  4. Neuer Befehl: "iob nodejs-update"
    6.7k
93 Beiträge 27 Kommentatoren 51.9k Aufrufe 36 Beobachtet
  • B Bert 0
    Habe jetzt auch den Befehl versucht auf meinem Raspi Slave mit Version nodejs18.17.1. Ist leider schief gegangen. Fallback auf v18.00.
    Anbei das Protokoll:
    ioBroker nodejs fixer 2023-10-13
    No recommendation for a nodejs version found on your system. We recommend to install latest version from nodejs v18 tree.
    Your current setup is:
    /usr/bin/nodejs         v18.17.1
    /usr/bin/node           v18.17.1
    /usr/bin/npm            9.6.7
    /usr/bin/npx            9.6.7
    /usr/bin/corepack       0.18.0
    We found these nodejs versions available for installation:
    nodejs:
      Installed: 18.17.1-deb-1nodesource1
      Candidate: 18.17.1-deb-1nodesource1
      Version table:
     *** 18.17.1-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_18.x bullseye/main arm64 Packages
         16.20.2-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_16.x bullseye/main arm64 Packages
         12.22.12~dfsg-1~deb11u4 500
            500 http://deb.debian.org/debian bullseye/main arm64 Packages
            500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
    Nothing to do - Your installation is using the correct paths.
    You are running nodejs v18.17.1. Do you want to install latest version from nodejs v.18 tree?
    Press <y> to continue or any other key to quit
    Trying to update your installation now. Please be patient.
    find: '/var/lib/lxcfs/cgroup': Input/output error
    Waiting for ioBroker to shut down - Give me a minute...
    *** These repos are active on your system:
    Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
    Hit:2 http://deb.debian.org/debian bullseye InRelease
    Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
    Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:5 https://apt.pivccu.de/piVCCU stable InRelease
    Reading package lists... Done
    *** Installing ca-certificates, curl and gnupg, just in case they are missing.
    *** Creating new /etc/apt/sources.list.d/nodesource.list and pinning source
    deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_18.x nodistro main
    Package: nodejs
    Pin: origin deb.nodesource.com
    Pin-Priority: 1001
    *** These repos are active after the adjustments:
    Hit:1 http://deb.debian.org/debian bullseye InRelease
    Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
    Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
    Get:6 https://deb.nodesource.com/node_18.x nodistro InRelease [12.1 kB]
    Get:7 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages [6155 B]
    Get:8 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages [6123 B]
    Fetched 24.4 kB in 4s (5509 B/s)
    Installing the recommended nodejs version now!
    Exact recommended version unknown, installing a fallback!
    dpkg: warning: downgrading nodejs from 18.17.1-deb-1nodesource1 to 18.0.0-1nodesource1
    (Reading database ... 91249 files and directories currently installed.)
    Preparing to unpack .../nodejs_18.0.0-1nodesource1_arm64.deb ...
    Detected old npm client, removing...
    Unpacking nodejs (18.0.0-1nodesource1) over (18.17.1-deb-1nodesource1) ...
    Setting up nodejs (18.0.0-1nodesource1) ...
    Processing triggers for man-db (2.9.4-2) ...
    Updating fallback to latest nodejs v18 release
    E: Failed to fetch https://deb.nodesource.com/node_18.x/pool/main/n/nodejs/nodejs_18.18.2-1nodesource1_arm64.deb  Connection timed out [IP: 2606:4700:10::ac43:acd 443]
    E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
    v18.0.0 has been installed! You are using the latest version now!
    Installing the recommended nodejs version!
    E: Failed to fetch https://deb.nodesource.com/node_18.x/pool/main/n/nodejs/nodejs_18.18.2-1nodesource1_arm64.deb  Error reading from server - read (5: Input/output error) [IP: 2606:4700:10::6816:41a 443]
    i
    We tried our best to fix your nodejs. Please run iob diag again to verify.
    *** RESTARTING ioBroker NOW! ***
     Please refresh or restart your browser in a few moments.
    Auserdem noch das Ergebnis bei iob diag
                            v.2023-10-10
       Static hostname: raspberrypi-slave
             Icon name: computer
      Operating System: Debian GNU/Linux 11 (bullseye)
                Kernel: Linux 6.1.21-v8+
          Architecture: arm64
    Kernel:                 aarch64
    Userland:               arm64
    Timezone:               Europe/Berlin (CET, +0100)
    User-ID:                1000
    X-Server:               false
    Boot Target:            multi-user.target
    Pending OS-Updates:     1
    Pending iob updates:    0
    Nodejs-Installation:    /usr/bin/nodejs         v18.0.0
                            /usr/bin/node           v18.0.0
                            /usr/bin/npm            8.6.0
                            /usr/bin/npx            8.6.0
                            /usr/bin/corepack       0.10.0
    Recommended versions are nodejs No connection to databases possible ... and npm No connection to databases possible ...
    MEMORY:
    Mem:            909M        237M        130M        0.0K        541M        608M
    Swap:            99M        2.0M         97M
    Total:          1.0G        239M        227M
    Active iob-Instances:   0
    ioBroker Core:          js-controller           5.0.12
                            admin                   "admin" not found
    ioBroker Status:        No connection to databases possible ...
    Objects:                1
    States:                 1
    Size of iob-Database:
    12M     /opt/iobroker/iobroker-data/objects.jsonl
    796K    /opt/iobroker/iobroker-data/states.jsonl
    Jemand eine Idee?
    #80
    @bert-0 sagte in Neuer Befehl: "iob nodejs-update":
    Jemand eine Idee?
    Das dürfte am nodesource-Server liegen, nicht am Skript.
    sudo apt update
    sudo apt full-update
    sagt?
      Jemand eine Idee?
      sudo apt update
      sagt?
      Bert 0
      #81
      @raspberrypi-slave:~ $ sudo apt update
      OK:1 http://deb.debian.org/debian bullseye InRelease
      OK:2 http://deb.debian.org/debian bullseye-updates InRelease
      OK:3 http://security.debian.org/debian-security bullseye-security InRelease
      OK:4 http://archive.raspberrypi.org/debian bullseye InRelease
      OK:5 https://apt.pivccu.de/piVCCU stable InRelease
      OK:6 https://deb.nodesource.com/node_18.x nodistro InRelease
      Alle Pakete sind aktuell.
      @raspberrypi-slave:~ $ sudo apt full-upgrade
      Paketaktualisierung (Upgrade) wird berechnet… Fertig
      0 aktualisiert, 0 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
      Mit
      sudo apt-get update && sudo apt-get upgrade -y
      hatte ich das nach dem Versuch mit iob nodejs-update dann noch mal drüberlaufen lassen und ist jetzt die aktuelle Version.
      • S Abwesend
        S Abwesend
        Shadowhunter23
        schrieb am zuletzt editiert von Shadowhunter23
        #82
        Ist bei mir seit heute im Angebot:
        Recommended versions are nodejs 18.19.0 and npm 10.2.3
        Auf diese Version kann man updaten?
        Proxmox 9 HA-Cluster mit 3x HP prodesk 400 G6 i5
        ioBroker Backup Analyzer
        • S Shadowhunter23
          #83
          @shadowhunter23
          Scheint ganz neu zu sein.
          Bei nodejs.org ist die 18.18.2 noch geführt.
            @shadowhunter23
            S Abwesend
            S Abwesend
            Shadowhunter23
            #84
            @thomas-braun dann mach ich mal nichts ( Update ) und warte auf andere die sich besser damit auskennen wie z.B. Du.
            • S Shadowhunter23
              #85
              @shadowhunter23 sagte in Neuer Befehl: "iob nodejs-update":
              wo steht das?
                wo steht das?
                S Abwesend
                S Abwesend
                Shadowhunter23
                #86
                Und als Text bei iob diag
                Nodejs-Installation:    /usr/bin/nodejs         v18.18.2        /usr/bin/node           v18.18.2
                                        /usr/bin/npm            9.8.1        /usr/bin/npx            9.8.1
                                        /usr/bin/corepack       0.19.0
                Recommended versions are nodejs 18.19.0 and npm 10.2.3        Your nodejs installation is correct
                • S Shadowhunter23
                  #87
                  @shadowhunter23
                  Das Paket kommt ja über die übliche Systempflege über das nodesource-Repo zu gegebener Zeit rein.
                  Mit 'iob 'nodejs-update' hat das ja nix mehr zu tun, wenn es einmal umgestellt wurde.
                    @shadowhunter23
                    S Abwesend
                    S Abwesend
                    Shadowhunter23
                    #88
                    @thomas-braun stimmt ja danke. Ich muss nur warten, hab ich vergessen. Ich bin ja schon auf der richtigen Version und das kommt dann als Update.
                    • S Shadowhunter23
                      #89
                      Nee, in regelmäßigen Abständen das System 'warten'.
                      • S Shadowhunter23
                        #90
                        @shadowhunter23
                        echad@chet:~ $ apt policy nodejs
                        nodejs:
                          Installed: 21.2.0-1nodesource1
                          Candidate: 21.2.0-1nodesource1
                          Version table:
                         *** 21.2.0-1nodesource1 1001
                                500 https://deb.nodesource.com/node_21.x nodistro/main arm64 Packages
                             18.19.0-1nodesource1 1001
                                500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages
                        Ist also via apt verfügbar.
                          @shadowhunter23
                          nodejs:
                            Version table:
                          S Abwesend
                          S Abwesend
                          Shadowhunter23
                          #91
                          @thomas-braun man muß nur 'warten' ;) :
                          • T tklein
                            @thomas-braun danke dafür. nur bootet der raspi danach nicht mehr. da wurde mal von einem dev op kollegen etwas am system geändert. seitdem klappt es mit dem update nicht mehr. muss dann erst rausfinden, was/wie geändert wurde.
                            #92
                            @tklein
                            Und der Kollege hat dann gesagt, Updates sind überflüssig oder wie?
                            • C Offline
                              Chris197
                              #93
                              konnte auf meinem IOBroker keine Adapter mehr aktuallisieren.
                              Dank diesem Thread funktioniert es nun.
                              Möchte auf diesem Wege mein Dank ausprechen.
                              Gruß, Chris
