  4. Vis über npm gibt EHOSTUNREACH
64 Beiträge 5 Kommentatoren 9.6k Aufrufe 3 Beobachtet
  • C Offline
    Christian 5
    @thomas-braun Besten Dank für eure Gedult und Mühe. glg Christian
    C 1 Antwort Letzte Antwort
    • C Christian 5
      Christian 5
      @christian-5 ...so iobroker neu aufgesetzt plus aller updates, nodejs18.installiert.
      ip rout
      default via 10.0.0.250 dev eth0 proto dhcp src 10.0.0.50 metric 100
      10.0.0.0/24 dev eth0 proto kernel scope link src 10.0.0.50 metric 100```
      ping -4 registry.npmjs.org
      PING  (104.16.2.35) 56(84) bytes of data.
      64 bytes from 104.16.2.35 (104.16.2.35): icmp_seq=1 ttl=57 time=22.7 ms
      64 bytes from 104.16.2.35 (104.16.2.35): icmp_seq=2 ttl=57 time=16.1 ms
      • C Christian 5
        ip rout
        Christian 5
        @christian-5 nur leider bekomme ich noch immer kein VIS 1.5.1 auch nicht im beta Respositorie
        Latest: http://download.iobroker.net/sources-dist-latest.json
        Latest: http://repo.iobroker.live/sources-dist-latest.json
        http://iobroker.live/repo/sources-dist-latest.json
        • C Christian 5
          @christian-5
          iob repo list
          iob update
          sagt?
            @christian-5
            iob repo list
            iob update
            sagt?
            Christian 5
            Skript v.2023-10-10
            *** BASE SYSTEM ***
             Static hostname: iobroker
                   Icon name: computer
                      Kernel: Linux 6.1.0-rpi6-rpi-v8
                Architecture: arm64
            Model           : Raspberry Pi 4 Model B Rev 1.5
            Docker          : false
            Virtualization  : none
            Kernel          : aarch64
            Userland        : arm64
            Systemuptime and Load:
             23:19:29 up 29 min,  2 users,  load average: 1.60, 1.45, 1.15
            CPU threads: 4
            *** RASPBERRY THROTTLING ***
            Current issues:
            Previously detected issues:
            *** Time and Time Zones ***
                           Local time: Fri 2023-11-24 23:19:29 CET
                       Universal time: Fri 2023-11-24 22:19:29 UTC
                             RTC time: n/a
                            Time zone: Europe/Vienna (CET, +0100)
                          NTP service: active
                      RTC in local TZ: no
            *** User and Groups ***
            Christian
            /home/Christian
            Christian adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
            *** X-Server-Setup ***
            X-Server:       false
            Desktop:
            Terminal:       tty
            Boot Target:    multi-user.target
            *** MEMORY ***
            Mem:            8.2G        1.0G        4.5G        1.2M        2.8G        7.2G
            Swap:           104M          0B        104M
            Total:          8.3G        1.0G        4.7G
                     7810 M total memory
                      971 M used memory
                     1069 M active memory
                     2097 M inactive memory
                     4336 M free memory
                       86 M buffer memory
                     2538 M swap cache
                       99 M total swap
                        0 M used swap
                       99 M free swap
            Raspberry only:
            oom events: 0
            *** FAILED SERVICES ***
            0 loaded units listed.
            *** FILESYSTEM ***
            udev           devtmpfs  3.6G     0  3.6G   0% /dev
            tmpfs          tmpfs     782M  1.2M  780M   1% /run
            /dev/sda2      ext4      117G  4.5G  107G   5% /
            tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
            tmpfs          tmpfs     5.0M   16K  5.0M   1% /run/lock
            /dev/sda1      vfat      510M   61M  450M  12% /boot/firmware
            tmpfs          tmpfs     782M     0  782M   0% /run/user/1000
            [Fri Nov 24 22:50:13 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=D8:3A:DD:2A:25:6C vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=167ecb30-02 rootfstype=ext4 fsck.repair=yes rootwait
            [Fri Nov 24 22:50:16 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
            [Fri Nov 24 22:50:18 2023] EXT4-fs (sda2): re-mounted. Quota mode: none.
            TARGET           SOURCE    FSTYPE OPTIONS
            /                /dev/sda2 ext4   rw,noatime
            `-/boot/firmware /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
            /var:
            629M    /var/
            317M    /var/cache
            311M    /var/cache/apt
            200M    /var/cache/apt/archives
            163M    /var/lib
            Archived and active journals take up 48.2M in the file system.
            /opt/iobroker/backups:
            15M     /opt/iobroker/backups/
            /opt/iobroker/iobroker-data:
            455M    /opt/iobroker/iobroker-data/
            403M    /opt/iobroker/iobroker-data/files
            132M    /opt/iobroker/iobroker-data/files/vis-2
            81M     /opt/iobroker/iobroker-data/files/vis-2/static
            80M     /opt/iobroker/iobroker-data/files/vis-2/static/js
            51M     /opt/iobroker/iobroker-data/objects.jsonl
            21M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.0b890418.js.map
            19M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.da06e220.js.map
            19M     /opt/iobroker/iobroker-data/files/vis-2/customWidgets.js.map
            14M     /opt/iobroker/iobroker-data/files/vis-2/static/js/258.6829e51a.chunk.js.map
            USB-Devices by-id:
            find: '/dev/serial/by-id/': No such file or directory
            *** NodeJS-Installation ***
            /usr/bin/nodejs         v18.17.1
            /usr/bin/node           v18.17.1
            /usr/bin/npm            9.6.7
            /usr/bin/npx            9.6.7
            /usr/bin/corepack       0.18.0
            nodejs:
              Installed: 18.17.1-deb-1nodesource1
              Candidate: 18.17.1-deb-1nodesource1
              Version table:
             *** 18.17.1-deb-1nodesource1 500
                    500 https://deb.nodesource.com/node_18.x bookworm/main arm64 Packages
                 18.13.0+dfsg1-1 500
                    500 http://deb.debian.org/debian bookworm/main arm64 Packages
            No problems detected
            Errors in npm tree:
            npm ERR! code ELSPROBLEMS
            npm ERR! extraneous: @types/minimist@ /opt/iobroker/node_modules/@types/minimist
            npm ERR! extraneous: @types/parse-json@ /opt/iobroker/node_modules/@types/parse-json
            npm ERR! extraneous: array-union@ /opt/iobroker/node_modules/array-union
            npm ERR! extraneous: arrify@ /opt/iobroker/node_modules/arrify
            npm ERR! extraneous: async-exit-hook@ /opt/iobroker/node_modules/async-exit-hook
            npm ERR! extraneous: camelcase-keys@ /opt/iobroker/node_modules/camelcase-keys
            npm ERR! extraneous: decamelize-keys@ /opt/iobroker/node_modules/decamelize-keys
            npm ERR! extraneous: duplexer3@ /opt/iobroker/node_modules/duplexer3
            npm ERR! extraneous: hard-rejection@ /opt/iobroker/node_modules/hard-rejection
            npm ERR! extraneous: iobroker.vis-inventwo@ /opt/iobroker/node_modules/iobroker.vis-inventwo
            npm ERR! extraneous: kind-of@ /opt/iobroker/node_modules/kind-of
            npm ERR! extraneous: map-age-cleaner@ /opt/iobroker/node_modules/map-age-cleaner
            npm ERR! extraneous: map-obj@ /opt/iobroker/node_modules/map-obj
            npm ERR! extraneous: min-indent@ /opt/iobroker/node_modules/min-indent
            npm ERR! extraneous: minimist-options@ /opt/iobroker/node_modules/minimist-options
            npm ERR! extraneous: p-defer@ /opt/iobroker/node_modules/p-defer
            npm ERR! extraneous: p-event@ /opt/iobroker/node_modules/p-event
            npm ERR! extraneous: p-finally@ /opt/iobroker/node_modules/p-finally
            npm ERR! extraneous: p-reflect@ /opt/iobroker/node_modules/p-reflect
            npm ERR! extraneous: p-settle@ /opt/iobroker/node_modules/p-settle
            npm ERR! extraneous: path-parse@ /opt/iobroker/node_modules/path-parse
            npm ERR! extraneous: prepend-http@ /opt/iobroker/node_modules/prepend-http
            npm ERR! extraneous: redent@ /opt/iobroker/node_modules/redent
            npm ERR! extraneous: resolve@ /opt/iobroker/node_modules/resolve
            npm ERR! extraneous: strip-indent@ /opt/iobroker/node_modules/strip-indent
            npm ERR! extraneous: supports-preserve-symlinks-flag@ /opt/iobroker/node_modules/supports-preserve-symlinks-flag
            npm ERR! extraneous: to-readable-stream@ /opt/iobroker/node_modules/to-readable-stream
            npm ERR! extraneous: trim-newlines@ /opt/iobroker/node_modules/trim-newlines
            npm ERR! extraneous: url-parse-lax@ /opt/iobroker/node_modules/url-parse-lax
            npm ERR! extraneous: yaml@ /opt/iobroker/node_modules/yaml
            npm ERR! extraneous: camelcase@5.3.1 /opt/iobroker/node_modules/camelcase-keys/node_modules/camelcase
            npm ERR! extraneous: quick-lru@4.0.1 /opt/iobroker/node_modules/camelcase-keys/node_modules/quick-lru
            npm ERR! extraneous: map-obj@1.0.1 /opt/iobroker/node_modules/decamelize-keys/node_modules/map-obj
            npm ERR! extraneous: @iobroker/adapter-core@2.6.8 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/@iobroker/adapter-core
            npm ERR! extraneous: @sindresorhus/is@ /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/@sindresorhus/is
            npm ERR! extraneous: @szmarczak/http-timer@4.0.6 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/@szmarczak/http-timer
            npm ERR! extraneous: aggregate-error@3.1.0 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/aggregate-error
            npm ERR! extraneous: any-observable@ /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/any-observable
            npm ERR! extraneous: boxen@5.1.2 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/boxen
            npm ERR! extraneous: brace-expansion@1.1.11 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/brace-expansion
            npm ERR! extraneous: cacheable-lookup@2.0.1 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/cacheable-lookup
            npm ERR! extraneous: cacheable-request@7.0.4 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/cacheable-request
            npm ERR! extraneous: callsites@3.1.0 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/callsites
            npm ERR! extraneous: camelcase@6.3.0 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/camelcase
            npm ERR! extraneous: chalk@4.1.2 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/chalk
            npm ERR! extraneous: ci-info@2.0.0 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/ci-info
            npm ERR! extraneous: clean-stack@2.2.0 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/clean-stack
            npm ERR! extraneous: cli-boxes@2.2.1 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/cli-boxes
            npm ERR! extraneous: cli-width@3.0.0 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/cli-width
            npm ERR! extraneous: configstore@5.0.1 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/configstore
            npm ERR! extraneous: cosmiconfig@ /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/cosmiconfig
            npm ERR! extraneous: crypto-random-string@2.0.0 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/crypto-random-string
            npm ERR! extraneous: decompress-response@5.0.0 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/decompress-response
            npm ERR! extraneous: del@ /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/del
            npm ERR! extraneous: dot-prop@6.0.1 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/dot-prop
            npm ERR! extraneous: escape-goat@ /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/escape-goat
            npm ERR! extraneous: escape-string-regexp@ /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/escape-string-regexp
            npm ERR! extraneous: figures@3.2.0 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/figures
            npm ERR! extraneous: get-stream@5.2.0 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/get-stream
            npm ERR! extraneous: global-dirs@2.1.0 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/global-dirs
            npm ERR! extraneous: globby@ /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/globby
            npm ERR! extraneous: got@ /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/got
            npm ERR! extraneous: has-yarn@2.1.0 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/has-yarn
            npm ERR! extraneous: hosted-git-info@ /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/hosted-git-info
            npm ERR! extraneous: ignore-walk@3.0.4 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/ignore-walk
            npm ERR! extraneous: import-lazy@2.1.0 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/import-lazy
            npm ERR! extraneous: indent-string@4.0.0 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/indent-string
            npm ERR! extraneous: ini@1.3.7 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/ini
            npm ERR! extraneous: inquirer@ /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/inquirer
            npm ERR! extraneous: is-ci@2.0.0 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/is-ci
            npm ERR! extraneous: is-docker@2.2.1 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/is-docker
            npm ERR! extraneous: is-installed-globally@0.3.2 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/is-installed-globally
            npm ERR! extraneous: is-interactive@1.0.0 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/is-interactive
            npm ERR! extraneous: is-npm@5.0.0 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/is-npm
            npm ERR! extraneous: is-path-cwd@2.2.0 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/is-path-cwd
            npm ERR! extraneous: is-path-inside@3.0.3 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/is-path-inside
            npm ERR! extraneous: is-scoped@2.1.0 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/is-scoped
            npm ERR! extraneous: is-unicode-supported@0.1.0 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/is-unicode-supported
            npm ERR! extraneous: is-url-superb@4.0.0 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/is-url-superb
            npm ERR! extraneous: is-yarn-global@0.3.0 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/is-yarn-global
            npm ERR! extraneous: issue-regex@3.1.0 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/issue-regex
            npm ERR! extraneous: json-buffer@3.0.0 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/json-buffer
            npm ERR! extraneous: latest-version@5.1.0 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/latest-version
            npm ERR! extraneous: locate-path@5.0.0 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/locate-path
            npm ERR! extraneous: log-symbols@4.1.0 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/log-symbols
            npm ERR! extraneous: lowercase-keys@2.0.0 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/lowercase-keys
            npm ERR! extraneous: meow@8.1.2 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/meow
            npm ERR! extraneous: mimic-fn@3.1.0 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/mimic-fn
            npm ERR! extraneous: mimic-response@2.1.0 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/mimic-response
            npm ERR! extraneous: minimatch@3.1.2 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/minimatch
            npm ERR! extraneous: new-github-release-url@1.0.0 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/new-github-release-url
            npm ERR! extraneous: normalize-url@6.1.0 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/normalize-url
            npm ERR! extraneous: np@ /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/np
            npm ERR! extraneous: npm-name@6.0.1 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/npm-name
            npm ERR! extraneous: open@ /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/open
            npm ERR! extraneous: ow@ /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/ow
            npm ERR! extraneous: p-cancelable@2.1.1 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/p-cancelable
            npm ERR! extraneous: p-limit@2.3.0 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/p-limit
            npm ERR! extraneous: p-locate@4.1.0 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/p-locate
            npm ERR! extraneous: p-map@4.0.0 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/p-map
            npm ERR! extraneous: p-memoize@4.0.4 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/p-memoize
            npm ERR! extraneous: p-timeout@4.1.0 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/p-timeout
            npm ERR! extraneous: package-json@6.5.0 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/package-json
            npm ERR! extraneous: path-exists@4.0.0 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/path-exists
            npm ERR! extraneous: pkg-dir@5.0.0 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/pkg-dir
            npm ERR! extraneous: pupa@2.1.1 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/pupa
            npm ERR! extraneous: read-pkg-up@7.0.1 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/read-pkg-up
            npm ERR! extraneous: read-pkg@5.2.0 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/read-pkg
            npm ERR! extraneous: registry-url@5.1.0 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/registry-url
            npm ERR! extraneous: responselike@2.0.1 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/responselike
            npm ERR! extraneous: run-async@2.4.1 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/run-async
            npm ERR! extraneous: rxjs@ /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/rxjs
            npm ERR! extraneous: scoped-regex@2.1.0 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/scoped-regex
            npm ERR! extraneous: semver-diff@3.1.1 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/semver-diff
            npm ERR! extraneous: slash@3.0.0 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/slash
            npm ERR! extraneous: symbol-observable@ /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/symbol-observable
            npm ERR! extraneous: terminal-link@2.1.1 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/terminal-link
            npm ERR! extraneous: tslib@1.14.1 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/tslib
            npm ERR! extraneous: type-fest@0.18.1 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/type-fest
            npm ERR! extraneous: unique-string@2.0.0 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/unique-string
            npm ERR! extraneous: update-notifier@ /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/update-notifier
            npm ERR! extraneous: widest-line@3.1.0 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/widest-line
            npm ERR! extraneous: xdg-basedir@4.0.0 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/xdg-basedir
            npm ERR! invalid: yargs-parser@ /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/yargs-parser
            npm ERR! extraneous: yargs-parser@ /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/yargs-parser
            npm ERR! extraneous: is-plain-obj@1.1.0 /opt/iobroker/node_modules/minimist-options/node_modules/is-plain-obj
            npm ERR! extraneous: p-timeout@3.2.0 /opt/iobroker/node_modules/p-event/node_modules/p-timeout
            npm ERR! extraneous: p-limit@2.3.0 /opt/iobroker/node_modules/p-settle/node_modules/p-limit
            npm ERR! extraneous: indent-string@4.0.0 /opt/iobroker/node_modules/redent/node_modules/indent-string
            npm ERR! extraneous: type-fest@0.20.2 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/boxen/node_modules/type-fest
            npm ERR! extraneous: dot-prop@5.3.0 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/configstore/node_modules/dot-prop
            npm ERR! extraneous: escape-string-regexp@1.0.5 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/figures/node_modules/escape-string-regexp
            npm ERR! extraneous: type-fest@0.10.0 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/got/node_modules/type-fest
            npm ERR! invalid: @types/minimist@ /opt/iobroker/node_modules/@types/minimist
            npm ERR! invalid: camelcase-keys@ /opt/iobroker/node_modules/camelcase-keys
            npm ERR! invalid: decamelize-keys@ /opt/iobroker/node_modules/decamelize-keys
            npm ERR! invalid: hard-rejection@ /opt/iobroker/node_modules/hard-rejection
            npm ERR! invalid: minimist-options@ /opt/iobroker/node_modules/minimist-options
            npm ERR! invalid: redent@ /opt/iobroker/node_modules/redent
            npm ERR! invalid: trim-newlines@ /opt/iobroker/node_modules/trim-newlines
            npm ERR! extraneous: type-fest@0.4.1 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/new-github-release-url/node_modules/type-fest
            npm ERR! invalid: got@ /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/got
            npm ERR! extraneous: p-map@3.0.0 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/npm-name/node_modules/p-map
            npm ERR! extraneous: @sindresorhus/is@4.6.0 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/ow/node_modules/@sindresorhus/is
            npm ERR! extraneous: type-fest@0.20.2 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/ow/node_modules/type-fest
            npm ERR! invalid: map-age-cleaner@ /opt/iobroker/node_modules/map-age-cleaner
            npm ERR! invalid: p-settle@ /opt/iobroker/node_modules/p-settle
            npm ERR! extraneous: @sindresorhus/is@0.14.0 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/package-json/node_modules/@sindresorhus/is
            npm ERR! extraneous: @szmarczak/http-timer@1.1.2 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/package-json/node_modules/@szmarczak/http-timer
            npm ERR! extraneous: cacheable-request@6.1.0 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/package-json/node_modules/cacheable-request
            npm ERR! extraneous: decompress-response@3.3.0 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/package-json/node_modules/decompress-response
            npm ERR! extraneous: defer-to-connect@1.1.3 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/package-json/node_modules/defer-to-connect
            npm ERR! extraneous: got@9.6.0 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/package-json/node_modules/got
            npm ERR! extraneous: keyv@3.1.0 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/package-json/node_modules/keyv
            npm ERR! extraneous: mimic-response@1.0.1 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/package-json/node_modules/mimic-response
            npm ERR! extraneous: normalize-url@4.5.1 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/package-json/node_modules/normalize-url
            npm ERR! extraneous: p-cancelable@1.1.0 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/package-json/node_modules/p-cancelable
            npm ERR! extraneous: responselike@1.0.2 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/package-json/node_modules/responselike
            npm ERR! extraneous: semver@6.3.1 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/package-json/node_modules/semver
            npm ERR! extraneous: to-readable-stream@1.0.0 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/package-json/node_modules/to-readable-stream
            npm ERR! extraneous: escape-goat@2.1.1 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/pupa/node_modules/escape-goat
            npm ERR! extraneous: find-up@4.1.0 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/read-pkg-up/node_modules/find-up
            npm ERR! extraneous: type-fest@0.8.1 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/read-pkg-up/node_modules/type-fest
            npm ERR! extraneous: hosted-git-info@2.8.9 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/read-pkg/node_modules/hosted-git-info
            npm ERR! extraneous: normalize-package-data@2.5.0 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/read-pkg/node_modules/normalize-package-data
            npm ERR! extraneous: semver@5.7.2 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/read-pkg/node_modules/semver
            npm ERR! extraneous: type-fest@0.6.0 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/read-pkg/node_modules/type-fest
            npm ERR! extraneous: semver@6.3.1 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/semver-diff/node_modules/semver
            npm ERR! extraneous: global-dirs@3.0.1 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/update-notifier/node_modules/global-dirs
            npm ERR! extraneous: ini@2.0.0 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/update-notifier/node_modules/ini
            npm ERR! extraneous: is-installed-globally@0.4.0 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/update-notifier/node_modules/is-installed-globally
            npm ERR! invalid: p-finally@ /opt/iobroker/node_modules/p-finally
            npm ERR! invalid: fsevents@ /opt/iobroker/node_modules/fsevents
            npm ERR! invalid: duplexer3@ /opt/iobroker/node_modules/duplexer3
            npm ERR! extraneous: get-stream@4.1.0 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/package-json/node_modules/got/node_modules/get-stream
            npm ERR! extraneous: lowercase-keys@1.0.1 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/package-json/node_modules/got/node_modules/lowercase-keys
            npm ERR! invalid: url-parse-lax@ /opt/iobroker/node_modules/url-parse-lax
            npm ERR! extraneous: lowercase-keys@1.0.1 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/package-json/node_modules/responselike/node_modules/lowercase-keys
            npm ERR! invalid: resolve@ /opt/iobroker/node_modules/resolve
            npm ERR! A complete log of this run can be found in: /home/Christian/.npm/_logs/2023-11-24T22_19_36_820Z-debug-0.log
            *** ioBroker-Installation ***
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            Core adapters versions
            js-controller:  5.0.16
            admin:          6.12.0
            javascript:     7.1.4
            Adapters from github:   2
            Adapter State
              system.adapter.alexa2.0                 : alexa2                : iobroker                                 - disabled
            + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
              system.adapter.bydhvs.0                 : bydhvs                : iobroker                                 - disabled
              system.adapter.cloud.0                  : cloud                 : iobroker                                 - disabled
              system.adapter.device-reminder.0        : device-reminder       : iobroker                                 - disabled
              system.adapter.discovery.0              : discovery             : iobroker                                 - disabled
              system.adapter.email.0                  : email                 : iobroker                                 - disabled
              system.adapter.energiefluss.0           : energiefluss          : iobroker                                 - disabled
              system.adapter.fronius-solarweb.0       : fronius-solarweb      : iobroker                                 - disabled
              system.adapter.fronius.0                : fronius               : iobroker                                 -  enabled
              system.adapter.fullybrowser.0           : fullybrowser          : iobroker                                 - disabled
              system.adapter.hs100.0                  : hs100                 : iobroker                                 - disabled
              system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: iobroker                                 - disabled
              system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : iobroker                                 - disabled
              system.adapter.icons-icons8.0           : icons-icons8          : iobroker                                 - disabled
              system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker                                 - disabled
              system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 - disabled
              system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobroker                                 - disabled
              system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : iobroker                                 - disabled
              system.adapter.influxdb.0               : influxdb              : iobroker                                 - disabled, port: 8086
              system.adapter.javascript.0             : javascript            : iobroker                                 - disabled
              system.adapter.linkeddevices.0          : linkeddevices         : iobroker                                 - disabled
              system.adapter.modbus.0                 : modbus                : iobroker                                 - disabled
              system.adapter.modbus.1                 : modbus                : iobroker                                 - disabled
              system.adapter.moma.0                   : moma                  : iobroker                                 - disabled
              system.adapter.mqtt.0                   : mqtt                  : iobroker                                 - disabled, port: 1883, bind: 0.0.0.0
              system.adapter.rpi2.0                   : rpi2                  : iobroker                                 - disabled
              system.adapter.sainlogic.0              : sainlogic             : iobroker                                 - disabled, port: 4500, bind: 0.0.0.0
              system.adapter.shelly.0                 : shelly                : iobroker                                 - disabled, port: 1882, bind: 0.0.0.0
              system.adapter.shelly.1                 : shelly                : iobroker                                 - disabled, port: 1882, bind: 0.0.0.0
              system.adapter.sonoff.0                 : sonoff                : iobroker                                 - disabled, port: 1885, bind: 0.0.0.0
              system.adapter.synology.0               : synology              : iobroker                                 - disabled, port: 5000
              system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: iobroker                                 - disabled
              system.adapter.vis-2.0                  : vis-2                 : iobroker                                 - disabled
              system.adapter.vis-bars.0               : vis-bars              : iobroker                                 - disabled
              system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker                                 - disabled
              system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobroker                                 - disabled
              system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 - disabled
              system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 - disabled
              system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 - disabled
              system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 - disabled
              system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 - disabled
              system.adapter.vis-material-advanced.0  : vis-material-advanced : iobroker                                 - disabled
              system.adapter.vis-metro.0              : vis-metro             : iobroker                                 - disabled
              system.adapter.vis-rgraph.0             : vis-rgraph            : iobroker                                 - disabled
              system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
              system.adapter.vis-weather.0            : vis-weather           : iobroker                                 - disabled
              system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
              system.adapter.web.0                    : web                   : iobroker                                 - disabled, port: 8082, bind: 0.0.0.0, run as: admin
            + instance is alive
            ioBroker-Repositories
            beta          : http://iobroker.live/repo/sources-dist-latest.json
            Active repo(s): beta
            Installed ioBroker-Instances
            Used repository: beta
            Adapter    "admin"        : 6.12.5   , installed 6.12.0 [Updatable]
            Adapter    "alexa2"       : 3.26.2   , installed 3.26.1 [Updatable]
            Adapter    "backitup"     : 2.9.4    , installed 2.8.7  [Updatable]
            Adapter    "bydhvs"       : 1.5.0    , installed 1.4.0  [Updatable]
            Adapter    "cloud"        : 4.4.1    , installed 4.4.1
            Adapter    "device-reminder": 3.0.0  , installed 3.0.0
            Adapter    "discovery"    : 4.2.0    , installed 4.2.0
            Adapter    "email"        : 1.2.0    , installed 1.2.0
            Adapter    "fronius"      : 2.0.2    , installed 2.0.2
            Adapter    "fronius-solarweb": 0.0.3 , installed 0.0.3
            Adapter    "fullybrowser" : 3.0.7    , installed 3.0.6  [Updatable]
            Adapter    "hs100"        : 2.2.0    , installed 2.2.0
            Adapter    "icons-fatcow-hosting": 0.1.0, installed 0.1.0
            Adapter    "javascript"   : 7.1.6    , installed 7.1.4  [Updatable]
            Controller "js-controller": 5.0.16   , installed 5.0.16
            Adapter    "linkeddevices": 1.5.5    , installed 1.5.5
            Adapter    "modbus"       : 6.0.1    , installed 5.0.11 [Updatable]
            Adapter    "moma"         : 1.2.9    , installed 1.2.9
            Adapter    "mqtt"         : 5.1.0    , installed 5.1.0
            Adapter    "sainlogic"    : 0.10.5   , installed 0.10.5
            Adapter    "shelly"       : 6.6.1    , installed 6.6.1
            Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
            Adapter    "synology"     : 3.0.1    , installed 3.0.1
            Adapter    "vis-2"        : 2.8.0    , installed 2.3.5  [Updatable]
            Adapter    "vis-2-widgets-material": 1.3.11, installed 1.3.3 [Updatable]
            Adapter    "vis-icontwo"  : 0.97.3   , installed 0.96.0 [Updatable]
            Objects and States
            Objects:        10202
            States:         7978
            Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
            Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
            Hit:5 https://deb.nodesource.com/node_18.x bookworm InRelease
            Reading package lists...
            Pending Updates: 0
            *** Listening Ports ***
            tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       16667      1053/iobroker.js-co
            tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       16660      1053/iobroker.js-co
            tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14610      694/sshd: /usr/sbin
            tcp6       0      0 :::8081                 :::*                    LISTEN      1001       14987      1081/io.admin.0
            tcp6       0      0 :::22                   :::*                    LISTEN      0          14612      694/sshd: /usr/sbin
            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        14505      554/avahi-daemon: r
            udp        0      0 0.0.0.0:42398           0.0.0.0:*                           104        14507      554/avahi-daemon: r
            udp6       0      0 :::36421                :::*                                104        14508      554/avahi-daemon: r
            udp6       0      0 fe80::6309:a8e9:9c6:546 :::*                                0          12075      628/NetworkManager
            udp6       0      0 :::5353                 :::*                                104        14506      554/avahi-daemon: r
            2023-11-24 23:20:15.356  - info: host.iobroker iobroker npm-install: Installing iobroker.vis-justgage@2.0.0... (System call)
            2023-11-24 23:20:30.425  - info: host.iobroker iobroker npm-install: added 1 package in 14s244 packages are looking for funding  run `npm fund` for detailshost.iobroker install adapter vis-justgage@2.0.0
            2023-11-24 23:20:30.542  - info: host.iobroker iobroker npm-install: upload [2] vis-justgage.admin /opt/iobroker/node_modules/iobroker.vis-justgage/admin/index.html index.html text/html
            2023-11-24 23:20:30.567  - info: host.iobroker iobroker npm-install: upload [1] vis-justgage.admin /opt/iobroker/node_modules/iobroker.vis-justgage/admin/index_m.html index_m.html text/html
            2023-11-24 23:20:30.578  - info: host.iobroker iobroker npm-install: upload [0] vis-justgage.admin /opt/iobroker/node_modules/iobroker.vis-justgage/admin/justgage.png justgage.png image/png
            2023-11-24 23:20:30.590  - info: host.iobroker iobroker npm-install: INFO: Directory "/opt/iobroker/node_modules/iobroker.vis-justgage/www" was not found! Nothing was uploaded or deleted.
            2023-11-24 23:20:30.660  - info: host.iobroker "system.adapter.vis.0" disabled
            2023-11-24 23:20:30.728  - info: host.iobroker "system.adapter.vis.0" enabled
            2023-11-24 23:20:30.734  - info: host.iobroker iobroker npm-install: Adapter "system.adapter.vis.0" restarted.
            2023-11-24 23:20:30.894  - info: host.iobroker iobroker npm-install: host.iobroker object system.adapter.vis-justgage created/updated
            2023-11-24 23:20:32.004  - info: host.iobroker iobroker npm-install: exit 0
            2023-11-24 23:20:33.005  - warn: host.iobroker startInstance cannot find adapter "vis-material-advanced@1.7.4". Try to install it... 1 attempt
            2023-11-24 23:20:33.005  - info: host.iobroker iobroker install vis-material-advanced@1.7.4 using installedFrom
            2023-11-24 23:20:37.173  - info: host.iobroker iobroker npm-install: NPM version: 9.6.7
            2023-11-24 23:20:37.178  - info: host.iobroker iobroker npm-install: Installing iobroker.vis-material-advanced@1.7.4... (System call)
            2023-11-24 23:20:50.739  - info: host.iobroker iobroker npm-install: added 1 package in 13s
            2023-11-24 23:20:50.740  - info: host.iobroker iobroker npm-install: 244 packages are looking for funding  run `npm fund` for details
            2023-11-24 23:20:50.791  - info: host.iobroker iobroker npm-install: host.iobroker install adapter vis-material-advanced@1.7.4
            2023-11-24 23:20:51.106  - info: host.iobroker iobroker npm-install: upload [1] vis-material-advanced.admin /opt/iobroker/node_modules/iobroker.vis-material-advanced/admin/vis-material-advanced.png vis-material-advanced.png image/png
            2023-11-24 23:20:51.136  - info: host.iobroker iobroker npm-install: upload [0] vis-material-advanced.admin /opt/iobroker/node_modules/iobroker.vis-material-advanced/admin/words.js words.js application/javascript
            2023-11-24 23:20:51.151  - info: host.iobroker iobroker npm-install: INFO: Directory "/opt/iobroker/node_modules/iobroker.vis-material-advanced/www" was not found! Nothing was uploaded or deleted.
            2023-11-24 23:20:51.214  - info: host.iobroker "system.adapter.vis.0" disabled
            2023-11-24 23:20:51.226  - info: host.iobroker "system.adapter.vis.0" enabled
            2023-11-24 23:20:51.335  - info: host.iobroker iobroker npm-install: Adapter "system.adapter.vis.0" restarted.
            2023-11-24 23:20:51.552  - info: host.iobroker iobroker npm-install: host.iobroker object system.adapter.vis-material-advanced created/updated
            • C Christian 5
              Skript v.2023-10-10
              *** BASE SYSTEM ***
                     Icon name: computer
                  Architecture: arm64
              Docker          : false
              Kernel          : aarch64
              Userland        : arm64
              CPU threads: 4
              Current issues:
                               RTC time: n/a
                            NTP service: active
                        RTC in local TZ: no
              Christian
              /home/Christian
              X-Server:       false
              Desktop:
              Terminal:       tty
              *** MEMORY ***
              Swap:           104M          0B        104M
                       7810 M total memory
                        971 M used memory
                       4336 M free memory
                         86 M buffer memory
                       2538 M swap cache
                         99 M total swap
                          0 M used swap
                         99 M free swap
              Raspberry only:
              oom events: 0
              *** FILESYSTEM ***
              /var:
              629M    /var/
              317M    /var/cache
              311M    /var/cache/apt
              163M    /var/lib
              USB-Devices by-id:
              /usr/bin/npm            9.6.7
              /usr/bin/npx            9.6.7
              nodejs:
                Version table:
                   18.13.0+dfsg1-1 500
              Errors in npm tree:
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              admin:          6.12.0
              javascript:     7.1.4
              Adapter State
              + instance is alive
              Objects and States
              Objects:        10202
              States:         7978
              Pending Updates: 0
              @christian-5
              iob nodejs-update
              • C Christian 5
                Skript v.2023-10-10
                *** BASE SYSTEM ***
                       Icon name: computer
                    Architecture: arm64
                Docker          : false
                Kernel          : aarch64
                Userland        : arm64
                CPU threads: 4
                Current issues:
                                 RTC time: n/a
                              NTP service: active
                          RTC in local TZ: no
                Christian
                /home/Christian
                X-Server:       false
                Desktop:
                Terminal:       tty
                *** MEMORY ***
                Swap:           104M          0B        104M
                         7810 M total memory
                          971 M used memory
                         4336 M free memory
                           86 M buffer memory
                         2538 M swap cache
                           99 M total swap
                            0 M used swap
                           99 M free swap
                Raspberry only:
                oom events: 0
                *** FILESYSTEM ***
                /var:
                629M    /var/
                317M    /var/cache
                311M    /var/cache/apt
                163M    /var/lib
                USB-Devices by-id:
                /usr/bin/npm            9.6.7
                /usr/bin/npx            9.6.7
                nodejs:
                  Version table:
                     18.13.0+dfsg1-1 500
                Errors in npm tree:
                ioBroker Status
                Objects type: jsonl
                States  type: jsonl
                admin:          6.12.0
                javascript:     7.1.4
                Adapter State
                + instance is alive
                Objects and States
                Objects:        10202
                States:         7978
                Pending Updates: 0
                @christian-5 sagte in Vis über npm gibt EHOSTUNREACH:
                Installier den iobroker.vis-inventwo nochmal neu.
                Dann die ganzen Adapter auf Stand bringen.
                C 2 Antworten Letzte Antwort
                  Christian 5
                  @thomas-braun Besten Dank, scheint jetzt zu funktionieren. SUUUPER Gute Nacht!!
                  • C Christian 5
                    @christian-5
                    iob diag
                    sagt?
                      Christian 5
                      inventwo Icon Set
                      inventwo Design Widgets
                      beide deinstallieren und dann neu..
                        @christian-5
                        iob diag
                        sagt?
                        Christian 5
                        @thomas-braun sagte in Vis über npm gibt EHOSTUNREACH:
                        iob diag
                        alles grün
                        Skript v.2023-10-10
                        *** BASE SYSTEM ***
                               Icon name: computer
                            Architecture: arm64
                        Docker          : false
                        Kernel          : aarch64
                        Userland        : arm64
                         23:36:54 up 46 min,  2 users,  load average: 0.26, 0.33, 0.69
                        CPU threads: 4
                        Current issues:
                                       Local time: Fri 2023-11-24 23:36:54 CET
                                   Universal time: Fri 2023-11-24 22:36:54 UTC
                                         RTC time: n/a
                                      NTP service: active
                                  RTC in local TZ: no
                        Christian
                        /home/Christian
                        X-Server:       false
                        Desktop:
                        Terminal:       tty
                        *** MEMORY ***
                        Mem:            8.2G        752M        4.3G        1.2M        3.2G        7.4G
                        Swap:           104M          0B        104M
                        Total:          8.3G        752M        4.4G
                                 7810 M total memory
                                  717 M used memory
                                  737 M active memory
                                 2585 M inactive memory
                                 4116 M free memory
                                  146 M buffer memory
                                 2952 M swap cache
                                   99 M total swap
                                    0 M used swap
                                   99 M free swap
                        Raspberry only:
                        oom events: 0
                        *** FILESYSTEM ***
                        /dev/sda2      ext4      117G  4.8G  107G   5% /
                        /var:
                        656M    /var/
                        345M    /var/cache
                        339M    /var/cache/apt
                        227M    /var/cache/apt/archives
                        163M    /var/lib
                        516M    /opt/iobroker/iobroker-data/
                        455M    /opt/iobroker/iobroker-data/files
                        59M     /opt/iobroker/iobroker-data/objects.jsonl
                        21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
                        USB-Devices by-id:
                        /usr/bin/nodejs         v18.18.2
                        /usr/bin/node           v18.18.2
                        /usr/bin/npm            9.8.1
                        /usr/bin/npx            9.8.1
                        /usr/bin/corepack       0.19.0
                        nodejs:
                          Installed: 18.18.2-1nodesource1
                          Candidate: 18.18.2-1nodesource1
                          Version table:
                         *** 18.18.2-1nodesource1 1001
                                500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages
                             18.18.1-1nodesource1 1001
                             18.18.0-1nodesource1 1001
                             18.17.1-1nodesource1 1001
                             18.17.0-1nodesource1 1001
                             18.16.1-1nodesource1 1001
                             18.16.0-1nodesource1 1001
                             18.15.0-1nodesource1 1001
                             18.14.2-1nodesource1 1001
                             18.14.1-1nodesource1 1001
                             18.14.0-1nodesource1 1001
                             18.13.0+dfsg1-1 500
                             18.13.0-1nodesource1 1001
                             18.12.0-1nodesource1 1001
                             18.11.0-1nodesource1 1001
                             18.10.0-1nodesource1 1001
                             18.9.1-1nodesource1 1001
                             18.9.0-1nodesource1 1001
                             18.8.0-1nodesource1 1001
                             18.7.0-1nodesource1 1001
                             18.6.0-1nodesource1 1001
                             18.5.0-1nodesource1 1001
                             18.4.0-1nodesource1 1001
                             18.3.0-1nodesource1 1001
                             18.2.0-1nodesource1 1001
                             18.1.0-1nodesource1 1001
                             18.0.0-1nodesource1 1001
                        Errors in npm tree:
                        ioBroker Status
                        Objects type: jsonl
                        States  type: jsonl
                        admin:          6.12.0
                        javascript:     7.1.4
                        Adapter State
                        + system.adapter.fronius.0                : fronius               : iobroker                                 -  enabled
                        + instance is alive
                        Adapter    "socketio"     : 6.6.0    , installed 6.6.0
                        Adapter    "vis"          : 1.5.1    , installed 1.4.16 [Updatable]
                        Adapter    "vis-justgage" : 2.0.1    , installed 2.0.0  [Updatable]
                        Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
                        Adapter    "web"          : 6.1.10   , installed 6.1.10
                        Adapter    "ws"           : 2.5.8    , installed 2.5.8
                        Objects and States
                        Objects:        10202
                        States:         7988
                        Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
                        Pending Updates: 0
                        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       32280      6971/iobroker.js-co
                        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       31547      6971/iobroker.js-co
                        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       33209      6992/io.admin.0
                        2023-11-24 23:29:21.578  - info: host.iobroker Delete state "system.host.iobroker.versions.npmNewestNext"
                        2023-11-24 23:29:21.585  - info: host.iobroker Some obsolete host states deleted.
                        2023-11-24 23:29:24.288  - info: admin.0 (6992) starting. Version 6.12.0 in /opt/iobroker/node_modules/iobroker.admin, node: v18.18.2, js-controller: 5.0.16
                        2023-11-24 23:29:24.346  - info: admin.0 (6992) requesting all objects
                        2023-11-24 23:29:26.579  - info: admin.0 (6992) received all objects
                        2023-11-24 23:29:26.732  - info: host.iobroker instance system.adapter.backitup.0 started with pid 7014
                        2023-11-24 23:29:27.345  - info: admin.0 (6992) socket.io server listening on port 8081
                        2023-11-24 23:29:27.351  - info: admin.0 (6992) http server listening on port 8081
                        2023-11-24 23:29:27.352  - info: admin.0 (6992) Use link "http://127.0.0.1:8081" to configure.
                        2023-11-24 23:29:29.180  - info: backitup.0 (7014) starting. Version 2.8.7 in /opt/iobroker/node_modules/iobroker.backitup, node: v18.18.2, js-controller: 5.0.16
                        2023-11-24 23:29:29.258  - info: backitup.0 (7014) [iobroker] backup will be activated at 02:40 every 2 day(s)
                        2023-11-24 23:29:29.374  - info: host.iobroker instance system.adapter.fronius.0 started with pid 7034
                        2023-11-24 23:29:31.508  - info: fronius.0 (7034) starting. Version 2.0.2 in /opt/iobroker/node_modules/iobroker.fronius, node: v18.18.2, js-controller: 5.0.16
                        2023-11-24 23:29:35.372  - info: vis.0 (7057) starting. Version 1.4.16 in /opt/iobroker/node_modules/iobroker.vis, node: v18.18.2, js-controller: 5.0.16
                        2023-11-24 23:29:35.716  - info: vis.0 (7057) vis license is OK.
                        2023-11-24 23:29:36.727  - info: vis.0 (7057) Changes in index.html detected => update cache.manifest
                        2023-11-24 23:29:36.751  - info: vis.0 (7057) Upload vis anew, while changes detected...
                        2023-11-24 23:29:37.042  - info: admin.0 (6992) ==> Connected system.user.admin from ::ffff:10.0.0.13
                        2023-11-24 23:29:40.228  - info: host.iobroker "system.adapter.vis.0" disabled
                        2023-11-24 23:29:40.230  - info: host.iobroker stopInstance system.adapter.vis.0 (force=false, process=true)
                        2023-11-24 23:29:40.241  - info: host.iobroker "system.adapter.vis.0" enabled
                        2023-11-24 23:29:40.242  - info: host.iobroker stopInstance system.adapter.vis.0 (force=false, process=true)
                        2023-11-24 23:30:00.184  - info: vis.0 (7057) Uploaded. 0
                        2023-11-24 23:30:00.699  - info: vis.0 (7057) Terminated (NO_ERROR): Without reason
                        2023-11-24 23:30:01.357  - info: host.iobroker instance system.adapter.vis.0 terminated while should be started once
                        • C Christian 5
                          iob diag
                          alles grün
                          Skript v.2023-10-10
                          *** BASE SYSTEM ***
                                 Icon name: computer
                              Architecture: arm64
                          Docker          : false
                          Kernel          : aarch64
                          Userland        : arm64
                          CPU threads: 4
                          Current issues:
                                           RTC time: n/a
                                        NTP service: active
                                    RTC in local TZ: no
                          Christian
                          /home/Christian
                          X-Server:       false
                          Desktop:
                          Terminal:       tty
                          *** MEMORY ***
                          Swap:           104M          0B        104M
                                   7810 M total memory
                                    717 M used memory
                                    737 M active memory
                                   4116 M free memory
                                    146 M buffer memory
                                   2952 M swap cache
                                     99 M total swap
                                      0 M used swap
                                     99 M free swap
                          Raspberry only:
                          oom events: 0
                          *** FILESYSTEM ***
                          /var:
                          656M    /var/
                          345M    /var/cache
                          339M    /var/cache/apt
                          163M    /var/lib
                          USB-Devices by-id:
                          /usr/bin/npm            9.8.1
                          /usr/bin/npx            9.8.1
                          nodejs:
                            Version table:
                               18.13.0+dfsg1-1 500
                          Errors in npm tree:
                          ioBroker Status
                          Objects type: jsonl
                          States  type: jsonl
                          admin:          6.12.0
                          javascript:     7.1.4
                          Adapter State
                          + instance is alive
                          Objects and States
                          Objects:        10202
                          States:         7988
                          Pending Updates: 0
                          Da isser doch.
