  4. Enocean 0.9.0 Geräte hinzufügen geht nicht mehr
29 Beiträge 2 Kommentatoren 3.2k Aufrufe 2 Beobachtet
  • M McBeath
    @thomas-braun said in Enocean 0.9.0 Geräte hinzufügen geht nicht mehr:
    sudo apt-key add raspberrypi.gpg.key
    admin@raspberrypi:~ $ sudo apt-key add raspberrypi.gpg.key
    Warning: apt-key is deprecated. Manage keyring files in trusted.gpg.d instead (see apt-key(8)).
    OK
    curl https://raw.githubusercontent.com/Grothesk242/ioBroker/master/node_update.sh > iob_node_update
    admin@raspberrypi:~ $ curl https://raw.githubusercontent.com/Grothesk242/ioBroker/master/node_update.sh > iob_node_update
      % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                     Dload  Upload   Total   Spent    Left  Speed
    100 16575  100 16575    0     0  43892      0 --:--:-- --:--:-- --:--:-- 43965
    chmod 744 iob_node_update
    admin@raspberrypi:~ $ chmod 744 iob_node_update
    ./iob_node_update
    ioBroker nodejs fixer 2023-10-24
    Recommended nodejs-version is: 18.18.2
    Checking your installation now. Please be patient!
    Your current setup is:
    /usr/bin/nodejs 	v18.13.0
    /usr/bin/node 		v18.13.0
    /usr/bin/npm 		9.2.0
    /usr/bin/npx 		9.2.0
    We found these nodejs versions available for installation:
    nodejs:
      Installed: 18.13.0+dfsg1-1+rpi1
      Candidate: 18.18.2-1nodesource1
      Version table:
         18.18.2-1nodesource1 1001
            500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
         18.18.1-1nodesource1 1001
         18.18.0-1nodesource1 1001
         18.17.1-1nodesource1 1001
         18.17.0-1nodesource1 1001
         18.16.1-1nodesource1 1001
         18.16.0-1nodesource1 1001
         18.15.0-1nodesource1 1001
         18.14.2-1nodesource1 1001
         18.14.1-1nodesource1 1001
         18.14.0-1nodesource1 1001
     *** 18.13.0+dfsg1-1+rpi1 500
            500 http://raspbian.raspberrypi.com/raspbian bookworm/main armhf Packages
         18.13.0-1nodesource1 1001
         18.12.0-1nodesource1 1001
         18.11.0-1nodesource1 1001
         18.10.0-1nodesource1 1001
         18.9.1-1nodesource1 1001
         18.9.0-1nodesource1 1001
         18.8.0-1nodesource1 1001
         18.7.0-1nodesource1 1001
         18.6.0-1nodesource1 1001
         18.5.0-1nodesource1 1001
         18.4.0-1nodesource1 1001
         18.3.0-1nodesource1 1001
         18.2.0-1nodesource1 1001
         18.1.0-1nodesource1 1001
         18.0.0-1nodesource1 1001
    Nothing to do - Your installation is using the correct paths.
    You are running nodejs v18.13.0. Do you want to install recommended version 18.18.2?
    Press <y> to continue or any other key to quit
    Trying to fix your installation now. Please be patient.
    find: '/run/user/1000/doc': Permission denied
    find: '/run/user/1000/gvfs': Permission denied
    Waiting for ioBroker to shut down - Give me a minute...
    *** Removing previous installations of nodejs
    (Reading database ... 167629 files and directories currently installed.)
    Removing npm (9.2.0~ds1-1) ...
    Removing node-css-loader (6.7.2+~cs14.0.11-1) ...
    Removing webpack (5.75.0+dfsg+~cs17.16.14-1+deb12u1) ...
    Removing eslint (6.4.0~dfsg+~6.1.9-7) ...
    Removing node-tap (16.3.2+ds1+~cs50.8.16-1) ...
    Removing node-webassemblyjs (1.11.4+dfsg+~cs10.11.17-2) ...
    Removing node-gyp (9.3.0-2) ...
    Removing libnode-dev (18.13.0+dfsg1-1+rpi1) ...
    Removing node-cacache (17.0.3+~cs10.3.7-1) ...
    Removing node-unique-filename (1.1.1+ds-2) ...
    Removing terser (5.16.5-2) ...
    Removing node-jest-worker (29.3.1~ds1+~cs70.48.25-2) ...
    Removing node-jest-debbundle (29.3.1~ds1+~cs70.48.25-2) ...
    Removing node-babel-plugin-lodash (3.3.4+~cs2.0.1-6) ...
    Removing node-ws (8.11.0+~cs13.7.3-1) ...
    Removing node-espree (9.4.1~dfsg-1) ...
    Removing node-https-proxy-agent (5.0.1+~cs8.0.0-3) ...
    Removing node-agent-base (6.0.2+~cs5.4.2-2) ...
    Removing node-schema-utils (3.1.1~ds-2) ...
    Removing node-ajv-keywords (3.5.2-2) ...
    Removing node-ajv (6.12.6-3) ...
    Removing node-terser (5.16.5-2) ...
    Removing node-ansi-escapes (5.0.0+really.4.3.1-1) ...
    Removing node-tap-mocha-reporter (5.0.3+~2.0.2-2) ...
    Removing node-npmlog (7.0.1+~4.1.4-1) ...
    Removing node-gauge (4.0.4-1) ...
    Removing node-widest-line (3.1.0-2) ...
    Removing node-wide-align (1.1.3-4) ...
    Removing node-cli-truncate (2.1.0-5) ...
    Removing node-watchpack (2.4.0+~cs2.8.1-1) ...
    Removing node-chokidar (3.5.3-2) ...
    Removing node-readdirp (3.6.0-1) ...
    Removing node-move-concurrently (1.0.1-5) ...
    Removing node-copy-concurrently (1.0.5-9) ...
    Removing node-run-queue (2.0.0-3) ...
    Removing node-aproba (2.0.0-3) ...
    Removing node-are-we-there-yet (3.0.1+~1.1.0-1) ...
    Removing node-coveralls (3.1.1-2) ...
    Removing node-async-each (1.0.3-3) ...
    Removing node-auto-bind (4.0.0-2) ...
    Removing node-file-entry-cache (6.0.0+~3.0.4+~2.0.0+~1.0.0+~2.0.1-5) ...
    Removing node-flat-cache (3.0.4~6.0.0+~3.0.4+~2.0.0+~1.0.0+~2.0.1-5) ...
    Removing node-base (3.0.0-3) ...
    Removing node-base64-js (1.5.1+dfsg+~1.3.0-2) ...
    Removing node-is-binary-path (2.1.0-5) ...
    Removing node-binary-extensions (2.2.0-2) ...
    Removing node-npm-package-arg (10.0.0+~3.0.0-2) ...
    Removing node-validate-npm-package-name (5.0.0+~4.0.0-1) ...
    Removing node-builtins (5.0.1-1) ...
    Removing node-cache-base (4.0.2-1) ...
    Removing node-tar (6.1.13+~cs7.0.5-1) ...
    Removing node-chownr (2.0.0-2) ...
    Removing node-chrome-trace-event (1.0.3-2) ...
    Removing node-ci-info (3.6.1+~cs1.1.0-1) ...
    Removing node-cli-boxes (2.2.1-2) ...
    Removing node-cli-cursor (4.0.0-3) ...
    Removing node-cli-table (0.3.11+~cs0.13.4-3) ...
    Removing node-columnify (1.6.0+~1.5.1-1) ...
    Removing node-collection-visit (1.0.0-4) ...
    Removing node-colors (1.4.0-4) ...
    Removing node-concat-stream (2.0.0+~2.0.0-2) ...
    Removing node-console-control-strings (1.1.0-3) ...
    Removing node-enhanced-resolve (5.10.0-1) ...
    Removing node-memory-fs (0.5.0+~0.3.3-2) ...
    Removing node-css-selector-tokenizer (0.8.0+~cs4.8.3-1) ...
    Removing node-fetch (3.3.0+~cs11.4.11-2) ...
    Removing node-data-uri-to-buffer (4.0.0-3) ...
    Removing node-got (11.8.5+~cs58.13.36-3) ...
    Removing node-decompress-response (6.0.0-2) ...
    Removing node-define-property (2.0.2+really+2.0.2-3) ...
    Removing node-delegates (1.0.0-3) ...
    Removing node-depd (2.0.0-2) ...
    Removing node-diff (5.0.0~dfsg+~5.0.1-4) ...
    Removing node-doctrine (3.0.0-4) ...
    Removing node-tap-parser (11.0.2+~cs2.1.4-1) ...
    Removing node-ssri (9.0.1-2) ...
    Removing node-minipass (3.3.6+~cs9.4.19-1) ...
    Removing node-encoding (0.1.13-2) ...
    Removing node-get-stream (6.0.1-1) ...
    Removing node-pump (3.0.0-5) ...
    Removing node-end-of-stream (1.4.4+~1.4.1-1) ...
    Removing node-promise-retry (2.0.1-4) ...
    Removing node-err-code (2.0.3+dfsg-3) ...
    Removing node-errno (1.0.0-3) ...
    Removing node-es-module-lexer (1.1.0+dfsg-2) ...
    Removing node-stack-utils (2.0.6+~2.0.1-1) ...
    Removing node-eslint-scope (7.1.1+~3.7.4-1) ...
    Removing node-eslint-utils (3.0.0-3) ...
    Removing node-eslint-visitor-keys (3.3.0+~1.0.0-1) ...
    Removing node-esquery (1.4.2~ds-1) ...
    Removing node-esrecurse (4.3.0-2) ...
    Removing node-events (3.3.0+~3.0.0-3) ...
    Removing node-fancy-log (1.3.3+~cs1.3.1-2) ...
    Removing node-fast-deep-equal (3.1.3-3) ...
    Removing node-flatted (3.2.7~ds-1) ...
    Removing node-mixin-deep (2.0.1-3) ...
    Removing node-fs-write-stream-atomic (1.0.10-6) ...
    Removing node-rechoir (0.8.0+~0.6.1-2) ...
    Removing node-npm-bundled (2.0.1-2) ...
    Removing node-read-package-json (5.0.2+~2.0.0-1) ...
    Removing node-functional-red-black-tree (1.0.1+20181105-7) ...
    Removing node-union-value (2.0.1-4) ...
    Removing node-unset-value (2.0.1-1) ...
    Removing node-has-value (2.0.2-4) ...
    Removing node-get-value (1:3.0.1-4) ...
    Removing node-growl (1.10.5-4) ...
    Removing node-has-unicode (2.0.1-5) ...
    Removing node-has-values (2.0.1-4) ...
    Removing node-iconv-lite (0.6.3-3) ...
    Removing node-postcss-modules-values (4.0.0+~4.0.0-1) ...
    Removing node-icss-utils (5.1.0+~5.1.0-1) ...
    Removing node-ieee754 (1.2.1-3) ...
    Removing node-iferr (1.0.2+~1.0.2-1) ...
    Removing node-ini (3.0.1-2) ...
    Removing node-interpret (2.2.0-3) ...
    Removing node-ip (2.0.0+~1.1.0-1) ...
    Removing node-ip-regex (4.3.0+~4.1.1-1) ...
    Removing node-is-descriptor (3.0.0-2) ...
    Removing node-set-value (4.1.0+~4.0.1-2) ...
    Removing node-is-primitive (3.0.1-3) ...
    Removing node-postcss-modules-extract-imports (3.0.0-2) ...
    Removing node-postcss (8.4.20+~cs8.0.23-1) ...
    Removing node-map-visit (1.0.0-4) ...
    Removing node-object-visit (1.0.1-5) ...
    Removing node-isobject (4.0.0-2) ...
    Removing node-json-buffer (3.0.1+~3.0.0-1) ...
    Removing node-json-schema (0.4.0+~7.0.11-1) ...
    Removing node-json-schema-traverse (1.0.0-3) ...
    Removing node-json-stable-stringify (1.0.2+~cs5.2.34-1) ...
    Removing node-shell-quote (1.7.4+~1.7.1-1) ...
    Removing node-jsonify (0.0.1-1) ...
    Removing node-jsonparse (1.3.1-10) ...
    Removing node-lcov-parse (1.0.0+20170612git80d039574ed9-6) ...
    Removing node-loader-runner (4.3.0-1) ...
    Removing node-log-driver (1.2.7+git+20180219+bba1761737-7) ...
    Removing node-lowercase-keys (2.0.0-2) ...
    Removing node-memfs (3.4.12+~cs1.0.3-1) ...
    Removing node-merge-stream (2.0.0+~1.1.2-2) ...
    Removing node-mime-types (2.1.35-1) ...
    Removing node-mime (3.0.0+dfsg+~cs3.97.1-1) ...
    Removing node-mimic-response (3.1.0-8) ...
    Removing node-promzard (0.3.0-2) ...
    Removing node-read (1.0.7-5) ...
    Removing node-mute-stream (0.0.8+~0.0.1-3) ...
    Removing node-negotiator (0.6.3+~0.6.1-1) ...
    Removing node-restore-cursor (4.0.0-2) ...
    Removing node-opener (1.5.2+~1.4.0-1) ...
    Removing node-osenv (0.1.5+~0.1.1-1) ...
    Removing node-p-cancelable (2.1.1-1) ...
    Removing node-pascalcase (1.0.0-1) ...
    Removing node-path-is-absolute (2.0.0-2) ...
    Removing node-postcss-value-parser (4.2.0-1) ...
    Removing node-progress (2.0.3-2) ...
    Removing node-promise-inflight (1.0.1+~1.0.0-1) ...
    Removing node-prr (1.0.1-3) ...
    Removing node-uri-js (4.4.0+dfsg-8) ...
    Removing node-punycode (2.1.1-6) ...
    Removing node-serialize-javascript (6.0.0-2) ...
    Removing node-randombytes (2.1.0+~2.0.0-2) ...
    Removing node-regexpp (3.2.0-4) ...
    Removing node-resolve-cwd (3.0.0-2) ...
    Removing node-retry (0.13.1+~0.12.1-1) ...
    Removing node-sellside-emitter (1.2.1-3) ...
    Removing node-set-blocking (2.0.0-2) ...
    Removing node-set-immediate-shim (2.0.0-2) ...
    Removing node-webpack-sources (3.2.3+~3.2.0-2) ...
    Removing node-source-list-map (2.0.1+dfsg-2) ...
    Removing node-strip-json-comments (4.0.0-4) ...
    Removing node-tapable (2.2.1-2) ...
    Removing node-text-table (0.2.0-4) ...
    Removing node-time-stamp (2.2.0-2) ...
    Removing node-tslib (2.4.1-1) ...
    Removing node-typedarray (0.0.7-1) ...
    Removing node-v8-compile-cache (2.3.0-3) ...
    Removing node-write (2.0.0~6.0.0+~3.0.4+~2.0.0+~1.0.0+~2.0.1-5) ...
    Removing node-yaml (2.1.3-2) ...
    Removing node-define-properties (1.1.4+~1.1.3-1) ...
    Removing node-es-abstract (1.20.4+~cs26.27.47-1) ...
    Removing node-deep-equal (2.1.0+~cs31.12.80-1) ...
    Removing node-tape (5.6.1+~cs8.20.19-1) ...
    Removing node-istanbul (0.4.5+repack10+~cs97.25.57-3) ...
    Removing node-read-pkg (5.2.0-2) ...
    Removing handlebars (3:4.7.7+~4.1.0-1) ...
    Removing node-nopt (5.0.0-4) ...
    Removing node-abbrev (1.1.1+~1.1.2-1) ...
    Removing node-yargs (16.2.0+~16.0.4-7) ...
    Removing node-cliui (7.0.4+repack+~cs3.1.0-4) ...
    Removing node-wrap-ansi (8.0.1+~8.0.1-3) ...
    Removing node-string-width (4.2.3+~cs13.2.3-1) ...
    Removing node-slice-ansi (5.0.0+~cs9.0.0-5) ...
    Removing node-archy (1.0.0-6) ...
    Removing node-js-yaml (4.1.0+dfsg+~4.0.5-7) ...
    Removing node-argparse (2.0.1-2) ...
    Removing node-optimist (0.6.1+~0.0.30-2) ...
    Removing node-minimist (1.2.7+~cs5.3.2-2) ...
    Removing node-arrify (2.0.1-3) ...
    Removing node-async (0.8.0-6) ...
    Removing node-yargs-parser (21.1.1+~21.0.0-4) ...
    Removing node-camelcase (7.0.0-3) ...
    Removing node-wcwidth.js (1.0.2-2) ...
    Removing node-defaults (1.0.4+~1.0.3-1) ...
    Removing node-clone (2.1.2-4) ...
    Removing node-decamelize (4.0.0-2) ...
    Removing node-escodegen (2.0.0+dfsg+~0.0.7-2) ...
    Removing node-optionator (0.9.1+dfsg+~cs1.2.3-1) ...
    Removing node-deep-is (0.1.4-1) ...
    Removing node-defined (1.0.1+~1.0.0-1) ...
    Removing node-es6-error (4.1.1-5) ...
    Removing node-esprima (4.0.1+ds+~4.0.3-2) ...
    Removing node-estraverse (5.3.0+ds+~5.1.1-1) ...
    Removing node-fast-levenshtein (2.0.6+ds-3) ...
    Removing node-foreground-child (2.0.0-5) ...
    Removing node-normalize-package-data (4.0.1+~2.4.1-1) ...
    Removing node-get-caller-file (2.0.5+~cs1.1.1-4) ...
    Removing node-hosted-git-info (6.1.1-2) ...
    Removing node-write-file-atomic (4.0.2+~4.0.0-1) ...
    Removing node-imurmurhash (0.1.4+dfsg+~0.1.1-2) ...
    Removing node-is-plain-obj (3.0.0-2) ...
    Removing node-is-stream (3.0.0-4) ...
    Removing node-typedarray-to-buffer (4.0.0-2) ...
    Removing node-is-typedarray (1.0.0-4) ...
    Removing node-is-windows (1.0.2+~cs1.0.0-1) ...
    Removing node-which (2.0.2+~cs1.3.2-3) ...
    Removing node-isexe (2.0.0+~2.0.1-5) ...
    Removing node-levn (0.4.1+dfsg-2) ...
    Removing node-mkdirp (1.0.4+~1.0.2-4) ...
    Removing node-neo-async (2.6.2+~cs3.0.0-2) ...
    Removing node-npm-run-path (5.1.0+~4.0.0-8) ...
    Removing node-object-inspect (1.12.2+~cs1.8.1-1) ...
    Removing node-type-check (0.4.0+dfsg-3) ...
    Removing node-prelude-ls (1.2.1+dfsg-3) ...
    Removing node-require-directory (2.1.1+~2.1.2-1) ...
    Removing node-resolve-from (5.0.0+~3.1.0+~3.3.0+~2.0.0-1) ...
    Removing node-resumer (0.0.0-6) ...
    Removing node-shebang-command (2.0.0-1) ...
    Removing node-shebang-regex (3.0.0-2) ...
    Removing node-signal-exit (3.0.7+~3.0.1-1) ...
    Removing node-validate-npm-package-license (3.0.4-2) ...
    Removing node-spdx-correct (3.1.1-2) ...
    Removing node-spdx-expression-parse (3.0.1+~3.0.1-1) ...
    Removing node-spdx-exceptions (2.3.0-2) ...
    Removing node-spdx-license-ids (3.0.12-1) ...
    Removing node-sprintf-js (1.1.2+ds1+~1.1.2-1) ...
    Removing node-strip-bom (4.0.0-2) ...
    Removing node-through (2.3.8+~cs0.0.30-1) ...
    Removing node-uuid (8.3.2+~8.3.3-3) ...
    Removing node-wordwrap (1.0.0-4) ...
    Removing node-y18n (5.0.8+~5.0.0-3) ...
    Removing node-parse-json (5.2.0+~cs5.1.7-1) ...
    Removing node-assert (2.0.0+~cs3.9.8-2) ...
    Removing node-util (0.12.5+~1.0.10-1) ...
    Removing libjs-util (0.12.5+~1.0.10-1) ...
    Removing node-debbundle-es-to-primitive (1.2.1+~cs9.7.25-2) ...
    Removing node-babel7 (7.20.15+ds1+~cs214.269.168-3) ...
    Removing node-find-cache-dir (3.3.2+~3.2.1-1) ...
    Removing node-del (7.0.0-5) ...
    Removing node-globby (13.1.3+~cs16.25.40-1) ...
    Removing node-micromatch (4.0.5+~4.0.2-1) ...
    Removing node-braces (3.0.2+~3.0.1-1) ...
    Removing node-fill-range (7.0.1+~7.0.0-1) ...
    Removing node-to-regex-range (5.0.1-4) ...
    Removing node-ampproject-remapping (2.2.0+~cs5.15.37-1) ...
    Removing node-strip-ansi (6.0.1-2) ...
    Removing node-ansi-regex (5.0.1-1) ...
    Removing node-chalk (5.2.0-1) ...
    Removing node-ansi-styles (6.2.1-2) ...
    Removing node-anymatch (3.1.3+~cs4.6.1-2) ...
    Removing node-babel-plugin-polyfill-regenerator (0.4.1~0~20220913+ds1-1) ...
    Removing node-babel-plugin-polyfill-corejs3 (0.6.0~0~20220913+ds1-1) ...
    Removing node-babel-plugin-add-module-exports (1.0.4+dfsg1~cs5.8.0-4) ...
    Removing node-regenerator-transform (0.15.1+~0.10.8-1) ...
    Removing node-babel7-runtime (7.20.15+ds1+~cs214.269.168-3) ...
    Removing node-rimraf (3.0.2-2) ...
    Removing node-glob (8.0.3+~cs8.4.15-1) ...
    Removing node-minimatch (5.1.1+~5.1.2-1) ...
    Removing node-brace-expansion (2.0.1-2) ...
    Removing node-balanced-match (2.0.0-1) ...
    Removing node-core-js-compat (3.26.1-3) ...
    Removing node-browserslist (4.21.4+~cs6.1.17-2) ...
    Removing node-caniuse-lite (1.0.30001436+dfsg+~1.0.1-1) ...
    Removing node-clone-deep (4.0.1+~cs7.0.2-1) ...
    Removing node-color-convert (2.0.1+~cs2.0.0-2) ...
    Removing node-color-name (1.1.4+~1.1.1-2) ...
    Removing node-commander (9.4.1-1) ...
    Removing node-commondir (1.0.1+~1.0.0-1) ...
    Removing node-convert-source-map (1.9.0+~1.5.2-1) ...
    Removing node-core-js (3.26.1-3) ...
    Removing node-core-js-pure (3.26.1-3) ...
    Removing node-n3 (1.16.3+~1.2.3+~1.10.4-1) ...
    Removing node-readable-stream (3.6.0+~cs3.0.0-4) ...
    Removing node-core-util-is (1.0.3-1) ...
    Removing node-electron-to-chromium (1.4.284-1) ...
    Removing node-error-ex (1.3.2-4) ...
    Removing node-p-map (4.0.0+~3.1.0+~3.0.1-1) ...
    Removing node-escape-string-regexp (4.0.0-2) ...
    Removing node-esutils (2.0.3+~2.0.0-1) ...
    Removing node-pkg-dir (5.0.0-2) ...
    Removing node-find-up (6.3.0-7) ...
    Removing node-for-own (1.0.0-3) ...
    Removing node-for-in (1.0.2-4) ...
    Removing node-fs-readdir-recursive (1.1.0+~1.1.0-1) ...
    Removing node-fs.realpath (1.0.0-3) ...
    Removing node-glob-parent (6.0.2+~5.1.1-2) ...
    Removing node-globals (13.18.0-1) ...
    Removing node-graceful-fs (4.2.10-1) ...
    Removing node-supports-color (8.1.1+~8.1.1-1) ...
    Removing node-has-flag (4.0.0-3) ...
    Removing node-ignore (5.2.1-1) ...
    Removing node-indent-string (4.0.0-2) ...
    Removing node-inflight (1.0.6-2) ...
    Removing node-inherits (2.0.4-6) ...
    Removing node-is-arrayish (0.3.2-3) ...
    Removing node-is-number (7.0.0-4) ...
    Removing node-kind-of (6.0.3+dfsg-2) ...
    Removing node-is-buffer (2.0.5-2) ...
    Removing node-is-extendable (1.0.1-3) ...
    Removing node-is-glob (4.0.3-2) ...
    Removing node-is-extglob (2.1.1-5) ...
    Removing node-is-path-cwd (2.2.0-2) ...
    Removing node-is-path-inside (3.0.3-2) ...
    Removing node-is-plain-object (5.0.0-7) ...
    Removing node-isarray (2.0.5-4) ...
    Removing node-js-tokens (8.0.0-2) ...
    Removing node-regexpu-core (5.2.2-3) ...
    Removing node-regjsparser (0.9.1+ds-2) ...
    Removing node-jsesc (3.0.2+~3.0.1-1) ...
    Removing node-json-parse-better-errors (1.0.2+~cs3.3.1-2) ...
    Removing node-json5 (2.2.3+dfsg-1) ...
    Removing node-locate-path (7.1.1-2) ...
    Removing node-lodash (4.17.21+dfsg+~cs8.31.198.20210220-9) ...
    Removing node-make-dir (3.1.0-3) ...
    Removing node-normalize-path (3.0.0+~3.0.0-1) ...
    Removing node-object-assign (4.1.1-7) ...
    Removing node-once (1.4.0-7) ...
    Removing node-p-locate (6.0.0-12) ...
    Removing node-p-limit (4.0.0+~cs4.0.0-5) ...
    Removing node-path-dirname (1.0.2-2) ...
    Removing node-path-exists (5.0.0-8) ...
    Removing node-path-is-inside (1.0.2+~1.0.0-1) ...
    Removing node-path-type (4.0.0-3) ...
    Removing node-picocolors (1.0.0-4) ...
    Removing node-pify (5.0.0+~cs5.0.1-1) ...
    Removing node-process-nextick-args (2.0.1-3) ...
    Removing node-quick-lru (6.1.1-4) ...
    Removing node-regenerate-unicode-properties (10.1.0+ds-1) ...
    Removing node-regenerate (1.4.2-3) ...
    Removing node-regenerator-runtime (0.15.1+~0.10.8-1) ...
    Removing node-regjsgen (0.7.1+ds-1) ...
    Removing node-repeat-string (1.6.1+repack-1) ...
    Removing node-string-decoder (1.3.0-6) ...
    Removing node-safe-buffer (5.2.1+~cs2.1.2-3) ...
    Removing node-slash (4.0.0-3) ...
    Removing node-source-map-support (0.5.21+ds+~0.5.4-1) ...
    Removing node-source-map (0.7.0++dfsg2+really.0.6.1-15) ...
    Removing node-to-fast-properties (3.0.1-3) ...
    Removing node-unicode-match-property-ecmascript (2.0.0-2) ...
    Removing node-unicode-canonical-property-names-ecmascript (2.0.0-2) ...
    Removing node-unicode-match-property-value-ecmascript (2.1.0+ds-1) ...
    Removing node-unicode-property-aliases-ecmascript (2.1.0+ds-1) ...
    Removing node-util-deprecate (1.0.2-3) ...
    Removing node-v8flags (3.2.0+~3.1.1-1) ...
    Removing node-wrappy (1.0.2-3) ...
    Removing node-babel-plugin-polyfill-corejs2 (0.3.3~0~20220913+ds1-1) ...
    Removing node-babel-helper-define-polyfill-provider (0.3.3~0~20220913+ds1-1) ...
    Removing node-debug (4.3.4+~cs4.1.7-1) ...
    Removing node-resolve (1.22.1+~cs5.31.10-1) ...
    Removing node-function-bind (1.1.1+repacked+~1.0.3-2) ...
    Removing node-lodash-packages (4.17.21+dfsg+~cs8.31.198.20210220-9) ...
    Removing node-semver (7.3.5+~7.3.9-2) ...
    Removing node-lru-cache (7.14.1-1) ...
    Removing node-ms (2.1.3+~cs0.7.31-3) ...
    Removing node-yallist (4.0.0+~4.0.1-1) ...
    Removing nodejs (18.13.0+dfsg1-1+rpi1) ...
    Removing libnode108:armhf (18.13.0+dfsg1-1+rpi1) ...
    Removing node-acorn (8.8.1+ds+~cs25.17.7-2) ...
    Removing node-undici (5.15.0+dfsg1+~cs20.10.9.3-1+deb12u1) ...
    Removing node-busboy (1.6.0+~cs2.6.0-2) ...
    Removing node-cjs-module-lexer (1.2.2+dfsg-5) ...
    Removing node-xtend (4.0.2-3) ...
    Processing triggers for man-db (2.11.2-2) ...
    Processing triggers for libc-bin (2.36-9+rpt2+deb12u3) ...
    (Reading database ... 138896 files and directories currently installed.)
    Purging configuration files for npm (9.2.0~ds1-1) ...
    Purging configuration files for node-mime (3.0.0+dfsg+~cs3.97.1-1) ...
    Purging configuration files for node-sprintf-js (1.1.2+ds1+~1.1.2-1) ...
    Purging configuration files for node-source-map (0.7.0++dfsg2+really.0.6.1-15) ...
    Purging configuration files for node-esprima (4.0.1+ds+~4.0.3-2) ...
    *** These repos are active on your system:
    Hit:1 http://raspbian.raspberrypi.com/raspbian bookworm InRelease
    Hit:2 http://archive.raspberrypi.com/debian bookworm InRelease
    Err:1 http://raspbian.raspberrypi.com/raspbian bookworm InRelease
      The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 9165938D90FDDD2E
    Reading package lists... Done
    W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: http://raspbian.raspberrypi.com/raspbian bookworm InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 9165938D90FDDD2E
    W: Failed to fetch http://raspbian.raspberrypi.com/raspbian/dists/bookworm/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 9165938D90FDDD2E
    W: Some index files failed to download. They have been ignored, or old ones used instead.
    *** Installing ca-certificates, curl and gnupg, just in case they are missing.
    *** Creating new /etc/apt/sources.list.d/nodesource.list and pinning source
    deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_18.x nodistro main
    Package: nodejs
    Pin: origin deb.nodesource.com
    Pin-Priority: 1001
    *** These repos are active after the adjustments:
    Hit:3 https://deb.nodesource.com/node_18.x nodistro InRelease
    Installing the recommended nodejs version now!
    Installing the recommended nodejs version!
    Removing nodejs-doc (18.13.0+dfsg1-1+rpi1) ...
    Selecting previously unselected package nodejs.
    (Reading database ... 138692 files and directories currently installed.)
    Preparing to unpack .../nodejs_18.18.2-1nodesource1_armhf.deb ...
    Unpacking nodejs (18.18.2-1nodesource1) ...
    Preparing to unpack .../archives/piwiz_0.65_armhf.deb ...
    Unpacking piwiz (0.65) over (0.64) ...
    Setting up nodejs (18.18.2-1nodesource1) ...
    Setting up piwiz (0.65) ...
    We tried our best to fix your nodejs. Please run iob diag again to verify.
    *** RESTARTING ioBroker NOW! ***
     Please refresh or restart your browser in a few moments.
    Sieht soweit doch gut aus, oder? 😊
    admin@raspberrypi:~ $ nodejs -v
    v18.18.2
    admin@raspberrypi:~ $ node -v
    v18.18.2
    admin@raspberrypi:~ $ npm -v
    9.8.1
    @mcbeath
    Ja, schaut besser aus. Bitte nochmal
    sudo apt update
      @mcbeath
      sudo apt update
      McBeath
      sudo apt update
      admin@raspberrypi:~ $ sudo apt update
      OK:1 https://deb.nodesource.com/node_18.x nodistro InRelease
      OK:2 http://archive.raspberrypi.com/debian bookworm InRelease
      OK:3 http://raspbian.raspberrypi.com/raspbian bookworm InRelease
      Fehl:3 http://raspbian.raspberrypi.com/raspbian bookworm InRelease
        Die folgenden Signaturen konnten nicht überprüft werden, weil ihr öffentlicher Schlüssel nicht verfügbar ist: NO_PUBKEY 9165938D90FDDD2E
      Abhängigkeitsbaum wird aufgebaut... Fertig
      Statusinformationen werden eingelesen... Fertig
      Alle Pakete sind aktuell.
      W: Während der Überprüfung der Signatur trat ein Fehler auf. Das Depot wurde nicht aktualisiert und die vorherigen Indexdateien werden verwendet. GPG-Fehler: http://raspbian.raspberrypi.com/raspbian bookworm InRelease: Die folgenden Signaturen konnten nicht überprüft werden, weil ihr öffentlicher Schlüssel nicht verfügbar ist: NO_PUBKEY 9165938D90FDDD2E
      W: Fehlschlag beim Holen von http://raspbian.raspberrypi.com/raspbian/dists/bookworm/InRelease Die folgenden Signaturen konnten nicht überprüft werden, weil ihr öffentlicher Schlüssel nicht verfügbar ist: NO_PUBKEY 9165938D90FDDD2E
      W: Einige Indexdateien konnten nicht heruntergeladen werden. Sie wurden ignoriert oder alte an ihrer Stelle benutzt.
      • M McBeath
        sudo apt update
        @mcbeath sagte in Enocean 0.9.0 Geräte hinzufügen geht nicht mehr:
        sudo apt-key adv --keyserver keyserver.ubuntu.com --recv-keys 9165938D90FDDD2E
        sudo apt update
          sudo apt update
          McBeath
          admin@raspberrypi:~ $ sudo apt-key adv --keyserver keyserver.ubuntu.com --recv-keys 9165938D90FDDD2E
          Executing: /tmp/apt-key-gpghome.4buJsFmM0I/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys 9165938D90FDDD2E
          gpg: Schlüssel 9165938D90FDDD2E: Öffentlicher Schlüssel "Mike Thompson (Raspberry Pi Debian armhf ARMv6+VFP) <mpthompson@gmail.com>" importiert
          gpg: Anzahl insgesamt bearbeiteter Schlüssel: 1
          gpg:                              importiert: 1
          OK:2 http://raspbian.raspberrypi.com/raspbian bookworm InRelease
          OK:3 http://archive.raspberrypi.com/debian bookworm InRelease
          W: http://raspbian.raspberrypi.com/raspbian/dists/bookworm/InRelease: Schlüssel ist im veralteten Schlüsselbund trusted.gpg gespeichert (/etc/apt/trusted.gpg), siehe den Abschnitt MISSBILLIGUNG in apt-key(8) für Details.
          • M McBeath
            gpg:                              importiert: 1
            @mcbeath
            sudo mv /etc/apt/trusted.gpg /etc/apt/trusted.gpg.d/
              @mcbeath
              McBeath
              admin@raspberrypi:~ $ sudo mv /etc/apt/trusted.gpg /etc/apt/trusted.gpg.d/
              hab der sache schon mal vorgefriffen ;)
              • M McBeath
                @mcbeath Dann schau dir jetzt nochmal 'das große Ganze' an per
                iob diag
                an.
                Und dann schau mal was enocean nun sagt. Falls der immer noch herumspinnen sollte mach am besten nochmal einen eigenen Thread dazu auf.
                  iob diag
                  an.
                  McBeath
                  Copy text starting here:
                  			v.2023-10-10
                   Static hostname: raspberrypi
                         Icon name: computer
                  Operating System: Raspbian GNU/Linux 12 (bookworm)
                            Kernel: Linux 6.1.0-rpi4-rpi-v8
                      Architecture: arm64
                  Installation: 		native
                  Kernel: 		aarch64
                  Userland: 		armhf
                  Timezone: 		Europe/Berlin (CET, +0100)
                  User-ID: 		1000
                  X-Server: 		false
                  Boot Target: 		graphical.target
                  Pending OS-Updates: 	0
                  Pending iob updates: 	0
                  Nodejs-Installation: 	/usr/bin/nodejs 	v18.18.2
                  			/usr/bin/node 		v18.18.2
                  			/usr/bin/npm 		9.8.1
                  			/usr/bin/npx 		9.8.1
                  			/usr/bin/corepack 	0.19.0
                  Recommended versions are nodejs 18.18.2 and npm 9.8.1
                  MEMORY:
                  Mem:            4.0G        1.4G        1.3G        259M        1.6G        2.6G
                  Swap:           104M          0B        104M
                  Total:          4.1G        1.4G        1.4G
                  Active iob-Instances: 	5
                  Active repo(s): stable
                  ioBroker Core: 		js-controller 		5.0.14
                  			admin 			6.12.0
                  ioBroker Status: 	iobroker is running on this host.
                  Objects type: jsonl
                  States  type: jsonl
                  Objects: 		463
                  States: 		323
                  Size of iob-Database:
                  8.7M	/opt/iobroker/iobroker-data/objects.jsonl
                  1.3M	/opt/iobroker/iobroker-data/states.jsonl
                  === Mark text until here for copying ===
                  Für mich sieht das jetzt prima aus :)
                  • M McBeath
                    			v.2023-10-10
                           Icon name: computer
                        Architecture: arm64
                    Kernel: 		aarch64
                    Userland: 		armhf
                    User-ID: 		1000
                    X-Server: 		false
                    			/usr/bin/npm 		9.8.1
                    			/usr/bin/npx 		9.8.1
                    MEMORY:
                    Swap:           104M          0B        104M
                    			admin 			6.12.0
                    Objects type: jsonl
                    States  type: jsonl
                    Objects: 		463
                    States: 		323
                    @mcbeath
                    Das ist zwar nur das 'kleine Ganze', bis auf Marginalien schaut das aber jetzt befahrbar aus.
                      @mcbeath
                      McBeath
                      schrieb am zuletzt editiert von McBeath
                      Danke schon mal für deine Mühen an dieser stelle.
                      Leider werden wir wohl noch einen neuen Thread öffnen müssen,
                      es ist leider noch immer nicht möglich neue Geräte hinzuzufügen :(
                      Hier geht es weiter
