  4. Test Adapter Weather-Warnings
1.1k Beiträge 36 Kommentatoren 496.8k Aufrufe 41 Beobachtet
  • Chris76eC Chris76e
    @sigi234
    stehe gerade auf dem schlauch, mit welchem Widget und wie kann ich die icon´s mit dem DP iconurl anzeigen lassen?
    sigi234S Online
    sigi234S Online
    #281
    @chris76e sagte in Test Adapter Weather-Warnings:
    @sigi234
    Widget:Edit
    [{"tpl":"tplImage","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","refreshInterval":"0","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"src":"/weather-warnings.admin/icons/black/storm.png","stretch":true},"style":{"left":"176px","top":"379px","z-index":"4","width":"100px","height":"100px"},"widgetSet":"basic"}]
    Chris76eC 1 Antwort Letzte Antwort
    • sigi234S sigi234
      @sigi234
      Widget:Edit
      Chris76eC Online
      Chris76eC Online
      Chris76e
      #282
      @sigi234
      aber da wird doch "per hand" ein Bild ausgesucht. Dachte das geht mit dem DP automatisch
        @sigi234
        T Nicht stören
        T Nicht stören
        ticaki
        #283
        @sigi234
        Das war auch so gedacht, wenn das nicht geht, baue ich im Admin ein Feld ein in dem man http://ip:port / https://ip:port selbst eingeben kann.
        Spenden
        M sigi234S Chris76eC 3 Antworten Letzte Antwort
        • T ticaki
          @sigi234
          Megawaldi
          #284
          @ticaki
          würde denn
          http://localhost:port oder
          https://localhost:port
          nicht funktionieren?
          • T ticaki
            @sigi234
            sigi234S Online
            sigi234S Online
            #285
            @ticaki sagte in Test Adapter Weather-Warnings:
            @sigi234
            So geht es bei mir:
            http://192.168.178.20:8082/adapter/weather-warnings/icons/black/storm.png
            Auch so:
            http://localhost:8082/adapter/weather-warnings/icons/black/storm.png
            • T ticaki
              @sigi234
              Chris76eC Online
              Chris76eC Online
              Chris76e
              #286
              @ticaki
              keine ahnung was besser ist. Habe die Wettersymbole von Adapter "DasWetter" bis jetzt so eingebunden, dann bräuchte man noch ein DP mit warntypenummer und eine Liste welce nummer für welchen type da ist.
              sigi234S T 2 Antworten Letzte Antwort
                @ticaki
                sigi234S Online
                sigi234S Online
                #287
                @ticaki
                Und welcher Provider
                Ist nicht so einfach mit den Icons.
                  @ticaki
                  T Nicht stören
                  T Nicht stören
                  ticaki
                  #288
                  @chris76e
                  @sigi234
                  Also ich hab die Tokens für Alexa eingebaut und en Urlprefixfeld. Paar Übersetzungen sind auch besser. Natürlich alles nicht getestet.
                  Eine einfache Liste gibts nicht wirklich: Man sieht hier welche Zahl welche Bedeutung hat: https://github.com/ticaki/ioBroker.weather-warnings/blob/322ccd2bd7a5617bf37b479ff05e029e525b6f76/src/lib/def/messages-def.ts#L302
                      '1': { name: 'genericWarntyp.1.name', id: 'unknown', dwdService: [], uwzService: [0, 1], zamgService: [0, 8] },
                      '2': {
                          dwdService: [40, 41, 44, 45, 48, 49, 51, 52, 53, 54, 55, 56, 57, 58, 96, 79],
                          uwzService: [2],
                          zamgService: [1],
                      '3': {
                          dwdService: [70, 71, 72, 73, 74, 75, 76],
                          uwzService: [3],
                          zamgService: [3],
                      '4': {
                          dwdService: [96, 95, 66, 65, 64, 63, 62, 61, 49, 48, 46, 45, 44, 42],
                          uwzService: [4],
                          zamgService: [2],
                      '5': { name: 'genericWarntyp.5.name', id: 'cold', dwdService: [82, 22], uwzService: [10, 11, 5], zamgService: [7] },
                      '6': { name: 'genericWarntyp.6.name', id: 'forest_fire', dwdService: [], uwzService: [6], zamgService: [] },
                      '7': {
                          dwdService: [90, 91, 92, 93, 95, 96, 31, 33, 34, 36, 38, 40, 41, 42, 44, 45, 46, 48, 49],
                          uwzService: [7],
                          zamgService: [5],
                      '8': {
                          dwdService: [87, 85, 84, 24],
                          uwzService: [8],
                          zamgService: [4],
                      '9': { name: 'genericWarntyp.9.name', id: 'heat', dwdService: [247, 248], uwzService: [9], zamgService: [6] },
                      '10': {
                          dwdService: [95, 96, 46, 48, 49],
                          uwzService: [],
                          zamgService: [],
                      '11': { name: 'genericWarntyp.11.name', id: 'fog', dwdService: [59], uwzService: [], zamgService: [] },
                      '12': { name: 'genericWarntyp.12.name', id: 'thaw', dwdService: [88, 89], uwzService: [], zamgService: [] },
                  Ah gibt doch ne Liste und zwar hier:
                  https://github.com/ticaki/ioBroker.weather-warnings/blob/72408c6b62074952775d61cf162ffa211b3616e5/admin/i18n/de/translations.json#L25
                  Ich könnte es auch noch in das Object formatedKeys.xx.genericwarntype rein schreiben. ins object common, weiß gerade nicht wie das heißt das zahlen als zeichenketten anzeigt.
                  Spenden
                  Chris76eC 2 Antworten Letzte Antwort
                  • T ticaki
                    @chris76e
                    @sigi234
                        '2': {
                            uwzService: [2],
                            zamgService: [1],
                        '3': {
                            uwzService: [3],
                            zamgService: [3],
                        '4': {
                            uwzService: [4],
                            zamgService: [2],
                        '7': {
                            uwzService: [7],
                            zamgService: [5],
                        '8': {
                            uwzService: [8],
                            zamgService: [4],
                        '10': {
                            uwzService: [],
                            zamgService: [],
                    Chris76eC Online
                    Chris76eC Online
                    Chris76e
                    #289
                    @ticaki
                    Wenn man die Symbole vom Adapternutzen will reicht es doch aus, wenn für diese
                        "genericWarntyp.1.name": "Unbekannt",
                        "genericWarntyp.10.name": "Hagel",
                        "genericWarntyp.11.name": "Nebel",
                        "genericWarntyp.12.name": "Tauwetter",
                        "genericWarntyp.2.name": "Sturm",
                        "genericWarntyp.3.name": "Schneefall",
                        "genericWarntyp.4.name": "Regen",
                        "genericWarntyp.5.name": "Kälte",
                        "genericWarntyp.6.name": "Waldbrand",
                        "genericWarntyp.7.name": "Gewitter",
                        "genericWarntyp.8.name": "Glatteis/rutschig",
                        "genericWarntyp.9.name": "Hitze",
                    die nummer ausgegeben wird. Mit den ganzen nummern von DWD wird das ja eh vielzuviel......
                      @ticaki
                      T Nicht stören
                      T Nicht stören
                      ticaki
                      #290
                      @ticaki
                      Nicht das wir an einander vorbei reden:
                      1. Es gibt im Admin ein Feld mit dem man das adapter/icons... um das fehlende http://192.168.x.x:8081 ergänzen kann (der / zwischen port und adapter wird ergänzt)
                      2. gibt es nicht... Mist, das ist nur Intern, genericwarntypenumber gibts dann demnächst auch in formatedKeys
                      Spenden
                      • T ticaki
                        @ticaki
                        Chris76eC Online
                        Chris76eC Online
                        Chris76e
                        #291
                        @ticaki 😊
                        • T ticaki
                          @chris76e
                          @sigi234
                              '2': {
                                  uwzService: [2],
                                  zamgService: [1],
                              '3': {
                                  uwzService: [3],
                                  zamgService: [3],
                              '4': {
                                  uwzService: [4],
                                  zamgService: [2],
                              '7': {
                                  uwzService: [7],
                                  zamgService: [5],
                              '8': {
                                  uwzService: [8],
                                  zamgService: [4],
                              '10': {
                                  uwzService: [],
                                  zamgService: [],
                          Chris76eC Online
                          Chris76eC Online
                          Chris76e
                          #292
                          Wenn ich das so für Alexa eingebe hört es sich richtig an
                          Hallo Christian. Es gibt eine ${headline}.     Die Warnung gilt von ${startdayofweek}  ${startday}ter  ${startmonth}ter  ${starttime} bis ${enddayofweek} ${endtime}.           Die Warnstufe ist ${warnlevelcolorname}
                          musste hinter startday und month jeweils ein ter schreiben
                          • rtwlR Offline
                            rtwlR Offline
                            rtwl
                            #293
                            ich denke es reicht, wenn es einen Datenpunkt "IconURL" gibt mit dem Pfad zum Icon.
                            DasWetter hat zb diesen Pfad in einem Datenpunkt als string: /adapter/daswetter/icons/tiempo-weather/galeria5/SVG/White/2.svg
                            einbinden in die VIS geht dann ganz einfach via Binding:
                            {daswetter.0.NextHours.Location_1.Day_1.current.iconURL}
                            Wichtig wäre dabei, dass man das Bild färben kann. keine Ahnung ob es mit der PNG möglich ist.
                            -Peter
                            • rtwlR rtwl
                              sigi234S Online
                              sigi234S Online
                              #294
                              @rtwl sagte in Test Adapter Weather-Warnings:
                              Ja
                              • T Nicht stören
                                T Nicht stören
                                ticaki
                                #295
                                Dann muß ich also nur ein / noch vor den adapter setzen... mit nächsten update ist es dann /adapter/adaptername/icons und das feld für den Prefix lass ich erstmal mal drin. dann mache ich es später raus und wenn sich wer beschwert kommts wieder rein. ;)
                                Spenden
                                • T ticaki
                                  Chris76eC Online
                                  Chris76eC Online
                                  Chris76e
                                  #296
                                  @ticaki kann es sein das unter command die Auslösung für Alexa nicht funktioniert? Zumindest sagt sie bei mir nichts, Telegram funktioniert. Beim neustart vom Adapter spricht Alexa mit mir
                                    sigi234S Online
                                    sigi234S Online
                                    #297
                                    Geht bei mir
                                      T Nicht stören
                                      T Nicht stören
                                      ticaki
                                      #298
                                      @chris76e
                                      guckmal ob bei Alexa auf der rechten Seite eine Vorlage ausgewählt ist.
                                      update
                                      • warntypegeneric - nummer des Warntyps und ne Liste in common.states (in Systemsprache) Ändern der Sprache von States erfordert löschen der States und restart des Adapters
                                      • / in iconurl ergänzt
                                      Und für weitere Iconsets - wenn ihr die drin haben wollt, wäre es nett wenn ihr mir die mit "warntype".png und einen Verweis auf den Urheber und die Lizenz zukommen lasst, dann sind die Fix drin - ich selbst brauch nen Abend für den Kram.
                                      Spenden
                                      Chris76eC rtwlR 3 Antworten Letzte Antwort
                                      • T ticaki
                                        @chris76e
                                        update
                                        Chris76eC Online
                                        Chris76eC Online
                                        Chris76e
                                        #299
                                        Fehler gefunden, hatte da nicht auf die Vorlage "Alexa" geändert. Da war die die Vorlage "NewMessage" drin und da das token ${description}. Das ${description} funktioniert nicht, kann es sein das es eine zeichen beschränkung für Alexa gibt?
                                          T Nicht stören
                                          T Nicht stören
                                          ticaki
                                          #300
                                          Steht in der Readme - 250 zeichen und dann muß ein ; kommen mache einfach nach jedem Token ein ; in die Vorlage. Hab noch kein Nina drin, da sollten die Texte nicht ganz so ausufern. Steht auch in der Readme zu Alexa2 :)
                                          Nach jeder Warnung fügt mein Code ein ; ein, deshalb auch die kleine Pause im Vorlesen.
                                          Spenden
