  4. Growatt WR Daten als Json
13 Beiträge 3 Kommentatoren 1.2k Aufrufe 1 Beobachtet
  • teletapiT teletapi
    @paul53 Morjen, vielen dank erstmal dafür das du helfen willst. Ich werde dann mal ein paar Aliase anlegen
    falkomfs
    @teletapi bei mir sieht es so aus.
    const idJson = 'mqtt.1.energy.solar.L1a';
    const path = '0_userdata.0.Solar.Auslesewerte.L1a.';
    on(idJson, function(dp) {
        let obj = JSON.parse(dp.state.val);
        let id = path + 'InverterStatus';
        if(existsState(id)) setState(id, obj.InverterStatus, true);
        else createState(id, obj.temp.temp, {type: 'number', name: 'InverterStatus', role: 'value', unit: '°C'});
        id = path + 'PV1Voltage';
        if(existsState(id)) setState(id, obj.PV1Voltage, true);
        else createState(id, obj.humid.humid, {type: 'number', name: 'PV1Voltage', role: 'value', unit: 'V'});
        id = path + 'BattPwr';
        if(existsState(id)) setState(id, obj.BattPwr, true);
        else createState(id, obj.humid.humid, {type: 'number', name: 'BattPwr', role: 'value', unit: 'V'});
        id = path + 'BattSOC';
        if(existsState(id)) setState(id, obj.BattSOC, true);
        else createState(id, obj.humid.humid, {type: 'number', name: 'BattSOC', role: 'value', unit: 'V'});
        id = path + 'LoadPercent';
        if(existsState(id)) setState(id, obj.LoadPercent, true);
        else createState(id, obj.humid.humid, {type: 'number', name: 'LoadPercent', role: 'value', unit: 'V'});
        id = path + 'OutActivePwr';
        if(existsState(id)) setState(id, obj.OutActivePwr, true);
        else createState(id, obj.humid.humid, {type: 'number', name: 'OutActivePwr', role: 'value', unit: 'V'});
        id = path + 'PV1ChargePwr';
        if(existsState(id)) setState(id, obj.PV1ChargePwr, true);
        else createState(id, obj.humid.humid, {type: 'number', name: 'PV1ChargePwr', role: 'value', unit: 'V'});
        id = path + 'BattVoltage';
        if(existsState(id)) setState(id, obj.BattVoltage, true);
        else createState(id, obj.humid.humid, {type: 'number', name: 'BattVoltage', role: 'value', unit: 'V'});
        id = path + 'Buck1Temp';
         if(existsState(id)) setState(id, obj.Buck1Temp, true);
        else createState(id, obj.humid.humid, {type: 'number', name: 'Buck1Temp', role: 'value', unit: 'W'});
        id = path + 'Buck2Temp';
         if(existsState(id)) setState(id, obj.Buck2Temp, true);
        else createState(id, obj.humid.humid, {type: 'number', name: 'Buck2Temp', role: 'value', unit: 'W'});
        // usw. für weitere Datenpunkte
    teletapiT 1 Antwort Letzte Antwort
    • F falkomfs
      teletapiT Online
      teletapiT Online
      teletapi
      Es fällt mir etwas schwer das zu sagen aber ich bin komplett ahnungslos wie das funktioniert. Selbst den Alias "mit den richtigen Eigenschaften" zu erstellen wird ohne eure Hilfe nicht gehn.
        @teletapi sagte: diese Daten in einzelne Datenpunkte.
        Erstelle für jeden Datenpunkt einen Alias unter "alias.0" mit passenden Eigenschaften und verwende eine Lesekonvertierung. Beispiel Konvertierung für "InputPower":
        JSON.parse(val).InputPower
        Ich gehe davon aus, dass im oberen Spoiler das MQTT-JSON enthalten ist.
        teletapiT Online
        teletapiT Online
        teletapi
        @paul53 wo schreibe ich das hin...?
          @teletapi sagte: Alias "mit den richtigen Eigenschaften" zu erstellen
          Im Tab "Objekte" erst ein Verzeichnis (z.B. "WR") unter "alias.0" erstellen und dann unter dem Verzeichnis die Datenpunkte:
          @teletapi sagte in Growatt WR Daten als Json:
          • teletapiT Online
            teletapiT Online
            teletapi
            schrieb am zuletzt editiert von teletapi
            hab ich jetzt so erstellt
              @teletapi sagte: hab ich jetzt so erstellt
              Zeige bitte die OBJEKTDATEN in Code tags.
                teletapiT Online
                teletapiT Online
                teletapi
                "common": {
                "name": "InputPower",
                "desc": "Manuell erzeugt",
                "role": "state",
                "type": "number",
                "read": true,
                "write": false,
                "alias": {
                "read": "JSON.parse(val).InputPower ",
                "id": "mqtt.0.energy.solar"
                "type": "state",
                "native": {},
                "_id": "alias.0.Solar.Growatt.InputPower",
                "acl": {
                "object": 1636,
                "state": 1636,
                "owner": "system.user.admin",
                "user": "system.user.admin",
                "ts": 1702657939627
                  "common": {
                  "role": "state",
                  "type": "number",
                  "read": true,
                  "write": false,
                  "alias": {
                  "type": "state",
                  "native": {},
                  "acl": {
                  "object": 1636,
                  "state": 1636,
                  "ts": 1702657939627
                  @teletapi
                  Ändere noch die Rolle in "value.power" oder "value" und ergänze die Unit: "W".
                  Code tags ist oben das 5. Symbol </>.
                    @teletapi
                    teletapiT Online
                    teletapiT Online
                    teletapi
                    Passiert mir jedesmal mit dem Codetag
                      teletapiT Online
                      teletapiT Online
                      teletapi
                      Das hat ja super geklappt vielen dank für eure Hilfe
                      Hawe
