write	false
                  lastup	0
                  YieldThisYear1
                  name	"YieldThisYear1"
                  passive	false
                  write	false
                  lastup	0
                  YieldThisYear2
                  name	"YieldThisYear2"
                  passive	false
                  write	false
                  lastup	0
                  YieldThisYear3
                  name	"YieldThisYear3"
                  passive	false
                  write	false
                  lastup	0
                  YieldThisYear4
                  name	"YieldThisYear4"
                  passive	false
                  write	false
                  lastup	0
                  YieldThisYear5
                  name	"YieldThisYear5"
                  passive	false
                  write	false
                  lastup	0
                  YieldThisYear6
                  name	"YieldThisYear6"
                  passive	false
                  write	false
                  lastup	0
                  YieldThisYear7
                  name	"YieldThisYear7"
                  passive	false
                  write	false
                  lastup	0
                  YieldThisYear8
                  name	"YieldThisYear8"
                  passive	false
                  write	false
                  lastup	0
                  YieldThisYear9
                  name	"YieldThisYear9"
                  passive	false
                  write	false
                  lastup	0
                  YieldTotal
                  name	"YieldTotal"
                  passive	false
                  write	false
                  lastup	0
                  sc
                  messages
                  Col
                  name	"Col"
                  passive	false
                  write	false
                  lastup	0
                  ColKickPumpTime
                  name	"ColKickPumpTime"
                  passive	false
                  write	false
                  lastup	0
                  ColKickTempDelta
                  name	"ColKickTempDelta"
                  passive	false
                  write	false
                  lastup	0
                  CollPump
                  name	"CollPump"
                  passive	false
                  write	false
                  lastup	0
                  currenterror
                  name	"currenterror"
                  passive	false
                  write	false
                  lastup	0
                  D1Temp
                  name	"D1Temp"
                  passive	false
                  write	false
                  lastup	0
                  D2Temp
                  name	"D2Temp"
                  passive	false
                  write	false
                  lastup	0
                  Date
                  name	"Date"
                  passive	false
                  write	false
                  lastup	0
                  EDFunction
                  name	"EDFunction"
                  passive	false
                  write	false
                  lastup	0
                  EnableScProtection
                  name	"EnableScProtection"
                  passive	false
                  write	false
                  lastup	0
                  errorhistory
                  name	"errorhistory"
                  passive	false
                  write	false
                  lastup	0
                  FlowRate
                  name	"FlowRate"
                  passive	false
                  write	false
                  lastup	0
                  FrostProtectionEnabled
                  name	"FrostProtectionEnabled"
                  passive	false
                  write	false
                  lastup	0
                  FrostProtectionLimit
                  name	"FrostProtectionLimit"
                  passive	false
                  write	false
                  lastup	0
                  Hc1PumpKol1PP1Port
                  name	"Hc1PumpKol1PP1Port"
                  passive	false
                  write	false
                  lastup	0
                  Hc2aLegPumpP2Port
                  name	"Hc2aLegPumpP2Port"
                  passive	false
                  write	false
                  lastup	0
                  Hc2zPort
                  name	"Hc2zPort"
                  passive	false
                  write	false
                  lastup	0
                  HydraulicScheme
                  passive	false
                  write	false
                  lastup	0
                  InitCircuit
                  name	"InitCircuit"
                  passive	false
                  write	false
                  lastup	0
                  IsInBoostMode
                  name	"IsInBoostMode"
                  passive	false
                  write	false
                  lastup	0
                  KickFunction
                  name	"KickFunction"
                  passive	false
                  write	false
                  lastup	0
                  LpZpMaPort
                  name	"LpZpMaPort"
                  passive	false
                  write	false
                  lastup	0
                  MAPreferredStorage
                  name	"MAPreferredStorage"
                  passive	false
                  write	false
                  lastup	0
                  MaximalTemp2
                  name	"MaximalTemp2"
                  passive	false
                  write	false
                  lastup	0
                  MaximalTemp
                  name	"MaximalTemp"
                  passive	false
                  write	false
                  lastup	0
                  MultifunctionOutput
                  name	"MultifunctionOutput"
                  passive	false
                  write	false
                  lastup	0
                  OMultifunction
                  name	"OMultifunction"
                  passive	false
                  write	false
                  lastup	0
                  PumpAntiLockingFlags
                  name	"PumpAntiLockingFlags"
                  passive	false
                  write	false
                  lastup	0
                  QuickVetoStart
                  name	"QuickVetoStart"
                  passive	false
                  write	false
                  lastup	0
                  ResetSolGain
                  name	"ResetSolGain"
                  passive	false
                  write	false
                  lastup	0
                  RuntimeCollPump
                  name	"RuntimeCollPump"
                  passive	false
                  write	false
                  lastup	0
                  RuntimeCollPumpSeconds
                  name	"RuntimeCollPumpSeconds"
                  passive	false
                  write	false
                  lastup	0
                  ScProtectionHysteresis
                  name	"ScProtectionHysteresis"
                  passive	false
                  write	false
                  lastup	0
                  ScProtectionLimit
                  name	"ScProtectionLimit"
                  passive	false
                  write	false
                  lastup	0
                  ScProtectionTime
                  name	"ScProtectionTime"
                  passive	false
                  write	false
                  lastup	0
                  SolCollPumpDcIntegrator
                  name	"SolCollPumpDcIntegrator"
                  passive	false
                  write	false
                  lastup	0
                  SolCollPumpED
                  name	"SolCollPumpED"
                  passive	false
                  write	false
                  lastup	0
                  SolGain
                  name	"SolGain"
                  passive	false
                  write	false
                  lastup	0
                  SolOperationMode
                  name	"SolOperationMode"
                  passive	false
                  write	false
                  lastup	0
                  SP1
                  name	"SP1"
                  passive	false
                  write	false
                  lastup	0
                  SP2
                  name	"SP2"
                  passive	false
                  write	false
                  lastup	0
                  SumSolGain
                  name	"SumSolGain"
                  passive	false
                  write	false
                  lastup	0
                  SumSolGainDayBefore
                  name	"SumSolGainDayBefore"
                  passive	false
                  write	false
                  lastup	0
                  SystemMode
                  name	"SystemMode"
                  passive	false
                  write	false
                  lastup	0
                  TempDifferenceOff2
                  name	"TempDifferenceOff2"
                  passive	false
                  write	false
                  lastup	0
                  TempDifferenceOff
                  name	"TempDifferenceOff"
                  passive	false
                  write	false
                  lastup	0
                  TempDifferenceOffTD12
                  name	"TempDifferenceOffTD12"
                  passive	false
                  write	false
                  lastup	0
                  TempDifferenceOn2
                  name	"TempDifferenceOn2"
                  passive	false
                  write	false
                  lastup	0
                  TempDifferenceOn
                  name	"TempDifferenceOn"
                  passive	false
                  write	false
                  lastup	0
                  TempDifferenceOnTD12
                  name	"TempDifferenceOnTD12"
                  passive	false
                  write	false
                  lastup	0
                  Time
                  name	"Time"
                  passive	false
                  write	false
                  lastup	0
                  Weekday
                  name	"Weekday"
                  passive	false
                  write	false
                  lastup	0
                  YieldLastYear
                  name	"YieldLastYear"
                  passive	false
                  write	false
                  lastup	0
                  YieldThisYear
                  name	"YieldThisYear"
                  passive	false
                  write	false
                  lastup	1706534096
                  zz	236
                  scan.05
                  messages
                  name	""
                  passive	false
                  write	false
                  lastup	1704089059
                  zz	5
                  fields
                  MF
                  value	"Vaillant"
                  ID
                  value	"VR921"
                  SW
                  value	"2801"
                  HW
                  value	"5703"
                  scan.08
                  messages
                  name	""
                  passive	false
                  write	false
                  lastup	1704088873
                  zz	8
                  fields
                  MF
                  value	"Vaillant"
                  ID
                  value	"HMU00"
                  SW
                  value	"0308"
                  HW
                  value	"0403"
                  id
                  name	"id"
                  passive	false
                  write	false
                  lastup	1706486462
                  zz	8
                  fields
                  prefix
                  value	"21"
                  year
                  value	"20"
                  week
                  value	"29"
                  product
                  value	"0010016422"
                  supplier
                  value	"0001"
                  counter
                  value	"005547"
                  suffix
                  value	"N6"
                  scan.15
                  messages
                  name	""
                  passive	false
                  write	false
                  lastup	1706486429
                  zz	21
                  fields
                  MF
                  value	"Vaillant"
                  ID
                  value	"70000"
                  SW
                  value	"0614"
                  HW
                  value	"6903"
                  id
                  name	"id"
                  passive	false
                  write	false
                  lastup	1706486430
                  zz	21
                  fields
                  prefix
                  value	"21"
                  year
                  value	"20"
                  week
                  value	"43"
                  product
                  value	"0020266797"
                  supplier
                  value	"0082"
                  counter
                  value	"070010"
                  suffix
                  value	"N2"
                  scan.76
                  messages
                  name	""
                  passive	false
                  write	false
                  lastup	1704088952
                  zz	118
                  fields
                  MF
                  value	"Vaillant"
                  ID
                  value	"VWZ00"
                  SW
                  value	"0308"
                  HW
                  value	"0403"
                  id
                  name	"id"
                  passive	false
                  write	false
                  lastup	1704094964
                  zz	118
                  scan.ec
                  messages
                  name	""
                  passive	false
                  write	false
                  lastup	1704089051
                  zz	236
                  fields
                  MF
                  value	"Vaillant"
                  ID
                  value	"SOL00"
                  SW
                  value	"0614"
                  HW
                  value	"6903"
                  id
                  name	"id"
                  passive	false
                  write	false
                  lastup	1704089066
                  zz	236
                  fields
                  prefix
                  value	"21"
                  year
                  value	"20"
                  week
                  value	"43"
                  product
                  value	"0020266797"
                  supplier
                  value	"0082"
                  counter
                  value	"070010"
                  suffix
                  value	"N2"
                  global
                  version	"23.3.23.3"
                  signal	true
                  symbolrate	23
                  maxsymbolrate	318
                  minarbitrationmicros	2
                  maxarbitrationmicros	2214
                  minsymbollatency	0
                  maxsymbollatency	584
                  qq	49
                  reconnects	0
                  masters	5
                  messages	584
                  lastup	1706534097
                  Das ist eine ganze Menge aber es wird halt nicht jeder datenpunkt von jeder Heizung übertragen.
                  Ich nutze das System mit IOBroker um die Heizung Wetter/Sonnenscheinabhänig die Heizkruve anzupassen was insgesamt Mega funktioniert. Daten werden auch angezeigt.
                  Man kann sogar ncoh mehr Daten bekommen wenn man dezidiert die Datenpunkte im Adapter abfragt.
                  DerDani
                  • D Dan.Master
                    @thomas0807
                    700
                    messages
                    AdaptHeatCurve
                    passive	false
                    write	false
                    lastup	0
                    passive	false
                    write	false
                    lastup	0
                    passive	false
                    write	false
                    lastup	0
                    ccTimer.Friday
                    passive	false
                    write	false
                    lastup	1706534086
                    zz	21
                    fields
                    name	"from"
                    value	"04:40"
                    name	"to"
                    value	"23:00"
                    name	"from"
                    value	"00:00"
                    name	"to"
                    value	"00:00"
                    name	"from"
                    value	"00:00"
                    name	"to"
                    value	"00:00"
                    ccTimer.Monday
                    passive	false
                    write	false
                    lastup	1706534085
                    zz	21
                    fields
                    name	"from"
                    value	"04:40"
                    name	"to"
                    value	"23:00"
                    name	"from"
                    value	"00:00"
                    name	"to"
                    value	"00:00"
                    name	"from"
                    value	"00:00"
                    name	"to"
                    value	"00:00"
                    ccTimer.Saturday
                    passive	false
                    write	false
                    lastup	1706534086
                    zz	21
                    fields
                    name	"from"
                    value	"07:00"
                    name	"to"
                    value	"23:00"
                    name	"from"
                    value	"00:00"
                    name	"to"
                    value	"00:00"
                    name	"from"
                    value	"00:00"
                    name	"to"
                    value	"00:00"
                    ccTimer.Sunday
                    passive	false
                    write	false
                    lastup	1706534086
                    zz	21
                    fields
                    name	"from"
                    value	"07:00"
                    name	"to"
                    value	"23:00"
                    name	"from"
                    value	"00:00"
                    name	"to"
                    value	"00:00"
                    name	"from"
                    value	"00:00"
                    name	"to"
                    value	"00:00"
                    ccTimer.Thursday
                    passive	false
                    write	false
                    lastup	1706534086
                    zz	21
                    fields
                    name	"from"
                    value	"04:40"
                    name	"to"
                    value	"23:00"
                    name	"from"
                    value	"00:00"
                    name	"to"
                    value	"00:00"
                    name	"from"
                    value	"00:00"
                    name	"to"
                    value	"00:00"
                    ccTimer.Tuesday
                    passive	false
                    write	false
                    lastup	1706534085
                    zz	21
                    fields
                    name	"from"
                    value	"04:40"
                    name	"to"
                    value	"23:00"
                    name	"from"
                    value	"00:00"
                    name	"to"
                    value	"00:00"
                    name	"from"
                    value	"00:00"
                    name	"to"
                    value	"00:00"
                    ccTimer.Wednesday
                    passive	false
                    write	false
                    lastup	1706534086
                    zz	21
                    fields
                    name	"from"
                    value	"04:40"
                    name	"to"
                    value	"23:00"
                    name	"from"
                    value	"00:00"
                    name	"to"
                    value	"00:00"
                    name	"from"
                    value	"00:00"
                    name	"to"
                    value	"00:00"
                    ContinuosHeating
                    passive	false
                    write	false
                    lastup	0
                    currenterror
                    name	"currenterror"
                    passive	false
                    write	false
                    lastup	1706533894
                    zz	21
                    fields
                    name	"error"
                    value	null
                    name	"error"
                    value	null
                    name	"error"
                    value	null
                    name	"error"
                    value	null
                    name	"error"
                    value	null
                    CylinderChargeHyst
                    passive	false
                    write	false
                    lastup	0
                    passive	false
                    write	false
                    lastup	0
                    Date
                    name	"Date"
                    passive	false
                    write	false
                    lastup	1706534050
                    zz	21
                    fields
                    date
                    value	"29.01.2024"
                    passive	false
                    write	false
                    lastup	1706534051
                    zz	21
                    fields
                    tempv
                    value	8.5625
                    errorhistory
                    name	"errorhistory"
                    passive	false
                    write	false
                    lastup	0
                    FrostOverRideTime
                    passive	false
                    write	false
                    lastup	0
                    GlobalSystemOff
                    passive	false
                    write	false
                    lastup	1706534049
                    zz	21
                    fields
                    yesno
                    value	"no"
                    passive	false
                    write	false
                    lastup	0
                    Hc1AutoOffMode
                    passive	false
                    write	false
                    lastup	1706534054
                    zz	21
                    fields
                    offmode
                    value	"eco"
                    Hc1CircuitType
                    passive	false
                    write	false
                    lastup	1706534053
                    zz	21
                    fields
                    mctype
                    value	"mixer"
                    Hc1ExcessTemp
                    passive	false
                    write	false
                    lastup	0
                    Hc1FlowTemp
                    name	"Hc1FlowTemp"
                    passive	false
                    write	false
                    lastup	1706534053
                    zz	21
                    fields
                    tempv
                    value	29
                    Hc1HeatCurve
                    name	"Hc1HeatCurve"
                    passive	false
                    write	false
                    lastup	0
                    passive	false
                    write	false
                    lastup	0
                    passive	false
                    write	false
                    lastup	0
                    passive	false
                    write	false
                    lastup	0
                    Hc1MixerMovement
                    passive	false
                    write	false
                    lastup	0
                    Hc1PumpStatus
                    passive	false
                    write	false
                    lastup	1706534053
                    zz	21
                    fields
                    name	""
                    value	1
                    Hc1RoomTempSwitchOn
                    passive	false
                    write	false
                    lastup	0
                    Hc1Status
                    name	"Hc1Status"
                    passive	false
                    write	false
                    lastup	0
                    Hc1SummerTempLimit
                    passive	false
                    write	false
                    lastup	0
                    passive	false
                    write	false
                    lastup	0
                    Hc2AutoOffMode
                    passive	false
                    write	false
                    lastup	0
                    Hc2CircuitType
                    passive	false
                    write	false
                    lastup	0
                    Hc2ExcessTemp
                    passive	false
                    write	false
                    lastup	0
                    Hc2FlowTemp
                    name	"Hc2FlowTemp"
                    passive	false
                    write	false
                    lastup	0
                    Hc2HeatCurve
                    name	"Hc2HeatCurve"
                    passive	false
                    write	false
                    lastup	0
                    passive	false
                    write	false
                    lastup	0
                    passive	false
                    write	false
                    lastup	0
                    passive	false
                    write	false
                    lastup	0
                    Hc2MixerMovement
                    passive	false
                    write	false
                    lastup	0
                    Hc2PumpStatus
                    passive	false
                    write	false
                    lastup	0
                    Hc2RoomTempSwitchOn
                    passive	false
                    write	false
                    lastup	0
                    Hc2Status
                    name	"Hc2Status"
                    passive	false
                    write	false
                    lastup	0
                    Hc2SummerTempLimit
                    passive	false
                    write	false
                    lastup	0
                    passive	false
                    write	false
                    lastup	0
                    Hc3AutoOffMode
                    passive	false
                    write	false
                    lastup	0
                    Hc3CircuitType
                    passive	false
                    write	false
                    lastup	0
                    Hc3ExcessTemp
                    passive	false
                    write	false
                    lastup	0
                    Hc3FlowTemp
                    name	"Hc3FlowTemp"
                    passive	false
                    write	false
                    lastup	0
                    Hc3HeatCurve
                    name	"Hc3HeatCurve"
                    passive	false
                    write	false
                    lastup	0
                    passive	false
                    write	false
                    lastup	0
                    passive	false
                    write	false
                    lastup	0
                    passive	false
                    write	false
                    lastup	0
                    Hc3MixerMovement
                    passive	false
                    write	false
                    lastup	0
                    Hc3PumpStatus
                    passive	false
                    write	false
                    lastup	0
                    Hc3RoomTempSwitchOn
                    passive	false
                    write	false
                    lastup	0
                    Hc3Status
                    name	"Hc3Status"
                    passive	false
                    write	false
                    lastup	0
                    Hc3SummerTempLimit
                    passive	false
                    write	false
                    lastup	0
                    HcStorageTempBottom
                    passive	false
                    write	false
                    lastup	0
                    HcStorageTempTop
                    passive	false
                    write	false
                    lastup	0
                    HolidayEndPeriod
                    passive	false
                    write	false
                    lastup	1706534049
                    zz	21
                    fields
                    hto
                    value	"01.01.2015"
                    HolidayStartPeriod
                    passive	false
                    write	false
                    lastup	1706534049
                    zz	21
                    fields
                    hfrom
                    value	"01.01.2015"
                    HolidayTemp
                    name	"HolidayTemp"
                    passive	false
                    write	false
                    lastup	1706534050
                    zz	21
                    fields
                    tempv
                    value	15
                    passive	false
                    write	false
                    lastup	0
                    passive	false
                    write	false
                    lastup	0
                    HwcFlowTemp
                    name	"HwcFlowTemp"
                    passive	false
                    write	false
                    lastup	0
                    HwcHolidayEndPeriod
                    passive	false
                    write	false
                    lastup	0
                    passive	false
                    write	false
                    lastup	0
                    HwcLockTime
                    name	"HwcLockTime"
                    passive	false
                    write	false
                    lastup	0
                    passive	false
                    write	false
                    lastup	0
                    HwcOpMode
                    name	"HwcOpMode"
                    passive	false
                    write	false
                    lastup	1706534056
                    zz	21
                    fields
                    opmode
                    value	"auto"
                    HwcParallelLoading
                    passive	false
                    write	false
                    lastup	0
                    HwcSFMode
                    name	"HwcSFMode"
                    passive	false
                    write	false
                    lastup	1706534055
                    zz	21
                    fields
                    sfmode
                    value	"auto"
                    HwcStorageTemp
                    passive	false
                    write	false
                    lastup	1706534055
                    zz	21
                    fields
                    tempv
                    value	47.5
                    passive	false
                    write	false
                    lastup	0
                    HwcStorageTempTop
                    passive	false
                    write	false
                    lastup	0
                    HwcTempDesired
                    passive	false
                    write	false
                    lastup	1706534080
                    zz	21
                    fields
                    tempv
                    value	50
                    hwcTimer.Friday
                    passive	false
                    write	false
                    lastup	1706534082
                    zz	21
                    fields
                    name	"from"
                    value	"04:30"
                    name	"to"
                    value	"23:00"
                    name	"from"
                    value	"00:00"
                    name	"to"
                    value	"00:00"
                    name	"from"
                    value	"00:00"
                    name	"to"
                    value	"00:00"
                    hwcTimer.Monday
                    passive	false
                    write	false
                    lastup	1706534081
                    zz	21
                    fields
                    name	"from"
                    value	"04:30"
                    name	"to"
                    value	"23:00"
                    name	"from"
                    value	"00:00"
                    name	"to"
                    value	"00:00"
                    name	"from"
                    value	"00:00"
                    name	"to"
                    value	"00:00"
                    hwcTimer.Saturday
                    passive	false
                    write	false
                    lastup	1706534082
                    zz	21
                    fields
                    name	"from"
                    value	"07:00"
                    name	"to"
                    value	"23:00"
                    name	"from"
                    value	"00:00"
                    name	"to"
                    value	"00:00"
                    name	"from"
                    value	"00:00"
                    name	"to"
                    value	"00:00"
                    hwcTimer.Sunday
                    passive	false
                    write	false
                    lastup	1706534082
                    zz	21
                    fields
                    name	"from"
                    value	"06:00"
                    name	"to"
                    value	"23:00"
                    name	"from"
                    value	"00:00"
                    name	"to"
                    value	"00:00"
                    name	"from"
                    value	"00:00"
                    name	"to"
                    value	"00:00"
                    hwcTimer.Thursday
                    passive	false
                    write	false
                    lastup	1706534082
                    zz	21
                    fields
                    name	"from"
                    value	"04:30"
                    name	"to"
                    value	"23:00"
                    name	"from"
                    value	"00:00"
                    name	"to"
                    value	"00:00"
                    name	"from"
                    value	"00:00"
                    name	"to"
                    value	"00:00"
                    hwcTimer.Tuesday
                    passive	false
                    write	false
                    lastup	1706534081
                    zz	21
                    fields
                    name	"from"
                    value	"04:30"
                    name	"to"
                    value	"23:00"
                    name	"from"
                    value	"00:00"
                    name	"to"
                    value	"00:00"
                    name	"from"
                    value	"00:00"
                    name	"to"
                    value	"00:00"
                    hwcTimer.Wednesday
                    passive	false
                    write	false
                    lastup	1706534081
                    zz	21
                    fields
                    name	"from"
                    value	"04:30"
                    name	"to"
                    value	"23:00"
                    name	"from"
                    value	"00:00"
                    name	"to"
                    value	"00:00"
                    name	"from"
                    value	"00:00"
                    name	"to"
                    value	"00:00"
                    HydraulicScheme
                    passive	false
                    write	false
                    lastup	0
                    Installer1
                    name	"Installer1"
                    passive	false
                    write	false
                    lastup	0
                    Installer2
                    name	"Installer2"
                    passive	false
                    write	false
                    lastup	0
                    passive	false
                    write	false
                    lastup	0
                    MaintenanceDate
                    passive	false
                    write	false
                    lastup	0
                    MaintenanceDue
                    passive	false
                    write	false
                    lastup	0
                    ManualCooling
                    passive	false
                    write	false
                    lastup	1706534051
                    zz	21
                    fields
                    name	""
                    value	0
                    passive	false
                    write	false
                    lastup	0
                    MaxRoomHumidity
                    passive	false
                    write	false
                    lastup	0
                    MultiRelaySetting
                    passive	false
                    write	false
                    lastup	0
                    passive	false
                    write	false
                    lastup	0
                    passive	false
                    write	false
                    lastup	1706534080
                    zz	21
                    fields
                    name	"from"
                    value	"06:00"
                    name	"to"
                    value	"22:00"
                    name	"from"
                    value	"-:-"
                    name	"to"
                    value	"-:-"
                    name	"from"
                    value	"-:-"
                    name	"to"
                    value	"-:-"
                    passive	false
                    write	false
                    lastup	0
                    passive	false
                    write	false
                    lastup	0
                    passive	false
                    write	false
                    lastup	0
                    passive	false
                    write	false
                    lastup	0
                    passive	false
                    write	false
                    lastup	0
                    OpMode
                    name	"OpMode"
                    passive	false
                    write	false
                    lastup	0
                    OpModeCooling
                    passive	false
                    write	false
                    lastup	0
                    OpModeEffect
                    name	"OpModeEffect"
                    passive	false
                    write	false
                    lastup	1706534048
                    zz	21
                    fields
                    zonesel
                    value	"alle"
                    OpModeVentilation
                    passive	false
                    write	false
                    lastup	1706534048
                    zz	21
                    fields
                    opmode
                    value	"auto"
                    OutsideTempAvg
                    passive	false
                    write	false
                    lastup	0
                    PhoneNumber1
                    name	"PhoneNumber1"
                    passive	false
                    write	false
                    lastup	0
                    PhoneNumber2
                    name	"PhoneNumber2"
                    passive	false
                    write	false
                    lastup	0
                    PrEnergySum
                    name	"PrEnergySum"
                    passive	false
                    write	false
                    lastup	0
                    PrEnergySumHc
                    passive	false
                    write	false
                    lastup	0
                    passive	false
                    write	false
                    lastup	0
                    passive	false
                    write	false
                    lastup	0
                    PrEnergySumHwc
                    passive	false
                    write	false
                    lastup	0
                    passive	false
                    write	false
                    lastup	0
                    passive	false
                    write	false
                    lastup	0
                    PrFuelSum
                    name	"PrFuelSum"
                    passive	false
                    write	false
                    lastup	0
                    PrFuelSumHc
                    name	"PrFuelSumHc"
                    passive	false
                    write	false
                    lastup	0
                    passive	false
                    write	false
                    lastup	0
                    passive	false
                    write	false
                    lastup	0
                    PrFuelSumHwc
                    name	"PrFuelSumHwc"
                    passive	false
                    write	false
                    lastup	0
                    passive	false
                    write	false
                    lastup	0
                    passive	false
                    write	false
                    lastup	0
                    PumpAdditionalTime
                    passive	false
                    write	false
                    lastup	0
                    SFMode
                    name	"SFMode"
                    passive	false
                    write	false
                    lastup	1706534052
                    zz	21
                    fields
                    sfmode
                    value	"auto"
                    SolarYieldTotal
                    passive	false
                    write	false
                    lastup	0
                    SystemFlowTemp
                    passive	false
                    write	false
                    lastup	1706534052
                    zz	21
                    fields
                    tempv
                    value	null
                    tariffTimer.Friday
                    passive	false
                    write	false
                    lastup	0
                    tariffTimer.Monday
                    passive	false
                    write	false
                    lastup	0
                    passive	false
                    write	false
                    lastup	0
                    tariffTimer.Sunday
                    passive	false
                    write	false
                    lastup	0
                    passive	false
                    write	false
                    lastup	0
                    tariffTimer.Tuesday
                    passive	false
                    write	false
                    lastup	0
                    passive	false
                    write	false
                    lastup	0
                    Time
                    name	"Time"
                    passive	false
                    write	false
                    lastup	1706534049
                    zz	21
                    fields
                    name	""
                    value	"14:14:21"
                    VentilationDay
                    passive	false
                    write	false
                    lastup	1706534079
                    zz	21
                    fields
                    name	""
                    value	0
                    VentilationNight
                    passive	false
                    write	false
                    lastup	1706534080
                    zz	21
                    fields
                    name	""
                    value	0
                    passive	false
                    write	false
                    lastup	0
                    passive	false
                    write	false
                    lastup	0
                    passive	false
                    write	false
                    lastup	0
                    passive	false
                    write	false
                    lastup	0
                    passive	false
                    write	false
                    lastup	0
                    passive	false
                    write	false
                    lastup	0
                    passive	false
                    write	false
                    lastup	0
                    WaterPressure
                    passive	false
                    write	false
                    lastup	1706534051
                    zz	21
                    fields
                    pressv
                    value	1.7
                    YieldTotal
                    name	"YieldTotal"
                    passive	false
                    write	false
                    lastup	0
                    passive	false
                    write	false
                    lastup	1706534062
                    zz	21
                    fields
                    tempv
                    value	22
                    passive	false
                    write	false
                    lastup	0
                    passive	false
                    write	false
                    lastup	0
                    z1CoolingTemp
                    passive	false
                    write	false
                    lastup	1706534077
                    zz	21
                    fields
                    tempv
                    value	22.5
                    passive	false
                    write	false
                    lastup	1706534079
                    zz	21
                    fields
                    name	"from"
                    value	"11:30"
                    name	"to"
                    value	"16:30"
                    name	"from"
                    value	"00:00"
                    name	"to"
                    value	"00:00"
                    name	"from"
                    value	"00:00"
                    name	"to"
                    value	"00:00"
                    passive	false
                    write	false
                    lastup	1706534078
                    zz	21
                    fields
                    name	"from"
                    value	"11:30"
                    name	"to"
                    value	"16:30"
                    name	"from"
                    value	"00:00"
                    name	"to"
                    value	"00:00"
                    name	"from"
                    value	"00:00"
                    name	"to"
                    value	"00:00"
                    passive	false
                    write	false
                    lastup	1706534079
                    zz	21
                    fields
                    name	"from"
                    value	"11:30"
                    name	"to"
                    value	"16:30"
                    name	"from"
                    value	"00:00"
                    name	"to"
                    value	"00:00"
                    name	"from"
                    value	"00:00"
                    name	"to"
                    value	"00:00"
                    passive	false
                    write	false
                    lastup	1706534079
                    zz	21
                    fields
                    name	"from"
                    value	"11:30"
                    name	"to"
                    value	"17:00"
                    name	"from"
                    value	"00:00"
                    name	"to"
                    value	"00:00"
                    name	"from"
                    value	"00:00"
                    name	"to"
                    value	"00:00"
                    passive	false
                    write	false
                    lastup	1706534078
                    zz	21
                    fields
                    name	"from"
                    value	"11:30"
                    name	"to"
                    value	"16:30"
                    name	"from"
                    value	"00:00"
                    name	"to"
                    value	"00:00"
                    name	"from"
                    value	"00:00"
                    name	"to"
                    value	"00:00"
                    passive	false
                    write	false
                    lastup	1706534078
                    zz	21
                    fields
                    name	"from"
                    value	"11:30"
                    name	"to"
                    value	"16:30"
                    name	"from"
                    value	"00:00"
                    name	"to"
                    value	"00:00"
                    name	"from"
                    value	"00:00"
                    name	"to"
                    value	"00:00"
                    passive	false
                    write	false
                    lastup	1706534078
                    zz	21
                    fields
                    name	"from"
                    value	"11:30"
                    name	"to"
                    value	"16:30"
                    name	"from"
                    value	"00:00"
                    name	"to"
                    value	"00:00"
                    name	"from"
                    value	"00:00"
                    name	"to"
                    value	"00:00"
                    z1DayTemp
                    name	"z1DayTemp"
                    passive	false
                    write	false
                    lastup	1706534075
                    zz	21
                    fields
                    tempv
                    value	22
                    z1HolidayEndPeriod
                    passive	false
                    write	false
                    lastup	0
                    passive	false
                    write	false
                    lastup	0
                    z1HolidayTemp
                    passive	false
                    write	false
                    lastup	0
                    z1Name1
                    name	"z1Name1"
                    passive	false
                    write	false
                    lastup	1706534077
                    zz	21
                    fields
                    zname
                    value	"Wohnu"
                    z1Name2
                    name	"z1Name2"
                    passive	false
                    write	false
                    lastup	1706534077
                    zz	21
                    z1NightTemp
                    name	"z1NightTemp"
                    passive	false
                    write	false
                    lastup	1706534075
                    zz	21
                    fields
                    tempv
                    value	19.5
                    z1OpMode
                    name	"z1OpMode"
                    passive	false
                    write	false
                    lastup	1706534057
                    zz	21
                    fields
                    opmode
                    value	"auto"
                    z1OpModeCooling
                    passive	false
                    write	false
                    lastup	1706534058
                    zz	21
                    fields
                    opmode
                    value	"off"
                    z1QuickVetoTemp
                    passive	false
                    write	false
                    lastup	1706534065
                    zz	21
                    fields
                    tempv
                    value	22
                    z1RoomTemp
                    name	"z1RoomTemp"
                    passive	false
                    write	false
                    lastup	1706534066
                    zz	21
                    fields
                    tempv
                    value	20.75
                    z1RoomZoneMapping
                    passive	false
                    write	false
                    lastup	0
                    z1SFMode
                    name	"z1SFMode"
                    passive	false
                    write	false
                    lastup	1706534065
                    zz	21
                    fields
                    sfmode
                    value	"auto"
                    z1Shortname
                    name	"z1Shortname"
                    passive	false
                    write	false
                    lastup	0
                    z1Timer.Friday
                    passive	false
                    write	false
                    lastup	1706534076
                    zz	21
                    fields
                    name	"from"
                    value	"05:10"
                    name	"to"
                    value	"22:00"
                    name	"from"
                    value	"22:10"
                    name	"to"
                    value	"22:10"
                    name	"from"
                    value	"22:10"
                    name	"to"
                    value	"22:10"
                    z1Timer.Monday
                    passive	false
                    write	false
                    lastup	1706534075
                    zz	21
                    fields
                    name	"from"
                    value	"05:10"
                    name	"to"
                    value	"22:00"
                    name	"from"
                    value	"22:10"
                    name	"to"
                    value	"22:10"
                    name	"from"
                    value	"22:10"
                    name	"to"
                    value	"22:10"
                    z1Timer.Saturday
                    passive	false
                    write	false
                    lastup	1706534076
                    zz	21
                    fields
                    name	"from"
                    value	"06:30"
                    name	"to"
                    value	"22:00"
                    name	"from"
                    value	"00:00"
                    name	"to"
                    value	"00:00"
                    name	"from"
                    value	"00:00"
                    name	"to"
                    value	"00:00"
                    z1Timer.Sunday
                    passive	false
                    write	false
                    lastup	1706534077
                    zz	21
                    fields
                    name	"from"
                    value	"06:30"
                    name	"to"
                    value	"22:00"
                    name	"from"
                    value	"00:00"
                    name	"to"
                    value	"00:00"
                    name	"from"
                    value	"00:00"
                    name	"to"
                    value	"00:00"
                    z1Timer.Thursday
                    passive	false
                    write	false
                    lastup	1706534076
                    zz	21
                    fields
                    name	"from"
                    value	"05:10"
                    name	"to"
                    value	"22:00"
                    name	"from"
                    value	"22:10"
                    name	"to"
                    value	"22:10"
                    name	"from"
                    value	"22:10"
                    name	"to"
                    value	"22:10"
                    z1Timer.Tuesday
                    passive	false
                    write	false
                    lastup	1706534075
                    zz	21
                    fields
                    name	"from"
                    value	"05:10"
                    name	"to"
                    value	"22:00"
                    name	"from"
                    value	"22:10"
                    name	"to"
                    value	"22:10"
                    name	"from"
                    value	"22:10"
                    name	"to"
                    value	"22:10"
                    z1Timer.Wednesday
                    passive	false
                    write	false
                    lastup	1706534076
                    zz	21
                    fields
                    name	"from"
                    value	"05:10"
                    name	"to"
                    value	"22:00"
                    name	"from"
                    value	"22:10"
                    name	"to"
                    value	"22:10"
                    name	"from"
                    value	"22:10"
                    name	"to"
                    value	"22:10"
                    z1ValveStatus
                    passive	false
                    write	false
                    lastup	0
                    passive	false
                    write	false
                    lastup	0
                    passive	false
                    write	false
                    lastup	0
                    passive	false
                    write	false
                    lastup	0
                    z2CoolingTemp
                    passive	false
                    write	false
                    lastup	0
                    passive	false
                    write	false
                    lastup	0
                    passive	false
                    write	false
                    lastup	0
                    passive	false
                    write	false
                    lastup	0
                    passive	false
                    write	false
                    lastup	0
                    passive	false
                    write	false
                    lastup	0
                    passive	false
                    write	false
                    lastup	0
                    passive	false
                    write	false
                    lastup	0
                    z2DayTemp
                    name	"z2DayTemp"
                    passive	false
                    write	false
                    lastup	0
                    z2HolidayEndPeriod
                    passive	false
                    write	false
                    lastup	0
                    passive	false
                    write	false
                    lastup	0
                    z2HolidayTemp
                    passive	false
                    write	false
                    lastup	0
                    z2Name1
                    name	"z2Name1"
                    passive	false
                    write	false
                    lastup	0
                    z2Name2
                    name	"z2Name2"
                    passive	false
                    write	false
                    lastup	0
                    z2NightTemp
                    name	"z2NightTemp"
                    passive	false
                    write	false
                    lastup	0
                    z2OpMode
                    name	"z2OpMode"
                    passive	false
                    write	false
                    lastup	0
                    z2OpModeCooling
                    passive	false
                    write	false
                    lastup	0
                    z2QuickVetoTemp
                    passive	false
                    write	false
                    lastup	0
                    z2RoomTemp
                    name	"z2RoomTemp"
                    passive	false
                    write	false
                    lastup	0
                    z2RoomZoneMapping
                    passive	false
                    write	false
                    lastup	0
                    z2SFMode
                    name	"z2SFMode"
                    passive	false
                    write	false
                    lastup	0
                    z2Shortname
                    name	"z2Shortname"
                    passive	false
                    write	false
                    lastup	0
                    z2Timer.Friday
                    passive	false
                    write	false
                    lastup	0
                    z2Timer.Monday
                    passive	false
                    write	false
                    lastup	0
                    z2Timer.Saturday
                    passive	false
                    write	false
                    lastup	0
                    z2Timer.Sunday
                    passive	false
                    write	false
                    lastup	0
                    z2Timer.Thursday
                    passive	false
                    write	false
                    lastup	0
                    z2Timer.Tuesday
                    passive	false
                    write	false
                    lastup	0
                    z2Timer.Wednesday
                    passive	false
                    write	false
                    lastup	0
                    z2ValveStatus
                    passive	false
                    write	false
                    lastup	0
                    passive	false
                    write	false
                    lastup	0
                    passive	false
                    write	false
                    lastup	0
                    passive	false
                    write	false
                    lastup	0
                    z3CoolingTemp
                    passive	false
                    write	false
                    lastup	0
                    z3DayTemp
                    name	"z3DayTemp"
                    passive	false
                    write	false
                    lastup	0
                    z3HolidayEndPeriod
                    passive	false
                    write	false
                    lastup	0
                    passive	false
                    write	false
                    lastup	0
                    z3HolidayTemp
                    passive	false
                    write	false
                    lastup	0
                    z3Name1
                    name	"z3Name1"
                    passive	false
                    write	false
                    lastup	0
                    z3Name2
                    name	"z3Name2"
                    passive	false
                    write	false
                    lastup	0
                    z3NightTemp
                    name	"z3NightTemp"
                    passive	false
                    write	false
                    lastup	0
                    z3OpMode
                    name	"z3OpMode"
                    passive	false
                    write	false
                    lastup	0
                    z3OpModeCooling
                    passive	false
                    write	false
                    lastup	0
                    z3QuickVetoTemp
                    passive	false
                    write	false
                    lastup	0
                    z3RoomTemp
                    name	"z3RoomTemp"
                    passive	false
                    write	false
                    lastup	0
                    z3RoomZoneMapping
                    passive	false
                    write	false
                    lastup	0
                    z3SFMode
                    name	"z3SFMode"
                    passive	false
                    write	false
                    lastup	0
                    z3Shortname
                    name	"z3Shortname"
                    passive	false
                    write	false
                    lastup	0
                    z3ValveStatus
                    passive	false
                    write	false
                    lastup	0
                    broadcast
                    messages
                    datetime
                    name	"datetime"
                    passive	true
                    write	false
                    lastup	0
                    error
                    name	"error"
                    passive	true
                    write	false
                    lastup	0
                    hwcStatus
                    name	"hwcStatus"
                    passive	true
                    write	false
                    lastup	0
                    id-u
                    name	"id"
                    passive	true
                    write	false
                    lastup	0
                    load
                    name	"load"
                    passive	true
                    write	false
                    lastup	0
                    outsidetemp
                    name	"outsidetemp"
                    passive	true
                    write	false
                    lastup	1706534057
                    zz	254
                    fields
                    temp2
                    value	8.562
                    signoflife
                    name	"signoflife"
                    passive	true
                    write	false
                    lastup	0
                    vdatetime
                    name	"vdatetime"
                    passive	true
                    write	false
                    lastup	1706534056
                    zz	254
                    fields
                    time
                    value	"14:14:26"
                    date
                    value	"29.01.2024"
                    hmu
                    messages
                    passive	false
                    write	false
                    lastup	0
                    passive	false
                    write	false
                    lastup	0
                    passive	false
                    write	false
                    lastup	0
                    passive	false
                    write	false
                    lastup	0
                    passive	false
                    write	false
                    lastup	0
                    passive	false
                    write	false
                    lastup	0
                    passive	false
                    write	false
                    lastup	0
                    passive	false
                    write	false
                    lastup	0
                    passive	false
                    write	false
                    lastup	0
                    passive	false
                    write	false
                    lastup	0
                    passive	false
                    write	false
                    lastup	0
                    passive	false
                    write	false
                    lastup	0
                    ConsumptionTotal
                    passive	false
                    write	false
                    lastup	0
                    passive	false
                    write	false
                    lastup	0
                    passive	false
                    write	false
                    lastup	0
                    currenterror
                    name	"currenterror"
                    passive	false
                    write	false
                    lastup	1706533889
                    zz	8
                    fields
                    name	"error"
                    value	null
                    name	"error"
                    value	null
                    name	"error"
                    value	null
                    name	"error"
                    value	null
                    name	"error"
                    value	null
                    CurrentYieldPower
                    passive	false
                    write	false
                    lastup	0
                    DateTime
                    name	"DateTime"
                    passive	false
                    write	false
                    lastup	1706534056
                    zz	8
                    fields
                    dcfstate
                    value	"nosignal"
                    btime
                    value	"-:-:-"
                    bdate
                    value	"-.-.-"
                    temp2
                    value	8.812
                    EnergyCool
                    name	"EnergyCool"
                    passive	false
                    write	false
                    lastup	0
                    EnergyHc
                    name	"EnergyHc"
                    passive	false
                    write	false
                    lastup	0
                    EnergyIntegral
                    passive	false
                    write	false
                    lastup	1706533833
                    zz	8
                    fields
                    integral
                    value	-222
                    errorhistory
                    name	"errorhistory"
                    passive	false
                    write	false
                    lastup	0
                    Hours
                    name	"Hours"
                    passive	false
                    write	false
                    lastup	0
                    HoursCool
                    name	"HoursCool"
                    passive	false
                    write	false
                    lastup	0
                    HoursHc
                    name	"HoursHc"
                    passive	false
                    write	false
                    lastup	0
                    SetMode
                    name	"SetMode"
                    passive	true
                    write	true
                    lastup	1706534097
                    zz	8
                    fields
                    hcmode
                    value	"auto"
                    flowtempdesired
                    value	25.5
                    hwctempdesired
                    value	null
                    hwcflowtempdesired
                    value	null
                    disablehc
                    value	0
                    disablehwctapping
                    value	1
                    disablehwcload
                    value	1
                    remoteControlHcPump
                    value	0
                    releaseBackup
                    value	0
                    releaseCooling
                    value	0
                    State
                    name	"State"
                    passive	false
                    write	false
                    lastup	0
                    Status01
                    name	"Status01"
                    passive	false
                    write	false
                    lastup	1706534094
                    zz	8
                    fields
                    name	"temp1"
                    value	29
                    name	"temp1"
                    value	24
                    name	"temp2"
                    value	8.812
                    name	"temp1"
                    value	null
                    name	"temp1"
                    value	47.5
                    name	"pumpstate"
                    value	"on"
                    Status02
                    name	"Status02"
                    passive	false
                    write	false
                    lastup	0
                    Status16
                    name	"Status16"
                    passive	false
                    write	false
                    lastup	0
                    Status
                    name	"Status"
                    passive	false
                    write	false
                    lastup	0
                    StatusCirPump
                    passive	true
                    write	true
                    lastup	1706533877
                    zz	8
                    fields
                    name	""
                    value	"on"
                    WaterThroughput
                    passive	false
                    write	false
                    lastup	0
                    YieldThisYear10
                    passive	false
                    write	false
                    lastup	0
                    YieldThisYear11
                    passive	false
                    write	false
                    lastup	0
                    YieldThisYear12
                    passive	false
                    write	false
                    lastup	0
                    YieldThisYear1
                    passive	false
                    write	false
                    lastup	0
                    YieldThisYear2
                    passive	false
                    write	false
                    lastup	0
                    YieldThisYear3
                    passive	false
                    write	false
                    lastup	0
                    YieldThisYear4
                    passive	false
                    write	false
                    lastup	0
                    YieldThisYear5
                    passive	false
                    write	false
                    lastup	0
                    YieldThisYear6
                    passive	false
                    write	false
                    lastup	0
                    YieldThisYear7
                    passive	false
                    write	false
                    lastup	0
                    YieldThisYear8
                    passive	false
                    write	false
                    lastup	0
                    YieldThisYear9
                    passive	false
                    write	false
                    lastup	0
                    YieldTotal
                    name	"YieldTotal"
                    passive	false
                    write	false
                    lastup	0
                    sc
                    messages
                    Col
                    name	"Col"
                    passive	false
                    write	false
                    lastup	0
                    ColKickPumpTime
                    passive	false
                    write	false
                    lastup	0
                    ColKickTempDelta
                    passive	false
                    write	false
                    lastup	0
                    CollPump
                    name	"CollPump"
                    passive	false
                    write	false
                    lastup	0
                    currenterror
                    name	"currenterror"
                    passive	false
                    write	false
                    lastup	0
                    D1Temp
                    name	"D1Temp"
                    passive	false
                    write	false
                    lastup	0
                    D2Temp
                    name	"D2Temp"
                    passive	false
                    write	false
                    lastup	0
                    Date
                    name	"Date"
                    passive	false
                    write	false
                    lastup	0
                    EDFunction
                    name	"EDFunction"
                    passive	false
                    write	false
                    lastup	0
                    EnableScProtection
                    passive	false
                    write	false
                    lastup	0
                    errorhistory
                    name	"errorhistory"
                    passive	false
                    write	false
                    lastup	0
                    FlowRate
                    name	"FlowRate"
                    passive	false
                    write	false
                    lastup	0
                    passive	false
                    write	false
                    lastup	0
                    passive	false
                    write	false
                    lastup	0
                    Hc1PumpKol1PP1Port
                    passive	false
                    write	false
                    lastup	0
                    Hc2aLegPumpP2Port
                    passive	false
                    write	false
                    lastup	0
                    Hc2zPort
                    name	"Hc2zPort"
                    passive	false
                    write	false
                    lastup	0
                    HydraulicScheme
                    passive	false
                    write	false
                    lastup	0
                    InitCircuit
                    name	"InitCircuit"
                    passive	false
                    write	false
                    lastup	0
                    IsInBoostMode
                    passive	false
                    write	false
                    lastup	0
                    KickFunction
                    name	"KickFunction"
                    passive	false
                    write	false
                    lastup	0
                    LpZpMaPort
                    name	"LpZpMaPort"
                    passive	false
                    write	false
                    lastup	0
                    MAPreferredStorage
                    passive	false
                    write	false
                    lastup	0
                    MaximalTemp2
                    name	"MaximalTemp2"
                    passive	false
                    write	false
                    lastup	0
                    MaximalTemp
                    name	"MaximalTemp"
                    passive	false
                    write	false
                    lastup	0
                    MultifunctionOutput
                    passive	false
                    write	false
                    lastup	0
                    OMultifunction
                    passive	false
                    write	false
                    lastup	0
                    passive	false
                    write	false
                    lastup	0
                    QuickVetoStart
                    passive	false
                    write	false
                    lastup	0
                    ResetSolGain
                    name	"ResetSolGain"
                    passive	false
                    write	false
                    lastup	0
                    RuntimeCollPump
                    passive	false
                    write	false
                    lastup	0
                    passive	false
                    write	false
                    lastup	0
                    passive	false
                    write	false
                    lastup	0
                    ScProtectionLimit
                    passive	false
                    write	false
                    lastup	0
                    ScProtectionTime
                    passive	false
                    write	false
                    lastup	0
                    passive	false
                    write	false
                    lastup	0
                    SolCollPumpED
                    passive	false
                    write	false
                    lastup	0
                    SolGain
                    name	"SolGain"
                    passive	false
                    write	false
                    lastup	0
                    SolOperationMode
                    passive	false
                    write	false
                    lastup	0
                    SP1
                    name	"SP1"
                    passive	false
                    write	false
                    lastup	0
                    SP2
                    name	"SP2"
                    passive	false
                    write	false
                    lastup	0
                    SumSolGain
                    name	"SumSolGain"
                    passive	false
                    write	false
                    lastup	0
                    SumSolGainDayBefore
                    passive	false
                    write	false
                    lastup	0
                    SystemMode
                    name	"SystemMode"
                    passive	false
                    write	false
                    lastup	0
                    TempDifferenceOff2
                    passive	false
                    write	false
                    lastup	0
                    TempDifferenceOff
                    passive	false
                    write	false
                    lastup	0
                    passive	false
                    write	false
                    lastup	0
                    TempDifferenceOn2
                    passive	false
                    write	false
                    lastup	0
                    TempDifferenceOn
                    passive	false
                    write	false
                    lastup	0
                    passive	false
                    write	false
                    lastup	0
                    Time
                    name	"Time"
                    passive	false
                    write	false
                    lastup	0
                    Weekday
                    name	"Weekday"
                    passive	false
                    write	false
                    lastup	0
                    YieldLastYear
                    passive	false
                    write	false
                    lastup	0
                    YieldThisYear
                    passive	false
                    write	false
                    lastup	1706534096
                    zz	236
                    scan.05
                    messages
                    name	""
                    passive	false
                    write	false
                    lastup	1704089059
                    zz	5
                    fields
                    MF
                    value	"Vaillant"
                    ID
                    value	"VR921"
                    SW
                    value	"2801"
                    HW
                    value	"5703"
                    scan.08
                    messages
                    name	""
                    passive	false
                    write	false
                    lastup	1704088873
                    zz	8
                    fields
                    MF
                    value	"Vaillant"
                    ID
                    value	"HMU00"
                    SW
                    value	"0308"
                    HW
                    value	"0403"
                    id
                    name	"id"
                    passive	false
                    write	false
                    lastup	1706486462
                    zz	8
                    fields
                    prefix
                    value	"21"
                    year
                    value	"20"
                    week
                    value	"29"
                    product
                    value	"0010016422"
                    supplier
                    value	"0001"
                    counter
                    value	"005547"
                    suffix
                    value	"N6"
                    scan.15
                    messages
                    name	""
                    passive	false
                    write	false
                    lastup	1706486429
                    zz	21
                    fields
                    MF
                    value	"Vaillant"
                    ID
                    value	"70000"
                    SW
                    value	"0614"
                    HW
                    value	"6903"
                    id
                    name	"id"
                    passive	false
                    write	false
                    lastup	1706486430
                    zz	21
                    fields
                    prefix
                    value	"21"
                    year
                    value	"20"
                    week
                    value	"43"
                    product
                    value	"0020266797"
                    supplier
                    value	"0082"
                    counter
                    value	"070010"
                    suffix
                    value	"N2"
                    scan.76
                    messages
                    name	""
                    passive	false
                    write	false
                    lastup	1704088952
                    zz	118
                    fields
                    MF
                    value	"Vaillant"
                    ID
                    value	"VWZ00"
                    SW
                    value	"0308"
                    HW
                    value	"0403"
                    id
                    name	"id"
                    passive	false
                    write	false
                    lastup	1704094964
                    zz	118
                    scan.ec
                    messages
                    name	""
                    passive	false
                    write	false
                    lastup	1704089051
                    zz	236
                    fields
                    MF
                    value	"Vaillant"
                    ID
                    value	"SOL00"
                    SW
                    value	"0614"
                    HW
                    value	"6903"
                    id
                    name	"id"
                    passive	false
                    write	false
                    lastup	1704089066
                    zz	236
                    fields
                    prefix
                    value	"21"
                    year
                    value	"20"
                    week
                    value	"43"
                    product
                    value	"0020266797"
                    supplier
                    value	"0082"
                    counter
                    value	"070010"
                    suffix
                    value	"N2"
                    global
                    version	"23.3.23.3"
                    signal	true
                    symbolrate	23
                    maxsymbolrate	318
                    minsymbollatency	0
                    qq	49
                    reconnects	0
                    masters	5
                    messages	584
                    lastup	1706534097
                    DerDani
                    Thomas0807
                    #363
                    @dan-master
                    Ja das hört sich doch schonma super an. Vorallem die Heizkurve anpassen. Dazu werde ich mich bestimmt noch bei dir melden wie du das gemacht hast. Hast du auch den esera als koppler?
                    Thomas
                      Dan.Master
                      schrieb am zuletzt editiert von Dan.Master
                      #364
                      @thomas0807
                      Ich arbeite mit dem ESERA Koppler mit einer USB Anbindung an einen Raspberry der direkt an der Heizung ist der IOBrober läuft im Docker Conatiner auf einem NUC11. Ich habe aber auch schon von Problematischen Installationen gehört incl der Abgleich mit dem Poti. Bei mir lief zum Glück alles out of the BOX.
                      Bin mit dem EBUS in ein eigene "Unterverteilung" mit 6 Plätzen gegangen da ist der Pi3 mit dem ESERA USB dort habe ich ein paar Phoenix Klemmen um den EBUS zu Verteilen. Eine Leitung geht an der VR921 und die andere an die Multimatic 700.
                      DerDani
                      T 2 Antworten Letzte Antwort
                      • D Dan.Master
                        @thomas0807
                        DerDani
                        Thomas0807
                        #365
                        @dan-master das hört sich an als wärst du vom Fach? An die multimatic kann man auch ran? Die ist bei mir in der Heizung eingebaut. Kommt kann da ran? Vielleicht kannst du mir ja mal deinen Aufbau schicken?!.
                        Thomas
                        • D Dan.Master
                          @thomas0807
                          DerDani
                          Thomas0807
                          #366
                          @dan-master Habe mir gerade mal deinen Aufbau in einem anderen Post gelesen, klingt spannend. Das Blocky würde mich auch interessieren.
                          Thomas
                          • T Thomas0807
                            Thomas
                            Dan.Master
                            #367
                            @thomas0807
                            Hallo Thomas,
                            vom Fach würde ich nicht sagen aber schon seit 25 Jahre Wärmepumpen Besitzer. Beruflich als SPS Techniker gearbeitet viel mit Steuer und Regelungstechnik zu tun gehabt.
                            Durch die Trägheit in unserem System einiges Überlegt und dann umgesetzt.
                            Man kann überreall ran wo der EBUS liegt. Das Bussystem ist quasi eine Spannungserversorgung mit "drauf" liegenden Daten. (Extrem vereinfacht gesagt).
                            Welche Heizung hast du denn in den Vaillaint Systemen gibt es extra Klemmen für den EBus und die Heizung erkennt dann automatisch ob du "intern" in der Heizung bist oder "Extern" ausserhalb. Dann sind auch ein paar Sachen mehr in der Multimatic aktiv.
                            Meine Blocklys bzw ein Javascript kannst du bekommen ich exportiere die nacher mal und schaue wo ich das ablege.
                            Daniel
                            • T Thomas0807
                              Thomas
                              Dan.Master
                              #368
                              @thomas0807 02_Interpol_Korrekturwert.json 00_Wolkenauswertung.json 03_SteuerungWP.json
                              Hallo Thomas,
                              das sind die drei Skripte dazu.
                              Hier mal kleine Erklärung mit dem Adater dasWetter hole ich die Daten ab. Es ist immer der heutige Tag unter Tag1.
                              Und über den Tag den Wolken Wert um 8/11/14/17 Uhr.
                              Daraus bilden des Mittelwerts für den Tag.
                              Im JS Interpol weise ich dem Wolkenwert einen "Abzug" der normalen HeatCurve mit einerm Wert von 0.0 bei 100% Wolken und 0.11 bei 0% Wolken zu. (Eingabe im Skript von Ymin/Ymax) Die Formel sieht man im Script.
                              Das wird dann morgens um 5:10 und 8:10 an die Pumpe gesendet und über den EBUSD.
                              Jeden Abend wird dann der Ursprungswert und HCBackup um 19 Uhr geschrieben.
                              Nichts wildes funktioniert und hat Nachweißlich 5-8% Energie gespart.
                              Daniel
                              Die JSON oben sind die Skipte aus nem aktuellen IOBroker exportiert.
                              • D Dan.Master
                                @thomas0807
                                Hallo Thomas,
                                Daniel
                                Thomas0807
                                #369
                                @dan-master ok, bei uns ist eine ecotec verbaut, also keine WP sondern eine Gasheizung. Aber ich denke das sollte keinen Unterschied machen. Ich gucke am Wochenende mal wo der Ebus an der multimatic zu finden ist.
                                Ach und super großes danke für die Exporte.
                                Thomas
                                • T Thomas0807
                                  Thomas
                                  Dan.Master
                                  #370
                                  @thomas0807
                                  Hier zwei Bilder von der Lokalen umstetzung.
                                  Daniel
                                  P 1 Antwort Letzte Antwort
                                  • D Dan.Master
                                    @thomas0807
                                    Daniel
                                    peterfido
                                    #371
                                    Ich würde jetzt nicht mehrmals täglich die Sollwerte wie Heizkurve ändern. Flashspeicher hat eine begrenzte Anzahl an Schreibzyklen, welche man bei der Lebenserwartung einer Heizung dann durchaus erreichen kann.
                                    Evtl. kann man die Heizkurve an sich etwas optimieren.
                                    Peterfido
                                    • P peterfido
                                      Dan.Master
                                      #372
                                      @peterfido
                                      Also moderne Flash Speicher lassen sich 30 -100.000 beschreiben.
                                      Hier wird im "schlechtesten Fall" 2 mal am Tag beschrieben das sind bei 30k/2= 15000 Tage das sind dann 41 Jahre im schlechten Fall bei 100k Zyklen wären es 120 Jahre. Also wird das länger als das Leben der Heizung halten.
                                      Daniel
                                        akloud
                                        #373
                                        Hallo!
                                        Ich kann vom iobroker aus meine VWS steuern, z.B. durch das Setzen von cmd auf "write -c mc TempDesired 22.0":
                                        Um PV-Überschuss allerdings sinnvoll verwenden zu können, würde ich gerne die Speicherladung des Warmwasserspeichers anstoßen. In der ebusd.log sehe ich auch folgende Meldung, wenn ich dies über das Bedienteil anstoße:
                                        2024-06-01 14:07:08.321 [update notice] received update-read broadcast load QQ=10: on
                                        Nach einger Zeit dann auch
                                        2024-06-01 14:37:27.525 [update notice] received update-read broadcast load QQ=10: off
                                        Wie kann ich diesen Befehl nun per iobroker oder ebusctl absetzen? Ich weiß ehrlich gesagt noch nicht einmal, wie ich den aktuellen Wert auslese:
                                        In meinem Objektbaum sehe ich diese Nachricht jedenfalls:
                                        Ich hoffe, dass mir einer der Experten hier weiterhelfen kann! Falls mein Ziel, PV-Überschuss möglichst sinnvoll selber zu nutzen besser anders erreicht werden kann, freue ich mich ebenfalls über eine Rückmeldung!
                                        Vielen Dank!
                                        LG
                                        Andreas
                                        • A akloud
                                          Hallo!
                                          Vielen Dank!
                                          LG
                                          Andreas
                                          Dan.Master
                                          #374
                                          @akloud
                                          Hallo Andreas,
                                          mit :
                                          ebusctl find -F circuit,name,comment
                                          Kannst du alle Elemente auflisten die im EBUS so rumflirren. Dort müsstest du den genauen Bezeichner finden unter broadcast.
                                          Dann damit mal versuchen.
                                          Daniel
