  4. Kein Zugriff au Iobroker
    2.9k
    4.9k
    4.1k
iobroker zugriff oberfläche
74 Beiträge 10 Kommentatoren 11.0k Aufrufe 7 Beobachtet
  • joergfrdeJ joergfrde
    Copy text starting here:
                            v.2023-10-10
       Static hostname: raspberrypi
             Icon name: computer
      Operating System: Raspbian GNU/Linux 10 (buster)
                Kernel: Linux 5.10.103-v7l+
          Architecture: arm
    Kernel:                 armv7l
    Userland:               armhf
    Timezone:               Europe/Berlin (CET, +0100)
    User-ID:                1000
    X-Server:               false
    Pending OS-Updates:     112
    Pending iob updates:    10
    Nodejs-Installation:    /usr/bin/nodejs         v18.16.0
                            /usr/bin/node           v18.16.0
                            /usr/bin/npm            9.5.1
                            /usr/bin/npx            9.5.1
                            /usr/bin/corepack       0.17.0
    Recommended versions are nodejs  Connection is closed.
     Unable to subscribe to evicted Keyspace events from Redis Server: Connection is closed.
     Unable to subscribe to meta namespace "meta." changes: Connection is closed. and npm  Cannot determine Set feature status: Connection is closed.
    MEMORY:
    Mem:           3.8G        2.1G        629M        8.0M        1.1G        1.5G
    Swap:           99M          0B         99M
    Total:         3.9G        2.1G        729M
    Active iob-Instances:   47
    Active repo(s): stable
    ioBroker Core:          js-controller           5.0.12
                            admin                   6.12.0
    Objects type: jsonl
    States  type: jsonl
    Objects:                1
    States:                 3
    Size of iob-Database:
    47M     /opt/iobroker/iobroker-data/objects.jsonl
    19M     /opt/iobroker/iobroker-data/objects.json.migrated
    19M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
    44K     /opt/iobroker/iobroker-data/objects.json.old
    28M     /opt/iobroker/iobroker-data/states.jsonl
    4.5M    /opt/iobroker/iobroker-data/states.json.migrated
    4.5M    /opt/iobroker/iobroker-data/states.json.bak.migrated
    3.6M    /opt/iobroker/iobroker-data/states.json.broken
    2.2M    /opt/iobroker/iobroker-data/states.json.old
    === Mark text until here for copying ===
    pi@raspberrypi:/opt/iobroker $ Copy text starting here:
    -bash: Copy: Kommando nicht gefunden.
    > ======================= SUMMARY =======================
    >                         v.2023-10-10
    >          Icon name: computer
    >       Architecture: arm
    > Kernel:                 armv7l
    > Userland:               armhf
    > User-ID:                1000
    > X-Server:               false
    > Boot Target:            graphical.target
    >                         /usr/bin/npm            9.5.1
    >                         /usr/bin/npx            9.5.1
    > Your nodejs installation is correct
    > MEMORY:
    >               total        used        free      shared  buff/cache   available
    > Swap:           99M          0B         99M
    >                         admin                   6.12.0
    > ioBroker Status:        iobroker is running on this host.
    > Objects type: jsonl
    > States  type: jsonl
    > Status admin and web instance:
    > + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    > Objects:                1
    > States:                 3
    > =================== END OF SUMMARY ====================
    -bash: =======================: Kommando nicht gefunden.
    -bash: v.2023-10-10: Kommando nicht gefunden.
    -bash: Static: Kommando nicht gefunden.
    -bash: Icon: Kommando nicht gefunden.
    -bash: command substitution: Zeile 8: Syntaxfehler beim unerwarteten Wort (' -bash: command substitution: Zeile 8: Operating System: Raspbian GNU/Linux 10 (buster)'
    @joergfrde
    buster ist tot, muss ersetzt werden.
    nodejs ist irgendwie schräg installiert und auch veraltet.
    Passt auch ins Bild.
    Für 4GB sportlich...
    joergfrdeJ 1 Antwort Letzte Antwort
      @glasfaser OK, über Putti komm ich wieder rein, aber web nicht.
      GlasfaserG Offline
      GlasfaserG Offline
      @joergfrde sagte in Kein Zugriff au Iobroker:
      aber web nicht.
      Was heißt web , bei dir .
      Laut dem Schnipsel ( SUMMARY ) .. läuft erstmal alles
      • GlasfaserG Glasfaser
        aber web nicht.
        joergfrdeJ Offline
        joergfrdeJ Offline
        joergfrde
        @glasfaser über Webbrowser
          @joergfrde
          joergfrdeJ Offline
          joergfrdeJ Offline
          joergfrde
          @thomas-braun was heißt buster ist tot
          Thomas BraunT GlasfaserG 2 Antworten Letzte Antwort
            GlasfaserG Offline
            GlasfaserG Offline
            @joergfrde
            Zeige bitte die Full Ausgabe ... kein SUMMARY !
              @joergfrde
              Tot heißt:
                GlasfaserG Offline
                GlasfaserG Offline
                ENDE ... kein Support mehr .
                https://www.debian.org/releases/buster/index.de.html
                  @joergfrde
                  joergfrdeJ Offline
                  joergfrdeJ Offline
                  joergfrde
                  @glasfaser
                  Skript v.2023-10-10
                  *** BASE SYSTEM ***
                           Icon name: computer
                        Architecture: arm
                  Model           : Raspberry Pi 4 Model B Rev 1.1
                  Docker          : false
                  Virtualization  : none
                  Kernel          : armv7l
                  Userland        : armhf
                  Systemuptime and Load:
                   20:53:15 up 26 min,  1 user,  load average: 0.92, 1.02, 1.41
                  CPU threads: 4
                  *** RASPBERRY THROTTLING ***
                  Current issues:
                  Previously detected issues:
                  *** Time and Time Zones ***
                                 Local time: Fri 2023-11-10 20:53:15 CET
                             Universal time: Fri 2023-11-10 19:53:15 UTC
                                   RTC time: n/a
                                NTP service: active
                            RTC in local TZ: no
                  *** User and Groups ***
                  pi
                  /home/pi
                  pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
                  *** X-Server-Setup ***
                  X-Server:       false
                  Desktop:
                  Terminal:       tty
                  *** MEMORY ***
                  Mem:           3.8G        2.0G        708M        8.0M        1.1G        1.6G
                  Swap:           99M          0B         99M
                  Total:         3.9G        2.0G        808M
                           3837 M total memory
                           2032 M used memory
                            568 M active memory
                           2375 M inactive memory
                            708 M free memory
                            184 M buffer memory
                            912 M swap cache
                             99 M total swap
                              0 M used swap
                             99 M free swap
                  Raspberry only:
                  oom events: 0
                  *** FAILED SERVICES ***
                    UNIT                LOAD   ACTIVE SUB    DESCRIPTION
                  * deconz-init.service loaded failed failed deCONZ: ZigBee gateway -- Initialisation
                  * proftpd.service     loaded failed failed LSB: Starts ProFTPD daemon
                  2 loaded units listed. Pass --all to see loaded but inactive units, too.
                  To show all installed unit files use 'systemctl list-unit-files'.
                  *** FILESYSTEM ***
                  /dev/root      ext4      220G   17G  195G   8% /
                  devtmpfs       devtmpfs  1.8G     0  1.8G   0% /dev
                  tmpfs          tmpfs     1.9G  8.8M  1.9G   1% /run
                  tmpfs          tmpfs     1.9G     0  1.9G   0% /sys/fs/cgroup
                  /dev/sda1      vfat      253M   49M  204M  20% /boot
                  tmpfs          tmpfs     384M     0  384M   0% /run/user/1000
                  [Fri Nov 10 20:27:07 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:22:43:EA vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=tty1 root=PARTUUID=6c586e13-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
                  [Fri Nov 10 20:27:09 2023] EXT4-fs (sda2): INFO: recovery required on readonly filesystem
                  [Fri Nov 10 20:27:09 2023] EXT4-fs (sda2): write access will be enabled during recovery
                  [Fri Nov 10 20:27:09 2023] EXT4-fs (sda2): orphan cleanup on readonly fs
                  [Fri Nov 10 20:27:09 2023] EXT4-fs (sda2): 50 orphan inodes deleted
                  [Fri Nov 10 20:27:09 2023] EXT4-fs (sda2): recovery complete
                  [Fri Nov 10 20:27:09 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
                  [Fri Nov 10 20:27:09 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
                  [Fri Nov 10 20:27:12 2023] EXT4-fs (sda2): re-mounted. Opts: (null)
                  TARGET        SOURCE    FSTYPE OPTIONS
                  /             /dev/sda2 ext4   rw,noatime
                  |-/sys/fs/bpf none      bpf    rw,nosuid,nodev,noexec,relatime,mode=700
                  `-/boot       /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                  /var:
                  1.3G    /var/
                  1.1G    /var/cache/apt
                  1.1G    /var/cache
                  990M    /var/cache/apt/archives
                  104M    /var/lib
                  Archived and active journals take up 8.0M in the file system.
                  /opt/iobroker/backups:
                  293M    /opt/iobroker/backups/
                  208K    /opt/iobroker/backups/scripte
                  112K    /opt/iobroker/backups/scripte/common
                  88K     /opt/iobroker/backups/scripte/Eigener_Ordner
                  /opt/iobroker/iobroker-data:
                  3.8G    /opt/iobroker/iobroker-data/
                  2.8G    /opt/iobroker/iobroker-data/history
                  524M    /opt/iobroker/iobroker-data/files
                  283M    /opt/iobroker/iobroker-data/backup-objects
                  78M     /opt/iobroker/iobroker-data/files/icons-open-icon-library-png
                  50M     /opt/iobroker/iobroker-data/objects.jsonl
                  35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
                  31M     /opt/iobroker/iobroker-data/states.jsonl
                  21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js.map
                  USB-Devices by-id:
                  /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2149438-if00
                  *** NodeJS-Installation ***
                  /usr/bin/npm            9.5.1
                  /usr/bin/npx            9.5.1
                  nodejs:
                    Installed: 18.16.0-deb-1nodesource1
                    Candidate: 18.17.1-deb-1nodesource1
                    Version table:
                       18.17.1-deb-1nodesource1 500
                          500 https://deb.nodesource.com/node_18.x buster/main armhf Packages
                   *** 18.16.0-deb-1nodesource1 100
                       10.24.0~dfsg-1~deb10u3 500
                  No problems detected
                  Errors in npm tree:
                  *** ioBroker-Installation ***
                  ioBroker Status
                  Objects type: jsonl
                  States  type: jsonl
                  Core adapters versions
                  js-controller:  5.0.12
                  admin:          6.12.0
                  javascript:     7.1.4
                  Adapters from github:   1
                  Adapter State
                    system.adapter.alarm.0                  : alarm                 : raspberrypi                              - disabled
                  + system.adapter.calendar.0               : calendar              : raspberrypi                              -  enabled, port: 8095
                  + system.adapter.calendar.1               : calendar              : raspberrypi                              -  enabled, port: 8095
                  + system.adapter.cameras.0                : cameras               : raspberrypi                              -  enabled, port: 8085, bind: 0.0.0.0
                  + system.adapter.cloud.0                  : cloud                 : raspberrypi                              -  enabled
                  + system.adapter.deconz.0                 : deconz                : raspberrypi                              -  enabled, port: 80
                    system.adapter.devices.0                : devices               : raspberrypi                              -  enabled
                    system.adapter.egigeozone.0             : egigeozone            : raspberrypi                              -  enabled, port: 7654
                  + system.adapter.email.0                  : email                 : raspberrypi                              -  enabled
                  + system.adapter.exchangerates.0          : exchangerates         : raspberrypi                              -  enabled
                    system.adapter.fb-checkpresence.0       : fb-checkpresence      : raspberrypi                              - disabled
                    system.adapter.feiertage.0              : feiertage             : raspberrypi                              -  enabled
                  + system.adapter.fritzbox.0               : fritzbox              : raspberrypi                              -  enabled
                  + system.adapter.fritzdect.0              : fritzdect             : raspberrypi                              -  enabled
                  + system.adapter.fullcalendar.0           : fullcalendar          : raspberrypi                              -  enabled
                  + system.adapter.geofency.0               : geofency              : raspberrypi                              -  enabled, port: 7999, bind: 0.0.0.0
                    system.adapter.heatingcontrol.0         : heatingcontrol        : raspberrypi                              - disabled
                  + system.adapter.history.0                : history               : raspberrypi                              -  enabled
                  + system.adapter.hm-rega.0                : hm-rega               : raspberrypi                              -  enabled
                  + system.adapter.hm-rpc.0                 : hm-rpc                : raspberrypi                              -  enabled, port: 8081
                  + system.adapter.hm-rpc.1                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
                  + system.adapter.hm-rpc.2                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
                  + system.adapter.hm-rpc.3                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
                  + system.adapter.hm-rpc.4                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
                  + system.adapter.homeconnect.0            : homeconnect           : raspberrypi                              -  enabled
                  + system.adapter.homee.0                  : homee                 : raspberrypi                              -  enabled
                    system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
                    system.adapter.ical.1                   : ical                  : raspberrypi                              -  enabled
                    system.adapter.ical.2                   : ical                  : raspberrypi                              -  enabled
                    system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: raspberrypi                              -  enabled
                    system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : raspberrypi                              -  enabled
                    system.adapter.icons-icons8.0           : icons-icons8          : raspberrypi                              -  enabled
                    system.adapter.icons-material-png.0     : icons-material-png    : raspberrypi                              -  enabled
                    system.adapter.icons-material-svg.0     : icons-material-svg    : raspberrypi                              -  enabled
                    system.adapter.icons-mfd-png.0          : icons-mfd-png         : raspberrypi                              -  enabled
                    system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: raspberrypi                              -  enabled
                    system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : raspberrypi                              -  enabled
                  + system.adapter.landroid.0               : landroid              : raspberrypi                              -  enabled
                  + system.adapter.lifx.0                   : lifx                  : raspberrypi                              -  enabled
                  + system.adapter.meross.0                 : meross                : raspberrypi                              -  enabled
                    system.adapter.node-red.0               : node-red              : raspberrypi                              - disabled, port: 1880, bind: 0.0.0.0
                  + system.adapter.onvif.0                  : onvif                 : raspberrypi                              -  enabled
                    system.adapter.openweathermap.0         : openweathermap        : raspberrypi                              -  enabled
                  + system.adapter.parcel.0                 : parcel                : raspberrypi                              -  enabled
                  + system.adapter.paw.0                    : paw                   : raspberrypi                              -  enabled, port: 8898
                    system.adapter.ring.0                   : ring                  : raspberrypi                              -  enabled
                  + system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              -  enabled
                  + system.adapter.sayit.0                  : sayit                 : raspberrypi                              -  enabled
                    system.adapter.schoolfree.0             : schoolfree            : raspberrypi                              -  enabled
                    system.adapter.schoolfree.1             : schoolfree            : raspberrypi                              -  enabled
                  + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
                  + system.adapter.shuttercontrol.0         : shuttercontrol        : raspberrypi                              -  enabled
                  + system.adapter.smartcontrol.0           : smartcontrol          : raspberrypi                              -  enabled
                  + system.adapter.tankerkoenig.0           : tankerkoenig          : raspberrypi                              -  enabled
                  + system.adapter.text2command.0           : text2command          : raspberrypi                              -  enabled
                  + system.adapter.toyota.0                 : toyota                : raspberrypi                              -  enabled
                  + system.adapter.tr-064.0                 : tr-064                : raspberrypi                              -  enabled
                  + system.adapter.trashschedule.2          : trashschedule         : raspberrypi                              -  enabled
                  + system.adapter.trashschedule.3          : trashschedule         : raspberrypi                              -  enabled
                    system.adapter.tvspielfilm.0            : tvspielfilm           : raspberrypi                              -  enabled
                    system.adapter.vis-bars.0               : vis-bars              : raspberrypi                              -  enabled
                    system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : raspberrypi                              -  enabled
                    system.adapter.vis-colorpicker.0        : vis-colorpicker       : raspberrypi                              -  enabled
                    system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : raspberrypi                              -  enabled
                    system.adapter.vis-google-fonts.0       : vis-google-fonts      : raspberrypi                              -  enabled
                    system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              -  enabled
                    system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              -  enabled
                    system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspberrypi                              -  enabled
                    system.adapter.vis-justgage.0           : vis-justgage          : raspberrypi                              -  enabled
                    system.adapter.vis-lcars.0              : vis-lcars             : raspberrypi                              -  enabled
                    system.adapter.vis-map.0                : vis-map               : raspberrypi                              -  enabled
                    system.adapter.vis-material-webfont.0   : vis-material-webfont  : raspberrypi                              -  enabled
                    system.adapter.vis-material.0           : vis-material          : raspberrypi                              -  enabled
                    system.adapter.vis-metro.0              : vis-metro             : raspberrypi                              -  enabled
                    system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              -  enabled
                    system.adapter.vis-weather.0            : vis-weather           : raspberrypi                              -  enabled
                    system.adapter.weatherunderground.0     : weatherunderground    : raspberrypi                              -  enabled
                  + system.adapter.worx.0                   : worx                  : raspberrypi                              -  enabled
                    system.adapter.yr.0                     : yr                    : raspberrypi                              -  enabled
                  + instance is alive
                  ioBroker-Repositories
                  Installed ioBroker-Instances
                  Used repository: stable
                  Adapter    "admin"        : 6.12.0   , installed 6.12.0
                  Adapter    "alarm"        : 3.4.0    , installed 3.4.0
                  Adapter    "alexa2"       : 3.25.2   , installed 3.25.2
                  Adapter    "backitup"     : 2.8.7    , installed 2.8.1  [Updatable]
                  Adapter    "cloud"        : 4.4.1    , installed 4.4.1
                  Adapter    "deconz"       : 1.3.21   , installed 2.0.5
                  Adapter    "denon"        : 1.15.4   , installed 1.15.4
                  Adapter    "devices"      : 1.1.5    , installed 1.1.5
                  Adapter    "egigeozone"   : 0.1.2    , installed 0.1.2
                  Adapter    "email"        : 1.2.0    , installed 1.2.0
                  Adapter    "exchangerates": 0.0.14   , installed 0.0.14
                  Adapter    "fb-checkpresence": 1.2.2 , installed 1.2.2
                  Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
                  Adapter    "fritzbox"     : 0.5.0    , installed 0.5.0
                  Adapter    "fritzdect"    : 2.3.1    , installed 2.3.1
                  Adapter    "fullcalendar" : 2.2.6    , installed 1.2.0  [Updatable]
                  Adapter    "geofency"     : 1.2.4    , installed 1.2.4
                  Adapter    "heatingcontrol": 2.11.1  , installed 2.11.1
                  Adapter    "hm-rega"      : 4.0.0    , installed 3.0.47 [Updatable]
                  Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
                  Adapter    "homeconnect"  : 1.1.1    , installed 1.1.1
                  Adapter    "homee"        : 1.2.0    , installed 1.2.0
                  Adapter    "ical"         : 1.13.3   , installed 1.13.3
                  Adapter    "icons-fatcow-hosting": 0.1.0, installed 0.1.0
                  Adapter    "info"         : 2.0.0    , installed 2.0.0
                  Adapter    "javascript"   : 7.1.4    , installed 7.1.4
                  Controller "js-controller": 5.0.12   , installed 5.0.12
                  Adapter    "landroid"     : 1.0.3    , installed 1.0.3
                  Adapter    "lifx"         : 1.0.3    , installed 1.0.3
                  Adapter    "meross"       : 1.15.1   , installed 1.15.1
                  Adapter    "node-red"     : 4.0.3    , installed 4.0.3
                  Adapter    "onvif"        : 1.0.5    , installed 1.0.5
                  Adapter    "openweathermap": 0.4.5   , installed 0.3.9  [Updatable]
                  Adapter    "parcel"       : 0.0.27   , installed 0.0.27
                  Adapter    "paw"          : 0.3.2    , installed 0.3.2
                  Adapter    "ring"         : 3.2.2    , installed 3.2.2
                  Adapter    "sayit"        : 3.0.5    , installed 3.0.5
                  Adapter    "schoolfree"   : 1.1.2    , installed 1.1.2
                  Adapter    "shelly"       : 6.6.1    , installed 6.4.5  [Updatable]
                  Adapter    "shuttercontrol": 1.6.2   , installed 1.6.2
                  Adapter    "smartcontrol" : 2.0.1    , installed 2.0.1
                  Adapter    "socketio"     : 6.5.5    , installed 6.5.5
                  Adapter    "telegram"     : 2.0.1    , installed 1.16.0 [Updatable]
                  Adapter    "text2command" : 3.0.2    , installed 3.0.2
                  Adapter    "toyota"       : 0.0.3    , installed 0.0.3
                  Adapter    "trashschedule": 2.3.0    , installed 2.2.0  [Updatable]
                  Adapter    "tvspielfilm"  : 2.0.5    , installed 2.0.5
                  Adapter    "vis-lcars"    : 1.1.1    , installed 1.1.1
                  Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
                  Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
                  Adapter    "weatherunderground": 3.6.0, installed 3.6.0
                  Adapter    "web"          : 6.1.10   , installed 6.1.2  [Updatable]
                  Adapter    "worx"         : 2.3.4    , installed 2.3.2  [Updatable]
                  Adapter    "ws"           : 2.5.8    , installed 2.5.5  [Updatable]
                  Adapter    "yr"           : 5.3.0    , installed 5.3.0
                  Objects and States
                  Objects:        74009
                  States:         60139
                  Hit:1 http://archive.raspberrypi.org/debian buster InRelease
                  Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
                  Hit:3 https://phoscon.de/apt/deconz buster InRelease
                  Hit:4 https://deb.nodesource.com/node_18.x buster InRelease
                  Reading package lists...
                  Pending Updates: 112
                  *** Listening Ports ***
                  tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      1000       17915      463/deCONZ
                  tcp        0      0 192.168.178.27:2001     0.0.0.0:*               LISTEN      1001       58919      6359/io.hm-rpc.4
                  tcp        0      0 192.168.178.27:8083     0.0.0.0:*               LISTEN      1001       54935      5990/io.hm-rpc.0
                  tcp        0      0 0.0.0.0:8085            0.0.0.0:*               LISTEN      1001       60653      8227/io.cameras.0
                  tcp        0      0 0.0.0.0:53              0.0.0.0:*               LISTEN      0          17313      798/dnsmasq
                  tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          20583      792/sshd
                  tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1000       24250      387/node-red
                  tcp        0      0 192.168.178.27:2010     0.0.0.0:*               LISTEN      1001       54939      6268/io.hm-rpc.1
                  tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      0          16257      776/mosquitto
                  tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      1000       16146      463/deCONZ
                  tcp        0      0 192.168.178.27:8701     0.0.0.0:*               LISTEN      1001       59620      6289/io.hm-rpc.2
                  tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       19965      775/iobroker.js-con
                  tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       19935      775/iobroker.js-con
                  tcp        0      0 192.168.178.27:9292     0.0.0.0:*               LISTEN      1001       59625      6311/io.hm-rpc.3
                  tcp6       0      0 :::8081                 :::*                    LISTEN      1001       49568      2563/io.admin.0
                  tcp6       0      0 :::8082                 :::*                    LISTEN      1001       58313      3905/io.web.0
                  tcp6       0      0 :::53                   :::*                    LISTEN      0          17315      798/dnsmasq
                  tcp6       0      0 :::22                   :::*                    LISTEN      0          20585      792/sshd
                  tcp6       0      0 :::1883                 :::*                    LISTEN      0          16258      776/mosquitto
                  tcp6       0      0 :::7999                 :::*                    LISTEN      1001       49602      3337/io.geofency.0
                  udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       59873      4059/io.shelly.0
                  udp        0      0 0.0.0.0:53              0.0.0.0:*                           0          17312      798/dnsmasq
                  udp        0      0 0.0.0.0:52801           0.0.0.0:*                           108        18675      467/avahi-daemon: r
                  udp        0      0 0.0.0.0:67              0.0.0.0:*                           0          17309      798/dnsmasq
                  udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          17006      773/dhcpcd
                  udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          19051      610/dhclient
                  udp        0      0 0.0.0.0:43084           0.0.0.0:*                           1001       54063      6995/io.lifx.0
                  udp        0      0 192.168.178.27:5353     0.0.0.0:*                           1001       58441      5099/io.tr-064.0
                  udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        18673      467/avahi-daemon: r
                  udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       64536      8123/io.deconz.0
                  udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       18165      463/deCONZ
                  udp6       0      0 :::53160                :::*                                108        18676      467/avahi-daemon: r
                  udp6       0      0 :::546                  :::*                                0          19714      773/dhcpcd
                  udp6       0      0 :::53                   :::*                                0          17314      798/dnsmasq
                  udp6       0      0 :::5353                 :::*                                108        18674      467/avahi-daemon: r
                  udp6       0      0 :::1900                 :::*                                1001       64539      8123/io.deconz.0
                  udp6       0      0 :::1900                 :::*                                1001       64538      8123/io.deconz.0
                  udp6       0      0 :::1900                 :::*                                1001       64537      8123/io.deconz.0
                  2023-11-10 20:54:24.446  - info: tr-064.0 (5099) forEachConfiguredDevice: in GetSpecificHostEntry 6(Lenovo-Tablet/48:88:CA:DF:E3:9F) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                  2023-11-10 20:54:24.669  - info: tr-064.0 (5099) forEachConfiguredDevice: in GetSpecificHostEntry 8(Meross-Smart-Plug/48:E1:E9:04:34:24) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                  2023-11-10 20:54:26.334  - info: tr-064.0 (5099) forEachConfiguredDevice: in GetSpecificHostEntry 20(joerg/98:09:CF:8C:90:48) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                  2023-11-10 20:54:26.684  - info: tr-064.0 (5099) forEachConfiguredDevice: in GetSpecificHostEntry 23(ccu3-webui/B8:27:EB:00:A4:4A) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                  2023-11-10 20:54:26.703  - warn: shelly.0 (4059) [authEnabled] 192.168.178.57 (shelly1 / shelly1-A4CF12F41BAF / SHSW-1#A4CF12F41BAF#1): This device is not protected via restricted login (see adapter documentation for details)
                  2023-11-10 20:54:38.824  - info: tr-064.0 (5099) forEachConfiguredDevice: in GetSpecificHostEntry 6(Lenovo-Tablet/48:88:CA:DF:E3:9F) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                  2023-11-10 20:54:39.048  - info: tr-064.0 (5099) forEachConfiguredDevice: in GetSpecificHostEntry 8(Meross-Smart-Plug/48:E1:E9:04:34:24) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                  2023-11-10 20:54:40.762  - info: tr-064.0 (5099) forEachConfiguredDevice: in GetSpecificHostEntry 20(joerg/98:09:CF:8C:90:48) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                  2023-11-10 20:54:41.176  - warn: shelly.0 (4059) [authEnabled] 192.168.178.57 (shelly1 / shelly1-A4CF12F41BAF / SHSW-1#A4CF12F41BAF#1): This device is not protected via restricted login (see adapter documentation for details)
                  2023-11-10 20:54:41.227  - info: tr-064.0 (5099) forEachConfiguredDevice: in GetSpecificHostEntry 23(ccu3-webui/B8:27:EB:00:A4:4A) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                  2023-11-10 20:54:42.216  - warn: deconz.0 (8123) Object of state "deconz.0.info.connection" is missing the required property "common.type"
                  2023-11-10 20:54:46.503  - warn: shelly.0 (4059) [authEnabled] 192.168.178.86 (shelly1 / shelly1-A4CF12F41DED / SHSW-1#A4CF12F41DED#1): This device is not protected via restricted login (see adapter documentation for details)
                  2023-11-10 20:54:53.013  - warn: shelly.0 (4059) [authEnabled] 192.168.178.57 (shelly1 / shelly1-A4CF12F41BAF / SHSW-1#A4CF12F41BAF#1): This device is not protected via restricted login (see adapter documentation for details)
                  2023-11-10 20:54:53.556  - info: tr-064.0 (5099) forEachConfiguredDevice: in GetSpecificHostEntry 6(Lenovo-Tablet/48:88:CA:DF:E3:9F) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                  2023-11-10 20:54:53.774  - info: tr-064.0 (5099) forEachConfiguredDevice: in GetSpecificHostEntry 8(Meross-Smart-Plug/48:E1:E9:04:34:24) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                  2023-11-10 20:54:55.198  - info: tr-064.0 (5099) forEachConfiguredDevice: in GetSpecificHostEntry 20(joerg/98:09:CF:8C:90:48) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                  2023-11-10 20:54:55.583  - info: tr-064.0 (5099) forEachConfiguredDevice: in GetSpecificHostEntry 23(ccu3-webui/B8:27:EB:00:A4:4A) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                  2023-11-10 20:55:01.666  - info: host.raspberrypi instance system.adapter.tvspielfilm.0 started with pid 21418
                  2023-11-10 20:55:07.737  - info: tr-064.0 (5099) forEachConfiguredDevice: in GetSpecificHostEntry 6(Lenovo-Tablet/48:88:CA:DF:E3:9F) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                  2023-11-10 20:55:07.979  - info: tr-064.0 (5099) forEachConfiguredDevice: in GetSpecificHostEntry 8(Meross-Smart-Plug/48:E1:E9:04:34:24) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                  2023-11-10 20:55:09.154  - info: tvspielfilm.0 (21418) starting. Version 2.0.5 in /opt/iobroker/node_modules/iobroker.tvspielfilm, node: v18.16.0, js-controller: 5.0.12
                  2023-11-10 20:55:09.498  - info: tr-064.0 (5099) forEachConfiguredDevice: in GetSpecificHostEntry 20(joerg/98:09:CF:8C:90:48) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                  2023-11-10 20:55:09.965  - info: tr-064.0 (5099) forEachConfiguredDevice: in GetSpecificHostEntry 23(ccu3-webui/B8:27:EB:00:A4:4A) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                  2023-11-10 20:55:11.060  - warn: shelly.0 (4059) [authEnabled] 192.168.178.57 (shelly1 / shelly1-A4CF12F41BAF / SHSW-1#A4CF12F41BAF#1): This device is not protected via restricted login (see adapter documentation for details)
                  2023-11-10 20:55:11.275  - info: tvspielfilm.0 (21418) objects written
                  iob diag has finished.
                  Thomas BraunT GlasfaserG 3 Antworten Letzte Antwort
                    @glasfaser
                    Skript v.2023-10-10
                    *** BASE SYSTEM ***
                             Icon name: computer
                          Architecture: arm
                    Docker          : false
                    Kernel          : armv7l
                    Userland        : armhf
                    CPU threads: 4
                    Current issues:
                                     RTC time: n/a
                                  NTP service: active
                              RTC in local TZ: no
                    pi
                    /home/pi
                    X-Server:       false
                    Desktop:
                    Terminal:       tty
                    *** MEMORY ***
                    Swap:           99M          0B         99M
                             3837 M total memory
                             2032 M used memory
                              568 M active memory
                              708 M free memory
                              184 M buffer memory
                              912 M swap cache
                               99 M total swap
                                0 M used swap
                               99 M free swap
                    Raspberry only:
                    oom events: 0
                    *** FILESYSTEM ***
                    /var:
                    1.3G    /var/
                    1.1G    /var/cache/apt
                    1.1G    /var/cache
                    104M    /var/lib
                    USB-Devices by-id:
                    /usr/bin/npm            9.5.1
                    /usr/bin/npx            9.5.1
                    nodejs:
                      Version table:
                    Errors in npm tree:
                    ioBroker Status
                    Objects type: jsonl
                    States  type: jsonl
                    admin:          6.12.0
                    javascript:     7.1.4
                    Adapter State
                    + instance is alive
                    Objects and States
                    Objects:        74009
                    States:         60139
                    Das Ding ist Matsch. Installier da von Null an das aktuelle Release von RaspberryOS in der 64bit Lite Variante.
                      @glasfaser
                      Skript v.2023-10-10
                      *** BASE SYSTEM ***
                               Icon name: computer
                            Architecture: arm
                      Docker          : false
                      Kernel          : armv7l
                      Userland        : armhf
                      CPU threads: 4
                      Current issues:
                                       RTC time: n/a
                                    NTP service: active
                                RTC in local TZ: no
                      pi
                      /home/pi
                      X-Server:       false
                      Desktop:
                      Terminal:       tty
                      *** MEMORY ***
                      Swap:           99M          0B         99M
                               3837 M total memory
                               2032 M used memory
                                568 M active memory
                                708 M free memory
                                184 M buffer memory
                                912 M swap cache
                                 99 M total swap
                                  0 M used swap
                                 99 M free swap
                      Raspberry only:
                      oom events: 0
                      *** FILESYSTEM ***
                      /var:
                      1.3G    /var/
                      1.1G    /var/cache/apt
                      1.1G    /var/cache
                      104M    /var/lib
                      USB-Devices by-id:
                      /usr/bin/npm            9.5.1
                      /usr/bin/npx            9.5.1
                      nodejs:
                        Version table:
                      Errors in npm tree:
                      ioBroker Status
                      Objects type: jsonl
                      States  type: jsonl
                      admin:          6.12.0
                      javascript:     7.1.4
                      Adapter State
                      + instance is alive
                      Objects and States
                      Objects:        74009
                      States:         60139
                      GlasfaserG Offline
                      GlasfaserG Offline
                      Objects: 74009
                      States: 60139
                      und das ist Sportlich ... das hab ich noch nicht mal !
                        joergfrdeJ Offline
                        joergfrdeJ Offline
                        joergfrde
                        #66
                        @thomas-braun Kann ich die Daten vom iob sicherm und wieder verwenden?
                          #67
                          Du hast doch laufend Backups via Backitup-Adapter gemacht. Nimm eines der funktionierenden von dort.
                            GlasfaserG Offline
                            GlasfaserG Offline
                            #68
                            mhh .. deine aktuellen Backups !
                              joergfrdeJ Offline
                              joergfrdeJ Offline
                              joergfrde
                              #69
                              @thomas-braun Wenn ich RasberryOS erneuere, bleiben die iob-Daten erhalten?
                                #70
                                Nein. Nur in einem Backup.
                                  @glasfaser
                                  Skript v.2023-10-10
                                  *** BASE SYSTEM ***
                                           Icon name: computer
                                        Architecture: arm
                                  Docker          : false
                                  Kernel          : armv7l
                                  Userland        : armhf
                                  CPU threads: 4
                                  Current issues:
                                                   RTC time: n/a
                                                NTP service: active
                                            RTC in local TZ: no
                                  pi
                                  /home/pi
                                  X-Server:       false
                                  Desktop:
                                  Terminal:       tty
                                  *** MEMORY ***
                                  Swap:           99M          0B         99M
                                           3837 M total memory
                                           2032 M used memory
                                            568 M active memory
                                            708 M free memory
                                            184 M buffer memory
                                            912 M swap cache
                                             99 M total swap
                                              0 M used swap
                                             99 M free swap
                                  Raspberry only:
                                  oom events: 0
                                  *** FILESYSTEM ***
                                  /var:
                                  1.3G    /var/
                                  1.1G    /var/cache/apt
                                  1.1G    /var/cache
                                  104M    /var/lib
                                  USB-Devices by-id:
                                  /usr/bin/npm            9.5.1
                                  /usr/bin/npx            9.5.1
                                  nodejs:
                                    Version table:
                                  Errors in npm tree:
                                  ioBroker Status
                                  Objects type: jsonl
                                  States  type: jsonl
                                  admin:          6.12.0
                                  javascript:     7.1.4
                                  Adapter State
                                  + instance is alive
                                  Objects and States
                                  Objects:        74009
                                  States:         60139
                                  GlasfaserG Offline
                                  GlasfaserG Offline
                                  #71
                                  ... und auch dieses ist von der Größe sportlich !
                                  meine Vermutung , der Ring Adapter müllt alles voll
                                    joergfrdeJ Offline
                                    joergfrdeJ Offline
                                    joergfrde
                                    #72
                                    @thomas-braun Wenn ich RasberryOS erneuert habe, muß ich sicherlich den iob neu installieren und dann das Backup einspielen. Ist das richtig?
                                      #73
                                      Ist das richtig?
                                      Ja, das ist das Standard-Vorgehen.
                                        Ist das richtig?
                                        joergfrdeJ Offline
                                        joergfrdeJ Offline
                                        joergfrde
                                        #74
                                        @thomas-braun OK, danke. Werde ich dann machen, aber nicht mehr heute. Melde ich dann wieder bei Erfolg oder Probleme. Danke erstmal.
