  4. Jarvis Adapter lässt sich nicht Installieren
83 Beiträge 5 Kommentatoren 12.5k Aufrufe 2 Beobachtet
  • S Schweiz
    john@raspberrypi:~ $ iob update
    Used repository: stable
    Adapter    "admin"        : 6.12.0   , installed 6.12.0
    Adapter    "alexa2"       : 3.26.4   , installed 3.26.3 [Updatable]
    Adapter    "backitup"     : 2.9.8    , installed 2.9.8
    Adapter    "discovery"    : 4.2.0    , installed 4.2.0
    Adapter    "enigma2"      : 2.0.5    , installed 2.0.5
    Adapter    "fb-checkpresence": 1.2.2 , installed 1.2.2
    Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
    Adapter    "heizoel"      : 1.0.3    , installed 1.0.3
    Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
    Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
    Adapter    "ical"         : 1.13.3   , installed 1.13.3
    Adapter    "iceroad"      : 1.2.1    , installed 1.2.1
    Adapter    "javascript"   : 7.1.6    , installed 7.1.6
    Controller "js-controller": 5.0.17   , installed 5.0.17
    Adapter    "smartthings"  : 0.0.4    , installed 0.0.4
    Adapter    "socketio"     : 6.6.0    , installed 6.6.0
    Adapter    "telegram"     : 3.0.1    , installed 3.0.1
    Adapter    "telegram-menu": 1.5.1    , installed 1.5.1
    Adapter    "trashschedule": 2.3.0    , installed 2.3.0
    Adapter    "viessmannapi" : 2.3.0    , installed 2.4.0
    Adapter    "weather-warnings": 0.6.6 , installed 0.6.4  [Updatable]
    Adapter    "web"          : 6.1.10   , installed 6.1.10
    Adapter    "worx"         : 2.3.4    , installed 2.3.4
    Adapter    "ws"           : 2.5.8    , installed 2.5.8
    Adapter    "youtube"      : 4.4.0    , installed 4.4.0
    also wenn ich alexa versuche...
    john@raspberrypi:~ $ iobroker update alexa2 --host raspberrypi --debug
    Used repository: alexa2
    Error: unknown repository is active - "alexa2". Known: stable, beta
    aktiv ist repository
    http://download.iobroker.net/sources-dist.json
    MFG Schweizer
    @schweiz
    Das wird auch per
    iob upgrade
    gemacht
    S 2 Antworten Letzte Antwort
      @schweiz
      Das wird auch per
      iob upgrade
      gemacht
      Schweiz
      @thomas-braun sagte in Jarvis Adapter lässt sich nicht Installieren:
      iob upgrade
      john@raspberrypi:~ $ iob upgrade alexa2 --host raspberrypi --debug
      This upgrade of "alexa2" will introduce the following changes:
      -> 3.26.4:
      Removed Weblink
      Adjust History query to recent Amazon changes
      Would you like to upgrade alexa2 from @3.26.3 to @3.26.4 now? [(y)es, (n)o]: y
      Update alexa2 from @3.26.3 to @3.26.4
      NPM version: 10.2.3
      Installing iobroker.alexa2@3.26.4... (System call)
      npm ERR! code ETARGET
      npm ERR! notarget No matching version found for iobroker.alexa2@3.26.4.
      npm ERR! notarget In most cases you or one of your dependencies are requesting
      npm ERR! notarget a package version that doesn't exist.
      npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2        024-01-27T19_08_48_318Z-debug-0.log
      host.raspberrypi Cannot install iobroker.alexa2@3.26.4: 1
      MFG Schweizer
        @schweiz
        Das wird auch per
        iob upgrade
        gemacht
        Schweiz
        iob upgrade
        -> 3.26.4:
        Removed Weblink
        NPM version: 10.2.3
        MFG Schweizer
        • S Schweiz
          iob upgrade
          -> 3.26.4:
          Removed Weblink
          NPM version: 10.2.3
          MFG Schweizer
          @schweiz
          iob repo list
            Schweiz
            john@raspberrypi:~ $ iob repo list
            Active repo(s): stable
            MFG Schweizer
            • S Schweiz
              iob upgrade
              -> 3.26.4:
              Removed Weblink
              NPM version: 10.2.3
              MFG Schweizer
              @schweiz sagte in Jarvis Adapter lässt sich nicht Installieren:
              bei notarget existiert das npm repo nicht.
              ist denn 3.26.4 auf npm?
                Schweiz
                john@raspberrypi:~ $ npm vers
                  npm: '10.2.3',
                  node: '18.19.0',
                  acorn: '8.10.0',
                  ada: '2.7.2',
                  ares: '1.20.1',
                  base64: '0.5.0',
                  brotli: '1.0.9',
                  cjs_module_lexer: '1.2.2',
                  cldr: '43.1',
                  icu: '73.2',
                  llhttp: '6.0.11',
                  modules: '108',
                  napi: '9',
                  nghttp2: '1.57.0',
                  nghttp3: '0.7.0',
                  ngtcp2: '0.8.1',
                  openssl: '3.0.12+quic',
                  simdutf: '3.2.18',
                  tz: '2023c',
                  undici: '5.26.4',
                  unicode: '15.0',
                  uv: '1.44.2',
                  uvwasi: '0.0.19',
                  v8: '10.2.154.26-node.28',
                  zlib: '1.2.13.1-motley'
                MFG Schweizer
                • S Schweiz
                    npm: '10.2.3',
                    node: '18.19.0',
                    acorn: '8.10.0',
                    ada: '2.7.2',
                    ares: '1.20.1',
                    base64: '0.5.0',
                    brotli: '1.0.9',
                    cldr: '43.1',
                    icu: '73.2',
                    llhttp: '6.0.11',
                    modules: '108',
                    napi: '9',
                    nghttp2: '1.57.0',
                    nghttp3: '0.7.0',
                    ngtcp2: '0.8.1',
                    simdutf: '3.2.18',
                    tz: '2023c',
                    undici: '5.26.4',
                    unicode: '15.0',
                    uv: '1.44.2',
                    uvwasi: '0.0.19',
                  MFG Schweizer
                  @schweiz nein, hier
                  https://www.npmjs.com/package/iobroker.alexa2?activeTab=versions
                  oder kommst du da mit deinem iobroker schon wieder nicht drauf
                    @schweiz nein, hier
                    Schweiz
                    Current Tags
                        Version
                        Downloads (Last 7 Days)
                            Tag
                        3.26.4
                        797
                            latest
                    steht dort, ja...
                    MFG Schweizer
                    • S Schweiz
                      Current Tags
                          Version
                              Tag
                          3.26.4
                          797
                              latest
                      steht dort, ja...
                      MFG Schweizer
                      steht dort, ja...
                      eben deswegen die Zusatzfrage
                        steht dort, ja...
                        Schweiz
                        ich denke er würde ja auch nicht
                        anzeigen wenn ich keinen zugriff hätte bzw, kein zugang zum internet hätte...
                        wie gesagt, ich habe ja bereits einige an Adapter installiert und nun geht nix mehr, kein Update und kein neuer Adapter...
                        MFG Schweizer
                        • S Schweiz
                          MFG Schweizer
                          warum?
                          die Liste hat der admin ein andermal runtergeladen. nach der geht er vor.
                          jetzt will er die Daten runterziehen.
                          Sie dir das doch mal näher an, mit
                          iob upgrade alexa2@3.26.4 --debug
                            warum?
                            Schweiz
                            john@raspberrypi:~ $ iob upgrade alexa2@3.26.4 --debug
                            -> 3.26.4:
                            Removed Weblink
                            NPM version: 10.2.3
                            npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-01-27T20_06_49_104Z-debug-0.log
                            MFG Schweizer
                            • S Schweiz
                              -> 3.26.4:
                              Removed Weblink
                              NPM version: 10.2.3
                              MFG Schweizer
                              GlasfaserG Offline
                              GlasfaserG Offline
                              Zeige mal die Ausgabe von :
                              curl -L -o diag.sh https://iobroker.net/diag.sh
                                zeigen
                                  zeigen
                                  Schweiz
                                  john@raspberrypi:~ $ curl -L -o diag.sh https://iobroker.net/diag.sh
                                    % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
        Dload  Upload   Total   Spent    Left  Speed
                                  100   185  100   185    0     0    693      0 --:--:-- --:--:-- --:--:--   692
                                  100 18519  100 18519    0     0  25049      0 --:--:-- --:--:-- --:--:-- 25049
                                  john@raspberrypi:~ $ nano /home/iobroker/.npm/_logs/2024-01-27T20_06_49_104Z-deb        ug-0.log
                                    GNU nano 7.2                                                        /home/iobroker/.npm/_logs/2024-01-27T20_06_49_104Z-debug-0.log
                                  0 verbose cli /usr/bin/node /usr/bin/npm
                                  1 info using npm@10.2.3
                                  2 info using node@v18.19.0
                                  3 timing npm:load:whichnode Completed in 4ms
                                  4 timing config:load:defaults Completed in 6ms
                                  5 timing config:load:file:/usr/lib/node_modules/npm/npmrc Completed in 3ms
                                  6 timing config:load:builtin Completed in 4ms
                                  7 timing config:load:cli Completed in 12ms
                                  8 timing config:load:env Completed in 1ms
                                  9 timing config:load:file:/opt/iobroker/.npmrc Completed in 5ms
                                  10 timing config:load:project Completed in 18ms
                                  11 timing config:load:file:/home/iobroker/.npmrc Completed in 0ms
                                  12 timing config:load:user Completed in 1ms
                                  13 timing config:load:file:/usr/etc/npmrc Completed in 0ms
                                  14 timing config:load:global Completed in 1ms
                                  15 timing config:load:setEnvs Completed in 3ms
                                  16 timing config:load Completed in 49ms
                                  17 timing npm:load:configload Completed in 50ms
                                  18 timing config:load:flatten Completed in 9ms
                                  19 timing npm:load:mkdirpcache Completed in 1ms
                                  20 timing npm:load:mkdirplogs Completed in 0ms
                                  21 verbose title npm install iobroker.alexa2@3.26.4
                                  22 verbose argv "install" "--save-exact" "iobroker.alexa2@3.26.4"
                                  23 timing npm:load:setTitle Completed in 4ms
                                  24 timing npm:load:display Completed in 2ms
                                  25 verbose logfile logs-max:10 dir:/home/iobroker/.npm/_logs/2024-01-27T20_06_49_104Z-
                                  26 verbose logfile /home/iobroker/.npm/_logs/2024-01-27T20_06_49_104Z-debug-0.log
                                  27 timing npm:load:logFile Completed in 29ms
                                  28 timing npm:load:timers Completed in 0ms
                                  29 timing npm:load:configScope Completed in 1ms
                                  30 timing npm:load Completed in 146ms
                                  31 timing arborist:ctor Completed in 3ms
                                  32 silly logfile start cleaning logs, removing 2 files
                                  33 silly logfile done cleaning log files
                                  34 timing idealTree:init Completed in 2412ms
                                  35 timing idealTree:userRequests Completed in 5ms
                                  36 silly idealTree buildDeps
                                  37 silly fetch manifest iobroker.alexa2@3.26.4
                                  38 verbose shrinkwrap failed to load node_modules/.package-lock.json out of date, updated: node_modules/iobroker.alexa2
                                  39 http fetch GET 200 https://registry.npmjs.org/iobroker.alexa2 460149ms (cache stale)
                                  40 silly placeDep ROOT iobroker.alexa2@ REPLACE for: iobroker.inst@3.0.0 want: 3.26.4
                                  41 timing idealTree:#root Completed in 460211ms
                                  42 timing idealTree:node_modules/iobroker.alexa2 Completed in 1ms
                                  43 timing idealTree:buildDeps Completed in 460215ms
                                  44 timing idealTree:fixDepFlags Completed in 85ms
                                  45 timing idealTree Completed in 462721ms
                                  46 timing command:install Completed in 462749ms
                                  47 verbose type version
                                  MFG Schweizer
                                  • S Schweiz
                                    MFG Schweizer
                                    GlasfaserG Offline
                                    GlasfaserG Offline
                                    iob stop
                                    rm /opt/iobroker/package*
                                    sudo reboot
                                    • GlasfaserG Glasfaser
                                      iob stop
                                      sudo reboot
                                      Schweiz
                                      @glasfaser
                                      -> 3.26.4:
                                      Removed Weblink
                                      NPM version: 10.2.3
                                      npm WARN deprecated querystring@0.2.1: The querystring API is considered Legacy. new code should use the URLSearchParams API instead.
                                      removed 746 packages, and changed 20 packages in 29s
                                      15 packages are looking for funding
                                        run `npm fund` for details
                                      Could not install iobroker.alexa2@3.26.4: Could not determine controller directory
                                      Cannot upgrade: Could not determine controller directory
                                      MFG Schweizer
                                      GlasfaserG S 2 Antworten Letzte Antwort
                                      • S Schweiz
                                        @glasfaser
                                        -> 3.26.4:
                                        Removed Weblink
                                        NPM version: 10.2.3
                                        MFG Schweizer
                                        GlasfaserG Offline
                                        GlasfaserG Offline
                                        @schweiz
                                        Zeige mal
                                        iob diag
                                        aber die Full Ausgabe
                                        • S Schweiz
                                          @glasfaser
                                          -> 3.26.4:
                                          Removed Weblink
                                          NPM version: 10.2.3
                                          MFG Schweizer
                                          Schweiz
                                          und es lässt sich weder iobroker noch homematic starten ;(
                                          MFG Schweizer
