  4. ioBroker stoppt und startet unbeabsichtigt
    5.0k
23 Beiträge 3 Kommentatoren 2.5k Aufrufe 2 Beobachtet
  • RaspiUserR RaspiUser
    @thomas-braun sagte in ioBroker stoppt und startet unbeabsichtigt:
    Abwarten. Der fängt sich.
    ... tatsächlich ... hat zwar ca. 15min gedauert aber er läuft wieder.
    Kannst Du (ich sehe nix ...) den Grund des Absturz erkennen ?
    (Wieder zu wenig RAM ? ... aber das habe ich zwischenzeitlich verstanden ... 😰 )
    Skript v.2023-10-10
    *** BASE SYSTEM ***
     Static hostname: ioBroker-Raspi
           Icon name: computer
              Kernel: Linux 6.1.21-v8+
        Architecture: arm64
    Model           : Raspberry Pi 4 Model B Rev 1.1
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : arm64
    Systemuptime and Load:
     09:49:01 up 1 day, 33 min,  2 users,  load average: 1.00, 16.80, 24.11
    CPU threads: 4
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** Time and Time Zones ***
                   Local time: Thu 2023-11-02 09:49:01 CET
               Universal time: Thu 2023-11-02 08:49:01 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    Boot Target:    multi-user.target
    *** MEMORY ***
    Mem:            1.9G        1.4G        403M        1.1M        247M        583M
    Swap:           104M        6.2M         98M
    Total:          2.0G        1.4G        502M
             1849 M total memory
             1292 M used memory
             1345 M active memory
                4 M inactive memory
              384 M free memory
               25 M buffer memory
              211 M swap cache
               99 M total swap
                5 M used swap
               94 M free swap
    Raspberry only:
    oom events: 0
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** FILESYSTEM ***
    /dev/root      ext4       15G  4.4G  9.4G  32% /
    devtmpfs       devtmpfs  667M     0  667M   0% /dev
    tmpfs          tmpfs     925M     0  925M   0% /dev/shm
    tmpfs          tmpfs     370M  1.2M  369M   1% /run
    tmpfs          tmpfs     5.0M   16K  5.0M   1% /run/lock
    /dev/mmcblk0p1 vfat      255M   31M  225M  13% /boot
    tmpfs          tmpfs     185M     0  185M   0% /run/user/1000
    [Wed Nov  1 09:15:52 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:12:B4:C8 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=bc66e88d-02 rootfstype=ext4 fsck.repair=yes rootwait
    [Wed Nov  1 09:15:53 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
    [Wed Nov  1 09:15:53 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
    [Wed Nov  1 09:15:56 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
    TARGET  SOURCE         FSTYPE OPTIONS
    /       /dev/mmcblk0p2 ext4   rw,noatime
    `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    1.3G    /var/
    647M    /var/log
    582M    /var/log/journal/ececfd62e7f741458cc0d2ea60d43f93
    328M    /var/cache
    Archived and active journals take up 581.2M in the file system.
    /opt/iobroker/backups:
    4.0K    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    215M    /opt/iobroker/iobroker-data/
    153M    /opt/iobroker/iobroker-data/files
    52M     /opt/iobroker/iobroker-data/files/javascript.admin
    43M     /opt/iobroker/iobroker-data/backup-objects
    34M     /opt/iobroker/iobroker-data/files/javascript.admin/static
    21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js.map
    13M     /opt/iobroker/iobroker-data/objects.jsonl
    8.3M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js
    7.8M    /opt/iobroker/iobroker-data/states.jsonl
    7.1M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/610.f22de4ab.chunk.js.map
    USB-Devices by-id:
    /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_6edb8350b219ec11a0e039cc47486eb0-if00-port0
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.18.2
    /usr/bin/node           v18.18.2
    /usr/bin/npm            9.8.1
    /usr/bin/npx            9.8.1
    /usr/bin/corepack       0.19.0
    nodejs:
      Installed: 18.18.2-1nodesource1
      Candidate: 18.18.2-1nodesource1
      Version table:
     *** 18.18.2-1nodesource1 1001
            500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages
         18.18.1-1nodesource1 1001
         18.18.0-1nodesource1 1001
         18.17.1-1nodesource1 1001
         18.17.0-1nodesource1 1001
         18.16.1-1nodesource1 1001
         18.16.0-1nodesource1 1001
         18.15.0-1nodesource1 1001
         18.14.2-1nodesource1 1001
         18.14.1-1nodesource1 1001
         18.14.0-1nodesource1 1001
         18.13.0+dfsg1-1 500
            500 http://deb.debian.org/debian bookworm/main arm64 Packages
         18.13.0-1nodesource1 1001
         18.12.0-1nodesource1 1001
         18.11.0-1nodesource1 1001
         18.10.0-1nodesource1 1001
         18.9.1-1nodesource1 1001
         18.9.0-1nodesource1 1001
         18.8.0-1nodesource1 1001
         18.7.0-1nodesource1 1001
         18.6.0-1nodesource1 1001
         18.5.0-1nodesource1 1001
         18.4.0-1nodesource1 1001
         18.3.0-1nodesource1 1001
         18.2.0-1nodesource1 1001
         18.1.0-1nodesource1 1001
         18.0.0-1nodesource1 1001
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  5.0.12
    admin:          6.12.0
    javascript:     7.1.4
    Adapters from github:   1
    Adapter State
    + system.adapter.admin.0                  : admin                 : ioBroker-Raspi                           -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.alpha-ess.0              : alpha-ess             : ioBroker-Raspi                           -  enabled
    + system.adapter.backitup.0               : backitup              : ioBroker-Raspi                           -  enabled
    + system.adapter.canbus.0                 : canbus                : ioBroker-Raspi                           -  enabled
      system.adapter.discovery.0              : discovery             : ioBroker-Raspi                           - disabled
      system.adapter.feiertage.0              : feiertage             : ioBroker-Raspi                           -  enabled
    + system.adapter.frontier_silicon.0       : frontier_silicon      : ioBroker-Raspi                           -  enabled
    + system.adapter.hm-rega.0                : hm-rega               : ioBroker-Raspi                           -  enabled
    + system.adapter.hm-rpc.0                 : hm-rpc                : ioBroker-Raspi                           -  enabled, port: 0
    + system.adapter.hm-rpc.1                 : hm-rpc                : ioBroker-Raspi                           -  enabled, port: 0
    + system.adapter.iqontrol.0               : iqontrol              : ioBroker-Raspi                           -  enabled
    + system.adapter.javascript.0             : javascript            : ioBroker-Raspi                           -  enabled
    + system.adapter.lgtv.0                   : lgtv                  : ioBroker-Raspi                           -  enabled
    + system.adapter.mqtt.0                   : mqtt                  : ioBroker-Raspi                           -  enabled, port: 1883, bind: 192.168.178.36
      system.adapter.onkyo.0                  : onkyo                 : ioBroker-Raspi                           - disabled
    + system.adapter.psa.0                    : psa                   : ioBroker-Raspi                           -  enabled
    + system.adapter.sainlogic.0              : sainlogic             : ioBroker-Raspi                           -  enabled, port: 1030, bind: 192.168.178.36
    + system.adapter.shuttercontrol.0         : shuttercontrol        : ioBroker-Raspi                           -  enabled
      system.adapter.simple-api.0             : simple-api            : ioBroker-Raspi                           - disabled, port: 8087, bind: 0.0.0.0, run as: admin
    + system.adapter.sonoff.0                 : sonoff                : ioBroker-Raspi                           -  enabled, port: 1885, bind: 0.0.0.0
    + system.adapter.tankerkoenig.0           : tankerkoenig          : ioBroker-Raspi                           -  enabled
    + system.adapter.telegram.0               : telegram              : ioBroker-Raspi                           -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.tr-064.0                 : tr-064                : ioBroker-Raspi                           -  enabled
    + system.adapter.vw-connect.0             : vw-connect            : ioBroker-Raspi                           -  enabled
    + system.adapter.web.0                    : web                   : ioBroker-Raspi                           -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.zigbee.0                 : zigbee                : ioBroker-Raspi                           -  enabled, port: /dev/ttyUSB0
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 6.12.0   , installed 6.12.0
    Adapter    "alpha-ess"    : 1.0.2    , installed 1.0.2
    Adapter    "backitup"     : 2.8.7    , installed 2.8.1  [Updatable]
    Adapter    "canbus"       : 1.3.1    , installed 1.3.1
    Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
    Adapter    "frontier_silicon": 0.1.1 , installed 0.1.1
    Adapter    "hm-rega"      : 3.0.47   , installed 3.0.47
    Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
    Adapter    "iqontrol"     : 2.3.0    , installed 2.3.0
    Adapter    "javascript"   : 7.1.4    , installed 7.1.4
    Controller "js-controller": 5.0.12   , installed 5.0.12
    Adapter    "lgtv"         : 2.1.1    , installed 2.1.1
    Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
    Adapter    "onkyo"        : 2.1.2    , installed 2.1.2
    Adapter    "psa"          : 0.0.11   , installed 0.0.11
    Adapter    "sainlogic"    : 0.10.5   , installed 0.10.5
    Adapter    "shuttercontrol": 1.6.2   , installed 1.6.2
    Adapter    "socketio"     : 6.5.5    , installed 6.5.5
    Adapter    "sonoff"       : 2.5.3    , installed 2.5.3
    Adapter    "telegram"     : 1.16.0   , installed 1.16.0
    Adapter    "vw-connect"   : 0.0.67   , installed 0.2.0
    Adapter    "web"          : 6.1.2    , installed 6.1.2
    Adapter    "ws"           : 2.5.5    , installed 2.5.5
    Adapter    "zigbee"       : 1.8.23   , installed 1.8.23
    Objects and States
    Objects:        5773
    States:         4364
    Hit:1 http://security.debian.org/debian-security bookworm-security InRelease
    Hit:2 http://deb.debian.org/debian bookworm InRelease
    Hit:4 http://archive.raspberrypi.org/debian bookworm InRelease
    Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
    Reading package lists...
    Pending Updates: 55
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13851      543/sshd: /usr/sbin
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       428961     7507/iobroker.js-co
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       430255     7507/iobroker.js-co
    tcp        0      0 192.168.178.36:1883     0.0.0.0:*               LISTEN      1001       430408     7700/io.mqtt.0
    tcp        0      0 192.168.178.36:1030     0.0.0.0:*               LISTEN      1001       432555     8067/io.sainlogic.0
    tcp        0      0 192.168.178.36:42010    0.0.0.0:*               LISTEN      1001       431490     7789/io.hm-rpc.1
    tcp        0      0 192.168.178.36:42001    0.0.0.0:*               LISTEN      1001       430426     7733/io.hm-rpc.0
    tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1001       430764     7871/io.sonoff.0
    tcp6       0      0 :::22                   :::*                    LISTEN      0          13862      543/sshd: /usr/sbin
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       429711     7640/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       433227     8097/io.web.0
    udp        0      0 0.0.0.0:20000           0.0.0.0:*                           65534      1587       708/cannelloni
    udp        0      0 0.0.0.0:49934           0.0.0.0:*                           108        11838      380/avahi-daemon: r
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14020      844/dhcpcd
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        11836      380/avahi-daemon: r
    udp6       0      0 :::546                  :::*                                0          14033      844/dhcpcd
    udp6       0      0 :::5353                 :::*                                108        11837      380/avahi-daemon: r
    udp6       0      0 :::39321                :::*                                108        11839      380/avahi-daemon: r
    2023-11-02 09:46:58.713  - info: iqontrol.0 (8112) Creating Widget States...
    2023-11-02 09:46:58.714  - info: iqontrol.0 (8112) Lists deactivated.
    2023-11-02 09:46:58.715  - info: iqontrol.0 (8112) Deleting unused Objects...
    2023-11-02 09:46:58.716  - info: iqontrol.0 (8112) Subscribing to states...
    2023-11-02 09:46:58.719  - info: iqontrol.0 (8112) iQontrol ready.
    2023-11-02 09:46:59.522  - info: host.ioBroker-Raspi instance system.adapter.vw-connect.0 started with pid 8127
    2023-11-02 09:47:02.502  - info: vw-connect.0 (8127) starting. Version 0.2.0 (non-npm: ta2k/ioBroker.vw-connect) in /opt/iobroker/node_modules/iobroker.vw-connect, node: v18.18.2, js-controller: 5.0.12
    2023-11-02 09:47:02.556  - info: vw-connect.0 (8127) Login in with vwv2
    2023-11-02 09:47:04.995  - info: vw-connect.0 (8127) Login successful
    2023-11-02 09:47:05.489  - info: vw-connect.0 (8127) {"mandatoryConsentInfo":[{"id":"termsOfUse","status":"VALID"}],"mandatoryFieldsStatus":true,"mbbIdStatus":true,"mbbUserId":"5qIgGpN2LkvdHc2H0TWDvtlwap51","missingMandatoryFields":[],"scopeId":"commonMandatoryFields","spinStatus":true,"ssoId":"de858a4a-f971-40f1-b375-baf01b331d2a"}
    2023-11-02 09:47:05.748  - info: vw-connect.0 (8127) Found 1 vehicles
    2023-11-02 09:47:41.431  - info: sonoff.0 (7871) Client [Steckdose-6-Kuehlkombi] connected with secret 1698914861421_288
    2023-11-02 09:47:46.989  - info: sonoff.0 (7871) Client [Steckdose-1-Trockner] connected with secret 1698914866986_6241
    2023-11-02 09:47:48.809  - info: sonoff.0 (7871) Client [Bodenlampen] connected with secret 1698914868808_4658
    2023-11-02 09:47:49.620  - warn: zigbee.0 (7823) Device '0x0017880102a2b974' announced itself
    2023-11-02 09:47:54.695  - info: sonoff.0 (7871) Client [Steckdose-2-Waschmaschine] connected with secret 1698914874694_3145
    2023-11-02 09:47:59.110  - info: sonoff.0 (7871) Client [Smartmeter] connected with secret 1698914879107_367
    2023-11-02 09:48:02.306  - info: sonoff.0 (7871) Client [Steckdose-4-OG-Medien] connected with secret 1698914882305_5112
    2023-11-02 09:48:03.405  - warn: zigbee.0 (7823) Device '0x7cb03eaa0a03fb8a' announced itself
    2023-11-02 09:48:03.407  - warn: zigbee.0 (7823) Device '0x7cb03eaa0a059b32' announced itself
    2023-11-02 09:48:06.841  - info: sonoff.0 (7871) Client [Steckdose-3-Geschirrspueler] connected with secret 1698914886840_7258
    2023-11-02 09:48:09.379  - info: sonoff.0 (7871) Client [Steckdose-5-EG-Medien] connected with secret 1698914889378_439
    2023-11-02 09:48:09.594  - info: sonoff.0 (7871) Client [Steckdose-9] connected with secret 1698914889592_1177
    2023-11-02 09:48:10.457  - info: sonoff.0 (7871) Client [Steckdose-7-Gefrierschrank] connected with secret 1698914890455_4919
    2023-11-02 09:48:10.481  - info: sonoff.0 (7871) Client [Steckdose-8] connected with secret 1698914890479_891
    iob diag has finished.
    @raspiuser
    Kein Wunder. Ab 4 ist die Kiste voll ausgelastet.
    Da knallt irgendwas heftig rein.
    Spiel die Updates ein!
    sudo apt update
    sudo apt full-upgrade
    sudo reboot
    Und auch den ioBroker auf Stand halten.
    RaspiUserR 1 Antwort Letzte Antwort
      @raspiuser
      sudo apt update
      sudo reboot
      RaspiUserR Online
      RaspiUserR Online
      RaspiUser
      ? ... meinst Du die Uhrzeit ?! 🙄 Was sagt diese "load average" ?
      irgendwas
      ... aber WAS sieht man scheinbar nicht ?
      ... ich mache alle 4 Wochen ...
      sudo apt-get update
      sudo apt-get upgrade
        irgendwas
        sudo apt-get update
        @raspiuser sagte in ioBroker stoppt und startet unbeabsichtigt:
        Ein Wert von 1 wäre eine Auslastung von 100% (pro Kern). Da du auf der CPU vier Kerne hast ist ab 4 der Prozessor vollständig dicht.
        Die Werte sind der Durchschnitt über 1, 5 und 15 Minuten. Kann man aber auch alles nachlesen.
        Updates: Mach sie häufiger.
          irgendwas
          sudo apt-get update
          Sieht man in Tools wie 'top' oder 'htop'.
            RaspiUserR Online
            RaspiUserR Online
            RaspiUser
            Updates
            ... habe jetzt ein Update mit "deinen" Befehlen durchgeführt ... hat etwas gedauert, war wohl nötig ....
            Ich habe jetzt auch (zufällig "gefunden") in deinen "LINUX-Werkzeugkaste" reingeschaut ... sehr interessant !!!
              Updates
              Das sind nicht 'meine Befehle ', das sind absolute Grundlagen.
                RaspiUserR Online
                RaspiUserR Online
                RaspiUser
                ... schon klar ... damit wollte ich nur zum Ausdruck bringen, dass ich "meine" Befehle nicht genutzt habe ...
                  RaspiUserR Online
                  RaspiUserR Online
                  RaspiUser
                  Sorry ... ich nerve weiter ...:
                  Ich habe jetzt im Terminal "top" bzw. "htop" ausgeführt ...
                  Auf was muss ich achten bzw. WAS knallt da rein ?
                    @raspiuser
                    Die Prozesse werden da angezeigt.
                      @raspiuser
                      RaspiUserR Online
                      RaspiUserR Online
                      RaspiUser
                      ... aber wo muss ich bzgl. meinem Problem genauer hinschauen ... ? Welcher Wert ?
                      Tasks: 170 total,   1 running, 169 sleeping,   0 stopped,   0 zombie
                      %Cpu(s):  4.5 us,  0.7 sy,  0.0 ni, 94.4 id,  0.2 wa,  0.0 hi,  0.1 si,  0.0 st
                      MiB Mem :   1849.2 total,    169.9 free,   1346.7 used,    401.5 buff/cache
                      MiB Swap:    100.0 total,    100.0 free,      0.0 used.    502.5 avail Mem
                          PID USER      PR  NI    VIRT    RES    SHR S  %CPU  %MEM     TIME+ COMMAND
                         2735 iobroker  20   0 5198148 162752  44132 S   7.0   8.6   1:12.02 iobroker.js-con
                         3053 iobroker  20   0  662620  72140  38296 S   3.3   3.8   0:05.25 io.sainlogic.0
                         2809 iobroker  20   0  671776  80036  37112 S   2.6   4.2   0:05.13 io.mqtt.0
                         2772 iobroker  20   0  998016 148360  37172 S   1.7   7.8   0:27.47 io.javascript.0
                         2790 iobroker  20   0  807240  93184  43108 S   1.3   4.9   0:08.92 io.telegram.0
                         3072 iobroker  20   0  924548  71424  37808 S   1.0   3.8   0:05.45 io.alpha-ess.0
                         2828 iobroker  20   0  666680  76528  38384 S   0.7   4.0   0:05.90 io.hm-rpc.0
                         2843 iobroker  20   0  670960  81628  37824 S   0.7   4.3   0:09.38 io.hm-rega.0
                         3042 iobroker  20   0  665712  81488  42348 S   0.7   4.3   0:06.26 io.shuttercontr
                         3117 iobroker  20   0 5128684  89056  39592 S   0.7   4.7   0:07.81 io.vw-connect.0
                        @raspiuser
                        %CPU oder %MEM sind erste Indikatoren. Man kann das auch danach sortieren. Jedenfalls bei htop.
                          @raspiuser
                          RaspiUserR Online
                          RaspiUserR Online
                          RaspiUser
                          %CPU oder %MEM
                          OK ... ich verdaue jetzt erstmal deine Anmerkungen.
                          Danke soweit.
