  4. [Neuer Adapter] Life360
    6.4k
adapterlife360geopositionpräsenzmelder
708 Beiträge 85 Kommentatoren 273.9k Aufrufe 70 Beobachtet
  • CKMartensC CKMartens
    @mrdisaster04 Ja fing um 2:30 heut nacht an.
    2023-12-24 02:31:18.433 - error: life360.0 (129585) Connection established but failed to authenticate. Check your credentials!
    2023-12-24 02:31:18.438 - info: life360.0 (129585) Waiting for online operations to finish ...
    2023-12-24 02:31:18.438 - info: life360.0 (129585) Disconnected from Life360 cloud services.
    2023-12-24 02:31:18.680 - error: life360.0 (129585) Connection established but failed to authenticate. Check your credentials!
    2023-12-24 02:31:18.681 - info: life360.0 (129585) Waiting for online operations to finish ...
    2023-12-24 02:31:18.923 - error: life360.0 (129585) Connection established but failed to authenticate. Check your credentials!
    2023-12-24 02:31:18.924 - info: life360.0 (129585) Waiting for online operations to finish ...
    2023-12-24 02:31:19.270 - error: life360.0 (129585) Connection established but failed to authenticate. Check your credentials!
    2023-12-24 02:31:19.271 - info: life360.0 (129585) Waiting for online operations to finish ...
    2023-12-24 02:31:19.495 - error: life360.0 (129585) Connection established but failed to authenticate. Check your credentials!
    2023-12-24 02:31:19.497 - info: life360.0 (129585) Waiting for online operations to finish ...
    2023-12-24 02:31:19.732 - error: life360.0 (129585) Connection established but failed to authenticate. Check your credentials!
    2023-12-24 02:31:19.733 - info: life360.0 (129585) Waiting for online operations to finish ...
    2023-12-24 02:31:19.733 - error: life360.0 (129585) Failed to connect or to login for 6 times. Aborting ...
    2023-12-24 02:31:19.734 - error: life360.0 (129585) Error: Error: Connection established but failed to authenticate. Check your credentials!
    2023-12-24 02:31:19.734 - warn: life360.0 (129585) No data received from Life360 cloud services!
    MiGollerM Offline
    MiGollerM Offline
    MiGoller
    #519
    Guten Morgen zusammen, das ist ja eine Bescherung. Dier Störung behandeln wir in Github unter https://github.com/MiGoller/ioBroker.life360/issues/86 .
    Bislang kann ich den Fehler allerdings nicht nachstellen: Es läuft bei mir auf dem produktiven wie auch auf meinem Entwicklungsserver ohne Probleme. Das macht es mir grad schwierig, etwas zu tun. Bislang sieht es so aus, als würde auch das Neuinstallieren des Adapters nicht helfen, wenn das Problem aufgetreten ist.
    Ich versuche, einen einfachen Checker zu programmieren, mit dem Ihr die Funktionalität ohne den Adapter testen könnt. Das an Heiligabend... macht meine Family nicht happy.
    ioBroker auf Intel Atom x5-Z8350 mit KNX, Gardena, Roomba, MQTT, Sonoff, Life360
    MiGollerM 1 Antwort Letzte Antwort
    • MiGollerM MiGoller
      MiGollerM Offline
      MiGollerM Offline
      MiGoller
      #520
      Bei einem Benutzer war das Life360 Kennwort abgelaufen. Ist beim erneuten Anmelden in der mobilen App aufgefallen. Das neue Passwort im ioBroker eingetragen. und dann lief es wieder. Mal schauen, ob das ein Einzelfall ist.
        MiGollerM Offline
        MiGollerM Offline
        MiGoller
        #521
        Mehrere Nutzer melden, dass deren Kennwörter abgelaufen waren, und dass der Adapter nach dem Ändern des Life360-Kennworts über die mobile App wieder läuft; mit dem neuen Kennwort natürlich.
        PischleuderP 1 Antwort Letzte Antwort
          PischleuderP Online
          PischleuderP Online
          Pischleuder
          #522
          @migoller
          Servus,
          stimmt, habe das Passwort in der App geändert und in iobroker eingetragen - läuft.
          Heute musst Du nichts ändern, kümmere Dich um die Familie, die ist viel wichtiger 🖖
          • PischleuderP Pischleuder
            @migoller
            Servus,
            MiGollerM Offline
            MiGollerM Offline
            MiGoller
            #523
            @pischleuder Danke, da hätte ich sonst auch noch besondere Geschenke additiv für die Family besorgen müssen. ;-)
            Wünsche Euch frohe Festtage.
              Markus 8
              #524
              Tatsache, bei mir lag es auch am Passwort habe es geändert und der Adapter läuft wieder. Ich wünsche allen schöne Weihnachten. Gruß Markus
              • BananaJoeB Offline
                BananaJoeB Offline
                BananaJoe
                #525
                Hier das gleiche, Kennwort in der App geändert und es ging wieder!
                  michael 1975
                  #526
                  Hier das selbe nach Passwort änderung geht alles wieder.
                  Schöne Weihnachten
                  • M michael 1975
                    Schöne Weihnachten
                    MiGollerM Offline
                    MiGollerM Offline
                    MiGoller
                    #527
                    Es wäre so schön, wenn Life360 einfach mal die API veröffentlichen würde, aber das Leben ist kein Ponyhof.
                      BananaJoeB Offline
                      BananaJoe
                      #528
                      Zu früh gefreut? Auf meinen VIS sieht alles ok aus (also wo wer gerade ist), im Log sehen ich
                      2023-12-24 12:32:18.232  - info: life360.0 (2650664) starting. Version 0.2.22 (non-npm: MiGoller/ioBroker.life360#23166aab1b2e36d917a9b7b480d9faa7f73ca2d1) in /opt/iobroker/node_modules/iobroker.life360, node: v18.19.0, js-controller: 5.0.17
                      2023-12-24 12:32:18.262  - info: life360.0 (2650664) Polling enabled every 60 seconds.
                      2023-12-24 12:32:25.517  - info: life360.0 (2650664) Connected to Life360 cloud services.
                      2023-12-24 12:34:19.531  - warn: life360.0 (2650664) Life360 circle data expected but missing!
                      2023-12-24 12:34:19.532  - warn: life360.0 (2650664) No circle data received from Life360. Aborting.
                      2023-12-24 12:35:19.574  - warn: life360.0 (2650664) Life360 circle data expected but missing!
                      2023-12-24 12:35:19.575  - warn: life360.0 (2650664) No circle data received from Life360. Aborting.
                      2023-12-24 12:37:19.662  - warn: life360.0 (2650664) Life360 circle data expected but missing!
                      2023-12-24 12:37:19.663  - warn: life360.0 (2650664) No circle data received from Life360. Aborting.
                      2023-12-24 12:38:19.659  - warn: life360.0 (2650664) Life360 circle data expected but missing!
                      2023-12-24 12:38:19.660  - warn: life360.0 (2650664) No circle data received from Life360. Aborting.
                      2023-12-24 12:39:19.477  - warn: life360.0 (2650664) Life360 circle data expected but missing!
                      2023-12-24 12:39:19.477  - warn: life360.0 (2650664) No circle data received from Life360. Aborting.
                      Nachtrag: Der Inhalt des Kreises passt aber, er fragt ja alle 60 Sekunden ab, und mein Skript was es auswertet zeigt die korrekten Orte an (Mädels sind gerade auf dem Reithof).
                      Die Meldung kommt ja auch nicht bei jedem Abruf.
                      Hab den Adapter noch mal neu gestartet und nun ist seit 5 Minuten Ruhe ... ich beobachte das mal
                      MiGollerM CKMartensC 2 Antworten Letzte Antwort
                      • BananaJoeB BananaJoe
                        MiGollerM Offline
                        MiGollerM Offline
                        MiGoller
                        #529
                        @bananajoe Wahrscheinlich durfte sich der vom Adapter ausgehandelte Token wieder anmelden, aber die API hatte noch zwischengespeicherte Inhalte, also hier jetzt keine, oder die Berechtigung war noch nicht wieder durchgängig auf allen Servern angekommen. Das muss ich Life360 bei einem global verteilten Netzwerk durchaus zugestehen.
                          CKMartensC Offline
                          CKMartensC Offline
                          CKMartens
                          #530
                          @bananajoe Bei mir hat es geholfen ein neues Passwort in der App zu vergeben. Kann auch das bestehende Passwort neu gesetzt werden.
                            BananaJoeB Offline
                            BananaJoe
                            #531
                            Öhm, ist mir fast etwas peinlich, aber: Kann man das Kennwort das im Adapter hinterlegt ist wieder extrahieren?
                            Ich hatte es nach dem Ändern in meinen Passwortmanager eingetragen, aber wohl nicht gespeichert.
                            Danke!
                              Danke!
                              BananaJoeB Offline
                              BananaJoeB Offline
                              BananaJoe
                              #532
                              @bananajoe und ich habe es selbst Lösen können, steht im Experten-Modus in den Eigenschaften der Instanz unter System:
                                SidM
                                #533
                                Ich habe vor 2 stunden auch bemerkt, dass ich die gleichen Fehlermeldungen im LOG bekomme.
                                Habe das Passwort in der App auf dem iPhone geändert und anschließend im Adapter. Leider bleibt die Meldung und zusätzlich werde ich ca. aller 10min aus der App ausgeloggt.
                                Es kann aber auch Möglich sein, dass dies am neuen Smartphone liegt, da ich auch schon länger nicht mehr ins Protokoll geschaut habe.
                                • malorossM Offline
                                  malorossM Offline
                                  maloross
                                  #534
                                  bisher läuft der Adapter stabil, obwohl ich mehrmals täglich diesen Report (Auszug) erhalte, der Adapter bleibt aber grün und Daten werden auch regelmäßig aktualisiert. Passwort musste ich bisher nicht erneuern.
                                  2023-12-27 22:21:52.249	debug	Auth tokens deleted.
                                  2023-12-27 22:18:32.248	debug	Saved auth tokens.
                                  2023-12-27 22:18:32.248	debug	Logged in as user: xxxx
                                  2023-12-27 22:18:31.744	debug	Connecting to Life360 service ...
                                  2023-12-27 22:18:31.744	debug	Not authenticated against Life360. Will try to connect ...
                                  2023-12-27 22:17:52.287	debug	Auth tokens deleted.
                                  Auch Frauen können sich für Technik begeistern! ;)
                                  Equipment:
                                  diverse HM-, HMIP-, Aeotec- Tradfri- Sonos- und Fibaro-Geräte, NAS, Proxmox mit div. LXC,
                                    michael 1975
                                    #535
                                    @MiGoller schau mal was ich bekommen habe.
                                    Dear Valued Member,
                                    At Life360, the security of our products and services has always been among our top priorities. Recently, we identified suspicious activity in which an unauthorized person used credentials (email address and password) obtained from outside sources to attempt to access your account. Based on our investigation to date, we have no evidence of unauthorized access to Life360 user location information, payment card information, or physical addresses. To safeguard against further suspicious activity, we took the precaution of resetting your password.
                                    This is a good reminder that using the same credentials across multiple services poses a risk to your personal information. Please make sure your passwords are secure by taking the following steps for all of your online accounts, including Life360:
                                    • Change the password on any online service for which you have used the same or similar credentials at Life360 or elsewhere
                                    • Don’t use the same username and/or password across different online services
                                    • Use strong passwords that include a mix of letters, numbers and special characters for each of your online service accounts
                                    • Change your passwords frequently
                                    You can find details on how to reset your Life360 password here.
                                    We are continuously monitoring and implementing features designed to enhance the security of our products and safety of our members. In the next year, we will begin rolling out a new way to safeguard your account with passwordless login. Passwordless login uses one-time passcodes delivered to your verified mobile number to log in to your account, instead of passwords, and it is the best way to protect your account from password misuse. We’ll let you know as soon as this feature is available to you.
                                    Security is an important part of our commitment to keep families safe online and in the real world. Thank you for taking the time to read this message and taking steps designed to protect your account.
                                    Best regards,
                                    Chris Hulls, CEO
                                    Gruß Michael
                                    • M michael 1975
                                      Dear Valued Member,
                                      Best regards,
                                      Chris Hulls, CEO
                                      Gruß Michael
                                      MiGollerM Offline
                                      MiGollerM Offline
                                      MiGoller
                                      #536
                                      @michael-1975 Diese Nachricht habe ich heute auch bekommen. Aus meiner Sicht ist das ein nachvollziehbarer Schritt seitens Life360, um die Sicherheit der Konten zu gewährleisten. Immerhin könnten sonst "Dritte" einfach nachvollziehen, wo jede Person in Euren Life360 Kreisen grad ist; da würden mir einige "Uses Cases" einfallen, leider auch nicht legale.
                                      Für den Adapter würde dies im besten Fall bedeuten, dass dieser regelmäßig mit einem neuen OTP wieder gestartet werden müsste. Wie oft wir dies tun müssten, würde von der Lebensdauer der Token abhängen, die damit generiert und vom Adapter genutzt würden.
                                      Was mich aber sehr stutzig macht, ist dieser Passus:
                                      Es gab also Zugriffsversuche von nicht autorisierten Personen auf Life360 Konten; ob diese erfolgreich waren, weiß Life360 nicht. Deshalb einfach mal die Kennwörter zurücksetzen? Das soll mir Sicherheit geben?!
                                      FRAGE: Haben alle, die Ihr Kennwort ändern mussten, eine solche E-Mail von Life360 erhalten?
                                      malorossM 1 Antwort Letzte Antwort
                                        malorossM Offline
                                        malorossM Offline
                                        maloross
                                        #537
                                        @migoller sagte in [Neuer Adapter] Life360:
                                        Im Adapter kann man sich ja auch mit Email und Passwort anmelden, vielleicht ist das der Auslöser und wird als nicht autorisierter Zugriff interpretiert? Mein Adapter meldet sich mit der Rufnummer an, musste bisher das PW nicht erneuern.
                                        Equipment:
                                        • malorossM maloross
                                          MiGollerM Offline
                                          MiGollerM Offline
                                          MiGoller
                                          #538
                                          @maloross Hmm, ausschließen möchte ich das nicht. 😇
