  3. Einsteigerfragen
  4. Fehler beim Update des Telegram Adapters
    5.5k
27 Beiträge 6 Kommentatoren 2.0k Aufrufe 5 Beobachtet
  • Andreas StürzerA Andreas Stürzer
    @djmarc75
    107*** BASE SYSTEM ***
       Static hostname: iobroker-prod
             Icon name: computer-container
               Chassis: container
        Virtualization: lxc
      Operating System: Ubuntu 20.04.6 LTS
                Kernel: Linux 6.2.16-3-pve
          Architecture: x86-64
    model name    : AMD Ryzen 5 5600U with Radeon Graphics
    Docker          : false
    Virtualization  : lxc
    Kernel          : x86_64
    Userland        : amd64
    Systemuptime and Load:
    16:49:03 up 1 day, 20:19,  0 users,  load average: 1.77, 1.95, 1.98
    CPU threads: 6
    107*** Time and Time Zones ***
                   Local time: Wed 2023-12-13 16:49:03 UTC
               Universal time: Wed 2023-12-13 16:49:03 UTC
                     RTC time: n/a
                    Time zone: Etc/UTC (UTC, +0000)
                  NTP service: inactive
              RTC in local TZ: no
    107*** User and Groups ***
    iobroker
    /home/iobroker
    iobroker tty dialout audio video
    107*** X-Server-Setup ***
    X-Server:     false
    Desktop:
    Terminal:
    Boot Target:     graphical.target
    107*** MEMORY ***
    Mem:             9G        2.7G        6.3G        0.0K        1.0G        7.3G
    Swap:          1.0G          0B        1.0G
    Total:          11G        2.7G        7.3G
             9980 M total memory
             2698 M used memory
              467 M active memory
             2999 M inactive memory
             6262 M free memory
                0 M buffer memory
             1018 M swap cache
             1024 M total swap
                0 M used swap
             1024 M free swap
    107*** FAILED SERVICES ***
      UNIT                 LOAD   ACTIVE SUB    DESCRIPTION
    * run-rpc_pipefs.mount loaded failed failed RPC Pipe File System
    1 loaded units listed.
    107*** FILESYSTEM ***
    Filesystem                       Type      Size  Used Avail Use% Mounted on
    /dev/mapper/pve-vm--102--disk--0 ext4       18G  4.7G   12G  28% /
    none                             tmpfs     492K  4.0K  488K   1% /dev
    udev                             devtmpfs  7.5G     0  7.5G   0% /dev/tty
    tmpfs                            tmpfs     7.6G     0  7.6G   0% /dev/shm
    tmpfs                            tmpfs     1.6G  120K  1.6G   1% /run
    tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
    sudo: a terminal is required to read the password; either use the -S option to read from standard input or configure an askpass helper
    TARGET                    SOURCE                           FSTYPE     OPTIONS
    /                         /dev/mapper/pve-vm--102--disk--0 ext4       rw,relatime,stripe=16
    |-/proc/cpuinfo           lxcfs[/proc/cpuinfo]             fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
    |-/proc/diskstats         lxcfs[/proc/diskstats]           fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
    |-/proc/loadavg           lxcfs[/proc/loadavg]             fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
    |-/proc/meminfo           lxcfs[/proc/meminfo]             fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
    |-/proc/slabinfo          lxcfs[/proc/slabinfo]            fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
    |-/proc/stat              lxcfs[/proc/stat]                fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
    |-/proc/swaps             lxcfs[/proc/swaps]               fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
    |-/proc/uptime            lxcfs[/proc/uptime]              fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
    `-/sys/devices/system/cpu lxcfs[/sys/devices/system/cpu]   fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
    /var:
    Archived and active journals take up 424.0M in the file system.
    /opt/iobroker/backups:
    33M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    399M    /opt/iobroker/iobroker-data/
    203M    /opt/iobroker/iobroker-data/files
    126M    /opt/iobroker/iobroker-data/backup-objects
    67M    /opt/iobroker/iobroker-data/files/javascript.admin
    48M    /opt/iobroker/iobroker-data/files/javascript.admin/static
    21M    /opt/iobroker/iobroker-data/objects.jsonl
    21M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
    18M    /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.274a4d8d.js.map
    9.5M    /opt/iobroker/iobroker-data/states.jsonl
    8.3M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js
    USB-Devices by-id:
    find: '/dev/serial/by-id/': No such file or directory
    107*** NodeJS-Installation ***
    /usr/bin/nodejs     v18.17.1
    /usr/bin/node         v18.17.1
    /usr/bin/npm         9.6.7
    /usr/bin/npx         9.6.7
    /usr/bin/corepack     0.18.0
    nodejs:
      Installed: 18.17.1-deb-1nodesource1
      Candidate: 18.17.1-deb-1nodesource1
      Version table:
    *** 18.17.1-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_18.x focal/main amd64 Packages
         10.19.0~dfsg-3ubuntu1.3 500
            500 http://archive.ubuntu.com/ubuntu focal-updates/universe amd64 Packages
            500 http://archive.ubuntu.com/ubuntu focal-security/universe amd64 Packages
         10.19.0~dfsg-3ubuntu1 500
            500 http://archive.ubuntu.com/ubuntu focal/universe amd64 Packages
    No problems detected
    Errors in npm tree:
    107*** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:     5.0.16
    admin:         6.12.1
    javascript:     7.1.6
    Adapters from github:     1
    Adapter State
    + system.adapter.admin.1                  : admin                 : iobroker-prod                            -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.backitup.0               : backitup              : iobroker-prod                            -  enabled
    + system.adapter.discovery.0              : discovery             : iobroker-prod                            -  enabled
    + system.adapter.evcc.0                   : evcc                  : iobroker-prod                            -  enabled, port: 7070
      system.adapter.ham.0                    : ham                   : iobroker-prod                            - disabled
    + system.adapter.hmip.0                   : hmip                  : iobroker-prod                            -  enabled
    + system.adapter.hue.0                    : hue                   : iobroker-prod                            -  enabled, port: 80
      system.adapter.ico-cloud.0              : ico-cloud             : iobroker-prod                            -  enabled
    + system.adapter.influxdb.1               : influxdb              : iobroker-prod                            -  enabled, port: 8086
    + system.adapter.info.0                   : info                  : iobroker-prod                            -  enabled
    + system.adapter.javascript.0             : javascript            : iobroker-prod                            -  enabled
    + system.adapter.knx.0                    : knx                   : iobroker-prod                            -  enabled, bind: 192.168.188.76
    + system.adapter.modbus.0                 : modbus                : iobroker-prod                            -  enabled
    + system.adapter.modbus.1                 : modbus                : iobroker-prod                            -  enabled
    + system.adapter.modbus.2                 : modbus                : iobroker-prod                            -  enabled
    + system.adapter.moma.0                   : moma                  : iobroker-prod                            -  enabled
    + system.adapter.mqtt.1                   : mqtt                  : iobroker-prod                            -  enabled, port: 1884, bind: 0.0.0.0
    + system.adapter.mqtt.2                   : mqtt                  : iobroker-prod                            -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.mywallbox.0              : mywallbox             : iobroker-prod                            -  enabled
    + system.adapter.netatmo.0                : netatmo               : iobroker-prod                            -  enabled
    + system.adapter.node-red.0               : node-red              : iobroker-prod                            -  enabled, port: 1880, bind: 0.0.0.0
    + system.adapter.philips-tv.0             : philips-tv            : iobroker-prod                            -  enabled
    + system.adapter.pushbullet.0             : pushbullet            : iobroker-prod                            -  enabled
    + system.adapter.pvforecast.0             : pvforecast            : iobroker-prod                            -  enabled
    + system.adapter.shelly.0                 : shelly                : iobroker-prod                            -  enabled, port: 1882, bind: 0.0.0.0
      system.adapter.shelly.1                 : shelly                : iobroker-prod                            - disabled, port: 1882, bind: 0.0.0.0
    + system.adapter.simple-api.0             : simple-api            : iobroker-prod                            -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
    + system.adapter.sma-em.0                 : sma-em                : iobroker-prod                            -  enabled
    + system.adapter.sonoff.0                 : sonoff                : iobroker-prod                            -  enabled, port: 1889, bind: 0.0.0.0
    + system.adapter.sonos.0                  : sonos                 : iobroker-prod                            -  enabled
    + system.adapter.tahoma.0                 : tahoma                : iobroker-prod                            -  enabled
    + system.adapter.telegram.0               : telegram              : iobroker-prod                            -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.terminal.0               : terminal              : iobroker-prod                            -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
    + system.adapter.text2command.0           : text2command          : iobroker-prod                            -  enabled
    + system.adapter.web.0                    : web                   : iobroker-prod                            -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.zigbee.0                 : zigbee                : iobroker-prod                            -  enabled, port: /dev/ttyACM0
    + instance is alive
    ioBroker-Repositories
    Stable (default): http://download.iobroker.net/sources-dist.json
    Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
    Installed ioBroker-Instances
    Adapter    "admin"        : 6.12.0   , installed 6.12.1
    Adapter    "backitup"     : 2.8.7    , installed 2.8.7
    Adapter    "discovery"    : 4.2.0    , installed 4.2.0
    Adapter    "evcc"         : 0.0.10   , installed 0.0.10
    Adapter    "ham"          : 5.3.1    , installed 5.3.1
    Adapter    "hmip"         : 1.20.0   , installed 1.20.0
    Adapter    "hue"          : 3.10.1   , installed 3.10.1
    Adapter    "ico-cloud"    : 1.1.0    , installed 1.1.0
    Adapter    "info"         : 2.0.0    , installed 2.0.0
    Adapter    "javascript"   : 7.1.6    , installed 7.1.6
    Controller "js-controller": 5.0.17   , installed 5.0.16 [Updatable]
    Adapter    "knx"          : 2.0.23   , installed 2.0.23
    Adapter    "modbus"       : 5.0.11   , installed 5.0.11
    Adapter    "moma"         : 1.2.9    , installed 1.2.9
    Adapter    "mqtt"         : 5.1.0    , installed 2.7.4  [Updatable]
    Adapter    "netatmo"      : 3.1.0    , installed 3.1.0
    Adapter    "node-red"     : 4.0.3    , installed 4.0.3
    Adapter    "philips-tv"   : 0.5.3    , installed 0.5.3
    Adapter    "pushbullet"   : 2.0.1    , installed 2.0.1
    Adapter    "pvforecast"   : 2.9.0    , installed 2.9.0
    Adapter    "shelly"       : 6.6.1    , installed 6.6.1
    Adapter    "sma-em"       : 1.0.0    , installed 1.0.0
    Adapter    "socketio"     : 6.6.0    , installed 6.6.0
    Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
    Adapter    "sonos"        : 3.0.0    , installed 3.0.0
    Adapter    "tahoma"       : 0.10.2   , installed 0.10.2
    Adapter    "telegram"     : 3.0.0    , installed 1.16.0 [Updatable]
    Adapter    "terminal"     : 1.0.0    , installed 1.0.0
    Adapter    "text2command" : 3.0.2    , installed 3.0.2
    Adapter    "web"          : 6.1.10   , installed 6.1.10
    Adapter    "ws"           : 2.5.8    , installed 2.5.8
    Adapter    "zigbee"       : 1.8.24   , installed 1.8.24
    Objects and States
    Objects:     4839
    States:     4027
    107*** OS-Repositories and Updates ***
    Hit:1 http://archive.ubuntu.com/ubuntu focal InRelease
    Hit:2 http://archive.ubuntu.com/ubuntu focal-updates InRelease
    Hit:3 http://archive.ubuntu.com/ubuntu focal-security InRelease
    Hit:4 https://deb.nodesource.com/node_18.x focal InRelease
    Reading package lists...
    Pending Updates: 45
    107*** Listening Ports ***
    107*** Log File - Last 25 Lines ***
    2023-12-13 16:49:30.254  - info: knx.0 (3245502) ( 3.6a ) Received L_DATA.con  06 10 04 20 00 15 04 01 bd 00 2e 00 bc e0 11 fa 72 00 01 00 00  was successfully processed by receiver.
    2023-12-13 16:49:30.254  - info: knx.0 (3245502) Change state from STATE_READY(7) to STATE_TUNNELLING_REQUEST(13)
    2023-12-13 16:49:30.254  - info: knx.0 (3245502) Change state from STATE_TUNNELLING_REQUEST(13) to STATE_TUNNELLING_ACK(14)
    2023-12-13 16:49:30.254  - info: knx.0 (3245502) =====> STATE_TUNNELING_ACK
    2023-12-13 16:49:30.254  - info: knx.0 (3245502) ( 4 ) Sending Tunnel_Request ACK  : 06 10 04 21 00 0a 04 01 bd 00   ChID : 1 SeqCntIN : 189 SeqCntOUT : 153 queue length : 1
    2023-12-13 16:49:30.254  - info: knx.0 (3245502) ( 4.b ) return to STATE_READY, processing : false
    2023-12-13 16:49:30.254  - info: knx.0 (3245502) Change state from STATE_TUNNELLING_ACK(14) to STATE_READY(7)
    2023-12-13 16:49:30.254  - info: knx.0 (3245502)  Has todo still 1 tasks, just processing : false
    2023-12-13 16:49:30.454  - info: knx.0 (3245502) Change state from STATE_READY(7) to STATE_TUNNELLING_SENDING_DATA(8)
    2023-12-13 16:49:30.455  - info: knx.0 (3245502) ( 1 ) Sending : GroupValueWrite :   06 10 04 20 00 19 04 01 99 00 11 00 bc e0 11 fa 72 01 05 00 80 46 c6 16 20    sent to 192.168.188.26:3671  ChID: 1 SeqCntIN : 189 SeqCntOUT : 153 GA : 14/2/1 conCheck.conected : true
    2023-12-13 16:49:30.455  - info: knx.0 (3245502) easy-knx: task.data : 06 10 04 20 00 19 04 01 99 00 11 00 bc e0 11 fa 72 01 05 00 80 46 c6 16 20  byteLen : 25
    2023-12-13 16:49:30.455  - info: knx.0 (3245502) Change state from STATE_TUNNELLING_SENDING_DATA(8) to STATE_TUNNELLING_WAIT_SENT_ACK(9)
    2023-12-13 16:49:30.455  - info: knx.0 (3245502) ( 2 ) Received TUNNEL_ACK      :             06 10 04 21 00 0a 04 01 99 00    from 192.168.188.26:3671 SeqCntIN : 189 SeqCntOUT : 154 GA : 0/0/0
    2023-12-13 16:49:30.455  - info: knx.0 (3245502) Change state from STATE_TUNNELLING_WAIT_SENT_ACK(9) to STATE_TUNNELLING_SENT_DATA_ACK_RECV(11)
    2023-12-13 16:49:30.455  - info: knx.0 (3245502) STATE_TUNNELLING_WAIT_SENT_ACK: received ACK for previous self sent package
    2023-12-13 16:49:30.455  - info: knx.0 (3245502)  ==>  successful acknowledged previous package... processing next of 0
    2023-12-13 16:49:30.455  - info: knx.0 (3245502) Change state from STATE_TUNNELLING_SENT_DATA_ACK_RECV(11) to STATE_READY(7)
    2023-12-13 16:49:30.455  - info: knx.0 (3245502)  ==> easy-knx.js: signal runtime : 0s  1.013398ms
    2023-12-13 16:49:30.484  - info: knx.0 (3245502) ( 3.6a ) Received L_DATA.con  06 10 04 20 00 19 04 01 be 00 2e 00 bc e0 11 fa 72 01 05 00 80 46 c6 16 20  was successfully processed by receiver.
    2023-12-13 16:49:30.484  - info: knx.0 (3245502) Change state from STATE_READY(7) to STATE_TUNNELLING_REQUEST(13)
    2023-12-13 16:49:30.484  - info: knx.0 (3245502) Change state from STATE_TUNNELLING_REQUEST(13) to STATE_TUNNELLING_ACK(14)
    2023-12-13 16:49:30.484  - info: knx.0 (3245502) =====> STATE_TUNNELING_ACK
    2023-12-13 16:49:30.484  - info: knx.0 (3245502) ( 4 ) Sending Tunnel_Request ACK  : 06 10 04 21 00 0a 04 01 be 00   ChID : 1 SeqCntIN : 190 SeqCntOUT : 154 queue length : 0
    2023-12-13 16:49:30.484  - info: knx.0 (3245502) ( 4.b ) return to STATE_READY, processing : false
    2023-12-13 16:49:30.484  - info: knx.0 (3245502) Change state from STATE_TUNNELLING_ACK(14) to STATE_READY(7)
    DJMarc75D Offline
    DJMarc75D Offline
    DJMarc75
    @andreas-stürzer und der User "iobroker" ist eine denkbar schlechte Wahl.
    Hat denn hier niemand einen Vornamen welchen man als User anlegt ? ;)
    Lehrling seit 1975 !!!
    • Andreas StürzerA Offline
      Andreas Stürzer
      Mhm danke für eure Rückmeldung aber so richtig weiter hilft mir das nicht.
      Gibt es die Möglichkeit hier weitere Details zu bekommen wo denn genau das Problem beim Update herkommt. Logs etc...
      Danke Andreas
        Danke Andreas
        @andreas-stürzer
        Richte das System erstmal richtig ein.
        Andreas StürzerA 1 Antwort Letzte Antwort
          @andreas-stürzer
          Andreas Stürzer
          Habe die meisten deiner Vorschläge schon umgesetzt bis auf das sudo Thema, das Problem ist leider aber nach wie vor das Gleiche....
            @andreas-stürzer
            Wie genau greifst du auf der Container zu, dass der kein Terminal haben soll?
              @andreas-stürzer
              Andreas Stürzer
              schrieb am zuletzt editiert von Andreas Stürzer
              @thomas-braun direkt aus dem iobroker via simple terminal adapter oder via proxmox console
              Alle anderen Adapter lassen sich ohne Probleme Updaten nur der Telegram eben nicht
                @andreas-stürzer
                Dann geh da per Terminalprogramm via ssh rein.
                Dann gibt es da auch ein terminal für den Prozess
                  @andreas-stürzer
                  Dann setzt du den User noch in die Gruppe 'adm' rein und lässt
                  iob diag
                  nochmal laufen.
                    @andreas-stürzer
                    iob diag
                    nochmal laufen.
                    Andreas Stürzer
                    *** BASE SYSTEM ***
                               Chassis: container
                        Virtualization: lxc
                    Docker          : false
                    Kernel          : x86_64
                    Userland        : amd64
                     23:22:16 up  3:25,  1 user,  load average: 1.99, 2.13, 2.02
                    CPU threads: 6
                                   Local time: Wed 2023-12-13 23:22:16 CET
                               Universal time: Wed 2023-12-13 22:22:16 UTC
                                     RTC time: n/a
                              RTC in local TZ: no
                    Andreas
                    Andreas sudo
                    X-Server:       false
                    Desktop:
                    Terminal:
                    *** MEMORY ***
                    Mem:             9G        2.3G        7.0G        0.0K        690M        7.6G
                    Swap:          1.0G          0B        1.0G
                    Total:          11G        2.3G        8.0G
                             9980 M total memory
                             2337 M used memory
                              437 M active memory
                             2360 M inactive memory
                             6951 M free memory
                                0 M buffer memory
                              690 M swap cache
                             1024 M total swap
                                0 M used swap
                             1024 M free swap
                    *** FILESYSTEM ***
                    /dev/mapper/pve-vm--102--disk--0 ext4       18G  4.8G   12G  29% /
                    tmpfs                            tmpfs     1.6G  116K  1.6G   1% /run
                    dmesg: read kernel buffer failed: Operation not permitted
                    /var:
                    1.5G    /var/
                    810M    /var/log
                    809M    /var/log/journal/b354c482f7cc342776f020ee5ea440c3
                    351M    /var/cache
                    Archived and active journals take up 8.0M in the file system.
                    385M    /opt/iobroker/iobroker-data/
                    16M     /opt/iobroker/iobroker-data/objects.jsonl
                    8.0M    /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.274a4d8d.js
                    USB-Devices by-id:
                    /usr/bin/nodejs         v18.19.0
                    /usr/bin/node           v18.19.0
                    /usr/bin/npm            10.2.3
                    /usr/bin/npx            10.2.3
                    /usr/bin/corepack       0.22.0
                    nodejs:
                      Installed: 18.19.0-1nodesource1
                      Candidate: 18.19.0-1nodesource1
                      Version table:
                     *** 18.19.0-1nodesource1 1001
                            500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
                         18.18.2-1nodesource1 1001
                         18.18.1-1nodesource1 1001
                         18.18.0-1nodesource1 1001
                         18.17.1-1nodesource1 1001
                         18.17.0-1nodesource1 1001
                         18.16.1-1nodesource1 1001
                         18.16.0-1nodesource1 1001
                         18.15.0-1nodesource1 1001
                         18.14.2-1nodesource1 1001
                         18.14.1-1nodesource1 1001
                         18.14.0-1nodesource1 1001
                         18.13.0-1nodesource1 1001
                         18.12.0-1nodesource1 1001
                         18.11.0-1nodesource1 1001
                         18.10.0-1nodesource1 1001
                         18.9.1-1nodesource1 1001
                         18.9.0-1nodesource1 1001
                         18.8.0-1nodesource1 1001
                         18.7.0-1nodesource1 1001
                         18.6.0-1nodesource1 1001
                         18.5.0-1nodesource1 1001
                         18.4.0-1nodesource1 1001
                         18.3.0-1nodesource1 1001
                         18.2.0-1nodesource1 1001
                         18.1.0-1nodesource1 1001
                         18.0.0-1nodesource1 1001
                    Errors in npm tree:
                    ioBroker Status
                    Objects type: jsonl
                    States  type: jsonl
                    js-controller:  5.0.17
                    admin:          6.12.1
                    javascript:     7.1.6
                    Adapter State
                    + system.adapter.ico-cloud.0              : ico-cloud             : iobroker-prod                            -  enabled
                    + instance is alive
                    Controller "js-controller": 5.0.17   , installed 5.0.17
                    Objects and States
                    Objects:        4839
                    States:         4028
                    Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
                    Pending Updates: 0
                    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          256387468  135/sshd: /usr/sbin
                    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          256385754  1/init
                    tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          256386963  285/master
                    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       256389980  1483/iobroker.js-co
                    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       256389973  1483/iobroker.js-co
                    tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1000       256401570  1629/io.mqtt.1
                    tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1000       256390126  1558/node-red
                    tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1000       256400023  1674/io.shelly.0
                    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1000       256401641  1644/io.mqtt.2
                    tcp        0      0 0.0.0.0:1889            0.0.0.0:*               LISTEN      1000       256402667  1787/io.sonoff.0
                    tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      106        256388408  96/systemd-resolved
                    tcp6       0      0 :::8088                 :::*                    LISTEN      1000       256411530  3304/io.terminal.0
                    tcp6       0      0 :::8087                 :::*                    LISTEN      1000       256405617  2236/io.simple-api.
                    tcp6       0      0 :::8081                 :::*                    LISTEN      1000       256400456  1501/io.admin.1
                    tcp6       0      0 :::8082                 :::*                    LISTEN      1000       256405810  2489/io.web.0
                    tcp6       0      0 :::22                   :::*                    LISTEN      0          256387470  135/sshd: /usr/sbin
                    tcp6       0      0 :::111                  :::*                    LISTEN      0          256385756  1/init
                    tcp6       0      0 ::1:25                  :::*                    LISTEN      0          256386964  285/master
                    tcp6       0      0 :::3500                 :::*                    LISTEN      1000       256402598  1696/io.sonos.0
                    udp        0      0 192.168.188.76:40004    0.0.0.0:*                           1000       256399260  2188/io.knx.0
                    udp        0      0 127.0.0.53:53           0.0.0.0:*                           106        256388407  96/systemd-resolved
                    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          256385755  1/init
                    udp6       0      0 :::111                  :::*                                0          256385757  1/init
                    2023-12-13 22:22:40.253  - info: knx.0 (2188) ( 3.6a ) Received L_DATA.con  06 10 04 20 00 15 04 01 bc 00 2e 00 bc e0 11 fa 72 00 01 00 00  was successfully processed by receiver.
                    2023-12-13 22:22:40.253  - info: knx.0 (2188) Change state from STATE_READY(7) to STATE_TUNNELLING_REQUEST(13)
                    2023-12-13 22:22:40.253  - info: knx.0 (2188) Change state from STATE_TUNNELLING_REQUEST(13) to STATE_TUNNELLING_ACK(14)
                    2023-12-13 22:22:40.253  - info: knx.0 (2188) =====> STATE_TUNNELING_ACK
                    2023-12-13 22:22:40.253  - info: knx.0 (2188) ( 4 ) Sending Tunnel_Request ACK  : 06 10 04 21 00 0a 04 01 bc 00   ChID : 1 SeqCntIN : 188 SeqCntOUT : 197 queue length : 1
                    2023-12-13 22:22:40.253  - info: knx.0 (2188) ( 4.b ) return to STATE_READY, processing : false
                    2023-12-13 22:22:40.253  - info: knx.0 (2188) Change state from STATE_TUNNELLING_ACK(14) to STATE_READY(7)
                    2023-12-13 22:22:40.253  - info: knx.0 (2188)  Has todo still 1 tasks, just processing : false
                    2023-12-13 22:22:40.453  - info: knx.0 (2188) Change state from STATE_READY(7) to STATE_TUNNELLING_SENDING_DATA(8)
                    2023-12-13 22:22:40.454  - info: knx.0 (2188) ( 1 ) Sending : GroupValueWrite :   06 10 04 20 00 19 04 01 c5 00 11 00 bc e0 11 fa 72 01 05 00 80 46 c6 16 20    sent to 192.168.188.26:3671  ChID: 1 SeqCntIN : 188 SeqCntOUT : 197 GA : 14/2/1 conCheck.conected : true
                    2023-12-13 22:22:40.454  - info: knx.0 (2188) easy-knx: task.data : 06 10 04 20 00 19 04 01 c5 00 11 00 bc e0 11 fa 72 01 05 00 80 46 c6 16 20  byteLen : 25
                    2023-12-13 22:22:40.454  - info: knx.0 (2188) Change state from STATE_TUNNELLING_SENDING_DATA(8) to STATE_TUNNELLING_WAIT_SENT_ACK(9)
                    2023-12-13 22:22:40.455  - info: knx.0 (2188) ( 2 ) Received TUNNEL_ACK      :             06 10 04 21 00 0a 04 01 c5 00    from 192.168.188.26:3671 SeqCntIN : 188 SeqCntOUT : 198 GA : 0/0/0
                    2023-12-13 22:22:40.455  - info: knx.0 (2188) Change state from STATE_TUNNELLING_WAIT_SENT_ACK(9) to STATE_TUNNELLING_SENT_DATA_ACK_RECV(11)
                    2023-12-13 22:22:40.455  - info: knx.0 (2188) STATE_TUNNELLING_WAIT_SENT_ACK: received ACK for previous self sent package
                    2023-12-13 22:22:40.455  - info: knx.0 (2188)  ==>  successful acknowledged previous package... processing next of 0
                    2023-12-13 22:22:40.455  - info: knx.0 (2188) Change state from STATE_TUNNELLING_SENT_DATA_ACK_RECV(11) to STATE_READY(7)
                    2023-12-13 22:22:40.455  - info: knx.0 (2188)  ==> easy-knx.js: signal runtime : 0s  1.33787ms
                    2023-12-13 22:22:40.483  - info: knx.0 (2188) ( 3.6a ) Received L_DATA.con  06 10 04 20 00 19 04 01 bd 00 2e 00 bc e0 11 fa 72 01 05 00 80 46 c6 16 20  was successfully processed by receiver.
                    2023-12-13 22:22:40.484  - info: knx.0 (2188) Change state from STATE_READY(7) to STATE_TUNNELLING_REQUEST(13)
                    2023-12-13 22:22:40.484  - info: knx.0 (2188) Change state from STATE_TUNNELLING_REQUEST(13) to STATE_TUNNELLING_ACK(14)
                    2023-12-13 22:22:40.484  - info: knx.0 (2188) =====> STATE_TUNNELING_ACK
                    2023-12-13 22:22:40.484  - info: knx.0 (2188) ( 4 ) Sending Tunnel_Request ACK  : 06 10 04 21 00 0a 04 01 bd 00   ChID : 1 SeqCntIN : 189 SeqCntOUT : 198 queue length : 0
                    2023-12-13 22:22:40.484  - info: knx.0 (2188) ( 4.b ) return to STATE_READY, processing : false
                    2023-12-13 22:22:40.484  - info: knx.0 (2188) Change state from STATE_TUNNELLING_ACK(14) to STATE_READY(7)
                      *** BASE SYSTEM ***
                                 Chassis: container
                          Virtualization: lxc
                      Docker          : false
                      Kernel          : x86_64
                      Userland        : amd64
                      CPU threads: 6
                                       RTC time: n/a
                                RTC in local TZ: no
                      Andreas
                      Andreas sudo
                      X-Server:       false
                      Desktop:
                      Terminal:
                      *** MEMORY ***
                      Swap:          1.0G          0B        1.0G
                               9980 M total memory
                               2337 M used memory
                                437 M active memory
                               6951 M free memory
                                  0 M buffer memory
                                690 M swap cache
                               1024 M total swap
                                  0 M used swap
                               1024 M free swap
                      *** FILESYSTEM ***
                      /var:
                      1.5G    /var/
                      810M    /var/log
                      351M    /var/cache
                      USB-Devices by-id:
                      /usr/bin/npm            10.2.3
                      /usr/bin/npx            10.2.3
                      nodejs:
                        Version table:
                      Errors in npm tree:
                      ioBroker Status
                      Objects type: jsonl
                      States  type: jsonl
                      admin:          6.12.1
                      javascript:     7.1.6
                      Adapter State
                      + instance is alive
                      Objects and States
                      Objects:        4839
                      States:         4028
                      Pending Updates: 0
                      @andreas-stürzer
                      Warum hat der User Andreas kein home?
                        *** BASE SYSTEM ***
                                   Chassis: container
                            Virtualization: lxc
                        Docker          : false
                        Kernel          : x86_64
                        Userland        : amd64
                        CPU threads: 6
                                         RTC time: n/a
                                  RTC in local TZ: no
                        Andreas
                        Andreas sudo
                        X-Server:       false
                        Desktop:
                        Terminal:
                        *** MEMORY ***
                        Swap:          1.0G          0B        1.0G
                                 9980 M total memory
                                 2337 M used memory
                                  437 M active memory
                                 6951 M free memory
                                    0 M buffer memory
                                  690 M swap cache
                                 1024 M total swap
                                    0 M used swap
                                 1024 M free swap
                        *** FILESYSTEM ***
                        /var:
                        1.5G    /var/
                        810M    /var/log
                        351M    /var/cache
                        USB-Devices by-id:
                        /usr/bin/npm            10.2.3
                        /usr/bin/npx            10.2.3
                        nodejs:
                          Version table:
                        Errors in npm tree:
                        ioBroker Status
                        Objects type: jsonl
                        States  type: jsonl
                        admin:          6.12.1
                        javascript:     7.1.6
                        Adapter State
                        + instance is alive
                        Objects and States
                        Objects:        4839
                        States:         4028
                        Pending Updates: 0
                        @andreas-stürzer
                        iob update
                        iob upgrade telegram --debug
                        sagt?
                          @andreas-stürzer
                          Andreas Stürzer
                          @thomas-braun Wurde wahrscheinlich bei der Anlage nicht gesetzt
                            @andreas-stürzer
                            iob update
                            sagt?
                            Andreas Stürzer
                            This upgrade of "telegram" will introduce the following changes:
                            -> 3.0.0:
                            BREAKING CHANGE: Socks5 support has been removed.
                            Extended and improved the returned list of processed messages.
                            -> 2.0.2:
                            Dependencies have been updated.
                            -> 2.0.1:
                            Incorrect trailing zero in callback of sendTo() has been fixed. [#680]
                            -> 2.0.0:
                            Packets were updated.
                            BREAKING CHANGE: The minimal node.js version is 16
                            BREAKING CHANGE: Return an object with chatId and messageId instead of the message count
                            BE CAREFUL: THIS IS A MAJOR UPGRADE, WHICH WILL MOST LIKELY INTRODUCE BREAKING CHANGES!
                            Would you like to upgrade telegram from @1.16.0 to @3.0.0 now? [(y)es, (n)o]: y
                            Update telegram from @1.16.0 to @3.0.0
                            Cannot upgrade: Cannot read properties of undefined (reading 'enabled')
                              @andreas-stürzer
                              Dann setz den in die Gruppen rein:
                              sudo usermod -a -G adm,dialout,iobroker Andreas
                                @andreas-stürzer
                                Andreas Stürzer
                                @thomas-braun ist erledigt
                                  @andreas-stürzer
                                  Vermutlich ist der Sprung zu groß.
                                  Deinstallier den telegram-Adapter und dann installierst du den neu.
                                    @andreas-stürzer
                                    Andreas Stürzer
                                    @thomas-braun Leider nicht:
                                    iobroker install telegram
                                    adapter "telegram" cannot be installed: Cannot read properties of undefined (reading 'enabled')
                                      mcm1957M Online
                                      mcm1957M Online
                                      mcm1957
                                      Kann nur beisteuern dass eine Installation bei mir problemlos durchlief.
                                      Support Repositoryverwaltung.
                                      LESEN - gute Forenbeitrage
                                      • mcm1957M mcm1957
                                        @mcm57
                                        Bei mir auch. Keine Ahnung wo es da beim TE klemmt.
                                          @mcm57
                                          @thomas-braun sagte in Fehler beim Update des Telegram Adapters:
                                          Vielleicht verrät es uns iob install telegram --debug
