  4. Sonoff Zigbee Stick und Proxmox
8 Beiträge 4 Kommentatoren 420 Aufrufe 4 Beobachtet
  • L Offline
    lustig29
    Habe das Problem das mein Sonoff Zigbee Stick an meinem Proxmox nicht läuft. Habe es nach der Anleitung von Eddy gemacht. Und nach den Ausgaben her stimmt auch alles. Leider bekomme ich aber den Zigbee Adapter nicht grün.
    2023-12-27 18:43:08.015	error	Error herdsman start
    zigbee.0
    	2023-12-27 18:43:08.015	error	Failed to start Zigbee
    zigbee.0
    	2023-12-27 18:43:08.014	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
    zigbee.0
    	2023-12-27 18:43:07.893	info	Installed Version: iobroker.zigbee@1.8.25
    zigbee.0
    	2023-12-27 18:43:07.888	info	Starting Zigbee npm ...
    zigbee.0
    	2023-12-27 18:43:07.887	info	Try to reconnect. 1 attempts left
    zigbee.0
    	2023-12-27 18:42:57.884	error	Error herdsman start
    zigbee.0
    	2023-12-27 18:42:57.884	error	Failed to start Zigbee
    zigbee.0
    	2023-12-27 18:42:57.884	error	Starting zigbee-herdsman problem : "startup failed - configuration-adapter mismatch - see logs above for more information"
    zigbee.0
    	2023-12-27 18:42:57.822	error	Re-commissioning your network will require re-pairing of all devices!
    zigbee.0
    	2023-12-27 18:42:57.822	error	If you wish to re-commission your network, please remove coordinator backup at /opt/iobroker/iobroker-data/zigbee_0/nvbackup.json.
    zigbee.0
    	2023-12-27 18:42:57.822	error	Please update configuration to prevent further issues.
    zigbee.0
    	2023-12-27 18:42:57.821	error	- Channel List: configured=11, adapter=11
    zigbee.0
    	2023-12-27 18:42:57.821	error	- Network Key: configured=01030507090b0d0f00020406080a0c0d, adapter=01030507090b0d0f00020406080a0c0d
    zigbee.0
    	2023-12-27 18:42:57.821	error	- Extended PAN ID: configured=00124b0024c6aa98, adapter=00124b0024c6aa98
    zigbee.0
    	2023-12-27 18:42:57.821	error	- PAN ID: configured=6754, adapter=6742
    zigbee.0
    	2023-12-27 18:42:57.820	error	Configuration is not consistent with adapter state/backup!
    DJMarc75D F 2 Antworten Letzte Antwort
    • L lustig29
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      DJMarc75D Offline
      DJMarc75D Offline
      DJMarc75
      @lustig29 sagte in Sonoff Zigbee Stick und Proxmox:
      Wer ist Eddy und gibt es dazu einen Link ?
      Lehrling seit 1975 !!!
      L 1 Antwort Letzte Antwort
      • DJMarc75D DJMarc75
        lustig29
        @djmarc75 https://youtu.be/1U7Sl8mfjDE?si=8WFJij5l6F03zGol
        • L lustig29
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          Frank579
          schrieb am zuletzt editiert von Frank579
          Nimm als erstes mal die 1.8.24 .. mit der .25 gabs hier schon einige diverser Probleme
          • L lustig29
            DJMarc75D Offline
            DJMarc75D Offline
            DJMarc75
            ok, youtube ... da bin ich raus
            • F Frank579
              Meister MopperM Online
              Meister Mopper
              @frank579 sagte in Sonoff Zigbee Stick und Proxmox:
              8.1.24 .. mit der .25
              @lustig29
              Falsche Ziffer, richtig: 1.8.24
              Proxmox und HA ...
              F 1 Antwort Letzte Antwort
                @lustig29
                Frank579
                @meister-mopper
                Danke hab's angepasst 👼
                • F Frank579
                  @meister-mopper
                  Meister Mopper
                  Besser ist es, dem eigenen Beitrag ein edit mit den geänderten Informationen anzufügen, dann können später Lesende den sinnigen Verlauf nachvollziehen. 😉
                  Proxmox und HA ...
