  3. Einsteigerfragen
  4. [Gelöst] Backup auf Synologie NAS
backitupnas
23 Beiträge 5 Kommentatoren 2.8k Aufrufe 6 Beobachtet
  • drsnuggles1982D Offline
    drsnuggles1982
    schrieb am zuletzt editiert von drsnuggles1982
    Hy,
    probiere grad mein backup auf meine NAS von Synolgie einzurichten. leider bekomme ich immer wieder Fehler beim mounten des laufwerks. Passwort und user name stimmen. von meinem Windows System kann ich alles ohne Probleme ereichen.
    Started iobroker ...
    [DEBUG] [mount] start with {"mountType":"CIFS","type":"storage","source":"local","mount":"//192.168.2.202","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","wolPort":"9","smb":"vers=2.0","sudo":false,"cifsDomain":"","clientInodes":false,"deleteOldBackup":false,"ownDir":false,"dir":"/Backup/Iobroker/Standard","dirMinimal":"sharename/backupDir","user":"felix","pass":"****","ignoreErrors":false}
    [DEBUG] [mount] - noserverino option: false
    [DEBUG] [mount] - cifs-mount command: "mount -t cifs -o username=felix,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777,vers=2.0 //192.168.2.202/Backup/Iobroker/Standard /opt/iobroker/backups"
    [DEBUG] [mount] - first mount attempt with smb option failed. try next mount attempt without smb option ...
    [DEBUG] [mount] - cifs-mount command: "mount -t cifs -o username=felix,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.2.202/Backup/Iobroker/Standard /opt/iobroker/backups"
    [ERROR] [mount] - [undefined Error: Command failed: mount -t cifs -o username=felix,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.2.202/Backup/Iobroker/Standard /opt/iobroker/backups
    mount.cifs: permission denied: no match for /opt/iobroker/backups found in /etc/fstab
    [ERROR] [mount] - Error: Command failed: mount -t cifs -o username=felix,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.2.202/Backup/Iobroker/Standard /opt/iobroker/backups
    Einstellungen im NAS sollten stimmen.
    Die Einstellungen in backitup sehen für mich auch gut aus
    Kann jemand mit den Ausgaben was anfangen? Bin noch zu unerfahren mit iobroker und Raspberry.
    Danke Felix
    • drsnuggles1982D drsnuggles1982
      Hy,
      Danke Felix
      Meister MopperM Online
      Meister Mopper
      @drsnuggles1982
      Welche Hardware hast du da?
      Proxmox und HA ...
      drsnuggles1982D 1 Antwort Letzte Antwort
        @drsnuggles1982
        drsnuggles1982
        @meister-mopper
        Raspberry Pi 4
        Plattform: linux
        Betriebssystem: linux
        Architektur: arm
        CPUs: 4
        Geschwindigkeit: 1500 MHz
        Modell: unknown
        RAM: 3.7 GB
        System-Betriebszeit: 11 T. 11:18:24
        Node.js: v16.19.1
        time: 1697440603544
        timeOffset: -120
        NPM: 8.19.3
        Adapter-Anzahl: 504
        Datenträgergröße: 58.2 GB
        Freier Festplattenspeicher: 54.5 GB
        Aktive Instanzen: 10
        Pfad: /opt/iobroker/
        Betriebszeit: 6 T. 21:47:51
        aktiv:
        MartinPM Thomas BraunT 3 Antworten Letzte Antwort
          @meister-mopper
          Raspberry Pi 4
          Plattform: linux
          Architektur: arm
          CPUs: 4
          Modell: unknown
          RAM: 3.7 GB
          Node.js: v16.19.1
          time: 1697440603544
          timeOffset: -120
          NPM: 8.19.3
          Adapter-Anzahl: 504
          aktiv:
          MartinPM Online
          MartinPM Online
          MartinP
          "... uid=iobroker,gid=iobroker..."
          Ist das denn auf dem Synology eingerichtet...
            @meister-mopper
            Raspberry Pi 4
            Plattform: linux
            Architektur: arm
            CPUs: 4
            Modell: unknown
            RAM: 3.7 GB
            Node.js: v16.19.1
            time: 1697440603544
            timeOffset: -120
            NPM: 8.19.3
            Adapter-Anzahl: 504
            aktiv:
            @drsnuggles1982
            Du musst das als root mounten. Also Option setzen .
            SMB-Typ auf 3.1.1.
            • MartinPM MartinP
              @martinp sagte in Backup auf Synologie NAS:
              Da muss nix aus der Synology eingerichtet sein, die uid und gid wird beim mounten über die Daten gelegt. Sonst würden die dem root gehören.
                @meister-mopper
                Raspberry Pi 4
                Plattform: linux
                Architektur: arm
                CPUs: 4
                Modell: unknown
                RAM: 3.7 GB
                Node.js: v16.19.1
                time: 1697440603544
                timeOffset: -120
                NPM: 8.19.3
                Adapter-Anzahl: 504
                aktiv:
                @drsnuggles1982 sagte in Backup auf Synologie NAS:
                Node.js: v16.19.1
                Bring das auf nodejs@18.
                Die 16 ist abgekündigt.
                  Node.js: v16.19.1
                  drsnuggles1982
                  @thomas-braun da Aust ja das Ziel. Wollte erstmal ein Backup machen und dann das Update.
                    @drsnuggles1982
                    Machst du bisher keine Backups?
                    iob nodejs-update
                    bringt die nodejs 18 an den Start.
                      @drsnuggles1982
                      iob nodejs-update
                      drsnuggles1982
                      @thomas-braun mein System ist grad mal zwei Wochen alt. Bin grade am umziehen von einer anderen Smartphone Umgebung. Jetzt hab ich einen Stand der funktioniert und wollte das Backup machen
                        @drsnuggles1982
                        Aber vor zwei Wochen war nodejs16 auch schon obsolet und es wurde vom Installer eine nodejs18 installiert.
                          @drsnuggles1982
                          drsnuggles1982
                          @thomas-braun nicht im raspberry Image.
                            Aber in 'richtigen' Installationen. Bei Fertigkost kann das sein. Aber u.a. aus diesem Grund halte ich diese Images für komplett unnötig.
                              drsnuggles1982
                              @thomas-braun ich bin ja bei dir ich brauche dieses Update. Wollte nur vorher das backup richtig machen. Wenn du mir sagts es liegt an de rNode.js version dann passt das für mich, dann amch ich ein old schoolbackup und zieh mir die daten dann runter.
                                @drsnuggles1982
                                Nein, es liegt an den falschen Optionen im Backitup.
                                Wie bereits gesagt muss das als root gemountet werden und den SMB-Dialekt auf 3.1.1
                                R drsnuggles1982D 2 Antworten Letzte Antwort
                                  @drsnuggles1982
                                  reutli
                                  schrieb am zuletzt editiert von reutli
                                  @thomas-braun sagte in Backup auf Synologie NAS:
                                  wenn möglich würde ich ohnehin auf NFS setzen
                                  iobroker in Debian-VM auf Proxmox Server (Ryzen 7 / 32GB / 1TB NVMe SSD) als Master - mehrere Raspberry Pis (3+4) als Slaves. InfluxDB V2 und Grafana auf LXC.
                                  *Wer freundlich ist, dem wird freundlich geholfen *
                                  • R reutli
                                    @reutli sagte in Backup auf Synologie NAS:
                                    Ja, natürlich.
                                      @drsnuggles1982
                                      drsnuggles1982
                                      das bringt keine Verbesserung
                                      [DEBUG] [mount] start with {"mountType":"CIFS","type":"storage","source":"local","mount":"//192.168.2.202","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","wolPort":"9","smb":"vers=3.1.1","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":false,"ownDir":false,"dir":"/Backup/Iobroker/Standard","dirMinimal":"sharename/backupDir","user":"felix","pass":"****","ignoreErrors":false}
                                      [DEBUG] [mount] - cifs-mount command: "sudo mount -t cifs -o username=felix,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777,vers=3.1.1 //192.168.2.202/Backup/Iobroker/Standard /opt/iobroker/backups"
                                      [DEBUG] [mount] - cifs-mount command: "sudo mount -t cifs -o username=felix,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.2.202/Backup/Iobroker/Standard /opt/iobroker/backups"
                                      [ERROR] [mount] - [undefined Error: Command failed: sudo mount -t cifs -o username=felix,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.2.202/Backup/Iobroker/Standard /opt/iobroker/backups
                                      mount error(13): Permission denied
                                      Refer to the mount.cifs(8) manual page (e.g. man mount.cifs) and kernel log messages (dmesg)
                                      [ERROR] [mount] - Error: Command failed: sudo mount -t cifs -o username=felix,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.2.202/Backup/Iobroker/Standard /opt/iobroker/backups
                                      R 1 Antwort Letzte Antwort
                                        reutli
                                        Permission denied
                                        User und Passwort stimmen und mehrfach geprüft?
                                        Spezielle Zeichen im Passwort?
                                        Lege mal auf der NAS neuen user mit "einfachem" Passwort an und prüfen mit dem User nochmals im Backitup-Adapter.
                                          Ja, natürlich.
                                          drsnuggles1982
                                          @thomas-braun mit NFS geht es jetzt hab noch ein Video gefunden welches dies erklärt. Hatte den Pfad nich korrekt eingefügt da der Volumen name gefehlt hat
                                          Danke!
                                          R 2 Antworten Letzte Antwort
