  3. Off Topic
  4. InfluxDB
  5. mit backitup kein Influxdb und Grafana backup möglich
    6.7k
Geplant Angeheftet Gesperrt Verschoben InfluxDB
119 Beiträge 10 Kommentatoren 19.8k Aufrufe 8 Beobachtet
  • simatecS simatec
    @willi-wunder sagte in mit backitup kein Influxdb und Grafana backup möglich:
    0c561c6ff19d0000 Markus 0c52172c23814000 Markus's Recovery Token yaNHdwh6KjzO0euGPkiyhVon1uZKN4tuqaDAUL4tvVKIz14-4A-_0ZIsP9ScW_XkjVYrdwpm5iUahPDBCbuhIw==
    Hier ist dein neuer Operatortoken... Den fügst du in Backitup ein und bitte nie wieder löschen
    W Offline
    W Offline
    Willi-Wunder
    schrieb am zuletzt editiert von Willi-Wunder
    #99
    [DEBUG] [influxDB] - InfluxDB-Backup started ...
    [DEBUG] [influxDB] - Start InfluxDB Backup ...
    [DEBUG] [influxDB] - InfluxDB Backup tmp directory created
    [DEBUG] [influxDB] - Try deleting the InfluxDB tmp directory: "/opt/iobroker/backups/influxDB_2023_12_27-00_30_36_backupiobroker"
    [DEBUG] [influxDB] - InfluxDB tmp directory "/opt/iobroker/backups/influxDB_2023_12_27-00_30_36_backupiobroker" successfully deleted
    [ERROR] [influxDB] - Error: Command failed: influx backup --bucket Iobroker -t yaNHdwh6KjzO0euGPkiyhVon1uZKN4tuqaDAUL4tvVKIz14-4A-_0ZIsP9ScW_XkjVYrdwpm5iUahPDBCbuhIw== "/opt/iobroker/backups/influxDB_2023_12_27-00_30_36_backupiobroker"
    Error: API compatibility check failed: Get "http://localhost:8086/health": dial tcp [::1]:8086: connect: connection refused
    [DEBUG] [influxDB] - InfluxDB-Backup for is finish
    [DEBUG] [influxDB] - done
    Warte, doof, influxDb war nicht gestartet, glaube jetzt läuft es......
    [DEBUG] [influxDB] - Packed 71MB so far...
    [DEBUG] [influxDB] - Packed 144MB so far...
    [DEBUG] [influxDB] - Backup created: /opt/iobroker/backups/influxDB_2023_12_27-00_34_14_backupiobroker.tar.gz
    [DEBUG] [influxDB] - Try deleting the InfluxDB tmp directory: "/opt/iobroker/backups/influxDB_2023_12_27-00_34_14_backupiobroker"
    [DEBUG] [influxDB] - InfluxDB tmp directory "/opt/iobroker/backups/influxDB_2023_12_27-00_34_14_backupiobroker" successfully deleted
    • W Willi-Wunder
      simatecS Offline
      simatecS Offline
      simatec
      #100
      @willi-wunder jup jetzt passt alles
      • Besuche meine Github Seite
      • HowTo Restore ioBroker
      • simatecS simatec
        W Offline
        W Offline
        Willi-Wunder
        #101
        @simatec
        @Thomas-Braun
        Herzlichen Dank für eure Unterstützung 👍 👍 👍
        Wenn Ihr mal Schreinertechnische Fragen habt, gerne an mich wenden 😀
        Der Token ist jetzt in KeePass gespeichert und geht nie wieder verloren.
        Kann man noch etwas bereinigen von der DB1.x damit das System sauber ist? Hatte diese nur zum Testen mal auf Buster installiert gehabt, verwendet habe ich da gar nix. Fange jetzt ganz neu damit an, bisher die Daten alle in History gehabt.
        Den anderen beiden API Token in InfluxDB brauche ich die noch? Löschen oder behalten? "Iobroker" war der erste API Token.
        • W Willi-Wunder
          @simatec
          @Thomas-Braun
          simatecS Offline
          simatecS Offline
          simatec
          #102
          @willi-wunder dein System sollte jetzt soweit sauber sein ... Die Token lass einfach drin ... schadet nicht
          W 1 Antwort Letzte Antwort
          • simatecS simatec
            W Offline
            W Offline
            Willi-Wunder
            #103
            @simatec
            Eine Frage noch, bei installed steht jetzt none...... paßt das so? War ja weiter oben schon mal auf installed gestanden......
            pi@iobroker:~ $ apt policy influxdb2-cli
            influxdb2-cli:
              Installed: (none)
              Candidate: 2.7.3-1
              Version table:
                 2.7.3-1 500
                    500 https://repos.influxdata.com/debian stable/main arm64 Packages
                 2.7.1-2 500
                 2.6.1 500
                 2.6.0 500
                 2.5.0 500
                 2.4.0 500
                 2.3.0 500
            • W Willi-Wunder
              @simatec
              influxdb2-cli:
                Installed: (none)
                Candidate: 2.7.3-1
                Version table:
                   2.7.3-1 500
                   2.7.1-2 500
                   2.6.1 500
                   2.6.0 500
                   2.5.0 500
                   2.4.0 500
                   2.3.0 500
              #104
              @willi-wunder
              Schau dir alles an:
              apt policy influx*
                @willi-wunder
                Schau dir alles an:
                apt policy influx*
                W Offline
                W Offline
                Willi-Wunder
                #105
                Okay, kannst du mir dann sagen was der Unterschied zwischen influxdb2-cli und influxdb2-client ist?
                pi@iobroker:~ $ apt policy influx*
                influxdb2-cli:
                  Installed: (none)
                  Candidate: 2.7.3-1
                  Version table:
                     2.7.3-1 500
                     2.7.1-2 500
                     2.6.1 500
                     2.6.0 500
                     2.5.0 500
                     2.4.0 500
                     2.3.0 500
                influxdb-client:
                  Installed: (none)
                  Candidate: 1.6.7~rc0-1+b13
                  Version table:
                     1.6.7~rc0-1+b13 500
                        500 http://deb.debian.org/debian bookworm/main arm64 Packages
                influxdb-dev:
                  Installed: (none)
                  Candidate: (none)
                  Version table:
                influxdb2-client:
                  Installed: 2.7.1-1
                  Candidate: 2.7.1-1
                  Version table:
                 *** 2.7.1-1 500
                influxdb:
                  Installed: (none)
                  Candidate: 1.8.10-1
                  Version table:
                     1.8.10-1 500
                     1.6.7~rc0-1+b13 500
                influxctl:
                  Installed: (none)
                  Candidate: 2.4.2
                  Version table:
                     2.4.2 500
                     2.4.1 500
                     2.4.0 500
                     2.3.1 500
                     2.3.0 500
                     2.2.0 500
                     2.1.0 500
                     2.0.4 500
                     2.0.3 500
                     2.0.2 500
                     2.0.1 500
                     2.0.0 500
                influxdb2:
                  Installed: 2.7.4-1
                  Candidate: 2.7.4-1
                  Version table:
                 *** 2.7.4-1 500
                     2.7.3-1 500
                     2.7.1-1 500
                     2.7.0-1 500
                     2.6.1-1 500
                     2.6.0-1 500
                     2.5.1-1 500
                     2.4.0-1 500
                     2.3.0-1 500
                     2.2.0 500
                @simatec sagte in mit backitup kein Influxdb und Grafana backup möglich:
                @willi-wunder Lösche den Pfad in den Settings von Backitup und installiere influxdb-cli
                influxd ist lediglich zur Sicherung von InfluxDB 1.x geeignet. Für InfluxDB 2.x wird influxdb-cli benötigt.
                Ich dachte deswegen das noch etwas fehlt 🕶
                • W Willi-Wunder
                  influxdb2-cli:
                    Installed: (none)
                    Candidate: 2.7.3-1
                    Version table:
                       2.7.3-1 500
                       2.7.1-2 500
                       2.6.1 500
                       2.6.0 500
                       2.5.0 500
                       2.4.0 500
                       2.3.0 500
                  influxdb-client:
                    Installed: (none)
                    Version table:
                       1.6.7~rc0-1+b13 500
                  influxdb-dev:
                    Installed: (none)
                    Candidate: (none)
                    Version table:
                  influxdb2-client:
                    Installed: 2.7.1-1
                    Candidate: 2.7.1-1
                    Version table:
                   *** 2.7.1-1 500
                  influxdb:
                    Installed: (none)
                    Candidate: 1.8.10-1
                    Version table:
                       1.8.10-1 500
                       1.6.7~rc0-1+b13 500
                  influxctl:
                    Installed: (none)
                    Candidate: 2.4.2
                    Version table:
                       2.4.2 500
                       2.4.1 500
                       2.4.0 500
                       2.3.1 500
                       2.3.0 500
                       2.2.0 500
                       2.1.0 500
                       2.0.4 500
                       2.0.3 500
                       2.0.2 500
                       2.0.1 500
                       2.0.0 500
                  influxdb2:
                    Installed: 2.7.4-1
                    Candidate: 2.7.4-1
                    Version table:
                   *** 2.7.4-1 500
                       2.7.3-1 500
                       2.7.1-1 500
                       2.7.0-1 500
                       2.6.1-1 500
                       2.6.0-1 500
                       2.5.1-1 500
                       2.4.0-1 500
                       2.3.0-1 500
                       2.2.0 500
                  #106
                  influxdb2-client:
                  Installed: 2.7.1-1
                  influxdb2:
                  Installed: 2.7.4-1
                  Passt also.
                    influxdb2-client:
                    Installed: 2.7.1-1
                    influxdb2:
                    Installed: 2.7.4-1
                    Passt also.
                    W Offline
                    W Offline
                    Willi-Wunder
                    #107
                    Funktioniert ja jetzt auch alles, nochmals vielen Dank.
                    Will es aber jetzt auch verstehen. Die influxdb2-cli ist dann für was genau bestimmt?
                    Thomas BraunT Marc BergM 2 Antworten Letzte Antwort
                    • W Willi-Wunder
                      #108
                      Die genauen Unterschiede kenne ich auch nicht. Die Kernfunktionen werden aber von beiden Paketen wohl abgedeckt, weswegen die auch nicht parallel installiert sein können.
                      • W Willi-Wunder
                        Marc BergM Offline
                        Marc BergM Offline
                        Marc Berg
                        #109
                        Beide Pakete installieren das Kommandozeilen-Interface (CLI) für InfluxDB2 "influx", nichts weiter.
                        Das Paket "...-client" bringt dabei immer eine etwas aktuellere Version mit.
                        Da sich am Daten(Speicher-)format des InfluxDB2 schon ewig nichts mehr geändert hat, ist es für Backup-Zwecke eigentlich völlig irrelevant, welches Paket benutzt wird.
                        Wenn man auf Nummer sicher gehen will, nimmt man die "-cli", die ist meist "gut abgehangen".
                        • Marc BergM Marc Berg
                          W Offline
                          W Offline
                          Willi-Wunder
                          #110
                          Vielen Dank für eure Infos, will ja auch etwas dazu lernen. Jetzt kommen die nächsten Schritte mit influxDB und Grafana......Vermutlich noch ein steiniger Weg, lach.
                            Taddy81
                            #111
                            Re: mit backitup kein Influxdb und Grafana backup möglich
                            Guten Morgen, leider muss ich mich auch mit einem Problem an euch wenden.
                            Ich habe einen LXC Container unter Proxmox auf dem meine IOBroker und meine Influx (2) Instanz liegt.
                            Durch eure bisherige Hilfestellung konnte ich ein Backup meiner Daten durchführen. Importiere ich die Daten auf meiner neuen IO Broker Instanz werden aber keine Buckets angelegt.
                            Hier ein paar Ergbnisse der CLI:
                            influx auth list -t Jwn-2_-7uR4NIwCjEFvoxMCYzmSt2qLbfHR3yxpaqFKL9V_XAcWzuil5Tb1OpLiSlvOJ79yonzaWF1IIUPptkA== --json
                                            "id": "0aa176f53b5ec000",
                                            "description": "admin's Token",
                                            "token": "oL0zQjQCzKLf0QThs2q-xjtIqpBVVsg7KwcA3lHuiwGL4KmtIaZzGt1AAUVOxA9kvmfkLVLRc8csjEqsv9s7PA==",
                                            "status": "active",
                                            "userName": "admin",
                                            "userID": "0aa176f5165ec000",
                                            "permissions": [
                                                    "read:/authorizations",
                                                    "write:/authorizations",
                                                    "read:/buckets",
                                                    "write:/buckets",
                                                    "read:/dashboards",
                                                    "write:/dashboards",
                                                    "read:/orgs",
                                                    "write:/orgs",
                                                    "read:/sources",
                                                    "write:/sources",
                                                    "read:/tasks",
                                                    "write:/tasks",
                                                    "read:/telegrafs",
                                                    "write:/telegrafs",
                                                    "read:/users",
                                                    "write:/users",
                                                    "read:/variables",
                                                    "write:/variables",
                                                    "read:/scrapers",
                                                    "write:/scrapers",
                                                    "read:/secrets",
                                                    "write:/secrets",
                                                    "read:/labels",
                                                    "write:/labels",
                                                    "read:/views",
                                                    "write:/views",
                                                    "read:/documents",
                                                    "write:/documents",
                                                    "read:/notificationRules",
                                                    "write:/notificationRules",
                                                    "read:/notificationEndpoints",
                                                    "write:/notificationEndpoints",
                                                    "read:/checks",
                                                    "write:/checks",
                                                    "read:/dbrp",
                                                    "write:/dbrp",
                                                    "read:/notebooks",
                                                    "write:/notebooks",
                                                    "read:/annotations",
                                                    "write:/annotations",
                                                    "read:/remotes",
                                                    "write:/remotes",
                                                    "read:/replications",
                                                    "write:/replications"
                                            "id": "0aa178ecd3cac000",
                                            "description": "admin",
                                            "token": "Jwn-2_-7uR4NIwCjEFvoxMCYzmSt2qLbfHR3yxpaqFKL9V_XAcWzuil5Tb1OpLiSlvOJ79yonzaWF1IIUPptkA==",
                                            "status": "active",
                                            "permissions": [
                                                    "read:orgs/88eaca12149fac9e/authorizations",
                                                    "write:orgs/88eaca12149fac9e/authorizations",
                                                    "read:orgs/88eaca12149fac9e/buckets",
                                                    "write:orgs/88eaca12149fac9e/buckets",
                                                    "read:orgs/88eaca12149fac9e/dashboards",
                                                    "write:orgs/88eaca12149fac9e/dashboards",
                                                    "read:/orgs/88eaca12149fac9e",
                                                    "write:/orgs/88eaca12149fac9e",
                                                    "read:orgs/88eaca12149fac9e/sources",
                                                    "write:orgs/88eaca12149fac9e/sources",
                                                    "read:orgs/88eaca12149fac9e/tasks",
                                                    "write:orgs/88eaca12149fac9e/tasks",
                                                    "read:orgs/88eaca12149fac9e/telegrafs",
                                                    "write:orgs/88eaca12149fac9e/telegrafs",
                                                    "read:/users/0aa176f5165ec000",
                                                    "write:/users/0aa176f5165ec000",
                                                    "read:orgs/88eaca12149fac9e/variables",
                                                    "write:orgs/88eaca12149fac9e/variables",
                                                    "read:orgs/88eaca12149fac9e/scrapers",
                                                    "write:orgs/88eaca12149fac9e/scrapers",
                                                    "read:orgs/88eaca12149fac9e/secrets",
                                                    "write:orgs/88eaca12149fac9e/secrets",
                                                    "read:orgs/88eaca12149fac9e/labels",
                                                    "write:orgs/88eaca12149fac9e/labels",
                                                    "read:orgs/88eaca12149fac9e/views",
                                                    "write:orgs/88eaca12149fac9e/views",
                                                    "read:orgs/88eaca12149fac9e/documents",
                                                    "write:orgs/88eaca12149fac9e/documents",
                                                    "read:orgs/88eaca12149fac9e/notificationRules",
                                                    "write:orgs/88eaca12149fac9e/notificationRules",
                                                    "read:orgs/88eaca12149fac9e/notificationEndpoints",
                                                    "write:orgs/88eaca12149fac9e/notificationEndpoints",
                                                    "read:orgs/88eaca12149fac9e/checks",
                                                    "write:orgs/88eaca12149fac9e/checks",
                                                    "read:orgs/88eaca12149fac9e/dbrp",
                                                    "write:orgs/88eaca12149fac9e/dbrp",
                                                    "read:orgs/88eaca12149fac9e/notebooks",
                                                    "write:orgs/88eaca12149fac9e/notebooks",
                                                    "read:orgs/88eaca12149fac9e/annotations",
                                                    "write:orgs/88eaca12149fac9e/annotations",
                                                    "read:orgs/88eaca12149fac9e/remotes",
                                                    "write:orgs/88eaca12149fac9e/remotes",
                                                    "read:orgs/88eaca12149fac9e/replications",
                                                    "write:orgs/88eaca12149fac9e/replications"
                            Mit Jwn habe ich immer gearbeitet, aber:
                            root@Influx:~# influx backup --bucket iobroker --host http://172.16.0.102:8086 -t Jwn-2_-7uR4NIwCjEFvoxMCYzmSt2qLbfHR3yxpaqFKL9V_XAcWzuil5Tb1OpLiSlvOJ79yonzaWF1IIUPptkA== "/tmp/influx-test"
                            2024/01/03 10:13:15 INFO: Downloading metadata snapshot
                            Error: failed to backup metadata: failed to download metadata snapshot: 401 Unauthorized: read:authorizations is unauthorized
                            Mit oL0 funktioniert ein Export:
                            root@Influx:~# influx backup --bucket iobroker --host http://172.16.0.102:8086 -t oL0zQjQCzKLf0QThs2q-xjtIqpBVVsg7KwcA3lHuiwGL4KmtIaZzGt1AAUVOxA9kvmfkLVLRc8csjEqsv9s7PA== "/tmp/influx-test"
                            2024/01/03 10:39:21 INFO: Downloading metadata snapshot
                            2024/01/03 10:39:21 INFO: Backing up TSM for shard 4110
                            2024/01/03 10:39:21 WARN: Shard 4110 removed during backup
                            Log von BackitUp
                            Started iobroker ...
                            [DEBUG] [mount] - done
                            [DEBUG] [iobroker] - host.Influx 4335 states saved
                            [DEBUG] [iobroker] - host.Influx 4958 objects saved
                            [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2024_01_03-11_12_14_backupiobroker.tar.gz
                            [DEBUG] [iobroker] - This backup can only be restored with js-controller version up from 4.1
                            [DEBUG] [iobroker] - done
                            [DEBUG] [influxDB] - InfluxDB-Backup for  is started ...
                            [DEBUG] [influxDB] - Backup created: /opt/iobroker/backups/influxDB_2024_01_03-11_12_17_backupiobroker.tar.gz
                            [DEBUG] [influxDB] - Try deleting the InfluxDB tmp directory: "/opt/iobroker/backups/influxDB_2024_01_03-11_12_17_backupiobroker"
                            [DEBUG] [influxDB] - InfluxDB tmp directory "/opt/iobroker/backups/influxDB_2024_01_03-11_12_17_backupiobroker" successfully deleted
                            [DEBUG] [influxDB] - Backup created: /opt/iobroker/backups/influxDB_2024_01_03-11_12_19_backupiobroker.tar.gz
                            [DEBUG] [influxDB] - Try deleting the InfluxDB tmp directory: "/opt/iobroker/backups/influxDB_2024_01_03-11_12_19_backupiobroker"
                            [DEBUG] [influxDB] - InfluxDB tmp directory "/opt/iobroker/backups/influxDB_2024_01_03-11_12_19_backupiobroker" successfully deleted
                            [DEBUG] [influxDB] - Backup created: /opt/iobroker/backups/influxDB_2024_01_03-11_12_20_backupiobroker.tar.gz
                            [DEBUG] [influxDB] - Try deleting the InfluxDB tmp directory: "/opt/iobroker/backups/influxDB_2024_01_03-11_12_20_backupiobroker"
                            [DEBUG] [influxDB] - InfluxDB tmp directory "/opt/iobroker/backups/influxDB_2024_01_03-11_12_20_backupiobroker" successfully deleted
                            [DEBUG] [influxDB] - Backup created: /opt/iobroker/backups/influxDB_2024_01_03-11_12_21_backupiobroker.tar.gz
                            [DEBUG] [influxDB] - Try deleting the InfluxDB tmp directory: "/opt/iobroker/backups/influxDB_2024_01_03-11_12_21_backupiobroker"
                            [DEBUG] [influxDB] - InfluxDB tmp directory "/opt/iobroker/backups/influxDB_2024_01_03-11_12_21_backupiobroker" successfully deleted
                            [DEBUG] [influxDB] - Backup created: /opt/iobroker/backups/influxDB_2024_01_03-11_12_26_backupiobroker.tar.gz
                            [DEBUG] [influxDB] - Try deleting the InfluxDB tmp directory: "/opt/iobroker/backups/influxDB_2024_01_03-11_12_26_backupiobroker"
                            [DEBUG] [influxDB] - InfluxDB tmp directory "/opt/iobroker/backups/influxDB_2024_01_03-11_12_26_backupiobroker" successfully deleted
                            [DEBUG] [influxDB] - Backup created: /opt/iobroker/backups/influxDB_2024_01_03-11_12_27_backupiobroker.tar.gz
                            [DEBUG] [influxDB] - Try deleting the InfluxDB tmp directory: "/opt/iobroker/backups/influxDB_2024_01_03-11_12_27_backupiobroker"
                            [DEBUG] [influxDB] - InfluxDB tmp directory "/opt/iobroker/backups/influxDB_2024_01_03-11_12_27_backupiobroker" successfully deleted
                            [DEBUG] [influxDB] - Backup created: /opt/iobroker/backups/influxDB_2024_01_03-11_12_28_backupiobroker.tar.gz
                            [DEBUG] [influxDB] - Try deleting the InfluxDB tmp directory: "/opt/iobroker/backups/influxDB_2024_01_03-11_12_28_backupiobroker"
                            [DEBUG] [influxDB] - InfluxDB tmp directory "/opt/iobroker/backups/influxDB_2024_01_03-11_12_28_backupiobroker" successfully deleted
                            [DEBUG] [cifs] - used copy path: /mnt/
                            [DEBUG] [cifs] - Copy iobroker_2024_01_03-11_12_14_backupiobroker.tar.gz...
                            [DEBUG] [cifs] - Copy influxDB_2024_01_03-11_12_17_backupiobroker.tar.gz...
                            [DEBUG] [cifs] - Copy influxDB_2024_01_03-11_12_19_backupiobroker.tar.gz...
                            [DEBUG] [cifs] - Copy influxDB_2024_01_03-11_12_20_backupiobroker.tar.gz...
                            [DEBUG] [cifs] - Copy influxDB_2024_01_03-11_12_21_backupiobroker.tar.gz...
                            [DEBUG] [cifs] - Copy influxDB_2024_01_03-11_12_26_backupiobroker.tar.gz...
                            [DEBUG] [cifs] - Copy influxDB_2024_01_03-11_12_27_backupiobroker.tar.gz...
                            [DEBUG] [cifs] - Copy influxDB_2024_01_03-11_12_28_backupiobroker.tar.gz...
                            [DEBUG] [cifs] - done
                            [DEBUG] [clean] - No older backup files are deleted, because this backup was started manually
                            [DEBUG] [clean] - done
                            [DEBUG] [historyHTML] - new history html values created
                            [DEBUG] [historyHTML] - done
                            [DEBUG] [historyJSON] - new history json values created
                            [DEBUG] [historyJSON] - done
                            [DEBUG] [umount] - done
                            [EXIT] 0
                            Lade ich nun die Influx Backups über die Backitup Oberfläche hoch, werden die Buckets nicht importiert
                            Proxmox 3Node Cluster, IOBroker in LXC
                            PV Visualisierung und Steuerung mit NodeRed und Grafana
                            simatecS Marc BergM 2 Antworten Letzte Antwort
                            • T Taddy81
                                              "status": "active",
                                              "permissions": [
                                                      "read:/buckets",
                                                      "write:/buckets",
                                                      "read:/dashboards",
                                                      "read:/orgs",
                                                      "write:/orgs",
                                                      "read:/sources",
                                                      "write:/sources",
                                                      "read:/tasks",
                                                      "write:/tasks",
                                                      "read:/telegrafs",
                                                      "write:/telegrafs",
                                                      "read:/users",
                                                      "write:/users",
                                                      "read:/variables",
                                                      "write:/variables",
                                                      "read:/scrapers",
                                                      "write:/scrapers",
                                                      "read:/secrets",
                                                      "write:/secrets",
                                                      "read:/labels",
                                                      "write:/labels",
                                                      "read:/views",
                                                      "write:/views",
                                                      "read:/documents",
                                                      "write:/documents",
                                                      "read:/checks",
                                                      "write:/checks",
                                                      "read:/dbrp",
                                                      "write:/dbrp",
                                                      "read:/notebooks",
                                                      "write:/notebooks",
                                                      "read:/remotes",
                                                      "write:/remotes",
                                              "status": "active",
                                              "permissions": [
                              Log von BackitUp
                              [EXIT] 0
                              simatecS Offline
                              simatecS Offline
                              simatec
                              #112
                              @taddy81 was meinst du genau mit hochladen? Laut Log werden deine Backups mit der Auswahl des richtigen Operator Token korrekt erstellt.
                              Beim „hochladen“ weiß ich nicht, was du da genau meinst
                              • T Taddy81
                                                "status": "active",
                                                "permissions": [
                                                        "read:/buckets",
                                                        "write:/buckets",
                                                        "read:/dashboards",
                                                        "read:/orgs",
                                                        "write:/orgs",
                                                        "read:/sources",
                                                        "write:/sources",
                                                        "read:/tasks",
                                                        "write:/tasks",
                                                        "read:/telegrafs",
                                                        "write:/telegrafs",
                                                        "read:/users",
                                                        "write:/users",
                                                        "read:/variables",
                                                        "write:/variables",
                                                        "read:/scrapers",
                                                        "write:/scrapers",
                                                        "read:/secrets",
                                                        "write:/secrets",
                                                        "read:/labels",
                                                        "write:/labels",
                                                        "read:/views",
                                                        "write:/views",
                                                        "read:/documents",
                                                        "write:/documents",
                                                        "read:/checks",
                                                        "write:/checks",
                                                        "read:/dbrp",
                                                        "write:/dbrp",
                                                        "read:/notebooks",
                                                        "write:/notebooks",
                                                        "read:/remotes",
                                                        "write:/remotes",
                                                "status": "active",
                                                "permissions": [
                                Log von BackitUp
                                [EXIT] 0
                                Marc BergM Offline
                                Marc BergM Offline
                                Marc Berg
                                #113
                                @taddy81 sagte in mit backitup kein Influxdb und Grafana backup möglich:
                                Ich gehe davon aus, dass du die Daten auf der neuen Instanz wiederherstellen willst, richtig?
                                Wenn du dort die InfluxDB neu installiert hast, benötigt du auch den Operator-Token der neuen DB. Das dürfte ein anderer sein, wenn du nicht den alten explizit beim Setup der DB angegeben hast.
                                • simatecS simatec
                                  Taddy81
                                  #114
                                  @simatec
                                  Danke für deine Antwort.
                                  Irgendwie habe ich nun alles zerschossen, ich habe die Backup Dateien über die GUI hochgeladen und diese dann über "Sicherung abrufen" hochgeladen.
                                  Nachdem ich dies gemacht habe, war in der Influx Datenbank kein Bucket hinzugefügt.
                                  Anschließend habe ich noch ein paar Influx Backups hochgeladen um diese nochmals Wiederherzustellen, aber nun läuft bei "Sicherung abrufen" nur ein blauer Balken oben durch, aber es erscheinen keine Backups mehr
                                  Wo finde ich denn unter SSH die Uploads auf der 2. Instanz?
                                  Ein find / -name ".tar.gz" ergibt kein Ergebnis
                                  • T Taddy81
                                    @simatec
                                    simatecS Offline
                                    simatecS Offline
                                    simatec
                                    #115
                                    @taddy81 schau mal…
                                    https://github.com/simatec/ioBroker.backitup/wiki/Diverse-Anleitungen-für-ioBroker.backitup#influxdb2-restore
                                    Damit sollte es funktionieren. Wichtig ist der richtige Operator Token deiner neuen Influx Installation
                                    • simatecS simatec
                                      @taddy81 schau mal…
                                      Taddy81
                                      #116
                                      @simatec
                                      Komme leider nicht weiter...
                                      Ich habe nun eine InfluxDB importieren wollen und bin auch nach deiner Anleitung vorgegangen.
                                      Ich habe die Organisation in Influx gleich benannt, war das nun richtig? Den Admin Token der NEUEN Influx Installation habe ich dann in die 3 Influx Instanzen geschrieben, nach einem Wiederherstellen erhalte ich folgende Fehlermeldung
                                      Started restore ...
                                      [DEBUG] [influxDB] - Created tmp directory
                                      [DEBUG] [influxDB] - Start infuxDB Restore ...
                                      [ERROR] [influxDB] - Error: failed to check existence of organization "homelab": 401 Unauthorized: unauthorized access
                                      [DEBUG] [influxDB] - InfluxDB tmp directory was successfully deleted
                                      [DEBUG] [influxDB] - infuxDB Restore completed successfully
                                      [EXIT] influxDB restore done
                                      oot@Influx2:~# influx auth list -t   r6cDtTGWFJR5UJe-jtnDkwdkHtYUPfrU25OU4Lb1rRxTEaA-vqdNZETg1MxoL3w0wTLnaNiLT4lPSzveAhkDEA== --json
                                                      "id": "0c5feb1b8e1fb000",
                                                      "token": "r6cDtTGWFJR5UJe-jtnDkwdkHtYUPfrU25OU4Lb1rRxTEaA-vqdNZETg1MxoL3w0wTLnaNiLT4lPSzveAhkDEA==",
                                                      "status": "active",
                                                      "userID": "0c5feb1b389fb000",
                                                      "permissions": [
                                                              "read:/buckets",
                                                              "write:/buckets",
                                                              "read:/dashboards",
                                                              "read:/orgs",
                                                              "write:/orgs",
                                                              "read:/sources",
                                                              "write:/sources",
                                                              "read:/tasks",
                                                              "write:/tasks",
                                                              "read:/telegrafs",
                                                              "write:/telegrafs",
                                                              "read:/users",
                                                              "write:/users",
                                                              "read:/variables",
                                                              "write:/variables",
                                                              "read:/scrapers",
                                                              "write:/scrapers",
                                                              "read:/secrets",
                                                              "write:/secrets",
                                                              "read:/labels",
                                                              "write:/labels",
                                                              "read:/views",
                                                              "write:/views",
                                                              "read:/documents",
                                                              "write:/documents",
                                                              "read:/checks",
                                                              "write:/checks",
                                                              "read:/dbrp",
                                                              "write:/dbrp",
                                                              "read:/notebooks",
                                                              "write:/notebooks",
                                                              "read:/remotes",
                                                              "write:/remotes",
                                      Und eine Frage für später, die Daten dieser 3 Influxinstanzen werden täglich in jeweils ein Langzeitbucket mit niedriger Auflösung geschrieben, ich nehme an, dass ich nur InfluxDatenbanken wiederherstellen kann, die auch in IOBroker eine Instanz haben?
                                      • T Taddy81
                                        @simatec
                                        Started restore ...
                                                        "status": "active",
                                                        "permissions": [
        "read:/buckets",
        "write:/buckets",
        "read:/dashboards",
        "read:/orgs",
        "write:/orgs",
        "read:/sources",
        "write:/sources",
        "read:/tasks",
        "write:/tasks",
        "read:/telegrafs",
        "write:/telegrafs",
        "read:/users",
        "write:/users",
        "read:/variables",
        "write:/variables",
        "read:/scrapers",
        "write:/scrapers",
        "read:/secrets",
        "write:/secrets",
        "read:/labels",
        "write:/labels",
        "read:/views",
        "write:/views",
        "read:/documents",
        "write:/documents",
        "read:/checks",
        "write:/checks",
        "read:/dbrp",
        "write:/dbrp",
        "read:/notebooks",
        "write:/notebooks",
        "read:/remotes",
        "write:/remotes",
                                        simatecS Offline
                                        simatecS Offline
                                        simatec
                                        #117
                                        Auch Backitup benötigt den Admin Token
                                        • simatecS simatec
                                          toki1973
                                          #118
                                          Ich habe bei mir in einer eigenen Instanz influx Version1.7.10 installiert. Wie komme ich denn an den Operator Token damit das Backitup funktioniert.
                                          NUC, PROXMOX, Grafana, Influx, Unify
