  4. [gelöst] Adapter lassen sich nicht Installieren!
Geplant Angeheftet Gesperrt Verschoben Gelöst ioBroker Allgemein
128 Beiträge 7 Kommentatoren 19.3k Aufrufe 4 Beobachtet
  • S Schweiz
    @homoran piVCCU
    john@raspberrypi:~ $ sudo apt install pivccu-modules-raspberrypi
    Reading package lists... Done
    E: Unable to locate package pivccu-modules-raspberrypi
    john@raspberrypi:~ $ echo "deb [signed-by=/usr/share/keyrings/debmatic.asc] http        s://apt.debmatic.de/debmatic stable main" | sudo tee /etc/apt/sources.list.d/deb        matic.list
    deb [signed-by=/usr/share/keyrings/debmatic.asc] https://apt.debmatic.de/debmati        c stable main
    john@raspberrypi:~ $ sudo apt update
    Get:2 http://archive.raspberrypi.com/debian bookworm InRelease [23.6 kB]
    Get:3 http://deb.debian.org/debian-security bookworm-security InRelease [48.0 kB        ]
    Get:4 http://deb.debian.org/debian bookworm-updates InRelease [52.1 kB]
    Get:5 https://apt.debmatic.de/debmatic stable InRelease [13.6 kB]
    Get:6 http://deb.debian.org/debian-security bookworm-security/main arm64 Package        s [128 kB]
    Get:7 http://deb.debian.org/debian-security bookworm-security/main armhf Package        s [125 kB]
    Get:8 http://deb.debian.org/debian-security bookworm-security/main Translation-e        n [77.3 kB]
    Get:9 http://archive.raspberrypi.com/debian bookworm/main armhf Packages [360 kB        ]
    Get:10 http://archive.raspberrypi.com/debian bookworm/main arm64 Packages [351 k        B]
    Get:11 http://deb.debian.org/debian bookworm-updates/main armhf Packages [10.9 k        B]
    Get:12 http://deb.debian.org/debian bookworm-updates/main arm64 Packages [11.4 k        B]
    Get:13 http://deb.debian.org/debian bookworm-updates/main Translation-en [13.1 k        B]
    Err:5 https://apt.debmatic.de/debmatic stable InRelease
      The following signatures couldn't be verified because the public key is not av        ailable: NO_PUBKEY 541230BA05C38BC4
    W: GPG error: https://apt.debmatic.de/debmatic stable InRelease: The following s        ignatures couldn't be verified because the public key is not available: NO_PUBKE        Y 541230BA05C38BC4
    E: The repository 'https://apt.debmatic.de/debmatic stable InRelease' is not sig        ned.
    N: Updating from such a repository can't be done securely, and is therefore disa        bled by default.
    N: See apt-secure(8) manpage for repository creation and user configuration deta        ils.
    john@raspberrypi:~ $ sudo apt install build-essential bison flex libssl-dev
    build-essential is already the newest version (12.9).
    bison is already the newest version (2:3.8.2+dfsg-1+b1).
    flex is already the newest version (2.6.4-8.2).
    libssl-dev is already the newest version (3.0.11-1~deb12u2+rpt1).
    0 upgraded, 0 newly installed, 0 to remove and 9 not upgraded.
    john@raspberrypi:~ $ sudo apt install raspberrypi-kernel-headers pivccu-modules-        dkm
    E: Unable to locate package pivccu-modules-dkm
    john@raspberrypi:~ $ echo "deb [signed-by=/usr/share/keyrings/debmatic.asc] https://apt.debmatic.de/debmatic stable main" | sudo tee /etc/apt/sources.list.d/debmatic.list
    Get:3 http://deb.debian.org/debian-security bookworm-security InRelease [48.0 kB]
    Get:6 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages [128 kB]
    Get:7 http://deb.debian.org/debian-security bookworm-security/main armhf Packages [125 kB]
    Get:8 http://deb.debian.org/debian-security bookworm-security/main Translation-en [77.3 kB]
    Get:9 http://archive.raspberrypi.com/debian bookworm/main armhf Packages [360 kB]
    Get:10 http://archive.raspberrypi.com/debian bookworm/main arm64 Packages [351 kB]
    Get:11 http://deb.debian.org/debian bookworm-updates/main armhf Packages [10.9 kB]
    Get:12 http://deb.debian.org/debian bookworm-updates/main arm64 Packages [11.4 kB]
    Get:13 http://deb.debian.org/debian bookworm-updates/main Translation-en [13.1 kB]
      The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 541230BA05C38BC4
    W: GPG error: https://apt.debmatic.de/debmatic stable InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 541230BA05C38BC4
    E: The repository 'https://apt.debmatic.de/debmatic stable InRelease' is not signed.
    N: Updating from such a repository can't be done securely, and is therefore disabled by default.
    N: See apt-secure(8) manpage for repository creation and user configuration details.
    john@raspberrypi:~ $ sudo apt install raspberrypi-kernel-headers pivccu-modules-dkm
    MFG Schweizer
    @schweiz sagte in Adapter lassen sich nicht Installieren!:
    und warum dann das debmatic repo?
    falsche Anleitung?
      falsche Anleitung?
      Schweiz
      nehme ich die Anleitung von https://github.com/alexreinert/piVCCU/blob/master/docs/setup/raspberrypi.md
      logge mich ein und erster schritt passiert schon nix... oder es dauert zu lange und ich bin ungeduldig...
      wget -q -O - https://apt.pivccu.de/piVCCU/public.key | sudo tee /usr/share/keyrings/pivccu.asc
      Last login: Tue Dec 26 14:45:45 2023 from 192.168.2.116
      john@raspberrypi:~ $ wget -q -O - https://apt.pivccu.de/piVCCU/public.key | sudo tee /usr/share/keyrings/pivccu.asc
      ^C
      john@raspberrypi:~ $ echo "deb [signed-by=/usr/share/keyrings/pivccu.asc] https://apt.pivccu.de/piVCCU stable main" | sudo tee /etc/apt/sources.list.d/pivccu.list
      Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
      Hit:3 http://archive.raspberrypi.com/debian bookworm InRelease
      Hit:4 http://deb.debian.org/debian bookworm-updates InRelease
      Get:6 https://apt.pivccu.de/piVCCU stable InRelease [13.6 kB]
      Err:6 https://apt.pivccu.de/piVCCU stable InRelease
      W: GPG error: https://apt.pivccu.de/piVCCU stable InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 541230BA05C38BC4
      E: The repository 'https://apt.pivccu.de/piVCCU stable InRelease' is not signed.
      0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
      john@raspberrypi:~ $ sudo apt install raspberrypi-kernel-headers pivccu-modules-dkms
      E: Unable to locate package pivccu-modules-dkms
      MFG Schweizer
      • S Schweiz
        ^C
        MFG Schweizer
        warten!
        Ein Abbruch mit STRG-C führt dazu, dass dir die Basis für die weiteren Befehle fehlt
          warten!
          Schweiz
          nunja, etwas weiter bin ich nun aber es lässt sich nicht Insatllieren, der Key ist ungültig?
          john@raspberrypi:~ $ john@raspberrypi:~ $ wget -q -O - https://apt.pivccu.de/piVCCU/public.key | sudo        tee /usr/share/keyrings/pivccu.asc
          -----BEGIN PGP PUBLIC KEY BLOCK-----
          Version: GnuPG v1.4.14 (GNU/Linux)
          mQENBFJsL6IBCADMlaNsEi/      --    gelöscht     --
          -----END PGP PUBLIC KEY BLOCK-----
          john@raspberrypi:~ $ echo "deb [signed-by=/usr/share/keyrings/pivccu.asc] https:        //apt.pivccu.de/piVCCU stable main" | sudo tee /etc/apt/sources.list.d/pivccu.li        st
          sudo apt update
          deb [signed-by=/usr/share/keyrings/pivccu.asc] https://apt.pivccu.de/piVCCU stab        le main
          Hit:2 http://archive.raspberrypi.com/debian bookworm InRelease
          Hit:3 http://deb.debian.org/debian-security bookworm-security InRelease
          Get:5 https://apt.pivccu.de/piVCCU stable InRelease [13.6 kB]
          Get:6 https://apt.debmatic.de/debmatic stable InRelease [13.6 kB]
          Get:7 https://apt.pivccu.de/piVCCU stable/main arm64 Packages [14.0 kB]
          Get:8 https://apt.pivccu.de/piVCCU stable/main armhf Packages [14.2 kB]
          Err:6 https://apt.debmatic.de/debmatic stable InRelease
          W: GPG error: https://apt.debmatic.de/debmatic stable InRelease: The following s        ignatures couldn't be verified because the public key is not available: NO_PUBKE        john@raspberrypi:~ $ manpage for repository creation and user configuration deta
          -bash: john@raspberrypi:~: command not found
          -bash: -----BEGIN: command not found
          -bash: syntax error near unexpected token `('
          -bash: G E L Ö S C H T Fm: No such file or directory
          Err:5 https://apt.pivccu.de/piVCCU stable InRelease
          N: Ignoring file 'pivccu.li' in directory '/etc/apt/sources.list.d/' as it has an invalid filename extension
          W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://apt.pivccu.de/piVCCU stable InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 541230BA05C38BC4
          MOD-EDIT: Code in code-tags gesetzt und Key gelöscht!
          MFG Schweizer
          • S Schweiz
            sudo apt update
            MFG Schweizer
            Schweiz
            ich bin mal einfach weiter gegangen in der Install
            The following additional packages will be installed:
              dkms
            Suggested packages:
              menu
            The following NEW packages will be installed:
              dkms pivccu-modules-dkms raspberrypi-kernel-headers
            0 upgraded, 3 newly installed, 0 to remove and 0 not upgraded.
            Need to get 10.3 MB of archives.
            After this operation, 65.0 MB of additional disk space will be used.
            Do you want to continue? [Y/n] y
            Get:1 http://deb.debian.org/debian bookworm/main arm64 dkms all 3.0.10-8+deb12u1 [48.7 kB]
            Get:2 http://archive.raspberrypi.com/debian bookworm/main arm64 raspberrypi-kernel-headers arm64 1:1.20230405-1 [10.2 MB]
            Get:3 https://apt.pivccu.de/piVCCU stable/main arm64 pivccu-modules-dkms all 1.0.84 [43.1 kB]
            Fetched 10.3 MB in 4s (2,853 kB/s)
            Preconfiguring packages ...
            Selecting previously unselected package dkms.
            (Reading database ... 55552 files and directories currently installed.)
            Preparing to unpack .../dkms_3.0.10-8+deb12u1_all.deb ...
            Unpacking dkms (3.0.10-8+deb12u1) ...
            Setting up dkms (3.0.10-8+deb12u1) ...
            Selecting previously unselected package pivccu-modules-dkms.
            (Reading database ... 55576 files and directories currently installed.)
            Preparing to unpack .../pivccu-modules-dkms_1.0.84_all.deb ...
            Unpacking pivccu-modules-dkms (1.0.84) ...
            Selecting previously unselected package raspberrypi-kernel-headers.
            Preparing to unpack .../raspberrypi-kernel-headers_1%3a1.20230405-1_arm64.deb ...
            Unpacking raspberrypi-kernel-headers (1:1.20230405-1) ...
            Setting up raspberrypi-kernel-headers (1:1.20230405-1) ...
            run-parts: executing /etc/kernel/header_postinst.d/dkms 6.1.21+
            dkms: autoinstall for kernel 6.1.21+ was skipped since the kernel headers for this kernel do not seem to be installed.
            run-parts: executing /etc/kernel/header_postinst.d/dkms 6.1.21-v7+
            dkms: autoinstall for kernel 6.1.21-v7+ was skipped since the kernel headers for this kernel do not seem to be installed.
            run-parts: executing /etc/kernel/header_postinst.d/dkms 6.1.21-v7l+
            dkms: autoinstall for kernel 6.1.21-v7l+ was skipped since the kernel headers for this kernel do not seem to be installed.
            run-parts: executing /etc/kernel/header_postinst.d/dkms 6.1.21-v8+
            dkms: running auto installation service for kernel 6.1.21-v8+.
            dkms: autoinstall for kernel: 6.1.21-v8+.
            Setting up pivccu-modules-dkms (1.0.84) ...
            Ensure non mixed processor architecure ... Done
            Create kernel modules ... Done
            Enable DKMS service ... Done
            Processing triggers for man-db (2.11.2-2) ...
            mal einen neustart machen...
            MFG Schweizer
            • S Schweiz
                dkms
              Suggested packages:
                menu
              MFG Schweizer
              warum?
              was war da mit dem Key?
              ich hatte mal keine Zeit!
              warum?
              der ist noch nicht fertig
              immer warten bis der Prompt wieder erscheint!
              hast du anscheinend auch ganz oben nicht gemacht.
              und zieh mal das putty Fenster größer damit die Zeilen vollständig sind
              das debmatic repo spukt da auch noch rum.
              Mach am besten alles komplett neu.
              und dann Zeile für Zeile abarbeiten bis der Prompt kommt, dann erst weitermachen.
              Was für ein Pi ist das denn?
                Schweiz
                schrieb am zuletzt editiert von Schweiz
                RP4
                musste noch Node installieren, IOBroker läuft nun, nur lässt sich immernoch kein Adapter installieren...
                Das fenster geht auf, es steht
                $ iobroker add alexa2 --host raspberrypi
                NPM version: 10.2.3
                Installing iobroker.alexa2@3.26.3... (System call)
                npm ERR! code ETIMEDOUTnpm ERR! syscall connectnpm ERR! errno ETIMEDOUTnpm ERR! network request to https://registry.npmjs.org/iobroker.alexa2 failed, reason: connect ETIMEDOUT 2606:4700::6810:1e22:443npm ERR! network This is a problem related to network connectivity.npm ERR! network In most cases you are behind a proxy or have bad network settings.npm ERR! network npm ERR! network If you are behind a proxy, please make sure that thenpm ERR! network 'proxy' config is set properly. See: 'npm help config'npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-12-26T18_25_44_393Z-debug-0.log
                host.raspberrypi Cannot install iobroker.alexa2@3.26.3: 1
                ERROR: Process exited with code 25
                oben läuft die blaue Leiste, 10 min... so lange hat es nie gedauert dann bricht es mit dem fehler oben ab...
                MFG Schweizer
                • S Schweiz
                  RP4
                  NPM version: 10.2.3
                  MFG Schweizer
                  doch nicht für piVCCU!
                  und für iobroker passiert das mit dem Installer.
                  bitte das aktuelle iob diag full
                  EDIT:
                  Nie nicht niemals nachträglich posts verändern ohne es zu markieren!
                  • S Schweiz
                    RP4
                    NPM version: 10.2.3
                    MFG Schweizer
                    das passt auch zu deinen piVCCU Problemen
                      Schweiz
                      CCU geht, und das alte Backup ist drin, Geräte laufen...
                      Copy text starting here:
                                              v.2023-10-10
                       Static hostname: raspberrypi
                             Icon name: computer
                                Kernel: Linux 6.1.0-rpi7-rpi-v8
                          Architecture: arm64
                      Kernel:                 aarch64
                      Userland:               arm64
                      Timezone:               Europe/London (GMT, +0000)
                      User-ID:                1000
                      X-Server:               false
                      Boot Target:            multi-user.target
                      Pending OS-Updates:     0
                      Pending iob updates:    0
                      Nodejs-Installation:    /usr/bin/nodejs         v18.19.0
                                              /usr/bin/node           v18.19.0
                                              /usr/bin/npm            10.2.3
                      ^C
                      ok, sorry mit dem Edit...
                       iob diag das grosse log kann ich nicht kopieren, weil unten steh weiter mit einer Taste, sobald ich kopieren will geht es weiter... :(
                      MFG Schweizer
                      • S Schweiz
                                                v.2023-10-10
                               Icon name: computer
                            Architecture: arm64
                        Kernel:                 aarch64
                        Userland:               arm64
                        User-ID:                1000
                        X-Server:               false
                                                /usr/bin/npm            10.2.3
                        ^C
                        MFG Schweizer
                        Schweiz
                        Skript v.2023-10-10
                        *** BASE SYSTEM ***
                               Icon name: computer
                            Architecture: arm64
                        Model           : Raspberry Pi 4 Model B Rev 1.1
                        Docker          : false
                        Virtualization  : none
                        Kernel          : aarch64
                        Userland        : arm64
                        Systemuptime and Load:
                         18:49:52 up 39 min,  2 users,  load average: 0.72, 0.48, 0.38
                        CPU threads: 4
                        *** RASPBERRY THROTTLING ***
                        Current issues:
                        Previously detected issues:
                        *** Time and Time Zones ***
                                       Local time: Tue 2023-12-26 18:49:52 GMT
                                   Universal time: Tue 2023-12-26 18:49:52 UTC
                                         RTC time: n/a
                                        Time zone: Europe/London (GMT, +0000)
                                      NTP service: active
                                  RTC in local TZ: no
                        *** User and Groups ***
                        john
                        /home/john
                        john adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
                        *** X-Server-Setup ***
                        X-Server:       false
                        Desktop:
                        Terminal:       tty
                        *** MEMORY ***
                        Mem:            4.0G        819M        2.1G        1.3M        1.1G        3.2G
                        Swap:           104M          0B        104M
                        Total:          4.1G        819M        2.2G
                                 3793 M total memory
                                  781 M used memory
                                  840 M active memory
                                  746 M inactive memory
                                 2018 M free memory
                                   64 M buffer memory
                                 1005 M swap cache
                                   99 M total swap
                                    0 M used swap
                                   99 M free swap
                        Raspberry only:
                        oom events: 0
                        *** FAILED SERVICES ***
                        0 loaded units listed.
                        *** FILESYSTEM ***
                        udev           devtmpfs  1.6G     0  1.6G   0% /dev
                        tmpfs          tmpfs     380M  1.2M  379M   1% /run
                        /dev/mmcblk0p2 ext4       29G  3.3G   25G  12% /
                        tmpfs          tmpfs     5.0M   16K  5.0M   1% /run/lock
                        /dev/mmcblk0p1 vfat      510M   62M  449M  13% /boot/firmware
                        tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
                        [Tue Dec 26 18:10:21 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:29:88:49 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=fed7638c-02 rootfstype=ext4 fsck.repair=yes rootwait
                        [Tue Dec 26 18:10:23 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                        [Tue Dec 26 18:10:25 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                        TARGET           SOURCE         FSTYPE OPTIONS
                        /                /dev/mmcblk0p2 ext4   rw,noatime
                        `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                        /var:
                        1.2G    /var/
                        826M    /var/lib
                        661M    /var/lib/piVCCU3
                        604M    /var/lib/piVCCU3/rootfs
                        279M    /var/lib/piVCCU3/rootfs/opt
                        Archived and active journals take up 64.0M in the file system.
                        /opt/iobroker/backups:
                        4.0K    /opt/iobroker/backups/
                        /opt/iobroker/iobroker-data:
                        19M     /opt/iobroker/iobroker-data/
                        15M     /opt/iobroker/iobroker-data/files
                        13M     /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
                        6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
                        4.0M    /opt/iobroker/iobroker-data/objects.jsonl
                        2.8M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js
                        1.6M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map
                        652K    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js.map
                        USB-Devices by-id:
                        find: '/dev/serial/by-id/': No such file or directory
                        *** NodeJS-Installation ***
                        /usr/bin/npm            10.2.3
                        /usr/bin/npx            10.2.3
                        /usr/bin/corepack       0.22.0
                        nodejs:
                          Installed: 18.19.0-1nodesource1
                          Candidate: 18.19.0-1nodesource1
                          Version table:
                         *** 18.19.0-1nodesource1 500
                                500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages
                             18.18.2-1nodesource1 500
                             18.18.1-1nodesource1 500
                             18.18.0-1nodesource1 500
                             18.17.1-1nodesource1 500
                             18.17.0-1nodesource1 500
                             18.16.1-1nodesource1 500
                             18.16.0-1nodesource1 500
                             18.15.0-1nodesource1 500
                             18.14.2-1nodesource1 500
                             18.14.1-1nodesource1 500
                             18.14.0-1nodesource1 500
                             18.13.0+dfsg1-1 500
                                500 http://deb.debian.org/debian bookworm/main arm64 Packages
                             18.13.0-1nodesource1 500
                             18.12.0-1nodesource1 500
                             18.11.0-1nodesource1 500
                             18.10.0-1nodesource1 500
                             18.9.1-1nodesource1 500
                             18.9.0-1nodesource1 500
                             18.8.0-1nodesource1 500
                             18.7.0-1nodesource1 500
                             18.6.0-1nodesource1 500
                             18.5.0-1nodesource1 500
                             18.4.0-1nodesource1 500
                             18.3.0-1nodesource1 500
                             18.2.0-1nodesource1 500
                             18.1.0-1nodesource1 500
                             18.0.0-1nodesource1 500
                        No problems detected
                        Errors in npm tree:
                        *** ioBroker-Installation ***
                        ioBroker Status
                        Objects type: jsonl
                        States  type: jsonl
                        Core adapters versions
                        js-controller:  5.0.17
                        admin:          6.12.0
                        javascript:     "javascript" not found
                        Adapters from github:   0
                        Adapter State
                        + instance is alive
                        ioBroker-Repositories
                        Active repo(s): stable
                        Installed ioBroker-Instances
                        Used repository: stable
                        Adapter    "admin"        : 6.12.0   , installed 6.12.0
                        Adapter    "backitup"     : 2.9.8    , installed 2.9.8
                        Adapter    "discovery"    : 4.2.0    , installed 4.2.0
                        Controller "js-controller": 5.0.17   , installed 5.0.17
                        Objects and States
                        Objects:        143
                        States:         106
                        Pending Updates: 0
                        *** Listening Ports ***
                        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14969      968/sshd: /usr/sbin
                        tcp        0      0 10.0.3.1:53             0.0.0.0:*               LISTEN      0          16511      1039/dnsmasq
                        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       41119      9275/iobroker.js-co
                        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       41112      9275/iobroker.js-co
                        tcp6       0      0 :::22                   :::*                    LISTEN      0          14971      968/sshd: /usr/sbin
                        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       43792      9754/io.admin.0
                        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        14782      534/avahi-daemon: r
                        udp        0      0 0.0.0.0:38951           0.0.0.0:*                           104        14784      534/avahi-daemon: r
                        udp        0      0 10.0.3.1:53             0.0.0.0:*                           0          16510      1039/dnsmasq
                        udp        0      0 0.0.0.0:67              0.0.0.0:*                           0          16507      1039/dnsmasq
                        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14924      889/dhclient
                        udp6       0      0 :::5353                 :::*                                104        14783      534/avahi-daemon: r
                        udp6       0      0 :::34621                :::*                                104        14785      534/avahi-daemon: r
                        2023-12-26 18:20:30.854  - info: admin.0 (9754) received all objects
                        2023-12-26 18:20:30.937  - warn: admin.0 (9754) Repository cannot be read: Active repo - stable
                        2023-12-26 18:20:30.939  - warn: admin.0 (9754) Active repository "stable" cannot be read
                        2023-12-26 18:20:31.082  - info: admin.0 (9754) socket.io server listening on port 8081
                        2023-12-26 18:20:31.087  - info: admin.0 (9754) http server listening on port 8081
                        2023-12-26 18:20:31.087  - info: admin.0 (9754) Use link "http://127.0.0.1:8081" to configure.
                        2023-12-26 18:20:31.350  - info: admin.0 (9754) failed connection to socket.io from ::ffff:192.168.2.116: Passport was not initialized
                        2023-12-26 18:20:31.782  - info: admin.0 (9754) failed connection to socket.io from ::ffff:192.168.2.116: Passport was not initialized
                        2023-12-26 18:20:48.435  - info: admin.0 (9754) ==> Connected system.user.admin from ::ffff:192.168.2.116
                        2023-12-26 18:20:48.914  - info: host.raspberrypi Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
                        2023-12-26 18:21:13.453  - info: admin.0 (9754) <== Disconnect system.user.admin from ::ffff:192.168.2.116 admin
                        2023-12-26 18:21:49.280  - info: admin.0 (9754) ==> Connected system.user.admin from ::ffff:192.168.2.116
                        2023-12-26 18:21:58.099  - info: admin.0 (9754) <== Disconnect system.user.admin from ::ffff:192.168.2.116 admin
                        2023-12-26 18:22:15.352  - info: admin.0 (9754) ==> Connected system.user.admin from ::ffff:192.168.2.116
                        2023-12-26 18:22:15.648  - info: admin.0 (9754) <== Disconnect system.user.admin from ::ffff:192.168.2.116 admin
                        2023-12-26 18:22:21.951  - info: admin.0 (9754) ==> Connected system.user.admin from ::ffff:192.168.2.116
                        2023-12-26 18:25:39.843  - info: host.raspberrypi iobroker add alexa2 --host raspberrypi
                        2023-12-26 18:25:43.464  - info: host.raspberrypi iobroker NPM version: 10.2.3
                        2023-12-26 18:25:43.466  - info: host.raspberrypi iobroker Installing iobroker.alexa2@3.26.3... (System call)
                        2023-12-26 18:33:27.397  - error: host.raspberrypi iobroker npm ERR! code ETIMEDOUTnpm ERR! syscall connectnpm ERR! errno ETIMEDOUTnpm ERR! network request to https://registry.npmjs.org/iobroker.alexa2 failed, reason: connect ETIMEDOUT 2606:4700::6810:1e22:443npm ERR! network This is a problem related to network connectivity.npm ERR! network In most cases you are behind a proxy or have bad network settings.npm ERR! network npm ERR! network If you are behind a proxy, please make sure that thenpm ERR! network 'proxy' config is set properly.  See: 'npm help config'npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-12-26T18_25_44_393Z-debug-0.log
                        2023-12-26 18:33:27.402  - error: host.raspberrypi iobroker host.raspberrypi Cannot install iobroker.alexa2@3.26.3: 1
                        2023-12-26 18:33:28.436  - info: host.raspberrypi iobroker exit 25
                        2023-12-26 18:45:27.826  - info: host.raspberrypi iobroker add hm-rega --host raspberrypi
                        2023-12-26 18:45:31.546  - info: host.raspberrypi iobroker NPM version: 10.2.3
                        2023-12-26 18:45:31.549  - info: host.raspberrypi iobroker Installing iobroker.hm-rega@4.0.0... (System call)
                        iob diag has finished.
                        • S Schweiz
                          Skript v.2023-10-10
                          *** BASE SYSTEM ***
                                 Icon name: computer
                              Architecture: arm64
                          Docker          : false
                          Kernel          : aarch64
                          Userland        : arm64
                          CPU threads: 4
                          Current issues:
                                           RTC time: n/a
                                        NTP service: active
                                    RTC in local TZ: no
                          john
                          /home/john
                          X-Server:       false
                          Desktop:
                          Terminal:       tty
                          *** MEMORY ***
                          Swap:           104M          0B        104M
                                   3793 M total memory
                                    781 M used memory
                                    840 M active memory
                                   2018 M free memory
                                     64 M buffer memory
                                   1005 M swap cache
                                     99 M total swap
                                      0 M used swap
                                     99 M free swap
                          Raspberry only:
                          oom events: 0
                          *** FILESYSTEM ***
                          /var:
                          1.2G    /var/
                          826M    /var/lib
                          USB-Devices by-id:
                          /usr/bin/npm            10.2.3
                          /usr/bin/npx            10.2.3
                          nodejs:
                            Version table:
                               18.13.0+dfsg1-1 500
                          Errors in npm tree:
                          ioBroker Status
                          Objects type: jsonl
                          States  type: jsonl
                          admin:          6.12.0
                          Adapter State
                          + instance is alive
                          Objects and States
                          Objects:        143
                          States:         106
                          Pending Updates: 0
                          da ist das unsignierte debmatic und kein piVCCU repo!
                          sonst nichts aufregendes bis auf die Probleme mit dem Zugriff auf npm
                          könnte ein kurzzeitiges Problem mit deren Server sein, muss aber nicht.
                          später nochmal versuchen, ggf. über due Konsole mit iob add alexa2 --debug
                            Schweiz
                            hmmm, ok soweit läuft ja CCU und IOBm beides über eigene IP, nur das ich im IOB nix hinzufügen kann...
                            Ich schau mal morgen nochmal rein, hab heute auch nicht mehr die lust, sitze schon so lange an der Kiste und gefühlt geht nix...
                            Erst einmal Herzlichen Dank für die Geduld mit mir und die erbrachte Hilfe ;)
                            iob add alexa2 --debug geht auf Console auch nicht voran...
                            NPM version: 10.2.3
                            npm ERR! network
                            npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-12-26T18_58_23_191Z-debug-0.log
                            npm ERR! network
                            MFG Schweizer
                            • S Schweiz
                              NPM version: 10.2.3
                              npm ERR! network
                              npm ERR! network
                              MFG Schweizer
                              Schweiz
                              john@raspberrypi:/opt/iobroker $ iobroker fix
                              library: loaded
                              Library version=2023-10-13
                                  Welcome to the ioBroker installation fixer!
                                  Script version: 2023-10-13
                                  You might need to enter your password a couple of times.
                                  Installing prerequisites (1/5)
                              Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
                              Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
                              Get:7 https://apt.debmatic.de/debmatic stable InRelease [13.6 kB]
                              Err:7 https://apt.debmatic.de/debmatic stable InRelease
                              Installed acl
                              Installed libavahi-compat-libdnssd-dev
                              Installed libudev-dev
                              Installed libpam0g-dev
                              Installed git
                              Installed libcairo2-dev
                              Installed libpango1.0-dev
                              Installed libjpeg-dev
                              Installed libgif-dev
                              Installed librsvg2-dev
                              Installed libpixman-1-dev
                              Installed cmake
                                  Checking ioBroker user and directory permissions (2/5)
                              This system does not support setting default permissions.
                              Do not use npm to manually install adapters unless you know what you are doing!
                                  Check and cleanup npm temporary directories (3/5)
                              Done.
                                  Database maintenance (4/5)
                              Checking for uncompressed JSONL databases... This might take a while!
                              npm ERR! network request to https://registry.npmjs.org/@iobroker%2fjsonltool failed, reason: connect ETIMEDOUT 2606:4700::6810:1e22:443
                              npm ERR! network
                              npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-12-26T19_12_31_342Z-debug-0.log
                                  Checking autostart (5/5)
                              Enabling autostart...
                              Autostart enabled!
                                  Your installation was fixed successfully
                                  Run iobroker start to start ioBroker again!
                              das ist aus IOB FIX, kann aber im npm help config nix finden bzgl. der Netzwerk Konfig...
                              MFG Schweizer
                              • S Schweiz
                                library: loaded
                                Installed acl
                                Installed git
                                Installed cmake
                                Done.
                                npm ERR! network
                                Autostart enabled!
                                MFG Schweizer
                                @schweiz du hast probleme mit dem Internet.
                                Möglicherweise mit IPv6
                                • S Schweiz
                                  library: loaded
                                  Installed acl
                                  Installed git
                                  Installed cmake
                                  Done.
                                  npm ERR! network
                                  Autostart enabled!
                                  MFG Schweizer
                                  @schweiz
                                  Sitzt du auf der Insel?
                                    @schweiz
                                    Schweiz
                                    bin zwar Engländer, aber nein...
                                    MFG Schweizer
                                    • S Schweiz
                                      MFG Schweizer
                                      @schweiz
                                      Dann ändere es auf die korrekte Zeitzone ab.
                                      Spart dir Rückfragen, warum irgendwas zur falschen Zeit ausgeführt wird. Und Trouble im Netzwerk auch.
                                        @schweiz
                                        Schweiz
                                        super, ich DANKE EUCH BEIDEN...
                                        die Uhrzeit hat er mir nach der konfig richtig angezeigt, und nun scheint es zu gehen...
                                        MFG Schweizer
                                        • S Schweiz
                                          MFG Schweizer
                                          @schweiz dann musst du jetzt nur noch dein piVCCU repo anlegen und dafür das debmatic repo wieder loswerden.
                                          Vielleicht kann dir @Thomas-Braun dabei unter die Arme greifen. ich kann so was nicht.
