  4. Router gewechselt, kein Zugriff auf Weboberfläche mehr
94 Beiträge 10 Kommentatoren 6.5k Aufrufe 8 Beobachtet
  • fiedlesF fiedles
    Skript v.2023-10-10
    *** BASE SYSTEM ***
       Static hostname: iobroker
             Icon name: computer
      Operating System: Raspbian GNU/Linux 10 (buster)
                Kernel: Linux 5.10.103-v7l+
          Architecture: arm
    Model           : Raspberry Pi 4 Model B Rev 1.4
    Docker          : false
    Virtualization  : none
    Kernel          : armv7l
    Userland        : armhf
    Systemuptime and Load:
     20:17:50 up 19:48,  1 user,  load average: 1.32, 1.07, 0.93
    CPU threads: 4
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    ~ Under-voltage has occurred
    ~ Arm frequency capping has occurred
    *** Time and Time Zones ***
                   Local time: Mon 2024-01-22 20:17:50 CET
               Universal time: Mon 2024-01-22 19:17:50 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:           7.9G        1.7G        5.4G        8.0M        887M        6.0G
    Swap:           99M          0B         99M
    Total:         8.0G        1.7G        5.5G
             7898 M total memory
             1654 M used memory
              533 M active memory
             1788 M inactive memory
             5356 M free memory
              241 M buffer memory
              646 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    Raspberry only:
    oom events: 0
    *** FAILED SERVICES ***
    0 loaded units listed. Pass --all to see loaded but inactive units, too.
    To show all installed unit files use 'systemctl list-unit-files'.
    *** FILESYSTEM ***
    /dev/root      ext4      117G   13G  100G  12% /
    devtmpfs       devtmpfs  3.7G     0  3.7G   0% /dev
    tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
    tmpfs          tmpfs     3.9G  8.5M  3.9G   1% /run
    tmpfs          tmpfs     3.9G     0  3.9G   0% /sys/fs/cgroup
    /dev/mmcblk0p1 vfat      253M   50M  203M  20% /boot
    tmpfs          tmpfs     790M     0  790M   0% /run/user/1000
    [Mon Jan 22 00:28:53 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:F9:AF:43 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=c5b1c200-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
    [Mon Jan 22 00:28:54 2024] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
    [Mon Jan 22 00:28:54 2024] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
    [Mon Jan 22 00:28:55 2024] EXT4-fs (mmcblk0p2): recovery complete
    [Mon Jan 22 00:28:55 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
    [Mon Jan 22 00:28:55 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
    [Mon Jan 22 00:28:57 2024] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
    TARGET        SOURCE         FSTYPE OPTIONS
    /             /dev/mmcblk0p2 ext4   rw,noatime
    |-/sys/fs/bpf none           bpf    rw,nosuid,nodev,noexec,relatime,mode=700
    `-/boot       /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    347M    /var/
    151M    /var/cache
    145M    /var/cache/apt
    93M     /var/lib
    86M     /var/cache/apt/archives
    Archived and active journals take up 8.0M in the file system.
    /opt/iobroker/backups:
    5.5G    /opt/iobroker/backups/
    4.0K    /opt/iobroker/backups/redistmp
    /opt/iobroker/iobroker-data:
    707M    /opt/iobroker/iobroker-data/
    552M    /opt/iobroker/iobroker-data/files
    116M    /opt/iobroker/iobroker-data/backup-objects
    89M     /opt/iobroker/iobroker-data/files/echarts.admin
    57M     /opt/iobroker/iobroker-data/files/javascript.admin
    36M     /opt/iobroker/iobroker-data/files/telegram-menu.admin/build/index.js.map
    35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
    33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
    24M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.2b7495c2.js.map
    24M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.2b7495c2.js.map
    USB-Devices by-id:
    find: '/dev/serial/by-id/': No such file or directory
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.19.0
    /usr/bin/node           v18.19.0
    /usr/bin/npm            10.2.3
    /usr/bin/npx            10.2.3
    /usr/bin/corepack       0.22.0
    nodejs:
      Installed: 18.19.0-1nodesource1
      Candidate: 18.19.0-1nodesource1
      Version table:
     *** 18.19.0-1nodesource1 1001
            500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
         18.18.2-1nodesource1 1001
         18.18.1-1nodesource1 1001
         18.18.0-1nodesource1 1001
         18.17.1-1nodesource1 1001
         18.17.0-1nodesource1 1001
         18.16.1-1nodesource1 1001
         18.16.0-1nodesource1 1001
         18.15.0-1nodesource1 1001
         18.14.2-1nodesource1 1001
         18.14.1-1nodesource1 1001
         18.14.0-1nodesource1 1001
         18.13.0-1nodesource1 1001
         18.12.0-1nodesource1 1001
         18.11.0-1nodesource1 1001
         18.10.0-1nodesource1 1001
         18.9.1-1nodesource1 1001
         18.9.0-1nodesource1 1001
         18.8.0-1nodesource1 1001
         18.7.0-1nodesource1 1001
         18.6.0-1nodesource1 1001
         18.5.0-1nodesource1 1001
         18.4.0-1nodesource1 1001
         18.3.0-1nodesource1 1001
         18.2.0-1nodesource1 1001
         18.1.0-1nodesource1 1001
         18.0.0-1nodesource1 1001
         10.24.0~dfsg-1~deb10u3 500
    No problems detected
    Errors in npm tree:
    npm ERR! code ELSPROBLEMS
    npm ERR! missing: homebridge-fibaro-hc2@^2.4.3, required by iobroker.ham@5.3.1
    npm ERR! missing: homebridge@^1.5.0, required by iobroker.ham@5.3.1
    npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2024-01-22T19_17_59_433Z-debug-0.log
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  5.0.17
    admin:          6.13.15
    javascript:     7.7.0
    Adapters from github:   0
    Adapter State
    + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 192.168.178.28, run as: admin
    + system.adapter.alarm.0                  : alarm                 : iobroker                                 -  enabled
    + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
      system.adapter.backitup.0               : backitup              : iobroker                                 - disabled
    + system.adapter.broadlink2.0             : broadlink2            : iobroker                                 -  enabled
    + system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
      system.adapter.devices.0                : devices               : iobroker                                 -  enabled
    + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
    + system.adapter.echarts.0                : echarts               : iobroker                                 -  enabled
      system.adapter.feiertage.0              : feiertage             : iobroker                                 -  enabled
    + system.adapter.fritzdect.0              : fritzdect             : iobroker                                 -  enabled
    + system.adapter.geofency.0               : geofency              : iobroker                                 -  enabled, port: 7999, bind: 0.0.0.0
    + system.adapter.ham.0                    : ham                   : iobroker                                 -  enabled
    + system.adapter.history.0                : history               : iobroker                                 -  enabled
    + system.adapter.hue.0                    : hue                   : iobroker                                 -  enabled, port: 443
    + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
    + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
    + system.adapter.iqontrol.0               : iqontrol              : iobroker                                 -  enabled
    + system.adapter.jarvis.0                 : jarvis                : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
    + system.adapter.net-tools.0              : net-tools             : iobroker                                 -  enabled
    + system.adapter.netatmo.0                : netatmo               : iobroker                                 -  enabled
    + system.adapter.onvif.0                  : onvif                 : iobroker                                 -  enabled
    + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
    + system.adapter.pushover.0               : pushover              : iobroker                                 -  enabled
    + system.adapter.roborock.0               : roborock              : iobroker                                 -  enabled
    + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
    + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1885, bind: 0.0.0.0
    + system.adapter.sony-bravia.0            : sony-bravia           : iobroker                                 -  enabled
    + system.adapter.synology.0               : synology              : iobroker                                 -  enabled, port: 5000
    + system.adapter.systeminfo.0             : systeminfo            : iobroker                                 -  enabled
    + system.adapter.tado.0                   : tado                  : iobroker                                 -  enabled
    + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.text2command.0           : text2command          : iobroker                                 -  enabled
      system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
      system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobroker                                 -  enabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 -  enabled
      system.adapter.vis-lcars.0              : vis-lcars             : iobroker                                 -  enabled
      system.adapter.vis-metro.0              : vis-metro             : iobroker                                 -  enabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 -  enabled
      system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
      system.adapter.yahka.0                  : yahka                 : iobroker                                 - disabled
      system.adapter.zigbee.0                 : zigbee                : iobroker                                 - disabled
    + instance is alive
    ioBroker-Repositories
    Active repo(s): beta
    Installed ioBroker-Instances
    Used repository: beta
    Adapter    "admin"        : 6.13.15  , installed 6.13.15
    Adapter    "alarm"        : 3.6.0    , installed 3.6.0
    Adapter    "alexa2"       : 3.26.3   , installed 3.26.3
    Adapter    "backitup"     : 2.10.5   , installed 2.10.5
    Adapter    "broadlink2"   : 2.1.5    , installed 2.1.5
    Adapter    "cloud"        : 4.4.1    , installed 4.4.1
    Adapter    "devices"      : 1.1.5    , installed 1.1.5
    Adapter    "discovery"    : 4.2.0    , installed 4.2.0
    Adapter    "echarts"      : 1.7.2    , installed 1.7.2
    Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
    Adapter    "fritzdect"    : 2.5.9    , installed 2.5.9
    Adapter    "geofency"     : 1.2.4    , installed 1.2.4
    Adapter    "ham"          : 5.3.1    , installed 5.3.1
    Adapter    "hue"          : 3.10.2   , installed 3.10.2
    Adapter    "info"         : 2.0.0    , installed 2.0.0
    Adapter    "iot"          : 2.0.11   , installed 2.0.11
    Adapter    "iqontrol"     : 2.3.0    , installed 2.3.0
    Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
    Adapter    "javascript"   : 7.7.0    , installed 7.7.0
    Controller "js-controller": 5.0.17   , installed 5.0.17
    Adapter    "net-tools"    : 1.0.3    , installed 1.0.3
    Adapter    "netatmo"      : 3.1.0    , installed 3.1.0
    Adapter    "onvif"        : 1.1.2    , installed 1.1.2
    Adapter    "pushover"     : 3.0.6    , installed 3.0.6
    Adapter    "roborock"     : 0.4.4    , installed 0.4.4
    Adapter    "socketio"     : 6.6.0    , installed 6.6.0
    Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
    Adapter    "sony-bravia"  : 1.0.9    , installed 1.0.9
    Adapter    "speedport"    : 0.0.3    , installed 0.0.3
    Adapter    "synology"     : 3.0.1    , installed 3.0.1
    Adapter    "systeminfo"   : 1.1.0    , installed 1.1.0
    Adapter    "tado"         : 0.5.1    , installed 0.5.1
    Adapter    "telegram"     : 3.0.1    , installed 3.0.1
    Adapter    "telegram-menu": 1.6.2    , installed 1.6.2
    Adapter    "text2command" : 3.0.3    , installed 3.0.3
    Adapter    "vis"          : 1.5.4    , installed 1.5.4
    Adapter    "vis-lcars"    : 1.1.1    , installed 1.1.1
    Adapter    "web"          : 6.2.3    , installed 6.2.3
    Adapter    "ws"           : 2.5.10   , installed 2.5.10
    Adapter    "yahka"        : 1.0.3    , installed 1.0.3
    Adapter    "zigbee"       : 1.10.1   , installed 1.10.1
    Objects and States
    Objects:        9671
    States:         7613
    Hit:1 http://archive.raspberrypi.org/debian buster InRelease
    Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
    Hit:3 https://deb.nodesource.com/node_18.x nodistro InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1001       47151      5047/io.jarvis.0
    tcp        0      0 192.168.178.28:8081     0.0.0.0:*               LISTEN      1001       38575      4099/io.admin.0
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          17293      635/sshd
    tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1001       41311      4288/io.sonoff.0
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       40312      4081/iobroker.js-co
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       40305      4081/iobroker.js-co
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       45338      4697/io.web.0
    tcp6       0      0 :::22                   :::*                    LISTEN      0          17295      635/sshd
    tcp6       0      0 :::8087                 :::*                    LISTEN      1001       45176      4641/io.simple-api.
    tcp6       0      0 :::39319                :::*                    LISTEN      1001       38762      4261/io.ham.0
    tcp6       0      0 :::7999                 :::*                    LISTEN      1001       38666      4200/io.geofency.0
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          15973      627/dhcpcd
    udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1001       45685      4869/io.broadlink2.
    udp        0      0 0.0.0.0:34980           0.0.0.0:*                           108        16898      405/avahi-daemon: r
    udp        0      0 0.0.0.0:52438           0.0.0.0:*                           1001       45768      4869/io.broadlink2.
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       38763      4261/io.ham.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        16896      405/avahi-daemon: r
    udp6       0      0 :::546                  :::*                                0          14830      627/dhcpcd
    udp6       0      0 :::51405                :::*                                108        16899      405/avahi-daemon: r
    udp6       0      0 :::5353                 :::*                                108        16897      405/avahi-daemon: r
    2024-01-22 20:17:26.135  - error: tr-064.0 (16095) ~
    2024-01-22 20:17:26.137  - warn: tr-064.0 (16095) Terminated (JS_CONTROLLER_STOPPED): Fatal error. Can not connect to your FritzBox.
    2024-01-22 20:17:26.796  - error: host.iobroker instance system.adapter.tr-064.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    2024-01-22 20:17:26.797  - info: host.iobroker Restart adapter system.adapter.tr-064.0 because enabled
    2024-01-22 20:17:56.934  - info: host.iobroker instance system.adapter.tr-064.0 started with pid 16300
    2024-01-22 20:18:00.803  - info: tr-064.0 (16300) starting. Version 4.2.18 in /opt/iobroker/node_modules/iobroker.tr-064, node: v18.19.0, js-controller: 5.0.17
    2024-01-22 20:18:01.139  - error: tr-064.0 (16300) Error: getaddrinfo ENOTFOUND http - {"errno":-3008,"code":"ENOTFOUND","syscall":"getaddrinfo","hostname":"http"}
    2024-01-22 20:18:01.140  - error: tr-064.0 (16300) ~
    2024-01-22 20:18:01.141  - error: tr-064.0 (16300) ~~ Fatal error. Can not connect to your FritzBox.
    2024-01-22 20:18:01.142  - error: tr-064.0 (16300) ~~ If configuration, network, IP address, etc. ok, try to restart your FritzBox
    2024-01-22 20:18:01.143  - error: tr-064.0 (16300) ~
    2024-01-22 20:18:01.145  - warn: tr-064.0 (16300) Terminated (JS_CONTROLLER_STOPPED): Fatal error. Can not connect to your FritzBox.
    2024-01-22 20:18:01.812  - error: host.iobroker instance system.adapter.tr-064.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    2024-01-22 20:18:01.813  - info: host.iobroker Restart adapter system.adapter.tr-064.0 because enabled
    2024-01-22 20:18:31.936  - info: host.iobroker instance system.adapter.tr-064.0 started with pid 16451
    2024-01-22 20:18:35.612  - info: tr-064.0 (16451) starting. Version 4.2.18 in /opt/iobroker/node_modules/iobroker.tr-064, node: v18.19.0, js-controller: 5.0.17
    2024-01-22 20:18:35.943  - error: tr-064.0 (16451) Error: getaddrinfo ENOTFOUND http - {"errno":-3008,"code":"ENOTFOUND","syscall":"getaddrinfo","hostname":"http"}
    2024-01-22 20:18:35.944  - error: tr-064.0 (16451) ~
    2024-01-22 20:18:35.945  - error: tr-064.0 (16451) ~~ Fatal error. Can not connect to your FritzBox.
    2024-01-22 20:18:35.946  - error: tr-064.0 (16451) ~~ If configuration, network, IP address, etc. ok, try to restart your FritzBox
    2024-01-22 20:18:35.947  - error: tr-064.0 (16451) ~
    2024-01-22 20:18:35.949  - warn: tr-064.0 (16451) Terminated (JS_CONTROLLER_STOPPED): Fatal error. Can not connect to your FritzBox.
    2024-01-22 20:18:36.586  - error: host.iobroker instance system.adapter.tr-064.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    2024-01-22 20:18:36.586  - info: host.iobroker Restart adapter system.adapter.tr-064.0 because enabled
    2024-01-22 20:19:06.786  - info: host.iobroker instance system.adapter.tr-064.0 started with pid 16847
    GlasfaserG Offline
    GlasfaserG Offline
    @sebastian-fiedler sagte in Router gewechselt, kein Zugriff auf Weboberfläche mehr:
    ... der auch Redis sichert ... dein Tool ... obwohl du es nicht hast !?
      über ein Tool aus dem Netz
      bitte nicht das, was ich befürchte!
      fiedlesF Offline
      fiedlesF Offline
      fiedles
      @homoran wahrscheinlich genau das was du befürchtest, wenn du schon so schreibst... elzershark 💩 bitte nicht lünchen 🙏 🤐
      • fiedlesF fiedles
        GlasfaserG Offline
        GlasfaserG Offline
        @sebastian-fiedler
        Jipp ... wo sind die Ste...
        • fiedlesF fiedles
          GlasfaserG Offline
          GlasfaserG Offline
          @sebastian-fiedler
          Und was hast du da drin .. im 5.5G Ordner
          zeige :
          ls -lh /opt/iobroker/backups
          • GlasfaserG Glasfaser
            @sebastian-fiedler
            @glasfaser sagte in Router gewechselt, kein Zugriff auf Weboberfläche mehr:
            @sebastian-fiedler
            sie war's, ähm er, er!
            @Sebastian-Fiedler
            ja! wenn die Elsterforelle da nicht mittlerweile massiv nachgebessert hat, verbiegt dir das "Tool" dein gesamtes System.
            Da wundern mich deine Baustellen kein bischen.
              @sebastian-fiedler
              @Sebastian-Fiedler
              GlasfaserG Offline
              GlasfaserG Offline
              @homoran sagte in Router gewechselt, kein Zugriff auf Weboberfläche mehr:
              Hi ... dein Edit mit
              ähm er, er!
              fiedlesF 1 Antwort Letzte Antwort
                ähm er, er!
                fiedlesF Offline
                fiedlesF Offline
                fiedles
                permitted by applicable law.
                Last login: Mon Jan 22 20:17:15 2024 from 192.168.178.35
                pi@iobroker:~ $ ls -lh /opt/iobroker/backups
                total 5.5G
                -rw-rwxr--+ 1 iobroker iobroker 2.1M Dec  1  2021 2021_12_01-11_50_18_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker 2.1M Jan 11  2022 2022_01_11-17_59_15_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker 4.9M Oct  5  2022 2022_10_05-15_39_16_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker 4.9M Oct  5  2022 2022_10_05-15_58_52_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  12M Nov 23  2022 2022_11_23-16_43_45_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker 2.3M Mar  7  2022 iobroker_2022_03_07-02_40_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker 2.3M Mar  8  2022 iobroker_2022_03_08-02_40_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker 2.3M Mar  9  2022 iobroker_2022_03_09-02_40_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker 2.4M Mar 10  2022 iobroker_2022_03_10-02_40_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker 2.4M Mar 11  2022 iobroker_2022_03_11-02_40_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker 2.4M Mar 12  2022 iobroker_2022_03_12-02_40_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker 2.4M Mar 13  2022 iobroker_2022_03_13-02_40_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker 2.4M Mar 14  2022 iobroker_2022_03_14-02_40_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker 2.4M Mar 15  2022 iobroker_2022_03_15-02_40_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker 2.4M Mar 16  2022 iobroker_2022_03_16-02_40_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker 2.5M Jul 22  2022 iobroker_2022_07_22-12_01_57_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker 4.7M Jul 23  2022 iobroker_2022_07_23-02_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker 4.7M Jul 25  2022 iobroker_2022_07_25-02_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker 4.7M Jul 27  2022 iobroker_2022_07_27-02_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker 4.7M Jul 29  2022 iobroker_2022_07_29-02_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker 4.7M Jul 31  2022 iobroker_2022_07_31-02_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker 4.7M Aug  1  2022 iobroker_2022_08_01-02_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker 4.7M Aug  3  2022 iobroker_2022_08_03-02_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker 4.7M Aug  5  2022 iobroker_2022_08_05-02_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker 4.7M Aug  7  2022 iobroker_2022_08_07-02_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker 4.7M Aug  9  2022 iobroker_2022_08_09-02_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker 4.7M Aug 11  2022 iobroker_2022_08_11-02_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker 4.7M Aug 13  2022 iobroker_2022_08_13-02_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker 4.7M Aug 15  2022 iobroker_2022_08_15-02_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker 4.7M Aug 17  2022 iobroker_2022_08_17-02_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker 4.7M Aug 19  2022 iobroker_2022_08_19-02_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker 4.7M Aug 21  2022 iobroker_2022_08_21-02_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker 4.7M Aug 23  2022 iobroker_2022_08_23-02_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker 4.7M Aug 25  2022 iobroker_2022_08_25-02_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker 4.7M Aug 27  2022 iobroker_2022_08_27-02_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker 4.7M Aug 29  2022 iobroker_2022_08_29-02_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker 4.8M Aug 31  2022 iobroker_2022_08_31-02_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker 4.8M Sep  1  2022 iobroker_2022_09_01-02_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker 4.8M Sep  3  2022 iobroker_2022_09_03-02_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker 4.8M Sep  5  2022 iobroker_2022_09_05-02_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker 4.8M Sep  7  2022 iobroker_2022_09_07-02_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker 4.8M Sep  9  2022 iobroker_2022_09_09-02_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker 4.7M Sep 11  2022 iobroker_2022_09_11-02_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker 4.8M Sep 13  2022 iobroker_2022_09_13-02_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker 4.8M Sep 15  2022 iobroker_2022_09_15-02_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker 4.8M Sep 17  2022 iobroker_2022_09_17-02_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker 4.8M Sep 19  2022 iobroker_2022_09_19-02_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker 4.8M Sep 20  2022 iobroker_2022_09_20-12_09_06_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker 4.8M Sep 20  2022 iobroker_2022_09_20-13_09_49_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker 4.8M Sep 21  2022 iobroker_2022_09_21-02_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker 4.8M Sep 21  2022 iobroker_2022_09_21-12_15_28_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker 4.8M Sep 21  2022 iobroker_2022_09_21-14_52_53_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker 4.8M Sep 22  2022 iobroker_2022_09_22-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker 4.9M Sep 23  2022 iobroker_2022_09_23-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker 4.9M Sep 24  2022 iobroker_2022_09_24-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker 4.9M Sep 25  2022 iobroker_2022_09_25-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker 4.9M Sep 26  2022 iobroker_2022_09_26-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker 4.9M Sep 27  2022 iobroker_2022_09_27-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker 4.9M Sep 28  2022 iobroker_2022_09_28-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker 4.9M Sep 29  2022 iobroker_2022_09_29-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker 4.9M Sep 30  2022 iobroker_2022_09_30-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker 4.9M Oct  1  2022 iobroker_2022_10_01-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker 4.9M Oct  2  2022 iobroker_2022_10_02-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker 4.9M Oct  3  2022 iobroker_2022_10_03-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker 4.9M Oct  4  2022 iobroker_2022_10_04-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker 4.9M Oct  5  2022 iobroker_2022_10_05-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker 4.9M Oct  5  2022 iobroker_2022_10_05-14_34_20_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker 4.9M Oct  6  2022 iobroker_2022_10_06-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker 4.9M Oct  7  2022 iobroker_2022_10_07-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker 4.9M Oct  8  2022 iobroker_2022_10_08-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker 4.9M Oct  9  2022 iobroker_2022_10_09-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker 4.9M Oct 10  2022 iobroker_2022_10_10-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker 4.9M Oct 11  2022 iobroker_2022_10_11-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker 4.9M Oct 12  2022 iobroker_2022_10_12-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker 4.9M Oct 13  2022 iobroker_2022_10_13-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker 4.9M Oct 14  2022 iobroker_2022_10_14-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker 4.9M Oct 15  2022 iobroker_2022_10_15-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker 4.9M Oct 16  2022 iobroker_2022_10_16-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker 4.9M Oct 17  2022 iobroker_2022_10_17-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker 4.9M Oct 18  2022 iobroker_2022_10_18-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker 4.9M Oct 19  2022 iobroker_2022_10_19-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker 4.9M Oct 20  2022 iobroker_2022_10_20-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker 4.9M Oct 21  2022 iobroker_2022_10_21-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker 4.9M Oct 22  2022 iobroker_2022_10_22-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker 4.9M Oct 23  2022 iobroker_2022_10_23-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker 4.9M Oct 24  2022 iobroker_2022_10_24-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker 4.9M Oct 25  2022 iobroker_2022_10_25-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker 4.9M Oct 26  2022 iobroker_2022_10_26-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker 4.9M Oct 27  2022 iobroker_2022_10_27-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker 4.9M Oct 28  2022 iobroker_2022_10_28-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker 4.9M Oct 29  2022 iobroker_2022_10_29-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker 4.9M Oct 30  2022 iobroker_2022_10_30-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker 4.9M Oct 31  2022 iobroker_2022_10_31-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker 4.9M Nov  1  2022 iobroker_2022_11_01-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker 4.9M Nov  2  2022 iobroker_2022_11_02-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker 5.0M Nov  3  2022 iobroker_2022_11_03-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker 5.0M Nov  4  2022 iobroker_2022_11_04-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker 7.2M Nov  5  2022 iobroker_2022_11_05-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker 7.2M Nov  6  2022 iobroker_2022_11_06-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  12M Nov  7  2022 iobroker_2022_11_07-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  12M Nov  8  2022 iobroker_2022_11_08-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  12M Nov  9  2022 iobroker_2022_11_09-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  12M Nov 10  2022 iobroker_2022_11_10-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  12M Nov 11  2022 iobroker_2022_11_11-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  12M Nov 12  2022 iobroker_2022_11_12-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  12M Nov 13  2022 iobroker_2022_11_13-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  12M Nov 14  2022 iobroker_2022_11_14-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  12M Nov 15  2022 iobroker_2022_11_15-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  12M Nov 16  2022 iobroker_2022_11_16-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  12M Nov 17  2022 iobroker_2022_11_17-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  12M Nov 18  2022 iobroker_2022_11_18-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  12M Nov 19  2022 iobroker_2022_11_19-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  12M Nov 20  2022 iobroker_2022_11_20-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  12M Nov 21  2022 iobroker_2022_11_21-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  12M Nov 22  2022 iobroker_2022_11_22-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  12M Nov 23  2022 iobroker_2022_11_23-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  12M Nov 24  2022 iobroker_2022_11_24-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  12M Nov 25  2022 iobroker_2022_11_25-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  12M Nov 26  2022 iobroker_2022_11_26-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  12M Nov 27  2022 iobroker_2022_11_27-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  12M Nov 28  2022 iobroker_2022_11_28-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  12M Nov 30  2022 iobroker_2022_11_30-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  12M Dec  1  2022 iobroker_2022_12_01-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  12M Dec  2  2022 iobroker_2022_12_02-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  12M Dec  3  2022 iobroker_2022_12_03-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  12M Dec  4  2022 iobroker_2022_12_04-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  12M Dec  5  2022 iobroker_2022_12_05-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  12M Dec  6  2022 iobroker_2022_12_06-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  12M Dec  7  2022 iobroker_2022_12_07-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  12M Dec  8  2022 iobroker_2022_12_08-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  12M Dec  9  2022 iobroker_2022_12_09-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  12M Dec 10  2022 iobroker_2022_12_10-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  12M Dec 11  2022 iobroker_2022_12_11-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  12M Dec 12  2022 iobroker_2022_12_12-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  12M Dec 13  2022 iobroker_2022_12_13-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  12M Dec 14  2022 iobroker_2022_12_14-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  12M Dec 15  2022 iobroker_2022_12_15-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  12M Dec 16  2022 iobroker_2022_12_16-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  12M Dec 17  2022 iobroker_2022_12_17-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  12M Dec 18  2022 iobroker_2022_12_18-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  12M Dec 19  2022 iobroker_2022_12_19-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  12M Dec 20  2022 iobroker_2022_12_20-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  12M Dec 21  2022 iobroker_2022_12_21-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  12M Dec 22  2022 iobroker_2022_12_22-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  12M Dec 23  2022 iobroker_2022_12_23-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  12M Dec 24  2022 iobroker_2022_12_24-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  12M Dec 25  2022 iobroker_2022_12_25-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  12M Dec 26  2022 iobroker_2022_12_26-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  12M Dec 27  2022 iobroker_2022_12_27-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  12M Dec 28  2022 iobroker_2022_12_28-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  12M Dec 29  2022 iobroker_2022_12_29-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  12M Dec 30  2022 iobroker_2022_12_30-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  12M Dec 31  2022 iobroker_2022_12_31-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  12M Jan  1  2023 iobroker_2023_01_01-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  12M Jan  2  2023 iobroker_2023_01_02-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  12M Jan  3  2023 iobroker_2023_01_03-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  13M Jan  4  2023 iobroker_2023_01_04-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  13M Jan  5  2023 iobroker_2023_01_05-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  13M Jan  6  2023 iobroker_2023_01_06-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  13M Jan  7  2023 iobroker_2023_01_07-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  13M Jan  8  2023 iobroker_2023_01_08-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  13M Jan  9  2023 iobroker_2023_01_09-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  13M Jan 10  2023 iobroker_2023_01_10-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  13M Jan 11  2023 iobroker_2023_01_11-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  13M Jan 12  2023 iobroker_2023_01_12-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  13M Jan 13  2023 iobroker_2023_01_13-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  13M Jan 14  2023 iobroker_2023_01_14-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  13M Jan 15  2023 iobroker_2023_01_15-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  13M Jan 16  2023 iobroker_2023_01_16-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  13M Jan 17  2023 iobroker_2023_01_17-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  13M Jan 18  2023 iobroker_2023_01_18-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  13M Jan 19  2023 iobroker_2023_01_19-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  13M Jan 20  2023 iobroker_2023_01_20-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  13M Jan 21  2023 iobroker_2023_01_21-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  13M Jan 22  2023 iobroker_2023_01_22-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  13M Jan 23  2023 iobroker_2023_01_23-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  13M Jan 24  2023 iobroker_2023_01_24-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  13M Jan 25  2023 iobroker_2023_01_25-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  13M Jan 26  2023 iobroker_2023_01_26-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  13M Jan 27  2023 iobroker_2023_01_27-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  13M Jan 28  2023 iobroker_2023_01_28-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  13M Jan 29  2023 iobroker_2023_01_29-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  13M Jan 30  2023 iobroker_2023_01_30-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  13M Jan 31  2023 iobroker_2023_01_31-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  13M Feb  1  2023 iobroker_2023_02_01-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  13M Feb  2  2023 iobroker_2023_02_02-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  13M Feb  3  2023 iobroker_2023_02_03-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  13M Feb  4  2023 iobroker_2023_02_04-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  13M Feb  5  2023 iobroker_2023_02_05-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  13M Feb  6  2023 iobroker_2023_02_06-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  13M Feb  7  2023 iobroker_2023_02_07-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  13M Feb  8  2023 iobroker_2023_02_08-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  13M Feb  9  2023 iobroker_2023_02_09-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  13M Feb 10  2023 iobroker_2023_02_10-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  13M Feb 11  2023 iobroker_2023_02_11-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  13M Feb 12  2023 iobroker_2023_02_12-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  13M Feb 13  2023 iobroker_2023_02_13-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  13M Feb 14  2023 iobroker_2023_02_14-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  13M Feb 15  2023 iobroker_2023_02_15-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  13M Feb 16  2023 iobroker_2023_02_16-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  13M Feb 17  2023 iobroker_2023_02_17-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  13M Feb 18  2023 iobroker_2023_02_18-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  13M Feb 19  2023 iobroker_2023_02_19-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  13M Feb 20  2023 iobroker_2023_02_20-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  13M Feb 21  2023 iobroker_2023_02_21-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  13M Feb 22  2023 iobroker_2023_02_22-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  13M Feb 23  2023 iobroker_2023_02_23-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  13M Feb 24  2023 iobroker_2023_02_24-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  13M Feb 25  2023 iobroker_2023_02_25-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  13M Feb 26  2023 iobroker_2023_02_26-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  13M Feb 27  2023 iobroker_2023_02_27-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  13M Feb 28  2023 iobroker_2023_02_28-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  13M Mar  1  2023 iobroker_2023_03_01-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  13M Mar  2  2023 iobroker_2023_03_02-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  13M Mar  3  2023 iobroker_2023_03_03-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  13M Mar  4  2023 iobroker_2023_03_04-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  13M Mar  5  2023 iobroker_2023_03_05-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  13M Mar  6  2023 iobroker_2023_03_06-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  13M Mar  7  2023 iobroker_2023_03_07-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  13M Mar  8  2023 iobroker_2023_03_08-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  13M Mar  9  2023 iobroker_2023_03_09-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  13M Mar 10  2023 iobroker_2023_03_10-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  13M Mar 11  2023 iobroker_2023_03_11-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  13M Mar 12  2023 iobroker_2023_03_12-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  13M Mar 13  2023 iobroker_2023_03_13-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  13M Mar 14  2023 iobroker_2023_03_14-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  13M Mar 15  2023 iobroker_2023_03_15-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  13M Mar 16  2023 iobroker_2023_03_16-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  13M Mar 17  2023 iobroker_2023_03_17-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  13M Mar 18  2023 iobroker_2023_03_18-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  13M Mar 19  2023 iobroker_2023_03_19-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  13M Mar 20  2023 iobroker_2023_03_20-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  13M Mar 21  2023 iobroker_2023_03_21-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  13M Mar 22  2023 iobroker_2023_03_22-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  13M Mar 23  2023 iobroker_2023_03_23-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  13M Mar 24  2023 iobroker_2023_03_24-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  13M Mar 25  2023 iobroker_2023_03_25-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  13M Mar 26  2023 iobroker_2023_03_26-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  13M Mar 27  2023 iobroker_2023_03_27-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  13M Mar 28  2023 iobroker_2023_03_28-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  13M Mar 29  2023 iobroker_2023_03_29-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  13M Mar 30  2023 iobroker_2023_03_30-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  13M Mar 31  2023 iobroker_2023_03_31-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  13M Apr  1  2023 iobroker_2023_04_01-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  13M Apr  2  2023 iobroker_2023_04_02-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  13M Apr  3  2023 iobroker_2023_04_03-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  13M Apr  4  2023 iobroker_2023_04_04-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  13M Apr  5  2023 iobroker_2023_04_05-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  13M Apr  6  2023 iobroker_2023_04_06-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  13M Apr  7  2023 iobroker_2023_04_07-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  13M Apr  8  2023 iobroker_2023_04_08-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  13M Apr  9  2023 iobroker_2023_04_09-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  13M Apr 10  2023 iobroker_2023_04_10-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  13M Apr 11  2023 iobroker_2023_04_11-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  13M Apr 12  2023 iobroker_2023_04_12-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  13M Apr 13  2023 iobroker_2023_04_13-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  15M Apr 14  2023 iobroker_2023_04_14-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  15M Apr 15  2023 iobroker_2023_04_15-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  15M Apr 16  2023 iobroker_2023_04_16-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  15M Apr 17  2023 iobroker_2023_04_17-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  15M Apr 18  2023 iobroker_2023_04_18-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  15M Apr 19  2023 iobroker_2023_04_19-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  15M Apr 20  2023 iobroker_2023_04_20-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  15M Apr 21  2023 iobroker_2023_04_21-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  15M Apr 22  2023 iobroker_2023_04_22-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  15M Apr 23  2023 iobroker_2023_04_23-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  15M Apr 24  2023 iobroker_2023_04_24-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  15M Apr 25  2023 iobroker_2023_04_25-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  15M Apr 26  2023 iobroker_2023_04_26-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  15M Apr 27  2023 iobroker_2023_04_27-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  15M Apr 28  2023 iobroker_2023_04_28-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  15M Apr 29  2023 iobroker_2023_04_29-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  15M Apr 30  2023 iobroker_2023_04_30-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  15M May  1  2023 iobroker_2023_05_01-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  15M May  2  2023 iobroker_2023_05_02-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  15M May  3  2023 iobroker_2023_05_03-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  15M May  4  2023 iobroker_2023_05_04-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  15M May  5  2023 iobroker_2023_05_05-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  15M May  6  2023 iobroker_2023_05_06-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  15M May  7  2023 iobroker_2023_05_07-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  15M May  8  2023 iobroker_2023_05_08-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  15M May  9  2023 iobroker_2023_05_09-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  15M May 10  2023 iobroker_2023_05_10-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  15M May 11  2023 iobroker_2023_05_11-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  15M May 12  2023 iobroker_2023_05_12-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  15M May 13  2023 iobroker_2023_05_13-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  15M May 14  2023 iobroker_2023_05_14-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  15M May 15  2023 iobroker_2023_05_15-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  15M May 16  2023 iobroker_2023_05_16-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  15M May 17  2023 iobroker_2023_05_17-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  15M May 18  2023 iobroker_2023_05_18-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  15M May 19  2023 iobroker_2023_05_19-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  15M May 20  2023 iobroker_2023_05_20-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  15M May 21  2023 iobroker_2023_05_21-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  15M May 22  2023 iobroker_2023_05_22-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  15M May 23  2023 iobroker_2023_05_23-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  15M May 24  2023 iobroker_2023_05_24-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  15M May 25  2023 iobroker_2023_05_25-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  15M May 26  2023 iobroker_2023_05_26-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  15M May 27  2023 iobroker_2023_05_27-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  15M May 28  2023 iobroker_2023_05_28-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  15M May 29  2023 iobroker_2023_05_29-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  15M May 30  2023 iobroker_2023_05_30-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  15M May 31  2023 iobroker_2023_05_31-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  15M Jun  1  2023 iobroker_2023_06_01-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  15M Jun  2  2023 iobroker_2023_06_02-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  15M Jun  3  2023 iobroker_2023_06_03-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  15M Jun  4  2023 iobroker_2023_06_04-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  15M Jun  5  2023 iobroker_2023_06_05-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  15M Jun  6  2023 iobroker_2023_06_06-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  15M Jun  7  2023 iobroker_2023_06_07-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  15M Jun  8  2023 iobroker_2023_06_08-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  15M Jun  9  2023 iobroker_2023_06_09-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  15M Jun 10  2023 iobroker_2023_06_10-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  15M Jun 11  2023 iobroker_2023_06_11-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  15M Jun 12  2023 iobroker_2023_06_12-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  15M Jun 13  2023 iobroker_2023_06_13-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  15M Jun 14  2023 iobroker_2023_06_14-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  15M Jun 15  2023 iobroker_2023_06_15-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  15M Jun 16  2023 iobroker_2023_06_16-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  15M Jun 17  2023 iobroker_2023_06_17-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  15M Jun 18  2023 iobroker_2023_06_18-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  15M Jun 19  2023 iobroker_2023_06_19-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  15M Jun 20  2023 iobroker_2023_06_20-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  15M Jun 21  2023 iobroker_2023_06_21-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  15M Jun 22  2023 iobroker_2023_06_22-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  15M Jun 23  2023 iobroker_2023_06_23-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  15M Jun 24  2023 iobroker_2023_06_24-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  15M Jun 25  2023 iobroker_2023_06_25-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  15M Jun 26  2023 iobroker_2023_06_26-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  15M Jun 27  2023 iobroker_2023_06_27-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  15M Jun 28  2023 iobroker_2023_06_28-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  15M Jun 29  2023 iobroker_2023_06_29-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  15M Jun 30  2023 iobroker_2023_06_30-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  15M Jul  1  2023 iobroker_2023_07_01-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  15M Jul  2  2023 iobroker_2023_07_02-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  15M Jul  3  2023 iobroker_2023_07_03-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  15M Jul  4  2023 iobroker_2023_07_04-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  15M Jul  5  2023 iobroker_2023_07_05-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  15M Jul  6  2023 iobroker_2023_07_06-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  15M Jul  7  2023 iobroker_2023_07_07-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  15M Jul  8  2023 iobroker_2023_07_08-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  15M Jul  9  2023 iobroker_2023_07_09-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  15M Jul 10  2023 iobroker_2023_07_10-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  15M Jul 11  2023 iobroker_2023_07_11-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  15M Jul 12  2023 iobroker_2023_07_12-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  15M Jul 13  2023 iobroker_2023_07_13-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  15M Jul 14  2023 iobroker_2023_07_14-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  15M Jul 15  2023 iobroker_2023_07_15-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  15M Jul 16  2023 iobroker_2023_07_16-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  15M Jul 17  2023 iobroker_2023_07_17-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  15M Jul 18  2023 iobroker_2023_07_18-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  15M Jul 19  2023 iobroker_2023_07_19-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  15M Jul 20  2023 iobroker_2023_07_20-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  15M Jul 21  2023 iobroker_2023_07_21-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  15M Jul 22  2023 iobroker_2023_07_22-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  15M Jul 23  2023 iobroker_2023_07_23-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  15M Jul 24  2023 iobroker_2023_07_24-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  15M Jul 25 03:30 iobroker_2023_07_25-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  15M Jul 26 03:30 iobroker_2023_07_26-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  16M Jul 27 03:30 iobroker_2023_07_27-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  16M Jul 28 03:30 iobroker_2023_07_28-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  16M Jul 29 03:30 iobroker_2023_07_29-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  16M Jul 30 03:30 iobroker_2023_07_30-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  16M Jul 31 03:30 iobroker_2023_07_31-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  16M Aug  1 03:30 iobroker_2023_08_01-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  16M Aug  2 03:30 iobroker_2023_08_02-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  16M Aug  3 03:30 iobroker_2023_08_03-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  16M Aug  4 03:30 iobroker_2023_08_04-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  16M Aug  5 03:30 iobroker_2023_08_05-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  16M Aug  6 03:30 iobroker_2023_08_06-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  16M Aug  7 03:30 iobroker_2023_08_07-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  16M Aug  8 03:30 iobroker_2023_08_08-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  16M Aug  9 03:30 iobroker_2023_08_09-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  16M Aug 10 03:30 iobroker_2023_08_10-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  16M Aug 11 03:30 iobroker_2023_08_11-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  16M Aug 12 03:30 iobroker_2023_08_12-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  16M Aug 13 03:30 iobroker_2023_08_13-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  16M Aug 14 03:30 iobroker_2023_08_14-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  16M Aug 15 03:30 iobroker_2023_08_15-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  16M Aug 16 03:30 iobroker_2023_08_16-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  16M Aug 17 03:30 iobroker_2023_08_17-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  16M Aug 18 03:30 iobroker_2023_08_18-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  16M Aug 19 03:30 iobroker_2023_08_19-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  16M Aug 20 03:30 iobroker_2023_08_20-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  16M Aug 21 03:30 iobroker_2023_08_21-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  16M Aug 22 03:30 iobroker_2023_08_22-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  16M Aug 23 03:30 iobroker_2023_08_23-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  16M Aug 24 03:30 iobroker_2023_08_24-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  16M Aug 25 03:30 iobroker_2023_08_25-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  16M Aug 26 03:30 iobroker_2023_08_26-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  16M Aug 27 03:30 iobroker_2023_08_27-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  16M Aug 28 03:30 iobroker_2023_08_28-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  16M Aug 29 03:30 iobroker_2023_08_29-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  16M Aug 30 03:30 iobroker_2023_08_30-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  16M Aug 31 03:30 iobroker_2023_08_31-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  16M Sep  1 03:30 iobroker_2023_09_01-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  16M Sep  2 03:30 iobroker_2023_09_02-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  16M Sep  3 03:30 iobroker_2023_09_03-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  16M Sep  4 03:30 iobroker_2023_09_04-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  15M Sep  5 03:30 iobroker_2023_09_05-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  16M Sep  6 03:30 iobroker_2023_09_06-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  16M Sep  7 03:30 iobroker_2023_09_07-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  16M Sep  8 03:30 iobroker_2023_09_08-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  16M Sep  9 03:30 iobroker_2023_09_09-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  16M Sep 10 03:30 iobroker_2023_09_10-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  16M Sep 11 03:30 iobroker_2023_09_11-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  16M Sep 12 03:30 iobroker_2023_09_12-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  16M Sep 13 03:30 iobroker_2023_09_13-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  16M Sep 14 03:30 iobroker_2023_09_14-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  16M Sep 15 03:30 iobroker_2023_09_15-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  16M Sep 16 03:30 iobroker_2023_09_16-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  16M Sep 17 03:30 iobroker_2023_09_17-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  16M Sep 18 03:30 iobroker_2023_09_18-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  16M Sep 19 03:30 iobroker_2023_09_19-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  16M Sep 20 03:30 iobroker_2023_09_20-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  16M Sep 21 03:30 iobroker_2023_09_21-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  16M Sep 22 03:30 iobroker_2023_09_22-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  16M Sep 23 03:30 iobroker_2023_09_23-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  16M Sep 24 03:30 iobroker_2023_09_24-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  16M Sep 25 03:30 iobroker_2023_09_25-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  16M Sep 26 03:30 iobroker_2023_09_26-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  16M Sep 27 03:30 iobroker_2023_09_27-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  16M Sep 28 03:30 iobroker_2023_09_28-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  16M Sep 29 03:30 iobroker_2023_09_29-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  16M Sep 30 03:30 iobroker_2023_09_30-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  16M Oct  1 03:30 iobroker_2023_10_01-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  16M Oct  2 03:30 iobroker_2023_10_02-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  16M Oct  3 03:30 iobroker_2023_10_03-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  16M Oct  3 19:19 iobroker_2023_10_03-19_19_30_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  16M Oct  3 19:40 iobroker_2023_10_03-19_40_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  16M Oct  4 03:30 iobroker_2023_10_04-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  16M Oct  5 03:30 iobroker_2023_10_05-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  16M Oct  6 03:30 iobroker_2023_10_06-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  16M Oct  7 03:30 iobroker_2023_10_07-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  16M Oct  8 03:30 iobroker_2023_10_08-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  16M Oct  9 03:30 iobroker_2023_10_09-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  16M Oct 10 03:30 iobroker_2023_10_10-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  16M Oct 11 03:30 iobroker_2023_10_11-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  16M Oct 12 03:30 iobroker_2023_10_12-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  16M Oct 13 03:30 iobroker_2023_10_13-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  16M Oct 14 03:30 iobroker_2023_10_14-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  16M Oct 15 03:30 iobroker_2023_10_15-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  16M Oct 16 03:30 iobroker_2023_10_16-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  16M Oct 17 03:30 iobroker_2023_10_17-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  16M Oct 18 03:30 iobroker_2023_10_18-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  16M Oct 19 03:30 iobroker_2023_10_19-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  16M Oct 20 03:30 iobroker_2023_10_20-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  16M Oct 21 03:30 iobroker_2023_10_21-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  16M Oct 22 03:30 iobroker_2023_10_22-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  16M Oct 23 03:30 iobroker_2023_10_23-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  16M Oct 24 03:30 iobroker_2023_10_24-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  16M Oct 25 03:30 iobroker_2023_10_25-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  16M Oct 26 03:30 iobroker_2023_10_26-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  16M Oct 27 03:30 iobroker_2023_10_27-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  16M Oct 28 03:30 iobroker_2023_10_28-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  16M Oct 29 03:30 iobroker_2023_10_29-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  16M Oct 30 03:30 iobroker_2023_10_30-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  16M Oct 31 03:30 iobroker_2023_10_31-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  16M Nov  1 03:30 iobroker_2023_11_01-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  16M Nov  2 03:30 iobroker_2023_11_02-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  16M Nov  3 03:30 iobroker_2023_11_03-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  16M Nov  4 03:30 iobroker_2023_11_04-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  16M Nov  5 03:30 iobroker_2023_11_05-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  16M Nov  6 03:30 iobroker_2023_11_06-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  16M Nov  7 03:30 iobroker_2023_11_07-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  16M Nov  8 03:30 iobroker_2023_11_08-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  13M Nov  9 03:30 iobroker_2023_11_09-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  13M Nov 10 03:30 iobroker_2023_11_10-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  13M Nov 11 03:30 iobroker_2023_11_11-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  13M Nov 12 03:30 iobroker_2023_11_12-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  13M Nov 13 03:30 iobroker_2023_11_13-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker  13M Nov 14 03:30 iobroker_2023_11_14-03_30_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker    0 Oct 14 03:30 mysql_2023_10_14-03_30_29_backupiobroker.sql
                -rw-rwxr--+ 1 iobroker iobroker    0 Oct 15 03:30 mysql_2023_10_15-03_30_31_backupiobroker.sql
                -rw-rwxr--+ 1 iobroker iobroker    0 Oct 16 03:30 mysql_2023_10_16-03_30_30_backupiobroker.sql
                -rw-rwxr--+ 1 iobroker iobroker    0 Oct 17 03:30 mysql_2023_10_17-03_30_31_backupiobroker.sql
                -rw-rwxr--+ 1 iobroker iobroker    0 Oct 18 03:30 mysql_2023_10_18-03_30_40_backupiobroker.sql
                -rw-rwxr--+ 1 iobroker iobroker    0 Oct 19 03:30 mysql_2023_10_19-03_30_38_backupiobroker.sql
                -rw-rwxr--+ 1 iobroker iobroker    0 Oct 20 03:30 mysql_2023_10_20-03_30_36_backupiobroker.sql
                -rw-rwxr--+ 1 iobroker iobroker    0 Oct 21 03:30 mysql_2023_10_21-03_30_29_backupiobroker.sql
                -rw-rwxr--+ 1 iobroker iobroker    0 Oct 22 03:30 mysql_2023_10_22-03_30_34_backupiobroker.sql
                -rw-rwxr--+ 1 iobroker iobroker    0 Oct 23 03:30 mysql_2023_10_23-03_30_31_backupiobroker.sql
                -rw-rwxr--+ 1 iobroker iobroker    0 Oct 24 03:30 mysql_2023_10_24-03_30_36_backupiobroker.sql
                -rw-rwxr--+ 1 iobroker iobroker    0 Oct 25 03:30 mysql_2023_10_25-03_30_37_backupiobroker.sql
                -rw-rwxr--+ 1 iobroker iobroker    0 Oct 26 03:30 mysql_2023_10_26-03_30_34_backupiobroker.sql
                -rw-rwxr--+ 1 iobroker iobroker    0 Oct 27 03:30 mysql_2023_10_27-03_30_40_backupiobroker.sql
                -rw-rwxr--+ 1 iobroker iobroker    0 Oct 28 03:30 mysql_2023_10_28-03_30_28_backupiobroker.sql
                -rw-rwxr--+ 1 iobroker iobroker    0 Oct 29 03:30 mysql_2023_10_29-03_30_27_backupiobroker.sql
                -rw-rwxr--+ 1 iobroker iobroker    0 Oct 30 03:30 mysql_2023_10_30-03_30_34_backupiobroker.sql
                -rw-rwxr--+ 1 iobroker iobroker    0 Oct 31 03:30 mysql_2023_10_31-03_30_27_backupiobroker.sql
                -rw-rwxr--+ 1 iobroker iobroker    0 Nov  1 03:30 mysql_2023_11_01-03_30_33_backupiobroker.sql
                -rw-rwxr--+ 1 iobroker iobroker    0 Nov  2 03:30 mysql_2023_11_02-03_30_35_backupiobroker.sql
                -rw-rwxr--+ 1 iobroker iobroker    0 Nov  3 03:30 mysql_2023_11_03-03_30_27_backupiobroker.sql
                -rw-rwxr--+ 1 iobroker iobroker    0 Nov  4 03:30 mysql_2023_11_04-03_30_30_backupiobroker.sql
                -rw-rwxr--+ 1 iobroker iobroker    0 Nov  5 03:30 mysql_2023_11_05-03_30_27_backupiobroker.sql
                -rw-rwxr--+ 1 iobroker iobroker    0 Nov  6 03:30 mysql_2023_11_06-03_30_27_backupiobroker.sql
                -rw-rwxr--+ 1 iobroker iobroker    0 Nov  7 03:30 mysql_2023_11_07-03_30_27_backupiobroker.sql
                -rw-rwxr--+ 1 iobroker iobroker    0 Nov  8 03:30 mysql_2023_11_08-03_30_42_backupiobroker.sql
                -rw-rwxr--+ 1 iobroker iobroker    0 Nov  9 03:30 mysql_2023_11_09-03_30_25_backupiobroker.sql
                -rw-rwxr--+ 1 iobroker iobroker    0 Nov 10 03:30 mysql_2023_11_10-03_30_25_backupiobroker.sql
                -rw-rwxr--+ 1 iobroker iobroker    0 Nov 11 03:30 mysql_2023_11_11-03_30_27_backupiobroker.sql
                -rw-rwxr--+ 1 iobroker iobroker    0 Nov 12 03:30 mysql_2023_11_12-03_30_25_backupiobroker.sql
                -rw-rwxr--+ 1 iobroker iobroker    0 Nov 13 03:30 mysql_2023_11_13-03_30_25_backupiobroker.sql
                -rw-rwxr--+ 1 iobroker iobroker    0 Nov 14 03:30 mysql_2023_11_14-03_30_25_backupiobroker.sql
                -rw-rwxr--+ 1 iobroker iobroker    0 Oct 14 03:30 pgsql_2023_10_14-03_30_29_backupiobroker.sql
                -rw-rwxr--+ 1 iobroker iobroker    0 Oct 15 03:30 pgsql_2023_10_15-03_30_31_backupiobroker.sql
                -rw-rwxr--+ 1 iobroker iobroker    0 Oct 16 03:30 pgsql_2023_10_16-03_30_30_backupiobroker.sql
                -rw-rwxr--+ 1 iobroker iobroker    0 Oct 17 03:30 pgsql_2023_10_17-03_30_31_backupiobroker.sql
                -rw-rwxr--+ 1 iobroker iobroker    0 Oct 18 03:30 pgsql_2023_10_18-03_30_40_backupiobroker.sql
                -rw-rwxr--+ 1 iobroker iobroker    0 Oct 19 03:30 pgsql_2023_10_19-03_30_38_backupiobroker.sql
                -rw-rwxr--+ 1 iobroker iobroker    0 Oct 20 03:30 pgsql_2023_10_20-03_30_36_backupiobroker.sql
                -rw-rwxr--+ 1 iobroker iobroker    0 Oct 21 03:30 pgsql_2023_10_21-03_30_29_backupiobroker.sql
                -rw-rwxr--+ 1 iobroker iobroker    0 Oct 22 03:30 pgsql_2023_10_22-03_30_35_backupiobroker.sql
                -rw-rwxr--+ 1 iobroker iobroker    0 Oct 23 03:30 pgsql_2023_10_23-03_30_31_backupiobroker.sql
                -rw-rwxr--+ 1 iobroker iobroker    0 Oct 24 03:30 pgsql_2023_10_24-03_30_36_backupiobroker.sql
                -rw-rwxr--+ 1 iobroker iobroker    0 Oct 25 03:30 pgsql_2023_10_25-03_30_37_backupiobroker.sql
                -rw-rwxr--+ 1 iobroker iobroker    0 Oct 26 03:30 pgsql_2023_10_26-03_30_34_backupiobroker.sql
                -rw-rwxr--+ 1 iobroker iobroker    0 Oct 27 03:30 pgsql_2023_10_27-03_30_40_backupiobroker.sql
                -rw-rwxr--+ 1 iobroker iobroker    0 Oct 28 03:30 pgsql_2023_10_28-03_30_28_backupiobroker.sql
                -rw-rwxr--+ 1 iobroker iobroker    0 Oct 29 03:30 pgsql_2023_10_29-03_30_27_backupiobroker.sql
                -rw-rwxr--+ 1 iobroker iobroker    0 Oct 30 03:30 pgsql_2023_10_30-03_30_34_backupiobroker.sql
                -rw-rwxr--+ 1 iobroker iobroker    0 Oct 31 03:30 pgsql_2023_10_31-03_30_27_backupiobroker.sql
                -rw-rwxr--+ 1 iobroker iobroker    0 Nov  1 03:30 pgsql_2023_11_01-03_30_33_backupiobroker.sql
                -rw-rwxr--+ 1 iobroker iobroker    0 Nov  2 03:30 pgsql_2023_11_02-03_30_35_backupiobroker.sql
                -rw-rwxr--+ 1 iobroker iobroker    0 Nov  3 03:30 pgsql_2023_11_03-03_30_27_backupiobroker.sql
                -rw-rwxr--+ 1 iobroker iobroker    0 Nov  4 03:30 pgsql_2023_11_04-03_30_30_backupiobroker.sql
                -rw-rwxr--+ 1 iobroker iobroker    0 Nov  5 03:30 pgsql_2023_11_05-03_30_27_backupiobroker.sql
                -rw-rwxr--+ 1 iobroker iobroker    0 Nov  6 03:30 pgsql_2023_11_06-03_30_27_backupiobroker.sql
                -rw-rwxr--+ 1 iobroker iobroker    0 Nov  7 03:30 pgsql_2023_11_07-03_30_27_backupiobroker.sql
                -rw-rwxr--+ 1 iobroker iobroker    0 Nov  8 03:30 pgsql_2023_11_08-03_30_43_backupiobroker.sql
                -rw-rwxr--+ 1 iobroker iobroker    0 Nov  9 03:30 pgsql_2023_11_09-03_30_25_backupiobroker.sql
                -rw-rwxr--+ 1 iobroker iobroker    0 Nov 10 03:30 pgsql_2023_11_10-03_30_25_backupiobroker.sql
                -rw-rwxr--+ 1 iobroker iobroker    0 Nov 11 03:30 pgsql_2023_11_11-03_30_27_backupiobroker.sql
                -rw-rwxr--+ 1 iobroker iobroker    0 Nov 12 03:30 pgsql_2023_11_12-03_30_26_backupiobroker.sql
                -rw-rwxr--+ 1 iobroker iobroker    0 Nov 13 03:30 pgsql_2023_11_13-03_30_25_backupiobroker.sql
                -rw-rwxr--+ 1 iobroker iobroker    0 Nov 14 03:30 pgsql_2023_11_14-03_30_26_backupiobroker.sql
                drwxrwxr-x+ 2 iobroker iobroker 4.0K Nov 14 03:30 redistmp
                HomoranH GlasfaserG 3 Antworten Letzte Antwort
                • fiedlesF fiedles
                  total 5.5G
                  @sebastian-fiedler die von März 22 sehen aber nach backitup aus.
                  edit; die gehen ja bis November 23
                    fiedlesF Offline
                    fiedlesF Offline
                    fiedles
                    @homoran da hatte er wohl noch funktioniert...
                    • fiedlesF fiedles
                      total 5.5G
                      GlasfaserG Offline
                      GlasfaserG Offline
                      hier ist ENTE im Gelände ...
                        für einRestore auf einem sauberen Bullseye gerade noch zu verkraften
                        • fiedlesF fiedles
                          total 5.5G
                          GlasfaserG Offline
                          GlasfaserG Offline
                          Würde den nehmen ... da danach nur noch 13M groß
                          • fiedlesF Offline
                            fiedlesF Offline
                            fiedles
                            sry :man-shrugging:
                            GlasfaserG HomoranH 2 Antworten Letzte Antwort
                            • fiedlesF fiedles
                              sry :man-shrugging:
                              GlasfaserG Offline
                              GlasfaserG Offline
                              @sebastian-fiedler
                              Raspberry mit Bookworm neu aufsetzten ( Neue SD Karte )
                              und dann diese Datei als Restore mit Backitup nutzen .
                              • fiedlesF fiedles
                                sry :man-shrugging:
                                @sebastian-fiedler wenn dein backitup noch aktiv ist, klick mal in der sidebar Anwendung auf iobroker Backup
                                Und stell vorher auf lokal.
                                Dann etwas warten bis oben das Backup als letztes drin steht.
                                Anschließend Backups abrufen und nachsehen
                                dann über den Downloadpfeil auf den PC übertragen
                                (deine Backups müssen deutlich größer sein)
                                • fiedlesF Offline
                                  fiedlesF Offline
                                  fiedles
                                  er ist am Backup erstellen.
                                  Ich muss jetzt schon mal ein fettes Dankeschön an euch beide richten! DAAAAAAAAANKE für eure Unterstützung und Geduld mit mir. 🙌 😇
                                  • fiedlesF fiedles
                                    @sebastian-fiedler
                                    na dann gute Nacht
                                    da_WoodyD fiedlesF 2 Antworten Letzte Antwort
                                      @sebastian-fiedler
                                      na dann gute Nacht
                                      da_WoodyD Offline
                                      da_WoodyD Offline
                                      #66
                                      na dann gute Nacht
                                      biglol.gif jau, der ist immer gut...
                                      @Sebastian-Fiedler bei einem restore immer warten bis er wirklich fertig ist! kann manchmal länger dauern...
                                        @sebastian-fiedler
                                        na dann gute Nacht
                                        fiedlesF Offline
                                        fiedlesF Offline
                                        fiedles
                                        #67
                                        @homoran Sicherung läuft meines Erachtens nicht richtig durch. Nach 2 Tagen tut sich nichts mehr, aber Fenster schließt sich nicht automatisch, obwohl der Harken gesetzt ist.
                                        ich poste später wieder den "ls -lh /opt/iobroker/backups" ich hoffe ihr könnt dadurch feststellen ob die Sicherung passt.
                                        Eduard77E 1 Antwort Letzte Antwort
                                        • fiedlesF fiedles
                                          Eduard77E Online
                                          Eduard77E Online
                                          Eduard77
                                          #68
                                          @sebastian-fiedler
                                          Ich weis nicht ob das zusammen hängt.
                                          Aber ich glaube, dass du Problem mit deiner Netzteil hast.
                                          Previously detected issues:
                                          ~ Under-voltage has occurred
                                          ~ Arm frequency capping has occurred
