  4. [gelöst] keine Updates mehr möglich - npm ERR! code ETARGET
    5.1k
51 Beiträge 5 Kommentatoren 7.6k Aufrufe 4 Beobachtet
  • K Kueppert
    thorsten@ioBroker2:/opt/iobroker$ less -R /home/iobroker/.npm/_logs/2022-07-18T08_58_06_029Z-debug-0.log
    44 timing idealTree:node_modules/iobroker.vis Completed in 0ms
    45 timing idealTree:buildDeps Completed in 1286ms
    46 timing idealTree:fixDepFlags Completed in 31ms
    47 timing idealTree Completed in 2796ms
    48 timing reify:loadTrees Completed in 3129ms
    49 timing reify:diffTrees Completed in 42ms
    50 silly reify moves {}
    51 timing reify:retireShallow Completed in 1ms
    52 timing reify:createSparse Completed in 2ms
    53 timing reify:loadBundles Completed in 0ms
    54 verbose reify failed optional dependency /opt/iobroker/node_modules/osx-temperature-sensor
    55 silly reify mark deleted [ '/opt/iobroker/node_modules/osx-temperature-sensor' ]
    56 verbose reify failed optional dependency /opt/iobroker/node_modules/fsevents
    57 silly reify mark deleted [ '/opt/iobroker/node_modules/fsevents' ]
    58 timing reifyNode:node_modules/osx-temperature-sensor Completed in 6ms
    59 timing reifyNode:node_modules/fsevents Completed in 6ms
    60 timing reifyNode:node_modules/iobroker.vis Completed in 363ms
    61 timing reify:unpack Completed in 363ms
    62 timing reify:unretire Completed in 0ms
    63 timing build:queue Completed in 2ms
    64 info run iobroker.vis@1.4.15 install node_modules/iobroker.vis node main.js --install
    65 info run iobroker.vis@1.4.15 install { code: 6, signal: null }
    66 timing reify:rollback:createSparse Completed in 203ms
    67 timing reify:rollback:retireShallow Completed in 0ms
    68 timing command:install Completed in 7574ms
    69 verbose stack Error: command failed
    69 verbose stack     at ChildProcess.<anonymous> (/usr/lib/node_modules/npm/node_modules/@npmcli/promise-spawn/lib/index.js:63:27)
    69 verbose stack     at ChildProcess.emit (node:events:527:28)
    69 verbose stack     at maybeClose (node:internal/child_process:1092:16)
    69 verbose stack     at Process.ChildProcess._handle.onexit (node:internal/child_process:302:5)
    70 verbose pkgid iobroker.vis@1.4.15
    71 verbose cwd /opt/iobroker
    72 verbose Linux 5.10.0-16-amd64
    73 verbose node v16.16.0
    74 verbose npm  v8.11.0
    75 error code 6
    76 error path /opt/iobroker/node_modules/iobroker.vis
    77 error command failed
    78 error command sh -c node main.js --install
    79 verbose exit 6
    80 timing npm Completed in 7755ms
    81 verbose unfinished npm timer reify 1658134686204
    82 verbose unfinished npm timer reify:build 1658134689753
    83 verbose unfinished npm timer build 1658134689754
    84 verbose unfinished npm timer build:deps 1658134689754
    85 verbose unfinished npm timer build:run:install 1658134689756
    86 verbose unfinished npm timer build:run:install:node_modules/iobroker.vis 1658134689757
    87 verbose code 6
    mehr steht in dem Log nicht drin
    crunchipC Abwesend
    crunchipC Abwesend
    @kueppert hab jetzt nicht die ganz gelesen, aber wie geschrieben, hatte ich auch vergessen vis vor dem backup zu installieren, abhilfe schaffte die Version 1.4.0 per konsole zu installieren und danach wieder hoch auf die aktuelle.
    Habe diesbezüglich auch im issue(ist zwar schon geschlossen) einen Eintrag hinterlassen
    https://github.com/ioBroker/ioBroker.vis/issues/502
    Hab diesbezüglich soeben auch meine Anleitung noch ergänzt zum Thema vis
    • K Kueppert
      @thomas-braun guter Hinweis. Hab das Issue gefunden:
      https://github.com/ioBroker/ioBroker.vis/issues/440
      VIS funktioniert trotzdem noch nicht...aber das ist ein anderes Problem...mal schauen, ob ich irgendwo ne Sicherung der Vis finde :/ Wenn ich ne Lösung hab, notiere ich sie hier noch.
      Das manuelle Installieren der VIS 1.4.6, dann Update auf 1.4.15 ging zwar, VIS ist grün, aber meine Visualisierungen öffnen sich nicht mehr:
      URIError: Failed to decode param '%web_protocol%://192.168.10.13:%web_port%/vis/edit.html'
          at decodeURIComponent (<anonymous>)
          at decode_param (/opt/iobroker/node_modules/express/lib/router/layer.js:172:12)
          at Layer.match (/opt/iobroker/node_modules/express/lib/router/layer.js:148:15)
          at matchLayer (/opt/iobroker/node_modules/express/lib/router/index.js:585:18)
          at next (/opt/iobroker/node_modules/express/lib/router/index.js:226:15)
          at compression (/opt/iobroker/node_modules/compression/index.js:220:5)
          at Layer.handle [as handle_request] (/opt/iobroker/node_modules/express/lib/router/layer.js:95:5)
          at trim_prefix (/opt/iobroker/node_modules/express/lib/router/index.js:328:13)
          at /opt/iobroker/node_modules/express/lib/router/index.js:286:9
          at Function.process_params (/opt/iobroker/node_modules/express/lib/router/index.js:346:12)
      @kueppert sagte in keine Updates mehr möglich - npm ERR! code ETARGET:
      Den web-Adapter auf ws als socket umstellen?
        Kueppert
        @thomas-braun @crunchip
        habs mir schon kaputt gebastelt...dachte ich machs einfach wie beim PiHole und installiere die VIS neu (vorher deinstallieren). Bekomm meine Views jetzt nimmer rein 😂 glaub, irgendwie Projekt anlegen, dann den Backup-Ordner drüber kopieren oder sowas wars...
        • K Kueppert
          crunchipC Abwesend
          crunchipC Abwesend
          @kueppert vis könntest du dir auch aus dem backup ziehen, muss aber glaub, per datei manager hochgeladen werden
            Kueppert
            @crunchip JOOOOOOOO, via WinSCP war dat nix. Via Dateimanager (Datei für Datei, Ordner gehen nicht) hats geklappt :D So, jetzt sollte mein System wieder laufen...mal das anstehende JS-Update ausprobieren ^^ Ich mach vorher mal noch nen Backup
            • K Kueppert
              Das sollte man eh meiden. Hat schon ein Win im Namen... 😆
              • tripperT Offline
                tripperT Offline
                tripper
                Schade gab's hier keine bessere Lösung als neu installieren.
                Ich hab auch ein Problem mit NPM: "npm ERR! code ELSPROBLEMS"
                Dann such ich mal weiter....
                Denn "Backup einspielen" tönt immer so schön, am Ende muss dann trotzdem vieles händisch eingerichtet werden bis wieder alles läuft wie es soll.
                Ich kenne meinen ioBroker leider nicht mehr in- und auswendig, da der eigentlich seit 3 Jahren zuverlässig vor sich hinläuft und ich mich nur 3-4mal pro Jahr kurz damit beschäftige, meistens wenn ich neue Geräte und Funktionen einrichten möchte.
                Für Linux-unerfahrene Gelegenheitsnutzer wie mich ist das System halt schon eher mühsam zu pflegen. Da müsste ich wohl etwas regelmässiger Updates von allem möglichen laufen lassen um nicht in so einer Missere wie jetzt zu landen. Am meisten nervt mich nun das dutzende von Zigbee Geräten nicht mehr angesteuert werden, Lichter sind alle wieder auf manuell-Betrieb :(
                • tripperT tripper
                  @tripper
                  Auf was beziehst du dich? Auf einen Thread aus dem letzten Jahr, der mit deinem Problem (welches genau?)nichts zu tun hat?
                  Mach einen eigenen Threads auf und stell da konkrete Meldungen rein.
                  • tripperT Offline
                    tripperT Offline
                    tripper
                    @thomas-braun Der Thread heisst: "keine Updates mehr möglich" und offensichtlich war NPM die Ursache des Problems. Ich habe alles durchgelesen und sehe genau die selben Probleme, auch bei mir helfen all die hier vorgeschlagene Lösungen nicht.
                    Neuen Thread für das (aus meiner Sicht) gleiche Problem aufmachen finde ich nicht sehr übersichtlich.
                    Ersteller warst wohl nicht du sondern Kueppert, danke trotzdem dass du hier gleich wieder reinspringst.
                    • tripperT tripper
                      @tripper sagte in [gelöst] keine Updates mehr möglich - npm ERR! code ETARGET:
                      Die Meldung kann alle möglichen Ursachen haben. Die Wahrscheinlichkeit das du zu 100% das gleiche Problem hast geht gegen Null.
                      Poste die Meldungen aus deinem System und reiß hier einen abgehandelten Thread nicht aus der Versenkung.
                      iob diag
                      in der Langfassung wäre hilfreich.
