  4. Test Adapter LG ThinQ
    6.8k
950 Beiträge 72 Kommentatoren 416.0k Aufrufe 69 Beobachtet
  • L Lucky_ESA
    @ofri2607
    Besteht die Möglichkeit das du mal vom GIT lädst?
    ofri2607O Online
    ofri2607O Online
    ofri2607
    #429
    @lucky_esa
    Klar kein Problem, siehe nachstehende Log (wieder alles inkl. Installation) brauchst ein debug-log auch?
    Adapter läuft damit grundsätzlich, schreibt aber alle 5 Sekunden zwei Log-Einträge zu WRONG WORKLIST und die Warnungen zum setObject bei den thinq2 Geräten sind noch da.
    2024-01-07 12:10:40.637 - info: host.raspberrypi iobroker url TA2k/ioBroker.lg-thinq --host raspberrypi --debug
    2024-01-07 12:10:43.456 - info: host.raspberrypi iobroker install TA2k/ioBroker.lg-thinq
    2024-01-07 12:10:44.585 - info: host.raspberrypi iobroker NPM version: 10.2.3
    2024-01-07 12:10:44.587 - info: host.raspberrypi iobroker Installing TA2k/ioBroker.lg-thinq... (System call)
    2024-01-07 12:11:00.120 - info: host.raspberrypi iobroker changed 1 package in 15s138 packages are looking for funding run `npm fund` for details
    2024-01-07 12:11:00.436 - info: host.raspberrypi iobroker upload [13] lg-thinq.admin /opt/iobroker/node_modules/iobroker.lg-thinq/admin/i18n/de/translations.json i18n/de/translations.json application/json
    2024-01-07 12:11:00.455 - info: host.raspberrypi iobroker upload [12] lg-thinq.admin /opt/iobroker/node_modules/iobroker.lg-thinq/admin/i18n/en/translations.json i18n/en/translations.json application/json
    2024-01-07 12:11:00.465 - info: host.raspberrypi iobroker upload [11] lg-thinq.admin /opt/iobroker/node_modules/iobroker.lg-thinq/admin/i18n/es/translations.json i18n/es/translations.json application/json
    2024-01-07 12:11:00.474 - info: host.raspberrypi iobroker upload [10] lg-thinq.admin /opt/iobroker/node_modules/iobroker.lg-thinq/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
    2024-01-07 12:11:00.483 - info: host.raspberrypi iobroker upload [9] lg-thinq.admin /opt/iobroker/node_modules/iobroker.lg-thinq/admin/i18n/it/translations.json i18n/it/translations.json application/json
    2024-01-07 12:11:00.494 - info: host.raspberrypi iobroker upload [8] lg-thinq.admin /opt/iobroker/node_modules/iobroker.lg-thinq/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
    2024-01-07 12:11:00.504 - info: host.raspberrypi iobroker upload [7] lg-thinq.admin /opt/iobroker/node_modules/iobroker.lg-thinq/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
    2024-01-07 12:11:00.514 - info: host.raspberrypi iobroker upload [6] lg-thinq.admin /opt/iobroker/node_modules/iobroker.lg-thinq/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
    2024-01-07 12:11:00.523 - info: host.raspberrypi iobroker upload [5] lg-thinq.admin /opt/iobroker/node_modules/iobroker.lg-thinq/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
    2024-01-07 12:11:00.534 - info: host.raspberrypi iobroker upload [4] lg-thinq.admin /opt/iobroker/node_modules/iobroker.lg-thinq/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
    2024-01-07 12:11:00.544 - info: host.raspberrypi iobroker upload [3] lg-thinq.admin /opt/iobroker/node_modules/iobroker.lg-thinq/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
    2024-01-07 12:11:00.554 - info: host.raspberrypi iobroker upload [2] lg-thinq.admin /opt/iobroker/node_modules/iobroker.lg-thinq/admin/index_m.html index_m.html text/html
    2024-01-07 12:11:00.563 - info: host.raspberrypi iobroker upload [1] lg-thinq.admin /opt/iobroker/node_modules/iobroker.lg-thinq/admin/jsonConfig.json jsonConfig.json application/json
    2024-01-07 12:11:00.572 - info: host.raspberrypi iobroker upload [0] lg-thinq.admin /opt/iobroker/node_modules/iobroker.lg-thinq/admin/lg-thinq.png lg-thinq.png image/png
    2024-01-07 12:11:00.663 - info: host.raspberrypi iobroker Update "system.adapter.lg-thinq.0"
    2024-01-07 12:11:01.732 - info: host.raspberrypi iobroker exit 0
    2024-01-07 12:11:23.290 - info: host.raspberrypi "system.adapter.lg-thinq.0" enabled
    2024-01-07 12:11:23.548 - info: host.raspberrypi instance system.adapter.lg-thinq.0 started with pid 1152227
    2024-01-07 12:11:26.337 - info: lg-thinq.0 (1152227) starting. Version 0.3.1 (non-npm: TA2k/ioBroker.lg-thinq) in /opt/iobroker/node_modules/iobroker.lg-thinq, node: v18.19.0, js-controller: 5.0.17
    2024-01-07 12:11:29.225 - info: lg-thinq.0 (1152227) Login successful
    2024-01-07 12:11:36.532 - info: lg-thinq.0 (1152227) Found: 3 devices
    2024-01-07 12:11:36.533 - info: lg-thinq.0 (1152227) Create or update datapoints for d27d1380-7149-11d3-80b8-2c2bf9760c6d
    2024-01-07 12:11:49.996 - info: lg-thinq.0 (1152227) Update raw datapoints for d27d1380-7149-11d3-80b8-2c2bf9760c6d
    2024-01-07 12:11:50.542 - info: lg-thinq.0 (1152227) Create or update datapoints for dfbdfc44-8efb-148a-acc9-44cb8b32f2ea
    2024-01-07 12:11:50.761 - warn: lg-thinq.0 (1152227) setObject dfbdfc44-8efb-148a-acc9-44cb8b32f2ea.remote.basicCtrl.windStrength (type=state) property common.role missing!
    2024-01-07 12:11:50.766 - warn: lg-thinq.0 (1152227) setObject dfbdfc44-8efb-148a-acc9-44cb8b32f2ea.remote.wDirCtrl.hStep (type=state) property common.role missing!
    2024-01-07 12:11:50.767 - warn: lg-thinq.0 (1152227) setObject dfbdfc44-8efb-148a-acc9-44cb8b32f2ea.remote.qualityMngCtrl.sensorMon (type=state) property common.role missing!
    2024-01-07 12:11:50.767 - warn: lg-thinq.0 (1152227) setObject dfbdfc44-8efb-148a-acc9-44cb8b32f2ea.remote.basicCtrl.target (type=state) property common.role missing!
    2024-01-07 12:11:50.768 - warn: lg-thinq.0 (1152227) setObject dfbdfc44-8efb-148a-acc9-44cb8b32f2ea.remote.basicCtrl.operation (type=state) property common.role missing!
    2024-01-07 12:11:50.770 - warn: lg-thinq.0 (1152227) setObject dfbdfc44-8efb-148a-acc9-44cb8b32f2ea.remote.wDirCtrl.vStep (type=state) property common.role missing!
    2024-01-07 12:11:50.776 - warn: lg-thinq.0 (1152227) setObject dfbdfc44-8efb-148a-acc9-44cb8b32f2ea.remote.settingInfo.basic (type=state) property common.role missing!
    2024-01-07 12:11:50.777 - warn: lg-thinq.0 (1152227) setObject dfbdfc44-8efb-148a-acc9-44cb8b32f2ea.remote.settingInfo.autoDry (type=state) property common.role missing!
    2024-01-07 12:11:50.779 - warn: lg-thinq.0 (1152227) setObject dfbdfc44-8efb-148a-acc9-44cb8b32f2ea.remote.basicCtrl.opMode (type=state) property common.role missing!
    2024-01-07 12:11:56.168 - info: lg-thinq.0 (1152227) Update raw datapoints for dfbdfc44-8efb-148a-acc9-44cb8b32f2ea
    2024-01-07 12:11:56.884 - info: lg-thinq.0 (1152227) Create or update datapoints for fd80ae07-21ef-18c3-bd4c-44cb8b63456e
    2024-01-07 12:11:56.936 - warn: lg-thinq.0 (1152227) setObject fd80ae07-21ef-18c3-bd4c-44cb8b63456e.remote.basicCtrl.windStrength (type=state) property common.role missing!
    2024-01-07 12:11:56.937 - warn: lg-thinq.0 (1152227) setObject fd80ae07-21ef-18c3-bd4c-44cb8b63456e.remote.wDirCtrl.hStep (type=state) property common.role missing!
    2024-01-07 12:11:56.938 - warn: lg-thinq.0 (1152227) setObject fd80ae07-21ef-18c3-bd4c-44cb8b63456e.remote.qualityMngCtrl.sensorMon (type=state) property common.role missing!
    2024-01-07 12:11:56.939 - warn: lg-thinq.0 (1152227) setObject fd80ae07-21ef-18c3-bd4c-44cb8b63456e.remote.basicCtrl.target (type=state) property common.role missing!
    2024-01-07 12:11:56.939 - warn: lg-thinq.0 (1152227) setObject fd80ae07-21ef-18c3-bd4c-44cb8b63456e.remote.basicCtrl.operation (type=state) property common.role missing!
    2024-01-07 12:11:56.940 - warn: lg-thinq.0 (1152227) setObject fd80ae07-21ef-18c3-bd4c-44cb8b63456e.remote.wDirCtrl.vStep (type=state) property common.role missing!
    2024-01-07 12:11:56.943 - warn: lg-thinq.0 (1152227) setObject fd80ae07-21ef-18c3-bd4c-44cb8b63456e.remote.settingInfo.basic (type=state) property common.role missing!
    2024-01-07 12:11:56.945 - warn: lg-thinq.0 (1152227) setObject fd80ae07-21ef-18c3-bd4c-44cb8b63456e.remote.settingInfo.autoDry (type=state) property common.role missing!
    2024-01-07 12:11:56.946 - warn: lg-thinq.0 (1152227) setObject fd80ae07-21ef-18c3-bd4c-44cb8b63456e.remote.basicCtrl.opMode (type=state) property common.role missing!
    2024-01-07 12:12:02.112 - info: lg-thinq.0 (1152227) Update raw datapoints for fd80ae07-21ef-18c3-bd4c-44cb8b63456e
    2024-01-07 12:12:03.006 - info: lg-thinq.0 (1152227) Found MQTT Host
    2024-01-07 12:12:03.103 - info: lg-thinq.0 (1152227) Found AWS CER
    2024-01-07 12:12:03.742 - info: lg-thinq.0 (1152227) Create certification done
    2024-01-07 12:12:04.041 - info: lg-thinq.0 (1152227) Start MQTT Connection
    2024-01-07 12:12:04.571 - info: lg-thinq.0 (1152227) MQTT connected to: t20/op/b10dc87ae5e62b453822886bad2bc820cbffdf1d8ef833c2a2b862cdb104d59b/inbox
    2024-01-07 12:12:10.066 - info: lg-thinq.0 (1152227) WRONG WORKLIST: []
    2024-01-07 12:12:10.067 - info: lg-thinq.0 (1152227) WRONG WORKLIST RESULT: {"returnCd":"0000","returnMsg":"OK","workList":{"deviceId":"d27d1380-7149-11d3-80b8-2c2bf9760c6d","deviceState":"E","format":"B64","returnCode":"0000","returnData":"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","stateCode":"S","workId":"n-d27d1380-7149-11d3-80b8-2c2bf9760c6d"}}
    2024-01-07 12:12:15.100 - info: lg-thinq.0 (1152227) WRONG WORKLIST: []
    2024-01-07 12:12:15.101 - info: lg-thinq.0 (1152227) WRONG WORKLIST RESULT: {"returnCd":"0000","returnMsg":"OK","workList":{"deviceId":"d27d1380-7149-11d3-80b8-2c2bf9760c6d","deviceState":"E","format":"B64","returnCode":"0000","returnData":"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","stateCode":"S","workId":"n-d27d1380-7149-11d3-80b8-2c2bf9760c6d"}}
    2024-01-07 12:12:20.075 - info: lg-thinq.0 (1152227) WRONG WORKLIST: []
    2024-01-07 12:12:20.076 - info: lg-thinq.0 (1152227) WRONG WORKLIST RESULT: {"returnCd":"0000","returnMsg":"OK","workList":{"deviceId":"d27d1380-7149-11d3-80b8-2c2bf9760c6d","deviceState":"E","format":"B64","returnCode":"0000","returnData":"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","stateCode":"S","workId":"n-d27d1380-7149-11d3-80b8-2c2bf9760c6d"}}
    2024-01-07 12:12:25.134 - info: lg-thinq.0 (1152227) WRONG WORKLIST: []
    2024-01-07 12:12:25.134 - info: lg-thinq.0 (1152227) WRONG WORKLIST RESULT: {"returnCd":"0000","returnMsg":"OK","workList":{"deviceId":"d27d1380-7149-11d3-80b8-2c2bf9760c6d","deviceState":"E","format":"B64","returnCode":"0000","returnData":"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","stateCode":"S","workId":"n-d27d1380-7149-11d3-80b8-2c2bf9760c6d"}}
    2024-01-07 12:12:30.139 - info: lg-thinq.0 (1152227) WRONG WORKLIST: []
    2024-01-07 12:12:30.139 - info: lg-thinq.0 (1152227) WRONG WORKLIST RESULT: {"returnCd":"0000","returnMsg":"OK","workList":{"deviceId":"d27d1380-7149-11d3-80b8-2c2bf9760c6d","deviceState":"E","format":"B64","returnCode":"0000","returnData":"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","stateCode":"S","workId":"n-d27d1380-7149-11d3-80b8-2c2bf9760c6d"}}
    2024-01-07 12:12:35.080 - info: lg-thinq.0 (1152227) WRONG WORKLIST: []
    2024-01-07 12:12:35.081 - info: lg-thinq.0 (1152227) WRONG WORKLIST RESULT: {"returnCd":"0000","returnMsg":"OK","workList":{"deviceId":"d27d1380-7149-11d3-80b8-2c2bf9760c6d","deviceState":"E","format":"B64","returnCode":"0000","returnData":"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","stateCode":"S","workId":"n-d27d1380-7149-11d3-80b8-2c2bf9760c6d"}}
    2024-01-07 12:12:40.128 - info: lg-thinq.0 (1152227) WRONG WORKLIST: []
    2024-01-07 12:12:40.129 - info: lg-thinq.0 (1152227) WRONG WORKLIST RESULT: {"returnCd":"0000","returnMsg":"OK","workList":{"deviceId":"d27d1380-7149-11d3-80b8-2c2bf9760c6d","deviceState":"E","format":"B64","returnCode":"0000","returnData":"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","stateCode":"S","workId":"n-d27d1380-7149-11d3-80b8-2c2bf9760c6d"}}
    2024-01-07 12:12:45.069 - info: lg-thinq.0 (1152227) WRONG WORKLIST: []
    2024-01-07 12:12:45.070 - info: lg-thinq.0 (1152227) WRONG WORKLIST RESULT: {"returnCd":"0000","returnMsg":"OK","workList":{"deviceId":"d27d1380-7149-11d3-80b8-2c2bf9760c6d","deviceState":"E","format":"B64","returnCode":"0000","returnData":"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","stateCode":"S","workId":"n-d27d1380-7149-11d3-80b8-2c2bf9760c6d"}}
    L 1 Antwort Letzte Antwort
    • ofri2607O ofri2607
      @lucky_esa
      L Online
      L Online
      Lucky_ESA
      #430
      @ofri2607 Bitte mal 2 Minuten warten und dann erneut vom GIT laden.
      Gruß//Lucky
      ofri2607O 1 Antwort Letzte Antwort
      • L Lucky_ESA
        Gruß//Lucky
        ofri2607O Online
        ofri2607O Online
        ofri2607
        #431
        @lucky_esa
        Sieht, denke ich an sich ganz gut aus und der Datenpunkt lg-thinq.0.interval.last_update wird auch alle 5 Sekunden aktualisiert.
        Log sieht ab dem Start so aus - schreibt jetzt alle 5 Sekunden die Einträge Length, Array und TypeOf
        2024-01-07 13:08:48.786 - info: lg-thinq.0 (1157199) starting. Version 0.3.1 (non-npm: TA2k/ioBroker.lg-thinq) in /opt/iobroker/node_modules/iobroker.lg-thinq, node: v18.19.0, js-controller: 5.0.17
        2024-01-07 13:08:51.056 - info: lg-thinq.0 (1157199) Login successful
        2024-01-07 13:08:53.420 - info: lg-thinq.0 (1157199) Found: 3 devices
        2024-01-07 13:08:53.421 - info: lg-thinq.0 (1157199) Create or update datapoints for d27d1380-7149-11d3-80b8-2c2bf9760c6d
        2024-01-07 13:09:06.975 - info: lg-thinq.0 (1157199) Update raw datapoints for d27d1380-7149-11d3-80b8-2c2bf9760c6d
        2024-01-07 13:09:07.444 - info: lg-thinq.0 (1157199) Create or update datapoints for dfbdfc44-8efb-148a-acc9-44cb8b32f2ea
        2024-01-07 13:09:07.596 - warn: lg-thinq.0 (1157199) setObject dfbdfc44-8efb-148a-acc9-44cb8b32f2ea.remote.basicCtrl.windStrength (type=state) property common.role missing!
        2024-01-07 13:09:07.599 - warn: lg-thinq.0 (1157199) setObject dfbdfc44-8efb-148a-acc9-44cb8b32f2ea.remote.wDirCtrl.hStep (type=state) property common.role missing!
        2024-01-07 13:09:07.600 - warn: lg-thinq.0 (1157199) setObject dfbdfc44-8efb-148a-acc9-44cb8b32f2ea.remote.qualityMngCtrl.sensorMon (type=state) property common.role missing!
        2024-01-07 13:09:07.601 - warn: lg-thinq.0 (1157199) setObject dfbdfc44-8efb-148a-acc9-44cb8b32f2ea.remote.basicCtrl.target (type=state) property common.role missing!
        2024-01-07 13:09:07.602 - warn: lg-thinq.0 (1157199) setObject dfbdfc44-8efb-148a-acc9-44cb8b32f2ea.remote.basicCtrl.operation (type=state) property common.role missing!
        2024-01-07 13:09:07.603 - warn: lg-thinq.0 (1157199) setObject dfbdfc44-8efb-148a-acc9-44cb8b32f2ea.remote.wDirCtrl.vStep (type=state) property common.role missing!
        2024-01-07 13:09:07.615 - warn: lg-thinq.0 (1157199) setObject dfbdfc44-8efb-148a-acc9-44cb8b32f2ea.remote.settingInfo.basic (type=state) property common.role missing!
        2024-01-07 13:09:07.615 - warn: lg-thinq.0 (1157199) setObject dfbdfc44-8efb-148a-acc9-44cb8b32f2ea.remote.settingInfo.autoDry (type=state) property common.role missing!
        2024-01-07 13:09:07.617 - warn: lg-thinq.0 (1157199) setObject dfbdfc44-8efb-148a-acc9-44cb8b32f2ea.remote.basicCtrl.opMode (type=state) property common.role missing!
        2024-01-07 13:09:12.760 - info: lg-thinq.0 (1157199) Update raw datapoints for dfbdfc44-8efb-148a-acc9-44cb8b32f2ea
        2024-01-07 13:09:13.227 - info: lg-thinq.0 (1157199) Create or update datapoints for fd80ae07-21ef-18c3-bd4c-44cb8b63456e
        2024-01-07 13:09:13.273 - warn: lg-thinq.0 (1157199) setObject fd80ae07-21ef-18c3-bd4c-44cb8b63456e.remote.basicCtrl.windStrength (type=state) property common.role missing!
        2024-01-07 13:09:13.275 - warn: lg-thinq.0 (1157199) setObject fd80ae07-21ef-18c3-bd4c-44cb8b63456e.remote.wDirCtrl.hStep (type=state) property common.role missing!
        2024-01-07 13:09:13.276 - warn: lg-thinq.0 (1157199) setObject fd80ae07-21ef-18c3-bd4c-44cb8b63456e.remote.qualityMngCtrl.sensorMon (type=state) property common.role missing!
        2024-01-07 13:09:13.279 - warn: lg-thinq.0 (1157199) setObject fd80ae07-21ef-18c3-bd4c-44cb8b63456e.remote.basicCtrl.target (type=state) property common.role missing!
        2024-01-07 13:09:13.280 - warn: lg-thinq.0 (1157199) setObject fd80ae07-21ef-18c3-bd4c-44cb8b63456e.remote.basicCtrl.operation (type=state) property common.role missing!
        2024-01-07 13:09:13.281 - warn: lg-thinq.0 (1157199) setObject fd80ae07-21ef-18c3-bd4c-44cb8b63456e.remote.wDirCtrl.vStep (type=state) property common.role missing!
        2024-01-07 13:09:13.282 - warn: lg-thinq.0 (1157199) setObject fd80ae07-21ef-18c3-bd4c-44cb8b63456e.remote.settingInfo.basic (type=state) property common.role missing!
        2024-01-07 13:09:13.282 - warn: lg-thinq.0 (1157199) setObject fd80ae07-21ef-18c3-bd4c-44cb8b63456e.remote.settingInfo.autoDry (type=state) property common.role missing!
        2024-01-07 13:09:13.283 - warn: lg-thinq.0 (1157199) setObject fd80ae07-21ef-18c3-bd4c-44cb8b63456e.remote.basicCtrl.opMode (type=state) property common.role missing!
        2024-01-07 13:09:18.336 - info: lg-thinq.0 (1157199) Update raw datapoints for fd80ae07-21ef-18c3-bd4c-44cb8b63456e
        2024-01-07 13:09:18.901 - info: lg-thinq.0 (1157199) Found MQTT Host
        2024-01-07 13:09:18.976 - info: lg-thinq.0 (1157199) Found AWS CER
        2024-01-07 13:09:19.834 - info: lg-thinq.0 (1157199) Create certification done
        2024-01-07 13:09:20.102 - info: lg-thinq.0 (1157199) Start MQTT Connection
        2024-01-07 13:09:20.540 - info: lg-thinq.0 (1157199) MQTT connected to: t20/op/fecc8c25e098a918b7b40ae14c6d9fbe43a481afaf1afcdcea5e38410861c646/inbox
        2024-01-07 13:09:26.083 - info: lg-thinq.0 (1157199) Length: 7
        2024-01-07 13:09:26.083 - info: lg-thinq.0 (1157199) Array: false
        2024-01-07 13:09:26.083 - info: lg-thinq.0 (1157199) Typeof: object
        2024-01-07 13:09:31.068 - info: lg-thinq.0 (1157199) Length: 7
        2024-01-07 13:09:31.068 - info: lg-thinq.0 (1157199) Array: false
        2024-01-07 13:09:31.069 - info: lg-thinq.0 (1157199) Typeof: object
        2024-01-07 13:09:36.049 - info: lg-thinq.0 (1157199) Length: 7
        2024-01-07 13:09:36.049 - info: lg-thinq.0 (1157199) Array: false
        2024-01-07 13:09:36.050 - info: lg-thinq.0 (1157199) Typeof: object
        2024-01-07 13:09:41.011 - info: lg-thinq.0 (1157199) Length: 7
        2024-01-07 13:09:41.012 - info: lg-thinq.0 (1157199) Array: false
        2024-01-07 13:09:41.013 - info: lg-thinq.0 (1157199) Typeof: object
        2024-01-07 13:09:46.010 - info: lg-thinq.0 (1157199) Length: 7
        2024-01-07 13:09:46.011 - info: lg-thinq.0 (1157199) Array: false
        2024-01-07 13:09:46.012 - info: lg-thinq.0 (1157199) Typeof: object
        2024-01-07 13:09:51.004 - info: lg-thinq.0 (1157199) Length: 7
        2024-01-07 13:09:51.004 - info: lg-thinq.0 (1157199) Array: false
        2024-01-07 13:09:51.005 - info: lg-thinq.0 (1157199) Typeof: object
        2024-01-07 13:09:56.010 - info: lg-thinq.0 (1157199) Length: 7
        2024-01-07 13:09:56.011 - info: lg-thinq.0 (1157199) Array: false
        2024-01-07 13:09:56.011 - info: lg-thinq.0 (1157199) Typeof: object
        2024-01-07 13:10:01.028 - info: lg-thinq.0 (1157199) Length: 7
        2024-01-07 13:10:01.029 - info: lg-thinq.0 (1157199) Array: false
        2024-01-07 13:10:01.029 - info: lg-thinq.0 (1157199) Typeof: object
        2024-01-07 13:10:05.997 - info: lg-thinq.0 (1157199) Length: 7
        2024-01-07 13:10:05.997 - info: lg-thinq.0 (1157199) Array: false
        2024-01-07 13:10:05.998 - info: lg-thinq.0 (1157199) Typeof: object
        2024-01-07 13:10:11.018 - info: lg-thinq.0 (1157199) Length: 7
        2024-01-07 13:10:11.019 - info: lg-thinq.0 (1157199) Array: false
        2024-01-07 13:10:11.020 - info: lg-thinq.0 (1157199) Typeof: object
        2024-01-07 13:10:16.084 - info: lg-thinq.0 (1157199) Length: 7
        2024-01-07 13:10:16.084 - info: lg-thinq.0 (1157199) Array: false
        2024-01-07 13:10:16.085 - info: lg-thinq.0 (1157199) Typeof: object
        2024-01-07 13:10:21.015 - info: lg-thinq.0 (1157199) Length: 7
        2024-01-07 13:10:21.016 - info: lg-thinq.0 (1157199) Array: false
        2024-01-07 13:10:21.016 - info: lg-thinq.0 (1157199) Typeof: object
        2024-01-07 13:10:26.006 - info: lg-thinq.0 (1157199) Length: 7
        2024-01-07 13:10:26.007 - info: lg-thinq.0 (1157199) Array: false
        2024-01-07 13:10:26.008 - info: lg-thinq.0 (1157199) Typeof: object
        2024-01-07 13:10:31.013 - info: lg-thinq.0 (1157199) Length: 7
        2024-01-07 13:10:31.013 - info: lg-thinq.0 (1157199) Array: false
        2024-01-07 13:10:31.013 - info: lg-thinq.0 (1157199) Typeof: object
        2024-01-07 13:10:36.022 - info: lg-thinq.0 (1157199) Length: 7
        2024-01-07 13:10:36.022 - info: lg-thinq.0 (1157199) Array: false
        2024-01-07 13:10:36.023 - info: lg-thinq.0 (1157199) Typeof: object
        2024-01-07 13:10:41.011 - info: lg-thinq.0 (1157199) Length: 7
        2024-01-07 13:10:41.012 - info: lg-thinq.0 (1157199) Array: false
        2024-01-07 13:10:41.013 - info: lg-thinq.0 (1157199) Typeof: object
          @lucky_esa
          L Online
          L Online
          Lucky_ESA
          #432
          @ofri2607 Ups, vergessen die Logs zu löschen. Habe ich gerade neu auf dem GIT geladen.
          • L Lucky_ESA
            ofri2607O Online
            ofri2607O Online
            ofri2607
            #433
            @lucky_esa
            Alles gut :-) hole ich mir dann gleich.
            Die warn-Meldung zum setObject bei den thinq2 Geräten, denke ich, ist an sich unkritisch, oder?
              @lucky_esa
              L Online
              L Online
              Lucky_ESA
              #434
              @ofri2607 sagte in Test Adapter LG ThinQ v0.0.1:
              @lucky_esa
              Ist kritisch. Muss da mal schauen.
              • L Lucky_ESA
                @lucky_esa
                ofri2607O Online
                ofri2607O Online
                ofri2607
                #435
                @lucky_esa
                Letzte GIT Version geholt und läuft :-) … mit den o.a. Warn-Meldungen zum setobject.
                Herzlichen Dank für deine schnelle Lösung!
                2024-01-07 13:26:54.283 - info: lg-thinq.0 (1158883) starting. Version 0.3.1 (non-npm: TA2k/ioBroker.lg-thinq) in /opt/iobroker/node_modules/iobroker.lg-thinq, node: v18.19.0, js-controller: 5.0.17
                2024-01-07 13:26:56.802 - info: lg-thinq.0 (1158883) Login successful
                2024-01-07 13:26:59.210 - info: lg-thinq.0 (1158883) Found: 3 devices
                2024-01-07 13:26:59.213 - info: lg-thinq.0 (1158883) Create or update datapoints for d27d1380-7149-11d3-80b8-2c2bf9760c6d
                2024-01-07 13:27:13.092 - info: lg-thinq.0 (1158883) Update raw datapoints for d27d1380-7149-11d3-80b8-2c2bf9760c6d
                2024-01-07 13:27:13.587 - info: lg-thinq.0 (1158883) Create or update datapoints for dfbdfc44-8efb-148a-acc9-44cb8b32f2ea
                2024-01-07 13:27:13.729 - warn: lg-thinq.0 (1158883) setObject dfbdfc44-8efb-148a-acc9-44cb8b32f2ea.remote.basicCtrl.windStrength (type=state) property common.role missing!
                2024-01-07 13:27:13.731 - warn: lg-thinq.0 (1158883) setObject dfbdfc44-8efb-148a-acc9-44cb8b32f2ea.remote.wDirCtrl.hStep (type=state) property common.role missing!
                2024-01-07 13:27:13.735 - warn: lg-thinq.0 (1158883) setObject dfbdfc44-8efb-148a-acc9-44cb8b32f2ea.remote.qualityMngCtrl.sensorMon (type=state) property common.role missing!
                2024-01-07 13:27:13.737 - warn: lg-thinq.0 (1158883) setObject dfbdfc44-8efb-148a-acc9-44cb8b32f2ea.remote.basicCtrl.target (type=state) property common.role missing!
                2024-01-07 13:27:13.738 - warn: lg-thinq.0 (1158883) setObject dfbdfc44-8efb-148a-acc9-44cb8b32f2ea.remote.basicCtrl.operation (type=state) property common.role missing!
                2024-01-07 13:27:13.739 - warn: lg-thinq.0 (1158883) setObject dfbdfc44-8efb-148a-acc9-44cb8b32f2ea.remote.wDirCtrl.vStep (type=state) property common.role missing!
                2024-01-07 13:27:13.741 - warn: lg-thinq.0 (1158883) setObject dfbdfc44-8efb-148a-acc9-44cb8b32f2ea.remote.settingInfo.basic (type=state) property common.role missing!
                2024-01-07 13:27:13.742 - warn: lg-thinq.0 (1158883) setObject dfbdfc44-8efb-148a-acc9-44cb8b32f2ea.remote.settingInfo.autoDry (type=state) property common.role missing!
                2024-01-07 13:27:13.743 - warn: lg-thinq.0 (1158883) setObject dfbdfc44-8efb-148a-acc9-44cb8b32f2ea.remote.basicCtrl.opMode (type=state) property common.role missing!
                2024-01-07 13:27:18.835 - info: lg-thinq.0 (1158883) Update raw datapoints for dfbdfc44-8efb-148a-acc9-44cb8b32f2ea
                2024-01-07 13:27:19.181 - info: lg-thinq.0 (1158883) Create or update datapoints for fd80ae07-21ef-18c3-bd4c-44cb8b63456e
                2024-01-07 13:27:19.226 - warn: lg-thinq.0 (1158883) setObject fd80ae07-21ef-18c3-bd4c-44cb8b63456e.remote.basicCtrl.windStrength (type=state) property common.role missing!
                2024-01-07 13:27:19.227 - warn: lg-thinq.0 (1158883) setObject fd80ae07-21ef-18c3-bd4c-44cb8b63456e.remote.wDirCtrl.hStep (type=state) property common.role missing!
                2024-01-07 13:27:19.227 - warn: lg-thinq.0 (1158883) setObject fd80ae07-21ef-18c3-bd4c-44cb8b63456e.remote.qualityMngCtrl.sensorMon (type=state) property common.role missing!
                2024-01-07 13:27:19.228 - warn: lg-thinq.0 (1158883) setObject fd80ae07-21ef-18c3-bd4c-44cb8b63456e.remote.basicCtrl.target (type=state) property common.role missing!
                2024-01-07 13:27:19.228 - warn: lg-thinq.0 (1158883) setObject fd80ae07-21ef-18c3-bd4c-44cb8b63456e.remote.basicCtrl.operation (type=state) property common.role missing!
                2024-01-07 13:27:19.228 - warn: lg-thinq.0 (1158883) setObject fd80ae07-21ef-18c3-bd4c-44cb8b63456e.remote.wDirCtrl.vStep (type=state) property common.role missing!
                2024-01-07 13:27:19.229 - warn: lg-thinq.0 (1158883) setObject fd80ae07-21ef-18c3-bd4c-44cb8b63456e.remote.settingInfo.basic (type=state) property common.role missing!
                2024-01-07 13:27:19.229 - warn: lg-thinq.0 (1158883) setObject fd80ae07-21ef-18c3-bd4c-44cb8b63456e.remote.settingInfo.autoDry (type=state) property common.role missing!
                2024-01-07 13:27:19.230 - warn: lg-thinq.0 (1158883) setObject fd80ae07-21ef-18c3-bd4c-44cb8b63456e.remote.basicCtrl.opMode (type=state) property common.role missing!
                2024-01-07 13:27:24.468 - info: lg-thinq.0 (1158883) Update raw datapoints for fd80ae07-21ef-18c3-bd4c-44cb8b63456e
                2024-01-07 13:27:24.992 - info: lg-thinq.0 (1158883) Found MQTT Host
                2024-01-07 13:27:25.076 - info: lg-thinq.0 (1158883) Found AWS CER
                2024-01-07 13:27:25.698 - info: lg-thinq.0 (1158883) Create certification done
                2024-01-07 13:27:25.970 - info: lg-thinq.0 (1158883) Start MQTT Connection
                2024-01-07 13:27:26.421 - info: lg-thinq.0 (1158883) MQTT connected to: t20/op/c506395e26728fd0340f7cf4a8e263719ced9d1b9effe7df9ec6d374156ea85c/inbox
                  @lucky_esa
                  L Online
                  L Online
                  Lucky_ESA
                  #436
                  @ofri2607 Der Fehler sollte nun auch behoben sein. Hab es gerade erst auf dem GIT geschoben daher mal 2 Minuten warten.
                  • L Lucky_ESA
                    ofri2607O Online
                    ofri2607O Online
                    ofri2607
                    #437
                    @lucky_esa
                    Läuft ruhig durch - ohne eine warn-Meldung 👍
                    Nochmals herzlichen Dank für deine schnelle Lösung und noch einen schönen Sonntag.
                      @lucky_esa
                      L Online
                      L Online
                      Lucky_ESA
                      #438
                      @ofri2607 Kannst du eventuell noch mal vom GIT laden. Hab noch was geändert um mehr Info anzuzeigen. Leider weiß ich nicht was die Fehlermeldung 0100 bedeutet aber die Werte werden trotzdem aktualisiert.
                      • interval.status_devices
                        • OK: Intervall OK
                        • Fail; Intervall Fail (Fehlermeldung 0100)
                        • Error: Fehlende WorkID - WorkID wird neu erstellt
                        • Error <code>: Unbekannter Fehler - WorkID wird neu erstellt
                      Gruß//Lucky
                      • L Lucky_ESA
                          • OK: Intervall OK
                        Gruß//Lucky
                        ofri2607O Online
                        ofri2607O Online
                        ofri2607
                        schrieb am zuletzt editiert von ofri2607
                        #439
                        @lucky_esa
                        Ist installiert und läuft.
                        Der neue Datenpunkt wurde als json mit dem Inhalt
                        {"d27d1380-7149-11d3-80b8-2c2bf9760c6d":"OK"}
                        angelegt.
                        Edit: gerade erste gesehen, der Adapter ist jetzt auf v0.3.2
                          @lucky_esa
                          angelegt.
                          L Online
                          L Online
                          Lucky_ESA
                          #440
                          @lucky_esa
                          angelegt.
                          Ja, musste jetzt schnell ein Release nachschieben da die Version 0.3.1 bei thinq1 User crasht. Da ich kein Thinq1 Geräte habe muss ich immer ein wenig vermuten.
                          • L Lucky_ESA
                            @lucky_esa
                            angelegt.
                            ofri2607O Online
                            ofri2607O Online
                            ofri2607
                            #441
                            @Lucky_ESA
                            Guten Morgen,
                            folgende Einträge hatte ich heute in unregelmäßigen Abständen im Log:
                            2024-01-08 23:00:17.622 - error: lg-thinq.0 (1325489) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                            2024-01-08 23:00:17.633 - error: lg-thinq.0 (1325489) unhandled promise rejection: undefined is not a valid state value
                            2024-01-08 23:00:17.951 - error: lg-thinq.0 (1325489) Error: undefined is not a valid state value
                            at Object.maybeCallbackWithError (/opt/iobroker/node_modules/@iobroker/js-controller-common/src/lib/common/maybeCallback.ts:136:17)
                            at LgThinq._setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:7593:26)
                            at LgThinq.setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:7551:21)
                            at LgThinq.setThinq1Interval (/opt/iobroker/node_modules/iobroker.lg-thinq/main.js:467:18)
                            at /opt/iobroker/node_modules/iobroker.lg-thinq/main.js:369:22
                            at processTicksAndRejections (node:internal/process/task_queues:95:5)
                            2024-01-08 23:00:17.952 - error: lg-thinq.0 (1325489) undefined is not a valid state value
                            2024-01-08 23:00:18.514 - info: lg-thinq.0 (1325489) terminating
                            2024-01-08 23:00:18.516 - warn: lg-thinq.0 (1325489) Terminated (UNCAUGHT_EXCEPTION): Without reason
                            2024-01-08 23:00:18.558 - info: lg-thinq.0 (1325489) terminating
                            2024-01-08 23:00:19.134 - error: host.raspberrypi Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                            2024-01-08 23:00:19.134 - error: host.raspberrypi Caught by controller[1]: Error: undefined is not a valid state value
                            2024-01-08 23:00:19.135 - error: host.raspberrypi Caught by controller[1]: at Object.maybeCallbackWithError (/opt/iobroker/node_modules/@iobroker/js-controller-common/src/lib/common/maybeCallback.ts:136:17)
                            2024-01-08 23:00:19.135 - error: host.raspberrypi Caught by controller[1]: at LgThinq._setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:7593:26)
                            2024-01-08 23:00:19.135 - error: host.raspberrypi Caught by controller[1]: at LgThinq.setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:7551:21)
                            2024-01-08 23:00:19.135 - error: host.raspberrypi Caught by controller[1]: at LgThinq.setThinq1Interval (/opt/iobroker/node_modules/iobroker.lg-thinq/main.js:467:18)
                            2024-01-08 23:00:19.135 - error: host.raspberrypi Caught by controller[1]: at /opt/iobroker/node_modules/iobroker.lg-thinq/main.js:369:22
                            2024-01-08 23:00:19.135 - error: host.raspberrypi Caught by controller[1]: at processTicksAndRejections (node:internal/process/task_queues:95:5)
                            2024-01-08 23:00:19.135 - error: host.raspberrypi instance system.adapter.lg-thinq.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                            2024-01-08 23:00:19.135 - info: host.raspberrypi Restart adapter system.adapter.lg-thinq.0 because enabled
                            2024-01-08 23:00:49.233 - info: host.raspberrypi instance system.adapter.lg-thinq.0 started with pid 1327629
                            2024-01-08 23:00:52.448 - info: lg-thinq.0 (1327629) starting. Version 0.3.2 (non-npm: TA2k/ioBroker.lg-thinq) in /opt/iobroker/node_modules/iobroker.lg-thinq, node: v18.19.0, js-controller: 5.0.17
                            2024-01-08 23:00:54.140 - info: lg-thinq.0 (1327629) Login successful
                            2024-01-08 23:00:58.992 - info: lg-thinq.0 (1327629) Found: 3 devices
                            2024-01-08 23:00:58.993 - info: lg-thinq.0 (1327629) Create or update datapoints for d27d1380-7149-11d3-80b8-2c2bf9760c6d
                            2024-01-08 23:01:14.671 - info: lg-thinq.0 (1327629) Update raw datapoints for d27d1380-7149-11d3-80b8-2c2bf9760c6d
                            2024-01-08 23:01:15.229 - info: lg-thinq.0 (1327629) Create or update datapoints for dfbdfc44-8efb-148a-acc9-44cb8b32f2ea
                            2024-01-08 23:01:20.776 - info: lg-thinq.0 (1327629) Update raw datapoints for dfbdfc44-8efb-148a-acc9-44cb8b32f2ea
                            2024-01-08 23:01:21.503 - info: lg-thinq.0 (1327629) Create or update datapoints for fd80ae07-21ef-18c3-bd4c-44cb8b63456e
                            2024-01-08 23:01:26.808 - info: lg-thinq.0 (1327629) Update raw datapoints for fd80ae07-21ef-18c3-bd4c-44cb8b63456e
                            2024-01-08 23:01:27.936 - info: lg-thinq.0 (1327629) Found MQTT Host
                            2024-01-08 23:01:28.026 - info: lg-thinq.0 (1327629) Found AWS CER
                            2024-01-08 23:01:28.678 - info: lg-thinq.0 (1327629) Create certification done
                            2024-01-08 23:01:29.117 - info: lg-thinq.0 (1327629) Start MQTT Connection
                            2024-01-08 23:01:29.647 - info: lg-thinq.0 (1327629) MQTT connected to: t20/op/7e0548ce9ab409359f1393e34f2529773cfe35ff338479a1d21060cdbe7d4db2/inbox
                            Es ist keine eindeutige Zeitabfolge erkennbar, war aber von gestern nach der Installation der v0.3.2 bis heute insgesamt 5 mal, zuletzt heute um 1:43:13.
                              @Lucky_ESA
                              Guten Morgen,
                              L Online
                              L Online
                              Lucky_ESA
                              #442
                              @Lucky_ESA
                              Guten Morgen,
                              OK, danke für die Info. Habe auf dem GIT den Fehler behoben. Dann konnte ca. 5 x keine Daten geholt werden. Das ist super und wahrscheinlich kommt noch die Zwangstrennung dazu.
                              Kannst du bitte vom GIT laden und weiter testen. Besteht die Möglichkeit das du ein Blockly erstellt was den DP interval.status_devices triggert und bei Änderungen ein Logeintrag erstellt.
                              Gruß//Lucky
                              ofri2607O 2 Antworten Letzte Antwort
                              • L Lucky_ESA
                                @Lucky_ESA
                                Guten Morgen,
                                Gruß//Lucky
                                ofri2607O Online
                                ofri2607O Online
                                ofri2607
                                #443
                                @lucky_esa
                                Servus, ja kann ich gerne machen, geht aber erst heute am Abend.
                                Blockly jetzt nicht so, mache das dann über JS.
                                • L Lucky_ESA
                                  @Lucky_ESA
                                  Guten Morgen,
                                  Gruß//Lucky
                                  ofri2607O Online
                                  ofri2607O Online
                                  ofri2607
                                  #444
                                  @lucky_esa
                                  Ist installiert, läuft und Skript mit Trigger vom Datenpunkt läuft auch.
                                  Ich lasse es mal über die Nacht durchlaufen und stelle dir dann morgen das Ergebnis der Logausgaben vom Skript ein.
                                    @lucky_esa
                                    L Online
                                    L Online
                                    Lucky_ESA
                                    #445
                                    @lucky_esa
                                    Super, vielen Dank.
                                    Gruß//Lucky
                                    • L Lucky_ESA
                                      @lucky_esa
                                      Super, vielen Dank.
                                      Gruß//Lucky
                                      ofri2607O Online
                                      ofri2607O Online
                                      ofri2607
                                      #446
                                      @lucky_esa
                                      Hier mal die ersten Ausgaben vom Log des Skripts …
                                      javascript.3
                                      2024-01-09 21:15:44.759	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"OK\"}"(alter Wert war "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Fail\"}")
                                      javascript.3
                                      2024-01-09 21:15:40.217	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Fail\"}"(alter Wert war "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"OK\"}")
                                      javascript.3
                                      2024-01-09 20:45:19.725	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"OK\"}"(alter Wert war "{}")
                                      javascript.3
                                      2024-01-09 20:45:17.951	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{}"(alter Wert war "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"OK\"}")
                                      javascript.3
                                      2024-01-09 20:17:39.501	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"OK\"}"(alter Wert war "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Error - undefined\"}")
                                      javascript.3
                                      2024-01-09 20:17:19.881	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Error - undefined\"}"(alter Wert war "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Fail\"}")
                                      javascript.3
                                      2024-01-09 20:17:14.957	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Fail\"}"(alter Wert war "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"OK\"}")
                                      javascript.3
                                      2024-01-09 20:03:04.792	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"OK\"}"(alter Wert war "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Fail\"}")
                                      javascript.3
                                      2024-01-09 20:03:00.409	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Fail\"}"(alter Wert war "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"OK\"}")
                                      javascript.3
                                      2024-01-09 19:15:47.479	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                                        @lucky_esa
                                        javascript.3
                                        javascript.3
                                        javascript.3
                                        javascript.3
                                        javascript.3
                                        javascript.3
                                        javascript.3
                                        javascript.3
                                        javascript.3
                                        javascript.3
                                        L Online
                                        L Online
                                        Lucky_ESA
                                        #447
                                        @ofri2607 Das sieht doch recht gut aus. Bei "Fail" kommen trotzdem Daten und es wechselt dann auch wieder auf "OK".
                                        Gruß//Lucky
                                        • L Lucky_ESA
                                          Gruß//Lucky
                                          ofri2607O Online
                                          ofri2607O Online
                                          ofri2607
                                          #448
                                          @lucky_esa
                                          Das habe ich mir auch gedacht, tut so wie es soll 👍
                                          Was ich mich gefragt habe, ist warum hin und wieder ein leerer Eintrag im json da ist?
                                          Über die Nacht ist es vergleichbar weitergelaufen, da war auch eine Zwangstrennung durch meinen Internetprovider dabei, die hat es auch problemlos gemeistert, siehe ...
                                          javascript.3
                                          2024-01-10 06:59:18.890	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"OK\"}"(alter Wert war "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Error - undefined\"}")
                                          javascript.3
                                          2024-01-10 06:59:09.050	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Error - undefined\"}"(alter Wert war "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"OK\"}")
                                          javascript.3
                                          2024-01-10 06:00:53.338	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"OK\"}"(alter Wert war "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Fail\"}")
                                          javascript.3
                                          2024-01-10 06:00:49.114	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Fail\"}"(alter Wert war "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"OK\"}")
                                          javascript.3
                                          2024-01-10 05:03:02.938	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"OK\"}"(alter Wert war "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Fail\"}")
                                          javascript.3
                                          2024-01-10 05:02:58.308	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Fail\"}"(alter Wert war "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"OK\"}")
                                          javascript.3
                                          2024-01-10 04:03:57.614	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"OK\"}"(alter Wert war "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Error - undefined\"}")
                                          javascript.3
                                          2024-01-10 04:03:47.989	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Error - undefined\"}"(alter Wert war "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Fail\"}")
                                          javascript.3
                                          2024-01-10 04:03:42.989	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Fail\"}"(alter Wert war "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"OK\"}")
                                          lg-thinq.0
                                          2024-01-10 03:52:06.773	info	MQTT connected to: t20/op/d6dd60f0475926a7f83dd2cacbcf6c92eddb8512492affc08b1a36fa323fe8be/inbox
                                          lg-thinq.0
                                          2024-01-10 03:52:06.501	info	Thinq MQTT reconnect
                                          javascript.3
                                          2024-01-10 03:51:47.800	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"OK\"}"(alter Wert war "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Error - undefined\"}")
                                          javascript.3
                                          2024-01-10 03:51:42.933	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Error - undefined\"}"(alter Wert war "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Error\"}")
                                          javascript.3
                                          2024-01-10 03:51:32.747	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Error\"}"(alter Wert war "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Error - 0106\"}")
                                          javascript.3
                                          2024-01-10 03:51:30.175	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Error - 0106\"}"(alter Wert war "{}")
                                          javascript.3
                                          2024-01-10 03:38:58.253	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{}"(alter Wert war "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"OK\"}")
                                          javascript.3
                                          2024-01-10 03:05:42.127	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"OK\"}"(alter Wert war "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Fail\"}")
                                          javascript.3
                                          2024-01-10 03:05:37.539	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Fail\"}"(alter Wert war "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"OK\"}")
                                          javascript.3
                                          2024-01-10 02:08:21.801	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"OK\"}"(alter Wert war "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Error - undefined\"}")
                                          javascript.3
                                          2024-01-10 02:07:12.200	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Error - undefined\"}"(alter Wert war "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Fail\"}")
                                          javascript.3
                                          2024-01-10 02:07:07.203	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Fail\"}"(alter Wert war "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"OK\"}")
                                          javascript.3
                                          2024-01-10 01:31:41.560	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"OK\"}"(alter Wert war "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Error - 0106\"}")
                                          javascript.3
                                          2024-01-10 01:31:31.985	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Error - 0106\"}"(alter Wert war "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Error - undefined\"}")
                                          javascript.3
                                          2024-01-10 01:30:52.049	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Error - undefined\"}"(alter Wert war "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Fail\"}")
                                          javascript.3
                                          2024-01-10 01:30:46.964	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Fail\"}"(alter Wert war "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"OK\"}")
                                          javascript.3
                                          2024-01-10 01:09:21.432	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"OK\"}"(alter Wert war "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Fail\"}")
                                          javascript.3
                                          2024-01-10 01:09:16.931	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Fail\"}"(alter Wert war "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"OK\"}")
                                          javascript.3
                                          2024-01-10 00:12:51.007	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"OK\"}"(alter Wert war "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Error - undefined\"}")
                                          javascript.3
                                          2024-01-10 00:12:41.496	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Error - undefined\"}"(alter Wert war "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Fail\"}")
                                          javascript.3
                                          2024-01-10 00:12:36.516	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Fail\"}"(alter Wert war "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"OK\"}")
                                          javascript.3
                                          2024-01-10 00:12:26.045	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"OK\"}"(alter Wert war "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Fail\"}")
                                          javascript.3
                                          2024-01-10 00:12:21.426	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Fail\"}"(alter Wert war "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"OK\"}")
                                          Soll ich das Logging noch weiter Laufen lassen, oder hast du gesehen was du sehen wolltest?
