  4. <gelöst> Serieller Port defekt
    6.8k
362 Beiträge 11 Kommentatoren 87.5k Aufrufe 9 Beobachtet
    @searcher57 und wo ist das log?
    searcher57
    #73
    @homoran said in Serieller Port defekt:
    smartmeter.0
    	2024-01-07 20:12:01.207	warn	No or too long answer from Serial Device after last request.
    smartmeter.0
    	2024-01-07 20:12:01.206	info	Error: No or too long answer from Serial Device after last request.
    smartmeter.0
    	2024-01-07 20:10:51.203	warn	No or too long answer from Serial Device after last request.
    smartmeter.0
    	2024-01-07 20:10:51.198	info	Error: No or too long answer from Serial Device after last request.
    host.raspberrypi
    	2024-01-07 20:10:25.500	info	instance system.adapter.yr.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    host.raspberrypi
    	2024-01-07 20:10:00.035	info	instance system.adapter.yr.0 started with pid 6921
    smartmeter.0
    	2024-01-07 20:09:41.193	warn	No or too long answer from Serial Device after last request.
    smartmeter.0
    	2024-01-07 20:09:41.191	info	Error: No or too long answer from Serial Device after last request.
      @searcher57 sagte in Serieller Port defekt:
      Ich habe mehrfach die Anschlüsse gedreht!
      was sollte das bringen, wenn du auf USB nach dem Lesekopf suchst?
      searcher57
      #74
      Dann sag mir bitte, wo ich das ändere.
      • S searcher57
        #75
        bistcdu doch gerade dabei - hoffentlich!
        • S searcher57
          smartmeter.0
          smartmeter.0
          smartmeter.0
          smartmeter.0
          host.raspberrypi
          host.raspberrypi
          smartmeter.0
          smartmeter.0
          #76
          @searcher57 ich brauch das log ab Neustart der Instanz als debug-log
            searcher57
            #77
            smartmeter.0
            	2024-01-07 20:16:37.648	warn	No or too long answer from Serial Device after last request.
            smartmeter.0
            	2024-01-07 20:16:37.646	info	Error: No or too long answer from Serial Device after last request.
            smartmeter.0
            	2024-01-07 20:16:27.606	info	starting. Version 3.4.0 in /opt/iobroker/node_modules/iobroker.smartmeter, node: v18.19.0, js-controller: 5.0.17
            host.raspberrypi
            	2024-01-07 20:16:24.706	info	instance system.adapter.smartmeter.0 started with pid 7091
            host.raspberrypi
            	2024-01-07 20:16:22.105	info	instance system.adapter.smartmeter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
            smartmeter.0
            	2024-01-07 20:16:21.992	info	terminating
            host.raspberrypi
            	2024-01-07 20:16:21.622	info	stopInstance system.adapter.smartmeter.0 send kill signal
            smartmeter.0
            	2024-01-07 20:16:21.489	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
            smartmeter.0
            	2024-01-07 20:16:21.486	info	terminating
            smartmeter.0
            	2024-01-07 20:16:21.482	info	Got terminate signal TERMINATE_YOURSELF
            host.raspberrypi
            	2024-01-07 20:16:21.468	info	stopInstance system.adapter.smartmeter.0 (force=false, process=true)
            admin.0
            	2024-01-07 20:16:04.221	info	<== Disconnect system.user.admin from ::ffff:192.168.178.30
            host.raspberrypi
            	2024-01-07 20:15:40.113	info	instance system.adapter.yr.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
            smartmeter.0
            	2024-01-07 20:15:33.596	info	List of port: [{"path":"/dev/ttyAMA0"},{"path":"/dev/ttyS0"}]
            admin.0
            	2024-01-07 20:15:33.145	info	==> Connected system.user.admin from ::ffff:192.168.178.30
            smartmeter.0
            	2024-01-07 20:15:31.223	warn	No or too long answer from Serial Device after last request.
            smartmeter.0
            	2024-01-07 20:15:31.221	info	Error: No or too long answer from Serial Device after last request.
            host.raspberrypi
            	2024-01-07 20:15:00.034	info	instance system.adapter.yr.0 started with pid 7052
            javascript.0
            	2024-01-07 20:15:00.022	info	script.js.downloads.Shelly-Verbrauch: Shelly Verbrauch: Verbrauchswerte aktualisiert: 1 | Reboots korrigiert: 0 | Unveränderte Werte: 12
            smartmeter.0
            	2024-01-07 20:14:21.218	warn	No or too long answer from Serial Device after last request.
            smartmeter.0
            	2024-01-07 20:14:21.217	info	Error: No or too long answer from Serial Device after last request.
            awtrix-light.0
            	2024-01-07 20:13:39.015	info	error ECONNABORTED from screen: timeout of 3000ms exceeded
            awtrix-light.0
            	2024-01-07 20:13:30.002	info	error ECONNABORTED from screen: timeout of 3000ms exceeded
            smartmeter.0
            	2024-01-07 20:13:11.212	warn	No or too long answer from Serial Device after last request.
            smartmeter.0
            	2024-01-07 20:13:11.210	info	Error: No or too long answer from Serial Device after last request.
            • S searcher57
              @martinp said in Serieller Port defekt:
              Fette Lötbrücke/fetter Kurzschluss ... bitte entfernen ...
              Bei meinem Kopf war TXD der Pin, auf dem der Lesekopf empfangen hat ... Das würde dann passen mit Pin 8 -> Lesekopf TX Pin 10->Lesekopf RX
              Ist entfernt! Ich habe mittlerweile mehrere Versuche durchgeführt!
              searcher57
              #78
              @searcher57 said in Serieller Port defekt:
              Sorry ich beantworte im Moment mehreren Helfern1 Kannst Du oben sehen!
              • S searcher57
                smartmeter.0
                smartmeter.0
                smartmeter.0
                host.raspberrypi
                host.raspberrypi
                smartmeter.0
                host.raspberrypi
                smartmeter.0
                smartmeter.0
                smartmeter.0
                host.raspberrypi
                admin.0
                host.raspberrypi
                smartmeter.0
                admin.0
                smartmeter.0
                smartmeter.0
                host.raspberrypi
                javascript.0
                smartmeter.0
                smartmeter.0
                awtrix-light.0
                awtrix-light.0
                smartmeter.0
                smartmeter.0
                #79
                da isses ja!
                wieso war das bisher nie im log?
                Wie gesagt habe ich mit GPIOs keinsterlei Erfahrung. Ich weiß daher auch nicht, ob
                @homoran sagte in Serieller Port defekt:
                kann @searcher57 via ls -la /dev/serial/by-id/ versuchen herauszufinden was er da hat
                das hilft.
                Was kommt denn dabei raus?
                Im Moment könnte S0 richtig sein, aber die Verdrahtung nicht
                  searcher57
                  #80
                  Bitte sag mir doch, wo ich die Einstellung ändere, dass der USB Port eingestellt ist.
                  • S searcher57
                    #81
                    tue ich die ganze Zeit!
                      searcher57
                      #82
                      Also ich habe den Anschluss folgendermaßen vorgenommen:
                      J8 PIN 1 +3,3V
                      J6 GND
                      J8 GPIO 14 TXD0
                      J10 GPIO 15 RXD0
                      • S searcher57
                        J8 PIN 1 +3,3V
                        J6 GND
                        J8 GPIO 14 TXD0
                        J10 GPIO 15 RXD0
                        #83
                        Was willst du mir damit sagen?
                          da isses ja!
                          das hilft.
                          searcher57
                          #84
                          da isses ja!
                          das hilft.
                          pi@raspberrypi:~ $ ls -la /dev/serial/by-id/
                          ls: Zugriff auf '/dev/serial/by-id/' nicht möglich: Datei oder Verzeichnis nicht gefunden
                          • S searcher57
                            da isses ja!
                            das hilft.
                            #85
                            @searcher57 ok!
                            entweder geht das nicht mit GPIOs
                            oder die serielle Schnittstelle ist nicht korrekt freigeschaltet
                            oder der Lesekopf ist falsch angeschlossen
                            damit sind wir keinen Schritt weiter
                            du kannst jetzt nur noch überprüfen ob die serielle in raspi-config freigeschaltet wurde (danach rebootet???!|
                            Dann AMA0 und S0 ausprobieren.
                            Den Sitz des Lesekopfs (auch mal um 180 grad drehen) prüfen.
                            und natürlich bei jeder Einstellung der Schnittstelle die Verkabelung checken.
                            Aber da kann ich nicht helfen
                            Thomas BraunT S 2 Antworten Letzte Antwort
                              @searcher57 ok!
                              #86
                              Das geht nur über USB-Geräte, die dann per udev-Regel dort als Link auf das richtige /dev-File gemappt werden. Ich meine per direktem GPIO-Anschluss geht das nicht.
                                @searcher57 ok!
                                searcher57
                                #87
                                @searcher57 ok!
                                Wie sagte schon Theo Lingen??... Schade, schade, schade..
                                Alle Deine Empfehlungen mehrfach durchgeführt und daher sooo frustriert!
                                Danke!
                                HomoranH S 2 Antworten Letzte Antwort
                                  searcher57
                                  #88
                                  @thomas-braun said in Serieller Port defekt:
                                  Aber ich habe den IR Lesekopf doch über mehrere Wochen ausgelesen! Warum seit ca. 3 Wochen(seit einem Jahr) nicht mehr?
                                  • S searcher57
                                    @searcher57 ok!
                                    Danke!
                                    #89
                                    kannst du doch gar nicht!
                                    es gibt so viele Permutationen der variablen möglichen Ursachen.
                                    Systematisch prüfen.
                                    Erst einmal alles unter S0
                                    Kabel kreuzem
                                    Kopf ausrichten
                                    dann das selbe mit AMA0
                                    • S searcher57
                                      @searcher57 ok!
                                      Danke!
                                      searcher57
                                      #90
                                      @searcher57 ok!
                                      Danke!
                                      Ich glaube Mathias hatte mir die Einstellungen gegen, die finde ich aber nicht mehr!
                                        Kabel kreuzem
                                        Kopf ausrichten
                                        searcher57
                                        #91
                                        Kabel kreuzem
                                        Kopf ausrichten
                                        AMOO auf Rheinländisch?
                                        • S searcher57
                                          @searcher57 ok!
                                          Danke!
                                          searcher57
                                          #92
                                          @searcher57 ok!
                                          Danke!
                                          AMAO
