  4. NodeRed kaput, alles im Haus steht
    5.8k
    1.5k
20 Beiträge 6 Kommentatoren 1.8k Aufrufe 5 Beobachtet
  • E Offline
    edstobi
    Hallo
    Mein NodeRed hat den Dienst versagt und nichts geht mehr. Es startet laut IObroker log kontinuierlich immer durch.
    node-red.0
    2023-10-28 23:44:51.098	info	Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    node-red.0
    2023-10-28 23:44:46.095	info	node-red exited with 6
    node-red.0
    [2023-10-28 23:44:45.661	error	28 Oct 23:44:45 - [error] [function:schreibe daten in flow] Error: Invalid property expression: unexpected ' ' at position 13]
    node-red.0
    2023-10-28 23:44:45.459	debug	28 Oct 23:44:45 - [info] [mqtt-broker:32723617.b884aa] Verbindung zum Broker mqtt://xxxx193:1883 aufgebaut
    node-red.0
    2023-10-28 23:44:45.438	debug	28 Oct 23:44:45 - [info] [mqtt-broker:1xxx160:1883] Verbindung zum Broker mqtt://xxx60:1883 aufgebaut
    node-red.0
    2023-10-28 23:44:45.426	debug	28 Oct 23:44:45 - [info] [tasmota-mqtt-broker:mqtt160] Connected to broker: mqtt://xxx160:1883
    node-red.0
    2023-10-28 23:44:44.743	warn	(node:28427) [DEP0128] DeprecationWarning: Invalid 'main' field in '/opt/iobroker/iobroker-data/node-red/node_modules/node-red-dashboard/package.json' of 'none'. Please either fix that or report it to the module author (Use `node --trace-deprecation ...` to show where the warning was created)
    node-red.0
    2023-10-28 23:44:43.794	debug	28 Oct 23:44:43 - [info] Flows sind gestartet
    node-red.0
    2023-10-28 23:44:42.896	debug	28 Oct 23:44:42 - [info] [whatsappLink:Web] Status : Initializing Whatsapp..
    node-red.0
    2023-10-28 23:44:41.274	debug	28 Oct 23:44:41 - [info] Flows werden gestartet
    node-red.0
    2023-10-28 23:44:40.706	debug	28 Oct 23:44:40 - [info] Flow-Datei: /opt/iobroker/iobroker-data/node-red/projects/pi4-iobroker/flows.json
    node-red.0
    2023-10-28 23:44:40.704	debug	28 Oct 23:44:40 - [info] Aktives Projekt: pi4-iobroker
    node-red.0
    2023-10-28 23:44:40.659	debug	28 Oct 23:44:40 - [info] Server wird jetzt auf http://127.0.0.1:1880/ ausgeführt
    node-red.0
    2023-10-28 23:44:40.418	debug	28 Oct 23:44:40 - [info] Projektverzeichnis: /opt/iobroker/iobroker-data/node-red/projects
    node-red.0
    2023-10-28 23:44:40.416	debug	28 Oct 23:44:40 - [info] Benutzerverzeichnis: /opt/iobroker/iobroker-data/node-red/
    node-red.0
    2023-10-28 23:44:40.323	debug	28 Oct 23:44:40 - [info] Kontextspeicher: default [module=memory]
    node-red.0
    2023-10-28 23:44:40.321	debug	28 Oct 23:44:40 - [info] Kontextspeicher: storeInFile [module=localfilesystem]
    node-red.0
    2023-10-28 23:44:40.313	debug	28 Oct 23:44:40 - [info] Einstellungsdatei: /opt/iobroker/iobroker-data/node-red/settings.js
    node-red.0
    2023-10-28 23:44:40.311	warn	28 Oct 23:44:40 - [warn] ------------------------------------------------------
    node-red.0
    2023-10-28 23:44:40.309	warn	28 Oct 23:44:40 - [warn] [node-red-contrib-moment2/moment] Der Typ 'moment' ist bereits von Modul 'node-red-contrib-moment' registriert
    node-red.0
    2023-10-28 23:44:40.304	warn	28 Oct 23:44:40 - [warn] ------------------------------------------------------
    node-red.0
    2023-10-28 23:44:39.139	debug	28 Oct 23:44:39 - [info] Polymer started at /polymer
    node-red.0
    2023-10-28 23:44:38.589	debug	28 Oct 23:44:38 - [info] Dashboard version 2.28.2 started at /ui
    node-red.0
    2023-10-28 23:44:32.183	debug	28 Oct 23:44:32 - [info] Paletten-Nodes werden geladen
    node-red.0
    2023-10-28 23:44:32.182	debug	28 Oct 23:44:32 - [info] Paletteneditor deaktiviert: Einstellungen
    node-red.0
    2023-10-28 23:44:32.172	debug	28 Oct 23:44:32 - [info] Linux 5.10.103-v7l+ arm LE
    node-red.0
    2023-10-28 23:44:32.170	debug	28 Oct 23:44:32 - [info] Node.js Version: v18.18.2
    node-red.0
    2023-10-28 23:44:32.169	debug	28 Oct 23:44:32 - [info] Node-RED Version: v3.0.2
    node-red.0
    2023-10-28 23:44:32.165	debug	28 Oct 23:44:32 - [info] Willkommen bei Node-RED ===================
    node-red.0
    2023-10-28 23:44:30.197	info	Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    node-red.0
    2023-10-28 23:44:27.938	debug	Writing extended authentication for authType: "None" : {"type":"credentials","users":[],"default":{"permissions":"*"}}
    node-red.0
    2023-10-28 23:44:27.770	info	Requested NPM packages: ["node-red-dashboard","node-red-node-openweathermap","node-red-contrib-ui-led","node-red-node-mysql","node-red-contrib-schedex","node-red-node-ping","node-red-contrib-telegrambot","node-red-node-wemo","node-red-contrib-moment2","node-red-contrib-shift-register","node-red-contrib-ui-multistate-switch","node-red-contrib-s7","node-red-contrib-sun-position","node-red-contrib-simpletime","node-red-contrib-owfs","node-red-contrib-boolean-logic","node-red-contrib-toggle","node-red-node-random","node-red-contrib-buffer-parser","node-red-contrib-influxdb","node-red-contrib-tasmota","node-red-contrib-wled","node-red-contrib-wled2","node-red-contrib-nora","node-red-contrib-timeouttrigger","node-red-contrib-hysteresis","node-red-contrib-button-events","node-red-contrib-whatsapp-link"]
    node-red.0
    2023-10-28 23:44:27.729	info	starting. Version 4.0.3 in /opt/iobroker/node_modules/iobroker.node-red, node: v18.18.2, js-controller: 5.0.15
    Ich weiß nicht was ich aus den Fehlermeldungen ableiten kann/soll
    Ich habe vor einigen Stunden ein Backup von NodeRed mit Backitup auf mein Google Drive gemacht.
    Die Datei nodered.0_2023_10_28-21_40_42_Pi_backupiobroker.tar.gz habe ich mir auf meinen Windows Rechner zurück geladen. Wie sage ich Backitup das es diese Datei auf meinen PI IObroker zurückspielt.
    Ich habe Angst noch mehr zu zerstören und bitte um Hilfe, da in NodeRed Jahre an Arbeit stecken.
    Heute Abend mache ich nichts mehr, da ich zu hibbelig bin und hoffe morgen mit eurer Hilfe NodeRed im IO Broker wieder zum laufen zu bekommen.
    Marc
    Mod-Edit: Code/Log in Code Tags gepackt. Bitte benutzt die Code Tags Funktion -> </>
    Hier gehts zur Hilfe.
    DJMarc75D mickymM 2 Antworten Letzte Antwort
    • E edstobi
      Hallo
      node-red.0
      node-red.0
      node-red.0
      node-red.0
      node-red.0
      node-red.0
      node-red.0
      node-red.0
      node-red.0
      node-red.0
      node-red.0
      node-red.0
      node-red.0
      node-red.0
      node-red.0
      node-red.0
      node-red.0
      node-red.0
      node-red.0
      node-red.0
      node-red.0
      node-red.0
      node-red.0
      node-red.0
      node-red.0
      node-red.0
      node-red.0
      node-red.0
      node-red.0
      node-red.0
      node-red.0
      node-red.0
      node-red.0
      Marc
      DJMarc75D Offline
      DJMarc75D Offline
      DJMarc75
      @edstobi
      Bitte Texte in Codetags packen, danke.
      Lehrling seit 1975 !!!
      • E edstobi
        Hallo
        node-red.0
        node-red.0
        node-red.0
        node-red.0
        node-red.0
        node-red.0
        node-red.0
        node-red.0
        node-red.0
        node-red.0
        node-red.0
        node-red.0
        node-red.0
        node-red.0
        node-red.0
        node-red.0
        node-red.0
        node-red.0
        node-red.0
        node-red.0
        node-red.0
        node-red.0
        node-red.0
        node-red.0
        node-red.0
        node-red.0
        node-red.0
        node-red.0
        node-red.0
        node-red.0
        node-red.0
        node-red.0
        node-red.0
        Marc
        mickymM Offline
        mickymM Offline
        mickym
        @edstobi Schalter den Sicherheitsmodus in Node-red und starte dann den Adapter neu.
        Dann suchst du diese function node und deaktivierst diese Node und versuchst dann normal zu starten. Dann musst du den fehlerhaften Code überarbeiten
        • E Offline
          edstobi
          @mickym
          Danke für deine Antwort. Ich habe mit meinen reparaturversuchen mittlerweile den IOBROKER geschrottet das nichts mehr geht. Ich versuche jetzt (11:50) ein komplettes Backup welches ich vor dem letzten Update mit ioBrokerToo gemacht habe, zurück zu spielen. Die Hoffnung stirbt zuletzt.
          Magst du mir erklären wie man den heirsmodus einschaltet? und startet man dann NodeRed ganz normal?
          mickymM HomoranH 2 Antworten Letzte Antwort
          • E edstobi
            @mickym
            mickymM Offline
            mickymM Offline
            mickym
            @edstobi den Sicherheitsmodus aktivierst du in der Adapterkonfiguration. NodeRed startet dann, die Flows sind dann aber alle gestoppt. Du kannst dann die fehlerhafte Node deaktivieren oder den fehlerhaften Flow deaktivieren und dann alle Flows über das Übernehmen Menü starten. Dann starten alle Flows bis auf die deaktivierten Flows oder Nodes.
            • E edstobi
              @mickym
              @edstobi sagte in NodeRed kaput, alles im Haus steht:
              Was ist denn das?
              ? E 2 Antworten Letzte Antwort
              • mickymM mickym
                mickymM Offline
                mickymM Offline
                mickym
                @mickym wenn du im iobroker backitup eine node-red backup gemacht hast und das mit dem Sicherheitsmodus nicht klappt dann gibt’s noch ein paar Möglichkeiten- aber probiere erst mal den Sicherheitsmodus.
                E 1 Antwort Letzte Antwort
                  Was ist denn das?
                  @homoran sagte in NodeRed kaput, alles im Haus steht:
                  Was ist denn das?
                  Moin,
                  auch ein Tool, dass mal vor 4 Jahren entstanden ist ⇒ https://www.elzershark.com/forum/index.php?thread/4-backup-reparatur-install-tool-iobroker/ wird wohl aber noch gepflegt. Initiator ist @Elzershark
                  Bernd
                    Was ist denn das?
                    edstobi
                    Schau einmal hier
                    "IoBroker Backitup Adapter einrichten und die Backups auf USB Stick speichern How To": https://www.youtube.com/watch?v=qQSefltobbY&t=531s
                    Was ich noch nicht kannte war der Sicherheitsmodus in node red. Der hätte mich bestimmt sehr viel besser schlafen lassen und ich hätte kein komplettes Backup zurückspielen müssen.
                    ABER es hat funktioniert!!🤸 🥂
                    • mickymM mickym
                      edstobi
                      @mickym
                      Dankeschön. Habe jetzt etwas gelernt was ich bestimmt nicht mehr vergessen werde. Dankschön.
                      Was ein kleiner Haken ✅ doch die Welt einfacher machen kann
                        Was ist denn das?
                        Moin,
                        Bernd
                        @dp20eic sagte in NodeRed kaput, alles im Haus steht:
                        auch ein Tool,
                        das hab ich fast befürchtet.
                        Scheint ein Rundumschlag mit root und Rechteverbiegung zu sein.
                        DJMarc75D E 2 Antworten Letzte Antwort
                          auch ein Tool,
                          DJMarc75D Offline
                          DJMarc75D Offline
                          DJMarc75
                          @homoran und zusätzlich vom "Entwickler" so kommentiert:
                          Es ist halt Node 16, statt Node 18. Aber es muss ja nicht das allerneuste sein. Trotzdem funzt es. Dauert nur. Ist halt sehr langsam.
                          Hast du es denn getestet??? Bei mir läuft das einwandfrei
                          Ich mach grad Popcorn 🤡
                            auch ein Tool,
                            edstobi
                            Nein, es arbeitet mit den Berechtigungen welche der IO Broker hat.
                            sudo hat bei mir andere Berechtigungen auf dem PI.
                            Ist auch egal, es hat mir den Ars.. gerettet und auch schon einen Umzug erleichtert, wird weiterentwickelt, gepflegt und ist für nicht linux Leute toll. Einfach mal anschauen.
                            • mickymM Offline
                              mickymM Offline
                              mickym
                              Sorry für die Verwirrung - aber auf dem iPad tippt es sich nicht immer fehlerfrei. ;)
                              • mickymM mickym
                                edstobi
                                @mickym Es läuft alles wieder. Das ist die Hauptsache!!
                                Ich habe etwas gelernt. Das ist Gut
                                Und ich lasse jetzt die Finger von NodeRed WhatsApp, den das war der Bösewicht!
                                Das werde ich die Tage auf einem Testsystem testen, Nicht mehr im Live system. Lesson learned
                                • E edstobi
                                  mickymM Offline
                                  mickymM Offline
                                  mickym
                                  @edstobi ich dachte nach Deinem Log eher - dass es eine function Node war
                                  Das hätte ich als erstes versucht
                                  • E edstobi
                                    @edstobi
                                    Das dolle "Tool" ist vollkommene Grütze. Finger weg von dem Ding, das verbiegt dir alles auf der Kiste.
                                      @edstobi
                                      mickymM Offline
                                      mickymM Offline
                                      mickym
                                      @thomas-braun sagte in NodeRed kaput, alles im Haus steht:
                                      @edstobi
                                      Was meinst Du damit?
                                      • mickymM mickym
                                        @edstobi
                                        @mickym
                                        Dieses krumme Ding vom Elsterhai oder wie der heißt.
                                          @mickym
                                          mickymM Offline
                                          mickymM Offline
                                          mickym
                                          @thomas-braun Ach so - ich hab gar nicht gelesen, dass sowas verwendet wurde. :(
                                          32.7k
                                          82.6k
