  4. Keinerlei Adaperupdates seit Monaten
18 Beiträge 5 Kommentatoren 1.7k Aufrufe 4 Beobachtet
  • A alexzi
    @Homoran
    strange, beim ersten iob diag kam nicht wirklich was, evtl. hatte ich mich verschrieben und nicht gesehen 🙈 dann kam der Fehler beim iob update
    hier der volle Output von iob diag
    Skript v.2023-10-10
    *** BASE SYSTEM ***
       Static hostname: SYS-Server-Raspi4
             Icon name: computer
      Operating System: Raspbian GNU/Linux 10 (buster)
                Kernel: Linux 5.10.103-v8+
          Architecture: arm64
    Model		: Raspberry Pi 4 Model B Rev 1.4
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : armhf
    Systemuptime and Load:
     15:50:59 up  4:12,  2 users,  load average: 5.40, 5.92, 5.82
    CPU threads: 4
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** Time and Time Zones ***
                   Local time: Wed 2023-12-27 15:50:59 CET
               Universal time: Wed 2023-12-27 14:50:59 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin docker gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server: 	true
    Desktop: 	LXDE-pi
    Terminal: 	x11
    Boot Target: 	graphical.target
    *** MEMORY ***
    Mem:           7.8G        1.5G        114M         97M        6.2G        6.1G
    Swap:           99M         21M         78M
    Total:         7.9G        1.5G        193M
             7813 M total memory
             1481 M used memory
              794 M active memory
             5850 M inactive memory
              114 M free memory
              493 M buffer memory
             5724 M swap cache
               99 M total swap
               21 M used swap
               78 M free swap
    Raspberry only:
    oom events: 0
    *** FAILED SERVICES ***
    0 loaded units listed. Pass --all to see loaded but inactive units, too.
    To show all installed unit files use 'systemctl list-unit-files'.
    *** FILESYSTEM ***
    /dev/root      ext4      117G   70G   41G  63% /
    devtmpfs       devtmpfs  3.7G     0  3.7G   0% /dev
    tmpfs          tmpfs     3.9G   11M  3.9G   1% /dev/shm
    tmpfs          tmpfs     3.9G  9.7M  3.9G   1% /run
    tmpfs          tmpfs     3.9G     0  3.9G   0% /sys/fs/cgroup
    /dev/mmcblk0p1 vfat      253M   49M  204M  20% /boot
    tmpfs          tmpfs     782M  4.0K  782M   1% /run/user/1000
    /dev/sda1      ext4      458G   70M  435G   1% /media/pi/792af2c5-30c9-445e-ab6e-cb506092c413
    /dev/sdb2      ext4      117G   16G   96G  14% /tmp/tmp.mMEpdvkZaF
    [Wed Dec 27 11:38:22 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 video=HDMI-A-1:1920x1080M@60D smsc95xx.macaddr=DC:A6:32:FA:33:E0 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=64538962-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
    [Wed Dec 27 11:38:23 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
    [Wed Dec 27 11:38:23 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
    [Wed Dec 27 11:38:25 2023] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
    [Wed Dec 27 11:38:44 2023] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: errors=remount-ro
    [Wed Dec 27 12:17:51 2023] EXT4-fs (sdb2): mounted filesystem with ordered data mode. Opts: (null)
    TARGET                                           SOURCE         FSTYPE          OPTIONS
    /                                                /dev/mmcblk0p2 ext4            rw,noatime
    |-/sys/fs/bpf                                    none           bpf             rw,nosuid,nodev,noexec,relatime,mode=700
    |-/run/user/1000/gvfs                            gvfsd-fuse     fuse.gvfsd-fuse rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
    |-/boot                                          /dev/mmcblk0p1 vfat            rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    |-/tmp/tmp.mMEpdvkZaF                            /dev/sdb2      ext4            rw,relatime
    |-/tmp/tmp.CY9tyJdyoV                            /dev/mmcblk0p2 ext4            rw,relatime
    `-/media/pi/792af2c5-30c9-445e-ab6e-cb506092c413 /dev/sda1      ext4            rw,nosuid,nodev,relatime,errors=remount-ro
    /var:
    1.3G	/var/
    716M	/var/lib
    417M	/var/lib/docker
    415M	/var/lib/docker/overlay2
    310M	/var/lib/docker/overlay2/9a19718ad57ef0af959ba0272376648d9dab28c6da97bab8013bb20f26fad944/diff
    Archived and active journals take up 8.0M in the file system.
    /opt/iobroker/backups:
    41G	/opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    2.2G	/opt/iobroker/iobroker-data/
    1.9G	/opt/iobroker/iobroker-data/history
    233M	/opt/iobroker/iobroker-data/files
    72M	/opt/iobroker/iobroker-data/files/telegram.admin
    52M	/opt/iobroker/iobroker-data/backup-objects
    15M	/opt/iobroker/iobroker-data/files/telegram.admin/rules/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-1d9f06.44fe4a3f.chunk.js.map
    8.9M	/opt/iobroker/iobroker-data/files/scenes.admin/static/js/2.7de3299d.chunk.js.map
    7.5M	/opt/iobroker/iobroker-data/files/scenes.admin/static/js/2.2afdfa2c.chunk.js.map
    7.2M	/opt/iobroker/iobroker-data/files/telegram.admin/rules/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-1d9f06.44fe4a3f.chunk.js
    7.0M	/opt/iobroker/iobroker-data/files/scenes.admin/static/js/2.5d4fbf6a.chunk.js.map
    USB-Devices by-id:
    /dev/serial/by-id/usb-1a86_USB_Serial-if00-port0
    *** NodeJS-Installation ***
    /usr/bin/nodejs 	v18.17.1
    /usr/bin/node 		v18.17.1
    /usr/bin/npm 		9.6.7
    /usr/bin/npx 		9.6.7
    /usr/bin/corepack 	0.18.0
    nodejs:
      Installed: 18.17.1-deb-1nodesource1
      Candidate: 18.17.1-deb-1nodesource1
      Version table:
     *** 18.17.1-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_18.x buster/main armhf Packages
         10.24.0~dfsg-1~deb10u3 500
    No problems detected
    Errors in npm tree:
    npm ERR! code ELSPROBLEMS
    npm ERR! invalid: @types/node@14.18.33 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/node
    npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2023-12-27T14_51_13_908Z-debug-0.log
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller: 	4.0.24
    admin: 		6.3.5
    javascript: 	6.1.4
    Adapters from github: 	0
    Adapter State
    + system.adapter.admin.0                  : admin                 : SYS-Server-Raspi4                        -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.alexa2.0                 : alexa2                : SYS-Server-Raspi4                        -  enabled
    + system.adapter.backitup.0               : backitup              : SYS-Server-Raspi4                        -  enabled
    + system.adapter.bring.0                  : bring                 : SYS-Server-Raspi4                        -  enabled
      system.adapter.daswetter.0              : daswetter             : SYS-Server-Raspi4                        - disabled
    + system.adapter.discovery.0              : discovery             : SYS-Server-Raspi4                        -  enabled
    + system.adapter.harmony.0                : harmony               : SYS-Server-Raspi4                        -  enabled
    + system.adapter.history.0                : history               : SYS-Server-Raspi4                        -  enabled
      system.adapter.homeconnect.0            : homeconnect           : SYS-Server-Raspi4                        - disabled
    + system.adapter.info.0                   : info                  : SYS-Server-Raspi4                        -  enabled
    + system.adapter.jarvis.0                 : jarvis                : SYS-Server-Raspi4                        -  enabled
    + system.adapter.javascript.0             : javascript            : SYS-Server-Raspi4                        -  enabled
      system.adapter.meross.0                 : meross                : SYS-Server-Raspi4                        - disabled
    + system.adapter.pi-hole.0                : pi-hole               : SYS-Server-Raspi4                        -  enabled
    + system.adapter.scenes.0                 : scenes                : SYS-Server-Raspi4                        -  enabled
    + system.adapter.shelly.0                 : shelly                : SYS-Server-Raspi4                        -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.smartcontrol.0           : smartcontrol          : SYS-Server-Raspi4                        -  enabled
      system.adapter.telegram.0               : telegram              : SYS-Server-Raspi4                        - disabled, port: 8443, bind: 0.0.0.0
    + system.adapter.tr-064.0                 : tr-064                : SYS-Server-Raspi4                        -  enabled
      system.adapter.vis.0                    : vis                   : SYS-Server-Raspi4                        -  enabled
    + system.adapter.web.0                    : web                   : SYS-Server-Raspi4                        -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : SYS-Server-Raspi4                        -  enabled
    + system.adapter.yahka.0                  : yahka                 : SYS-Server-Raspi4                        -  enabled
    + system.adapter.zigbee.0                 : zigbee                : SYS-Server-Raspi4                        -  enabled, port: /dev/ttyUSB0
    + instance is alive
    ioBroker-Repositories
    List is empty
    Installed ioBroker-Instances
    Error: Object "system.repositories" not found
    Objects and States
    Objects: 	10043
    States: 	9057
    Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
    Hit:2 http://archive.raspberrypi.org/debian buster InRelease
    Hit:3 https://download.docker.com/linux/raspbian buster InRelease
    Hit:4 https://download.mono-project.com/repo/debian stable-raspbianbuster InRelease
    Hit:5 https://deb.nodesource.com/node_18.x buster InRelease
    Reading package lists...
    E: Broken packages
    Pending Updates:
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:33341           0.0.0.0:*               LISTEN      1001       880431     10196/io.yahka.0
    tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN      0          27357      1499/smbd
    tcp        0      0 127.0.0.1:45825         0.0.0.0:*               LISTEN      1001       880462     10196/io.yahka.0
    tcp        0      0 0.0.0.0:2049            0.0.0.0:*               LISTEN      0          21773      -
    tcp        0      0 127.0.0.1:33763         0.0.0.0:*               LISTEN      1001       880472     10196/io.yahka.0
    tcp        0      0 0.0.0.0:43845           0.0.0.0:*               LISTEN      0          20824      599/rpc.mountd
    tcp        0      0 127.0.0.1:4711          0.0.0.0:*               LISTEN      999        30097      590/pihole-FTL
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       867170     8836/iobroker.js-co
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       867163     8836/iobroker.js-co
    tcp        0      0 127.0.0.1:3306          0.0.0.0:*               LISTEN      116        22872      663/mysqld
    tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN      0          27358      1499/smbd
    tcp        0      0 0.0.0.0:5900            0.0.0.0:*               LISTEN      0          19417      550/vncserver-x11-c
    tcp        0      0 0.0.0.0:52941           0.0.0.0:*               LISTEN      0          20816      599/rpc.mountd
    tcp        0      0 0.0.0.0:34671           0.0.0.0:*               LISTEN      0          21782      -
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          10388      1/init
    tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1001       871998     9634/io.jarvis.0
    tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      0          21150      682/lighttpd
    tcp        0      0 127.0.0.1:38481         0.0.0.0:*               LISTEN      1001       880467     10196/io.yahka.0
    tcp        0      0 0.0.0.0:47761           0.0.0.0:*               LISTEN      0          20832      599/rpc.mountd
    tcp        0      0 0.0.0.0:35603           0.0.0.0:*               LISTEN      1001       880434     10196/io.yahka.0
    tcp        0      0 0.0.0.0:34517           0.0.0.0:*               LISTEN      1001       880428     10196/io.yahka.0
    tcp        0      0 0.0.0.0:53              0.0.0.0:*               LISTEN      999        30091      590/pihole-FTL
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          21705      571/sshd
    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          28667      1820/cupsd
    tcp6       0      0 :::3389                 :::*                    LISTEN      115        23642      651/xrdp
    tcp6       0      0 :::59709                :::*                    LISTEN      0          20820      599/rpc.mountd
    tcp6       0      0 :::445                  :::*                    LISTEN      0          27355      1499/smbd
    tcp6       0      0 :::2049                 :::*                    LISTEN      0          18803      -
    tcp6       0      0 :::58181                :::*                    LISTEN      998        33414      1699/homebridge
    tcp6       0      0 :::8581                 :::*                    LISTEN      998        30791      1025/hb-service
    tcp6       0      0 :::61991                :::*                    LISTEN      1001       875433     9859/io.harmony.0
    tcp6       0      0 ::1:4711                :::*                    LISTEN      999        30098      590/pihole-FTL
    tcp6       0      0 :::47433                :::*                    LISTEN      0          18667      599/rpc.mountd
    tcp6       0      0 :::139                  :::*                    LISTEN      0          27356      1499/smbd
    tcp6       0      0 :::5900                 :::*                    LISTEN      0          19416      550/vncserver-x11-c
    tcp6       0      0 :::111                  :::*                    LISTEN      0          10182      1/init
    tcp6       0      0 :::51376                :::*                    LISTEN      998        33081      1699/homebridge
    tcp6       0      0 :::8080                 :::*                    LISTEN      0          28229      1312/node /home/Shi
    tcp6       0      0 :::80                   :::*                    LISTEN      0          21151      682/lighttpd
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       865126     9117/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       871839     9615/io.web.0
    tcp6       0      0 :::41235                :::*                    LISTEN      998        33101      1699/homebridge
    tcp6       0      0 :::34355                :::*                    LISTEN      0          21784      -
    tcp6       0      0 :::53                   :::*                    LISTEN      999        30093      590/pihole-FTL
    tcp6       0      0 :::45461                :::*                    LISTEN      0          20828      599/rpc.mountd
    tcp6       0      0 ::1:3350                :::*                    LISTEN      0          20850      591/xrdp-sesman
    tcp6       0      0 :::22                   :::*                    LISTEN      0          21715      571/sshd
    tcp6       0      0 ::1:631                 :::*                    LISTEN      0          28666      1820/cupsd
    tcp6       0      0 :::57272                :::*                    LISTEN      998        31441      1699/homebridge
    udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1001       875434     9859/io.harmony.0
    udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          31849      1821/cups-browsed
    udp        0      0 0.0.0.0:37984           0.0.0.0:*                           0          20830      599/rpc.mountd
    udp        0      0 10.100.200.1:5353       0.0.0.0:*                           1001       873134     9300/io.tr-064.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           998        33102      1699/homebridge
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           998        33082      1699/homebridge
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           998        30788      1025/hb-service
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        17749      419/avahi-daemon: r
    udp        0      0 0.0.0.0:50642           0.0.0.0:*                           0          20814      599/rpc.mountd
    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       869574     9562/io.shelly.0
    udp        0      0 0.0.0.0:54839           0.0.0.0:*                           0          21781      -
    udp        0      0 0.0.0.0:46775           0.0.0.0:*                           0          20822      599/rpc.mountd
    udp        0      0 0.0.0.0:2049            0.0.0.0:*                           0          21066      -
    udp        0      0 0.0.0.0:48411           0.0.0.0:*                           108        17751      419/avahi-daemon: r
    udp        0      0 0.0.0.0:53              0.0.0.0:*                           999        30090      590/pihole-FTL
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          22856      467/dhcpcd
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          11275      1/init
    udp        0      0 172.17.255.255:137      0.0.0.0:*                           0          29120      540/nmbd
    udp        0      0 172.17.0.1:137          0.0.0.0:*                           0          29119      540/nmbd
    udp        0      0 10.100.200.255:137      0.0.0.0:*                           0          29116      540/nmbd
    udp        0      0 10.100.200.1:137        0.0.0.0:*                           0          29115      540/nmbd
    udp        0      0 0.0.0.0:137             0.0.0.0:*                           0          19404      540/nmbd
    udp        0      0 172.17.255.255:138      0.0.0.0:*                           0          29122      540/nmbd
    udp        0      0 172.17.0.1:138          0.0.0.0:*                           0          29121      540/nmbd
    udp        0      0 10.100.200.255:138      0.0.0.0:*                           0          29118      540/nmbd
    udp        0      0 10.100.200.1:138        0.0.0.0:*                           0          29117      540/nmbd
    udp        0      0 0.0.0.0:138             0.0.0.0:*                           0          19405      540/nmbd
    udp6       0      0 :::546                  :::*                                0          22892      467/dhcpcd
    udp6       0      0 :::37625                :::*                                108        17752      419/avahi-daemon: r
    udp6       0      0 :::5353                 :::*                                108        17750      419/avahi-daemon: r
    udp6       0      0 :::46883                :::*                                0          18665      599/rpc.mountd
    udp6       0      0 :::2049                 :::*                                0          18804      -
    udp6       0      0 :::55946                :::*                                0          20826      599/rpc.mountd
    udp6       0      0 :::44573                :::*                                0          21783      -
    udp6       0      0 :::44931                :::*                                0          20818      599/rpc.mountd
    udp6       0      0 :::53                   :::*                                999        30092      590/pihole-FTL
    udp6       0      0 :::111                  :::*                                0          11278      1/init
    2023-12-27 15:44:23.458  - info: yahka.0 (10196) adding Maurice-Stehlampe-TV with UUID: 9a024b0a-3b72-476e-9703-1562fd95b928
    2023-12-27 15:44:23.463  - info: yahka.0 (10196) adding Maurice-Stehlampe-TV-oben with UUID: bd093dc5-d30a-4ea6-9423-2c9cb8d23107
    2023-12-27 15:44:23.475  - info: yahka.0 (10196) adding Maurice-Stehlampe-TV-unten with UUID: cd87fb94-2c88-410b-bc09-bc9e267e2c9a
    2023-12-27 15:44:23.485  - info: yahka.0 (10196) adding Außenbereich-Bewegungsmelder with UUID: 8db7716d-cf91-48aa-b28a-7dbad46dd014
    2023-12-27 15:44:23.487  - info: yahka.0 (10196) publishing bridge ioBrokerPi4 on 10.100.200.1 using avahi
    2023-12-27 15:44:23.604  - info: yahka.0 (10196) publishing camera Terrasse-Lounge-Kamera on 10.100.200.1 using avahi
    2023-12-27 15:44:23.634  - info: yahka.0 (10196) publishing camera Hof-Haustuer-Kamera on 10.100.200.1 using avahi
    2023-12-27 15:44:26.079  - info: smartcontrol.0 (10281) starting. Version 1.3.2 in /opt/iobroker/node_modules/iobroker.smartcontrol, node: v18.17.1, js-controller: 4.0.24
    2023-12-27 15:44:27.355  - info: pi-hole.0 (10516) starting. Version 1.3.4 in /opt/iobroker/node_modules/iobroker.pi-hole, node: v18.17.1, js-controller: 4.0.24
    2023-12-27 15:44:27.448  - info: harmony.0 (9859) [DISCOVER] Discovered Wohnzimmer (10.100.200.74) and will try to connect
    2023-12-27 15:44:27.822  - info: harmony.0 (9859) [CONNECT] Connecting to Wohnzimmer (10.100.200.74)
    2023-12-27 15:44:29.190  - info: harmony.0 (9859) [CONNECT] Connected to Wohnzimmer (10.100.200.74)
    2023-12-27 15:44:30.051  - info: harmony.0 (9859) [PROCESS] Synced hub config for Wohnzimmer (10.100.200.74)
    2023-12-27 15:44:32.731  - info: bring.0 (10677) starting. Version 1.8.1 in /opt/iobroker/node_modules/iobroker.bring, node: v18.17.1, js-controller: 4.0.24
    2023-12-27 15:44:33.196  - info: vis.0 (10758) starting. Version 1.4.16 in /opt/iobroker/node_modules/iobroker.vis, node: v18.17.1, js-controller: 4.0.24
    2023-12-27 15:44:33.292  - info: smartcontrol.0 (10281) Adapter admin configuration successfully validated...
    2023-12-27 15:44:33.862  - info: vis.0 (10758) vis license is OK.
    2023-12-27 15:44:33.980  - info: bring.0 (10677) [LOGIN] Successfully logged in as Ali
    2023-12-27 15:44:34.865  - info: vis.0 (10758) Terminated (NO_ERROR): Without reason
    2023-12-27 15:44:35.592  - info: host.SYS-Server-Raspi4 instance system.adapter.vis.0 terminated while should be started once
    2023-12-27 15:44:35.816  - info: smartcontrol.0 (10281) Subscribing to all target devices and trigger states. 4 trigger schedules activated...
    2023-12-27 15:44:38.612  - info: alexa2.0 (9212) Subscribing to states...
    2023-12-27 15:44:38.622  - info: alexa2.0 (9212) Deleting the following states: ["Smart-Home-Devices.9f4e9ab6-8817-4fc0-837c-080303c57239","Smart-Home-Devices.3b42e75f-f188-487d-978b-4b716e9f3647","Smart-Home-Devices.deleteAll","Smart-Home-Devices.discoverDevices","Smart-Home-Devices.9f4e9ab6-8817-4fc0-837c-080303c57239.#enabled","Smart-Home-Devices.9f4e9ab6-8817-4fc0-837c-080303c57239.#delete","Smart-Home-Devices.3b42e75f-f188-487d-978b-4b716e9f3647.#enabled","Smart-Home-Devices.3b42e75f-f188-487d-978b-4b716e9f3647.#delete"]
    2023-12-27 15:44:40.302  - info: alexa2.0 (9212) Alexa-Push-Connection (macDms = true) established. Disable Polling
    2023-12-27 15:44:44.730  - info: alexa2.0 (9212) Initialization Done ...
    			v.2023-10-10
             Icon name: computer
          Architecture: arm64
    Installation: 		native
    Kernel: 		aarch64
    Userland: 		armhf
    Timezone: 		Europe/Berlin (CET, +0100)
    User-ID: 		1000
    X-Server: 		true
    Pending OS-Updates:
    Pending iob updates: 	0
    Nodejs-Installation: 	/usr/bin/nodejs 	v18.17.1
    			/usr/bin/npm 		9.6.7
    			/usr/bin/npx 		9.6.7
    Recommended versions are nodejs 16.20.2 and npm 8.19.4
    MEMORY:
    Mem:           7.8G        1.4G        486M         80M        5.9G        6.2G
    Swap:           99M         21M         78M
    Total:         7.9G        1.4G        565M
    Active iob-Instances: 	20
    List is empty
    ioBroker Core: 		js-controller 		4.0.24
    			admin 			6.3.5
    ioBroker Status: 	iobroker is running on this host.
    Objects type: jsonl
    States  type: jsonl
    Objects: 		10043
    States: 		9057
    Size of iob-Database:
    6.5M	/opt/iobroker/iobroker-data/objects.json.migrated
    6.5M	/opt/iobroker/iobroker-data/objects.json.bak.migrated
    6.4M	/opt/iobroker/iobroker-data/objects.jsonl
    4.0K	/opt/iobroker/iobroker-data/objects.json.old
    3.1M	/opt/iobroker/iobroker-data/states.jsonl
    1.5M	/opt/iobroker/iobroker-data/states.json.old
    1.5M	/opt/iobroker/iobroker-data/states.json.migrated
    1.5M	/opt/iobroker/iobroker-data/states.json.bak.migrated
    0	/opt/iobroker/iobroker-data/states.json.broken
    @alexzi sagte in Keinerlei Adaperupdates seit Monaten:
    Deswegen immer alles zeigen!
    Auch die Eingabezeile
    • A alexzi
      @Homoran
      Skript v.2023-10-10
      *** BASE SYSTEM ***
               Icon name: computer
            Architecture: arm64
      Docker          : false
      Kernel          : aarch64
      Userland        : armhf
      CPU threads: 4
      Current issues:
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      pi
      /home/pi
      X-Server: 	true
      Desktop: 	LXDE-pi
      Terminal: 	x11
      *** MEMORY ***
      Swap:           99M         21M         78M
               7813 M total memory
               1481 M used memory
                794 M active memory
                114 M free memory
                493 M buffer memory
               5724 M swap cache
                 99 M total swap
                 21 M used swap
                 78 M free swap
      Raspberry only:
      oom events: 0
      *** FILESYSTEM ***
      /var:
      1.3G	/var/
      716M	/var/lib
      USB-Devices by-id:
      /usr/bin/npm 		9.6.7
      /usr/bin/npx 		9.6.7
      nodejs:
        Version table:
      Errors in npm tree:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      admin: 		6.3.5
      javascript: 	6.1.4
      Adapter State
      + instance is alive
      List is empty
      Objects and States
      Objects: 	10043
      States: 	9057
      E: Broken packages
      Pending Updates:
      			v.2023-10-10
               Icon name: computer
            Architecture: arm64
      Kernel: 		aarch64
      Userland: 		armhf
      User-ID: 		1000
      X-Server: 		true
      Pending OS-Updates:
      			/usr/bin/npm 		9.6.7
      			/usr/bin/npx 		9.6.7
      MEMORY:
      Swap:           99M         21M         78M
      List is empty
      			admin 			6.3.5
      Objects type: jsonl
      States  type: jsonl
      Objects: 		10043
      States: 		9057
      viel zu hoch!
      viel zu alt
      Terminal: x11
      vollkommen unnötig auf einem Server
      /usr/bin/npm 9.6.7
      auch nicht aktuell
      • A alexzi
        @Homoran
        Skript v.2023-10-10
        *** BASE SYSTEM ***
                 Icon name: computer
              Architecture: arm64
        Docker          : false
        Kernel          : aarch64
        Userland        : armhf
        CPU threads: 4
        Current issues:
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        pi
        /home/pi
        X-Server: 	true
        Desktop: 	LXDE-pi
        Terminal: 	x11
        *** MEMORY ***
        Swap:           99M         21M         78M
                 7813 M total memory
                 1481 M used memory
                  794 M active memory
                  114 M free memory
                  493 M buffer memory
                 5724 M swap cache
                   99 M total swap
                   21 M used swap
                   78 M free swap
        Raspberry only:
        oom events: 0
        *** FILESYSTEM ***
        /var:
        1.3G	/var/
        716M	/var/lib
        USB-Devices by-id:
        /usr/bin/npm 		9.6.7
        /usr/bin/npx 		9.6.7
        nodejs:
          Version table:
        Errors in npm tree:
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        admin: 		6.3.5
        javascript: 	6.1.4
        Adapter State
        + instance is alive
        List is empty
        Objects and States
        Objects: 	10043
        States: 	9057
        E: Broken packages
        Pending Updates:
        			v.2023-10-10
                 Icon name: computer
              Architecture: arm64
        Kernel: 		aarch64
        Userland: 		armhf
        User-ID: 		1000
        X-Server: 		true
        Pending OS-Updates:
        			/usr/bin/npm 		9.6.7
        			/usr/bin/npx 		9.6.7
        MEMORY:
        Swap:           99M         21M         78M
        List is empty
        			admin 			6.3.5
        Objects type: jsonl
        States  type: jsonl
        Objects: 		10043
        States: 		9057
        GlasfaserG Offline
        GlasfaserG Offline
        List is empty
        Dazu
        iob stop
        iob setup first
        der Rest zum ( alten ) System von dir , wurde schon oben genannt .
          viel zu hoch!
          viel zu alt
          Terminal: x11
          /usr/bin/npm 9.6.7
          auch nicht aktuell
          alexzi
          nach apt full upgrade und reboot sehen die uptime infos zumindest besser aus, ob das gut genug ist kann ich nicht beurteilen. Hatte auch noch den SD-Kopierer laufen, evtl. hat der die hohen Werte mit beeinflusst.
          hier nochmal der Output von iob diag
          wenn das OS viel zu alt ist, Empfehlung? Upgrade von Buster auf 'Name habe ich vergessen' ist ja nicht empfohlen, werde wohl um Neuanfang mit neuem OS nicht rum kommen
          ja, X11 mag unnötig sein, aber ein paar Kleinigkeiten mache ich lieber über die GUI, bin nicht der CLI-Profi, wobei ohne ja eh nichts geht 🙈
          Wie kann ich das umstellen, dass er Boot Target CLI hat?
          wenn ich nodejs mit iob nodejs-update aktualisieren will, zeigt er nichts neueres an.
          ufffff, ich bin echt für jede Hilfe dankbar, egal was ich versuche, nur Probleme, Layer 8. 😢
          Skript v.2023-10-10
          *** BASE SYSTEM ***
                   Icon name: computer
                Architecture: arm64
          Docker          : false
          Kernel          : aarch64
          Userland        : armhf
           16:36:31 up 16 min,  3 users,  load average: 0.33, 0.46, 0.63
          CPU threads: 4
          Current issues:
                         Local time: Wed 2023-12-27 16:36:31 CET
                     Universal time: Wed 2023-12-27 15:36:31 UTC
                           RTC time: n/a
                        NTP service: active
                    RTC in local TZ: no
          pi
          /home/pi
          X-Server:       true
          Desktop:
          Terminal:       tty
          *** MEMORY ***
          Mem:           7.8G        1.4G        5.0G         59M        1.5G        6.3G
          Swap:           99M          0B         99M
          Total:         7.9G        1.4G        5.1G
                   7813 M total memory
                   1355 M used memory
                    467 M active memory
                   1851 M inactive memory
                   4972 M free memory
                    176 M buffer memory
                   1307 M swap cache
                     99 M total swap
                      0 M used swap
                     99 M free swap
          Raspberry only:
          oom events: 0
          *** FILESYSTEM ***
          /dev/root      ext4      117G   70G   42G  63% /
          tmpfs          tmpfs     3.9G  4.5M  3.9G   1% /dev/shm
          tmpfs          tmpfs     3.9G  9.6M  3.9G   1% /run
          [Wed Dec 27 16:19:54 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 video=HDMI-A-1:1920x1080M@60D smsc95xx.macaddr=DC:A6:32:FA:33:E0 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=64538962-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
          [Wed Dec 27 16:19:55 2023] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
          [Wed Dec 27 16:19:55 2023] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
          [Wed Dec 27 16:19:56 2023] EXT4-fs (mmcblk0p2): orphan cleanup on readonly fs
          [Wed Dec 27 16:19:56 2023] EXT4-fs (mmcblk0p2): 4 orphan inodes deleted
          [Wed Dec 27 16:19:56 2023] EXT4-fs (mmcblk0p2): recovery complete
          [Wed Dec 27 16:19:56 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
          [Wed Dec 27 16:19:56 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
          [Wed Dec 27 16:19:58 2023] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
          `-/boot               /dev/mmcblk0p1 vfat            rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
          /var:
          1.2G    /var/
          717M    /var/lib
          7.4M    /opt/iobroker/iobroker-data/states.jsonl
          USB-Devices by-id:
          /usr/bin/npm            9.6.7
          /usr/bin/npx            9.6.7
          nodejs:
            Version table:
          Errors in npm tree:
          npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2023-12-27T15_36_45_002Z-debug-0.log
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          admin:          6.3.5
          javascript:     6.1.4
          Adapter State
          + instance is alive
          List is empty
          Objects and States
          Objects:        10043
          States:         9057
          Hit:1 http://archive.raspberrypi.org/debian buster InRelease
          Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
          Pending Updates: 0
          tcp        0      0 127.0.0.1:3306          0.0.0.0:*               LISTEN      116        21257      664/mysqld
          tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN      0          26864      1260/smbd
          tcp        0      0 0.0.0.0:40395           0.0.0.0:*               LISTEN      0          20705      599/rpc.mountd
          tcp        0      0 0.0.0.0:5900            0.0.0.0:*               LISTEN      0          20288      542/vncserver-x11-c
          tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          11699      1/init
          tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1001       33071      2219/io.jarvis.0
          tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      0          20875      669/lighttpd
          tcp        0      0 127.0.0.1:35025         0.0.0.0:*               LISTEN      1001       33416      2593/io.yahka.0
          tcp        0      0 0.0.0.0:39441           0.0.0.0:*               LISTEN      0          18404      599/rpc.mountd
          tcp        0      0 0.0.0.0:45491           0.0.0.0:*               LISTEN      1001       31731      2593/io.yahka.0
          tcp        0      0 0.0.0.0:53              0.0.0.0:*               LISTEN      999        26817      582/pihole-FTL
          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          21594      600/sshd
          tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          17014      423/cupsd
          tcp        0      0 0.0.0.0:43961           0.0.0.0:*               LISTEN      1001       31729      2593/io.yahka.0
          tcp        0      0 127.0.0.1:39035         0.0.0.0:*               LISTEN      1001       33411      2593/io.yahka.0
          tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN      0          26863      1260/smbd
          tcp        0      0 0.0.0.0:52031           0.0.0.0:*               LISTEN      0          17164      599/rpc.mountd
          tcp        0      0 0.0.0.0:44673           0.0.0.0:*               LISTEN      0          17404      -
          tcp        0      0 0.0.0.0:2049            0.0.0.0:*               LISTEN      0          17397      -
          tcp        0      0 127.0.0.1:41605         0.0.0.0:*               LISTEN      1001       34164      2593/io.yahka.0
          tcp        0      0 0.0.0.0:39109           0.0.0.0:*               LISTEN      1001       31727      2593/io.yahka.0
          tcp        0      0 127.0.0.1:4711          0.0.0.0:*               LISTEN      999        26823      582/pihole-FTL
          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       29006      541/iobroker.js-con
          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       28232      541/iobroker.js-con
          tcp6       0      0 :::37035                :::*                    LISTEN      0          17406      -
          tcp6       0      0 :::35819                :::*                    LISTEN      0          20695      599/rpc.mountd
          tcp6       0      0 :::139                  :::*                    LISTEN      0          26862      1260/smbd
          tcp6       0      0 :::5900                 :::*                    LISTEN      0          20287      542/vncserver-x11-c
          tcp6       0      0 :::111                  :::*                    LISTEN      0          8983       1/init
          tcp6       0      0 :::51376                :::*                    LISTEN      998        27232      1650/homebridge
          tcp6       0      0 :::8080                 :::*                    LISTEN      0          27008      1266/node /home/Shi
          tcp6       0      0 :::80                   :::*                    LISTEN      0          20876      669/lighttpd
          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       26583      1557/io.admin.0
          tcp6       0      0 :::8082                 :::*                    LISTEN      1001       30154      2204/io.web.0
          tcp6       0      0 :::53                   :::*                    LISTEN      999        26819      582/pihole-FTL
          tcp6       0      0 :::22                   :::*                    LISTEN      0          21596      600/sshd
          tcp6       0      0 ::1:3350                :::*                    LISTEN      0          20685      581/xrdp-sesman
          tcp6       0      0 ::1:631                 :::*                    LISTEN      0          17013      423/cupsd
          tcp6       0      0 :::57272                :::*                    LISTEN      998        30952      1650/homebridge
          tcp6       0      0 :::35613                :::*                    LISTEN      998        27237      1650/homebridge
          tcp6       0      0 :::3389                 :::*                    LISTEN      115        23747      602/xrdp
          tcp6       0      0 :::445                  :::*                    LISTEN      0          26054      1260/smbd
          tcp6       0      0 :::2049                 :::*                    LISTEN      0          17401      -
          tcp6       0      0 :::58181                :::*                    LISTEN      998        31200      1650/homebridge
          tcp6       0      0 :::8581                 :::*                    LISTEN      998        29229      1009/hb-service
          tcp6       0      0 :::61991                :::*                    LISTEN      1001       32370      2441/io.harmony.0
          tcp6       0      0 ::1:4711                :::*                    LISTEN      999        26824      582/pihole-FTL
          tcp6       0      0 :::38759                :::*                    LISTEN      0          20711      599/rpc.mountd
          tcp6       0      0 :::54697                :::*                    LISTEN      0          17168      599/rpc.mountd
          udp        0      0 0.0.0.0:2049            0.0.0.0:*                           0          17400      -
          udp        0      0 0.0.0.0:38990           0.0.0.0:*                           0          17403      -
          udp        0      0 0.0.0.0:56151           0.0.0.0:*                           108        18833      426/avahi-daemon: r
          udp        0      0 0.0.0.0:48823           0.0.0.0:*                           0          20698      599/rpc.mountd
          udp        0      0 0.0.0.0:40652           0.0.0.0:*                           0          18402      599/rpc.mountd
          udp        0      0 0.0.0.0:53              0.0.0.0:*                           999        26816      582/pihole-FTL
          udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          23758      485/dhcpcd
          udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          11700      1/init
          udp        0      0 172.17.255.255:137      0.0.0.0:*                           0          26763      543/nmbd
          udp        0      0 172.17.0.1:137          0.0.0.0:*                           0          26762      543/nmbd
          udp        0      0 10.100.200.255:137      0.0.0.0:*                           0          26759      543/nmbd
          udp        0      0 10.100.200.1:137        0.0.0.0:*                           0          26758      543/nmbd
          udp        0      0 0.0.0.0:137             0.0.0.0:*                           0          22884      543/nmbd
          udp        0      0 172.17.255.255:138      0.0.0.0:*                           0          26765      543/nmbd
          udp        0      0 172.17.0.1:138          0.0.0.0:*                           0          26764      543/nmbd
          udp        0      0 10.100.200.255:138      0.0.0.0:*                           0          26761      543/nmbd
          udp        0      0 10.100.200.1:138        0.0.0.0:*                           0          26760      543/nmbd
          udp        0      0 0.0.0.0:138             0.0.0.0:*                           0          22885      543/nmbd
          udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1001       32371      2441/io.harmony.0
          udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          20186      546/cups-browsed
          udp        0      0 0.0.0.0:42050           0.0.0.0:*                           0          17170      599/rpc.mountd
          udp        0      0 10.100.200.1:5353       0.0.0.0:*                           1001       34145      1877/io.tr-064.0
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           998        27238      1650/homebridge
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           998        27233      1650/homebridge
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           998        28407      1009/hb-service
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        18831      426/avahi-daemon: r
          udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       31317      2122/io.shelly.0
          udp6       0      0 :::2049                 :::*                                0          17402      -
          udp6       0      0 :::60723                :::*                                0          20708      599/rpc.mountd
          udp6       0      0 :::53                   :::*                                999        26818      582/pihole-FTL
          udp6       0      0 :::111                  :::*                                0          8986       1/init
          udp6       0      0 :::33280                :::*                                0          17166      599/rpc.mountd
          udp6       0      0 :::546                  :::*                                0          21416      485/dhcpcd
          udp6       0      0 :::41984                :::*                                0          20693      599/rpc.mountd
          udp6       0      0 :::33820                :::*                                108        18834      426/avahi-daemon: r
          udp6       0      0 :::5353                 :::*                                108        18832      426/avahi-daemon: r
          udp6       0      0 :::58941                :::*                                0          17405      -
          2023-12-27 16:21:32.991  - info: yahka.0 (2593) publishing bridge ioBrokerPi4 on 10.100.200.1 using avahi
          2023-12-27 16:21:33.081  - info: yahka.0 (2593) publishing camera Terrasse-Lounge-Kamera on 10.100.200.1 using avahi
          2023-12-27 16:21:33.103  - info: yahka.0 (2593) publishing camera Hof-Haustuer-Kamera on 10.100.200.1 using avahi
          2023-12-27 16:21:33.275  - warn: zigbee.0 (1866) DeviceAvailability:Failed to ping 0x60a423fffead7944 TS0121
          2023-12-27 16:21:34.890  - warn: zigbee.0 (1866) DeviceAvailability:Failed to ping 0x60a423fffef8e119 TS0121
          2023-12-27 16:21:35.974  - info: smartcontrol.0 (2739) starting. Version 1.3.2 in /opt/iobroker/node_modules/iobroker.smartcontrol, node: v18.17.1, js-controller: 4.0.24
          2023-12-27 16:21:36.888  - info: host.SYS-Server-Raspi4 instance system.adapter.bring.0 started with pid 3105
          2023-12-27 16:21:37.212  - info: pi-hole.0 (3006) starting. Version 1.3.4 in /opt/iobroker/node_modules/iobroker.pi-hole, node: v18.17.1, js-controller: 4.0.24
          2023-12-27 16:21:37.955  - info: smartcontrol.0 (2739) Adapter admin configuration successfully validated...
          2023-12-27 16:21:38.943  - info: harmony.0 (2441) [DISCOVER] Discovered Wohnzimmer (10.100.200.74) and will try to connect
          2023-12-27 16:21:39.455  - info: harmony.0 (2441) [CONNECT] Connecting to Wohnzimmer (10.100.200.74)
          2023-12-27 16:21:40.783  - info: harmony.0 (2441) [CONNECT] Connected to Wohnzimmer (10.100.200.74)
          2023-12-27 16:21:41.632  - info: harmony.0 (2441) [PROCESS] Synced hub config for Wohnzimmer (10.100.200.74)
          2023-12-27 16:21:41.890  - info: bring.0 (3105) starting. Version 1.8.1 in /opt/iobroker/node_modules/iobroker.bring, node: v18.17.1, js-controller: 4.0.24
          2023-12-27 16:21:42.067  - info: smartcontrol.0 (2739) Subscribing to all target devices and trigger states. 4 trigger schedules activated...
          2023-12-27 16:21:43.034  - info: bring.0 (3105) [LOGIN] Successfully logged in as Ali
          2023-12-27 16:21:44.064  - info: vis.0 (3152) starting. Version 1.4.16 in /opt/iobroker/node_modules/iobroker.vis, node: v18.17.1, js-controller: 4.0.24
          2023-12-27 16:21:44.462  - info: vis.0 (3152) vis license is OK.
          2023-12-27 16:21:44.625  - info: alexa2.0 (1817) Subscribing to states...
          2023-12-27 16:21:44.635  - info: alexa2.0 (1817) Deleting the following states: ["Smart-Home-Devices.9f4e9ab6-8817-4fc0-837c-080303c57239","Smart-Home-Devices.3b42e75f-f188-487d-978b-4b716e9f3647","Smart-Home-Devices.deleteAll","Smart-Home-Devices.discoverDevices","Smart-Home-Devices.9f4e9ab6-8817-4fc0-837c-080303c57239.#enabled","Smart-Home-Devices.9f4e9ab6-8817-4fc0-837c-080303c57239.#delete","Smart-Home-Devices.3b42e75f-f188-487d-978b-4b716e9f3647.#enabled","Smart-Home-Devices.3b42e75f-f188-487d-978b-4b716e9f3647.#delete"]
          2023-12-27 16:21:45.291  - info: vis.0 (3152) Terminated (NO_ERROR): Without reason
          2023-12-27 16:21:45.621  - warn: zigbee.0 (1866) DeviceAvailability:Failed to ping 0x540f57fffe896f3f TS011F
          2023-12-27 16:21:46.009  - info: host.SYS-Server-Raspi4 instance system.adapter.vis.0 terminated while should be started once
          2023-12-27 16:21:46.394  - info: alexa2.0 (1817) Alexa-Push-Connection (macDms = true) established. Disable Polling
          2023-12-27 16:21:52.495  - info: alexa2.0 (1817) Initialization Done ...
          • GlasfaserG Glasfaser
            List is empty
            Dazu
            iob stop
            iob setup first
            alexzi
            @glasfaser
            $ iob setup first
            Successfully migrated 10930 objects to Redis Sets
            Existing earlier generated certificate is invalid (too old, validity longer then 345 days or keylength too short). Generating new Certificate!
            object system.certificates updated
            object system.repositories created
            object _design/system updated
              "defaultPrivate": "-----BEGIN RSA PRIVATE KEY-----........-----END CERTIFICATE-----\r\n"
            Update certificate defaultPrivate
            The object "system.certificates" was updated successfully.
            Update certificate defaultPublic
            pi@SYS-Server-Raspi4:~ $ iob update
            Error: unknown repository is active - "Stable (default)". Known: stable, beta
            • GlasfaserG Offline
              GlasfaserG Offline
              @alexzi
              iob repo del beta
              iob repo del stable
              iob repo add stable http://download.iobroker.net/sources-dist.json
              iob repo add beta http://download.iobroker.net/sources-dist-latest.json
              iob repo list
                @alexzi
                iob repo del beta
                iob repo del stable
                iob repo list
                alexzi
                @glasfaser
                Danke, ich krieg nen Vogel... 😢
                pi@SYS-Server-Raspi4:~ $ iob repo del beta
                Repository "beta" deleted.
                pi@SYS-Server-Raspi4:~ $ iob repo del stable
                Repository "stable" deleted.
                pi@SYS-Server-Raspi4:~ $ iob repo add stable http://download.iobroker.net/sources-dist.json
                Repository "stable" added as "http://download.iobroker.net/sources-dist.json"
                pi@SYS-Server-Raspi4:~ $ iob repo add beta http://download.iobroker.net/sources-dist-latest.json
                Repository "beta" added as "http://download.iobroker.net/sources-dist-latest.json"
                pi@SYS-Server-Raspi4:~ $ iob repo list
                pi@SYS-Server-Raspi4:~ $ iob stop
                GlasfaserG HomoranH 2 Antworten Letzte Antwort
                • A alexzi
                  @glasfaser
                  GlasfaserG Offline
                  GlasfaserG Offline
                  @alexzi
                  Mache mal ein :
                  sudo reboot
                  was ist dann
                  • A alexzi
                    @glasfaser
                    @alexzi iob repo unset "Stable (default)"
                    iob repo set stable
                    • A alexzi
                      Skript v.2023-10-10
                      *** BASE SYSTEM ***
                               Icon name: computer
                            Architecture: arm64
                      Docker          : false
                      Kernel          : aarch64
                      Userland        : armhf
                      CPU threads: 4
                      Current issues:
                                       RTC time: n/a
                                    NTP service: active
                                RTC in local TZ: no
                      pi
                      /home/pi
                      X-Server:       true
                      Desktop:
                      Terminal:       tty
                      *** MEMORY ***
                      Swap:           99M          0B         99M
                               7813 M total memory
                               1355 M used memory
                                467 M active memory
                               4972 M free memory
                                176 M buffer memory
                               1307 M swap cache
                                 99 M total swap
                                  0 M used swap
                                 99 M free swap
                      Raspberry only:
                      oom events: 0
                      *** FILESYSTEM ***
                      /var:
                      1.2G    /var/
                      717M    /var/lib
                      USB-Devices by-id:
                      /usr/bin/npm            9.6.7
                      /usr/bin/npx            9.6.7
                      nodejs:
                        Version table:
                      Errors in npm tree:
                      ioBroker Status
                      Objects type: jsonl
                      States  type: jsonl
                      admin:          6.3.5
                      javascript:     6.1.4
                      Adapter State
                      + instance is alive
                      List is empty
                      Objects and States
                      Objects:        10043
                      States:         9057
                      Pending Updates: 0
                      Richtig, installier da Raspberry OS 12 'Bookworm' komplett neu in der 64Bit Lite Version.
                        iob repo set stable
                        alexzi
                        Halleluja, das wars, zumindest geht das Update wieder. DANKE
                        Beim Rest muss ich mich reinbeißen.
                        Noch eine generelle Frage: ist es ratsam/empfehlenswert IOB in Docker laufen zu lassen? Wenn ich schon neu anfange, dann hoffentlich richtig (zumindest deutlich besser).
                        • A alexzi
                          Samson71S Offline
                          Samson71S Offline
                          Samson71
                          @alexzi
                          Für den "Otto-Normalanwender", der auf seinem PI ausschließlich ioBroker betreibt, bzw. betreiben will, ist (in meinen Augen) weder Docker noch eine Proxmox Umgebung sinnvoll. Du schaffst Dir höchstens mehr Probleme als Dir lieb ist.
                          Markus
                          Bitte beachten:
