  3. Off Topic
  4. Raspberry Pi OS Lite 'Bookworm' ist da.
68 Beiträge 10 Kommentatoren 14.4k Aufrufe 6 Beobachtet
  • R reutli
    @martybr
    @Thomas-Braun
    So jetzt hänge ich bei der Slave Geschichte.
    Was habe ich gemacht:
    • neue SD Karte mit bookworm Image erstellt
    • gleicher Hostname und IP
    • iobroker auf Slave installiert
    pi@iobroker2:~ $ curl -sLf https://iobroker.net/install.sh | bash -
    library: loaded
    Library version=2023-10-13
        Welcome to the ioBroker installer!
        Installer version: 2023-10-13
        You might need to enter your password a couple of times.
        Installing prerequisites (1/4)
    Get:2 http://deb.debian.org/debian-security bookworm-security InRelease [48.0 kB]
    Get:3 http://archive.raspberrypi.com/debian bookworm InRelease [23.6 kB]
    Get:4 http://deb.debian.org/debian bookworm-updates InRelease [52.1 kB]
    Get:5 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages [77.0 kB]
    Get:6 http://deb.debian.org/debian-security bookworm-security/main armhf Packages [74.5 kB]
    Get:7 http://deb.debian.org/debian-security bookworm-security/main Translation-en [46.0 kB]
    Get:8 http://archive.raspberrypi.com/debian bookworm/main arm64 Packages [337 kB]
    Get:9 http://archive.raspberrypi.com/debian bookworm/main armhf Packages [345 kB]
    Fetched 1,003 kB in 3s (386 kB/s)
    Reading package lists... Done
    N: Repository 'http://archive.raspberrypi.com/debian bookworm InRelease' changed its 'Suite' value from 'testing' to 'stable'
        Node.js not found. Installing...
    Hit:1 http://archive.raspberrypi.com/debian bookworm InRelease
    Hit:2 http://deb.debian.org/debian bookworm InRelease
    Hit:3 http://deb.debian.org/debian-security bookworm-security InRelease
    Hit:4 http://deb.debian.org/debian bookworm-updates InRelease
    ca-certificates is already the newest version (20230311).
    gnupg is already the newest version (2.2.40-1.1).
    gnupg set to manually installed.
    The following packages will be upgraded:
      curl libcurl3-gnutls libcurl4
    3 upgraded, 0 newly installed, 0 to remove and 11 not upgraded.
    Need to get 1,035 kB of archives.
    After this operation, 0 B of additional disk space will be used.
    Get:1 http://deb.debian.org/debian-security bookworm-security/main arm64 curl arm64 7.88.1-10+deb12u4 [308 kB]
    Get:2 http://deb.debian.org/debian-security bookworm-security/main arm64 libcurl4 arm64 7.88.1-10+deb12u4 [366 kB]
    Get:3 http://deb.debian.org/debian-security bookworm-security/main arm64 libcurl3-gnutls arm64 7.88.1-10+deb12u4 [361 kB]
    Fetched 1,035 kB in 0s (3,235 kB/s)
    apt-listchanges: Reading changelogs...
    (Reading database ... 55058 files and directories currently installed.)
    Preparing to unpack .../curl_7.88.1-10+deb12u4_arm64.deb ...
    Unpacking curl (7.88.1-10+deb12u4) over (7.88.1-10+deb12u3) ...
    Preparing to unpack .../libcurl4_7.88.1-10+deb12u4_arm64.deb ...
    Unpacking libcurl4:arm64 (7.88.1-10+deb12u4) over (7.88.1-10+deb12u3) ...
    Preparing to unpack .../libcurl3-gnutls_7.88.1-10+deb12u4_arm64.deb ...
    Unpacking libcurl3-gnutls:arm64 (7.88.1-10+deb12u4) over (7.88.1-10+deb12u3) ...
    Setting up libcurl3-gnutls:arm64 (7.88.1-10+deb12u4) ...
    Setting up libcurl4:arm64 (7.88.1-10+deb12u4) ...
    Setting up curl (7.88.1-10+deb12u4) ...
    Processing triggers for man-db (2.11.2-2) ...
    Processing triggers for libc-bin (2.36-9+rpt2+deb12u3) ...
    deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_18.x nodistro main
     Processing triggers for man-db (2.11.2-2) ...ource1_arm64.deb ...led.)
    Installed nodejs
    Node.js Installed successfully!
    Changing npm registry to https://registry.npmjs.org
     Processing triggers for man-db (2.11.2-2) ...arm64.deb ... installed.)
    Installed acl
     Setting up libavahi-compat-libdnssd-dev:arm64 (0.8-10) ...-10_arm64.deb ...
    Installed libavahi-compat-libdnssd-dev
     Processing triggers for man-db (2.11.2-2) ...1) ...1_arm64.deb ...ed.)
    Installed libudev-dev
     Processing triggers for libc-bin (2.36-9+rpt2+deb12u3) .....m64.deb ...pt2) ...
    Installed libpam0g-dev
     Processing triggers for man-db (2.11.2-2) ...m64.deb ......installed.)
    Installed git
    Extracting templates from packages: 100%
     Setting up libcairo2-dev:arm64 (1.16.0-7+rpt1) ....u3) ...t1) .........rm64.deb ...
    Installed libcairo2-dev
     Processing triggers for libc-bin (2.36-9+rpt2+deb12u3) ...m64.deb ... ....
    Installed libpango1.0-dev
     Setting up libjpeg-dev:arm64 (1:2.1.5-2) ...5-2) ...4.deb ....deb ...)
    Installed libjpeg-dev
     Processing triggers for libc-bin (2.36-9+rpt2+deb12u3) ... installed.)
    Installed libgif-dev
     Processing triggers for libgdk-pixbuf-2.0-0:arm64 (2.42.10+dfsg-1+b1) ..........
    Installed librsvg2-dev
     Processing triggers for libc-bin (2.36-9+rpt2+deb12u3) .....nstalled.)
    Installed cmake
        Creating ioBroker user and directory (2/4)
    User iobroker created
    Directory /opt/iobroker created
        Installing ioBroker (3/4)
        Finalizing installation (4/4)
    Enabling autostart...
    Created symlink /etc/systemd/system/multi-user.target.wants/iobroker.service → /lib/systemd/system/iobroker.service.
    Autostart enabled!
        ioBroker was installed successfully
        Open http://192.168.200.42:8081 in a browser and start configuring!
    You need to re-login before doing anything else on the console!
    • Update gemacht
    pi@iobroker2:~ $ sudo apt update
    Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
    6 packages can be upgraded. Run 'apt list --upgradable' to see them.
    pi@iobroker2:~ $ sudo apt full-upgrade
    Calculating upgrade... Done
      libssl3 libwbclient0 openssl raspberrypi-net-mods raspi-config raspi-utils
    6 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
    Need to get 3,342 kB of archives.
    After this operation, 57.3 kB of additional disk space will be used.
    Do you want to continue? [Y/n] Y
    Get:1 http://archive.raspberrypi.com/debian bookworm/main arm64 libssl3 arm64 3.0.11-1~deb12u1+rpt1 [1,808 kB]
    Get:2 http://deb.debian.org/debian-security bookworm-security/main arm64 libwbclient0 arm64 2:4.17.12+dfsg-0+deb12u1 [52.8 kB]
    Get:3 http://archive.raspberrypi.com/debian bookworm/main arm64 openssl arm64 3.0.11-1~deb12u1+rpt1 [1,384 kB]
    Get:4 http://archive.raspberrypi.com/debian bookworm/main arm64 raspi-config all 20231013 [29.4 kB]
    Get:5 http://archive.raspberrypi.com/debian bookworm/main arm64 raspberrypi-net-mods all 1.4.0 [2,160 B]
    Get:6 http://archive.raspberrypi.com/debian bookworm/main arm64 raspi-utils arm64 20231013-1 [65.8 kB]
    Fetched 3,342 kB in 1s (4,305 kB/s)
    Reading changelogs... Done
    (Reading database ... 68262 files and directories currently installed.)
    Preparing to unpack .../0-libssl3_3.0.11-1~deb12u1+rpt1_arm64.deb ...
    Unpacking libssl3:arm64 (3.0.11-1~deb12u1+rpt1) over (3.0.11-1~deb12u1) ...
    Preparing to unpack .../1-libwbclient0_2%3a4.17.12+dfsg-0+deb12u1_arm64.deb ...
    Unpacking libwbclient0:arm64 (2:4.17.12+dfsg-0+deb12u1) over (2:4.17.11+dfsg-0+deb12u1) ...
    Preparing to unpack .../2-openssl_3.0.11-1~deb12u1+rpt1_arm64.deb ...
    Unpacking openssl (3.0.11-1~deb12u1+rpt1) over (3.0.11-1~deb12u1) ...
    Preparing to unpack .../3-raspi-config_20231013_all.deb ...
    Unpacking raspi-config (20231013) over (20231009) ...
    Preparing to unpack .../4-raspberrypi-net-mods_1.4.0_all.deb ...
    Unpacking raspberrypi-net-mods (1.4.0) over (1.3.4) ...
    Preparing to unpack .../5-raspi-utils_20231013-1_arm64.deb ...
    Unpacking raspi-utils (20231013-1) over (20230922+1-1~rc1) ...
    Setting up libssl3:arm64 (3.0.11-1~deb12u1+rpt1) ...
    Setting up raspi-utils (20231013-1) ...
    Setting up libwbclient0:arm64 (2:4.17.12+dfsg-0+deb12u1) ...
    Setting up openssl (3.0.11-1~deb12u1+rpt1) ...
    Setting up raspi-config (20231013) ...
    Setting up raspberrypi-net-mods (1.4.0) ...
    pi@iobroker2:~ $ sudo reboot
    Broadcast message from root@iobroker2 on pts/1 (Sun 2023-10-15 17:47:04 CEST):
    The system will reboot now!
    • alle Adapter gelöscht - Ergebnis:
    pi@iobroker2:~ $ iob list adapters
    • Multihost Connect versucht - keine Reaktion auch nach langer Zeit:
    pi@iobroker2:~ $ iobroker multihost connect
    • dann config versucht - keine Reaktion
    iob setup custom
    Current configuration:
    - Objects database:
      - Type: jsonl
      - Host/Unix Socket: 127.0.0.1
      - Port: 9001
    - States database:
      - Type: jsonl
      - Port: 9000
    - Data Directory: ../../iobroker-data/
    Type of objects DB [(j)sonl, (f)ile, (r)edis, ...], default [jsonl]:
    Host / Unix Socket of objects DB(jsonl), default[127.0.0.1]: 192.168.200.5
    Port of objects DB(jsonl), default[9001]:
    Type of states DB [(j)sonl, (f)file, (r)edis, ...], default [jsonl]:
    Host / Unix Socket of states DB (jsonl), default[192.168.200.5]:
    Port of states DB (jsonl), default[9000]:
    Host name of this machine [iobroker2]:
    updating conf/iobroker.json
    • reboot und nochmals versucht (hier steht die Maschine nun ohne weitere Reaktion):
    Broadcast message from root@iobroker2 on pts/1 (Sun 2023-10-15 18:12:16 CEST):
    pi@iobroker2:~ $ Connection to 192.168.200.42 closed by remote host.
    Connection to 192.168.200.42 closed.
    micha@iMac-Micha ~ % ssh pi@192.168.200.42
    pi@192.168.200.42's password:
    Linux iobroker2 6.1.0-rpi4-rpi-v8 #1 SMP PREEMPT Debian 1:6.1.54-1+rpt2 (2023-10-05) aarch64
    permitted by applicable law.
    Last login: Sun Oct 15 17:50:25 2023 from 192.168.200.167
    Zusätzlich auf dem Master:
    admin@macmini-iobroker:~$ iob multihost enable
    Multihost discovery server activated on this host. If iobroker is currently not running please start befeore trying to discover this host.
    Important: Multihost discovery works with UDP packets. Make sure they are routed correctly in your network. If you use Docker you also need to configure this correctly.
    Multihost discovery will be automatically deactivated after 15 minutes. If you want to activate it permanently use the --persist flag
    Discovery authentication activated.
    Enter secret phrase for connection:
    Repeat secret phrase for connection:
    Please check the binding of the configured jsonl server to allow remote connections.
    Please restart ioBroker for the changes to take effect: "iobroker restart"
    Multihost discovery server: enabled
    Discovery authentication:   enabled
    Persistent activation:      disabled
    Objects:                    jsonl on 0.0.0.0
    States:                     jsonl on 0.0.0.0
    sudo reboot
    ^C
    admin@macmini-iobroker:~$ sudo reboot
    [sudo] Passwort für admin:
    Connection to 192.168.200.5 closed by remote host.
    Connection to 192.168.200.5 closed.
    micha@iMac-Micha ~ % ssh admin@192.168.200.5
    admin@192.168.200.5's password:
    Linux macmini-iobroker 5.10.0-26-amd64 #1 SMP Debian 5.10.197-1 (2023-09-29) x86_64
    Last login: Sun Oct 15 18:09:41 2023 from 192.168.200.167
    admin@macmini-iobroker:~$ iob status
    Objects type: jsonl
    States  type: jsonl
    admin@macmini-iobroker:~$ iob multihost status
    No configuration change needed.
    Jetzt habe ich keine Idee mehr, wie ich den Slave reinbekomme...
    HomoranH Offline
    HomoranH Offline
    @reutli sagte in Raspberry Pi OS Lite 'Bookworm' ist da.:
    welche Node-Version? mit 18.18.0 gabs Probleme
    R 1 Antwort Letzte Antwort
      R Online
      R Online
      reutli
      auf demSlave:
      pi@iobroker2:~ $ node -v
      v18.18.2
      iobroker in Debian-VM auf Proxmox Server (Ryzen 7 / 32GB / 1TB NVMe SSD) als Master - mehrere Raspberry Pis (3+4) als Slaves. InfluxDB V2 und Grafana auf LXC.
      *Wer freundlich ist, dem wird freundlich geholfen *
      • R reutli
        auf demSlave:
        v18.18.2
        HomoranH Offline
        HomoranH Offline
        auf demSlave:
        v18.18.2
        und auf dem Master?
        • M MartyBr
          @reutli
          Ich habe es nun für mich gelöst. Das Problem war der io.js-controller. Ich habe ihn auf dem Master auf 5.0.11 und den Slave auf 4.0.24 downgegraded und dann konnte ich den Slave mit dem Master verbinden. Danach war es Easy.
          Auf dem Slave habe ich nur 3 Adapter laufen: BLE, SmartMeter und W-MBUS.
          Die Einstellungen und die USB-Verbindungen wurden auf dem Slave sauber erkannt. Bluetooth läuft unter Bookworm out of the Box. Keinerlei Verrenkungen mehr mit hciconfig etc.
          Zu Zigbee kann ich dir keinen Bericht geben, das läuft bei mir auf dem Master (auch Debian 12 Bookworm). Hier ohne Probleme. Der Master wurde aber nur upgedated und nicht neu erstellt.
          MartyBr
          @reutli
          Hast du auch die js-controller downgegraded? Das hat bei mir geholfen.
          @martybr sagte in Raspberry Pi OS Lite 'Bookworm' ist da.:
          @reutli
          Martin
          Homematic und Homematic IP
          R HomoranH 2 Antworten Letzte Antwort
            auf demSlave:
            v18.18.2
            und auf dem Master?
            R Online
            R Online
            reutli
            Master:
            admin@macmini-iobroker:~$ node -v
            v18.18.0
            dann ist's der Master? Also mit dem fixer-script von @Thomas-Braun ?
            • M MartyBr
              @reutli
              @reutli
              R Online
              R Online
              reutli
              @reutli
              wenn notwendig... wie?
              Will ich auf'm master ungern machen (da rennt 'ne Menge)...
              @Homoran reicht der Node-Update?
              • R reutli
                @reutli
                HomoranH Offline
                HomoranH Offline
                @reutli ich hab das nicht mehr zu Ende verfolgt.
                Ich kann es daher nicht versprechen
                  R Online
                  R Online
                  reutli
                  Habe auf'm Master nun 18.18.2 leider bleibt das Problem:
                  ioBroker nodejs fixer 2023-10-09
                  Recommended nodejs-version is: 18.18.2
                  Checking your installation now. Please be patient!
                  Your current setup is:
                  /usr/bin/nodejs 	v18.18.2
                  /usr/bin/node 		v18.18.2
                  /usr/bin/npm 		9.8.1
                  /usr/bin/npx 		9.8.1
                  /usr/bin/corepack 	0.19.0
                  We found these nodejs versions available for installation:
                  nodejs:
                    Installed: 18.18.2-1nodesource1
                    Candidate: 18.18.2-1nodesource1
                    Version table:
                   *** 18.18.2-1nodesource1 1001
                          500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
                       18.18.1-1nodesource1 1001
                       18.18.0-1nodesource1 1001
                       18.17.1-1nodesource1 1001
                       18.17.0-1nodesource1 1001
                       18.16.1-1nodesource1 1001
                       18.16.0-1nodesource1 1001
                       18.15.0-1nodesource1 1001
                       18.14.2-1nodesource1 1001
                       18.14.1-1nodesource1 1001
                       18.14.0-1nodesource1 1001
                       18.13.0-1nodesource1 1001
                       18.12.0-1nodesource1 1001
                       18.11.0-1nodesource1 1001
                       18.10.0-1nodesource1 1001
                       18.9.1-1nodesource1 1001
                       18.9.0-1nodesource1 1001
                       18.8.0-1nodesource1 1001
                       18.7.0-1nodesource1 1001
                       18.6.0-1nodesource1 1001
                       18.5.0-1nodesource1 1001
                       18.4.0-1nodesource1 1001
                       18.3.0-1nodesource1 1001
                       18.2.0-1nodesource1 1001
                       18.1.0-1nodesource1 1001
                       18.0.0-1nodesource1 1001
                       12.22.12~dfsg-1~deb11u4 500
                          500 http://deb.debian.org/debian bullseye/main amd64 Packages
                          500 http://security.debian.org/debian-security bullseye-security/main amd64 Packages
                  Nothing to do - Your installation is using the correct paths.
                  Nothing to do - Your version is the recommended one.
                  ***You can now keep your whole system up-to-date using the usual 'sudo apt update && sudo apt full-upgrade' commands. ***
                  *** DO NOT USE node version managers like 'nvm', 'n' and others in parallel. They will break your current installation! ***
                   *** DO NOT use 'nodejs-update' as part of a regular update process! ***
                  Multihost discovery server: disabled
                  ^C
                  admin@macmini-iobroker:~$ iobroker restart
                  Auf dem Slave bleibt es beim alten:
                  --> Kiste hängt
                  • M MartyBr
                    @reutli
                    @reutli
                    HomoranH Offline
                    HomoranH Offline
                    @reutli
                    mist!
                    dann bleibt wohl nur es so zu versuchen
                    @reutli
                      @reutli
                      mist!
                      @reutli
                      R Online
                      R Online
                      reutli
                      ähhh, und wie sieht es mit einem 'how to' aus und 'root cause analysis'?
                      Bevor ich da ran gehe, wüsste ich schon, warum js-contoller und vor allem Konsequenzen... habe einen Master (mit viel drauf) und zwei Salzes am rennen als Prod-System- da möchte ich nur berechenbares Risiko eingehen.
                      • R reutli
                        HomoranH Offline
                        HomoranH Offline
                        root cause analysis
                        ich denke das wird gerade gemacht. ich hab das wohlt durcheinander gebracht mit der node version.
                        sieh dir den Thread dazu mal an
                        müsste der von @MartyBr gewesen sein
                          root cause analysis
                          R Online
                          R Online
                          reutli
                          Ja, habe ich gelesen, weiss aber nicht, warum der downgrade benötigt wird.
                          Dazu müsste es ja schon was geben.
                          Wenn ich auf meinem Prod-Master (mit für mich unbekannten Konsequenzen!) ein dorngrade machen soll, dann müsst ich da gerne ein bisschen mehr.
                          Offen ist auch das 'how to' für das downgrade und wo notwendig...
                          Da hängt ein ganzes Haus dran....
                          • R reutli
                            HomoranH Offline
                            HomoranH Offline
                            was?
                              was?
                              R Online
                              R Online
                              reutli
                              schrieb am zuletzt editiert von reutli
                              @homoran sagte in Raspberry Pi OS Lite 'Bookworm' ist da.:
                              was?
                              technische Begründung, Anleitung, welche Version, wo wann in welcher Konstellation (master zu Slave)
                              HomoranH M 2 Antworten Letzte Antwort
                              • R reutli
                                was?
                                HomoranH Offline
                                HomoranH Offline
                                was?
                                Da verlangst du aber ein bischen viel!
                                der "Fehler" ist doch gerade das erste mal beobachtet worden und versucht einzugrenzen.
                                Wie soll es da sofirt ein Rundumsorglos Paket geben, wenn es erst einen Fall gibt und das Ganze nicht einmal verifiziert wurde.
                                • R reutli
                                  was?
                                  MartyBr
                                  schrieb am zuletzt editiert von MartyBr
                                  @reutli
                                  Das lief bei mir ohne Probleme ab:
                                  cd /opt/iobroker
                                  npm install iobroker.js-controller@5.0.11
                                  Martin
                                  • M MartyBr
                                    @reutli
                                    cd /opt/iobroker
                                    R Online
                                    R Online
                                    reutli
                                    @martybr
                                    Das ist ja genau die Frage(n):
                                    1. warum ist der downgrade in Sachen Multi-Host notwendig?
                                    2. Downgrade auf welchen notwendig? Master und/oder Slave?
                                    3. Danach Update wieder möglich?
                                    4. Über NPM habe ich gelernt nicht "korrekt"?!
                                    • R reutli
                                      @martybr
                                      HomoranH Offline
                                      HomoranH Offline
                                      nochmal!
                                      Das weiss noch niemand!
                                      .../geprüft
                                        nochmal!
                                        .../geprüft
                                        R Online
                                        R Online
                                        reutli
                                        ok, verstanden.
                                        und der Rest?
                                          MartyBr
                                          @reutli
                                          Wie @Homoran sagte, der Fehler/das Problem ist in Prüfung. Ich beschreibe nur einen Workaround der mir geholfen hat.
                                          Master auf 5.0.11 und Slave auf die 4.0.24
                                          Nach Kopplung kannst du bei Server auf die aktuelle Version 5.0.12 heben.
                                          Martin
