  4. Nach Installation Bullseye: Restore funzt nicht
26 Beiträge 4 Kommentatoren 3.2k Aufrufe 4 Beobachtet
    @karacho
    Log File sagt?
    iob diag
    sagt?
    Karacho
    Skript v.2023-10-10
    *** BASE SYSTEM ***
     Static hostname: iobrokernew
           Icon name: computer
              Kernel: Linux 6.1.0-rpi6-rpi-v8
        Architecture: arm64
    Model           : Raspberry Pi 4 Model B Rev 1.2
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : arm64
    Systemuptime and Load:
     21:55:28 up 59 min,  2 users,  load average: 1.86, 1.70, 1.44
    CPU threads: 4
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** Time and Time Zones ***
                   Local time: Tue 2023-11-28 21:55:28 CET
               Universal time: Tue 2023-11-28 20:55:28 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    Boot Target:    multi-user.target
    *** MEMORY ***
    Mem:            4.0G        825M        900M        1.2M        2.3G        3.2G
    Swap:           104M          0B        104M
    Total:          4.1G        825M        1.0G
             3793 M total memory
              787 M used memory
              848 M active memory
             1826 M inactive memory
              858 M free memory
               76 M buffer memory
             2147 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    Raspberry only:
    oom events: 0
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** FILESYSTEM ***
    Filesystem                                 Type      Size  Used Avail Use% Mounted on
    udev                                       devtmpfs  1.6G     0  1.6G   0% /dev
    tmpfs                                      tmpfs     380M  1.2M  379M   1% /run
    /dev/mmcblk0p2                             ext4       59G  4.5G   51G   9% /
    tmpfs                                      tmpfs     1.9G     0  1.9G   0% /dev/shm
    tmpfs                                      tmpfs     5.0M   16K  5.0M   1% /run/lock
    /dev/mmcblk0p1                             vfat      510M   61M  450M  12% /boot/firmware
    tmpfs                                      tmpfs     380M     0  380M   0% /run/user/1000
    //192.168.178.65/backup/Rapsberry/iobroker cifs      2.7T  1.1T  1.6T  41% /opt/iobroker/backups
    [Tue Nov 28 20:55:52 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:61:2C:40 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=77eeeb6e-02 rootfstype=ext4 fsck.repair=yes rootwait
    [Tue Nov 28 20:55:55 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
    [Tue Nov 28 20:55:57 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
    TARGET                    SOURCE                                     FSTYPE OPTIONS
    /                         /dev/mmcblk0p2                             ext4   rw,noatime,commit=600
    |-/boot/firmware          /dev/mmcblk0p1                             vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    `-/opt/iobroker/backups   //192.168.178.65/backup/Rapsberry/iobroker cifs   rw,relatime,vers=2.0,cache=strict,username=backup_eigene,domain=iobroker,uid=1001,noforceuid,gid=1001,noforcegid,addr=192.168.178.65,file_mode=0777,dir_mode=0777,soft,nounix,serverino,mapposix,rsize=65536,wsize=65536,bsize=1048576,echo_interval=60,actimeo=1,closetimeo=1
      `-/opt/iobroker/backups //192.168.178.65/backup/Rapsberry/iobroker cifs   rw,relatime,vers=3.1.1,cache=strict,username=backup_eigene,domain=iobroker,uid=1001,noforceuid,gid=1001,noforcegid,addr=192.168.178.65,file_mode=0777,dir_mode=0777,soft,nounix,serverino,mapposix,rsize=4194304,wsize=4194304,bsize=1048576,echo_interval=60,actimeo=1,closetimeo=1
    /var:
    523M    /var/
    200M    /var/cache
    195M    /var/cache/apt
    163M    /var/lib
    131M    /var/lib/apt/lists
    Archived and active journals take up 60.0M in the file system.
    /opt/iobroker/backups:
    1.2G    /opt/iobroker/backups/
    0       /opt/iobroker/backups/redistmp
    /opt/iobroker/iobroker-data:
    943M    /opt/iobroker/iobroker-data/
    697M    /opt/iobroker/iobroker-data/history
    211M    /opt/iobroker/iobroker-data/files
    52M     /opt/iobroker/iobroker-data/files/javascript.admin
    45M     /opt/iobroker/iobroker-data/files/devices.admin/static
    35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
    27M     /opt/iobroker/iobroker-data/objects.jsonl
    21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
    9.3M    /opt/iobroker/iobroker-data/states.jsonl
    8.9M    /opt/iobroker/iobroker-data/files/scenes.admin/static/js/2.7de3299d.chunk.js.map
    USB-Devices by-id:
    /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_e486124e65c8eb11afebc4c3de5b81b4-if00-port0
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.18.2
    /usr/bin/node           v18.18.2
    /usr/bin/npm            9.8.1
    /usr/bin/npx            9.8.1
    /usr/bin/corepack       0.19.0
    nodejs:
      Installed: 18.18.2-1nodesource1
      Candidate: 18.18.2-1nodesource1
      Version table:
     *** 18.18.2-1nodesource1 500
            500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages
         18.18.1-1nodesource1 500
         18.18.0-1nodesource1 500
         18.17.1-1nodesource1 500
         18.17.0-1nodesource1 500
         18.16.1-1nodesource1 500
         18.16.0-1nodesource1 500
         18.15.0-1nodesource1 500
         18.14.2-1nodesource1 500
         18.14.1-1nodesource1 500
         18.14.0-1nodesource1 500
         18.13.0+dfsg1-1 500
            500 http://deb.debian.org/debian bookworm/main arm64 Packages
         18.13.0-1nodesource1 500
         18.12.0-1nodesource1 500
         18.11.0-1nodesource1 500
         18.10.0-1nodesource1 500
         18.9.1-1nodesource1 500
         18.9.0-1nodesource1 500
         18.8.0-1nodesource1 500
         18.7.0-1nodesource1 500
         18.6.0-1nodesource1 500
         18.5.0-1nodesource1 500
         18.4.0-1nodesource1 500
         18.3.0-1nodesource1 500
         18.2.0-1nodesource1 500
         18.1.0-1nodesource1 500
         18.0.0-1nodesource1 500
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  5.0.16
    admin:          6.12.0
    javascript:     7.1.4
    Adapters from github:   4
    Adapter State
    + system.adapter.admin.0                  : admin                 : iobrokernew                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.backitup.0               : backitup              : iobrokernew                              -  enabled
      system.adapter.bmw.0                    : bmw                   : iobrokernew                              - disabled
      system.adapter.bosch-ebike.0            : bosch-ebike           : iobrokernew                              - disabled
      system.adapter.broadlink2.0             : broadlink2            : iobrokernew                              - disabled
      system.adapter.cloud.0                  : cloud                 : iobrokernew                              - disabled
      system.adapter.daswetter.0              : daswetter             : iobrokernew                              - disabled
      system.adapter.devices.0                : devices               : iobrokernew                              - disabled
      system.adapter.discovery.0              : discovery             : iobrokernew                              - disabled
      system.adapter.dwd.0                    : dwd                   : iobrokernew                              - disabled
      system.adapter.easee.0                  : easee                 : iobrokernew                              - disabled
      system.adapter.ems-esp.0                : ems-esp               : iobrokernew                              - disabled
      system.adapter.energiefluss.0           : energiefluss          : iobrokernew                              - disabled
      system.adapter.flot.0                   : flot                  : iobrokernew                              - disabled
      system.adapter.harmony.0                : harmony               : iobrokernew                              - disabled
      system.adapter.heatingcontrol.0         : heatingcontrol        : iobrokernew                              - disabled
      system.adapter.history.0                : history               : iobrokernew                              - disabled
      system.adapter.hmip.0                   : hmip                  : iobrokernew                              - disabled
      system.adapter.homeconnect.0            : homeconnect           : iobrokernew                              - disabled
      system.adapter.hs100.0                  : hs100                 : iobrokernew                              - disabled
      system.adapter.ical.0                   : ical                  : iobrokernew                              - disabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobrokernew                              - disabled
      system.adapter.info.0                   : info                  : iobrokernew                              - disabled
      system.adapter.javascript.0             : javascript            : iobrokernew                              - disabled
      system.adapter.meater.0                 : meater                : iobrokernew                              - disabled
      system.adapter.mercedesme.0             : mercedesme            : iobrokernew                              - disabled
      system.adapter.mihome-vacuum.0          : mihome-vacuum         : iobrokernew                              - disabled, port: 54321
      system.adapter.mihome-vacuum.1          : mihome-vacuum         : iobrokernew                              - disabled, port: 54321
      system.adapter.nuki-extended.0          : nuki-extended         : iobrokernew                              - disabled
      system.adapter.pushover.0               : pushover              : iobrokernew                              - disabled
      system.adapter.rpi2.0                   : rpi2                  : iobrokernew                              - disabled
      system.adapter.scenes.0                 : scenes                : iobrokernew                              - disabled
      system.adapter.smartgarden.0            : smartgarden           : iobrokernew                              - disabled
      system.adapter.solarlog.0               : solarlog              : iobrokernew                              - disabled, port: 80
      system.adapter.sonoff.0                 : sonoff                : iobrokernew                              - disabled, port: 1883, bind: 0.0.0.0
      system.adapter.trashschedule.0          : trashschedule         : iobrokernew                              - disabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : iobrokernew                              - disabled
      system.adapter.vis-justgage.0           : vis-justgage          : iobrokernew                              - disabled
      system.adapter.vis-rgraph.0             : vis-rgraph            : iobrokernew                              - disabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobrokernew                              - disabled
      system.adapter.vis.0                    : vis                   : iobrokernew                              - disabled
      system.adapter.web.1                    : web                   : iobrokernew                              - disabled, port: 8082, bind: 0.0.0.0, run as: admin
      system.adapter.worx.0                   : worx                  : iobrokernew                              - disabled
      system.adapter.zigbee.0                 : zigbee                : iobrokernew                              - disabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_e486124e65c8eb11afebc4c3de5b81b4-if00-port0
    + instance is alive
    ioBroker-Repositories
    Stable (default): http://download.iobroker.net/sources-dist.json
    Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
    Installed ioBroker-Instances
    Adapter    "admin"        : 6.12.0   , installed 6.12.0
    Adapter    "backitup"     : 2.8.7    , installed 2.8.7
    Adapter    "bmw"          : 2.5.7    , installed 2.6.3
    Adapter    "bosch-ebike"  : 0.0.3    , installed 0.1.0
    Adapter    "broadlink2"   : 2.1.5    , installed 2.1.5
    Adapter    "cloud"        : 4.4.1    , installed 4.4.1
    Adapter    "daswetter"    : 3.1.10   , installed 3.1.10
    Adapter    "devices"      : 1.1.5    , installed 1.1.5
    Adapter    "discovery"    : 4.2.0    , installed 4.2.0
    Adapter    "easee"        : 1.0.10   , installed 1.0.10
    Adapter    "ems-esp"      : 2.6.1    , installed 2.6.1
    Adapter    "harmony"      : 1.3.0    , installed 1.2.2  [Updatable]
    Adapter    "heatingcontrol": 2.11.1  , installed 2.11.1
    Adapter    "hmip"         : 1.20.0   , installed 1.20.0
    Adapter    "homeconnect"  : 1.1.1    , installed 1.1.1
    Adapter    "ical"         : 1.13.3   , installed 1.13.3
    Adapter    "javascript"   : 7.1.6    , installed 7.1.4  [Updatable]
    Controller "js-controller": 5.0.16   , installed 5.0.16
    Adapter    "mihome-vacuum": 4.1.0    , installed 4.0.0  [Updatable]
    Adapter    "nuki-extended": 2.6.5    , installed 2.6.5
    Adapter    "pushover"     : 3.0.3    , installed 3.0.3
    Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
    Adapter    "vis-icontwo"  : 0.97.1   , installed 0.96.0 [Updatable]
    Adapter    "zigbee"       : 1.8.24   , installed 1.8.24
    Objects and States
    Objects:        15731
    States:         13346
    Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
    Hit:3 http://archive.raspberrypi.com/debian bookworm InRelease
    Hit:4 http://deb.debian.org/debian bookworm-updates InRelease
    Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       28078      4884/iobroker.js-co
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       28085      4884/iobroker.js-co
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          16435      723/sshd: /usr/sbin
    tcp6       0      0 :::22                   :::*                    LISTEN      0          16437      723/sshd: /usr/sbin
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       26283      4909/io.admin.0
    udp        0      0 0.0.0.0:49700           0.0.0.0:*                           104        11624      476/avahi-daemon: r
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        11622      476/avahi-daemon: r
    udp6       0      0 :::39159                :::*                                104        11625      476/avahi-daemon: r
    udp6       0      0 :::5353                 :::*                                104        11623      476/avahi-daemon: r
    2023-11-28 21:56:45.045  - info: host.iobrokernew iobroker npm-install: upload [50] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/logos/coreos.png lib/img/logos/coreos.png image/png
    2023-11-28 21:56:45.140  - info: host.iobrokernew iobroker npm-install: upload [40] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/logos/manjaro.png lib/img/logos/manjaro.png image/png
    2023-11-28 21:56:45.236  - info: host.iobrokernew iobroker npm-install: upload [30] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/logos/slackware.png lib/img/logos/slackware.png image/png
    2023-11-28 21:56:45.352  - info: host.iobrokernew iobroker npm-install: upload [20] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/bootstrap.min.js lib/js/bootstrap.min.js application/javascript
    2023-11-28 21:56:45.362  - info: host.iobrokernew iobroker npm-install: upload [19] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/chartist.min.js lib/js/chartist.min.js application/javascript
    2023-11-28 21:56:45.379  - info: host.iobrokernew iobroker npm-install: upload [18] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/clock.js lib/js/clock.js application/javascript
    2023-11-28 21:56:45.390  - info: host.iobrokernew iobroker npm-install: upload [17] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/commons.js lib/js/commons.js application/javascript
    2023-11-28 21:56:45.401  - info: host.iobrokernew iobroker npm-install: upload [16] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/documentation.js lib/js/documentation.js application/javascript
    2023-11-28 21:56:45.412  - info: host.iobrokernew iobroker npm-install: upload [15] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/feednami.min.js lib/js/feednami.min.js application/javascript
    2023-11-28 21:56:45.423  - info: host.iobrokernew iobroker npm-install: upload [14] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/format-google-calender.js lib/js/format-google-calender.js application/javascript
    2023-11-28 21:56:45.434  - info: host.iobrokernew iobroker npm-install: upload [13] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/forum.js lib/js/forum.js application/javascript
    2023-11-28 21:56:45.446  - info: host.iobrokernew iobroker npm-install: upload [12] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/githubData.js lib/js/githubData.js application/javascript
    2023-11-28 21:56:45.458  - info: host.iobrokernew iobroker npm-install: upload [11] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/helper.js lib/js/helper.js application/javascript
    2023-11-28 21:56:45.468  - info: host.iobrokernew iobroker npm-install: upload [10] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/hostInfo.js lib/js/hostInfo.js application/javascript
    2023-11-28 21:56:45.478  - info: host.iobrokernew iobroker npm-install: upload [9] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/info.js lib/js/info.js application/javascript
    2023-11-28 21:56:45.488  - info: host.iobrokernew iobroker npm-install: upload [8] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/news.js lib/js/news.js application/javascript
    2023-11-28 21:56:45.499  - info: host.iobrokernew iobroker npm-install: upload [7] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/popupnews.js lib/js/popupnews.js application/javascript
    2023-11-28 21:56:45.510  - info: host.iobrokernew iobroker npm-install: upload [6] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/searchGithub.js lib/js/searchGithub.js application/javascript
    2023-11-28 21:56:45.520  - info: host.iobrokernew iobroker npm-install: upload [5] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/showdown.min.js lib/js/showdown.min.js application/javascript
    2023-11-28 21:56:45.532  - info: host.iobrokernew iobroker npm-install: upload [4] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/simplemde.min.js lib/js/simplemde.min.js application/javascript
    2023-11-28 21:56:45.553  - info: host.iobrokernew iobroker npm-install: upload [3] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/systemInformation.js lib/js/systemInformation.js application/javascript
    2023-11-28 21:56:45.574  - info: host.iobrokernew iobroker npm-install: upload [2] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/updateAdapter.js lib/js/updateAdapter.js application/javascript
    2023-11-28 21:56:45.583  - info: host.iobrokernew iobroker npm-install: upload [1] info.admin /opt/iobroker/node_modules/iobroker.info/admin/tab_m.html tab_m.html text/html
    2023-11-28 21:56:45.605  - info: host.iobrokernew iobroker npm-install: upload [0] info.admin /opt/iobroker/node_modules/iobroker.info/admin/words.js words.js application/javascript
    2023-11-28 21:56:45.867  - info: host.iobrokernew iobroker npm-install: host.iobrokernew object system.adapter.info created/updated
    • K Karacho
      Skript v.2023-10-10
      *** BASE SYSTEM ***
             Icon name: computer
          Architecture: arm64
      Docker          : false
      Kernel          : aarch64
      Userland        : arm64
      CPU threads: 4
      Current issues:
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      pi
      /home/pi
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Swap:           104M          0B        104M
               3793 M total memory
                787 M used memory
                848 M active memory
                858 M free memory
                 76 M buffer memory
               2147 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      Raspberry only:
      oom events: 0
      *** FILESYSTEM ***
      /var:
      523M    /var/
      200M    /var/cache
      195M    /var/cache/apt
      163M    /var/lib
      USB-Devices by-id:
      /usr/bin/npm            9.8.1
      /usr/bin/npx            9.8.1
      nodejs:
        Version table:
           18.13.0+dfsg1-1 500
      Errors in npm tree:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      admin:          6.12.0
      javascript:     7.1.4
      Adapter State
      + instance is alive
      Objects and States
      Objects:        15731
      States:         13346
      Pending Updates: 0
      @karacho
      Du hast es irgendwie hinbekommen zwei mounts in den selben Mountpunkt zu drücken.
        @karacho
        Karacho
        Wovon redest Du?
        Meinst Du das die alte Version auf einer Festplatte war und ich jetzt auf SD Card bin?
        Was kann ich tun?
        • K Karacho
          Wovon redest Du?
          Was kann ich tun?
          @karacho
          Ich rede davon:
          Das geht nicht. Wie und wo du auch immer das so eingestellt hast. In der /etc/fstab und dann nochmal per Backitup gemountet?
            @karacho
            Ich rede davon:
            Karacho
            Ich hatte mein NFS erst mit smb311 verbunden, daber keine Verbindung .. dann auf smb20 geändert...
            • K Karacho
              @karacho
              Das ist aber irgendwie doppelt.
                @karacho
                Karacho
                wie kriege ich das weg, so dass dann die adpater alle installiert werden?
                • K Karacho
                  @karacho sagte in Nach Installation Bullseye: Restore funzt nicht:
                  Wie hast du es denn hinbekommen? Ich weiß immer noch nicht an welcher Stelle du da was eingestellt hast. Im Backitup-Adapter?
                    Karacho
                    ja im Backup Adapter
                    • K Karacho
                      @karacho
                      Zeig Mal die Einstellungen da.
                      Und mal
                      sudo umount /opt/iobroker/backups
                        @karacho
                        Und mal
                        Karacho
                        Befehl habe ich ausgeführt
