  4. Test Adapter onvif camera v1.x.x
    6.6k
341 Beiträge 48 Kommentatoren 125.8k Aufrufe 49 Beobachtet
  • K Knusterus
    @tombox
    alles auf dem neusten Stand. admin Version 6.12.0 Sonst keine Fehler.
    Hier nochmal die komplette Fehlerliste. Ich hoffe Du findest den Fehler
    onvif.0
    2023-11-12 19:18:52.881	warn	State "onvif.0.192_168_178_43_8080.infos.streamUris.SecondStreamProfile".http_stream.timeout" has no existing object, this might lead to an error in future versions
    onvif.0
    2023-11-12 19:18:52.818	warn	Used invalid characters: onvif.0.192_168_178_43_8080.infos.streamUris.SecondStreamProfile".http_stream.timeout changed to onvif.0.192_168_178_43_8080.infos.streamUris.SecondStreamProfile_.http_stream.timeout
    onvif.0
    2023-11-12 19:18:52.785	warn	State "onvif.0.192_168_178_43_8080.infos.streamUris.SecondStreamProfile".http_stream.invalidAfterReboot" has no existing object, this might lead to an error in future versions
    onvif.0
    2023-11-12 19:18:52.736	warn	Used invalid characters: onvif.0.192_168_178_43_8080.infos.streamUris.SecondStreamProfile".http_stream.invalidAfterReboot changed to onvif.0.192_168_178_43_8080.infos.streamUris.SecondStreamProfile_.http_stream.invalidAfterReboot
    onvif.0
    2023-11-12 19:18:52.695	warn	State "onvif.0.192_168_178_43_8080.infos.streamUris.SecondStreamProfile".http_stream.invalidAfterConnect" has no existing object, this might lead to an error in future versions
    onvif.0
    2023-11-12 19:18:52.536	warn	Used invalid characters: onvif.0.192_168_178_43_8080.infos.streamUris.SecondStreamProfile".http_stream.invalidAfterConnect changed to onvif.0.192_168_178_43_8080.infos.streamUris.SecondStreamProfile_.http_stream.invalidAfterConnect
    onvif.0
    2023-11-12 19:18:52.449	warn	State "onvif.0.192_168_178_43_8080.infos.streamUris.SecondStreamProfile".http_stream.uri" has no existing object, this might lead to an error in future versions
    onvif.0
    2023-11-12 19:18:52.202	warn	Used invalid characters: onvif.0.192_168_178_43_8080.infos.streamUris.SecondStreamProfile".http_stream.uri changed to onvif.0.192_168_178_43_8080.infos.streamUris.SecondStreamProfile_.http_stream.uri
    onvif.0
    2023-11-12 19:18:52.181	info	Starting snapshot server
    onvif.0
    2023-11-12 19:18:52.180	info	Finished onvif discovery
    onvif.0
    2023-11-12 19:18:52.153	warn	State "onvif.0.192_168_178_43_8080.infos.streamUris.SecondStreamProfile".live_stream_multicast.timeout" has no existing object, this might lead to an error in future versions
    onvif.0
    2023-11-12 19:18:52.065	warn	Used invalid characters: onvif.0.192_168_178_43_8080.infos.streamUris.SecondStreamProfile".live_stream_multicast.timeout changed to onvif.0.192_168_178_43_8080.infos.streamUris.SecondStreamProfile_.live_stream_multicast.timeout
    onvif.0
    2023-11-12 19:18:52.038	warn	State "onvif.0.192_168_178_43_8080.infos.streamUris.SecondStreamProfile".live_stream_multicast.invalidAfterReboot" has no existing object, this might lead to an error in future versions
    onvif.0
    2023-11-12 19:18:51.979	warn	Used invalid characters: onvif.0.192_168_178_43_8080.infos.streamUris.SecondStreamProfile".live_stream_multicast.invalidAfterReboot changed to onvif.0.192_168_178_43_8080.infos.streamUris.SecondStreamProfile_.live_stream_multicast.invalidAfterReboot
    onvif.0
    2023-11-12 19:18:51.941	warn	State "onvif.0.192_168_178_43_8080.infos.streamUris.SecondStreamProfile".live_stream_multicast.invalidAfterConnect" has no existing object, this might lead to an error in future versions
    onvif.0
    2023-11-12 19:18:51.877	warn	Used invalid characters: onvif.0.192_168_178_43_8080.infos.streamUris.SecondStreamProfile".live_stream_multicast.invalidAfterConnect changed to onvif.0.192_168_178_43_8080.infos.streamUris.SecondStreamProfile_.live_stream_multicast.invalidAfterConnect
    onvif.0
    2023-11-12 19:18:51.833	warn	State "onvif.0.192_168_178_43_8080.infos.streamUris.SecondStreamProfile".live_stream_multicast.uri" has no existing object, this might lead to an error in future versions
    onvif.0
    2023-11-12 19:18:51.683	warn	Used invalid characters: onvif.0.192_168_178_43_8080.infos.streamUris.SecondStreamProfile".live_stream_multicast.uri changed to onvif.0.192_168_178_43_8080.infos.streamUris.SecondStreamProfile_.live_stream_multicast.uri
    onvif.0
    2023-11-12 19:18:51.625	warn	State "onvif.0.192_168_178_43_8080.infos.streamUris.SecondStreamProfile".live_stream_udp.timeout" has no existing object, this might lead to an error in future versions
    onvif.0
    2023-11-12 19:18:51.553	warn	Used invalid characters: onvif.0.192_168_178_43_8080.infos.streamUris.SecondStreamProfile".live_stream_udp.timeout changed to onvif.0.192_168_178_43_8080.infos.streamUris.SecondStreamProfile_.live_stream_udp.timeout
    onvif.0
    2023-11-12 19:18:51.531	warn	State "onvif.0.192_168_178_43_8080.infos.streamUris.SecondStreamProfile".live_stream_udp.invalidAfterReboot" has no existing object, this might lead to an error in future versions
    onvif.0
    2023-11-12 19:18:51.462	warn	Used invalid characters: onvif.0.192_168_178_43_8080.infos.streamUris.SecondStreamProfile".live_stream_udp.invalidAfterReboot changed to onvif.0.192_168_178_43_8080.infos.streamUris.SecondStreamProfile_.live_stream_udp.invalidAfterReboot
    onvif.0
    2023-11-12 19:18:51.418	warn	State "onvif.0.192_168_178_43_8080.infos.streamUris.SecondStreamProfile".live_stream_udp.invalidAfterConnect" has no existing object, this might lead to an error in future versions
    onvif.0
    2023-11-12 19:18:51.368	warn	Used invalid characters: onvif.0.192_168_178_43_8080.infos.streamUris.SecondStreamProfile".live_stream_udp.invalidAfterConnect changed to onvif.0.192_168_178_43_8080.infos.streamUris.SecondStreamProfile_.live_stream_udp.invalidAfterConnect
    onvif.0
    2023-11-12 19:18:51.337	warn	State "onvif.0.192_168_178_43_8080.infos.streamUris.SecondStreamProfile".live_stream_udp.uri" has no existing object, this might lead to an error in future versions
    onvif.0
    2023-11-12 19:18:51.249	warn	Used invalid characters: onvif.0.192_168_178_43_8080.infos.streamUris.SecondStreamProfile".live_stream_udp.uri changed to onvif.0.192_168_178_43_8080.infos.streamUris.SecondStreamProfile_.live_stream_udp.uri
    onvif.0
    2023-11-12 19:18:51.173	warn	State "onvif.0.192_168_178_43_8080.infos.streamUris.SecondStreamProfile".live_stream_tcp.timeout" has no existing object, this might lead to an error in future versions
    onvif.0
    2023-11-12 19:18:51.104	warn	Used invalid characters: onvif.0.192_168_178_43_8080.infos.streamUris.SecondStreamProfile".live_stream_tcp.timeout changed to onvif.0.192_168_178_43_8080.infos.streamUris.SecondStreamProfile_.live_stream_tcp.timeout
    onvif.0
    2023-11-12 19:18:51.049	warn	State "onvif.0.192_168_178_43_8080.infos.streamUris.SecondStreamProfile".live_stream_tcp.invalidAfterReboot" has no existing object, this might lead to an error in future versions
    onvif.0
    2023-11-12 19:18:50.943	warn	Used invalid characters: onvif.0.192_168_178_43_8080.infos.streamUris.SecondStreamProfile".live_stream_tcp.invalidAfterReboot changed to onvif.0.192_168_178_43_8080.infos.streamUris.SecondStreamProfile_.live_stream_tcp.invalidAfterReboot
    onvif.0
    2023-11-12 19:18:50.919	warn	State "onvif.0.192_168_178_43_8080.infos.streamUris.SecondStreamProfile".live_stream_tcp.invalidAfterConnect" has no existing object, this might lead to an error in future versions
    onvif.0
    2023-11-12 19:18:50.751	warn	Used invalid characters: onvif.0.192_168_178_43_8080.infos.streamUris.SecondStreamProfile".live_stream_tcp.invalidAfterConnect changed to onvif.0.192_168_178_43_8080.infos.streamUris.SecondStreamProfile_.live_stream_tcp.invalidAfterConnect
    onvif.0
    2023-11-12 19:18:50.503	warn	State "onvif.0.192_168_178_43_8080.infos.streamUris.SecondStreamProfile".live_stream_tcp.uri" has no existing object, this might lead to an error in future versions
    onvif.0
    2023-11-12 19:18:50.324	warn	Used invalid characters: onvif.0.192_168_178_43_8080.infos.streamUris.SecondStreamProfile".live_stream_tcp.uri changed to onvif.0.192_168_178_43_8080.infos.streamUris.SecondStreamProfile_.live_stream_tcp.uri
    onvif.0
    2023-11-12 19:18:50.273	warn	State "onvif.0.192_168_178_43_8080.infos.streamUris.SecondStreamProfile".snapshotUrl.timeout" has no existing object, this might lead to an error in future versions
    onvif.0
    2023-11-12 19:18:50.189	warn	Used invalid characters: onvif.0.192_168_178_43_8080.infos.streamUris.SecondStreamProfile".snapshotUrl.timeout changed to onvif.0.192_168_178_43_8080.infos.streamUris.SecondStreamProfile_.snapshotUrl.timeout
    onvif.0
    2023-11-12 19:18:50.115	warn	State "onvif.0.192_168_178_43_8080.infos.streamUris.SecondStreamProfile".snapshotUrl.invalidAfterReboot" has no existing object, this might lead to an error in future versions
    onvif.0
    2023-11-12 19:18:50.014	warn	Used invalid characters: onvif.0.192_168_178_43_8080.infos.streamUris.SecondStreamProfile".snapshotUrl.invalidAfterReboot changed to onvif.0.192_168_178_43_8080.infos.streamUris.SecondStreamProfile_.snapshotUrl.invalidAfterReboot
    onvif.0
    2023-11-12 19:18:49.983	warn	State "onvif.0.192_168_178_43_8080.infos.streamUris.SecondStreamProfile".snapshotUrl.invalidAfterConnect" has no existing object, this might lead to an error in future versions
    onvif.0
    2023-11-12 19:18:49.930	warn	Used invalid characters: onvif.0.192_168_178_43_8080.infos.streamUris.SecondStreamProfile".snapshotUrl.invalidAfterConnect changed to onvif.0.192_168_178_43_8080.infos.streamUris.SecondStreamProfile_.snapshotUrl.invalidAfterConnect
    onvif.0
    2023-11-12 19:18:49.906	warn	State "onvif.0.192_168_178_43_8080.infos.streamUris.SecondStreamProfile".snapshotUrl.uri" has no existing object, this might lead to an error in future versions
    onvif.0
    2023-11-12 19:18:49.849	warn	Used invalid characters: onvif.0.192_168_178_43_8080.infos.streamUris.SecondStreamProfile".snapshotUrl.uri changed to onvif.0.192_168_178_43_8080.infos.streamUris.SecondStreamProfile_.snapshotUrl.uri
    onvif.0
    2023-11-12 19:18:47.984	info	Device successful initialized: 192.168.178.25:8080
    onvif.0
    2023-11-12 19:18:47.928	info	Device successful initialized: 192.168.178.30:8080
    onvif.0
    2023-11-12 19:18:47.322	info	Try to login to 192.168.178.30:8080 with admin:v****5
    onvif.0
    2023-11-12 19:18:47.317	info	Discovery Reply from 192.168.178.30 (IPCAM) () (http://192.168.178.30:8080/onvif/devices) (urn:uuid:5f5a69c2-e0ae-504f-829b-E8ABFA40520D)
    onvif.0
    2023-11-12 19:18:47.289	info	Skip device 192.168.178.43 because it is already configured via iobroker object. Delete the device under objects for reconfigure.
    onvif.0
    2023-11-12 19:18:47.286	info	Discovery Reply from 192.168.178.43 (IPCAM) (HD-53NV1080HSD) (http://192.168.178.43:8080/onvif/device_service) (um:uuid:5f5a69c2-e0ae-504f-829b-203233397E7B)
    onvif.0
    2023-11-12 19:18:47.258	info	Try to login to 192.168.178.25:8080 with admin:v****5
    onvif.0
    2023-11-12 19:18:47.253	info	Discovery Reply from 192.168.178.25 (IPCAM) () (http://192.168.178.25:8080/onvif/devices) (urn:uuid:5f5a69c2-e0ae-504f-829b-E8ABFA405567)
    onvif.0
    2023-11-12 19:18:47.175	info	Start onvif discovery
    onvif.0
    2023-11-12 19:18:46.396	info	Device successful initialized: 192.168.178.43:8080
    onvif.0
    2023-11-12 19:18:46.238	info	Found Adapter Device: onvif.0.192_168_178_43_8080 IPCAM C6F0SgZ3N0P6L2 192.168.178.43:8080
    onvif.0
    2023-11-12 19:18:46.130	info	starting. Version 1.1.1 (non-npm: iobroker-community-adapters/ioBroker.onvif) in /opt/iobroker/node_modules/iobroker.onvif, node: v18.17.0, js-controller: 5.0.12
    host.iobroker
    2023-11-12 19:18:41.328	info	instance system.adapter.onvif.0 started with pid 175534
    host.iobroker
    2023-11-12 19:18:39.163	info	instance system.adapter.onvif.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    onvif.0
    2023-11-12 19:18:38.531	info	terminating
    host.iobroker
    2023-11-12 19:18:38.206	info	stopInstance system.adapter.onvif.0 send kill signal
    onvif.0
    2023-11-12 19:18:38.030	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    onvif.0
    2023-11-12 19:18:38.029	info	terminating
    onvif.0
    2023-11-12 19:18:38.027	info	Got terminate signal TERMINATE_YOURSELF
    host.iobroker
    2023-11-12 19:18:38.024	info	stopInstance system.adapter.onvif.0 (force=false, process=true)
    admin.0
    2023-11-12 19:18:10.395	warn	onvif has an invalid jsonConfig: [{"instancePath":"/items/_discover","schemaPath":"#/definitions/sendToProps/additionalProperties","keyword":"additionalProperties","params":{"additionalProperty":"showProcessing"},"message":"must NOT have additional properties"}]
    Danke schon mal für deine Mühe
    Knusterus
    tombox
    #216
    @knusterus bitte mal GitHub version testen aber ist nicht die Ursache für ein problem
      Knusterus
      #217
      @tombox
      Guten Morgen, das ist schon die GitHub Version 1.1.1 .
      • K Knusterus
        @tombox
        tombox
        #218
        @knusterus bitte erneut installieren Versionsnummer ändert sich nicht
        K 2 Antworten Letzte Antwort
        • R Offline
          Rookie50
          schrieb am zuletzt editiert von Rookie50
          #219
          ich habe länger RTSPtoWEB laufen gehabt. Es gab aber immer wieder das Problem, dass ein Stream nicht starten wollte. Ich habe den RTSPtoWEB Container auf einer Synology und einem Raspi4 getesten. Egal wo der Container lief, mal startete das WebRTC, mal nicht. Außerdem fand ich diese Multiview Seite nicht ganz gelungen. Ich bin selber aber kein Designer oder Programmierer ;-)
          Ich habe nun den Container go2rtc installiert (https://github.com/AlexxIT/go2rtc). Dieser stellt pro Kamera eine Streamingseite zur Verfügung. Was die Einbindung in VIS, sowie iQontrol, vereinfacht. Ausserdem stehen viele Codecs für alle möglichen Browser zur Verfügung:
          Any codec in source
          stream.html with auto-select mode / browsers: all / codecs: H264, H265*, MJPEG, JPEG, AAC, PCMU, PCMA, OPUS
          info.json page with active connections
          rtsp with only one video and one audio / codecs: any
          rtsp for MP4 recording (Hass or Frigate) / codecs: H264, H265, AAC
          rtsp with all tracks / codecs: any
          ffplay -fflags nobuffer -flags low_delay -rtsp_transport tcp "rtsp://192.168.101.243:8554/Eingang"
          H264/H265 source
          stream.html WebRTC stream / browsers: all / codecs: H264, PCMU, PCMA, OPUS / +H265 in Safari
          stream.html MSE stream / browsers: Chrome, Firefox, Safari Mac/iPad / codecs: H264, H265*, AAC, PCMA*, PCMU*, PCM* / +OPUS in Chrome and Firefox
          stream.mp4 legacy MP4 stream with AAC audio / browsers: Chrome, Firefox / codecs: H264, H265*, AAC
          stream.mp4 modern MP4 stream with common audio / browsers: Chrome, Firefox / codecs: H264, H265*, AAC, FLAC (PCMA, PCMU, PCM)
          stream.mp4 MP4 stream with any audio / browsers: Chrome / codecs: H264, H265*, AAC, OPUS, MP3, FLAC (PCMA, PCMU, PCM)
          frame.mp4 snapshot in MP4-format / browsers: all / codecs: H264, H265*
          stream.m3u8 legacy HLS/TS / browsers: Safari all, Chrome Android / codecs: H264
          stream.m3u8 legacy HLS/fMP4 / browsers: Safari all, Chrome Android / codecs: H264, H265*, AAC
          stream.m3u8 modern HLS/fMP4 / browsers: Safari all, Chrome Android / codecs: H264, H265*, AAC, FLAC (PCMA, PCMU, PCM)
          MJPEG source
          stream.html with MJPEG mode / browsers: all / codecs: MJPEG, JPEG
          stream.mjpeg MJPEG stream / browsers: all / codecs: MJPEG, JPEG
          frame.jpeg snapshot in JPEG-format / browsers: all / codecs: MJPEG, JPEG
          Play audio
          example: ffmpeg:https://example.com/song.mp3#audio=pcma#input=file
          send / cameras with two way audio support
          Publish stream
          YouTube:  rtmps://xxx.rtmp.youtube.com/live2/xxxx-xxxx-xxxx-xxxx-xxxx
          Telegram: rtmps://xxx-x.rtmp.t.me/s/xxxxxxxxxx:xxxxxxxxxxxxxxxxxxxxxx
          send / Telegram RTMPS server
          WebRTC Magic
          video+audio = simple viewer
          video+audio+microphone = two way audio from camera
          camera+microphone = stream from browser
          display+speaker = broadcast software
          webrtc.html local WebRTC viewer
          share link external WebRTC viewer
          Im VIS kann man das Basic HTML Widget nehmen und als Quelle die stream seite angeben : http://<IP-Adresse>:1984/stream.html?src=<KAMERANAME>&mode=webrtc
          Man braucht also kein Script mehr um die Kamera darzustellen.
          Robert
          I T 2 Antworten Letzte Antwort
          • T tombox
            Knusterus
            #220
            @tombox
            hallo ich habe jetzt die alte Version komplett gelöscht und die neue von Github installiert.
            jetzt sehen die Fehler so aus
            onvif.0
            2023-11-13 16:56:35.293	error	Cannot check object existence of "onvif.0.192_168_178_43_8080.infos.deviceProfiles.01.videoAnalyticsConfiguration.analyticsEngineConfiguration.analyticsModule01.parameters.elementItem.cellLayout.transformation.translate.$": Connection is closed.
            onvif.0
            2023-11-13 16:56:35.289	error	Error: DB closed
            onvif.0
            2023-11-13 16:56:35.288	error	Error: DB closed
            onvif.0
            2023-11-13 16:56:35.286	error	Error: DB closed
            onvif.0
            2023-11-13 16:56:35.285	error	Error: DB closed
            onvif.0
            2023-11-13 16:56:35.284	error	Error: DB closed
            onvif.0
            2023-11-13 16:56:35.283	error	Error extract keys: 192_168_178_43_8080.infos.presets {"Preset1":"Preset1","Preset2":"Preset2","Preset3":"Preset3","Preset4":"Preset4","Preset5":"Preset5","Preset6":"Preset6","Preset7":"Preset7","Preset8":"Preset8","Preset9":"Preset9","Preset10":"Preset10","Preset11":"Preset11","Preset12":"Preset12","Preset13":"Preset13","Preset14":"Preset14","Preset15":"Preset15","Preset16":"Preset16","Preset17":"Preset17","Preset18":"Preset18","Preset19":"Preset19","Preset20":"Preset20","Preset21":"Preset21","Preset22":"Preset22","Preset23":"Preset23","Preset24":"Preset24","Preset25":"Preset25","Preset26":"Preset26","Preset27":"Preset27","Preset28":"Preset28","Preset29":"Preset29","Preset30":"Preset30","Preset31":"Preset31","Preset32":"Preset32","Preset33":"Preset33","Preset34":"Preset34","Preset35":"Preset35","Preset36":"Preset36","Preset37":"Preset37","Preset38":"Preset38","Preset39":"Preset39","Preset40":"Preset40","Preset41":"Preset41","Preset42":"Preset42","Preset43":"Preset43","Preset44":"Preset44","Preset45":"Preset45","Preset46":"Preset46","Preset47":"Preset47","Preset48":"Preset48","Preset49":"Preset49","Preset50":"Preset50","Preset51":"Preset51","Preset52":"Preset52","Preset53":"Preset53","Preset54":"Preset54","Preset55":"Preset55","Preset56":"Preset56","Preset57":"Preset57","Preset58":"Preset58","Preset59":"Preset59","Preset60":"Preset60","Preset61":"Preset61","Preset62":"Preset62","Preset63":"Preset63","Preset64":"Preset64","Preset65":"Preset65","Preset66":"Preset66","Preset67":"Preset67","Preset68":"Preset68","Preset69":"Preset69","Preset70":"Preset70","Preset71":"Preset71","Preset72":"Preset72","Preset73":"Preset73","Preset74":"Preset74","Preset75":"Preset75","Preset76":"Preset76","Preset77":"Preset77","Preset78":"Preset78","Preset79":"Preset79","Preset80":"Preset80","Preset81":"Preset81","Preset82":"Preset82","Preset83":"Preset83","Preset84":"Preset84","Preset85":"Preset85","Preset86":"Preset86","Preset87":"Preset87","Preset88":"Preset88","Preset89":"Preset89","Preset90":"Preset90","Preset91":"Preset91","Preset92":"Preset92","Preset93":"Preset93","Preset94":"Preset94","Preset95":"Preset95","Preset96":"Preset96","Preset97":"Preset97","Preset98":"Preset98","Preset99":"Preset99","Preset100":"Preset100","Preset101":"Preset101","Preset102":"Preset102","Preset103":"Preset103","Preset104":"Preset104","Preset105":"Preset105","Preset106":"Preset106","Preset107":"Preset107","Preset108":"Preset108","Preset109":"Preset109","Preset110":"Preset110","Preset111":"Preset111","Preset112":"Preset112","Preset113":"Preset113","Preset114":"Preset114","Preset115":"Preset115","Preset116":"Preset116","Preset117":"Preset117","Preset118":"Preset118","Preset119":"Preset119","Preset120":"Preset120","Preset121":"Preset121","Preset122":"Preset122","Preset123":"Preset123","Preset124":"Preset124","Preset125":"Preset125","Preset126":"Preset126","Preset127":"Preset127","Preset128":"Preset128"}
            onvif.0
            2023-11-13 16:56:35.280	error	Error: DB closed
            onvif.0
            2023-11-13 16:56:35.278	error	Error extract keys: 192_168_178_30_8080.infos.presets {"Preset1":"Preset1","Preset2":"Preset2","Preset3":"Preset3","Preset4":"Preset4","Preset5":"Preset5","Preset6":"Preset6","Preset7":"Preset7","Preset8":"Preset8","Preset9":"Preset9","Preset10":"Preset10","Preset11":"Preset11","Preset12":"Preset12","Preset13":"Preset13","Preset14":"Preset14","Preset15":"Preset15","Preset16":"Preset16","Preset17":"Preset17","Preset18":"Preset18","Preset19":"Preset19","Preset20":"Preset20","Preset21":"Preset21","Preset22":"Preset22","Preset23":"Preset23","Preset24":"Preset24","Preset25":"Preset25","Preset26":"Preset26","Preset27":"Preset27","Preset28":"Preset28","Preset29":"Preset29","Preset30":"Preset30","Preset31":"Preset31","Preset32":"Preset32","Preset33":"Preset33","Preset34":"Preset34","Preset35":"Preset35","Preset36":"Preset36","Preset37":"Preset37","Preset38":"Preset38","Preset39":"Preset39","Preset40":"Preset40","Preset41":"Preset41","Preset42":"Preset42","Preset43":"Preset43","Preset44":"Preset44","Preset45":"Preset45","Preset46":"Preset46","Preset47":"Preset47","Preset48":"Preset48","Preset49":"Preset49","Preset50":"Preset50","Preset51":"Preset51","Preset52":"Preset52","Preset53":"Preset53","Preset54":"Preset54","Preset55":"Preset55","Preset56":"Preset56","Preset57":"Preset57","Preset58":"Preset58","Preset59":"Preset59","Preset60":"Preset60","Preset61":"Preset61","Preset62":"Preset62","Preset63":"Preset63","Preset64":"Preset64","Preset65":"Preset65","Preset66":"Preset66","Preset67":"Preset67","Preset68":"Preset68","Preset69":"Preset69","Preset70":"Preset70","Preset71":"Preset71","Preset72":"Preset72","Preset73":"Preset73","Preset74":"Preset74","Preset75":"Preset75","Preset76":"Preset76","Preset77":"Preset77","Preset78":"Preset78","Preset79":"Preset79","Preset80":"Preset80","Preset81":"Preset81","Preset82":"Preset82","Preset83":"Preset83","Preset84":"Preset84","Preset85":"Preset85","Preset86":"Preset86","Preset87":"Preset87","Preset88":"Preset88","Preset89":"Preset89","Preset90":"Preset90","Preset91":"Preset91","Preset92":"Preset92","Preset93":"Preset93","Preset94":"Preset94","Preset95":"Preset95","Preset96":"Preset96","Preset97":"Preset97","Preset98":"Preset98","Preset99":"Preset99","Preset100":"Preset100","Preset101":"Preset101","Preset102":"Preset102","Preset103":"Preset103","Preset104":"Preset104","Preset105":"Preset105","Preset106":"Preset106","Preset107":"Preset107","Preset108":"Preset108","Preset109":"Preset109","Preset110":"Preset110","Preset111":"Preset111","Preset112":"Preset112","Preset113":"Preset113","Preset114":"Preset114","Preset115":"Preset115","Preset116":"Preset116","Preset117":"Preset117","Preset118":"Preset118","Preset119":"Preset119","Preset120":"Preset120","Preset121":"Preset121","Preset122":"Preset122","Preset123":"Preset123","Preset124":"Preset124","Preset125":"Preset125","Preset126":"Preset126","Preset127":"Preset127","Preset128":"Preset128"}
            onvif.0
            2023-11-13 16:56:35.275	error	Error: DB closed
            onvif.0
            2023-11-13 16:56:35.274	error	Error: DB closed
            onvif.0
            2023-11-13 16:56:35.273	error	Error: DB closed
            onvif.0
            2023-11-13 16:56:35.271	error	Error: DB closed
            onvif.0
            2023-11-13 16:56:35.270	error	Error: DB closed
            onvif.0
            2023-11-13 16:56:35.264	error	Cannot check object existence of "onvif.0.192_168_178_67_8080.infos.deviceCapabilities.media.extension": Connection is closed.
            onvif.0
            2023-11-13 16:56:35.252	error	Error: Could not check object existence of onvif.0.192_168_178_43_8080.infos.deviceProfiles.01.videoAnalyticsConfiguration.analyticsEngineConfiguration.analyticsModule01.parameters.elementItem.cellLayout.transformation.translate: Cannot check object existence of "onvif.0.192_168_178_43_8080.infos.deviceProfiles.01.videoAnalyticsConfiguration.analyticsEngineConfiguration.analyticsModule01.parameters.elementItem.cellLayout.transformation.translate": DB closed
            onvif.0
            2023-11-13 16:56:35.250	error	Error: Could not check object existence of onvif.0.192_168_178_43_8080.infos.deviceServices.04.version: Cannot check object existence of "onvif.0.192_168_178_43_8080.infos.deviceServices.04.version": DB closed
            onvif.0
            2023-11-13 16:56:35.239	error	Error: DB closed
            onvif.0
            2023-11-13 16:56:35.237	error	Error extract keys: 192_168_178_67_8080.infos.presets {"Preset001":"Preset001","Preset002":"Preset002","Preset003":"Preset003","Preset004":"Preset004","Preset005":"Preset005","Preset006":"Preset006","Preset007":"Preset007","Preset008":"Preset008","Preset009":"Preset009","Preset010":"Preset010","Preset011":"Preset011","Preset012":"Preset012","Preset013":"Preset013","Preset014":"Preset014","Preset015":"Preset015","Preset016":"Preset016","Preset017":"Preset017","Preset018":"Preset018","Preset019":"Preset019","Preset020":"Preset020","Preset021":"Preset021","Preset022":"Preset022","Preset023":"Preset023","Preset024":"Preset024","Preset025":"Preset025","Preset026":"Preset026","Preset027":"Preset027","Preset028":"Preset028","Preset029":"Preset029","Preset030":"Preset030","Preset031":"Preset031","Preset032":"Preset032","Preset033":"Preset033","Preset034":"Preset034","Preset035":"Preset035","Preset036":"Preset036","Preset037":"Preset037","Preset038":"Preset038","Preset039":"Preset039","Preset040":"Preset040","Preset041":"Preset041","Preset042":"Preset042","Preset043":"Preset043","Preset044":"Preset044","Preset045":"Preset045","Preset046":"Preset046","Preset047":"Preset047","Preset048":"Preset048","Preset049":"Preset049","Preset050":"Preset050","Preset051":"Preset051","Preset052":"Preset052","Preset053":"Preset053","Preset054":"Preset054","Preset055":"Preset055","Preset056":"Preset056","Preset057":"Preset057","Preset058":"Preset058","Preset059":"Preset059","Preset060":"Preset060","Preset061":"Preset061","Preset062":"Preset062","Preset063":"Preset063","Preset064":"Preset064","Preset065":"Preset065","Preset066":"Preset066","Preset067":"Preset067","Preset068":"Preset068","Preset069":"Preset069","Preset070":"Preset070","Preset071":"Preset071","Preset072":"Preset072","Preset073":"Preset073","Preset074":"Preset074","Preset075":"Preset075","Preset076":"Preset076","Preset077":"Preset077","Preset078":"Preset078","Preset079":"Preset079","Preset080":"Preset080","Preset081":"Preset081","Preset082":"Preset082","Preset083":"Preset083","Preset084":"Preset084","Preset085":"Preset085","Preset086":"Preset086","Preset087":"Preset087","Preset088":"Preset088","Preset089":"Preset089","Preset090":"Preset090","Preset091":"Preset091","Preset092":"Preset092","Preset093":"Preset093","Preset094":"Preset094","Preset095":"Preset095","Preset096":"Preset096","Preset097":"Preset097","Preset098":"Preset098","Preset099":"Preset099","Preset100":"Preset100","Preset101":"Preset101","Preset102":"Preset102","Preset103":"Preset103","Preset104":"Preset104","Preset105":"Preset105","Preset106":"Preset106","Preset107":"Preset107","Preset108":"Preset108","Preset109":"Preset109","Preset110":"Preset110","Preset111":"Preset111","Preset112":"Preset112","Preset113":"Preset113","Preset114":"Preset114","Preset115":"Preset115","Preset116":"Preset116","Preset117":"Preset117","Preset118":"Preset118","Preset119":"Preset119","Preset120":"Preset120","Preset121":"Preset121","Preset122":"Preset122","Preset123":"Preset123","Preset124":"Preset124","Preset125":"Preset125","Preset126":"Preset126","Preset127":"Preset127","Preset128":"Preset128","Preset129":"Preset129","Preset130":"Preset130","Preset131":"Preset131","Preset132":"Preset132","Preset133":"Preset133","Preset134":"Preset134","Preset135":"Preset135","Preset136":"Preset136","Preset137":"Preset137","Preset138":"Preset138","Preset139":"Preset139","Preset140":"Preset140","Preset141":"Preset141","Preset142":"Preset142","Preset143":"Preset143","Preset144":"Preset144","Preset145":"Preset145","Preset146":"Preset146","Preset147":"Preset147","Preset148":"Preset148","Preset149":"Preset149","Preset150":"Preset150","Preset151":"Preset151","Preset152":"Preset152","Preset153":"Preset153","Preset154":"Preset154","Preset155":"Preset155","Preset156":"Preset156","Preset157":"Preset157","Preset158":"Preset158","Preset159":"Preset159","Preset160":"Preset160","Preset161":"Preset161","Preset162":"Preset162","Preset163":"Preset163","Preset164":"Preset164","Preset165":"Preset165","Preset166":"Preset166","Preset167":"Preset167","Preset168":"Preset168","Preset169":"Preset169","Preset170":"Preset170","Preset171":"Preset171","Preset172":"Preset172","Preset173":"Preset173","Preset174":"Preset174","Preset175":"Preset175","Preset176":"Preset176","Preset177":"Preset177","Preset178":"Preset178","Preset179":"Preset179","Preset180":"Preset180","Preset181":"Preset181","Preset182":"Preset182","Preset183":"Preset183","Preset184":"Preset184","Preset185":"Preset185","Preset186":"Preset186","Preset187":"Preset187","Preset188":"Preset188","Preset189":"Preset189","Preset190":"Preset190","Preset191":"Preset191","Preset192":"Preset192","Preset193":"Preset193","Preset194":"Preset194","Preset195":"Preset195","Preset196":"Preset196","Preset197":"Preset197","Preset198":"Preset198","Preset199":"Preset199","Preset200":"Preset200","Preset201":"Preset201","Preset202":"Preset202","Preset203":"Preset203","Preset204":"Preset204","Preset205":"Preset205","Preset206":"Preset206","Preset207":"Preset207","Preset208":"Preset208","Preset209":"Preset209","Preset210":"Preset210","Preset211":"Preset211","Preset212":"Preset212","Preset213":"Preset213","Preset214":"Preset214","Preset215":"Preset215","Preset216":"Preset216","Preset217":"Preset217","Preset218":"Preset218","Preset219":"Preset219","Preset220":"Preset220","Preset221":"Preset221","Preset222":"Preset222","Preset223":"Preset223","Preset224":"Preset224","Preset225":"Preset225","Preset226":"Preset226","Preset227":"Preset227","Preset228":"Preset228","Preset229":"Preset229","Preset230":"Preset230","Preset231":"Preset231","Preset232":"Preset232","Preset233":"Preset233","Preset234":"Preset234","Preset235":"Preset235","Preset236":"Preset236","Preset237":"Preset237","Preset238":"Preset238","Preset239":"Preset239","Preset240":"Preset240","Preset241":"Preset241","Preset242":"Preset242","Preset243":"Preset243","Preset244":"Preset244","Preset245":"Preset245","Preset246":"Preset246","Preset247":"Preset247","Preset248":"Preset248","Preset249":"Preset249","Preset250":"Preset250","Preset251":"Preset251","Preset252":"Preset252","Preset253":"Preset253","Preset254":"Preset254","Preset255":"Preset255","Preset256":"Preset256"}
            onvif.0
            2023-11-13 16:56:35.234	error	Error: DB closed
            onvif.0
            2023-11-13 16:56:35.232	error	Error extract keys: 192_168_178_67_8080.infos.deviceCapabilities.media.streamingCapabilities {"RTPMulticast":false,"RTP_TCP":false,"RTP_RTSP_TCP":false}
            onvif.0
            2023-11-13 16:56:35.223	error	Cannot check object existence of "onvif.0.192_168_178_43_8080.infos.deviceProfiles.01.videoAnalyticsConfiguration.analyticsEngineConfiguration.analyticsModule01.parameters.elementItem.cellLayout.transformation.translate": DB closed
            onvif.0
            2023-11-13 16:56:35.220	error	Cannot check object existence of "onvif.0.192_168_178_43_8080.infos.deviceServices.04.version": DB closed
            onvif.0
            2023-11-13 16:56:35.176	error	Error: DB closed
            onvif.0
            2023-11-13 16:56:35.173	error	Error extract keys: 192_168_178_43_8080.infos.deviceServices.04.capabilities.capabilities.$ {"VideoSources":1,"VideoOutputs":1,"AudioSources":1,"AudioOutputs":1,"RelayOutputs":2,"SerialPorts":1,"DigitalInputs":1}
            onvif.0
            2023-11-13 16:56:35.101	error	Error: DB closed
            onvif.0
            2023-11-13 16:56:35.098	error	Error extract keys: 192_168_178_43_8080.infos.deviceProfiles.01.videoAnalyticsConfiguration.analyticsEngineConfiguration.analyticsModule01.parameters.elementItem.cellLayout.$ {"Columns":22,"Rows":18}
            onvif.0
            2023-11-13 16:56:35.093	error	Error: DB closed
            onvif.0
            2023-11-13 16:56:35.088	error	Error extract keys: 192_168_178_30_8080.infos.deviceCapabilities.device.security {"TLS1.1":false,"TLS1.2":false,"onboardKeyGeneration":false,"accessPolicyConfig":false,"X.509Token":false,"SAMLToken":false,"kerberosToken":false,"RELToken":false}
            Die Kamera die es betrifft ist die 192.168.178.43. Wäre schön wenn die funktionieren würde.
            • R Rookie50
              Any codec in source
              H264/H265 source
              MJPEG source
              Play audio
              Publish stream
              WebRTC Magic
              Robert
              I Online
              I Online
              ioBrokerMike
              #221
              @rookie50 sagte in Test Adapter onvif camera v1.0.0:
              Container
              Moin rookie50
              • Muss man das unter einem Container laufen lassen ?
              • Kann ich das mit einem GEEKOM MiniAir 11 | Linux : bookworm parallel
                Laufen lassen ?
              • Wenn ich das richtig Verstanden 🙂 habe ich dann ein
                Livebild?
              • Kannst du mir eine Anleitung zur Hand geben mit der auch ich was
                Anfangen kann?
              Mfg
              IOBrokerMike
              Achtung ! Sehkraft 25% | 60% , kein scherz
              Systeme : GEEKOM MiniAir 11 | Linux : Trixie 13.6 | HMIP | OpenCCU / RasPi3 | SMA PV Anlage | Robonect Hx | RTL_433
              • R Rookie50
                Any codec in source
                H264/H265 source
                MJPEG source
                Play audio
                Publish stream
                WebRTC Magic
                Robert
                tombox
                #222
                @rookie50 Habs mal ausprobiert und fühlt sich gut an habe die Anleitung aktualisiert
                • R Offline
                  Rookie50
                  #223
                  @iobrokermike Hi IObrokerMike, ich habe es halt in einem Container installiert und nicht als Paket auf einem Host installiert. Daher kann ich nicht wirklich etwas zur Installation sagen. Aber schau doch mal hier: https://forum.iobroker.net/topic/66871/go2rtc-installieren-und-einrichten
                  Da wurde eine eine Installation schon diskutiert.
                  Und ja, damit kann man ein Live Bild und Live Video bekommen.
                  Robert
                  • T tombox
                    Knusterus
                    schrieb am zuletzt editiert von Knusterus
                    #224
                    @tombox
                    Hallo ich habe jetzt meine Iobroker Datensicherung vom vorletzten Wochenende ,
                    vor der onvif Installation, zurückgespielt. Dann habe ich Deine Version von Github installiert . Jetzt kommt beim ersten Start noch eine Fehlermeldung
                    admin.0
                    2023-11-14 19:18:43.713	warn	onvif has an invalid jsonConfig: [{"instancePath":"/items/_discover","schemaPath":"#/definitions/sendToProps/additionalProperties","keyword":"additionalProperties","params":{"additionalProperty":"showProcessing"},"message":"must NOT have additional properties"}]
                    Aber was viel wichtiger ist, es funktioniert. Ist die Meldung was schlimmes?
                    Eine Frage habe ich noch, wo kann die Daten des Bewegungsmelders auslesen.
                    Ist es möglich ,wenn die Kamera Bewegung , einen Bildwechsel im Vis auszulösen?
                    • K Knusterus
                      @tombox
                      admin.0
                      tombox
                      #225
                      @knusterus kann ignoriert werden.
                      unter events sollten alle vents sein
                      • T tombox
                        Knusterus
                        #226
                        @tombox
                        Adapter läuft prima,vielen Dank dafür.
                        Allerdings finde ich die Events nicht. Bei mir ist alles leer.
                        Wo genau wird die Medung vom Bewegungsmelder hinterlegt. Oder kann das meine Kamera nicht.
                        Sie hat aber eine Bewegungserkennung die auch funktioniert.
                        Knusterus
                        • K Knusterus
                          @tombox
                          Knusterus
                          tombox
                          #227
                          @knusterus du kannst mal den ONVIF Device Manager testen bzw den adapter im debug log modus laufen lassen
                          • T tombox
                            Knusterus
                            #228
                            @tombox
                            Den Adapter habe ich mal im debug log laufen lassen und eine Bewegung simuliert. sollte ich da im Debug was sehen.
                            Da ist nix passiert. Was kann ich mit dem Manager tun ,den kenne ich nicht?
                            • K Knusterus
                              @tombox
                              tombox
                              #229
                              @knusterus Ja irgendwas müsste da passieren.
                              der kann detailliert alle onvif Informationen darstellen wäre ein test ob er was kann
                              ansonsten googeln ob man für die camera bezüglich onvif noch was aktivieren muss
                              • T tombox
                                Knusterus
                                #230
                                @tombox
                                Also auch im Manager werden keine Events angezeigt. wahrscheinlich kann meine Kamera das noch nicht.
                                Hauptsache das Livebild ohne Passwort funktioniert, und das funktioniert super.
                                Vielen Dank
                                Knusterus
                                • K Knusterus
                                  @tombox
                                  Vielen Dank
                                  Knusterus
                                  tombox
                                  #231
                                  @knusterus Ja vielleicht mal Hersteller wegen onvif events anfragen
                                  • T tombox
                                    Knusterus
                                    #232
                                    @tombox
                                    Habe ich bereits getan, warte auf Antwort. Melde mich sobald ich eine Antwort habe.
                                    • K Knusterus
                                      @tombox
                                      micw42
                                      #233
                                      seit Version 1.1.1 startet der Adapter nicht mehr, Fehlermeldung ist folgende:
                                      TypeError: callback.call is not a function at Cam.<anonymous> (/opt/iobroker/node_modules/onvif/lib/events.js:309:14) at ClientRequest.<anonymous> (/opt/iobroker/node_modules/onvif/lib/cam.js:328:4) at ClientRequest.emit (node:events:525:35) at ClientRequest.emit (node:domain:489:12) at Socket.socketErrorListener (node:_http_client:494:9) at Socket.emit (node:events:513:28) at Socket.emit (node:domain:489:12) at emitErrorNT (node:internal/streams/destroy:157:8) at emitErrorCloseNT (node:internal/streams/destroy:122:3) at processTicksAndRejections (node:internal/process/task_queues:83:21)
                                      Jemand eine Idee?
                                      • M micw42
                                        Jemand eine Idee?
                                        #234
                                        @micw42 sagte in Test Adapter onvif camera v1.0.0:
                                        Jemand eine Idee?
                                        Das Umfeld schaut wie aus?
                                        iob diag
                                        anschauen.
                                        XBiTX 1 Antwort Letzte Antwort
                                          Jemand eine Idee?
                                          iob diag
                                          anschauen.
                                          XBiTX Online
                                          XBiTX Online
                                          XBiT
                                          #235
                                          @thomas-braun @micw42
                                          bei mir leider das gleiche..
                                          Log:
                                          host.IoBroker
                                          2023-11-20 13:32:55.269	info	Restart adapter system.adapter.onvif.0 because enabled
                                          host.IoBroker
                                          2023-11-20 13:32:55.269	error	instance system.adapter.onvif.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                          host.IoBroker
                                          2023-11-20 13:32:55.269	error	Caught by controller[0]: at processTicksAndRejections (node:internal/process/task_queues:82:21)
                                          host.IoBroker
                                          2023-11-20 13:32:55.269	error	Caught by controller[0]: at endReadableNT (node:internal/streams/readable:1368:12)
                                          host.IoBroker
                                          2023-11-20 13:32:55.269	error	Caught by controller[0]: at IncomingMessage.emit (node:domain:489:12)
                                          host.IoBroker
                                          2023-11-20 13:32:55.269	error	Caught by controller[0]: at IncomingMessage.emit (node:events:529:35)
                                          host.IoBroker
                                          2023-11-20 13:32:55.269	error	Caught by controller[0]: at IncomingMessage.<anonymous> (/opt/iobroker/node_modules/onvif/lib/cam.js:297:4)
                                          host.IoBroker
                                          2023-11-20 13:32:55.269	error	Caught by controller[0]: at parseSOAPString (/opt/iobroker/node_modules/onvif/lib/utils.js:108:3)
                                          host.IoBroker
                                          2023-11-20 13:32:55.269	error	Caught by controller[0]: at Cam.<anonymous> (/opt/iobroker/node_modules/onvif/lib/events.js:309:14)
                                          host.IoBroker
                                          2023-11-20 13:32:55.269	error	Caught by controller[0]: TypeError: callback.call is not a function
                                          onvif.0
                                          2023-11-20 13:32:55.037	error	callback.call is not a function
                                          onvif.0
                                          2023-11-20 13:32:55.036	error	TypeError: callback.call is not a function at Cam.<anonymous> (/opt/iobroker/node_modules/onvif/lib/events.js:309:14) at parseSOAPString (/opt/iobroker/node_modules/onvif/lib/utils.js:108:3) at IncomingMessage.<anonymous> (/opt/iobroker/node_modules/onvif/lib/cam.js:297:4) at IncomingMessage.emit (node:events:529:35) at IncomingMessage.emit (node:domain:489:12) at endReadableNT (node:internal/streams/readable:1368:12) at processTicksAndRejections (node:internal/process/task_queues:82:21)
                                          onvif.0
                                          2023-11-20 13:32:55.036	error	uncaught exception: callback.call is not a function
                                          onvif.0
                                          2023-11-20 13:32:43.482	info	Starting snapshot server
                                          onvif.0
                                          2023-11-20 13:32:43.481	info	Finished onvif discovery
                                          onvif.0
                                          2023-11-20 13:32:41.644	info	Data: undefined xml: undefined
                                          iob_diag:
                                          Skript v.2023-10-10
                                          *** BASE SYSTEM ***
                                             Static hostname: IoBroker
                                                   Icon name: computer-vm
                                                     Chassis: vm
                                              Virtualization: kvm
                                            Operating System: Debian GNU/Linux 10 (buster)
                                                      Kernel: Linux 4.19.0-24-amd64
                                                Architecture: x86-64
                                          model name      : Common KVM processor
                                          Docker          : false
                                          Virtualization  : kvm
                                          Kernel          : x86_64
                                          Userland        : amd64
                                          Systemuptime and Load:
                                           13:33:48 up 16 days, 18:50,  1 user,  load average: 0.50, 0.66, 0.67
                                          CPU threads: 8
                                          *** Time and Time Zones ***
                                                         Local time: Mon 2023-11-20 13:33:49 CET
                                                     Universal time: Mon 2023-11-20 12:33:49 UTC
                                                           RTC time: Mon 2023-11-20 12:33:50
                                                        NTP service: active
                                                    RTC in local TZ: no
                                          *** User and Groups ***
                                          stephan
                                          /home/stephan
                                          stephan cdrom floppy sudo audio dip video plugdev netdev
                                          *** X-Server-Setup ***
                                          X-Server:       false
                                          Desktop:
                                          Terminal:       tty
                                          *** MEMORY ***
                                          Mem:            16G        3.4G         10G         24M        2.1G         12G
                                          Swap:          6.1G          0B        6.1G
                                          Total:          22G        3.4G         16G
                                                  16042 M total memory
                                                   3423 M used memory
                                                   4064 M active memory
                                                    987 M inactive memory
                                                  10474 M free memory
                                                    482 M buffer memory
                                                   1662 M swap cache
                                                   6140 M total swap
                                                      0 M used swap
                                                   6140 M free swap
                                          *** FAILED SERVICES ***
                                          0 loaded units listed. Pass --all to see loaded but inactive units, too.
                                          To show all installed unit files use 'systemctl list-unit-files'.
                                          *** FILESYSTEM ***
                                          udev           devtmpfs  7.9G     0  7.9G   0% /dev
                                          tmpfs          tmpfs     1.6G   25M  1.6G   2% /run
                                          /dev/sda1      ext4       34G  7.8G   24G  25% /
                                          tmpfs          tmpfs     7.9G     0  7.9G   0% /dev/shm
                                          tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
                                          tmpfs          tmpfs     7.9G     0  7.9G   0% /sys/fs/cgroup
                                          tmpfs          tmpfs     1.6G     0  1.6G   0% /run/user/1000
                                          [Fri Nov  3 18:43:46 2023] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
                                          [Fri Nov  3 18:43:46 2023] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
                                          TARGET        SOURCE    FSTYPE OPTIONS
                                          /             /dev/sda1 ext4   rw,relatime,errors=remount-ro
                                          `-/sys/fs/bpf bpf       bpf    rw,nosuid,nodev,noexec,relatime,mode=700
                                          /var:
                                          565M    /var/
                                          392M    /var/cache
                                          385M    /var/cache/apt
                                          324M    /var/cache/apt/archives
                                          156M    /var/lib
                                                Users in the 'systemd-journal' group can see all messages. Pass -q to
                                                turn off this notice.
                                          No journal files were opened due to insufficient permissions.
                                          /opt/iobroker/backups:
                                          379M    /opt/iobroker/backups/
                                          /opt/iobroker/iobroker-data:
                                          747M    /opt/iobroker/iobroker-data/
                                          402M    /opt/iobroker/iobroker-data/files
                                          238M    /opt/iobroker/iobroker-data/backup-objects
                                          94M     /opt/iobroker/iobroker-data/files/vis-2-beta
                                          52M     /opt/iobroker/iobroker-data/files/javascript.admin
                                          43M     /opt/iobroker/iobroker-data/objects.jsonl
                                          21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
                                          21M     /opt/iobroker/iobroker-data/files/eventlist/static/js/main.605c1bc5.js.map
                                          21M     /opt/iobroker/iobroker-data/files/eventlist.admin/static/js/main.605c1bc5.js.map
                                          20M     /opt/iobroker/iobroker-data/objects.json.migrated
                                          USB-Devices by-id:
                                          find: '/dev/serial/by-id/': No such file or directory
                                          *** NodeJS-Installation ***
                                          /usr/bin/nodejs         v18.18.2
                                          /usr/bin/node           v18.18.2
                                          /usr/bin/npm            9.8.1
                                          /usr/bin/npx            9.8.1
                                          /usr/bin/corepack       0.19.0
                                          nodejs:
                                            Installed: 18.18.2-1nodesource1
                                            Candidate: 18.18.2-1nodesource1
                                            Version table:
                                           *** 18.18.2-1nodesource1 1001
                                                  500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
                                               18.18.1-1nodesource1 1001
                                               18.18.0-1nodesource1 1001
                                               18.17.1-1nodesource1 1001
                                               18.17.0-1nodesource1 1001
                                               18.16.1-1nodesource1 1001
                                               18.16.0-1nodesource1 1001
                                               18.15.0-1nodesource1 1001
                                               18.14.2-1nodesource1 1001
                                               18.14.1-1nodesource1 1001
                                               18.14.0-1nodesource1 1001
                                               18.13.0-1nodesource1 1001
                                               18.12.0-1nodesource1 1001
                                               18.11.0-1nodesource1 1001
                                               18.10.0-1nodesource1 1001
                                               18.9.1-1nodesource1 1001
                                               18.9.0-1nodesource1 1001
                                               18.8.0-1nodesource1 1001
                                               18.7.0-1nodesource1 1001
                                               18.6.0-1nodesource1 1001
                                               18.5.0-1nodesource1 1001
                                               18.4.0-1nodesource1 1001
                                               18.3.0-1nodesource1 1001
                                               18.2.0-1nodesource1 1001
                                               18.1.0-1nodesource1 1001
                                               18.0.0-1nodesource1 1001
                                               10.24.0~dfsg-1~deb10u3 500
                                                  500 http://security.debian.org/debian-security buster/updates/main amd64 Packages
                                               10.24.0~dfsg-1~deb10u1 500
                                                  500 http://deb.debian.org/debian buster/main amd64 Packages
                                          No problems detected
                                          Errors in npm tree:
                                          *** ioBroker-Installation ***
                                          ioBroker Status
                                          Objects type: jsonl
                                          States  type: jsonl
                                          Core adapters versions
                                          js-controller:  5.0.16
                                          admin:          6.12.0
                                          javascript:     7.1.4
                                          Adapters from github:   11
                                          Adapter State
                                          + system.adapter.admin.0                  : admin                 : IoBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                            system.adapter.alias-manager.0          : alias-manager         : IoBroker                                 - disabled
                                          + system.adapter.backitup.0               : backitup              : IoBroker                                 -  enabled
                                          + system.adapter.device-watcher.0         : device-watcher        : IoBroker                                 -  enabled
                                          + system.adapter.discovery.0              : discovery             : IoBroker                                 -  enabled
                                          + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: IoBroker                                 -  enabled
                                          + system.adapter.enigma2.0                : enigma2               : IoBroker                                 -  enabled
                                          + system.adapter.enigma2.1                : enigma2               : IoBroker                                 -  enabled
                                          + system.adapter.enigma2.2                : enigma2               : IoBroker                                 -  enabled
                                            system.adapter.feiertage.0              : feiertage             : IoBroker                                 -  enabled
                                            system.adapter.flot.0                   : flot                  : IoBroker                                 - disabled
                                          + system.adapter.followthesun.0           : followthesun          : IoBroker                                 -  enabled
                                          + system.adapter.fullybrowser.0           : fullybrowser          : IoBroker                                 -  enabled
                                          + system.adapter.google-sharedlocations.0 : google-sharedlocations: IoBroker                                 -  enabled
                                          + system.adapter.hm-rega.0                : hm-rega               : IoBroker                                 -  enabled
                                          + system.adapter.hm-rpc.0                 : hm-rpc                : IoBroker                                 -  enabled, port: 0
                                          + system.adapter.hm-rpc.1                 : hm-rpc                : IoBroker                                 -  enabled, port: 0
                                          + system.adapter.hm-rpc.2                 : hm-rpc                : IoBroker                                 -  enabled, port: 0
                                          + system.adapter.hm-rpc.3                 : hm-rpc                : IoBroker                                 -  enabled, port: 0
                                            system.adapter.ical.0                   : ical                  : IoBroker                                 -  enabled
                                            system.adapter.icons-mfd-png.0          : icons-mfd-png         : IoBroker                                 - disabled
                                          + system.adapter.info.0                   : info                  : IoBroker                                 -  enabled
                                          + system.adapter.javascript.0             : javascript            : IoBroker                                 -  enabled
                                          + system.adapter.logparser.0              : logparser             : IoBroker                                 -  enabled
                                          + system.adapter.lovelace.0               : lovelace              : IoBroker                                 -  enabled, port: 8091, bind: 192.168.1.251, run as: admin
                                          + system.adapter.meater.0                 : meater                : IoBroker                                 -  enabled
                                          + system.adapter.mercedesme.0             : mercedesme            : IoBroker                                 -  enabled
                                          + system.adapter.mihome-vacuum.0          : mihome-vacuum         : IoBroker                                 -  enabled, port: 54321
                                          + system.adapter.omada.0                  : omada                 : IoBroker                                 -  enabled, port: 8043
                                            system.adapter.onvif.0                  : onvif                 : IoBroker                                 - disabled, port: 80, 7575, 8000, 8080, 8081, 8899
                                          + system.adapter.ping.0                   : ping                  : IoBroker                                 -  enabled
                                          + system.adapter.proxmox.0                : proxmox               : IoBroker                                 -  enabled, port: 8006
                                            system.adapter.roborock.0               : roborock              : IoBroker                                 - disabled
                                          + system.adapter.sayit.0                  : sayit                 : IoBroker                                 -  enabled
                                          + system.adapter.shelly.1                 : shelly                : IoBroker                                 -  enabled, port: 2023, bind: 0.0.0.0
                                          + system.adapter.sia.0                    : sia                   : IoBroker                                 -  enabled, port: 50001, bind: 0.0.0.0
                                          + system.adapter.sonos.0                  : sonos                 : IoBroker                                 -  enabled
                                          + system.adapter.sony-bravia.0            : sony-bravia           : IoBroker                                 -  enabled
                                          + system.adapter.sourceanalytix.0         : sourceanalytix        : IoBroker                                 -  enabled
                                          + system.adapter.sql.0                    : sql                   : IoBroker                                 -  enabled, port: 3306
                                          + system.adapter.synochat.0               : synochat              : IoBroker                                 -  enabled
                                          + system.adapter.synology.0               : synology              : IoBroker                                 -  enabled, port: 5000
                                          + system.adapter.tankerkoenig.0           : tankerkoenig          : IoBroker                                 -  enabled
                                          + system.adapter.telegram.0               : telegram              : IoBroker                                 -  enabled, port: 8443, bind: 0.0.0.0
                                          + system.adapter.telegram.1               : telegram              : IoBroker                                 -  enabled, port: 8443, bind: 0.0.0.0
                                          + system.adapter.telegram.2               : telegram              : IoBroker                                 -  enabled, port: 8443, bind: 0.0.0.0
                                          + system.adapter.tr-064.0                 : tr-064                : IoBroker                                 -  enabled
                                          + system.adapter.trashschedule.0          : trashschedule         : IoBroker                                 -  enabled
                                          + system.adapter.upnp.0                   : upnp                  : IoBroker                                 -  enabled
                                          + system.adapter.viessmannapi.0           : viessmannapi          : IoBroker                                 -  enabled
                                            system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : IoBroker                                 - disabled
                                          + system.adapter.vis-inventwo.0           : vis-inventwo          : IoBroker                                 -  enabled
                                            system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : IoBroker                                 - disabled
                                            system.adapter.vis-metro.0              : vis-metro             : IoBroker                                 - disabled
                                            system.adapter.vis-players.0            : vis-players           : IoBroker                                 - disabled
                                            system.adapter.vis-plumb.0              : vis-plumb             : IoBroker                                 - disabled
                                            system.adapter.vis-timeandweather.0     : vis-timeandweather    : IoBroker                                 - disabled
                                            system.adapter.vis.0                    : vis                   : IoBroker                                 -  enabled
                                          + system.adapter.web.0                    : web                   : IoBroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                          + instance is alive
                                          ioBroker-Repositories
                                          Active repo(s): stable
                                          Installed ioBroker-Instances
                                          Used repository: stable
                                          Adapter    "admin"        : 6.12.0   , installed 6.12.0
                                          Adapter    "alias-manager": 1.2.6    , installed 1.2.6
                                          Adapter    "backitup"     : 2.8.7    , installed 2.8.7
                                          Adapter    "coronavirus-statistics": 0.8.7, installed 0.8.7
                                          Adapter    "device-watcher": 2.9.4   , installed 2.9.4
                                          Adapter    "discovery"    : 4.2.0    , installed 4.2.0
                                          Adapter    "enigma2"      : 2.0.5    , installed 2.0.5
                                          Adapter    "eventlist"    : 2.0.0    , installed 2.0.0
                                          Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
                                          Adapter    "followthesun" : 0.4.2    , installed 0.4.2
                                          Adapter    "fullybrowser" : 3.0.6    , installed 3.0.6
                                          Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
                                          Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
                                          Adapter    "ical"         : 1.13.3   , installed 1.13.3
                                          Adapter    "info"         : 2.0.0    , installed 2.0.0
                                          Adapter    "javascript"   : 7.1.4    , installed 7.1.4
                                          Controller "js-controller": 5.0.16   , installed 5.0.16
                                          Adapter    "logparser"    : 2.2.0    , installed 2.2.0
                                          Adapter    "lovelace"     : 3.0.1    , installed 3.0.1
                                          Adapter    "meater"       : 1.0.2    , installed 1.0.2
                                          Adapter    "mercedesme"   : 0.1.1    , installed 0.1.1
                                          Adapter    "mihome-vacuum": 4.1.0    , installed 4.1.0
                                          Adapter    "onvif"        : 1.1.1    , installed 1.1.1
                                          Adapter    "proxmox"      : 2.2.1    , installed 2.2.1
                                          Adapter    "roborock"     : 0.4.4    , installed 0.4.4
                                          Adapter    "sayit"        : 3.0.5    , installed 3.0.5
                                          Adapter    "shelly"       : 6.6.1    , installed 6.6.1
                                          Adapter    "sia"          : 1.0.4    , installed 1.0.4
                                          Adapter    "socketio"     : 6.5.5    , installed 6.5.5
                                          Adapter    "sonos"        : 3.0.0    , installed 3.0.0
                                          Adapter    "sony-bravia"  : 1.0.9    , installed 1.0.9
                                          Adapter    "synochat"     : 1.3.1    , installed 1.3.1
                                          Adapter    "synology"     : 3.0.1    , installed 3.0.1
                                          Adapter    "telegram"     : 2.0.1    , installed 2.0.1
                                          Adapter    "trashschedule": 2.3.0    , installed 2.3.0
                                          Adapter    "upnp"         : 1.0.21   , installed 1.0.21
                                          Adapter    "viessmannapi" : 2.3.0    , installed 2.3.0
                                          Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
                                          Adapter    "web"          : 6.1.10   , installed 6.1.10
                                          Adapter    "ws"           : 2.5.8    , installed 2.5.8
                                          Objects and States
                                          Objects:        30217
                                          States:         24890
                                          Hit:1 http://deb.debian.org/debian buster InRelease
                                          Hit:2 http://deb.debian.org/debian buster-updates InRelease
                                          Hit:3 http://security.debian.org/debian-security buster/updates InRelease
                                          Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
                                          Reading package lists...
                                          Pending Updates: 0
                                          *** Listening Ports ***
                                          tcp        0      0 192.168.1.251:42010     0.0.0.0:*               LISTEN      1001       42089991   4473/io.hm-rpc.1
                                          tcp        0      0 192.168.1.251:8091      0.0.0.0:*               LISTEN      1001       42092665   5196/io.lovelace.0
                                          tcp        0      0 192.168.1.251:8701      0.0.0.0:*               LISTEN      1001       42088993   4503/io.hm-rpc.3
                                          tcp        0      0 0.0.0.0:2023            0.0.0.0:*               LISTEN      1001       42089126   4632/io.shelly.1
                                          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       42088726   4305/iobroker.js-co
                                          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       42090513   4305/iobroker.js-co
                                          tcp        0      0 192.168.1.251:49292     0.0.0.0:*               LISTEN      1001       42090005   4488/io.hm-rpc.2
                                          tcp        0      0 0.0.0.0:5005            0.0.0.0:*               LISTEN      0          5652559    12204/node
                                          tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          12300      1/init
                                          tcp        0      0 0.0.0.0:50001           0.0.0.0:*               LISTEN      1001       42093859   5245/io.sia.0
                                          tcp        0      0 192.168.1.251:42001     0.0.0.0:*               LISTEN      1001       42088247   4458/io.hm-rpc.0
                                          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14888      400/sshd
                                          tcp6       0      0 :::8000                 :::*                    LISTEN      1001       42096728   5308/io.upnp.0
                                          tcp6       0      0 :::3500                 :::*                    LISTEN      0          5652562    12204/node
                                          tcp6       0      0 :::3501                 :::*                    LISTEN      1001       42088329   4566/io.sonos.0
                                          tcp6       0      0 :::111                  :::*                    LISTEN      0          2523       1/init
                                          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       42088772   4326/io.admin.0
                                          tcp6       0      0 :::8082                 :::*                    LISTEN      1001       42092359   5372/io.web.0
                                          tcp6       0      0 :::22                   :::*                    LISTEN      0          14890      400/sshd
                                          tcp6       0      0 :::3000                 :::*                    LISTEN      1001       42095759   5533/io.fullybrowse
                                          udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       42090843   4533/io.mihome-vacu
                                          udp        0      0 192.168.1.251:5353      0.0.0.0:*                           1001       42090232   4616/io.tr-064.0
                                          udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          12301      1/init
                                          udp        0      0 0.0.0.0:50001           0.0.0.0:*                           1001       42093860   5245/io.sia.0
                                          udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       42092344   5308/io.upnp.0
                                          udp        0      0 0.0.0.0:42883           0.0.0.0:*                           1001       42094828   5308/io.upnp.0
                                          udp6       0      0 :::111                  :::*                                0          2526       1/init
                                          2023-11-20 13:33:20.553  - info: host.IoBroker "system.adapter.onvif.0" disabled
                                          2023-11-20 13:33:26.814  - error: onvif.0 (5601) adapter disabled
                                          2023-11-20 13:33:26.826  - warn: javascript.0 (4353) getState "system.adapter.onvif.0.cpu" not found (3)
                                          2023-11-20 13:33:26.827  - warn: javascript.0 (4353)     at tabelle_generieren (script.js.common.0_userdata_0_.Home.Status.Adapter.adapterstatus:56:20)
                                          2023-11-20 13:33:26.827  - warn: javascript.0 (4353)     at Object.<anonymous> (script.js.common.0_userdata_0_.Home.Status.Adapter.adapterstatus:92:3)
                                          2023-11-20 13:33:26.827  - warn: javascript.0 (4353) getState "system.adapter.onvif.0.memHeapUsed" not found (3)
                                          2023-11-20 13:33:26.827  - warn: javascript.0 (4353)     at tabelle_generieren (script.js.common.0_userdata_0_.Home.Status.Adapter.adapterstatus:61:20)
                                          2023-11-20 13:33:26.861  - warn: onvif.0 (5601) Terminated (NO_ADAPTER_CONFIG_FOUND): Without reason
                                          2023-11-20 13:33:27.457  - error: host.IoBroker instance system.adapter.onvif.0 terminated with code 3 (NO_ADAPTER_CONFIG_FOUND)
                                          2023-11-20 13:33:27.458  - info: host.IoBroker Do not restart adapter system.adapter.onvif.0 because disabled or deleted
                                          2023-11-20 13:33:34.843  - info: mihome-vacuum.0 (4533) create states for mop
                                          2023-11-20 13:33:34.846  - info: mihome-vacuum.0 (4533) change states from State control.fan_power
                                          2023-11-20 13:33:34.846  - info: mihome-vacuum.0 (4533) create states for water box
                                          2023-11-20 13:33:34.850  - info: mihome-vacuum.0 (4533) create states for water box mode
                                          2023-11-20 13:33:34.922  - info: mihome-vacuum.0 (4533) change states from State control.fan_power mihome-vacuum.0.rooms.218001011242.roomFanPower
                                          2023-11-20 13:33:34.922  - info: mihome-vacuum.0 (4533) change states from State control.fan_power mihome-vacuum.0.rooms.218001011304.roomFanPower
                                          2023-11-20 13:33:34.923  - info: mihome-vacuum.0 (4533) change states from State control.fan_power mihome-vacuum.0.rooms.218001011305.roomFanPower
                                          2023-11-20 13:33:34.923  - info: mihome-vacuum.0 (4533) change states from State control.fan_power mihome-vacuum.0.rooms.room1.roomFanPower
                                          2023-11-20 13:33:34.923  - info: mihome-vacuum.0 (4533) change states from State control.fan_power mihome-vacuum.0.rooms.room16.roomFanPower
                                          2023-11-20 13:33:34.924  - info: mihome-vacuum.0 (4533) change states from State control.fan_power mihome-vacuum.0.rooms.room17.roomFanPower
                                          2023-11-20 13:33:34.924  - info: mihome-vacuum.0 (4533) change states from State control.fan_power mihome-vacuum.0.rooms.room18.roomFanPower
                                          2023-11-20 13:33:34.924  - info: mihome-vacuum.0 (4533) change states from State control.fan_power mihome-vacuum.0.rooms.room19.roomFanPower
                                          2023-11-20 13:33:34.924  - info: mihome-vacuum.0 (4533) change states from State control.fan_power mihome-vacuum.0.rooms.room2.roomFanPower
                                          2023-11-20 13:33:34.924  - info: mihome-vacuum.0 (4533) change states from State control.fan_power mihome-vacuum.0.rooms.room20.roomFanPower
