  4. Blockly Schreibrechte Debian
    5.2k
33 Beiträge 4 Kommentatoren 3.8k Aufrufe 3 Beobachtet
    aleks-83
    schrieb am zuletzt editiert von aleks-83
    Habe den fix ausgeführt.
    cp funktioniert jetzt ! Danke !
    Jetzt erhalte ich im log alle 30s diese Fehlermeldungen:
    2024-01-08 15:10:55.558 - error: host.Debian Caught by controller[0]: /bin/sh: 1: npm: not found
    2024-01-08 15:10:55.558 - error: host.Debian Caught by controller[1]: /opt/iobroker/node_modules/iobroker.info/main.js:89
    2024-01-08 15:10:55.558 - error: host.Debian Caught by controller[1]: adapter.log.error("Could not check npm version: " + e);
    2024-01-08 15:10:55.558 - error: host.Debian Caught by controller[1]: ^
    2024-01-08 15:10:55.559 - error: host.Debian Caught by controller[1]: TypeError: Cannot read properties of undefined (reading 'log')
    2024-01-08 15:10:55.559 - error: host.Debian Caught by controller[1]: at getSystemVersions (/opt/iobroker/node_modules/iobroker.info/main.js:89:11)
    2024-01-08 15:10:55.559 - error: host.Debian Caught by controller[1]: at Object. (/opt/iobroker/node_modules/iobroker.info/main.js:58:18)
    2024-01-08 15:10:55.559 - error: host.Debian Caught by controller[1]: at Module._compile (node:internal/modules/cjs/loader:1356:14)
    2024-01-08 15:10:55.559 - error: host.Debian Caught by controller[1]: at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
    2024-01-08 15:10:55.559 - error: host.Debian Caught by controller[1]: at Module.load (node:internal/modules/cjs/loader:1197:32)
    2024-01-08 15:10:55.559 - error: host.Debian Caught by controller[1]: at Module._load (node:internal/modules/cjs/loader:1013:12)
    2024-01-08 15:10:55.559 - error: host.Debian Caught by controller[1]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12)
    2024-01-08 15:10:55.559 - error: host.Debian Caught by controller[1]: at node:internal/main/run_main_module:28:49
    2024-01-08 15:10:55.559 - error: host.Debian Caught by controller[1]: Node.js v18.19.0
    2024-01-08 15:10:55.559 - error: host.Debian instance system.adapter.info.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    = Dell Optiplex Micro - 10GB RAM - 200GB SSD - Debian VM =
    = Node.js v20.19.6 = NPM 10.8.2 = JS Controller 7.0.7 =
    Ubiquiti UAP-AC-LR - UAP-AC-Lite - Synology DS716+II - Fritz!Box 7490
    Glasfaser 400
    • A aleks-83
      @aleks-83
      https://forum.iobroker.net/topic/71478/plötzliche-probleme-durch-nodejs-dfsg-version-npm-fehlt
        @aleks-83
        aleks-83
        Ich hab einfach kein Glück :-X
        Glasfaser 400
        • A aleks-83
          @aleks-83
          Bitte keine Bilder von Texten. Und was ist das bitte für ein Terminal? Das sieht 'kaputt' aus.
            aleks-83
            Wie bereits erwähnt, funktioniert das Copy & Paste noch nicht in meiner Debian VM obwohl ich die Guest Additions installiert habe. Daran arbeite ich als nächstes.
            Die Konsole ist die direkte Eingabe in der Debian VM. Das ist headless und hat keine GUI.
            Glasfaser 400
            • A aleks-83
              @aleks-83
              Ich würde ja mit einem Terminal via ssh auf die Kiste gehen.
                aleks-83
                Würde ich auch gerne aber das funktioniert ebenfalls nicht.
                Beim login über putty kommt "Access denied"
                Glasfaser 400
                • A aleks-83
                  @aleks-83 sagte in Blockly Schreibrechte Debian:
                  Wie versuchst du das? Als root evtl.?
                    aleks-83
                    Nein mit meinem neuen User.
                    Aber jetzt geht ssh …
                    Allerdings geht der fix für die npm nicht.
                    Last login: Mon Jan  8 21:50:54 2024 from 10.0.0.60
                    $ echo -e "Package: nodejs\nPin: origin deb.nodesource.com\nPin-Priority: 1001" | sudo tee /etc/apt/preferences.d/nodejs.pref
                    [sudo] Passwort für alex:
                    -e Package: nodejs
                    Pin-Priority: 1001
                    $ sudo apt update
                    OK:1 http://security.debian.org/debian-security bookworm-security InRelease
                    OK:2 http://deb.debian.org/debian bookworm InRelease
                    Holen:3 http://deb.debian.org/debian bookworm-updates InRelease [52,1 kB]
                    OK:4 https://deb.nodesource.com/node_18.x nodistro InRelease
                    Es wurden 52,1 kB in 1 s geholt (42,1 kB/s).
                    E: Ungültiger Eintrag in Einstellungsdatei /etc/apt/preferences.d/nodejs.pref, keine »Package«-Kopfzeile(n)
                    Glasfaser 400
                    • A aleks-83
                      -e Package: nodejs
                      Pin-Priority: 1001
                      $ sudo apt update
                      sudo  rm /etc/apt/preferences.d/nodejs.pref
                      sudo apt update
                      sudo apt install nodejs=18.19.0-1nodesource1
                      • A aleks-83
                        -e Package: nodejs
                        Pin-Priority: 1001
                        $ sudo apt update
                        @aleks-83
                        Falls deine shell mit echo -e nix anfangen kann...
                        Trag mit einem Editor das in die nodejs.pref rein:
                        Package: nodejs
                        Pin-Priority: 1001
                          aleks-83
                          Moin. Das Echo funktioniert, aber beim apt Update kommt die gleiche Fehlermeldung
                          Glasfaser 400
                          • A aleks-83
                            @aleks-83
                            Zeig mal den Inhalt der Datei 1:1.
                              @aleks-83
                              aleks-83
                              -e Package: nodejs
                              Pin-Priority: 1001
                              Glasfaser 400
                              • A aleks-83
                                -e Package: nodejs
                                Pin-Priority: 1001
                                @aleks-83
                                Das -e ist bei dir zu viel.
                                  aleks-83
                                  @thomas-braun Läuft! Danke
                                  Glasfaser 400
