  4. keine Geräte im Zigbee Adapter [gelöst - Vielen Dank]
zigbee-adapter
61 Beiträge 2 Kommentatoren 6.5k Aufrufe 2 Beobachtet
  • W wolkenloser
    @thomas-braun sagte in keine Geräte im Zigbee Adapter - funktioniert aber.:
    iob nodejs-update
    Danke für die fixe Antwort:
    Ich hab das mal gemacht - krass was da alles angestossen wird.
    IOB DIAG:
    Copy text starting here:
                            v.2023-10-10
       Static hostname: iobroker
             Icon name: computer-vm
               Chassis: vm
        Virtualization: microsoft
      Operating System: Ubuntu 20.04.6 LTS
                Kernel: Linux 5.4.0-166-generic
          Architecture: x86-64
    Installation:           microsoft
    Kernel:                 x86_64
    Userland:               amd64
    Timezone:               Europe/Berlin (CET, +0100)
    User-ID:                1000
    X-Server:               false
    Pending OS-Updates:     0
    Pending iob updates:    31
    This system needs to be REBOOTED NOW!
    Nodejs-Installation:    /usr/bin/nodejs         v18.18.2
                            /usr/local/bin/node             v18.9.0
                            /usr/local/bin/npm              8.19.1
                            /usr/local/bin/npx              8.19.1
                            /usr/local/bin/corepack         0.14.0
    Recommended versions are nodejs 16.20.2 and npm 8.19.4
    *** nodejs is NOT correctly installed ***
    Wrong installation path detected. This needs to be fixed.
    Please check
    https://forum.iobroker.net/topic/35090/howto-nodejs-installation-und-upgrades-unter-debian
    for more information on how to fix these errors.
    MEMORY:
    Mem:           3.9G        531M        1.3G        1.0M        2.1G        3.2G
    Swap:          2.0G        7.0M        2.0G
    Total:         5.9G        539M        3.2G
    Active iob-Instances:   1
    Active repo(s): stable
    ioBroker Core:          js-controller           4.0.24
                            admin                   6.2.23
    ioBroker Status:        iobroker is not running on this host.
    Objects type: jsonl
    States  type: jsonl
      system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    Objects:                11799
    States:                 10540
    Size of iob-Database:
    16M     /opt/iobroker/iobroker-data/objects.jsonl
    9.7M    /opt/iobroker/iobroker-data/objects.json.migrated
    9.7M    /opt/iobroker/iobroker-data/objects.json.bak.migrated
    0       /opt/iobroker/iobroker-data/objects.json.broken
    2.6M    /opt/iobroker/iobroker-data/states.jsonl
    1.3M    /opt/iobroker/iobroker-data/states.json.migrated
    1.3M    /opt/iobroker/iobroker-data/states.json.bak.migrated
    0       /opt/iobroker/iobroker-data/states.json.broken
    === Mark text until here for copying ===
    So wie es aussieht konnte JS nicht geupdatet werden. Nach dem Reboot versuch ich die drei Befhele nocheinmal....
    @wolkenloser sagte in keine Geräte im Zigbee Adapter - funktioniert aber.:
    Wenn iob nodejs-update
    die falschen Pfade nicht löschen können sollte (ich wüsste aber nicht, warum es das nicht können sollte...) hau die von Hand raus:
    rm /usr/local/bin/n*
    rm /usr/local/bin/corepack
    W 2 Antworten Letzte Antwort
      W Offline
      W Offline
      wolkenloser
      Jetzt sieht die DIAG Anzeige besser aus:
                              v.2023-10-10
                 Chassis: vm
      Kernel:                 x86_64
      Userland:               amd64
      User-ID:                1000
      X-Server:               false
      Pending iob updates:    27
                              /usr/bin/node           v18.18.2
                              /usr/bin/npm            9.8.1
                              /usr/bin/npx            9.8.1
                              /usr/bin/corepack       0.19.0
      MEMORY:
      Mem:           3.9G        322M        1.9G        1.0M        1.7G        3.3G
      Swap:          2.0G          0B        2.0G
      Total:         5.9G        322M        3.8G
                              admin                   "admin" not found
      Objects type: jsonl
      States  type: jsonl
      Objects:                11799
      States:                 10539
      Die roten NPN Fehler waren aber auch jetzt da
      • W wolkenloser
                                v.2023-10-10
                   Chassis: vm
        Kernel:                 x86_64
        Userland:               amd64
        User-ID:                1000
        X-Server:               false
                                /usr/bin/npm            9.8.1
                                /usr/bin/npx            9.8.1
        MEMORY:
        Swap:          2.0G          0B        2.0G
        Objects type: jsonl
        States  type: jsonl
        Objects:                11799
        States:                 10539
        Wassen da los?
        Ran da!
          Wassen da los?
          Ran da!
          W Offline
          W Offline
          wolkenloser
          Das hatte ich zuerst versucht, mit dem Ergebnis das das Update beim ersten Adapter "hängen geblieben" ist. Danach lief der IOBROKER nicht mehr.
          Dann musste ich Freitag auf den Spapshot zurückgehen.
          Bei Mir ist auch Grafana mit a Bord, das würde ich irgendwann al auf ein anderes System bringen, dann würden mir keine Logdaten (Energie Verbrauch) verloren gehen, weil das immer ärgerlich ist.
          Ich veruch es aber gleich nochmal......
          • W wolkenloser
            Das ganz Ding ist ja auch total windschief.
            W 1 Antwort Letzte Antwort
              W Offline
              W Offline
              wolkenloser
              Bin mir nicht sicher ob ich das richtig verstehe..
              in dem verzeichnis steht nur eine Datei
              • W wolkenloser
                Ja, jetzt. Eben stand da aber noch die falsch hingeklatschte nvm-Installation drin.
                  W Offline
                  W Offline
                  wolkenloser
                  Ja, irgendwie schon.
                  Ich habe hier bei edem Update immer wieder extrem Probleme.
                  Nur irgendwie läuft es am Ende dann doch wieder vernüftig.
                  Die Updates sind leider immer problematisch....und ich versuche eigendlich immer nahch de Leitfaden hier vorzugehen...
                  • W wolkenloser
                    Nein, sind sie auf einem ordentlich aufgesetzen System nicht.
                    iob update
                    iob upgrade all
                    sagt?
                      W Offline
                      W Offline
                      wolkenloser
                      schrieb am zuletzt editiert von wolkenloser
                                              v.2023-10-10
                                 Chassis: vm
                      Kernel:                 x86_64
                      Userland:               amd64
                      User-ID:                1000
                      X-Server:               false
                                              /usr/bin/npm            9.8.1
                                              /usr/bin/npx            9.8.1
                      MEMORY:
                      Mem:           3.9G        398M        1.7G        1.0M        1.8G        3.2G
                      Swap:          2.0G          0B        2.0G
                      Total:         5.9G        398M        3.7G
                      Objects type: jsonl
                      States  type: jsonl
                      Objects:                11799
                      States:                 10539
                      Jetzt guck ich mal wegen den Adapter Updates
                        iob update
                        iob upgrade all
                        sagt?
                        W Offline
                        W Offline
                        wolkenloser
                        iob update
                        Mein System hab ich 2019 aufgesetzt.
                        ICh wäre froh wenn das mal "bereinigt ist.
                        Aber mein Linux Wissen ist leider begrenzt....
                        iob update
                        Used repository: stable
                        Adapter    "alias-manager": 1.2.6    , installed 1.2.6
                        Adapter    "backitup"     : 2.8.7    , installed 2.9.3
                        Adapter    "bydbatt"      : 1.1.0    , installed 1.1.0
                        Adapter    "bydhvs"       : 1.4.0    , installed 1.5.0
                        Adapter    "chromecast"   : 3.0.3    , installed 2.3.1  [Updatable]
                        Adapter    "cloud"        : 4.4.1    , installed 4.4.1
                        Adapter    "daswetter"    : 3.1.10   , installed 3.1.11
                        Adapter    "device-reminder": 3.0.0  , installed 1.2.9  [Updatable]
                        Adapter    "discovery"    : 4.2.0    , installed 3.2.0  [Updatable]
                        Adapter    "easee"        : 1.0.10   , installed 1.0.10
                        Adapter    "echarts"      : 1.5.4    , installed 1.0.12 [Updatable]
                        Adapter    "fakeroku"     : 0.2.2    , installed 0.2.2
                        Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
                        Adapter    "fritzbox"     : 0.5.0    , installed 0.2.1  [Updatable]
                        Adapter    "fronius"      : 2.0.2    , installed 2.0.2
                        Adapter    "fronius-solarweb": 0.0.3 , installed 0.0.3
                        Adapter    "harmony"      : 1.2.2    , installed 1.3.0
                        Adapter    "history"      : 3.0.1    , installed 2.2.6  [Updatable]
                        Adapter    "ical"         : 1.13.3   , installed 1.13.3
                        Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
                        Adapter    "info"         : 2.0.0    , installed 1.9.26 [Updatable]
                        Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
                        Controller "js-controller": 5.0.16   , installed 4.0.24 [Updatable]
                        Adapter    "knx"          : 2.0.23   , installed 2.0.13 [Updatable]
                        Adapter    "lg-thinq"     : 0.1.4    , installed 0.1.4
                        Adapter    "lgtv"         : 2.1.2    , installed 1.1.12 [Updatable]
                        Adapter    "midea"        : 0.0.7    , installed 0.0.7
                        Adapter    "mihome"       : 1.4.0    , installed 1.4.0
                        Adapter    "mihome-vacuum": 4.1.0    , installed 3.8.6  [Updatable]
                        Adapter    "moma"         : 1.2.9    , installed 1.2.9
                        Adapter    "onkyo"        : 2.1.2    , installed 2.1.2
                        Adapter    "openweathermap": 0.4.5   , installed 0.3.11 [Updatable]
                        Adapter    "parser"       : 2.0.7    , installed 1.3.2  [Updatable]
                        Adapter    "phantomjs"    : 1.1.3    , installed 1.1.3
                        Adapter    "pi-hole"      : 1.3.6    , installed 1.3.6
                        Adapter    "pvforecast"   : 2.9.0    , installed 2.7.1  [Updatable]
                        Adapter    "sayit"        : 3.0.5    , installed 1.13.0 [Updatable]
                        Adapter    "schwoerer-ventcube": 1.4.2, installed 1.4.2
                        Adapter    "shelly"       : 6.6.1    , installed 6.0.0  [Updatable]
                        Adapter    "shuttercontrol": 1.6.2   , installed 1.6.3
                        Adapter    "smartmeter"   : 3.3.4    , installed 3.3.4
                        Adapter    "socketio"     : 6.5.5    , installed 4.2.0  [Updatable]
                        Adapter    "sonoff"       : 3.0.3    , installed 2.5.7  [Updatable]
                        Adapter    "tankerkoenig" : 3.3.7    , installed 2.1.1  [Updatable]
                        Adapter    "trashschedule": 2.3.0    , installed 2.0.3  [Updatable]
                        Adapter    "tuya"         : 3.14.2   , installed 3.9.4  [Updatable]
                        Adapter    "unifi"        : 0.6.6    , installed 0.5.10 [Updatable]
                        Adapter    "vis-canvas-gauges": 1.0.1, installed 0.1.5  [Updatable]
                        Adapter    "vis-colorpicker": 2.0.3  , installed 1.2.0  [Updatable]
                        Adapter    "vis-justgage" : 2.0.0    , installed 1.0.2  [Updatable]
                        Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
                        Adapter    "vis-lcars"    : 1.1.1    , installed 1.1.1
                        Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
                        Adapter    "vis-material" : 0.1.3    , installed 0.1.3
                        Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
                        Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
                        Adapter    "wifilight"    : 1.1.4    , installed 1.1.4
                        Adapter    "wled"         : 0.7.1    , installed 0.6.7  [Updatable]
                        Adapter    "ws"           : 2.5.8    , installed 1.3.0  [Updatable]
                        Adapter    "zigbee"       : 1.8.24   , installed 1.8.24
                        iob upgrade all
                        This upgrade of "ws" will at least introduce the following changes:
                        -> 2.5.8:
                        Corrected adapter termination if the alias has no target
                        -> 2.5.7:
                        upgraded socket-classes to fix vis problems
                        -> 2.5.6:
                        upgraded socket-classes to correct the error by unsubscribing on client disconnect
                        -> 2.5.5:
                        upgraded socket-classes to fix crash cases
                        -> 2.5.4:
                        added missing node16 requirement
                        -> 2.5.3:
                        Added the subscribing on the specific instance messages
                        -> 2.4.0:
                        (bluefox) extended the getObjects function with the possibility to read the list of IDs
                        BE CAREFUL: THIS IS A MAJOR UPGRADE, WHICH WILL MOST LIKELY INTRODUCE BREAKING CHANGES!
                        Would you like to upgrade ws from @1.3.0 to @2.5.8 now? [(y)es, (n)o]:
                        Thomas BraunT W 2 Antworten Letzte Antwort
                        • W wolkenloser
                          iob update
                          iob update
                          iob upgrade all
                          -> 2.5.8:
                          -> 2.5.7:
                          -> 2.5.6:
                          -> 2.5.5:
                          -> 2.5.4:
                          -> 2.5.3:
                          -> 2.4.0:
                          @wolkenloser
                          Dann hau die Updates rein.
                          Und warum ist da kein admin installiert?
                          • W wolkenloser
                            iob update
                            iob update
                            iob upgrade all
                            -> 2.5.8:
                            -> 2.5.7:
                            -> 2.5.6:
                            -> 2.5.5:
                            -> 2.5.4:
                            -> 2.5.3:
                            -> 2.4.0:
                            W Offline
                            W Offline
                            wolkenloser
                            Ich hab mal y gewählt.... jetzt Installiert er....
                            • W wolkenloser
                              W Offline
                              W Offline
                              wolkenloser
                              Anscheinden dauert das ein Weilchen:
                                @wolkenloser
                                W Offline
                                W Offline
                                wolkenloser
                                @wolkenloser
                                Kann ich nicht sagen....
                                Hat aber heute Nachmittag noch funktioniert..
                                Er hat jetzt erst drei Updates installier.....
                                • W wolkenloser
                                  @wolkenloser
                                  W Offline
                                  W Offline
                                  wolkenloser
                                  was kann ich denn jetzt machen um den Admin wieder hinzuzufügen......?
                                  • W wolkenloser
                                    @wolkenloser
                                    iob add admin
                                      @wolkenloser
                                      iob add admin
                                      W Offline
                                      W Offline
                                      wolkenloser
                                      iob add admin
                                      bis hier schon mal ein großes Dankeschönfür den Support.
                                      Ich kann erst morgen weitermachen.
                                      • W Offline
                                        W Offline
                                        wolkenloser
                                        ich aber Ich habe die Updates gemacht, bei den Adaptern habe kein Chance, schon beim ersten schlägt das Fehl, sowohl über die Konsole und auch über die WEB Oberfläche.
                                        Dann habe ich noch gesehen das es ein Host Update gibt, das habe ich auch gemacht.
                                        Damnach war dann alles auf aktuellstem Stand bis auf die 23 Adapter.
                                        Im Endergebnis läuft der IOBROKER gar nicht mehr.
                                        Wennn ich nach dem reboot nach 5 Minuten iob start all eingebe kommt eine Meldung
                                        iob start all
                                        iob status
                                        Ich habe jetzt den Snapshot von gesten abend wieder eingespielt.
                                        Das letzte was ich danach versucht habe war das Update vom Host gemäß Anleitung
                                        Danach hab ich keinen IOBROKER mehr :-(
                                        • W wolkenloser
                                          iob start all
                                          iob status
                                          @wolkenloser
                                          Meldungen im Logfile?
                                          iob diag
                                          in der Langfassung sagt?
