  3. Off Topic
  4. InfluxDB
  5. Influx DB unter bookworm installieren
    6.7k
Geplant Angeheftet Gesperrt Verschoben InfluxDB
33 Beiträge 4 Kommentatoren 6.6k Aufrufe 4 Beobachtet
    @nobbiman
    sudo rm /etc/apt/sources.list.d/influxdb.list
    sudo apt update
    apt policy influxdb*
    N Offline
    N Offline
    nobbiman
    @thomas-braun sagte in Influx DB unter bookworm installieren:
    pi@RasPi-ioBroker:~ $ sudo rm /etc/apt/sources.list.d/influxdb.list
    sudo apt update
    Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
    Hit:4 https://repos.influxdata.com/debian stable InRelease
    Hit:5 https://apt.grafana.com stable InRelease
    Hit:6 https://deb.nodesource.com/node_18.x nodistro InRelease
    Hit:7 http://archive.raspberrypi.com/debian bookworm InRelease
    Err:7 http://archive.raspberrypi.com/debian bookworm InRelease
      The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 82B129927FA3303E
    Reading package lists... Done
    All packages are up to date.
    W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: http://archive.raspberrypi.com/debian bookworm InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 82B129927FA3303E
    W: Failed to fetch http://archive.raspberrypi.com/debian/dists/bookworm/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 82B129927FA3303E
    W: Some index files failed to download. They have been ignored, or old ones used instead.
    N: Unable to locate package influxdb.key
    N: Couldn't find any package by glob 'influxdb.key'
    • N nobbiman
      sudo apt update
      @nobbiman
      rm influxdb.key
      sudo apt update
      N 1 Antwort Letzte Antwort
        @nobbiman
        rm influxdb.key
        sudo apt update
        N Offline
        N Offline
        nobbiman
        rm influxdb.key
        pi@RasPi-ioBroker:~ $ rm influxdb.key
        sudo apt update
        influxdb2-cli:
          Installed: (none)
          Candidate: 2.7.3-1
          Version table:
             2.7.3-1 500
                500 https://repos.influxdata.com/debian stable/main arm64 Packages
             2.7.1-2 500
             2.6.1 500
             2.6.0 500
             2.5.0 500
             2.4.0 500
             2.3.0 500
        influxdb-client:
          Installed: (none)
          Candidate: 1.6.7~rc0-1+b13
          Version table:
             1.6.7~rc0-1+b13 500
                500 http://deb.debian.org/debian bookworm/main arm64 Packages
        influxdb-dev:
          Installed: (none)
          Candidate: (none)
          Version table:
        influxdb2-client:
          Installed: (none)
          Candidate: 2.7.1-1
          Version table:
             2.7.1-1 500
        influxdb:
          Installed: (none)
          Candidate: 1.8.10-1
          Version table:
             1.8.10-1 500
             1.6.7~rc0-1+b13 500
        influxdb2:
          Installed: (none)
          Candidate: 2.7.3-1
          Version table:
             2.7.3-1 500
             2.7.1-1 500
             2.7.0-1 500
             2.6.1-1 500
             2.6.0-1 500
             2.5.1-1 500
             2.4.0-1 500
             2.3.0-1 500
             2.2.0 500
        • N nobbiman
          rm influxdb.key
          sudo apt update
          influxdb2-cli:
            Installed: (none)
            Candidate: 2.7.3-1
            Version table:
               2.7.3-1 500
               2.7.1-2 500
               2.6.1 500
               2.6.0 500
               2.5.0 500
               2.4.0 500
               2.3.0 500
          influxdb-client:
            Installed: (none)
            Version table:
               1.6.7~rc0-1+b13 500
          influxdb-dev:
            Installed: (none)
            Candidate: (none)
            Version table:
          influxdb2-client:
            Installed: (none)
            Candidate: 2.7.1-1
            Version table:
               2.7.1-1 500
          influxdb:
            Installed: (none)
            Candidate: 1.8.10-1
            Version table:
               1.8.10-1 500
               1.6.7~rc0-1+b13 500
          influxdb2:
            Installed: (none)
            Candidate: 2.7.3-1
            Version table:
               2.7.3-1 500
               2.7.1-1 500
               2.7.0-1 500
               2.6.1-1 500
               2.6.0-1 500
               2.5.1-1 500
               2.4.0-1 500
               2.3.0-1 500
               2.2.0 500
          @nobbiman
          Alles in der Auslage.
          Jetzt kannst du den Key für raspberry noch reinziehen.
            @nobbiman
            N Offline
            N Offline
            nobbiman
            schrieb am zuletzt editiert von nobbiman
            @thomas-braun Du sprichst in Rätseln, wahrscheinlich hast du schon bemerkt, dass ich kein Linux-Fan/-Freund/-Kenner bin. bitte sag mir, was ich zu tun habe, sprich den Key "reinziehen" kann
            • N nobbiman
              @nobbiman
              wget http://archive.raspberrypi.org/debian/raspberrypi.gpg.key
              sudo apt-key add raspberrypi.gpg.key
              rm raspberrypi.gpg.key
              Dann prüfen:
              sudo apt update
                @nobbiman
                Dann prüfen:
                sudo apt update
                N Offline
                N Offline
                nobbiman
                pi@RasPi-ioBroker:~ $ wget http://archive.raspberrypi.org/debian/raspberrypi.gpg.key
                --2023-10-31 14:32:52--  http://archive.raspberrypi.org/debian/raspberrypi.gpg.key
                Resolving archive.raspberrypi.org (archive.raspberrypi.org)... 46.235.231.151, 46.235.231.145, 93.93.130.212, ...
                Connecting to archive.raspberrypi.org (archive.raspberrypi.org)|46.235.231.151|:80... connected.
                HTTP request sent, awaiting response... 200 OK
                Length: 1719 (1.7K) [application/pgp-keys]
                Saving to: ‘raspberrypi.gpg.key’
                raspberrypi.gpg.key                                 100%[==================================================================================================================>]   1.68K  --.-KB/s    in 0.002s
                2023-10-31 14:32:52 (785 KB/s) - ‘raspberrypi.gpg.key’ saved [1719/1719]
                Warning: apt-key is deprecated. Manage keyring files in trusted.gpg.d instead (see apt-key(8)).
                OK
                pi@RasPi-ioBroker:~ $ sudo apt update
                Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
                Hit:5 https://repos.influxdata.com/debian stable InRelease
                Hit:6 https://apt.grafana.com stable InRelease
                Hit:7 https://deb.nodesource.com/node_18.x nodistro InRelease
                W: http://archive.raspberrypi.com/debian/dists/bookworm/InRelease: Key is stored in legacy trusted.gpg keyring (/etc/apt/trusted.gpg), see the DEPRECATION section in apt-key(8) for details.
                Wenn ich das mit meinem Geringwissen richtig interpretiere, sieht das gut aus, zumindest wurde offenbar der key für den raspberry gespeichert.
                Kann ich denn jetzt die erstgenannte influxdb-Installation erneut starten?
                Install lt. Hausautomation, s.o.
                • N nobbiman
                  OK
                  @nobbiman
                  sudo mv /etc/apt/trusted.gpg /etc/apt/trusted.gpg.d/
                  Dann halt die gewünschte Version von influxdb installieren. Ich würde die influxdb2 nehmen.
                    @nobbiman
                    N Offline
                    N Offline
                    nobbiman
                    Ich verneige mich vor dir und deiner Hilfsbereitschaft, wahrscheinlich hätte ich das ohne Hilfe nicht hinbekommen - sag mir, wo ich dir einen Kaffee spendieren kann!
                    Aber noch eines: weißt du, ob ich vor der Installation mit
                    sudo apt-get install influxdb2
                    noch einen Key installieren muss? Ich frage, weil unter einer YT-Anleitung, ab 8:43 davon gesprochen wird.
                    • N nobbiman
                      @nobbiman
                      Ich schau keine YT-Filmchen. Solltest du auch nicht, die wenigsten davon sind wirklich zu gebrauchen.
                      apt wird aber Meckern, wenn ein Key fehlen sollte. Es fehlt aber keiner, sonst hättest du da Meldungen analog zu der Meldung gesehen, die du jetzt ja angegangen bist.
                        @nobbiman
                        N Offline
                        N Offline
                        nobbiman
                        @thomas-braun Das sagt einer, der sich auskennt, dem Laien blieb eine intensive Einarbeitung in Linux, um ein Systemverständnis zu entwickeln. Eigentlich will ich nur mit dem später noch zu installierenden Grafan Daten aus dem ioBroker visualisieren. Das kostet mich genug Zeit.
                        Also, was ist mit dem Kaffee?
                        • N nobbiman
                          @nobbiman sagte in Influx DB unter bookworm installieren:
                          YT-Clips sind halt eine große Zeitverschwendung. In der Zeit, wir da noch ein tolles Intro läuft und die erste nervige Werbeunterbrechung mir auf den Zeiger geht hab ich da schon eine bessere und aktuellere Anleitung in Schriftform gefunden. Zuletzt mal eine (ungelogen!) 10 minütige längliche Anleitung mit allem nervigen Krams gesehen, in der eine Datei mittels Editor um zwei Einträge ergänzt wurde. Das ist in einem Wiki oder Forum maximal ein Zweizeiler.
                          Nicht erforderlich. Du kannst aber wenn du magst meiner Patentochter in Togo ein Taschengeld zukommen lassen.
                            N Offline
                            N Offline
                            nobbiman
                            @thomas-braun OK, dann gehe ich mal auf die Suche, wenn ich Grafana installieren werde.
                            Tolle Idee mit der Patentochter, wie bekomme ich das Taschengeld nach Togo?
                            • werner2000xW Offline
                              werner2000x
                              Ich habe auch das Problem mit influx unter bookworm und folgende Fehlerausgabe:
                              sudo apt update
                              Hit:1 http://raspbian.raspberrypi.com/raspbian bookworm InRelease
                              Hit:2 https://apt.grafana.com stable InRelease
                              Hit:3 http://archive.raspberrypi.com/debian bookworm InRelease
                              Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
                              Err:5 https://repos.influxdata.com/debian stable InRelease
                                The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
                              W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://repos.influxdata.com/debian stable InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
                              W: Failed to fetch https://repos.influxdata.com/debian/dists/stable/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
                              Raspi4 8 GB mit Aqara Zigbee USB, iob
                              Innogy Smarthome
                              Bosch Bridge 2
                              HUE Bridge
                              OpenWB Wallbox mit EVU Kit
                              Google Nest Pro Hub
                              HA auf uGreen dxp4800
                              • werner2000xW werner2000x
                                sudo apt update
                                @werner2000x
                                Richte das influxdb-Repo neu ein:
                                https://forum.iobroker.net/topic/59231/phantastische-repositories-und-wo-sie-zu-finden-sind
                                werner2000xW 1 Antwort Letzte Antwort
                                  @werner2000x
                                  werner2000x
                                  @thomas-braun Danke für den Link:
                                  Nun habe ich noch folgenden Fehler bei der Installation von influx:
                                   rm influxdata-archive_compat.key
                                  rm: cannot remove 'influxdata-archive_compat.key': No such file or directory
                                  pi@raspberrypi:~ $ wget -qO- https://repos.influxdata.com/influxdb.key | sudo apt-key add -
                                  Innogy Smarthome
                                  Bosch Bridge 2
                                  HUE Bridge
                                  Google Nest Pro Hub
                                    @werner2000x
                                    Und warum machst du es nicht wie es in meinem Link drin steht?
                                    Da ist es nämlich richtig, ohne apt-key.
                                      @werner2000x
                                      werner2000x
                                      @thomas-braun Ja, Danke.
                                      Ich bekomme mit dem Befehl:
                                      sudo service influxdb Status
                                      influxdb: unrecognized service
                                      und in Grafana:
                                      Post "http://139.168.198.39:8086/query?db=iobroker&epoch=ms": dial tcp 139.168.198.39:8086: i/o timeout error reading influxDB
                                      Innogy Smarthome
                                      Bosch Bridge 2
                                      HUE Bridge
                                      Google Nest Pro Hub
                                        und in Grafana:
                                        @werner2000x
                                        Das heißt ja auch auf modernen Systemen
                                        systemctl status influxdb.service
                                          @werner2000x
                                          werner2000x
                                          @thomas-braun Ja richtig, aber in grafana geht es nicht obwohl die instance ok meldet. Hier der status:
                                          Linux raspberrypi 6.6.47+rpt-rpi-v8 #1 SMP PREEMPT Debian 1:6.6.47-1+rpt1 (2024-09-02) aarch64
                                          permitted by applicable law.
                                          Last login: Tue Sep 17 20:40:37 2024 from 192.168.198.72
                                          pi@raspberrypi:~ $ systemctl status influxdb.service
                                          ● influxdb.service - InfluxDB is an open-source, distributed, time series database
                                               Loaded: loaded (/lib/systemd/system/influxdb.service; enabled; preset: enable>     Active: active (running) since Tue 2024-09-17 21:13:28 CEST; 36min ago
                                                 Docs: https://docs.influxdata.com/influxdb/
                                              Process: 16923 ExecStart=/usr/lib/influxdb/scripts/influxd-systemd-start.sh (c>   Main PID: 16924 (influxd)
                                                Tasks: 14 (limit: 4915)
                                                  CPU: 50.711s
                                               CGroup: /system.slice/influxdb.service
                                                       └─16924 /usr/bin/influxd -config /etc/influxdb/influxdb.conf
                                          Sep 17 21:49:32 raspberrypi influxd-systemd-start.sh[16924]: [httpd] 192.168.198.3>Sep 17 21:49:32 raspberrypi influxd-systemd-start.sh[16924]: [httpd] 192.168.198.3>Sep 17 21:49:32 raspberrypi influxd-systemd-start.sh[16924]: [httpd] 192.168.198.3>Sep 17 21:49:37 raspberrypi influxd-systemd-start.sh[16924]: [httpd] 192.168.198.3>Sep 17 21:49:42 raspberrypi influxd-systemd-start.sh[16924]: [httpd] 192.168.198.3>Sep 17 21:49:42 raspberrypi influxd-systemd-start.sh[16924]: [httpd] 192.168.198.3>Sep 17 21:49:42 raspberrypi influxd-systemd-start.sh[16924]: [httpd] 192.168.198.3>Sep 17 21:49:42 raspberrypi influxd-systemd-start.sh[16924]: [httpd] 192.168.198.3>Sep 17 21:49:42 raspberrypi influxd-systemd-start.sh[16924]: [httpd] 192.168.198.3>Sep 17 21:49:42 raspberrypi influxd-systemd-start.sh[16924]: [httpd] 192.168.198.3>...skipping...
                                                  CPU: 50.711s
                                               Loaded: loaded (/lib/systemd/system/influxdb.service; enabled; preset: enabled)        Active: active (running) since Tue 2024-09-17 21:13:28 CEST; 36min ago        Docs: https://docs.influxdata.com/influxdb/        Process: 16923 ExecStart=/usr/lib/influxdb/scripts/influxd-systemd-start.sh (code=exited, status=0/SUCCESS)                                                            Main PID: 16924 (influxd)
                                                  CPU: 50.711s
                                          Sep 17 21:49:32 raspberrypi influxd-systemd-start.sh[16924]: [httpd] 192.168.198.39 - iobroker [17/Sep/2024:21:49:31 +0200] "POST /write?database=iobroker&db=iobroker&>Sep 17 21:49:32 raspberrypi influxd-systemd-start.sh[16924]: [httpd] 192.168.198.39 - iobroker [17/Sep/2024:21:49:32 +0200] "POST /write?database=iobroker&db=iobroker&>Sep 17 21:49:32 raspberrypi influxd-systemd-start.sh[16924]: [httpd] 192.168.198.39 - iobroker [17/Sep/2024:21:49:32 +0200] "POST /write?database=iobroker&db=iobroker&>Sep 17 21:49:37 raspberrypi influxd-systemd-start.sh[16924]: [httpd] 192.168.198.39 - iobroker [17/Sep/2024:21:49:37 +0200] "POST /write?database=iobroker&db=iobroker&>Sep 17 21:49:42 raspberrypi influxd-systemd-start.sh[16924]: [httpd] 192.168.198.39 - iobroker [17/Sep/2024:21:49:42 +0200] "POST /write?database=iobroker&db=iobroker&>Sep 17 21:49:42 raspberrypi influxd-systemd-start.sh[16924]: [httpd] 192.168.198.39 - iobroker [17/Sep/2024:21:49:42 +0200] "POST /write?database=iobroker&db=iobroker&>Sep 17 21:49:42 raspberrypi influxd-systemd-start.sh[16924]: [httpd] 192.168.198.39 - iobroker [17/Sep/2024:21:49:42 +0200] "POST /write?database=iobroker&db=iobroker&>Sep 17 21:49:42 raspberrypi influxd-systemd-start.sh[16924]: [httpd] 192.168.198.39 - iobroker [17/Sep/2024:21:49:42 +0200] "POST /write?database=iobroker&db=iobroker&>Sep 17 21:49:42 raspberrypi influxd-systemd-start.sh[16924]: [httpd] 192.168.198.39 - iobroker [17/Sep/2024:21:49:42 +0200] "POST /write?database=iobroker&db=iobroker&>Sep 17 21:49:42 raspberrypi influxd-systemd-start.sh[16924]: [httpd] 192.168.198.39 - iobroker [17/Sep/2024:21:49:42 +0200] "POST /write?database=iobroker&db=iobroker&>~
                                          lines 1-21/21 (END)
                                          Innogy Smarthome
                                          Bosch Bridge 2
                                          HUE Bridge
                                          Google Nest Pro Hub
