  3. Entwicklung
  4. Neuer Adapter - Android TV & Fire TV Benachrichtigungen
    1.0k
81 Beiträge 20 Kommentatoren 16.1k Aufrufe 26 Beobachtet
  • stolly82S stolly82
    @matthsc Hey, du willst praktisch ein JSON payload übergeben?
    {message:"BLA",'image_url:'http://bla.gif''} ?
    Marty56
    Super! Funktioniert bei den ersten Tests ohne Probleme.
    Tolle Arbeit. Danke!
    HW:NUC (16 GB Ram)
    OS: Debian Bullseye, Promox V7, node v16.x npm 8.19.3
      matthscM Offline
      matthscM Offline
      matthsc
      @stolly82 said in Neuer Adapter - Android TV & Fire TV Benachrichtigungen:
      Ja, genau :-)
      stolly82S 1 Antwort Letzte Antwort
      • matthscM matthsc
        Ja, genau :-)
        stolly82S Offline
        stolly82S Offline
        stolly82
        @matthsc said in Neuer Adapter - Android TV & Fire TV Benachrichtigungen:
        Ja, genau :-)
        Erledigt!
        Changelog
        2.3.0 (2024-01-08)
        • (DNAngel) extended payload possibility as message object
        matthscM 1 Antwort Letzte Antwort
        • ? Offline
          @stolly82
          seit V2.3.0, Host Docker V9.0.1, alles latest.
          2024-01-09 11:03:38.210  - info: host.iobroker "system.adapter.notificationforandroidtv.0" enabled
          2024-01-09 11:03:38.304  - info: host.iobroker instance system.adapter.notificationforandroidtv.0 started with pid 3609
          2024-01-09 11:03:39.597  - info: notificationforandroidtv.0 (3609) starting. Version 2.3.0 (non-npm: DNAngelX/ioBroker.notificationforandroidtv) in /opt/iobroker/node_modules/iobroker.notificationforandroidtv, node: v18.19.0, js-controller: 5.0.17
          2024-01-09 11:03:39.607  - error: notificationforandroidtv.0 (3609) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
          2024-01-09 11:03:39.611  - error: notificationforandroidtv.0 (3609) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
          2024-01-09 11:03:39.612  - error: notificationforandroidtv.0 (3609) unhandled promise rejection: Cannot read properties of undefined (reading 'error')
          2024-01-09 11:03:39.612  - error: notificationforandroidtv.0 (3609) TypeError: Cannot read properties of undefined (reading 'error')
              at Notificationforandroidtv.onReady (/opt/iobroker/node_modules/iobroker.notificationforandroidtv/main.js:338:22)
              at Notificationforandroidtv.emit (node:events:517:28)
              at Notificationforandroidtv._callReadyHandler (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:9118:18)
              at /opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:9097:26
          2024-01-09 11:03:39.612  - error: notificationforandroidtv.0 (3609) Cannot read properties of undefined (reading 'error')
          2024-01-09 11:03:39.608  - error: notificationforandroidtv.0 (3609) unhandled promise rejection: Cannot read properties of undefined (reading 'error')
          2024-01-09 11:03:39.610  - error: notificationforandroidtv.0 (3609) TypeError: Cannot read properties of undefined (reading 'error')
          2024-01-09 11:03:39.610  - error: notificationforandroidtv.0 (3609) Cannot read properties of undefined (reading 'error')
          2024-01-09 11:03:39.611  - info: notificationforandroidtv.0 (3609) registerNotification not processed because States database not connected
          2024-01-09 11:03:39.620  - info: notificationforandroidtv.0 (3609) terminating
          2024-01-09 11:03:39.621  - warn: notificationforandroidtv.0 (3609) Terminated (UNCAUGHT_EXCEPTION): Without reason
            @stolly82
            stolly82S Offline
            stolly82S Offline
            stolly82
            @ilovegym
            Hmm, merkwürdig. Ich bekomme den im dev System und live nicht.
            Ich schaue noch mal
              @ilovegym
              Ich schaue noch mal
              @stolly82
              hab den Fehler gefunden, ich musste die Konfig neu anlegen, deshalb auch der Fehler im Log mit unexpected json ...
              Ich habe in der Konfig den Namen mit Leerzeichen versehen, also Fire TV Keller, da tritt der Fehler auf, wenn ich als Name FireTVKeller eintrage, geht alles...
              Edit:
              Zu frueh gefreut, hab alle 9 auf einmal angelegt, gleicher Fehler... ((
              Edit2:
              Also, ein FireTV angelegt, gespeichert, Adapter laeuft.
              Naechster Firetv in der Konfig angelegt, gespeichert, Adapter laeuft... so gehts.. beim neunten isser dann wieder abgestuerzt, hab ihn geloescht und nochmal angelegt (also den neunten FireTV), seitdem gehts...
              Denke, wenn du in der Konfig-Json suchst, biste richtig.. vielleicht kam das ja auch erst mit Admin 6.13.15..
              • wendy2702W Online
                wendy2702W Online
                Geht mit dem Adapter und Notification for Android auch ein Live Stream einer Kamera?
                L 1 Antwort Letzte Antwort
                • wendy2702W wendy2702
                  Lucky_ESA
                  @wendy2702 sagte in Neuer Adapter - Android TV & Fire TV Benachrichtigungen:
                  Dazu müsste noch die APP PiPup implementiert werden.
                  Gruß//Lucky
                  • L Lucky_ESA
                    Gruß//Lucky
                    wendy2702W Online
                    wendy2702W Online
                    @lucky_esa Ja,
                    Mit Pipup und Blockly mache ich es aktuell.
                    Dachte es würde hiermit auch schon gehen.
                      @lucky_esa Ja,
                      Lucky_ESA
                      @lucky_esa Ja,
                      Ein Adapter wäre immer die bessere Lösung. Vielleicht implementiert @stolly82 PiPup noch.
                      Gruß//Lucky
                      • L Lucky_ESA
                        @lucky_esa Ja,
                        Gruß//Lucky
                        stolly82S Offline
                        stolly82S Offline
                        stolly82
                        @lucky_esa
                        HMMMM, gar nicht mal so doof die Idee!
                        Schon mal, da die Configs ja schon alle da sind, sollte das nicht so schwer sein ;-)
                        Ich schaue mal
                          @lucky_esa
                          Ich schaue mal
                          Lucky_ESA
                          @stolly82 sagte in Neuer Adapter - Android TV & Fire TV Benachrichtigungen:
                          @lucky_esa
                          Ich schaue mal
                          Hier wäre die API
                          readme.md
                          Gruß//Lucky
                            @stolly82
                            Edit:
                            Edit2:
                            stolly82S Offline
                            stolly82S Offline
                            stolly82
                            @ilovegym
                            Objekt payload hatte ich nicht geprüft, wenn "leer" dann war es kein JSON und somit ist der Adapter abgestürzt.
                            Ist behoben, bekomme den über das DEV Portal nur nicht in add to latest
                            • L Lucky_ESA
                              @lucky_esa
                              Ich schaue mal
                              Hier wäre die API
                              readme.md
                              Gruß//Lucky
                              stolly82S Offline
                              stolly82S Offline
                              stolly82
                              @lucky_esa
                              Ich muss das App erstmal auf die FireTV's drauf bekommen.
                              Grusel 😖
                              So, the tutorial:
                              Installing PiPup
                              Download ADB drivers (Platform-Tools) for the device you’re using from here 138. On windows you just unzip the file, open terminal there and everything should work. People using linux - you know what to do.
                              Enable ADB and connect to the TV: follow this 166, it’s way better than what I can write.
                              Download Pipup from here 156 (app-debug.apk file). Put it in the directory with ADB drivers
                              In the terminal you have open run: adb sideload app-debug.apk (you must already be connected to TV, so don’t forget adb connect <IP> from the last step)
                              Grant needed permission with: adb shell appops set nl.rogro82.pipup SYSTEM_ALERT_WINDOW allow
                              Open the app on your TV, you can close it pretty much immediately, it just needs to run in the background
                              • BananaJoeB Offline
                                BananaJoeB Offline
                                BananaJoe
                                Kann PiPup denn RSTP-Streams? Das wäre der Kamera Standard. Oder "nur" Video?
                                Das Issue dazu ist noch offen, https://github.com/rogro82/PiPup/issues/8
                                Ich habe nur einen gefunden der das Video vorher über WebRTC umwandelt/bereitstellt.
                                • BananaJoeB BananaJoe
                                  BananaJoeB Offline
                                  BananaJoeB Offline
                                  BananaJoe
                                  @bananajoe Nachtrag: Direkt das Bild von der Kamera zu holen klappt mit dem Adapter nicht (was aber wohl an der App auf Android liegen wird), ich hole es erst auf den ioBroker und stelle es dort bereit. Die App hat wohl nicht die gedult auf das Bild zu warten (Reolink Kameras)
                                    @ilovegym
                                    mcm1957M Online
                                    mcm1957M Online
                                    mcm1957
                                    @ilovegym
                                    Du brauchst nur EINMAL ein "add to latest" auslösen. Dein PR existiert als https://github.com/ioBroker/ioBroker.repositories/pull/3189.
                                    Das Review ist noch pending.
                                    Neue Releases brauchen für das latest Repository KEINEN neuerlichen Aufruf via dev Protal. Sobald ein Adapter für Latest freigeschaltet ist wird er im latest Repositpory automatisch aktualisisert. Nur fürs stable Repo musst du später einen Reqeust per Release stellen (dazu gibts dann aber ggF Erinnerungen)
                                    Support Repositoryverwaltung.
                                    LESEN - gute Forenbeitrage
                                    • wendy2702W Online
                                      wendy2702W Online
                                      @BananaJoe Ich nutze den http Stream aus Motioneye. RTSP direkt geht wohl nicht weil die auch im Browser nicht mehr gehen.
                                        BananaJoeB Offline
                                        BananaJoeB Offline
                                        BananaJoe
                                        @wendy2702 könnte ich bei mir auch machen (aus BlueIris). Hab dann aber irgendwann entschieden das ein Bild pro Sekunde auch reicht um zusehen wer da steht.
                                        Der Stream war immer eine ganz schöne Last ... und es hat lange gedauert bis das System erkannt hat das auf der anderen Seite gar keiner mehr zu hört und wieder runter geschaltet hat.
                                          Ja, genau :-)
                                          Erledigt!
                                          Changelog
                                          2.3.0 (2024-01-08)
                                          matthscM Offline
                                          matthscM Offline
                                          matthsc
                                          Erledigt!
                                          Changelog
                                          2.3.0 (2024-01-08)
                                          Danke dir, funktioniert einwandfrei!
