  4. Node-Red
  5. Shelly Plus 1PM über MQTTund Node Red schalten
    6.4k
13 Beiträge 3 Kommentatoren 3.4k Aufrufe 2 Beobachtet
  • N NetFritz
    Hallo
    Ich versuche schon ein paar Tage meinen Shelly Plus 1PM zu schalten.
    Der Shelly soll über Mosquito und Node Red über den Node mqtt-out geschaltet werden.
    Habe schon vieles versucht aber es geht nicht.
    Habe im Netz folgendes gefunden.
    shellyplus1pm-3c610579ce9c/rpc/{"id":0, "src":"user_1", "method":"Switch.Set", "params":{"id":0,"on":true}}
    Ich kann den Shelly über Mosquito - Node Red mqtt-in Spannung,Leistung,Strom und ob er Ein oder Aus ist abfragen.
            "id": "964735a35b7aa98a",
            "type": "debug",
            "z": "f82aa93122621ea5",
            "name": "Spannung",
            "active": true,
            "tosidebar": true,
            "console": false,
            "tostatus": false,
            "complete": "payload",
            "targetType": "msg",
            "statusVal": "",
            "statusType": "auto",
            "x": 950,
            "y": 100,
            "wires": []
            "id": "c2565c95cb85bf8f",
            "type": "change",
            "name": "",
            "rules": [
                    "t": "set",
                    "p": "payload",
                    "pt": "msg",
                    "to": "payload.voltage",
                    "tot": "msg"
            "action": "",
            "property": "",
            "from": "",
            "to": "",
            "reg": false,
            "x": 710,
            "y": 100,
            "wires": [
                    "964735a35b7aa98a"
            "id": "29acf3fe02d623fd",
            "type": "json",
            "name": "",
            "property": "payload",
            "action": "",
            "pretty": false,
            "x": 490,
            "y": 100,
            "wires": [
                    "6dab402eca743cf0",
                    "c2565c95cb85bf8f",
                    "de25efb695d82cbc",
                    "863b0621f826911d"
            "id": "d95a1c0e2ab9a70d",
            "type": "mqtt in",
            "name": "",
            "topic": "shellyplus1pm-3c610579ce9c/status/switch:0",
            "qos": "0",
            "datatype": "auto",
            "broker": "1239431927fd4b8e",
            "nl": false,
            "rap": true,
            "rh": 0,
            "inputs": 0,
            "x": 190,
            "y": 100,
            "wires": [
                    "29acf3fe02d623fd",
                    "43e928ccc34ec5dd"
            "id": "6dab402eca743cf0",
            "type": "debug",
            "name": "json",
            "active": false,
            "tosidebar": true,
            "console": false,
            "tostatus": false,
            "statusVal": "",
            "x": 670,
            "y": 40,
            "wires": []
            "id": "43e928ccc34ec5dd",
            "type": "debug",
            "name": "debug 8",
            "active": false,
            "tosidebar": true,
            "console": false,
            "tostatus": false,
            "complete": "false",
            "statusVal": "",
            "x": 480,
            "y": 40,
            "wires": []
            "id": "7a62379f4c8012f7",
            "type": "debug",
            "name": "Leistung",
            "active": true,
            "tosidebar": true,
            "console": false,
            "tostatus": false,
            "statusVal": "",
            "x": 940,
            "y": 180,
            "wires": []
            "id": "de25efb695d82cbc",
            "type": "change",
            "name": "",
            "rules": [
                    "t": "set",
                    "p": "payload",
                    "pt": "msg",
                    "to": "payload.apower",
                    "tot": "msg"
            "action": "",
            "property": "",
            "from": "",
            "to": "",
            "reg": false,
            "x": 710,
            "y": 180,
            "wires": [
                    "7a62379f4c8012f7"
            "id": "863b0621f826911d",
            "type": "change",
            "name": "",
            "rules": [
                    "t": "set",
                    "p": "payload",
                    "pt": "msg",
                    "to": "payload.output",
                    "tot": "msg"
            "action": "",
            "property": "",
            "from": "",
            "to": "",
            "reg": false,
            "x": 730,
            "y": 260,
            "wires": [
                    "f922a276b14e3074"
            "id": "f922a276b14e3074",
            "type": "debug",
            "name": "Schaltstatus",
            "active": true,
            "tosidebar": true,
            "console": false,
            "tostatus": false,
            "statusVal": "",
            "x": 950,
            "y": 260,
            "wires": []
            "id": "1239431927fd4b8e",
            "type": "mqtt-broker",
            "name": "",
            "broker": "192.168.2.6",
            "port": "1883",
            "clientid": "",
            "autoConnect": true,
            "usetls": false,
            "protocolVersion": "4",
            "keepalive": "60",
            "cleansession": true,
            "birthTopic": "",
            "birthQos": "0",
            "birthPayload": "",
            "birthMsg": {},
            "closeTopic": "",
            "closeQos": "0",
            "closePayload": "",
            "closeMsg": {},
            "willTopic": "",
            "willQos": "0",
            "willPayload": "",
            "willMsg": {},
            "userProps": "",
            "sessionExpiry": ""
    Braue mal ein paar Denkanstöße oder ein Flow währen auch nicht schlecht.
    Gruß NetFritz
    mickymM Offline
    mickymM Offline
    mickym
    @netfritz Inzwischen solltest Du die Shellies direkt über einen command Ast schalten können:
           "id": "d775455e51c30f95",
           "type": "mqtt out",
           "z": "529512d1ca548981",
           "name": "",
           "topic": "shellyplus1pm-3c610579ce9c/command/switch:0",
           "qos": "",
           "retain": "",
           "respTopic": "",
           "contentType": "",
           "userProps": "",
           "correl": "",
           "expiry": "",
           "x": 890,
           "y": 680,
           "wires": []
           "id": "c4c7f1430c4a3e09",
           "type": "inject",
           "name": "",
           "props": [
                   "p": "payload"
           "repeat": "",
           "crontab": "",
           "once": false,
           "onceDelay": 0.1,
           "topic": "",
           "payload": "on",
           "payloadType": "str",
           "x": 570,
           "y": 640,
           "wires": [
                   "d775455e51c30f95"
           "id": "b15f359e5ef4442e",
           "type": "inject",
           "name": "",
           "props": [
                   "p": "payload"
           "repeat": "",
           "crontab": "",
           "once": false,
           "onceDelay": 0.1,
           "topic": "",
           "payload": "toggle",
           "x": 570,
           "y": 720,
           "wires": [
                   "d775455e51c30f95"
           "id": "e26c283cc02a643c",
           "type": "inject",
           "name": "",
           "props": [
                   "p": "payload"
           "repeat": "",
           "crontab": "",
           "once": false,
           "onceDelay": 0.1,
           "topic": "",
           "payload": "off",
           "x": 570,
           "y": 680,
           "wires": [
                   "d775455e51c30f95"
           "name": "",
           "port": "1883",
           "clientid": "",
           "usetls": false,
           "keepalive": "60",
           "birthTopic": "",
           "birthQos": "0",
           "birthPayload": "",
           "birthMsg": {},
           "closeTopic": "",
           "closeQos": "0",
           "closePayload": "",
           "closeMsg": {},
           "willTopic": "",
           "willQos": "0",
           "willPayload": "",
           "willMsg": {},
           "userProps": "",
           "sessionExpiry": ""
    über den rpc Datenpunkt kannst Du auch schalten, musst Du aber nicht mehr.
    P 1 Antwort Letzte Antwort
    • mickymM mickym
             "type": "mqtt out",
             "name": "",
             "qos": "",
             "retain": "",
             "respTopic": "",
             "contentType": "",
             "userProps": "",
             "correl": "",
             "expiry": "",
             "x": 890,
             "y": 680,
             "wires": []
             "type": "inject",
             "name": "",
             "props": [
                     "p": "payload"
             "repeat": "",
             "crontab": "",
             "once": false,
             "onceDelay": 0.1,
             "topic": "",
             "payload": "on",
             "x": 570,
             "y": 640,
             "wires": [
                     "d775455e51c30f95"
             "type": "inject",
             "name": "",
             "props": [
                     "p": "payload"
             "repeat": "",
             "crontab": "",
             "once": false,
             "onceDelay": 0.1,
             "topic": "",
             "x": 570,
             "y": 720,
             "wires": [
                     "d775455e51c30f95"
             "type": "inject",
             "name": "",
             "props": [
                     "p": "payload"
             "repeat": "",
             "crontab": "",
             "once": false,
             "onceDelay": 0.1,
             "topic": "",
             "payload": "off",
             "x": 570,
             "y": 680,
             "wires": [
                     "d775455e51c30f95"
             "name": "",
             "port": "1883",
             "clientid": "",
             "usetls": false,
             "keepalive": "60",
             "birthTopic": "",
             "birthQos": "0",
             "birthPayload": "",
             "birthMsg": {},
             "closeTopic": "",
             "closeQos": "0",
             "closePayload": "",
             "closeMsg": {},
             "willTopic": "",
             "willQos": "0",
             "willPayload": "",
             "willMsg": {},
             "userProps": "",
             "sessionExpiry": ""
      Philipp 5
      @mickym Hi, ich sitz jetzt seit 3h dran 😬 . Kannst du mir den Inhalt von z.B off schicken und der MqttOut posten?
      • P Philipp 5
        mickymM Offline
        mickymM Offline
        mickym
        @philipp-5 Na so wie Du es in der Abbildung siehst. Am Anfang steht halt dein Shelly und dann
        ..../command/switch:0
        halt mit den Doppelpunkt und Deinem Pfad zum Gerät
        • mickymM mickym
          Philipp 5
          @mickym ... joa.. und im inject einfach als string off schreiben ?
          • P Philipp 5
            mickymM Offline
            mickymM Offline
            mickym
            @philipp-5 ja off/on/toogle also EINS von den dreien. Aber nur wenn es ein Gerät der 2. Generation ist. Bei Geräten der 1. Generation ist der Pfad anders. Was hast Du denn?
            • mickymM mickym
              Philipp 5
              @mickym Hab einen Plug S. Danke dir.. Ich glaube dann liegt mein Problem woanders.
              Kann ihn auslesen aber über command geht nichts.
              • P Philipp 5
                mickymM Offline
                mickymM Offline
                mickym
                @philipp-5 Na die PlugS sind vielleicht Generation 1 - warte da schaut das anders aus. Da musst Du das command unter relay/0 machen.
                Also
                .../relay/0/command
                • mickymM mickym
                  Also
                  .../relay/0/command
                  Philipp 5
                  @mickym
                  :man-facepalming:
                  oh man...
                  ich mach erstmal feierabend für Heute. Hast mir trotzdem schon geholfen, vielen Dank!
                  • P Philipp 5
                    @mickym
                    :man-facepalming:
                    oh man...
                    mickymM Offline
                    mickymM Offline
                    mickym
                    @philipp-5 Hat es geklappt?
                    • mickymM mickym
                      Philipp 5
                      @mickym
                      nope :(
                      • P Philipp 5
                        @mickym
                        nope :(
                        mickymM Offline
                        mickymM Offline
                        mickym
                        @philipp-5
                        Na ich seh schon - das ist eine 2.Generation - aber es fehlt das command topic!!!
                        shelly1/command/switch:0
                        Ich seh kein command Ast
                        Wichtig ist, dass die neueste Firmware drauf ist - die ersten konnten das noch nicht, da musstest Du über den rpc Punkt gehen.
                        • P Offline
                          Philipp 5
                          @mickym
                          hab es eben nochmal versucht und einfach mal einen Factory-Reset durchgeführt.
                          Jetzt gehen die ".../command/swich:0" Befehle auf wundersame weise. Es gibt gerade eine optionale Beta-Firmware. Vielleicht hängt es damit zusammen.
                          Danke dir trotzdem für die Hilfe!
