  5. komplettes Script zB. von November bis Januar aktivieren
    6.4k
43 Beiträge 5 Kommentatoren 3.3k Aufrufe 2 Beobachtet
  • H Offline
    Hicki
    schrieb am zuletzt editiert von Hicki
    Ich danke Dir.
    Hier mal meine Lösung. Würde es funktionieren?
      <variables>
        <variable id="aL_X)*sBl03%NEW0`$16">licht</variable>
      </variables>
      <block type="variables_set" id="nAb*8A.{e9B7yRo7Vp4$" x="-255" y="7">
        <field name="VAR" id="aL_X)*sBl03%NEW0`$16">licht</field>
        <value name="VALUE">
          <block type="get_value" id="5osR!02k6g`HA4bCFFc3">
            <field name="OID">meross.0.2103167712159190845648e1e962ef89.2</field>
          </block>
        </value>
        <next>
          <block type="on_ext" id="{C!-q#5L0R;9f?kYAsry">
            <value name="OID0">
              <shadow type="field_oid" id="E`(8h#e|S}7v|r5d0.Mc">
                <field name="oid">hm-rpc.0.PEQ1447187.1.LUX</field>
              </shadow>
            </value>
            <statement name="STATEMENT">
              <block type="controls_if" id="G^5|WqVzjvmK,U%fMdMq">
                <value name="IF0">
                  <block type="logic_operation" id="0!U[bEw56oGuFc_yfZqy" inline="false">
                    <field name="OP">OR</field>
                    <value name="A">
                      <block type="logic_compare" id="47YF}hPY)Nx(JS!4Y~td">
                        <field name="OP">GTE</field>
                        <value name="A">
                          <block type="time_get" id="z}:J)6`L7;6o}JW~sJ`u">
                            <field name="OPTION">MM.DD</field>
                          </block>
                        </value>
                        <value name="B">
                          <block type="text" id="kPaw)1bj?}#e*j7(+OuX">
                            <field name="TEXT">12/01</field>
                          </block>
                        </value>
                      </block>
                    </value>
                    <value name="B">
                      <block type="logic_compare" id="dWU^lD%(7ac*e$PKNrhF">
                        <field name="OP">LTE</field>
                        <value name="A">
                          <block type="time_get" id="d(3^$vsg3DKf@7wn(_9s">
                          </block>
                        </value>
                        <value name="B">
                          <block type="text" id="=L^_)Og/Pb#z58x$Ks0;">
                            <field name="TEXT">01/31</field>
                          </block>
                        </value>
                      </block>
                    </value>
                  </block>
                </value>
                <statement name="DO0">
                  <block type="controls_if" id=";}+3f,3x_YBFZFD~i@.Y">
                    <value name="IF0">
                      <block type="time_compare" id="b^e@Rw{#Wsk;K#:VY3;#">
                        <mutation xmlns="http://www.w3.org/1999/xhtml" end_time="true"></mutation>
                        <field name="OPTION">between</field>
                        <field name="START_TIME">6:00</field>
                        <field name="END_TIME">23:00</field>
                      </block>
                    </value>
                      <block type="variables_set" id="VbB+lbG|FS58Fk3H5vcH">
                          <block type="logic_compare" id="_#buL5doh#t/okTN*!a6">
                            <field name="OP">LT</field>
                            <value name="A">
                              <block type="on_source" id="VEtoDSob:sF14%jmnXr[">
                              </block>
                            </value>
                            <value name="B">
                              <block type="math_number" id="V!?+lG#2|7VQ-dgnn?4|">
                                <field name="NUM">300</field>
                              </block>
                            </value>
                          </block>
                        </value>
                      </block>
                    </statement>
                    <value name="IF1">
                      <block type="logic_operation" id="IC)`}jgNen5F1N#Qjb:~" inline="false">
                        <field name="OP">AND</field>
                        <value name="A">
                          <block type="time_compare" id="qhQ*DY~ZoD9U*WJiSE.8">
                            <mutation xmlns="http://www.w3.org/1999/xhtml" end_time="false"></mutation>
                            <field name="OPTION">&gt;</field>
                            <field name="START_TIME">23:00</field>
                          </block>
                        </value>
                        <value name="B">
                          <block type="logic_compare" id="FeHt$8yMCXvUq$5ye-RE">
                            <value name="A">
                              <block type="on_source" id="wr/psQ*vKTIf+8y}gg4R">
                              </block>
                            </value>
                            <value name="B">
                              <block type="math_number" id="lIx1BP/VE)`}t!k!U4r|">
                              </block>
                            </value>
                          </block>
                        </value>
                      </block>
                    </value>
                    <statement name="DO1">
                      <block type="variables_set" id="L+4Ku-/v|69KE0nD7Pb7">
                          <block type="logic_boolean" id="W,a2FN}d^%PaI]hyCYkK">
                          </block>
                        </value>
                      </block>
                    </statement>
                    <next>
                      <block type="controls_if" id="_qgWF*jdZ/QKfr9POs0L">
                        <value name="IF0">
                          <block type="logic_compare" id="X7KYR)Q6|-QL@=*ZWTBD">
                            <field name="OP">NEQ</field>
                            <value name="A">
                              <block type="variables_get" id="[-Bv!#,hV:Yz8I53N2Y~">
                              </block>
                            </value>
                            <value name="B">
                              <block type="get_value" id="kD~ukn|f|d@uo5#GX.y}">
                              </block>
                            </value>
                          </block>
                        </value>
                          <block type="control" id="fT~xYZ|F)+1p)_rAB}a,">
                              <block type="variables_get" id="y8rYr_L_eWEvAR[d$pG_">
                              </block>
                            </value>
                          </block>
                        </statement>
                        <next>
                          <block type="debug" id=":;07tr72fVw{?`HNic(q">
                            <value name="TEXT">
                              <shadow type="text" id="3P6x:CGgrB2V^fsr0hn0">
                              </shadow>
                              <block type="text_join" id="!E[?o{_K5c3tfHgAa+6O">
                                <mutation items="4"></mutation>
                                <value name="ADD0">
                                  <block type="text" id=":,psL={k/UsAtc1$,U=1">
                                    <field name="TEXT">Außenbeleuchtung:</field>
                                  </block>
                                </value>
                                <value name="ADD1">
                                  <block type="variables_get" id="(ybtL.qIEg()hW:uHkyH">
                                  </block>
                                </value>
                                <value name="ADD2">
                                  <block type="text" id="gmO[[Owfys^]w}t]IQTL">
                                    <field name="TEXT"> und Helligkeit:</field>
                                  </block>
                                </value>
                                <value name="ADD3">
                                  <block type="get_value" id="~7fMP8j.GBv_e,jA{XD[">
                                    <field name="OID">hm-rpc.0.PEQ1447187.1.LUX</field>
                                  </block>
                                </value>
                              </block>
                            </value>
                          </block>
                        </next>
                      </block>
                    </next>
                  </block>
                </statement>
              </block>
            </statement>
            <next>
              <block type="schedule" id="ak~y9Iwu#Cup^J),=;v@">
                <field name="SCHEDULE">0 3 * * *</field>
                  <block type="control" id="oZj+MJkM;{]VnsEg.;A^">
                      <block type="logic_boolean" id="cV3]LAPIrt2tIOX-)d|t">
                      </block>
                    </value>
                    <next>
                      <block type="debug" id="7^r40|R30Z}3Kv)r|f8f">
                        <value name="TEXT">
                          </shadow>
                          <block type="text_join" id="y/kf?#2~+Z[c#pQjx#Z)">
                            <value name="ADD0">
                              <block type="text" id="]u=J_0w=vHN{zR/[yPoZ">
                              </block>
                            </value>
                            <value name="ADD1">
                              <block type="variables_get" id="W^;Ww~TaenQB+RO$hkHN">
                              </block>
                            </value>
                            <value name="ADD2">
                              <block type="text" id="h6f=xZOU[Zo.](Qcl+v)">
                              </block>
                            </value>
                            <value name="ADD3">
                              <block type="get_value" id=",=-.E{00d*V[KQse*.GF">
                              </block>
                            </value>
                          </block>
                        </value>
                      </block>
                    </next>
                  </block>
                </statement>
                <next>
                  <block type="schedule" id=",ECUIntEI0QA|h_h+kct">
                    <field name="SCHEDULE">0 6 * * *</field>
                      <block type="controls_if" id=",}pMxq4a7bGFzlZ^GWVf">
                        <value name="IF0">
                          <block type="logic_compare" id="uqgMXHv#IWDH6P9bzJ7w">
                            <value name="A">
                              <block type="get_value" id="U;u.tz;2xslL9g4SO8qx">
                              </block>
                            </value>
                            <value name="B">
                              <block type="math_number" id="}NM^dhdqr7^?*`h`R4t0">
                              </block>
                            </value>
                          </block>
                        </value>
                          <block type="control" id="fBR6ceNE|aLkv?~u_*sn">
                              <block type="logic_boolean" id="~9g-D.r!~]S;KRZ10Z6,">
                              </block>
                            </value>
                          </block>
                        </statement>
                        <next>
                          <block type="debug" id="[k9j)X3_5#kaEq`l,o]*">
                            <value name="TEXT">
                              </shadow>
                              <block type="text_join" id="l--#7]:HfKX$u94:lwEl">
                                <value name="ADD0">
                                  <block type="text" id="yD*h{N`o+]^xO|xUX^ZC">
                                  </block>
                                </value>
                                <value name="ADD1">
                                  <block type="variables_get" id="TN-#Gu]hUM+${?$|}Z7r">
                                  </block>
                                </value>
                                <value name="ADD2">
                                  <block type="text" id="(.q3YL3bmfx4IpU$_z4r">
                                  </block>
                                </value>
                                <value name="ADD3">
                                  <block type="get_value" id="KR/ZhBngvcuN5{7fcU{;">
                                  </block>
                                </value>
                              </block>
                            </value>
                          </block>
                        </next>
                      </block>
                    </statement>
                  </block>
                </next>
              </block>
            </next>
          </block>
        </next>
      </block>
    </xml>
      @hicki sagte: von November bis Januar aktivieren.
      Im Datenpunkt-Trigger:
      In den Zeitplänen mit CRON:
      Hicki
      @paul53 sagte in komplettes Script zB. von November bis Januar aktivieren:
      ich habe es geändert, so wie es Paul53 geschrieben hat. Es funktioniert aber nicht.
        <variables>
          <variable id="h9D`_bjnh7+zfds1apYJ">monat</variable>
        </variables>
        <block type="variables_set" id="nAb*8A.{e9B7yRo7Vp4$" x="-312" y="-13">
            </block>
          </value>
          <next>
              <value name="OID0">
                </shadow>
              </value>
                <block type="variables_set" id="+C=!uRkGaZV+@fwXn(^-">
                  <field name="VAR" id="h9D`_bjnh7+zfds1apYJ">monat</field>
                    <block type="time_get" id="SP54U[1N:+(T*JZQ35wy">
                      <field name="OPTION">M</field>
                    </block>
                  </value>
                  <next>
                      <value name="IF0">
                        <block type="logic_operation" id="2+e?:^M.*R-ZIHgD];C,">
                          <value name="A">
                            <block type="logic_compare" id="i.rk`1TXp!JYA42Sew%U">
                              <value name="A">
                                <block type="variables_get" id="vMq!pTewS+y1_IO8Bk6B">
                                </block>
                              </value>
                              <value name="B">
                                <block type="math_number" id="$#|ns76)0ik=DuJX^0zN">
                                  <field name="NUM">11</field>
                                </block>
                              </value>
                            </block>
                          </value>
                          <value name="B">
                            <block type="logic_compare" id="th?,9uz!uBdsFyN|jn:5">
                              <field name="OP">EQ</field>
                              <value name="A">
                                <block type="variables_get" id="@K=3Ujd]%!-{yW{Btq9S">
                                </block>
                              </value>
                              <value name="B">
                                <block type="math_number" id="6u%uJ.L,f[{xNNP88$9n">
                                  <field name="NUM">1</field>
                                </block>
                              </value>
                            </block>
                          </value>
                        </block>
                      </value>
                        <block type="controls_if" id="ah9bdqk^?`(F?iRu9K0E">
                          <value name="IF0">
                            </block>
                          </value>
                                  <value name="A">
                                    </block>
                                  </value>
                                  <value name="B">
                                      <field name="NUM">350</field>
                                    </block>
                                  </value>
                                </block>
                              </value>
                            </block>
                          </statement>
                        </block>
                      </statement>
                      <value name="IF1">
                          <value name="A">
                              <field name="START_TIME">23:30</field>
                            </block>
                          </value>
                          <value name="B">
                              <value name="A">
                                </block>
                              </value>
                              <value name="B">
                                </block>
                              </value>
                            </block>
                          </value>
                        </block>
                      </value>
                            </block>
                          </value>
                        </block>
                      </statement>
                      <next>
                          <value name="IF0">
                              <value name="A">
                                </block>
                              </value>
                              <value name="B">
                                </block>
                              </value>
                            </block>
                          </value>
                            <block type="control" id="w.%$^mNIRkE/BvQ_kibz">
                                <block type="variables_get" id="_b]p1k!)%d}f%ykWXd=4">
                                </block>
                              </value>
                            </block>
                          </statement>
                          <next>
                              <value name="TEXT">
                                </shadow>
                                  <value name="ADD0">
                                    </block>
                                  </value>
                                  <value name="ADD1">
                                    </block>
                                  </value>
                                  <value name="ADD2">
                                    </block>
                                  </value>
                                  <value name="ADD3">
                                    </block>
                                  </value>
                                </block>
                              </value>
                            </block>
                          </next>
                        </block>
                      </next>
                    </block>
                  </next>
                </block>
              </statement>
              <next>
                <block type="schedule" id="EF?3)TIqPV%Jq)SG/g|P">
                  <field name="SCHEDULE">0 2 * 1,11,12 *</field>
                    <block type="control" id="e$Hyu9Sa.Sz9/5=Ma4TE">
                        <block type="logic_boolean" id="Y9SG.fNG@^=%Y+$@ow|)">
                        </block>
                      </value>
                      <next>
                        <block type="debug" id="=e7HUvXBE%fz)WI8HLUD">
                          <value name="TEXT">
                            </shadow>
                            <block type="text_join" id="3q=r},YXe!pv`V[ma!,4">
                              <value name="ADD0">
                                <block type="text" id="q`mw%gyq)T$lgE)rqzm5">
                                </block>
                              </value>
                              <value name="ADD1">
                                <block type="variables_get" id="p2svWA!S`R4*pV0%9e0?">
                                </block>
                              </value>
                              <value name="ADD2">
                                <block type="text" id="8GP6#MJ5^K`b?`g~f2*9">
                                </block>
                              </value>
                              <value name="ADD3">
                                <block type="get_value" id="NAU_RnF6{6U?#-{_rOqv">
                                </block>
                              </value>
                            </block>
                          </value>
                        </block>
                      </next>
                    </block>
                  </statement>
                  <next>
                    <block type="schedule" id="=1HK,tlY!FMQ?IZ%RF0,">
                      <field name="SCHEDULE">0 6 * 1,11,12 *</field>
                        <block type="controls_if" id="U`8u9o:Am{Eun=MmoPK_">
                          <value name="IF0">
                            <block type="logic_compare" id="i)kldwDoimFLu5k8ox0_">
                              <value name="A">
                                <block type="get_value" id="_-:}|R08h~[Uj:eeFG#K">
                                </block>
                              </value>
                              <value name="B">
                                <block type="math_number" id="0k|EA=5[YYT5]j0{|g^.">
                                </block>
                              </value>
                            </block>
                          </value>
                            <block type="control" id="KXd3@lXse#4s[gt=zm@Z">
                                <block type="logic_boolean" id="BN-5gr7sNQ?R^8E|3*m+">
                                </block>
                              </value>
                            </block>
                          </statement>
                          <next>
                            <block type="debug" id="Vx}Nv%]Bt_k9]N^RakQS">
                              <value name="TEXT">
                                </shadow>
                                <block type="text_join" id="p8.wQe+)UP~?43;ljchF">
                                  <value name="ADD0">
                                    <block type="text" id="F7*Cv|^vdR#Ii(6B#S|o">
                                    </block>
                                  </value>
                                  <value name="ADD1">
                                    <block type="variables_get" id="H~:(r8Vn#tJIH5kFM|u=">
                                    </block>
                                  </value>
                                  <value name="ADD2">
                                    <block type="text" id="*+C:ANSOjYY~O8=l?U0=">
                                    </block>
                                  </value>
                                  <value name="ADD3">
                                    <block type="get_value" id="C,R}00?Q0*-VlVaY([+[">
                                    </block>
                                  </value>
                                </block>
                              </value>
                            </block>
                          </next>
                        </block>
                      </statement>
                    </block>
                  </next>
                </block>
              </next>
            </block>
          </next>
        </block>
      </xml>
      Was habe ich falsch gemacht?
      besser dargestellt
      • H Hicki
          <variables>
          </variables>
              </block>
            </value>
            <next>
                <value name="OID0">
                  </shadow>
                </value>
                      </block>
                    </value>
                    <next>
                        <value name="IF0">
                            <value name="A">
                                <value name="A">
                                  </block>
                                </value>
                                <value name="B">
                                  </block>
                                </value>
                              </block>
                            </value>
                            <value name="B">
                                <value name="A">
                                  </block>
                                </value>
                                <value name="B">
                                  </block>
                                </value>
                              </block>
                            </value>
                          </block>
                        </value>
                            <value name="IF0">
                              </block>
                            </value>
                                    <value name="A">
                                      </block>
                                    </value>
                                    <value name="B">
                                      </block>
                                    </value>
                                  </block>
                                </value>
                              </block>
                            </statement>
                          </block>
                        </statement>
                        <value name="IF1">
                            <value name="A">
                              </block>
                            </value>
                            <value name="B">
                                <value name="A">
                                  </block>
                                </value>
                                <value name="B">
                                  </block>
                                </value>
                              </block>
                            </value>
                          </block>
                        </value>
                              </block>
                            </value>
                          </block>
                        </statement>
                        <next>
                            <value name="IF0">
                                <value name="A">
                                  </block>
                                </value>
                                <value name="B">
                                  </block>
                                </value>
                              </block>
                            </value>
                                  </block>
                                </value>
                              </block>
                            </statement>
                            <next>
                                <value name="TEXT">
                                  </shadow>
                                    <value name="ADD0">
                                      </block>
                                    </value>
                                    <value name="ADD1">
                                      </block>
                                    </value>
                                    <value name="ADD2">
                                      </block>
                                    </value>
                                    <value name="ADD3">
                                      </block>
                                    </value>
                                  </block>
                                </value>
                              </block>
                            </next>
                          </block>
                        </next>
                      </block>
                    </next>
                  </block>
                </statement>
                <next>
                          </block>
                        </value>
                        <next>
                            <value name="TEXT">
                              </shadow>
                                <value name="ADD0">
                                  </block>
                                </value>
                                <value name="ADD1">
                                  </block>
                                </value>
                                <value name="ADD2">
                                  </block>
                                </value>
                                <value name="ADD3">
                                  </block>
                                </value>
                              </block>
                            </value>
                          </block>
                        </next>
                      </block>
                    </statement>
                    <next>
                            <value name="IF0">
                                <value name="A">
                                  </block>
                                </value>
                                <value name="B">
                                  </block>
                                </value>
                              </block>
                            </value>
                                  </block>
                                </value>
                              </block>
                            </statement>
                            <next>
                                <value name="TEXT">
                                  </shadow>
                                    <value name="ADD0">
                                      </block>
                                    </value>
                                    <value name="ADD1">
                                      </block>
                                    </value>
                                    <value name="ADD2">
                                      </block>
                                    </value>
                                    <value name="ADD3">
                                      </block>
                                    </value>
                                  </block>
                                </value>
                              </block>
                            </next>
                          </block>
                        </statement>
                      </block>
                    </next>
                  </block>
                </next>
              </block>
            </next>
          </block>
        </xml>
        besser dargestellt
        @hicki sagte in komplettes Script zB. von November bis Januar aktivieren:
        besser dargestellt
        dein falls mit den Zeitabfragen umschliesst nicht alles!
        ist das gewollt?
        ...ist keine Fehlerbeschreibung!
        was passiert?
        was erwartest du?
        H 1 Antwort Letzte Antwort
          besser dargestellt
          ist das gewollt?
          was passiert?
          was erwartest du?
          Hicki
          @homoran Hallo,
          ich erkläre noch einmal was ich genau mit dem Script erreichen will.
          Lichtsensor - Terrasse.LUX ist der Lichtsensor
          Objekt ID Switch2 ist schaltbare Steckdose
          Von November bis Januar soll das Script aktiv sein, dass heißt,
          von 6 - 23Uhr soll bei weniger als 350Lux die Steckdose an gehen
          ab 23.30Uhr Steckdose aus
          ab 6Uhr Steckdose wieder an bei weniger als 350Lux
          bei allen Uhrzeiten bei mehr als 350Lux Steckdose aus
          Ich hoffe es verständlich erklärt zu haben.
          Gruß Hicki
          paul53P HomoranH 3 Antworten Letzte Antwort
          • H Hicki
            @homoran Hallo,
            Gruß Hicki
            @hicki sagte: ab 23.30Uhr Steckdose aus
            Weshalb dann per Zeitplan erst um 2:00 Uhr? Der Lux-Wert wird sich nach 23:00 Uhr nicht mehr ändern.
            Versuche es mal einfacher:
            • H Hicki
              @homoran Hallo,
              Gruß Hicki
              @hicki sagte: bei allen Uhrzeiten bei mehr als 350Lux Steckdose aus
              Wenn der Wert um 350 Lux schwankt, geht das Licht ein und aus. Besser ist es, am Vormittag das Licht bei erster Überschreitung nur auszuschalten und abends bei erster Unterschreitung nur einzuschalten.
              • H Hicki
                @homoran Hallo,
                Gruß Hicki
                nicht wirklich!
                also nochmal:
                heisst was?
                  Hicki
                  weil 2Uhr das Licht ausgeschalten werden soll.
                  • H Hicki
                    und nicht wird?
                    aber die Systemzeit ist richtig?
                      Hicki
                      Abend geht das Licht nicht an.
                      • H Hicki
                        Hicki
                        @hicki Ich war jetzt lange Krank, deshalb melde ich mich jetzt erst.
                        Es haut immer noch nicht hin. Wer kann mir bitte helfen.
                        Vielen Dank -
                        Hicki
                        • H Hicki
                          Vielen Dank -
                          Hicki
                          Michi_Pi
                          @hicki was genau funktioniert denn jetzt und was nicht? Dann wäre es auch einfacher dir zu helfen.
                          • M Michi_Pi
                            Hicki
                            @michi_pi Hallo,
                            das Licht geht nicht an.
                            • H Hicki
                              @michi_pi Hallo,
                              @michi_pi Hallo,
                              und wie hell ist es?
                                @michi_pi Hallo,
                                Hicki
                                @homoran Wenn es unter 350Lux ist, bleibt es dunkel
                                • H Hicki
                                  ja! deshalb die Frage
                                    Hicki
                                    @homoran sagte in komplettes Script zB. von November bis Januar aktivieren:
                                    Wie gesagt, wenn das Licht unter 350Lux ist, schaltet die Beleuchtung nicht an.
                                    • H Hicki
                                      soll!!!
                                      und wie hell IST es?
                                      lass dir doch die Bedingungen per debug anzeigen
                                        soll!!!
                                        Hicki
                                        @homoran Jetzt schaltet es noch nicht.Ist noch zu hell. Wenn es später soweit ist melde ich mich. Debug sende ich dann mit. Den Lichtwert habe ich auf 1000 gesetzt, da geht es schneller.
                                        • H Hicki
                                          Hicki
                                          @hicki hier die Debugausgabe
                                          2.11.2025, 16:05:37.254	[info ]: javascript.0 (1968) script.js.Scripte_-_Andreas.Außenbeleuchtung_mit_Datum5: getState(id=meross.0.2103167712159190845648e1e962ef89.2, timerId=undefined) => {"val":false,"ack":true,"ts":1762095824738,"q":0,"from":"system.adapter.meross.0","user":"system.user.admin","lc":1762095824738}
                                          2.11.2025, 16:05:37.255	[info ]: javascript.0 (1968) script.js.Scripte_-_Andreas.Außenbeleuchtung_mit_Datum5: setForeignState(id=meross.0.2103167712159190845648e1e962ef89.2, state={"val":true,"ack":false,"ts":1762095937255,"q":0,"from":"system.adapter.javascript.0","lc":1762095937255,"c":"script.js.Scripte_-_Andreas.Außenbeleuchtung_mit_Datum5"})
                                          2.11.2025, 16:05:37.255	[warn ]: javascript.0 (1968) script.js.Scripte_-_Andreas.Außenbeleuchtung_mit_Datum5: setForeignState(id=meross.0.2103167712159190845648e1e962ef89.2, state={"val":true,"ack":false,"ts":1762095937255,"q":0,"from":"system.adapter.javascript.0","lc":1762095937255,"c":"script.js.Scripte_-_Andreas.Außenbeleuchtung_mit_Datum5"}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                                          2.11.2025, 16:05:37.256	[info ]: javascript.0 (1968) script.js.Scripte_-_Andreas.Außenbeleuchtung_mit_Datum5: getState(id=hm-rpc.0.PEQ1447187.1.LUX, timerId=undefined) => {"val":673.46,"ack":true,"ts":1762095937252,"q":0,"from":"system.adapter.hm-rpc.0","user":"system.user.admin","lc":1762095937252}
                                          Das dazugehörige Blockly
                                            <variables>
                                            </variables>
                                            <block type="on_ext" id="{C!-q#5L0R;9f?kYAsry" x="-312" y="14">
                                              <value name="OID0">
                                                </shadow>
                                              </value>
                                                    </block>
                                                  </value>
                                                  <next>
                                                    <block type="controls_if" id="d,YSKZ.xFAT`;R,vIx2D">
                                                      <value name="IF0">
                                                        <block type="logic_operation" id=":sCXl^))p5{Xh%v$OKt!" inline="false">
                                                          <value name="A">
                                                              <value name="A">
        <value name="A">
        </block>
        </value>
        <value name="B">
        </block>
        </value>
        </block>
                                                              </value>
                                                              <value name="B">
        <value name="A">
        </block>
        </value>
        <value name="B">
        </block>
        </value>
        </block>
                                                              </value>
                                                            </block>
                                                          </value>
                                                          <value name="B">
                                                              <field name="START_TIME">06:00</field>
                                                            </block>
                                                          </value>
                                                        </block>
                                                      </value>
                                                        <block type="variables_set" id="FynZ+bVq1MPh55VOl_q`">
                                                            <block type="logic_compare" id=":qpdm}*R*.qIV}[b4MQO">
                                                              <value name="A">
        <block type="on_source" id="!u2_GN{4eMdq[GC%tjOm">
        </block>
                                                              </value>
                                                              <value name="B">
        <block type="math_number" id="e=3=QK~heu0PaUN)=_eB">
        <field name="NUM">1000</field>
        </block>
                                                              </value>
                                                            </block>
                                                          </value>
                                                          <next>
                                                            <block type="controls_if" id="iX(Z4x6.^1Am:O3b$#To">
                                                              <value name="IF0">
        <block type="logic_compare" id=")Hsxue?IHr)#[4uQ.E#K">
        <value name="A">
        <block type="variables_get" id="(=F@DeY}ZXlw`3H@jjSe">
        </block>
        </value>
        <value name="B">
        <block type="get_value" id="iRDMVgP*lqUkL94f,N[}">
        </block>
        </value>
        </block>
                                                              </value>
        <block type="control" id="%Y^,A~ps;6j3+zVe%Pb$">
        <block type="variables_get" id="5D^CvDup/L{}o((]sZNc">
        </block>
        </value>
        </block>
                                                              </statement>
                                                            </block>
                                                          </next>
                                                        </block>
                                                      </statement>
                                                      <next>
                                                          <field name="Severity">debug</field>
                                                          <value name="TEXT">
                                                            </shadow>
                                                              <value name="ADD0">
        </block>
                                                              </value>
                                                              <value name="ADD1">
        </block>
                                                              </value>
                                                              <value name="ADD2">
        </block>
                                                              </value>
                                                              <value name="ADD3">
        </block>
                                                              </value>
                                                            </block>
                                                          </value>
                                                        </block>
                                                      </next>
                                                    </block>
                                                  </next>
                                                </block>
                                              </statement>
                                              <next>
                                                  <field name="SCHEDULE">0 3 * 1,2,11,12 *</field>
                                                        </block>
                                                      </value>
                                                      <next>
                                                          <value name="TEXT">
                                                            </shadow>
                                                              <value name="ADD0">
        </block>
                                                              </value>
                                                              <value name="ADD1">
        </block>
                                                              </value>
                                                              <value name="ADD2">
        </block>
                                                              </value>
                                                              <value name="ADD3">
        </block>
                                                              </value>
                                                            </block>
                                                          </value>
                                                        </block>
                                                      </next>
                                                    </block>
                                                  </statement>
                                                  <next>
                                                          <value name="IF0">
                                                              <value name="A">
        </block>
                                                              </value>
                                                              <value name="B">
        </block>
                                                              </value>
                                                            </block>
                                                          </value>
        </block>
                                                              </value>
                                                            </block>
                                                          </statement>
                                                          <next>
                                                              <value name="TEXT">
        </shadow>
        <value name="ADD0">
        </block>
        </value>
        <value name="ADD1">
        </block>
        </value>
        <value name="ADD2">
        </block>
        </value>
        <value name="ADD3">
        </block>
        </value>
        </block>
                                                              </value>
                                                            </block>
                                                          </next>
                                                        </block>
                                                      </statement>
                                                    </block>
                                                  </next>
                                                </block>
                                              </next>
                                            </block>
                                          </xml>
                                          hier noch die Ausgabe der Switch2
                                          Ich hoffe es ist jetzt alles dabei
