  4. [gelöst] MQTT Server Restart?
    5.8k
41 Beiträge 3 Kommentatoren 7.9k Aufrufe
  • ? Offline
    Hm, gar nicht gut. Mit Chunking Patch aktiviert wird alles rot und nix geht mehr:
    • host.TARDIS 2017-12-03 10:31:27.674 info Restart adapter system.adapter.mqtt.0 because enabled
    host.TARDIS 2017-12-03 10:31:27.674 error instance system.adapter.mqtt.0 terminated with code 0 (OK)
    Caught 2017-12-03 10:31:27.673 error by controller[2]: at Connection.Writable.write (C:\ioBroker\node_modules\iobroker.mqtt\node_modules\readable-stream\lib\_stream_writable.js:322:11)
    Caught 2017-12-03 10:31:27.673 error by controller[2]: at writeOrBuffer (C:\ioBroker\node_modules\iobroker.mqtt\node_modules\readable-stream\lib\_stream_writable.js:395:5)
    Caught 2017-12-03 10:31:27.673 error by controller[2]: at doWrite (C:\ioBroker\node_modules\iobroker.mqtt\node_modules\readable-stream\lib\_stream_writable.js:406:64)
    Caught 2017-12-03 10:31:27.673 error by controller[2]: at Connection.Duplexify._write (C:\ioBroker\node_modules\iobroker.mqtt\node_modules\duplexify\index.js:201:22)
    Caught 2017-12-03 10:31:27.673 error by controller[2]: at Writable.write (_stream_writable.js:243:11)
    Caught 2017-12-03 10:31:27.673 error by controller[2]: at writeOrBuffer (_stream_writable.js:317:5)
    Caught 2017-12-03 10:31:27.673 error by controller[2]: at doWrite (_stream_writable.js:331:12)
    Caught 2017-12-03 10:31:27.673 error by controller[2]: at Writable.write [as _write] (C:\ioBroker\node_modules\iobroker.mqtt\node_modules\mqtt-connection\lib\writeToStream.js:10:9)
    Caught 2017-12-03 10:31:27.673 error by controller[2]: at publish (C:\ioBroker\node_modules\iobroker.mqtt\node_modules\mqtt-packet\writeToStream.js:248:23)
    Caught 2017-12-03 10:31:27.673 error by controller[2]: at Function.Buffer.concat (buffer.js:304:24)
    Caught 2017-12-03 10:31:27.672 error by controller[2]: 2017-12-03 10:31:27.154 - mqtt.0 TypeError: Cannot read property 'length' of undefined
    Caught 2017-12-03 10:31:27.672 error by controller[1]: 2017-12-03 10:31:27.154 - mqtt.0 uncaught exception: Cannot read property 'length' of undefined
    Caught 2017-12-03 10:31:27.672 error by controller[0]: at Connection.Writable.write (C:\ioBroker\node_modules\iobroker.mqtt\node_modules\readable-stream\lib\_stream_writable.js:322:11)
    Caught 2017-12-03 10:31:27.672 error by controller[0]: at writeOrBuffer (C:\ioBroker\node_modules\iobroker.mqtt\node_modules\readable-stream\lib\_stream_writable.js:395:5)
    Caught 2017-12-03 10:31:27.672 error by controller[0]: at doWrite (C:\ioBroker\node_modules\iobroker.mqtt\node_modules\readable-stream\lib\_stream_writable.js:406:64)
    Caught 2017-12-03 10:31:27.672 error by controller[0]: at Connection.Duplexify._write (C:\ioBroker\node_modules\iobroker.mqtt\node_modules\duplexify\index.js:201:22)
    Caught 2017-12-03 10:31:27.672 error by controller[0]: at Writable.write (_stream_writable.js:243:11)
    Caught 2017-12-03 10:31:27.672 error by controller[0]: at writeOrBuffer (_stream_writable.js:317:5)
    Caught 2017-12-03 10:31:27.671 error by controller[0]: at doWrite (_stream_writable.js:331:12)
    Caught 2017-12-03 10:31:27.671 error by controller[0]: at Writable.write [as _write] (C:\ioBroker\node_modules\iobroker.mqtt\node_modules\mqtt-connection\lib\writeToStream.js:10:9)
    Caught 2017-12-03 10:31:27.671 error by controller[0]: at publish (C:\ioBroker\node_modules\iobroker.mqtt\node_modules\mqtt-packet\writeToStream.js:248:23)
    Caught 2017-12-03 10:31:27.671 error by controller[0]: at Function.Buffer.concat (buffer.js:304:24)
    Caught 2017-12-03 10:31:27.671 error by controller[0]: TypeError: Cannot read property 'length' of undefined
    mqtt.0 2017-12-03 10:31:27.658 info terminating
    mqtt.0 2017-12-03 10:31:27.169 info Client [Countdown_Lab] closed
    mqtt.0 2017-12-03 10:31:27.167 warn Client error [Countdown_Lab]: Error: not opened
    mqtt.0 2017-12-03 10:31:27.163 info Client [Countdown_Lab] connected
    mqtt.0 2017-12-03 10:31:27.158 info Client [labspinnen8266] closed
    mqtt.0 2017-12-03 10:31:27.154 error at Connection.Writable.write (C:\ioBroker\node_modules\iobroker.mqtt\node_modules\readable-stream\lib\_stream_writable.js:322:11)
    mqtt.0 2017-12-03 10:31:27.154 error at writeOrBuffer (C:\ioBroker\node_modules\iobroker.mqtt\node_modules\readable-stream\lib\_stream_writable.js:395:5)
    mqtt.0 2017-12-03 10:31:27.154 error at doWrite (C:\ioBroker\node_modules\iobroker.mqtt\node_modules\readable-stream\lib\_stream_writable.js:406:64)
    mqtt.0 2017-12-03 10:31:27.154 error at Connection.Duplexify._write (C:\ioBroker\node_modules\iobroker.mqtt\node_modules\duplexify\index.js:201:22)
    mqtt.0 2017-12-03 10:31:27.154 error at Writable.write (_stream_writable.js:243:11)
    mqtt.0 2017-12-03 10:31:27.154 error at writeOrBuffer (_stream_writable.js:317:5)
    mqtt.0 2017-12-03 10:31:27.154 error at doWrite (_stream_writable.js:331:12)
    mqtt.0 2017-12-03 10:31:27.154 error at Writable.write [as _write] (C:\ioBroker\node_modules\iobroker.mqtt\node_modules\mqtt-connection\lib\writeToStream.js:10:9)
    mqtt.0 2017-12-03 10:31:27.154 error at publish (C:\ioBroker\node_modules\iobroker.mqtt\node_modules\mqtt-packet\writeToStream.js:248:23)
    mqtt.0 2017-12-03 10:31:27.154 error at Function.Buffer.concat (buffer.js:304:24)
    mqtt.0 2017-12-03 10:31:27.154 error TypeError: Cannot read property 'length' of undefined
    mqtt.0 2017-12-03 10:31:27.154 error uncaught exception: Cannot read property 'length' of undefined
    mqtt.0 2017-12-03 10:31:27.116 info Client [labspinnen8266] connected
    mqtt.0 2017-12-03 10:31:26.979 info Starting MQTT-WebSocket server on port 1884
    mqtt.0 2017-12-03 10:31:26.978 info Starting MQTT server on port 1883
    mqtt.0 2017-12-03 10:31:26.756 info Patch applied
    mqtt.0 2017-12-03 10:31:26.742 info starting. Version 1.3.2 in C:/ioBroker/node_modules/iobroker.mqtt, node: v6.10.3
    host.TARDIS 2017-12-03 10:31:26.085 info instance system.adapter.mqtt.0 started with pid 13632
      @meome:
      C:\ioBroker\node_modules\iobroker.mqtt\node_modules\readable-stream\lib_stream_writable.js:322:11 `
      Also windoof??
      Da bin ich leider raus :(
      Aber hast du mal an den automatischen restart gefacht?
      http://www.iobroker.net/docu/?page_id=5 … #6_restart
      Gruß Rainer
      • ? Offline
        Ja, ein automatischer Restart würde das Problem auf jeden Fall lösen machen, denke ich.
        Es startet aber nicht automatisch neu. Zumindest nicht sofort.
        Dein Link hat mir da grad leider nicht weiter geholfen.
        Da steht nur, das ich resarten kann? Das tue ich ja auch schon. Das funktioniert.
        Aber wie geht das automatisch?
        • ? Offline
          Und ja, alles Windows 10, in der Tat.
          Ich überlege grad Umzug auf RasPi, aber mit Linux kenne ich mich noch so gut wie gar nicht aus.
            @meome:
            Aber wie geht das automatisch? `
            Indem du dort im Admin unter Instanzen einen cron eingibst (Expertenmodus vorher aktivieren!).
            Den stellst du entsprechend deiner wünsche nach dem restartintervall ein.
            • ? Offline
              Hm. Danke für die Anregung.
              Unter Windows 10 gibts wohl nur die Taskplanung. Habe auch das Programm Z-Cron gefunden, das anscheinend gut ist.
              Ist es denn echt ok, wenn ich den MQTT-Adapter jede Minute neu starte?
              Besser wäre ja eigentlich, wenn ich jede Minute ein Programm ausführen lassen würde, das prüft, ob MQTT läuft.
              Wenn ja: Alle sgut und nix tun.
              Wenn nein: Neustart MQTT-Adapter per Kommandozeilenbefehl.
              Gibt es eine Möglichkeit, mit einem Kommandozeilen-Befehl zu prüfen, ob MQTT läuft?
              Ich glaube, ich mus smir auch noch mal das mit dem Chunking Patch durchlesen, das hat im anderen Thread ja funktioniert.
              Eine dritte alternative wäre natürlich noch auf Mosquitto umzusteigen und zu hoffen, das es da besser läuft.
              Würde aber am liebsten alles im iobroker-Universum lassen.
              • ? Offline
                Oh nein, war mal wieder zu schnell.
                Habe die Cron-Experten-Einstellungen gefunden.
                Frage bleibt: Ist das ok, jede Minute neu zu starten? Verliere ich dann evtl. Daten?
                • DutchmanD Offline
                  DutchmanD Offline
                  Dutchman
                  @meome:
                  Frage bleibt: Ist das ok, jede Minute neu zu starten? Verliere ich dann evtl. Daten? `
                  Ich wuerde ihn auf keinen falll jede minute neu starten :/
                  Pruefe doch mal bitten ob der status alive auf false schlaegt wen der adapter abschmiert
                  (vorher bei den objecten experten modus einschalten sonst siehst du diese variable nicht)
                  system.adapter.mqtt.0.alive
                  wen ja kan man mit javascript dafuer sorgen "wenn alive = false dann adapter neustart"
                  • ? Offline
                    Das wäre eine gute Lösung.
                    So weit ich weiß, ist es false (die oberen 2 von 3 Punkten sind rot), aber ich werd das morgen prüfen und berichten.
                    Wie ich die Systemnachricht system.adapter.mqtt.0.alive per Websockets in meine Webseite kriege, weiß ich (glaube ich).
                    Aber wie kann ich mit Javascript aus einer Webseite heraus den Adapter neu starten?
                    • DutchmanD Offline
                      DutchmanD Offline
                      Dutchman
                      @meome:
                      Aber wie kann ich mit Javascript aus einer Webseite heraus den Adapter neu starten? `
                      Schau mal hier für ein Script Beispiel.
                      Die Frage ist ob du es von der Webseite aus machen möchtest, Dan musst du da einen Button mit Trigger erstellen, oder einfach nen Adapter reboot machst wen de Werte alive = false wird:
                      http://forum.iobroker.net/viewtopic.php?t=9190
                      Send from mobile device
                      • ? Offline
                        Hatte endlich Zeit:
                        Per iobroker Javascript-Adapter ein Blocky-Script erstellt
                        (ich wollte es eigentlich per DOS-Batch-Befehl machen a la "iobroker restart mqtt.0" , Blocky ist glaub ich viel besser :-) Da hatte ich kompliziert gedacht und wusste nichts vom Javascript-Adapter. iobroker ist immer wieder eindrucksvoll :D ).
                        Das Skript läuft und sieht folgendermaßen aus:
                        on({id: "system.adapter.mqtt.0.alive"/*mqtt.0.alive*/, val: false}, function (obj) {
                          var value = obj.state.val;
                          console.log('MQTT RESTART');
                          setState("system.adapter.mqtt.0.alive"/*mqtt.0.alive*/, true);
                          setState("system.adapter.mqtt.0.connected"/*mqtt.0.connected*/, true);
                        Die Frage ist jetzt: Ist das richtig so?
                        Ich setze ja nur die Werte alive und connected auf true.
                        Einen wirklichen Adapter-Restart mache ich damit nicht?
                        Oder doch?
                        Wenn nicht, was wäre denn der Befehl dafür? Finde in Blocky nichts.
                        Leider kann ich es nicht testen, da der mqtt-Ausfall nur äußerst sporadisch auftritt und ich immer noch keinen Anhaltspunkt habe, warum es passiert.
                        Ich habe das gleiche Problem letztens sogar bei socket.io gehabt. War einfach rot und wurde durch manuellen Neustart sofort wieder funktional.
                        Dafür würde ich dann gleich ein zweites Skript anlegen.
                        Müsste nur wissen, ob das so wirklich funkional ist oder ob ich einen anderes Kommando für Adapter-Restart brauche.
                        Habe in der Suche nichts gefunden.
                          Das geht viel einfacher (per cron):
                          bitte vorher Expertenmodus aktivieren.
                          • DutchmanD Offline
                            DutchmanD Offline
                            Dutchman
                            Warum setzt Nu Werte alive und connected das ist der Status!
                            Du musst den Adapter enabled Werte auf FALSE und dann zB 30sec später auf true setzen.
                            Der alive/connected gibt für den Status ob er abgeschmiert ist
                            @Homoran
                            Die Frage war nicht cyclisch zu rebooten was mit cron geht sondern nur wenn er abgeschmiert ist
                            • ? Offline
                              Ich glaub, ich habs!
                              Hab das Script von Blocky in Javascript kopiert und dann folgendermaßen abgeändert:
                                var obj2 = getObject("system.adapter.mqtt.0");
                                obj2.common.enabled = true;  // Adapter einschalten
                                setObject("system.adapter.mqtt.0", obj2);
                              Jetzt startet der MQTT-Adapter jedes mal neu, wenn ich ihn zum Beispiel manuell deaktiviere!
                              Denke, wenn irgendwas anderes ihn aus der Fassung bringt, passiert das auch.
                              Jetzt bastel ich das gleich noch für Socket.io.
                              Damit kann man den Adapter zwar nicht mehr deaktivieren, solange das Skript läuft, aber das ist bei MQTT und Socket.io ja herzlich egal.
                              Damit sollten meine Panikattacken endlich vorüber sein :) :) :)
                              Hoffentlich ist das jetzt richtig so.
                              • DutchmanD Offline
                                DutchmanD Offline
                                Dutchman
                                Man könnte das noch verfeinern durch nur auf alive zu überprüfen und eine Aktion aus zu lösen wen der Adapter enabled ist. Dann könntest du ihn auch manuell wieder ausschalten
                                • ? Offline
                                  @Dutchman: Das wäre cool. Ja.
                                  Ich fände es auch toll, wenn es da sowas wie eine Sicherheitssperre von 10-15 Sekunden gäbe, damit bei einem richtig fiesen Absturz nicht 1000 Neustartanforderungen pro Sekunde gesendet werden und evtl. das gesamte System blockieren.
                                  Ich weiß nicht, ob das so passieren kann. Aber damit würde ich mich sicherer fühlen.
                                  Leider übersteigt das aber meine Fähigkeiten.
                                  Vielleicht spiele ich mal in Blocky rum, um zu sehen, wie so eine Zeitsteuerung funktioniert.
                                  Ich bin leider totaler Noob.
                                  Ich brauche immer vorgegebene Codeschnipsel, die ich dann per try&error zusammensetze.
                                  Freu mich schon, wenn jetzt keiner mehr sagt: Das geht so nicht, das darfst du nicht tun, weil gefährlich und alles kann abschmieren oder so :-)
                                  • DutchmanD Offline
                                    DutchmanD Offline
                                    Dutchman
                                    Ich verstehe deine Sicherheitsperre logic nicht ;) was meinst du damit
                                    • ? Offline
                                      Noch mehr würde ich mich freuen, wenn diese seltsamen Abstürze überhaupt nicht vorkommen würden oder ich zumindest den Grund dafür rausbekäme.
                                      Aber ein Autorestart per Skript ist ja hoffentlich auch schon eine gute Methode, um mein System ausfallsicherer zu machen.
                                      Mit "Sicherheitssperre" meine ich: Falls der Adapter bei einem Neustart wieder und wieder Abstürzt, soll das Skript nicht unendlich oft und schnell versuchen, ihn neu zu starten. Eine kleine Pause von 10 Sekunden zwischen den versuchen wär toll. Einfach um das System nicht zu überlasten.
                                      Sorry, ich weiß nicht, ob das überhaupt ein Problem bei modernen Javascript-Systemen bzw. iobroker ist.
                                      Keine Ahnung, wie das Ereignis-/Zeitsystem eigentlich funktioniert (leider),
                                      Ich arbeite manchmal mit Arduinos und ESP8266, da muss man auf sowas evtl. Acht geben.
                                      • ? Offline
                                        Vielleicht muss ich es auch noch weiter verfeinern?
                                        Ein Interval aufrufen, das alle 10 Sekunden versucht, den Adapter neu zu starten.
                                        Und erst gestoppt wird, wenn der Adapter wieder läuft?
                                        Ich mache das so beim MQTT-Connect auf meiner Webseite und bei meinen Mikrokontrollern.
                                        Bei Abbruch alle 10 Sekunden Neuverbindungsversuch, bis Reconnect.
                                        Im Moment kann es vielleicht passieren, dass der Adapter off geht.
                                        Das Skript versucht, es neu zu starten.
                                        Klappt nicht.
                                        Aber da keine weitere Änderung des MQTT Adapters ausgelöst wird, wird das Skript nicht erneut aufgerufen.
                                        So gibt es bei jedem Absturz nur insgesamt 1 Neustartversuch?
                                        Bin mir nicht sicher, wie die Aufruflogik des Skriptes funktioniert.
                                        • DutchmanD Offline
                                          DutchmanD Offline
                                          Dutchman
                                          Eine pause kannst du mit nem time-out realisieren, habe dein script mal damit erweitert + die abfrage ob der adapter enabled sein soll.
                                              //Timeout, erst 5 sekunden nach status alive = false neustart initieren
                                              timeout = setTimeout(function () {
                                                  var obj2 = getObject("system.adapter.mqtt.0").common.enabled;
                                                  //Nur ausfuehren wen adapter enabled ist UND der alive status immernoch false
                                                  if (obj2 === true && getState("system.adapter.mqtt.0.alive").val === false) {
                                                      var obj = getObject("system.adapter.mqtt.0");
                                                      obj.common.enabled = true;
                                                      setObject("system.adapter.mqtt.0", obj);
                                              // Hier stehen die 10 sekunden
                                              }, 10000);
                                          was due gerade in den andere thread gepostet hast geht auch ist eine andere vorgehensweise.
                                          Also entscheiden entweder den trigger auf alive lassen und damit initieren ob de adapter neu starten soll oder mit cron alle x sekunden/minuten ueberprpuefen ob er alive ist und wen nicht neu starten
