  4. Test Adapter Garmin
Test Adapter Garmin
196 Beiträge 21 Kommentatoren 53.8k Aufrufe 21 Beobachtet
  • Curtis777C Curtis777
    in meinem Test Iobroker lief der Adapter gut, allerdings jetzt wo meine aktive IObroker installation auf Node.js
    v18.16.0 is habe ich es hier versucht und bekomme folgende Fehlermeldung... die mir nichts sagt.
    host.HomeBeast
    2023-05-23 10:53:11.035	info	Restart adapter system.adapter.garmin.0 because enabled
    host.HomeBeast
    2023-05-23 10:53:11.035	error	instance system.adapter.garmin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    host.HomeBeast
    2023-05-23 10:53:11.035	error	Caught by controller[0]: Node.js v18.16.0
    host.HomeBeast
    2023-05-23 10:53:11.035	error	Caught by controller[0]: }
    host.HomeBeast
    2023-05-23 10:53:11.035	error	Caught by controller[0]: code: 'ERR_REQUIRE_ESM'
    host.HomeBeast
    2023-05-23 10:53:11.034	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.garmin/main.js:11:13) {
    host.HomeBeast
    2023-05-23 10:53:11.034	error	Caught by controller[0]: Instead change the require of index.js in /opt/iobroker/node_modules/iobroker.garmin/main.js to a dynamic import() which is available in all CommonJS modules.
    host.HomeBeast
    2023-05-23 10:53:11.034	error	Caught by controller[0]: Error [ERR_REQUIRE_ESM]: require() of ES Module /opt/iobroker/node_modules/got/dist/source/index.js from /opt/iobroker/node_modules/iobroker.garmin/main.js not supported.
    host.HomeBeast
    2023-05-23 10:53:11.034	error	Caught by controller[0]: ^
    host.HomeBeast
    2023-05-23 10:53:11.034	error	Caught by controller[0]: const got = require("got").default;
    host.HomeBeast
    2023-05-23 10:53:11.034	error	Caught by controller[0]: /opt/iobroker/node_modules/iobroker.garmin/main.js:11
    host.HomeBeast
    2023-05-23 10:53:10.236	info	instance system.adapter.garmin.0 started with pid 30710
    host.HomeBeast
    2023-05-23 10:53:10.178	info	"system.adapter.garmin.0" enabled
    tombox
    @curtis777 sollte nicht passieren liegt auch nicht direkt an node 18
    bitte mal die github version testen
    Curtis777C 1 Antwort Letzte Antwort
    • T tombox
      Curtis777C Offline
      Curtis777C Offline
      Curtis777
      @tombox Danke, funktioniert wieder.
      Läuft wie am Schnürchen.
      Gibts denn schon selbst gebaute Widgets ?
      um das ganze Optisch gut darzustellen ?
      • T tombox
        Hi ich habe ein neuen Adapter für Garmin connect geschrieben.
        Minimum Node v18 muss installiert sein, sonst bekommt man exit code 25 beim installieren
        Zum Installieren:
        https://github.com/TA2k/ioBroker.garmin
        Unter Adapter Experten Modus aktivieren:
        Unter Adapter das Github Icon klicken:
        Benutzerdefiniert auswählen und die Url einfügen.
        Dann unter Adapter den Garmin Adapter suchen und ganz rechts auf das Plus klicken.
        Loginablauf:
        Die Garmin connect Zugangsdaten eingeben
        Beispiel für filter
        hydration.valueInML, hydration.sweatLossInML, hydration.goalInML, trainingstatus.mostRecentVO2Max.generic.vo2MaxValue, dailystress.avgStressLevel, usersummary.latestSpo2, dailysleep.dailySleepDTO.sleepScores.overall.value, usersummary.restingHeartRate, usersummary.maxHeartRate, usersummary.bodyBatteryDrainedValue, usersummary.bodyBatteryChargedValue, usersummary.bodyBatteryMostRecentValue, usersummary.totalDistanceMeters, usersummary.floorsAscended, usersummary.dailyStepGoal, usersummary.totalSteps, weight.dateWeightList.bodyWater, weight.dateWeightList.muscleMass, weight.dateWeightList.boneMass, weight.dateWeightList.weight, weight.dateWeightList.bodyFat, weight.dateWeightList.bmi
        AgrippinenserA Offline
        Agrippinenser
        #66
        Ich habe testweise Garmin v0.0.4 installiert. Node.js v18.16.0. Kein MFA.
        Dabei treten reichlich Fehler auf. Ich hatte testweise alle 15 Minuten aktualisiert - nun wieder auf 60 Minuten hoch gesetzt. Kann das mit der "geringen" Aktualisierung Zeit zusammen hängen?
        {"clientMessage":"Reference Error ID in error logs for further information","errorId":"xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx","error":"WebApplicationException"}
        garmin.0
        2023-06-09 15:40:45.376	error	AxiosError: Request failed with status code 403
        garmin.0
        2023-06-09 15:40:45.376	error	https://connect.garmin.com/modern/proxy/weight-service/weight/dateRange?startDate=2023-06-03&endDate=2023-06-09
        garmin.0
        2023-06-09 15:40:45.151	error	{"clientMessage":"Reference Error ID in error logs for further information","errorId":"xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx","error":"WebApplicationException"}
        garmin.0
        2023-06-09 15:40:45.151	error	AxiosError: Request failed with status code 403
        garmin.0
        2023-06-09 15:40:45.151	error	https://connect.garmin.com/modern/proxy/activitylist-service/activities/search/activities?start=0&limit=10
        garmin.0
        2023-06-09 15:40:44.915	error	{"clientMessage":"Reference Error ID in error logs for further information","errorId":"xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx","error":"WebApplicationException"}
        Grüße vom Rhein @Colonia Claudia Ara Agrippinensium
        • AgrippinenserA Offline
          Agrippinenser
          #67
          gerade mal das Konto mit MFA konfiguriert. Aber wie @newbie0815 zuvor geschrieben hat sendete Garmin im Sekundentakt 5-10 Codes. Werde der erste noch der letzte funktionierte. Zu guter Letzt war das Garmin Konto wegen zu vieler Anmeldeversuche gesperrt.
          AgrippinenserA 1 Antwort Letzte Antwort
          • AgrippinenserA Agrippinenser
            Agrippinenser
            #68
            Ein Frage noch. Unter Garmin.0 liegen hier 13795 Datenpunkte. Das ist schon ne Menge Zeugs denke ich, zumal ich nur ca. 10 davon einmal am Tag brauche.
            Kann man ermitteln wie lange der Aktualisierungsvorgang dauert ?
            Die Idee war den Adapter morgens zur bestimmten Uhrzeit per Script zu starten und nach Aktualisierung der Daten wieder zu beenden.
            • hg6806H Offline
              hg6806H Offline
              hg6806
              #69
              Ein Garmin Adapter klingt sehr vielversprechend.
              Allerdings zeichne ich seit 15 Jahren auf, und als Triathlet kommen so einige Objekte zusammen.
              Deshalb habe ich etwas Angst das System zu zerschießen, zumal ich nur 4GB RAM habe.
              Kann man das irgendwie begrenzen?
              • hg6806H hg6806
                tombox
                #70
                @hg6806 Wo sind denn genau zuviel Objekte
                hg6806H 1 Antwort Letzte Antwort
                • T tombox
                  hg6806H Offline
                  hg6806H Offline
                  hg6806
                  #71
                  @tombox
                  Es wurde berichtet, dass teilweise über 100.000 Objekte geladen wurden, und da ich nur ein 4GB RasPi habe bin ich da vorsichtig.
                  Deshalb die Frage ob man das begrenzen kann wie z.B. nur einen bestimmten Zeitraum.
                  • T tombox
                    Zum Installieren:
                    Loginablauf:
                    Beispiel für filter
                    micha182
                    #72
                    @tombox
                    Toller Adapter, herzlichen Dank!
                      kirbsi
                      #73
                      Hallo Leute. Bekommt ihr noch Daten von Garmin. Seit dem 20.10.2023 kommt bei mir nichts mehr rein!
                        kirbsi
                        #74
                        Ich bekomme nur noch 126 Datenpunkte rein. Keine über 9000 mehr.
                        • K kirbsi
                          tombox
                          #75
                          @kirbsi Vielleicht kannst du im debug log mehr sehen was das problem ist
                          • T tombox
                            bommel_030
                            #76
                            @tombox
                            Hab den Adapter schon lange nicht mehr genutzt da er bei mir regelmäßig abstürzt. Nach dem Post hab ich in mal wieder reaktivert, anbei das Debug-Log wenn ich den Adapter starte. Zumindest von den von mir verwendeten Werten wird keine mehr aktualisiert. Benutzername und Passwort sind korrekt.
                            garmin.0
                            2023-11-07 10:00:28.354	error	""
                            garmin.0
                            2023-11-07 10:00:28.353	error	AxiosError: Request failed with status code 402
                            garmin.0
                            2023-11-07 10:00:28.353	error	https://connect.garmin.com/modern/proxy/weight-service/weight/dateRange?startDate=2023-11-01&endDate=2023-11-07
                            garmin.0
                            2023-11-07 10:00:28.279	error	""
                            garmin.0
                            2023-11-07 10:00:28.279	error	AxiosError: Request failed with status code 402
                            garmin.0
                            2023-11-07 10:00:28.279	error	https://connect.garmin.com/modern/proxy/activitylist-service/activities/search/activities?start=0&limit=10
                            garmin.0
                            2023-11-07 10:00:28.206	error	""
                            garmin.0
                            2023-11-07 10:00:28.206	error	AxiosError: Request failed with status code 402
                            garmin.0
                            2023-11-07 10:00:28.205	error	https://connect.garmin.com/modern/proxy/metrics-service/metrics/trainingstatus/aggregated/2023-11-07
                            garmin.0
                            2023-11-07 10:00:28.124	error	""
                            garmin.0
                            2023-11-07 10:00:28.124	error	AxiosError: Request failed with status code 402
                            garmin.0
                            2023-11-07 10:00:28.124	error	https://connect.garmin.com/modern/proxy/userstats-service/wellness/daily/bommel_030?fromDate=2023-11-01
                            garmin.0
                            2023-11-07 10:00:28.053	error	""
                            garmin.0
                            2023-11-07 10:00:28.053	error	AxiosError: Request failed with status code 402
                            garmin.0
                            2023-11-07 10:00:28.053	error	https://connect.garmin.com/modern/proxy/wellness-service/wellness/dailyStress/2023-11-07
                            garmin.0
                            2023-11-07 10:00:27.978	error	""
                            garmin.0
                            2023-11-07 10:00:27.978	error	AxiosError: Request failed with status code 402
                            garmin.0
                            2023-11-07 10:00:27.977	error	https://connect.garmin.com/modern/proxy/wellness-service/wellness/dailySleepData/bommel_030?date=2023-11-07&nonSleepBufferMinutes=60
                            garmin.0
                            2023-11-07 10:00:27.899	error	""
                            garmin.0
                            2023-11-07 10:00:27.899	error	AxiosError: Request failed with status code 402
                            garmin.0
                            2023-11-07 10:00:27.898	error	https://connect.garmin.com/modern/proxy/usersummary-service/usersummary/hydration/daily/2023-11-07
                            garmin.0
                            2023-11-07 10:00:27.815	error	""
                            garmin.0
                            2023-11-07 10:00:27.815	error	AxiosError: Request failed with status code 402
                            garmin.0
                            2023-11-07 10:00:27.815	error	https://connect.garmin.com/modern/proxy/metrics-service/metrics/maxmet/daily/2023-11-07/2023-11-07
                            garmin.0
                            2023-11-07 10:00:27.708	error	""
                            garmin.0
                            2023-11-07 10:00:27.708	error	AxiosError: Request failed with status code 402
                            garmin.0
                            2023-11-07 10:00:27.708	error	https://connect.garmin.com/modern/proxy/usersummary-service/usersummary/daily/bommel_030?calendarDate=2023-11-07
                            garmin.0
                            2023-11-07 10:00:27.618	error	""
                            garmin.0
                            2023-11-07 10:00:27.618	error	AxiosError: Request failed with status code 402
                            garmin.0
                            2023-11-07 10:00:27.543	debug	{"scope":"COMMUNITY_COURSE_READ GOLF_API_READ GHS_HID ATP_READ GHS_SAMD INSIGHTS_READ COMMUNITY_COURSE_WRITE CONNECT_WRITE DIVE_SHARED_READ GHS_REGISTRATION DT_CLIENT_ANALYTICS_WRITE GOLF_API_WRITE INSIGHTS_WRITE PRODUCT_SEARCH_READ GOLF_SHARED_READ CONNECT_NON_SOCIAL_SHARED_READ CONNECT_READ ATP_WRITE","jti":"764eb129-84e2-4a89-a71d-615106000918","access_token":"eyJhbGciOiJSUzI1NiIsInR5cCI6IkpXVCIsImtpZCI6ImRpLW9hdXRoLXNpZ25lci1wcm9kLTIwMjMtcTIifQ.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.Mp6Tb9mKVELodO2kUPpjBUvWdVIfr14BLllw9_UDBKtOrOxhDUjokQBzyanaoI1BTHAuAwlZ0gPBb4kQtlYPaOQovuNqHaIuE3eXDHY2m1ilzzLDWfr7VThlsfNDw3Nl5ocapvDshq4QDoaoftrZNVTqaPsq_Xlmlxe5vToNFxFbIZ7emGqwxOcPKvVX84bXuLVDKkEwnKvNvvl_eqbsvZIcPItBDe4K7vAd3_mNxBv8tX7ZbmmAZ7XFazmNQa6fA1Ob8SnOtfO9jfqZv8g5EEqzHl9zCIH4awfzweA7RzjOoQAhZS27-mlVyOm9GEmo_hsR4b-AM2Ts4fRQrxgwKg","token_type":"Bearer","refresh_token":"eyJyZWZyZXNoVG9rZW5WYWx1ZSI6ImUwMzNmMDRjLWI0MzctNDgzOS1hNWEzLWEwYjVmZDU5NjIxOCIsImdhcm1pbkd1aWQiOiI0MjRmYmU5Ny1hODlkLTQ3ZWItYTFjYi1jYmViN2YwMGViODUifQ==","expires_in":3599,"refresh_token_expires_in":7199}
                            garmin.0
                            2023-11-07 10:00:26.929	debug	"<!DOCTYPE html>\n<html class=\"signed-in\" lang=\"de\">\n\n\n\n<head>\n <meta http-equiv=\"X-UA-Compatible\" content=\"IE=edge\"/>\n <meta charset=\"UTF-8\"/>\n <meta name=\"viewport\" content=\"width=device-width, initial-scale=1.0\"/>\n\n <title>Garmin Connect</title>\n\n \n\n\n \n\n <link rel=\"shortcut icon\" href=\"/modern/images/favicon.ico\" />\n\n <!-- Connect Styles -->\n \n <link rel=\"stylesheet\" type=\"text/css\" href=\"/modern/css/dropzone.min.css?bust=4.72.4.2\" />\n <link rel=\"stylesheet\" type=\"text/css\" href=\"/web-react/styles/global.css?bust=4.72.4.2\" />\n \n \n\n \n\n <!-- to be modify the google fonts in cdn here -->\n <!--garmin.cn-->\n\n \n \n <!-- FONTS -->\n <link rel='stylesheet' type='text/css' href=\"https://fonts.googleapis.com/css?family=Open+Sans:300,400,600,700&amp;subset=latin,cyrillic-ext,greek-ext,vietnamese\" />\n \n\n\n\n <title>Connect</title>\n</head>\n\n\n<body>\n<a href=\"connectagent://launch\" id=\"notify-agent\" style=\"display: none\" tabindex=\"-1\"><!-- dummy comment --></a>\n\n\n\n<div class=\"connect-container\">\n\n <nav class=\"main-nav hide\"><!-- main navigation --></nav>\n\n <div class=\"react-global-modal\"><!-- react-global-modal --></div>\n\n <div class=\"main-body\">\n <!-- Header -->\n \n\n <header class=\"header hide\">\n <!-- placeholder -->\n </header>\n\n <section class=\"beta-testers-survey-banner takeover-container\">\n <!-- placeholder -->\n </section>\n\n\n<div class=\"main-header\"></div>\n\n\n <!-- Content Container -->\n \n<div class=\"content clearfix\">\n\n \n <script>\n window.VIEWER_USERPREFERENCES = {\"availableTrainingDays\":null,\"heartRateFormat\":{\"formatKey\":\"bpm\",\"formatId\":21,\"maxFraction\":0,\"displayFormat\":null,\"groupingUsed\":false,\"minFraction\":0},\"golfSpeedUnit\":null,\"preferredLongTrainingDays\":null,\"dateFormat\":{\"formatKey\":\"ddmmyyyy\",\"formatId\":24,\"maxFraction\":0,\"displayFormat\":\"EEE, d MMM yyyy\",\"groupingUsed\":false,\"minFraction\":0},\"displayName\":\"bommel_030\",\"golfDistanceUnit\":\"statute_us\",\"timeZone\":\"Europe\\/Paris\",\"hydrationContainers\":[{\"volume\":100,\"unit\":\"milliliter\",\"name\":\"Gefäß 1\"},{\"volume\":500,\"unit\":\"milliliter\",\"name\":\"Gefäß 2\"},{\"volume\":750,\"unit\":\"milliliter\",\"name\":\"Gefäß 3\"}],\"hydrationMeasurementUnit\":\"milliliter\",\"powerFormat\":{\"formatKey\":\"power_zones\",\"formatId\":29,\"maxFraction\":1,\"displayFormat\":null,\"groupingUsed\":false,\"minFraction\":1},\"numberFormat\":\"decimal_comma\",\"firstDayOfWeek\":{\"dayName\":\"monday\",\"isPossibleFirstDay\":true,\"sortOrder\":3,\"dayId\":3},\"timeFormat\":{\"formatKey\":\"time_twenty_four_hr\",\"formatId\":33,\"maxFraction\":0,\"displayFormat\":\"H:mm\",\"groupingUsed\":false,\"minFraction\":0},\"measurementSystem\":\"metric\",\"golfElevationUnit\":null,\"preferredLocale\":\"de\"};\n window.VIEWER_SOCIAL_PROFILE = {\"runningTrainingSpeed\":0,\"swimmingTrainingSpeed\":0,\"showRecentDevice\":false,\"twitterUrl\":null,\"levelIsViewed\":false,\"bio\":null,\"activityStartVisibility\":\"private\",\"cyclingTrainingSpeed\":0,\"showHeight\":false,\"showBadges\":true,\"levelUpdateDate\":\"2023-06-17T13:29:46.0\",\"id\":2379666,\"showRecentFavorites\":false,\"makeGolfScorecardsPrivate\":false,\"activityHeartRateVisibility\":\"public\",\"profileVisibility\":\"following\",\"nameApproved\":true,\"garminGUID\":\"424fbe97-a89d-47eb-a1cb-cbeb7f00eb85\",\"otherMotivation\":null,\"showAgeRange\":false,\"showLifetimeTotals\":false,\"favoriteCyclingActivityTypes\":[],\"cyclingClassification\":null,\"otherPrimaryActivity\":null,\"userPointOffset\":0,\"userRoles\":[\"ROLE_OUTDOOR_USER\",\"ROLE_CONNECTUSER\",\"ROLE_FITNESS_USER\",\"ROLE_WELLNESS_USER\",\"ROLE_CONNECT_2_USER\"],\"profileId\":2400759,\"showActivityClass\":false,\"profileImageUrlSmall\":\"https:\\/\\/s3.amazonaws.com\\/garmin-connect-prod\\/profile_images\\/39f253fa-1f1d-444b-90e0-d2dadecbcb7d-2400759.png\",\"showRecentGear\":false,\"showLast12Months\":false,\"showGender\":true,\"displayName\":\"bommel_030\",\"personalWebsite\":null,\"motivation\":null,\"primaryActivity\":null,\"facebookUrl\":null,\"userLevel\":5,\"userPro\":false,\"favoriteActivityTypes\":[],\"courseVisibility\":\"public\",\"profileImageUuid\":\"c1166cf1-78a4-41d6-9b1b-2ea7131c84b9\",\"userPoint\":383,\"badgeVisibility\":\"following\",\"fullName\":\"Bommel\",\"showWeightClass\":false,\"allowGolfScoringByConnections\":true,\"levelPointThreshold\":620,\"userName\":\"bommel_030\",\"showVO2Max\":false,\"allowGolfLiveScoring\":false,\"profileImageUrlMedium\":\"https:\\/\\/s3.amazonaws.com\\/garmin-connect-prod\\/profile_images\\/71566b41-f46b-4b4e-a7fb-8a69c9952101-2400759.png\",\"otherActivity\":null,\"showUpcomingEvents\":false,\"showAge\":false,\"profileImageUrlLarge\":\"https:\\/\\/s3.amazonaws.com\\/garmin-connect-prod\\/profile_images\\/c1166cf1-78a4-41d6-9b1b-2ea7131c84b9-2400759.png\",\"location\":\"Schönwalde, Brandenburg\",\"showPersonalRecords\":false,\"activityMapVisibility\":\"public\",\"userProfileFullName\":\"Bommel\",\"cyclingMaxAvgPower\":0,\"showWeight\":false,\"activityPowerVisibility\":\"public\"};\n window.VIEWER_DASHBOARDS = [{\"dashboardTitle\":\"\",\"dashboardId\":681261,\"dashboardOrder\":1,\"ownerId\":2400759,\"dashboardTitleKey\":\"fitness_dashboard\"},{\"dashboardTitle\":\"\",\"dashboardId\":3070555,\"dashboardOrder\":2,\"ownerId\":2400759,\"dashboardTitleKey\":\"wellness_dashboard\"}];\n\n window.queueNotificationTimeout = 600000;\n window.queuePollRate = 600000;\n\n window.ERROR_VIEW = null;\n window.USER_PROFILE = null;\n\n window.viewerIsAuthenticated = true;\n\n window.SYSTEM_TIME_GMT = 1699347626848;\n window.SESSION_LENGTH = 2700000;\n window.GAUTH_HOST = \"https:\\/\\/sso.garmin.com\\/sso\";\n window.GARMIN_APP_URL = \"https:\\/\\/apps.garmin.com\\/connect?locale={locale}\";\n window.WEB_TOKEN = \"\";\n window.URL_BUST_VALUE = \"4.72.4.2\";\n\n window.IS_READONLY = null;\n window.PRODUCT_SUPPORT_MODE = null;\n window.IS_RACE_MANAGEMENT = null;\n\n window.JS_ERROR = true;\n window.DI_BACKENDS = {\"golf\":\"golf.garmin.com\",\"ghs\":\"ghs.connect.garmin.com\",\"insights\":\"insights.gcs.garmin.com\",\"gcs\":\"api.gcs.garmin.com\",\"gcapi\":\"connectapi.garmin.com\",\"omt\":\"omt.garmin.com\",\"gcsalt\":\"gcs.garmin.com\",\"didt\":\"api-didt-test.garmin.com\",\"atp\":\"atp.gcs.garmin.com\"};\n window.PREFERENCES = {\"5b5ea560-3015-46c8-9f15-28c038165b87\":\"ROLE_MBTESTER\",\"ce34657d-8a85-4b6e-8bb4-00897590c217\":\"ROLE_CONNECTUSER\",\"5c8d3401-e6e7-4354-9095-39526016a47c\":\"ROLE_CONNECTUSER\",\"d3c94498-8962-4a62-bd3a-0d80a08e3386\":\"false\",\"7ae52c9a-1967-46e9-952f-3e40e3770bde\":\"ROLE_CONNECTUSER\"};\n </script>\n\n <script src=\"/web-react/static/js/vendor.js?bust=4.72.4.2\"></script>\n <script src=\"/web-react/static/js/backbone-lib.js?bust=4.72.4.2\"></script>\n <script src=\"/web-react/static/js/bundle.js?bust=4.72.4.2\"></script>\n</div>\n\n <!-- END .content -->\n\n <!-- Footer -->\n <div class=\"main-footer\"></div>\n <!-- END .footer -->\n <p style=\"display: none;\" id=\"garmin-connect-version\">4.72.4.2</p>\n </div>\n\n <!-- END .container -->\n</div>\n\n<style>\n .privacy-overlay {\n position: fixed; /* Sit on top of the page content */\n width: 100%; /* Full width (cover the whole page) */\n height: 100%; /* Full height (cover the whole page) */\n top: 0;\n left: 0;\n background-color: #fff;\n z-index: 9999; /* Specify a stack order in case you're using a different order for other elements */\n }\n</style>\n\n<div id=\"overlay\" class=\"privacy-overlay\">\n</div>\n\n<script defer src=\"https://static.cloudflareinsights.com/beacon.min.js/v84a3a4012de94ce1a686ba8c167c359c1696973893317\" integrity=\"sha512-euoFGowhlaLqXsPWQ48qSkBSCFs3DPRyiwVu3FjR96cMPx+Fr+gpWRhIafcHwqwCqWS42RZhIudOvEI+Ckf6MA==\" data-cf-beacon='{\"rayId\":\"822462c69bc9160d\",\"b\":1,\"version\":\"2023.10.0\",\"token\":\"1bd18b8f69214e379ef7bd34509191ae\"}' crossorigin=\"anonymous\"></script>\n</body>\n\n\n\n</html>"
                            garmin.0
                            2023-11-07 10:00:25.455	debug	"<!DOCTYPE html>\n<html class=\"no-js\">\n\t<head>\n\t\t<title>Success</title>\n\t\t<meta charset=\"utf-8\">\n\t\t<meta http-equiv=\"X-UA-Compatible\" content=\"IE=edge;\" />\n\t\t<meta name=\"description\" content=\"\">\n\t\t<meta name=\"viewport\" content=\"width=device-width, initial-scale=1\">\n\t\t<meta http-equiv=\"cleartype\" content=\"on\">\n\t\t<script type=\"text/javascript\" src=\"/sso/js/jquery/3.7.1/jquery.min.js?20210319\"></script>\n\t\t<script type=\"text/javascript\">jQuery.noConflict();</script>\n\t\t<script type=\"text/javascript\" src=\"/sso/js/json2.js\"></script>\n\t\t<script type=\"text/javascript\" src=\"/sso/js/consoleUtils.js?20210319\"></script>\n\t\t<script type=\"text/javascript\" src=\"/sso/js/postmessage.js?20210319\"></script>\n\t\t<script type=\"text/javascript\">\n\t\t\tvar redirectAfterAccountLoginUrl \t = \"https:\\/\\/connect.garmin.com\\/modern\\/\";\n\t\t\tvar redirectAfterAccountCreationUrl = \"https:\\/\\/connect.garmin.com\\/modern\\/\";\n\t\t\tvar consumeServiceTicket \t = \"false\";\n\t\t\tvar service_url \t = \"https:\\/\\/connect.garmin.com\\/modern\\/\";\n\t\t\tvar parent_url \t = \"https:\\/\\/connect.garmin.com\\/signin\";\n\t\t\tvar response_url \t = \"https:\\/\\/connect.garmin.com\\/modern\\/?ticket=ST-0832024-LCBlkytjV1VKQhfBsJFR-cas\";\n\t\t\tvar logintoken \t = \"\";\n\t\t\tvar socialLogin \t = \"\";\n\t\t\tvar performMFACheck = \"false\";\n\n\t\t\t// Decode url if it's encoded unnecessarily (which is happening when SSO GAuth logins redisplay the login page due to session timeouts.)\n\t\t\tif (response_url.indexOf('%3A%2F%2F') != -1) {\n\t\t\t\tresponse_url = decodeURIComponent(response_url);\n\t\t\t}\n\t\t\tresponse_url = response_url.replace(new RegExp(\"&amp;\", 'g'),\"&\");\n\n\t\t\tvar service_ticket = response_url.substring(response_url.indexOf('ticket=') + 7, response_url.length);\n\n\t\t\tif (redirectAfterAccountLoginUrl) {\n\t\t\t\tconsoleInfo('casEmbedSuccess.html: redirectAfterAccountLoginUrl: [' + redirectAfterAccountLoginUrl + ']');\n\t\t\t}\n\t\t\tconsoleInfo('casEmbedSuccess.html: consumeServiceTicket: [' + consumeServiceTicket + ']');\n\t\t\tconsoleInfo('casEmbedSuccess.html: service_url: [' + service_url + ']');\n\t\t\tconsoleInfo('casEmbedSuccess.html: parent_url: [' + parent_url + ']');\n\t\t\tconsoleInfo('casEmbedSuccess.html: response_url: [' + response_url + ']');\n\t\t\tconsoleInfo('casEmbedSuccess.html: service_ticket: [' + service_ticket + ']');\n\t\t\tif (logintoken) {\n\t\t\t\tconsoleInfo('casEmbedSuccess.html: logintoken: [' + logintoken + ']');\n\t\t\t}\n\t\t\tif (socialLogin) {\n\t\t\t\tconsoleInfo('casEmbedSuccess.html: socialLogin: [' + socialLogin + ']');\n\t\t\t}\n\n\t\t\tfunction send(msg) {\n\t\t\t\tconsoleInfo('casEmbedSuccess.html: send(): Calling XD.postMessage(msg:[' + JSON.stringify(msg) + '], target_url:[' + parent_url + '])...');\n\t\t\t\tXD.postMessage(msg, parent_url, parent);\n\t\t\t\treturn false;\n\t\t\t}\n\n\t\t\tfunction redirect(target){\n\t\t\t\tvar embedWidget = \"false\";\n\t\t\t\tif (embedWidget != 'true') {\n\t\t\t\t\tif (logintoken || socialLogin) {\n\t\t\t\t\t\t// Tell parent to close opened Gauth lite box.\n\t\t\t\t\t\tsend({'closeLiteBox':'1'});\n\t\t\t\t\t} else {\n\t\t\t\t\t\t// Tell parent to resize Gauth widget's height to just that of the loading icon.\n\t\t\t\t\t\tsend({'gauthHeight':jQuery(\"#GAuth-component\").height()});\n\t\t\t\t\t}\n\t\t\t\t}\n\n\t\t\t\tif (window.opener != null) {\n\t\t\t\t\tvar iframeParent = window.opener.parent;\n\t\t\t\t\tiframeParent.location.href = target;\n\t\t\t\t\twindow.close();\n\t\t\t\t} else {\n\t\t\t\t\t// If the \"redirectAfterAccountLoginUrl\" GAuth config parameter was specified,\n\t\t\t\t\t// a full page refresh upon logon was requested, so redirect the parent window upon login.\n\t\t\t\t\tif (redirectAfterAccountLoginUrl || redirectAfterAccountCreationUrl || (socialLogin && socialLogin === 'true') || (performMFACheck && performMFACheck === 'true')) {\n\n\t\t\t\t\t\tif (embedWidget != 'true') {\n\t\t\t\t\t\t\tsend({'status':'SUCCESS', 'successDetails':'Login Successful'});\n\t\t\t\t\t\t}\n\n\t\t\t\t\t\t// Redirect parent of login iframe to requested service URL with ?ST=<Service Ticket ID> appended,\n\t\t\t\t\t\t// so the webapp can validate the service ticket and log the user on to the webapp.\n\t\t\t\t\t\tconsoleInfo('casEmbedSuccess.html: Calling parent.location.href = [' + response_url + '];...');\n\t\t\t\t\t\ttop.location.href = response_url;\n\n\t\t\t\t\t// Else if GAuth was configured not to consume the service ticket, send the service ticket and service url.\n\t\t\t\t\t// It's then up to the parent page to hide the GAuth widget and validate the service ticket.\n\t\t\t\t\t} else if (consumeServiceTicket == 'false') {\n\n\t\t\t\t\t\tsend({'status':'SUCCESS', 'successDetails':'Login Successful', 'serviceTicket':service_ticket, 'serviceUrl':service_url});\n\n\t\t\t\t\t} else {\n\t\t\t\t\t\t// Else consume the service ticket and log the user into the parent webapp, by making a JSONP request to the response url.\n\t\t\t\t\t\t// This service ticket request to the parent webapp will return a small amount of JSON that we\n\t\t\t\t\t\t// can send in the success event to the parent page to notify them of successful logon\n\t\t\t\t\t\t// It's then up to the parent page to hide the GAuth widget and do whatever it wants.\n\t\t\t\t\t\tconsoleInfo('casEmbedSuccess.html: Loading ajax jsonp URL: [' + response_url + ']');\n\t\t\t\t\t\tjQuery.ajax({\n\t\t\t\t\t\t\ttype: \"REDIRECT\",\n\t\t\t\t\t\t\turl: response_url,\n\t\t\t\t\t\t\tdataType: 'jsonp',\n\t\t\t\t\t\t\terror: function(xhr, status, error) {\n\t\t\t\t\t\t\t\tconsoleError('casEmbedSuccess.html: Error loading ajax jsonp URL: [' + response_url + ']! Error: ' + error);\n\t\t\t\t\t\t\t},\n\t\t\t\t\t\t\tsuccess: function( data, status, xhr ) {\n\t\t\t\t\t\t\t\tconsoleInfo('casEmbedSuccess.html: success loading ajax jsonp url. data: [' + data + ']');\n\t\t\t\t\t\t\t\tvar userdata = data;\n\t\t\t\t\t\t\t\tif (typeof(userdata) === 'string') {\n\t\t\t\t\t\t\t\t\tuserdata = JSON.parse(data);\n\t\t\t\t\t\t\t\t}\n\t\t\t\t\t\t\t\tconsoleInfo('casGenericRedirect.jsp: customerId: [' + userdata.customerId\n\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t+ '], username: [' + userdata.username\n\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t+ '], rememberMe: [' + userdata.rememberMe\n\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t+ '], password: [' + userdata.password\n\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t+ '], email: [' + userdata.email\n\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t+ '], displayName: [' + userdata.displayName\n\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t+ '], firstName: [' + userdata.firstName\n\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t+ '], lastName: [' + userdata.lastName\n\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t+ '], localePreference: [' + userdata.localePreference\n\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t+ '], addressLine1: [' + userdata.addressLine1\n\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t+ '], addressLine2: [' + userdata.addressLine2\n\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t+ '], cityName: [' + userdata.cityName\n\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t+ '], state: [' + userdata.state\n\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t+ '], postalCode: [' + userdata.postalCode\n\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t+ '], country: [' + userdata.country\n\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t+ '], passwordChangeRequired: [' + userdata.passwordChangeRequired\n\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t+ '], lastLogin: [' + userdata.lastLogin\n\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t+ '], erpCustomerNumber: [' + userdata.erpCustomerNumber\n\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t+ ']');\n\t\t\t\t\t\t\t\tsend({'status' : 'SUCCESS',\n\t\t\t\t\t\t\t\t\t\t\t'successDetails' : 'Login Successful',\n\t\t\t\t\t\t\t\t\t\t\t'customerId' : userdata.customerId,\n\t\t\t\t\t\t\t\t\t\t\t'username' : userdata.username,\n\t\t\t\t\t\t\t\t\t\t\t'rememberMe' : userdata.rememberMe,\n\t\t\t\t\t\t\t\t\t\t\t'password' : userdata.password,\n\t\t\t\t\t\t\t\t\t\t\t'email' : userdata.email,\n\t\t\t\t\t\t\t\t\t\t\t'displayName' : userdata.displayName,\n\t\t\t\t\t\t\t\t\t\t\t'firstName' : userdata.firstName,\n\t\t\t\t\t\t\t\t\t\t\t'lastName' : userdata.lastName,\n\t\t\t\t\t\t\t\t\t\t\t'localePreference' : userdata.localePreference,\n\t\t\t\t\t\t\t\t\t\t\t'addressLine1' : userdata.addressLine1,\n\t\t\t\t\t\t\t\t\t\t\t'addressLine2' : userdata.addressLine2,\n\t\t\t\t\t\t\t\t\t\t\t'cityName' : userdata.cityName,\n\t\t\t\t\t\t\t\t\t\t\t'state' : userdata.state,\n\t\t\t\t\t\t\t\t\t\t\t'postalCode' : userdata.postalCode,\n\t\t\t\t\t\t\t\t\t\t\t'country' : userdata.country,\n\t\t\t\t\t\t\t\t\t\t\t'passwordChangeRequired' : userdata.passwordChangeRequired,\n\t\t\t\t\t\t\t\t\t\t\t'lastLogin' : userdata.lastLogin,\n\t\t\t\t\t\t\t\t\t\t\t'erpCustomerNumber' : userdata.erpCustomerNumber\n\t\t\t\t\t\t\t\t});\n\t\t\t\t\t\t\t}\n\t\t\t\t\t\t});\n\t\t\t\t\t}\n\t\t\t\t}\n\t\t\t}\n\t\t</script>\n\t</head>\n\t<body>\n\t\t<div id=\"GAuth-component\">\n\t\t\t<img src='/sso/images/ajax-loader.gif' class=\"loaderImage\"/>\n\t\t</div>\n\t\t<script type=\"text/javascript\">\n\t\t\tjQuery(document).ready(function(){\n\t\t\t\tvar service = \"https:\\/\\/connect.garmin.com\\/modern\\/\";\n\t\t\t\tconsoleInfo(\"casEmbedSuccess.html: ready, calling redirect('\" + service + \"')...\");\n\t\t\t\tredirect(service);\n\t\t\t});\n\t\t</script>\n\t<script>(function(){var js = \"window['__CF$cv$params']={r:'822462bb5da144f8',t:'MTY5OTM0NzYyNS40NDEwMDA='};_cpo=document.createElement('script');_cpo.nonce='',_cpo.src='/cdn-cgi/challenge-platform/scripts/jsd/main.js',document.getElementsByTagName('head')[0].appendChild(_cpo);\";var _0xh = document.createElement('iframe');_0xh.height = 1;_0xh.width = 1;_0xh.style.position = 'absolute';_0xh.style.top = 0;_0xh.style.left = 0;_0xh.style.border = 'none';_0xh.style.visibility = 'hidden';document.body.appendChild(_0xh);function handler() {var _0xi = _0xh.contentDocument || _0xh.contentWindow.document;if (_0xi) {var _0xj = _0xi.createElement('script');_0xj.innerHTML = js;_0xi.getElementsByTagName('head')[0].appendChild(_0xj);}}if (document.readyState !== 'loading') {handler();} else if (window.addEventListener) {document.addEventListener('DOMContentLoaded', handler);} else {var prev = document.onreadystatechange || function () {};document.onreadystatechange = function (e) {prev(e);if (document.readyState !== 'loading') {document.onreadystatechange = prev;handler();}};}})();</script></body>\n</html>\n"
                            garmin.0
                            2023-11-07 10:00:24.108	debug	"<!DOCTYPE html>\n<html lang=\"en\" class=\"no-js\">\n <head>\n <meta http-equiv=\"Content-Type\" content=\"text/html; charset=UTF-8\" />\n <meta name=\"viewport\" content=\"width=device-width\" />\n <meta http-equiv=\"X-UA-Compatible\" content=\"IE=edge;\" />\n <title>GARMIN Authentication Application</title>\n <link href=\"/sso/css/GAuth.css?20210406\" rel=\"stylesheet\" type=\"text/css\" media=\"all\" />\n\n\t <link rel=\"stylesheet\" href=\"https://connect.garmin.com/gauth-custom-v1.2-min.css\"/>\n\n <script type=\"text/javascript\" src=\"/sso/js/jquery/3.7.1/jquery.min.js?20210319\"></script>\n <script type=\"text/javascript\">jQuery.noConflict();</script>\n\t\t<script type=\"text/javascript\" src=\"/sso/js/jquery-validate/1.16.0/jquery.validate.min.js?20210319\"></script>\n <script type=\"text/javascript\" src=\"/sso/js/jsUtils.js?20210406\"></script>\n <script type=\"text/javascript\" src=\"/sso/js/json2.js\"></script>\n <script type=\"text/javascript\" src=\"/sso/js/consoleUtils.js?20210319\"></script>\n <script type=\"text/javascript\" src=\"/sso/js/postmessage.js?20210319\"></script>\n <script type=\"text/javascript\" src=\"/sso/js/popupWindow.js\"></script>\n <script type=\"text/javascript\" src=\"/sso/js/base.js?20231020\"></script>\n\t\t<script type=\"text/javascript\" src=\"/sso/js/gigyaUtils.js?20210319\"></script>\n <script type=\"text/javascript\" src=\"/sso/js/login.js?20211102\"></script>\n <script type=\"text/javascript\" src=\"/sso/js/reCaptchaUtil.js?20230706\"></script>\n\n <script>\n var recaptchaSiteKey = null;\n var reCaptchaURL = \"\\\\\\/reCaptcha?service=https%3A%2F%2Fconnect.garmin.com%2Fmodern%2F\\u0026webhost=https%3A%2F%2Fconnect.garmin.com%2Fmodern%2F\\u0026source=https%3A%2F%2Fconnect.garmin.com%2Fsignin%2F\\u0026redirectAfterAccountLoginUrl=https%3A%2F%2Fconnect.garmin.com%2Fmodern%2F\\u0026redirectAfterAccountCreationUrl=https%3A%2F%2Fconnect.garmin.com%2Fmodern%2F\\u0026gauthHost=https%3A%2F%2Fsso.garmin.com%2Fsso\\u0026locale=en_GB\\u0026id=gauth-widget\\u0026cssUrl=https%3A%2F%2Fconnect.garmin.com%2Fgauth-custom-v1.2-min.css\\u0026privacyStatementUrl=https%3A%2F%2Fwww.garmin.com%2Fen-GB%2Fprivacy%2Fconnect%2F\\u0026clientId=GarminConnect\\u0026rememberMeShown=true\\u0026rememberMeChecked=false\\u0026createAccountShown=true\\u0026openCreateAccount=false\\u0026displayNameShown=false\\u0026consumeServiceTicket=false\\u0026initialFocus=true\\u0026embedWidget=false\\u0026socialEnabled=false\\u0026generateExtraServiceTicket=true\\u0026generateTwoExtraServiceTickets=true\\u0026generateNoServiceTicket=false\\u0026globalOptInShown=true\\u0026globalOptInChecked=false\\u0026mobile=false\\u0026connectLegalTerms=true\\u0026showTermsOfUse=false\\u0026showPrivacyPolicy=false\\u0026showConnectLegalAge=false\\u0026locationPromptShown=true\\u0026showPassword=true\\u0026useCustomHeader=false\\u0026mfaRequired=false\\u0026performMFACheck=false\\u0026rememberMyBrowserShown=true\\u0026rememberMyBrowserChecked=false\";\n var isRecaptchaEnabled = null;\n var recaptchaToken = null; \n </script>\n <script type=\"text/javascript\">\n var parent_url = \"https:\\/\\/connect.garmin.com\\/signin\\/\";\n var status \t\t\t= \"\";\n\t\t\tvar result = \"\";\n\t\t\tvar clientId\t\t= 'GarminConnect';\n\t\t\tvar embedWidget \t= false;\n\t\t\tvar isUsernameDefined = (false == true) || (false == true);\n\n // Gigya callback to SocialSignInController for brand new social network users redirects to this page\n // to popup Create or Link Social Account page, but has a possibly mangled source parameter\n // where \"?\" is set as \"<QM>\", so translate it back to \"?\" here.\n parent_url = parent_url.replace('<QM>', '?');\n var parent_scheme = parent_url.substring(0, parent_url.indexOf(\"://\"));\n var parent_hostname = parent_url.substring(parent_scheme.length + 3, parent_url.length);\n if (parent_hostname.indexOf(\"/\") != -1) {\n parent_hostname = parent_hostname.substring(0, parent_hostname.indexOf(\"/\"));\n }\n var parentHost \t = parent_scheme + \"://\" + parent_hostname;\n\t\t\tvar createAccountConfigURL = '\\/createNewAccount?service%3Dhttps%253A%252F%252Fconnect.garmin.com%252Fmodern%252F%26webhost%3Dhttps%253A%252F%252Fconnect.garmin.com%252Fmodern%252F%26source%3Dhttps%253A%252F%252Fconnect.garmin.com%252Fsignin%252F%26redirectAfterAccountLoginUrl%3Dhttps%253A%252F%252Fconnect.garmin.com%252Fmodern%252F%26redirectAfterAccountCreationUrl%3Dhttps%253A%252F%252Fconnect.garmin.com%252Fmodern%252F%26gauthHost%3Dhttps%253A%252F%252Fsso.garmin.com%252Fsso%26locale%3Den_GB%26id%3Dgauth-widget%26cssUrl%3Dhttps%253A%252F%252Fconnect.garmin.com%252Fgauth-custom-v1.2-min.css%26privacyStatementUrl%3Dhttps%253A%252F%252Fwww.garmin.com%252Fen-GB%252Fprivacy%252Fconnect%252F%26clientId%3DGarminConnect%26rememberMeShown%3Dtrue%26rememberMeChecked%3Dfalse%26createAccountShown%3Dtrue%26openCreateAccount%3Dfalse%26displayNameShown%3Dfalse%26consumeServiceTicket%3Dfalse%26initialFocus%3Dtrue%26embedWidget%3Dfalse%26socialEnabled%3Dfalse%26generateExtraServiceTicket%3Dtrue%26generateTwoExtraServiceTickets%3Dtrue%26generateNoServiceTicket%3Dfalse%26globalOptInShown%3Dtrue%26globalOptInChecked%3Dfalse%26mobile%3Dfalse%26connectLegalTerms%3Dtrue%26showTermsOfUse%3Dfalse%26showPrivacyPolicy%3Dfalse%26showConnectLegalAge%3Dfalse%26locationPromptShown%3Dtrue%26showPassword%3Dtrue%26useCustomHeader%3Dfalse%26mfaRequired%3Dfalse%26performMFACheck%3Dfalse%26rememberMyBrowserShown%3Dtrue%26rememberMyBrowserChecked%3Dfalse';\n var socialConfigURL = 'https://sso.garmin.com/sso/socialSignIn?service%3Dhttps%3A%2F%2Fconnect.garmin.com%2Fmodern%2F%26webhost%3Dhttps%3A%2F%2Fconnect.garmin.com%2Fmodern%2F%26source%3Dhttps%3A%2F%2Fconnect.garmin.com%2Fsignin%2F%26redirectAfterAccountLoginUrl%3Dhttps%3A%2F%2Fconnect.garmin.com%2Fmodern%2F%26redirectAfterAccountCreationUrl%3Dhttps%3A%2F%2Fconnect.garmin.com%2Fmodern%2F%26gauthHost%3Dhttps%3A%2F%2Fsso.garmin.com%2Fsso%26locale%3Den_GB%26id%3Dgauth-widget%26cssUrl%3Dhttps%3A%2F%2Fconnect.garmin.com%2Fgauth-custom-v1.2-min.css%26privacyStatementUrl%3Dhttps%3A%2F%2Fwww.garmin.com%2Fen-GB%2Fprivacy%2Fconnect%2F%26clientId%3DGarminConnect%26rememberMeShown%3Dtrue%26rememberMeChecked%3Dfalse%26createAccountShown%3Dtrue%26openCreateAccount%3Dfalse%26displayNameShown%3Dfalse%26consumeServiceTicket%3Dfalse%26initialFocus%3Dtrue%26embedWidget%3Dfalse%26socialEnabled%3Dfalse%26generateExtraServiceTicket%3Dtrue%26generateTwoExtraServiceTickets%3Dtrue%26generateNoServiceTicket%3Dfalse%26globalOptInShown%3Dtrue%26globalOptInChecked%3Dfalse%26mobile%3Dfalse%26connectLegalTerms%3Dtrue%26showTermsOfUse%3Dfalse%26showPrivacyPolicy%3Dfalse%26showConnectLegalAge%3Dfalse%26locationPromptShown%3Dtrue%26showPassword%3Dtrue%26useCustomHeader%3Dfalse%26mfaRequired%3Dfalse%26performMFACheck%3Dfalse%26rememberMyBrowserShown%3Dtrue%26rememberMyBrowserChecked%3Dfalse';\n var gigyaURL = \"https://cdns.gigya.com/js/gigya.js?apiKey=2_R3ZGY8Bqlwwk3_63knoD9wA_m-Y19mAgW61bF_s5k9gymYnMEAtMrJiF5MjF-U7B\";\n\n if (createAccountConfigURL.indexOf('%253A%252F%252F') != -1) {\n \tcreateAccountConfigURL = decodeURIComponent(createAccountConfigURL);\n }\n consoleInfo('signin.html embedWidget: false, createAccountConfigURL: \\/createNewAccount?service%3Dhttps%253A%252F%252Fconnect.garmin.com%252Fmodern%252F%26webhost%3Dhttps%253A%252F%252Fconnect.garmin.com%252Fmodern%252F%26source%3Dhttps%253A%252F%252Fconnect.garmin.com%252Fsignin%252F%26redirectAfterAccountLoginUrl%3Dhttps%253A%252F%252Fconnect.garmin.com%252Fmodern%252F%26redirectAfterAccountCreationUrl%3Dhttps%253A%252F%252Fconnect.garmin.com%252Fmodern%252F%26gauthHost%3Dhttps%253A%252F%252Fsso.garmin.com%252Fsso%26locale%3Den_GB%26id%3Dgauth-widget%26cssUrl%3Dhttps%253A%252F%252Fconnect.garmin.com%252Fgauth-custom-v1.2-min.css%26privacyStatementUrl%3Dhttps%253A%252F%252Fwww.garmin.com%252Fen-GB%252Fprivacy%252Fconnect%252F%26clientId%3DGarminConnect%26rememberMeShown%3Dtrue%26rememberMeChecked%3Dfalse%26createAccountShown%3Dtrue%26openCreateAccount%3Dfalse%26displayNameShown%3Dfalse%26consumeServiceTicket%3Dfalse%26initialFocus%3Dtrue%26embedWidget%3Dfalse%26socialEnabled%3Dfalse%26generateExtraServiceTicket%3Dtrue%26generateTwoExtraServiceTickets%3Dtrue%26generateNoServiceTicket%3Dfalse%26globalOptInShown%3Dtrue%26globalOptInChecked%3Dfalse%26mobile%3Dfalse%26connectLegalTerms%3Dtrue%26showTermsOfUse%3Dfalse%26showPrivacyPolicy%3Dfalse%26showConnectLegalAge%3Dfalse%26locationPromptShown%3Dtrue%26showPassword%3Dtrue%26useCustomHeader%3Dfalse%26mfaRequired%3Dfalse%26performMFACheck%3Dfalse%26rememberMyBrowserShown%3Dtrue%26rememberMyBrowserChecked%3Dfalse, socialEnabled: false, gigyaSupported: true, socialConfigURL(): https://sso.garmin.com/sso/socialSignIn?service%3Dhttps%3A%2F%2Fconnect.garmin.com%2Fmodern%2F%26webhost%3Dhttps%3A%2F%2Fconnect.garmin.com%2Fmodern%2F%26source%3Dhttps%3A%2F%2Fconnect.garmin.com%2Fsignin%2F%26redirectAfterAccountLoginUrl%3Dhttps%3A%2F%2Fconnect.garmin.com%2Fmodern%2F%26redirectAfterAccountCreationUrl%3Dhttps%3A%2F%2Fconnect.garmin.com%2Fmodern%2F%26gauthHost%3Dhttps%3A%2F%2Fsso.garmin.com%2Fsso%26locale%3Den_GB%26id%3Dgauth-widget%26cssUrl%3Dhttps%3A%2F%2Fconnect.garmin.com%2Fgauth-custom-v1.2-min.css%26privacyStatementUrl%3Dhttps%3A%2F%2Fwww.garmin.com%2Fen-GB%2Fprivacy%2Fconnect%2F%26clientId%3DGarminConnect%26rememberMeShown%3Dtrue%26rememberMeChecked%3Dfalse%26createAccountShown%3Dtrue%26openCreateAccount%3Dfalse%26displayNameShown%3Dfalse%26consumeServiceTicket%3Dfalse%26initialFocus%3Dtrue%26embedWidget%3Dfalse%26socialEnabled%3Dfalse%26generateExtraServiceTicket%3Dtrue%26generateTwoExtraServiceTickets%3Dtrue%26generateNoServiceTicket%3Dfalse%26globalOptInShown%3Dtrue%26globalOptInChecked%3Dfalse%26mobile%3Dfalse%26connectLegalTerms%3Dtrue%26showTermsOfUse%3Dfalse%26showPrivacyPolicy%3Dfalse%26showConnectLegalAge%3Dfalse%26locationPromptShown%3Dtrue%26showPassword%3Dtrue%26useCustomHeader%3Dfalse%26mfaRequired%3Dfalse%26performMFACheck%3Dfalse%26rememberMyBrowserShown%3Dtrue%26rememberMyBrowserChecked%3Dfalse');\n\n if (socialConfigURL.indexOf('%3A%2F%2F') != -1) {\n \tsocialConfigURL = decodeURIComponent(socialConfigURL);\n }\n\n if( status != null && status != ''){\n \tsend({'status':status});\n }\n\n jQuery(document).ready( function(){\n\n\n consoleInfo(\"signin.html: setting field validation rules...\");\n\n jQuery(\"#username\").rules(\"add\",{\n required: true,\n messages: {\n required: \"Email is required.\"\n }});\n\n jQuery(\"#password\").rules(\"add\", {\n required: true,\n messages: {\n required: \"Password is required.\"\n }\n });\n\n consoleInfo(\"signin.html: done setting field validation rules...\");\n\n });\n\n XD.receiveMessage(function(m){\n consoleInfo(\"signin.html: \" + m.data + \" received on \" + window.location.host);\n if (m && m.data) {\n var md = m.data;\n if (typeof(md) === 'string') {\n md = JSON.parse(m.data);\n }\n if (md.setUsername) {\n consoleInfo(\"signin.html: Setting username \\\"\" + md.username + \"\\\"...\");\n jQuery(\"#signInWithDiffLink\").click(); // Ensure the normal login form is shown.\n jQuery(\"#username\").val(md.username);\n jQuery(\"#password\").focus();\n }\n }\n }, parentHost);\n </script>\n </head>\n <body>\n\n <!-- begin GAuth component -->\n <div id=\"GAuth-component\">\n <!-- begin login component-->\n <div id=\"login-component\" class=\"blueForm-basic\">\n <input type=\"hidden\" id=\"queryString\" value=\"service=https%3A%2F%2Fconnect.garmin.com%2Fmodern%2F&amp;webhost=https%3A%2F%2Fconnect.garmin.com%2Fmodern%2F&amp;source=https%3A%2F%2Fconnect.garmin.com%2Fsignin%2F&amp;redirectAfterAccountLoginUrl=https%3A%2F%2Fconnect.garmin.com%2Fmodern%2F&amp;redirectAfterAccountCreationUrl=https%3A%2F%2Fconnect.garmin.com%2Fmodern%2F&amp;gauthHost=https%3A%2F%2Fsso.garmin.com%2Fsso&amp;locale=en_GB&amp;id=gauth-widget&amp;cssUrl=https%3A%2F%2Fconnect.garmin.com%2Fgauth-custom-v1.2-min.css&amp;privacyStatementUrl=https%3A%2F%2Fwww.garmin.com%2Fen-GB%2Fprivacy%2Fconnect%2F&amp;clientId=GarminConnect&amp;rememberMeShown=true&amp;rememberMeChecked=false&amp;createAccountShown=true&amp;openCreateAccount=false&amp;displayNameShown=false&amp;consumeServiceTicket=false&amp;initialFocus=true&amp;embedWidget=false&amp;socialEnabled=false&amp;generateExtraServiceTicket=true&amp;generateTwoExtraServiceTickets=true&amp;generateNoServiceTicket=false&amp;globalOptInShown=true&amp;globalOptInChecked=false&amp;mobile=false&amp;connectLegalTerms=true&amp;showTermsOfUse=false&amp;showPrivacyPolicy=false&amp;showConnectLegalAge=false&amp;locationPromptShown=true&amp;showPassword=true&amp;useCustomHeader=false&amp;mfaRequired=false&amp;performMFACheck=false&amp;rememberMyBrowserShown=true&amp;rememberMyBrowserChecked=false\" />\n\t \t <input type=\"hidden\" id=\"contextPath\" value=\"/sso\" />\n <!-- begin login form -->\n <div id=\"login-state-default\">\n <h2>Sign In</h2>\n\n <form method=\"post\" id=\"login-form\">\n\n <div class=\"form-alert\">\n\t\t\t\t\t\t\t\n \n \n \n \n \n \n\n <div id=\"username-error\" style=\"display:none;\"></div>\n <div id=\"password-error\" style=\"display:none;\"></div>\n </div>\n <div class=\"textfield\">\n\t\t\t\t\t\t\t<label for=\"username\">Email</label>\n \t\t<!-- If the lockToEmailAddress parameter is specified then we want to mark the field as readonly,\n \t\tpreload the email address, and disable the other input so that null isn't sent to the server. We'll\n \t\talso style the field to have a darker grey background and disable the mouse pointer\n \t\t -->\n\t\t\t\t\t\t\t \n\t\t\t\t\t\t\t\t<!-- If the lockToEmailAddress parameter is NOT specified then keep the existing functionality and disable the readonly input field\n\t\t\t\t\t\t\t -->\n\t\t\t\t\t\t\t <input class=\"login_email\" name=\"username\" id=\"username\" value=\"\" type=\"email\" spellcheck=\"false\" autocorrect=\"off\" autocapitalize=\"off\"/>\n\n </div>\n\n <div class=\"textfield\">\n <label for=\"password\">Password</label>\n <a id=\"loginforgotpassword\" class=\"login-forgot-password\" style=\"cursor:pointer\">(Forgot?)</a>\n <input type=\"password\" name=\"password\" id=\"password\" spellcheck=\"false\" autocorrect=\"off\" autocapitalize=\"off\" />\n <strong id=\"capslock-warning\" class=\"information\" title=\"Caps lock is on.\" style=\"display: none;\">Caps lock is on.</strong>\n\t\t\t\t\t </div>\n <input type=\"hidden\" name=\"embed\" value=\"false\"/>\n <input type=\"hidden\" name=\"_csrf\" value=\"30B49FDDC157F17F1A3F4266E7ED8D8C04EDF5487BBD88FE2C7F82976579D56A8B06DCB0784A2BE9E7ABCCBA93456A612BAB\" />\n <button type=\"submit\" id=\"login-btn-signin\" class=\"btn1\" accesskey=\"l\">Sign In</button>\n <span>\n\t <input type=\"checkbox\" name=\"rememberme\" id=\"login-remember-checkbox\" onClick=\"if (this.checked) { createAccountConfigURL += '&rememberme=on'; socialConfigURL += '&rememberme=on'; } else { createAccountConfigURL = createAccountConfigURL.replace('&rememberme=on', ''); socialConfigURL = socialConfigURL.replace('&rememberme=on', ''); }\"/>\n \t<label id=\"login-remember\" for=\"login-remember-checkbox\">Remember Me</label>\n </span>\n\n\n <!-- The existence of the \"rememberme\" parameter at all will remember the user! -->\n \n\n </form>\n </div>\n <!-- end login form -->\n\n <!-- begin Create Account message -->\n\t <div id=\"login-create-account\">\n\t <span>\n\t\t <span>Don&#39;t have an account?</span>\n\n\t \n\t <a href='javascript:void(0)' class=\"createAccountLink\" id=\"lnkCreateAccount\" title=\"Create Account\" >Create One</a>\n\t\t\t\t\t</span>\n\t </div>\n\t <!-- end Create Account message -->\n\n\t <!-- begin Social Sign In component -->\n\t <div id=\"SSI-component\">\n \n\n\t\t\t\t\t\n\t </div>\n\t <!-- end Social Sign In component -->\n <div class=\"clearfix\"></div> <!-- Ensure that GAuth-component div's height is computed correctly. -->\n </div>\n <!-- end login component-->\n\n\t\t</div>\n\t\t<!-- end GAuth component -->\n\n <script type=\"text/javascript\">\n jQuery(document).ready(function(){\n \tresizePageOnLoad(jQuery(\"#GAuth-component\").height());\n\n\t\t if(isUsernameDefined == true){\n\t\t // If the user's login just failed, redisplay the email/username specified, and focus them in the password field.\n\t\t jQuery(\"#password\").focus();\n\t\t } else if(true == true && result != \"PASSWORD_RESET_RESULT\"){\n // Otherwise focus them in the username field of the login dialog.\n jQuery(\"#username\").focus();\n }\n\n // Scroll to top of iframe to fix problem where Firefox 3.0-3.6 browsers initially show top of iframe cutoff.\n location.href=\"#\";\n\n if(!embedWidget){\n \tjQuery('.createAccountLink').click(function(){\n\t send({'openLiteBox':'createAccountLink', 'popupUrl': createAccountConfigURL, 'popupTitle':'Create An Account', 'clientId':clientId});\n\t });\n }\n });\n </script>\n <script>(function(){var js = \"window['__CF$cv$params']={r:'822462b56b45165b',t:'MTY5OTM0NzYyMy45MzEwMDA='};_cpo=document.createElement('script');_cpo.nonce='',_cpo.src='/cdn-cgi/challenge-platform/scripts/jsd/main.js',document.getElementsByTagName('head')[0].appendChild(_cpo);\";var _0xh = document.createElement('iframe');_0xh.height = 1;_0xh.width = 1;_0xh.style.position = 'absolute';_0xh.style.top = 0;_0xh.style.left = 0;_0xh.style.border = 'none';_0xh.style.visibility = 'hidden';document.body.appendChild(_0xh);function handler() {var _0xi = _0xh.contentDocument || _0xh.contentWindow.document;if (_0xi) {var _0xj = _0xi.createElement('script');_0xj.innerHTML = js;_0xi.getElementsByTagName('head')[0].appendChild(_0xj);}}if (document.readyState !== 'loading') {handler();} else if (window.addEventListener) {document.addEventListener('DOMContentLoaded', handler);} else {var prev = document.onreadystatechange || function () {};document.onreadystatechange = function (e) {prev(e);if (document.readyState !== 'loading') {document.onreadystatechange = prev;handler();}};}})();</script></body>\n</html>\n"
                            garmin.0
                            2023-11-07 10:00:23.113	info	Login to Garmin
                            garmin.0
                            2023-11-07 10:00:23.079	debug	Schedule restart: 57 23 * * *
                            garmin.0
                            2023-11-07 10:00:23.057	info	starting. Version 0.0.4 in /opt/iobroker/node_modules/iobroker.garmin, node: v18.17.1, js-controller: 5.0.16
                            admin.0
                            2023-11-07 10:00:09.969	warn	garmin has an invalid jsonConfig: [{"instancePath":"","schemaPath":"#/required","keyword":"required","params":{"missingProperty":"type"},"message":"must have required property 'type'"}]
                            • B bommel_030
                              @tombox
                              garmin.0
                              garmin.0
                              garmin.0
                              garmin.0
                              garmin.0
                              garmin.0
                              garmin.0
                              garmin.0
                              garmin.0
                              garmin.0
                              garmin.0
                              garmin.0
                              garmin.0
                              garmin.0
                              garmin.0
                              garmin.0
                              garmin.0
                              garmin.0
                              garmin.0
                              garmin.0
                              garmin.0
                              garmin.0
                              garmin.0
                              garmin.0
                              garmin.0
                              garmin.0
                              garmin.0
                              garmin.0
                              garmin.0
                              garmin.0
                              garmin.0
                              garmin.0
                              garmin.0
                              garmin.0
                              garmin.0
                              garmin.0
                              admin.0
                              tombox
                              #77
                              @bommel_030 und du darfst alle die werte über die Webseite abrufen. weil 402 bedeutet kein abo abgeschlossen
                              • T tombox
                                bommel_030
                                #78
                                @tombox
                                "aktiv" nutze ich nur die Basics wie Schritte / Stockwerke / Gewicht etc. Die kann ich von der Webseite auslesen.
                                Ich wüsste, mal abgesehen vom LTE Abo, wo ich bei Garmin eins abschließen könnte.
                                • K kirbsi
                                  tombox
                                  #79
                                  @kirbsi Bitte mal die GitHub version testen ob das so funktioniert
                                  B 2 Antworten Letzte Antwort
                                  • T tombox
                                    bommel_030
                                    #80
                                    @tombox
                                    Mit der github Version werden meine verwendeten Datenpunkte wieder aktualisiert. Danke schon mal dafür.
                                    Momentan läuft der Adapter seit 8h stabil. Bis jetzt hat er nach 2 bis 3 Tagen immer zum Passwort-Reset seitens Garmin geführt. Vielleicht passiert das jetzt auch nicht mehr.
                                    • T tombox
                                      bommel_030
                                      #81
                                      @tombox
                                      So, der Adapter hat jetzt knapp 7 Tage durchgehalten, eben bekam ich wieder die Mail von Garmin "Wir haben eine Anfrage zum Zurücksetzen deines Kennwortes erhalten." Das konnte ich jetzt schon mehrfach beobachten, sobald der Adapter läuft wird früher oder später das Passwort zurückgesetzt. Ist der Adapter aus kommt das nie. Im Log kommt dann verständlicherweise nur:
                                      garmin.0 2023-11-14 09:07:19.345	error	TypeError: Cannot read properties of undefined (reading 'split')
                                      garmin.0 2023-11-14 09:07:19.342	error	Failed ticket please check username and password
                                      Abrufintervall ist aktuell bei 61 Minuten. Hatte das Phänomen aber auch schon bei nur 1x täglich um 23:55 abrufen.
                                      Hast du eine Idee woran das liegen könnte?
                                      • B bommel_030
                                        @tombox
                                        tombox
                                        #82
                                        @bommel_030 bitte mal die GitHub version testen ob sie sich anders verhält
                                        • T tombox
                                          bommel_030
                                          #83
                                          @tombox
                                          Mit GitHub Version mit den gleichen Einstellungen wieder ins Rennen geschickt. Melde mich wenn/falls das Passwort wieder resettet wird. Thx
