  4. Adapter: ioBroker.unifi
    6.3k
unifi
1.0k Beiträge 172 Kommentatoren 530.8k Aufrufe 93 Beobachtet
  • W Offline
    W Offline
    warp735
    #833
    Hab heute die UDM Pro auf die 3.2.7 gezogen und bekomm den Adapter nicht mehr auf grün. Ist da was bekannt?
    unifi.0
    	2023-12-13 09:32:29.199	info	terminating
    unifi.0
    	2023-12-13 09:32:28.698	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
    unifi.0
    	2023-12-13 09:32:28.698	info	terminating
    unifi.0
    	2023-12-13 09:32:28.698	info	cleaned everything up...
    unifi.0
    	2023-12-13 09:32:28.696	error	Cannot read properties of undefined (reading 'captureException')
    unifi.0
    	2023-12-13 09:32:28.696	error	TypeError: Cannot read properties of undefined (reading 'captureException') at Unifi.handleError (/opt/iobroker/node_modules/iobroker.unifi/main.js:243:53) at Unifi.updateUnifiData (/opt/iobroker/node_modules/iobroker.unifi/main.js:268:22) at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
    unifi.0
    	2023-12-13 09:32:28.696	error	unhandled promise rejection: Cannot read properties of undefined (reading 'captureException')
    unifi.0
    	2023-12-13 09:32:28.696	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    unifi.0
    	2023-12-13 09:32:28.695	error	[updateUnifiData-login site undefined] error: Request failed with status code 401, stack: AxiosError: Request failed with status code 401 at settle (/opt/iobroker/node_modules/node-unifi/node_modules/axios/dist/node/axios.cjs:1909:12) at IncomingMessage.handleStreamEnd (/opt/iobroker/node_modules/node-unifi/node_modules/axios/dist/node/axios.cjs:2989:11) at IncomingMessage.emit (node:events:529:35) at endReadableNT (node:internal/streams/readable:1400:12) at process.processTicksAndRejections (node:internal/process/task_queues:82:21)
    unifi.0
    	2023-12-13 09:32:28.695	error	Error site undefined (data): {"error":{"code":401,"message":"Unauthorized"}}
    unifi.0
    	2023-12-13 09:32:28.595	info	UniFi adapter is ready
    • W warp735
      unifi.0
      unifi.0
      unifi.0
      unifi.0
      unifi.0
      unifi.0
      unifi.0
      unifi.0
      unifi.0
      unifi.0
      unifi.0
      #834
      @warp735 noe, Adapter laeuft einwandfrei auf 3.2.7 und Netzwerk 8.0.x
      Welche Version vom Adapter benutzt du denn?
      draexlerD W 2 Antworten Letzte Antwort
        draexlerD Offline
        draexlerD Offline
        draexler
        #835
        @ilovegym Funktioniert bei dir noch die Vouchererstellung?
        • draexlerD draexler
          #836
          @draexler
          Ich nutze das leider nicht, kann ich nicht sagen..
          draexlerD 1 Antwort Letzte Antwort
            W Offline
            W Offline
            warp735
            #837
            @ilovegym
            @ilovegym sagte in Adapter: ioBroker.unifi:
            stable 0.6.6
            bin jetzt auf die 0.6.7 und damit läufts wieder. Vielen Dank für den Schubs 👍
            F 1 Antwort Letzte Antwort
            • W warp735
              @ilovegym
              stable 0.6.6
              fliegema
              #838
              @warp735 Gude, muss mal blöd fragen, wie hast du die Version bekommen? Das ist ja noch nicht stable, aber selbst wenn ich
              sudo npm i iobroker.unifi@0.6.7
              eingebe, installiert er die Version zwar aber, im iobroker kommt die nicht an.
              Sonst warte ich einfach, bis die Version stable wird.
              Cheers
              Meister MopperM W Thomas BraunT 3 Antworten Letzte Antwort
              • F fliegema
                Meister MopperM Offline
                Meister Mopper
                #839
                @fliegema sagte in Adapter: ioBroker.unifi:
                Das funktioniert im Expertenmodus über die Github-Katze. Bei 4. die Github-url reinkopieren.
                Proxmox und HA ...
                • F fliegema
                  W Offline
                  W Offline
                  warp735
                  #840
                  @fliegema
                  Hab kurzzeitig auf latest gestellt, dann hats die angezeigt.
                  • F fliegema
                    #841
                    Bitte NIE, NIE, NIE Befehle wie npm, iobroker usw. mit root-Rechten/sudo anpacken. NIE!
                    Hant0rH 1 Antwort Letzte Antwort
                      Hant0rH Offline
                      Hant0rH Offline
                      Hant0r
                      #842
                      @thomas-braun kannst du kurz erklären warum? - würde mich interessieren :)
                      • Hant0rH Hant0r
                        #843
                        @hant0r
                        Weil sudo (ohne weitere Optionen) immer die root-Rechte heranzieht. Und Dateien, die mit diesen angepackt wurden dann dem root gehören und von anderen Usern nicht verwendet werden können (wenn die Rechte nicht im Nachgang angepasst wurden).
                        Und man verwendet den root bzw. dessen Rechte nur dort, wo es unbedingt erforderlich ist, wenn es also in Bereiche im System geht, die für 'normale' user tabu sind. Den ioBroker kann aber jeder user anpacken, der auch in der Gruppe 'iobroker' enthalten ist. Sollte dein Standarduser aber sein.
                        Bei 'npm' kommt noch dazu, dass dieses Kommando im richtigen Verzeichnis ausgeführt werden muss. Da man das aber bei dir auch nicht sieht, wo du da standst gehe ich davon aus, dass du nun mit root-Rechten in ein home-Verzeichnis gedonnert hast. Also alles krumm.
                        Edit: User verwechselt. Der root-Missbraucher war ja @fliegema
                          @hant0r
                          Hant0rH Offline
                          Hant0rH Offline
                          Hant0r
                          #844
                          Hehe, dachte gerade schon, wieso ich?! :D
                          Mich hat es nur interessiert, da ich im Linux-Umfeld nicht so bewandt bin - daher vielen Dank für die schlüssige Erklärung.
                          Bei NPM etc. verlasse ich mich immer voll auf die Anleitungen, die es hier im Forum gibt.
                          Bisher hat das auch (toi toi toi) meist gut geklappt :)
                          • NegaleinN Offline
                            NegaleinN Offline
                            Negalein
                            #845
                            seit 0.6.7 startet der Adapter immer neu und die CPU schießt in die Höhe.
                            unifi.0 2023-12-14 16:51:11.294	error	[updateUnifiData-fetchSites site undefined] error: Cannot find view "system", stack: Error: Cannot find view "system" at ObjectsInRedisClient._getObjectView (/opt/iobroker/node_modules/@iobroker/db-objects-redis/src/lib/objects/objectsInRedisClient.ts:4317:19) at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-objects-redis/src/lib/objects/objectsInRedisClient.ts:4392:37)
                            unifi.0 2023-12-14 16:51:11.246	error	Cannot find view "system" for search "state" : Connection is closed.
                            unifi.0 2023-12-14 16:51:11.245	error	[updateUnifiData site default] error: DB closed, stack: Error: DB closed at Redis.sendCommand (/opt/iobroker/node_modules/ioredis/built/redis/index.js:636:24) at Redis.get (/opt/iobroker/node_modules/ioredis/built/commander.js:122:25) at StateRedisClient.setState (/opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:726:40) at Unifi._setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:7710:33)
                            unifi.0 2023-12-14 16:51:11.127	warn	get state error: Connection is closed.
                            unifi.0 2023-12-14 16:51:00.720	error	[updateUnifiData-fetchSites site undefined] error: DB closed, stack: Error: DB closed at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25) at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20) at Object.onceWrapper (node:events:632:26) at Socket.emit (node:events:517:28) at Socket.emit (node:domain:489:12) at TCP.<anonymous> (node:net:350:12)
                            unifi.0 2023-12-14 16:50:00.727	warn	get state error: Connection is closed.
                            unifi.0 2023-12-14 16:49:00.540	warn	get state error: Connection is closed.
                            ° Fixer ---> iob fix
                            • NegaleinN Negalein
                              Meister Mopper
                              #846
                              @negalein sagte in Adapter: ioBroker.unifi:
                              Das kann ich bei mir nicht beobachten. Ich sehe aber gerade, dass dein node.js etwas hinterher hinkt, vielleicht ist es das :man-shrugging: .
                              Proxmox und HA ...
                                NegaleinN Offline
                                NegaleinN Offline
                                Negalein
                                #847
                                @meister-mopper sagte in Adapter: ioBroker.unifi:
                                Ich sehe aber gerade, dass dein node.js etwas hinterher hinkt, vielleicht ist es das .
                                vergess ich immer in der Signatur auszubessern.
                                  Meister Mopper
                                  #848
                                  @negalein
                                  thomas@iobroker:~$ nodejs -v
                                  v18.19.0
                                  thomas@iobroker:~$ npm -v
                                  10.2.3
                                  thomas@iobroker:~$
                                  Dann stimmts trotzdem nicht 😁
                                  Proxmox und HA ...
                                    @draexler
                                    draexlerD Offline
                                    draexlerD Offline
                                    draexler
                                    #849
                                    @ilovegym ok, trotzdem danke
                                    Gehts bei jemand anders noch? Will nur ausschließen das es an mir liegt.
                                    P 1 Antwort Letzte Antwort
                                      Pino72
                                      #850
                                      Hi, hab denb Adapter auf 0.6.7 geupdated...ledier bekomme ich immer noch folgenden Fehler wie schon davor:
                                      [updateUnifiData-login site undefined] error: timeout of 10000ms exceeded, stack: AxiosError: timeout of 10000ms exceeded at RedirectableRequest.handleRequestTimeout (C:\Program Files\ioBroker\node_modules\axios\lib\adapters\http.js:643:16) at RedirectableRequest.emit (node:events:517:28) at RedirectableRequest.emit (node:domain:489:12) at Timeout.<anonymous> (C:\Program Files\ioBroker\node_modules\follow-redirects\index.js:179:12) at listOnTimeout (node:internal/timers:569:17) at processTimers (node:internal/timers:512:7)
                                      Habt ihr das auch oder nur bei mir so? Wie kann man das beheben? Leider wir der is_online Wert dann nicht mehr aktualisiert....
                                      • P Pino72
                                        #851
                                        @pino72
                                        Update mal deine Konfig, der Fehler sagt, dass du da nichts eingetragen hast..
                                        ( updateUnifiData-login site undefined )
                                          @pino72
                                          Pino72
                                          #852
                                          @ilovegym Hat sicher nichts mit der Config zu tun...da war und steht schon immer alles richtig drinnen. Der Adapter startet ja auch immer:
                                          unifi.0
                                          	2023-12-18 10:00:30.027	info	UniFi adapter is ready
                                          unifi.0
                                          	2023-12-18 10:00:29.991	info	starting. Version 0.6.7 in C:/Program Files/ioBroker/node_modules/iobroker.unifi, node: v18.19.0, js-controller: 5.0.17
                                          unifi.0
                                          	2023-12-18 10:00:22.042	info	terminating
                                          unifi.0
                                          	2023-12-18 10:00:21.525	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                          unifi.0
                                          	2023-12-18 10:00:21.523	info	terminating
                                          unifi.0
                                          	2023-12-18 10:00:21.522	info	cleaned everything up...
                                          unifi.0
                                          	2023-12-18 10:00:21.514	info	Got terminate signal TERMINATE_YOURSELF
                                          unifi.0
                                          	2023-12-18 09:34:20.308	error	[updateUnifiData-login site undefined] error: timeout of 10000ms exceeded, stack: AxiosError: timeout of 10000ms exceeded at RedirectableRequest.handleRequestTimeout (C:\Program Files\ioBroker\node_modules\axios\lib\adapters\http.js:643:16) at RedirectableRequest.emit (node:events:517:28) at RedirectableRequest.emit (node:domain:489:12) at Timeout.<anonymous> (C:\Program Files\ioBroker\node_modules\follow-redirects\index.js:179:12) at listOnTimeout (node:internal/timers:569:17) at processTimers (node:internal/timers:512:7)
