  4. HILFE, kein Zugriff auf IOBroker
    2.9k
    5.0k
138 Beiträge 11 Kommentatoren 18.7k Aufrufe 8 Beobachtet
  • tiobbT tiobb
    *** BASE SYSTEM ***
       Static hostname: raspberrypi
             Icon name: computer
      Operating System: Raspbian GNU/Linux 10 (buster)
                Kernel: Linux 5.10.52-v7l+
          Architecture: arm
    Model		: Raspberry Pi 4 Model B Rev 1.4
    Docker          : false
    Virtualization  : none
    Kernel          : armv7l
    Userland        : armhf
    Systemuptime and Load:
     18:00:21 up  4:19,  1 user,  load average: 0.25, 0.08, 0.02
    CPU threads: 4
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    This system needs to be REBOOTED!
    *** Time and Time Zones ***
                   Local time: Thu 2023-11-02 18:00:21 CET
               Universal time: Thu 2023-11-02 17:00:21 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin gpio i2c spi iobroker
    *** X-Server-Setup ***
    /home/iobroker/.diag.sh: line 200: [[: 4036
    8227: syntax error in expression (error token is "8227")
    X-Server: 	false
    Desktop: 	LXDE-pi
    Terminal: 	x11
    Boot Target: 	graphical.target
    *** MEMORY ***
    Mem:           7.9G        282M        3.8G         74M        3.9G        7.3G
    Swap:           99M        2.0M         97M
    Total:         8.0G        285M        3.9G
             7898 M total memory
              282 M used memory
              534 M active memory
             3357 M inactive memory
             3760 M free memory
              275 M buffer memory
             3579 M swap cache
               99 M total swap
                2 M used swap
               97 M free swap
    Raspberry only:
    oom events: 0
    *** FAILED SERVICES ***
      UNIT             LOAD   ACTIVE SUB    DESCRIPTION
    * iobroker.service loaded failed failed ioBroker Server
    * lightdm.service  loaded failed failed Light Display Manager
    2 loaded units listed. Pass --all to see loaded but inactive units, too.
    To show all installed unit files use 'systemctl list-unit-files'.
    *** FILESYSTEM ***
    /dev/root      ext4       29G   14G   15G  49% /
    devtmpfs       devtmpfs  3.7G     0  3.7G   0% /dev
    tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
    tmpfs          tmpfs     3.9G   49M  3.9G   2% /run
    tmpfs          tmpfs     3.9G     0  3.9G   0% /sys/fs/cgroup
    /dev/mmcblk0p1 vfat      253M   49M  204M  20% /boot
    tmpfs          tmpfs     790M  4.0K  790M   1% /run/user/1000
    [Thu Nov  2 13:41:15 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=E4:5F:01:35:E0:6E vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=5168531a-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
    [Thu Nov  2 13:41:16 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
    [Thu Nov  2 13:41:16 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
    [Thu Nov  2 13:41:18 2023] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
    TARGET                       SOURCE         FSTYPE            OPTIONS
    /                            /dev/mmcblk0p2 ext4              rw,noatime
    |-/sys/fs/bpf                none           bpf               rw,nosuid,nodev,noexec,relatime,mode=700
    |-/run/user/1000/gvfs        gvfsd-fuse     fuse.gvfsd-fuse   rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
    |-/boot                      /dev/mmcblk0p1 vfat              rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    `-/home/pi/thinclient_drives xrdp-chansrv   fuse.xrdp-chansrv rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
    /var:
    2.8G	/var/
    2.0G	/var/cache/apt/archives
    2.0G	/var/cache/apt
    2.0G	/var/cache
    526M	/var/log
    Archived and active journals take up 48.0M in the file system.
    /opt/iobroker/backups:
    54M	/opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    505M	/opt/iobroker/iobroker-data/
    337M	/opt/iobroker/iobroker-data/history
    146M	/opt/iobroker/iobroker-data/files
    29M	/opt/iobroker/iobroker-data/files/javascript.admin
    24M	/opt/iobroker/iobroker-data/files/vis
    11M	/opt/iobroker/iobroker-data/files/echarts/static/js/2.d8ebf8a2.chunk.js.map
    11M	/opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/2.d8ebf8a2.chunk.js.map
    9.5M	/opt/iobroker/iobroker-data/files/javascript.admin/static/js/2.0ffea560.chunk.js.map
    7.0M	/opt/iobroker/iobroker-data/files/echarts.admin/static/js/2.9483ccfd.chunk.js.map
    4.4M	/opt/iobroker/iobroker-data/files/iot.admin/static/js/2.934fa7ad.chunk.js.map
    USB-Devices by-id:
    /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B001CDD4A3A-if00
    *** NodeJS-Installation ***
    /usr/bin/nodejs 	v18.18.2
    /usr/bin/node 		v18.18.2
    /usr/bin/npm 		9.8.1
    /usr/bin/npx 		9.8.1
    /usr/bin/corepack 	0.19.0
    nodejs:
      Installed: 18.18.2-1nodesource1
      Candidate: 18.18.2-1nodesource1
      Version table:
     *** 18.18.2-1nodesource1 1001
            500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
         18.18.1-1nodesource1 1001
         18.18.0-1nodesource1 1001
         18.17.1-1nodesource1 1001
         18.17.0-1nodesource1 1001
         18.16.1-1nodesource1 1001
         18.16.0-1nodesource1 1001
         18.15.0-1nodesource1 1001
         18.14.2-1nodesource1 1001
         18.14.1-1nodesource1 1001
         18.14.0-1nodesource1 1001
         18.13.0-1nodesource1 1001
         18.12.0-1nodesource1 1001
         18.11.0-1nodesource1 1001
         18.10.0-1nodesource1 1001
         18.9.1-1nodesource1 1001
         18.9.0-1nodesource1 1001
         18.8.0-1nodesource1 1001
         18.7.0-1nodesource1 1001
         18.6.0-1nodesource1 1001
         18.5.0-1nodesource1 1001
         18.4.0-1nodesource1 1001
         18.3.0-1nodesource1 1001
         18.2.0-1nodesource1 1001
         18.1.0-1nodesource1 1001
         18.0.0-1nodesource1 1001
         10.24.0~dfsg-1~deb10u3 500
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
     Cannot read system.config: null (OK when migrating or restoring)
     Cannot find view "system" for search "host"
    iobroker is not running on this host.
    Objects type: file
    States  type: file
    Core adapters versions
    js-controller: 	3.3.15
    admin: 		5.1.23
    javascript: 	5.2.8
    Adapters from github: 	1
    Adapter State
    + instance is alive
    ioBroker-Repositories
    Cannot get list: undefined
    Installed ioBroker-Instances
    Error: Object "system.config" not found
    scheint alles beim alten zu sein
    @tiobb
    Und du eimerst da immer noch mit einem Desktop durch die Gegend. AUSSCHALTEN!!!!
    sudo systemctl set-default multi-user.target
      @tiobb sagte in HILFE, kein Zugriff auf IOBroker:
      tiobbT Offline
      tiobbT Offline
      tiobb
      schrieb am zuletzt editiert von tiobb
      Das ging automatisch, starte es aber gerade manuell neu mit sudo reboot.
      @thomas-braun sagte in HILFE, kein Zugriff auf IOBroker:
      @tiobb
      Keine Ahnung wie ich dann da weiter "arbeiten" soll
      Raspberry Pi 4 8gb
      • tiobbT tiobb
        @tiobb
        Mit einem Terminal? Du agierst doch eh nur auf der Konsole oder dem WebGUI vom ioBroker. Macht man mit der PowerShell, puTTY oder einem der sonstigen Terminals.
        tiobbT 1 Antwort Letzte Antwort
          tiobbT Offline
          tiobbT Offline
          tiobb
          puTTY habe ich sogar installiert
          hier die iob diag nach manuellem neustart
          ** BASE SYSTEM ***
                   Icon name: computer
                      Kernel: Linux 5.10.103-v7l+
                Architecture: arm
          Docker          : false
          Kernel          : armv7l
          Userland        : armhf
           18:11:30 up 3 min,  1 user,  load average: 0.64, 0.59, 0.27
          CPU threads: 4
          Current issues:
                         Local time: Thu 2023-11-02 18:11:30 CET
                     Universal time: Thu 2023-11-02 17:11:30 UTC
                           RTC time: n/a
                        NTP service: active
                    RTC in local TZ: no
          pi
          /home/pi
          X-Server: 	true
          Desktop: 	LXDE-pi
          Terminal: 	x11
          *** MEMORY ***
          Mem:           7.9G        183M        7.4G         16M        284M        7.5G
          Swap:           99M          0B         99M
          Total:         8.0G        183M        7.5G
                   7898 M total memory
                    183 M used memory
                    147 M active memory
                    260 M inactive memory
                   7430 M free memory
                     39 M buffer memory
                    245 M swap cache
                     99 M total swap
                      0 M used swap
                     99 M free swap
          Raspberry only:
          oom events: 0
          1 loaded units listed. Pass --all to see loaded but inactive units, too.
          *** FILESYSTEM ***
          tmpfs          tmpfs     3.9G  8.6M  3.9G   1% /run
          [Thu Nov  2 18:07:43 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=E4:5F:01:35:E0:6E vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=5168531a-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
          [Thu Nov  2 18:07:44 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
          [Thu Nov  2 18:07:44 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
          [Thu Nov  2 18:07:46 2023] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
          /var:
          2.8G	/var/
          2.0G	/var/cache/apt
          2.0G	/var/cache
          527M	/var/log
          Archived and active journals take up 8.0M in the file system.
          504M	/opt/iobroker/iobroker-data/
          USB-Devices by-id:
          /usr/bin/npm 		9.8.1
          /usr/bin/npx 		9.8.1
          nodejs:
            Version table:
          Errors in npm tree:
          ioBroker Status
          Objects type: file
          States  type: file
          admin: 		5.1.23
          javascript: 	5.2.8
          Adapter State
           Objects database error: connect ECONNREFUSED 127.0.0.1:9001
          + instance is alive
          Raspberry Pi 4 8gb
          • tiobbT tiobb
            ** BASE SYSTEM ***
                     Icon name: computer
                  Architecture: arm
            Docker          : false
            Kernel          : armv7l
            Userland        : armhf
            CPU threads: 4
            Current issues:
                             RTC time: n/a
                          NTP service: active
                      RTC in local TZ: no
            pi
            /home/pi
            X-Server: 	true
            Desktop: 	LXDE-pi
            Terminal: 	x11
            *** MEMORY ***
            Swap:           99M          0B         99M
                     7898 M total memory
                      183 M used memory
                      147 M active memory
                     7430 M free memory
                       39 M buffer memory
                      245 M swap cache
                       99 M total swap
                        0 M used swap
                       99 M free swap
            Raspberry only:
            oom events: 0
            *** FILESYSTEM ***
            /var:
            2.8G	/var/
            2.0G	/var/cache/apt
            2.0G	/var/cache
            527M	/var/log
            USB-Devices by-id:
            /usr/bin/npm 		9.8.1
            /usr/bin/npx 		9.8.1
            nodejs:
              Version table:
            Errors in npm tree:
            ioBroker Status
            Objects type: file
            States  type: file
            admin: 		5.1.23
            javascript: 	5.2.8
            Adapter State
            + instance is alive
            Dann verwende es.
            Und die Ausgabe von iob diag ist nicht komplett.
            • tiobbT tiobb
              ** BASE SYSTEM ***
                       Icon name: computer
                    Architecture: arm
              Docker          : false
              Kernel          : armv7l
              Userland        : armhf
              CPU threads: 4
              Current issues:
                               RTC time: n/a
                            NTP service: active
                        RTC in local TZ: no
              pi
              /home/pi
              X-Server: 	true
              Desktop: 	LXDE-pi
              Terminal: 	x11
              *** MEMORY ***
              Swap:           99M          0B         99M
                       7898 M total memory
                        183 M used memory
                        147 M active memory
                       7430 M free memory
                         39 M buffer memory
                        245 M swap cache
                         99 M total swap
                          0 M used swap
                         99 M free swap
              Raspberry only:
              oom events: 0
              *** FILESYSTEM ***
              /var:
              2.8G	/var/
              2.0G	/var/cache/apt
              2.0G	/var/cache
              527M	/var/log
              USB-Devices by-id:
              /usr/bin/npm 		9.8.1
              /usr/bin/npx 		9.8.1
              nodejs:
                Version table:
              Errors in npm tree:
              ioBroker Status
              Objects type: file
              States  type: file
              admin: 		5.1.23
              javascript: 	5.2.8
              Adapter State
              + instance is alive
              @tiobb
              iobroker stop
              iob fix
              cd /opt/iobroker
              iob upgrade self
              iob restart
              Wenn das nicht funktioniert alternativ:
              iobroker stop
              iob fix
              cd /opt/iobroker
              sudo -H -u iobroker npm install iobroker.js-controller
              iob restart
                Dann verwende es.
                tiobbT Offline
                tiobbT Offline
                tiobb
                Doch, mehr gibt es nicht in der Liste, außer das sich die letzte Zeile immer wiederholt
                Ich probiere jetzt mal deine letzte Anleitung
                Raspberry Pi 4 8gb
                • tiobbT tiobb
                  Irgendwann wiederholt es sich aber nicht mehr .
                    tiobbT Offline
                    tiobbT Offline
                    tiobb
                    Ah ok, ich hatte vorhin bestimmt 15 Zeilen mit immer dem selben Eintrag, das dauerte ewig.
                    ** BASE SYSTEM ***
                             Icon name: computer
                          Architecture: arm
                    Docker          : false
                    Kernel          : armv7l
                    Userland        : armhf
                    CPU threads: 4
                    Current issues:
                                     RTC time: n/a
                                  NTP service: active
                              RTC in local TZ: no
                    pi
                    /home/pi
                    X-Server: 	true
                    Desktop: 	LXDE-pi
                    Terminal: 	x11
                    *** MEMORY ***
                    Swap:           99M          0B         99M
                             7898 M total memory
                              183 M used memory
                              147 M active memory
                             7430 M free memory
                               39 M buffer memory
                              245 M swap cache
                               99 M total swap
                                0 M used swap
                               99 M free swap
                    Raspberry only:
                    oom events: 0
                    *** FILESYSTEM ***
                    /var:
                    2.8G	/var/
                    2.0G	/var/cache/apt
                    2.0G	/var/cache
                    527M	/var/log
                    USB-Devices by-id:
                    /usr/bin/npm 		9.8.1
                    /usr/bin/npx 		9.8.1
                    nodejs:
                      Version table:
                    Errors in npm tree:
                    ioBroker Status
                    Objects type: file
                    States  type: file
                    admin: 		5.1.23
                    javascript: 	5.2.8
                    Adapter State
                    + instance is alive
                    Raspberry Pi 4 8gb
                    • tiobbT tiobb
                      ** BASE SYSTEM ***
                               Icon name: computer
                            Architecture: arm
                      Docker          : false
                      Kernel          : armv7l
                      Userland        : armhf
                      CPU threads: 4
                      Current issues:
                                       RTC time: n/a
                                    NTP service: active
                                RTC in local TZ: no
                      pi
                      /home/pi
                      X-Server: 	true
                      Desktop: 	LXDE-pi
                      Terminal: 	x11
                      *** MEMORY ***
                      Swap:           99M          0B         99M
                               7898 M total memory
                                183 M used memory
                                147 M active memory
                               7430 M free memory
                                 39 M buffer memory
                                245 M swap cache
                                 99 M total swap
                                  0 M used swap
                                 99 M free swap
                      Raspberry only:
                      oom events: 0
                      *** FILESYSTEM ***
                      /var:
                      2.8G	/var/
                      2.0G	/var/cache/apt
                      2.0G	/var/cache
                      527M	/var/log
                      USB-Devices by-id:
                      /usr/bin/npm 		9.8.1
                      /usr/bin/npx 		9.8.1
                      nodejs:
                        Version table:
                      Errors in npm tree:
                      ioBroker Status
                      Objects type: file
                      States  type: file
                      admin: 		5.1.23
                      javascript: 	5.2.8
                      Adapter State
                      + instance is alive
                      Desktop: LXDE-pi
                      Ich hab jetzt keinen Bock mehr...
                      SCHALT DIE SCHEISSE AUS!!!!11!!!!!!!!!111111
                      Meister MopperM tiobbT 2 Antworten Letzte Antwort
                        Desktop: LXDE-pi
                        Meister MopperM Online
                        Meister Mopper
                        Oh, das ist selten, aber Recht haste 👍 👍 👍
                        Proxmox und HA ...
                        Ich schreibe den Code nicht mehr selbst – ich schimpfe mit der KI, bis er funktioniert.
                          Desktop: LXDE-pi
                          tiobbT Offline
                          tiobbT Offline
                          tiobb
                          Hab jetzt das iob diag mit putty gemacht, aber wenn ich dort alles markiere und es dann Kopieren will ist alles wieder weg
                          Raspberry Pi 4 8gb
                          DJMarc75D HomoranH 2 Antworten Letzte Antwort
                          • tiobbT tiobb
                            DJMarc75D Offline
                            DJMarc75D Offline
                            DJMarc75
                            in PuTTY wir nur markiert und nix kopiert. Das Markierte geht automatisch in den Zwischenspeicher.
                            Lehrling seit 1975 !!!
                            • tiobbT tiobb
                              sobald es markiert ist, ist es bereits im Zwischenspeicher
                                tiobbT Offline
                                tiobbT Offline
                                tiobb
                                @DJMarc75
                                Da soll mal einer wie ich drauf kommen
                                @Thomas-Braun
                                *** BASE SYSTEM ***
                                         Icon name: computer
                                      Architecture: arm
                                Docker          : false
                                Kernel          : armv7l
                                Userland        : armhf
                                 19:07:07 up 59 min,  2 users,  load average: 0.18, 0.41, 0.63
                                CPU threads: 4
                                Current issues:
                                               Local time: Thu 2023-11-02 19:07:07 CET
                                           Universal time: Thu 2023-11-02 18:07:07 UTC
                                                 RTC time: n/a
                                              NTP service: active
                                          RTC in local TZ: no
                                pi
                                /home/pi
                                X-Server:       true
                                Desktop:
                                Terminal:       tty
                                *** MEMORY ***
                                Mem:           7.9G        327M        6.6G         17M        976M        7.3G
                                Swap:           99M          0B         99M
                                Total:         8.0G        327M        6.7G
                                         7898 M total memory
                                          327 M used memory
                                          404 M active memory
                                          728 M inactive memory
                                         6594 M free memory
                                          150 M buffer memory
                                          826 M swap cache
                                           99 M total swap
                                            0 M used swap
                                           99 M free swap
                                Raspberry only:
                                oom events: 0
                                *** FILESYSTEM ***
                                /var:
                                2.8G    /var/
                                2.0G    /var/cache/apt
                                2.0G    /var/cache
                                527M    /var/log
                                512M    /opt/iobroker/iobroker-data/
                                7.4M    /opt/iobroker/iobroker-data/objects.jsonl
                                USB-Devices by-id:
                                /usr/bin/npm            9.8.1
                                /usr/bin/npx            9.8.1
                                nodejs:
                                  Version table:
                                Errors in npm tree:
                                ioBroker Status
                                Objects type: jsonl
                                States  type: jsonl
                                js-controller:  5.0.12
                                admin:          5.1.23
                                javascript:     5.2.8
                                Adapter State
                                + instance is alive
                                Active repo(s): stable
                                Used repository: stable
                                Adapter    "admin"        : 6.12.0   , installed 5.1.23 [Updatable]
                                Adapter    "alexa2"       : 3.25.2   , installed 3.9.3  [Updatable]
                                Adapter    "backitup"     : 2.8.7    , installed 2.1.17 [Updatable]
                                Adapter    "cloud"        : 4.4.1    , installed 4.1.0  [Updatable]
                                Adapter    "discovery"    : 3.1.0    , installed 2.7.0  [Updatable]
                                Adapter    "echarts"      : 1.5.1    , installed 1.0.3  [Updatable]
                                Adapter    "flot"         : 1.12.0   , installed 1.10.6 [Updatable]
                                Adapter    "fritzdect"    : 2.3.1    , installed 2.1.15 [Updatable]
                                Adapter    "harmony"      : 1.2.2    , installed 1.2.2
                                Adapter    "history"      : 3.0.1    , installed 1.9.13 [Updatable]
                                Adapter    "ical"         : 1.13.3   , installed 1.11.3 [Updatable]
                                Adapter    "icons-mfd-svg": 1.1.0    , installed 1.0.2  [Updatable]
                                Adapter    "iot"          : 1.14.5   , installed 1.8.22 [Updatable]
                                Adapter    "javascript"   : 7.1.4    , installed 5.2.8  [Updatable]
                                Controller "js-controller": 5.0.12   , installed 5.0.12
                                Adapter    "mqtt"         : 4.1.1    , installed 2.4.0  [Updatable]
                                Adapter    "rpi2"         : 1.3.2    , installed 1.3.1  [Updatable]
                                Adapter    "shelly"       : 6.4.5    , installed 4.0.7  [Updatable]
                                Adapter    "simple-api"   : 2.7.2    , installed 2.6.1  [Updatable]
                                Adapter    "socketio"     : 6.5.5    , installed 3.1.4  [Updatable]
                                Adapter    "sonoff"       : 2.5.3    , installed 2.4.5  [Updatable]
                                Adapter    "tankerkoenig" : 3.3.7    , installed 2.1.1  [Updatable]
                                Adapter    "telegram"     : 1.16.0   , installed 1.10.0 [Updatable]
                                Adapter    "text2command" : 3.0.2    , installed 2.1.1  [Updatable]
                                Adapter    "tr-064"       : 4.2.18   , installed 4.2.14 [Updatable]
                                Adapter    "trashschedule": 2.2.0    , installed 1.2.0  [Updatable]
                                Adapter    "vis"          : 1.4.16   , installed 1.4.3  [Updatable]
                                Adapter    "vis-hqwidgets": 1.4.0    , installed 1.1.7  [Updatable]
                                Adapter    "vis-material-advanced": 1.7.4, installed 1.7.0 [Updatable]
                                Adapter    "web"          : 6.1.2    , installed 3.4.7  [Updatable]
                                Adapter    "wifilight"    : 1.1.4    , installed 1.1.0  [Updatable]
                                Adapter    "yeelight-2"   : 1.2.1    , installed 1.0.3  [Updatable]
                                Adapter    "zigbee"       : 1.8.23   , installed 1.6.3  [Updatable]
                                Objects and States
                                Objects:        134
                                States:         96
                                Hit:1 http://archive.raspberrypi.org/debian buster InRelease
                                Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
                                Hit:3 https://deb.nodesource.com/node_18.x nodistro InRelease
                                Reading package lists...
                                Pending Updates: 0
                                *** Listening Ports ***
                                tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15330      520/sshd
                                tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          17433      374/cupsd
                                tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       50954      6217/iobroker.js-co
                                tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       50947      6217/iobroker.js-co
                                tcp6       0      0 :::8081                 :::*                    LISTEN      1001       53250      6238/io.admin.0
                                tcp6       0      0 ::1:3350                :::*                    LISTEN      0          17799      521/xrdp-sesman
                                tcp6       0      0 :::22                   :::*                    LISTEN      0          15332      520/sshd
                                tcp6       0      0 ::1:631                 :::*                    LISTEN      0          17432      374/cupsd
                                tcp6       0      0 :::3389                 :::*                    LISTEN      115        16320      535/xrdp
                                udp        0      0 0.0.0.0:55790           0.0.0.0:*                           108        17424      366/avahi-daemon: r
                                udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          18085      438/dhcpcd
                                udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          18520      497/cups-browsed
                                udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        17422      366/avahi-daemon: r
                                udp6       0      0 :::60395                :::*                                108        17425      366/avahi-daemon: r
                                udp6       0      0 :::546                  :::*                                0          19804      438/dhcpcd
                                udp6       0      0 :::5353                 :::*                                108        17423      366/avahi-daemon: r
                                2023-11-02 18:38:21.599  - info: host.raspberrypi ip addresses: 192.168.178.75 fd00::cfc7:3047:144a:2a06 2a02:f90:e586:4700:9886:797:4456:5ccf fe80::2b27:87ea:3c74:2b60 192.168.178.76 fd00::3d89:1fee:ee4c:21d8 2a02:f90:e586:4700:86fe:be6c:37ae:bcf4 fe80::fa01:3136:8d9d:4ffd
                                2023-11-02 18:38:21.914  - info: host.raspberrypi connected to Objects and States
                                2023-11-02 18:38:21.943  - info: host.raspberrypi added notifications configuration of host
                                2023-11-02 18:38:21.950  - info: host.raspberrypi Node.js version has changed from unknown to 18.18.2
                                2023-11-02 18:38:22.010  - info: host.raspberrypi Successfully updated capabilities "cap_net_admin, cap_net_bind_service, cap_net_raw" for /usr/bin/node
                                2023-11-02 18:38:22.603  - info: host.raspberrypi 3 instances found
                                2023-11-02 18:38:22.612  - info: host.raspberrypi starting 3 instances
                                2023-11-02 18:38:22.685  - info: host.raspberrypi instance system.adapter.admin.0 started with pid 6238
                                2023-11-02 18:38:25.875  - info: admin.0 (6238) starting. Version 5.1.23 in /opt/iobroker/node_modules/iobroker.admin, node: v18.18.2, js-controller: 5.0.12
                                2023-11-02 18:38:25.934  - info: admin.0 (6238) requesting all states
                                2023-11-02 18:38:25.936  - info: admin.0 (6238) requesting all objects
                                2023-11-02 18:38:26.132  - info: admin.0 (6238) received all objects
                                2023-11-02 18:38:26.148  - warn: admin.0 (6238) Information for Developer: Using the direct "Let's encrypt" module import is deprecated and will be removed in the next js-controller version, use @iobroker/webserver instead
                                2023-11-02 18:38:26.153  - warn: admin.0 (6238) Object admin.0.info.lastUpdateCheck is invalid: Default value has to be type "number" but received type "string"
                                2023-11-02 18:38:26.154  - warn: admin.0 (6238) This object will not be created in future versions. Please report this to the developer.
                                2023-11-02 18:38:26.391  - info: admin.0 (6238) http server listening on port 8081
                                2023-11-02 18:38:26.391  - info: admin.0 (6238) Use link "http://localhost:8081" to configure.
                                2023-11-02 18:38:26.484  - info: admin.0 (6238) State value to set for "admin.0.info.lastUpdateCheck" has to be type "number" but received type "string"
                                2023-11-02 18:38:26.493  - warn: admin.0 (6238) Repository cannot be read
                                2023-11-02 18:38:26.653  - info: host.raspberrypi instance system.adapter.discovery.0 started with pid 6253
                                2023-11-02 18:38:26.718  - error: admin.0 (6238) Cannot update news: TypeError: newNews.forEach is not a function
                                2023-11-02 18:38:29.313  - info: discovery.0 (6253) starting. Version 2.7.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v18.18.2, js-controller: 5.0.12
                                2023-11-02 18:38:30.661  - info: host.raspberrypi instance system.adapter.backitup.0 started with pid 6268
                                2023-11-02 18:38:33.396  - info: backitup.0 (6268) starting. Version 2.1.17 in /opt/iobroker/node_modules/iobroker.backitup, node: v18.18.2, js-controller: 5.0.12
                                2023-11-02 18:38:33.472  - info: backitup.0 (6268) [iobroker] backup was activated at 02:40 every 1 day(s)
                                iob diag has finished.
                                Raspberry Pi 4 8gb
                                Thomas BraunT DJMarc75D 3 Antworten Letzte Antwort
                                • tiobbT tiobb
                                  @DJMarc75
                                  @Thomas-Braun
                                  *** BASE SYSTEM ***
                                           Icon name: computer
                                        Architecture: arm
                                  Docker          : false
                                  Kernel          : armv7l
                                  Userland        : armhf
                                  CPU threads: 4
                                  Current issues:
                                                   RTC time: n/a
                                                NTP service: active
                                            RTC in local TZ: no
                                  pi
                                  /home/pi
                                  X-Server:       true
                                  Desktop:
                                  Terminal:       tty
                                  *** MEMORY ***
                                  Swap:           99M          0B         99M
                                           7898 M total memory
                                            327 M used memory
                                            404 M active memory
                                           6594 M free memory
                                            150 M buffer memory
                                            826 M swap cache
                                             99 M total swap
                                              0 M used swap
                                             99 M free swap
                                  Raspberry only:
                                  oom events: 0
                                  *** FILESYSTEM ***
                                  /var:
                                  2.8G    /var/
                                  2.0G    /var/cache/apt
                                  2.0G    /var/cache
                                  527M    /var/log
                                  USB-Devices by-id:
                                  /usr/bin/npm            9.8.1
                                  /usr/bin/npx            9.8.1
                                  nodejs:
                                    Version table:
                                  Errors in npm tree:
                                  ioBroker Status
                                  Objects type: jsonl
                                  States  type: jsonl
                                  admin:          5.1.23
                                  javascript:     5.2.8
                                  Adapter State
                                  + instance is alive
                                  Objects and States
                                  Objects:        134
                                  States:         96
                                  Pending Updates: 0
                                  @tiobb
                                  sudo reboot
                                  • tiobbT tiobb
                                    @DJMarc75
                                    @Thomas-Braun
                                    *** BASE SYSTEM ***
                                             Icon name: computer
                                          Architecture: arm
                                    Docker          : false
                                    Kernel          : armv7l
                                    Userland        : armhf
                                    CPU threads: 4
                                    Current issues:
                                                     RTC time: n/a
                                                  NTP service: active
                                              RTC in local TZ: no
                                    pi
                                    /home/pi
                                    X-Server:       true
                                    Desktop:
                                    Terminal:       tty
                                    *** MEMORY ***
                                    Swap:           99M          0B         99M
                                             7898 M total memory
                                              327 M used memory
                                              404 M active memory
                                             6594 M free memory
                                              150 M buffer memory
                                              826 M swap cache
                                               99 M total swap
                                                0 M used swap
                                               99 M free swap
                                    Raspberry only:
                                    oom events: 0
                                    *** FILESYSTEM ***
                                    /var:
                                    2.8G    /var/
                                    2.0G    /var/cache/apt
                                    2.0G    /var/cache
                                    527M    /var/log
                                    USB-Devices by-id:
                                    /usr/bin/npm            9.8.1
                                    /usr/bin/npx            9.8.1
                                    nodejs:
                                      Version table:
                                    Errors in npm tree:
                                    ioBroker Status
                                    Objects type: jsonl
                                    States  type: jsonl
                                    admin:          5.1.23
                                    javascript:     5.2.8
                                    Adapter State
                                    + instance is alive
                                    Objects and States
                                    Objects:        134
                                    States:         96
                                    Pending Updates: 0
                                    DJMarc75D Offline
                                    DJMarc75D Offline
                                    DJMarc75
                                    @tiobb Desktop immer noch aktiv 👎
                                    • tiobbT tiobb
                                      @DJMarc75
                                      @Thomas-Braun
                                      *** BASE SYSTEM ***
                                               Icon name: computer
                                            Architecture: arm
                                      Docker          : false
                                      Kernel          : armv7l
                                      Userland        : armhf
                                      CPU threads: 4
                                      Current issues:
                                                       RTC time: n/a
                                                    NTP service: active
                                                RTC in local TZ: no
                                      pi
                                      /home/pi
                                      X-Server:       true
                                      Desktop:
                                      Terminal:       tty
                                      *** MEMORY ***
                                      Swap:           99M          0B         99M
                                               7898 M total memory
                                                327 M used memory
                                                404 M active memory
                                               6594 M free memory
                                                150 M buffer memory
                                                826 M swap cache
                                                 99 M total swap
                                                  0 M used swap
                                                 99 M free swap
                                      Raspberry only:
                                      oom events: 0
                                      *** FILESYSTEM ***
                                      /var:
                                      2.8G    /var/
                                      2.0G    /var/cache/apt
                                      2.0G    /var/cache
                                      527M    /var/log
                                      USB-Devices by-id:
                                      /usr/bin/npm            9.8.1
                                      /usr/bin/npx            9.8.1
                                      nodejs:
                                        Version table:
                                      Errors in npm tree:
                                      ioBroker Status
                                      Objects type: jsonl
                                      States  type: jsonl
                                      admin:          5.1.23
                                      javascript:     5.2.8
                                      Adapter State
                                      + instance is alive
                                      Objects and States
                                      Objects:        134
                                      States:         96
                                      Pending Updates: 0
                                      @tiobb
                                      iob update
                                      iob upgrade all -y
                                        @tiobb
                                        iob update
                                        iob upgrade all -y
                                        tiobbT Offline
                                        tiobbT Offline
                                        tiobb
                                        So, habe wieder Zugriff auf den iobroker, leider ist aber alles weg, außer die installierten Adapter sind noch da. Keine Objekte, keine Scripte usw.
                                        Trotzdem Danke für die Hilfe
                                        Raspberry Pi 4 8gb
                                        • tiobbT tiobb
                                          @tiobb
                                          Hätte eigentlich erwartet das die wieder auftauchen.
                                          Offenbar waren die dir ja aber auch nicht soooooooo wichtig, sonst gäbe es ja ein Backup dieser Daten.
                                          Kannst aber mal nach dem Skript von fastfoot schauen. Vielleicht funktioniert das.
