  4. iobroker zeschossen
iobroker zeschossen
175 Beiträge 9 Kommentatoren 48.8k Aufrufe 7 Beobachtet
  • KrisiunK Krisiun
    Hallo allerseits, ich habe gestern versucht Nodje auf die neueste Version zu aktualisieren und hab bestimmt was falsch gemacht. Jetzt startet iob überhaupt nicht mehr.
    Bei " iobroker start" über Konsole kommt:
    root@Marek2:~# iobroker start
    /usr/bin/node: 1: cannot create : Permission denied
    /usr/bin/node: 2: : not found
    /usr/bin/node: 4: Syntax error: Unterminated quoted string
    Wenn ich " iob diag " mache kommt das:
    Skript v.2023-06-20
    *** BASE SYSTEM ***
    Failed to connect to bus: Host is down
    model name      : Intel(R) Core(TM) i7-6700HQ CPU @ 2.60GHz
    Docker          : false
    Virtualization  : wsl
    Kernel          : x86_64
    Userland        : amd64
    Systemuptime and Load:
     18:46:07 up 27 min,  0 users,  load average: 0.52, 0.58, 0.59
    CPU threads: 8
    *** Time and Time Zones ***
    System has not been booted with systemd as init system (PID 1). Can't operate.
    *** User and Groups ***
    root
    /root
    root
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:
    *** MEMORY ***
    Mem:             16G        5.9G         10G         17M        223M         10G
    Swap:            30G          0B         30G
    Total:           46G        5.9G         40G
    Error: /proc must be mounted
      To mount /proc at boot you need an /etc/fstab line like:
          proc   /proc   proc    defaults
      In the meantime, run "mount proc /proc -t proc"
    *** FILESYSTEM ***
    Filesystem     Type   Size  Used Avail Use% Mounted on
    rootfs         lxfs   238G  195G   43G  83% /
    none           tmpfs  238G  195G   43G  83% /dev
    none           tmpfs  238G  195G   43G  83% /run
    none           tmpfs  238G  195G   43G  83% /run/lock
    none           tmpfs  238G  195G   43G  83% /run/shm
    none           tmpfs  238G  195G   43G  83% /run/user
    tmpfs          tmpfs  238G  195G   43G  83% /sys/fs/cgroup
    C:\            drvfs  238G  195G   43G  83% /mnt/c
    D:\            drvfs  932G  541G  391G  59% /mnt/d
    TARGET   SOURCE FSTYPE OPTIONS
    /        rootfs lxfs   rw,noatime
    |-/mnt/c C:\    drvfs  rw,noatime,uid=0,gid=0,case=off
    `-/mnt/d D:\    drvfs  rw,noatime,uid=0,gid=0,case=off
    /var:
    428M    /var/
    330M    /var/lib
    157M    /var/lib/snapd/seed/snaps
    157M    /var/lib/snapd
    No journal files were found.
    Archived and active journals take up 0B in the file system.
    /opt/iobroker/backups:
    103M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    431M    /opt/iobroker/iobroker-data/
    285M    /opt/iobroker/iobroker-data/files
    107M    /opt/iobroker/iobroker-data/backup-objects
    72M     /opt/iobroker/iobroker-data/files/telegram.admin
    52M     /opt/iobroker/iobroker-data/files/javascript.admin
    21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js.map
    19M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.2975a411.js.map
    15M     /opt/iobroker/iobroker-data/objects.jsonl
    15M     /opt/iobroker/iobroker-data/files/telegram.admin/rules/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-1d9f06.44fe4a3f.chunk.js.map
    8.9M    /opt/iobroker/iobroker-data/files/scenes.admin/static/js/2.7de3299d.chunk.js.map
    *** NodeJS-Installation ***
    /home/iobroker/.diag.sh: line 177: /usr/bin/nodejs: cannot execute binary file: Exec format error
    /usr/bin/nodejs
    /home/iobroker/.diag.sh: line 178: /usr/bin/node: cannot execute binary file: Exec format error
    /usr/bin/node
    /mnt/c/Windows/system32/npm
    : not foundram Files/nodejs/npx: 2:
    : not foundram Files/nodejs/npx: 5:
    : not foundram Files/nodejs/npx: 7:
    : not foundram Files/nodejs/npx: 9:
    /mnt/c/Program Files/nodejs/npx: 10: Syntax error: word unexpected (expecting "in")
    /home/iobroker/.diag.sh: line 186: /usr/bin/nodejs: cannot execute binary file: Exec format error
    /home/iobroker/.diag.sh: line 187: /usr/bin/node: cannot execute binary file: Exec format error
    *** nodejs is NOT correctly installed ***
    nodejs:
      Installed: 12.22.9~dfsg-1ubuntu3
      Candidate: 12.22.9~dfsg-1ubuntu3
      Version table:
     *** 12.22.9~dfsg-1ubuntu3 500
            500 http://archive.ubuntu.com/ubuntu jammy/universe amd64 Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Core adapters versions
    js-controller:
    admin:
    javascript:
    Adapters from github:   0
    Adapter State
    ioBroker-Repositories
    Installed ioBroker-Instances
    Objects and States
    Objects:        0
    States:         0
    W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://dl.yarnpkg.com/debian stable InRelease: The following signatures were invalid: EXPKEYSIG 23E7166788B63E1E Yarn Packaging <yarn@dan.cx>
    W: Failed to fetch https://dl.yarnpkg.com/debian/dists/stable/InRelease  The following signatures were invalid: EXPKEYSIG 23E7166788B63E1E Yarn Packaging <yarn@dan.cx>
    W: Some index files failed to download. They have been ignored, or old ones used instead.
    Get:1 https://dl.yarnpkg.com/debian stable InRelease [17.1 kB]
    Hit:2 http://security.ubuntu.com/ubuntu jammy-security InRelease
    Hit:3 http://archive.ubuntu.com/ubuntu jammy InRelease
    Hit:4 http://archive.ubuntu.com/ubuntu jammy-updates InRelease
    Hit:5 http://archive.ubuntu.com/ubuntu jammy-backports InRelease
    Err:1 https://dl.yarnpkg.com/debian stable InRelease
    Fetched 17.1 kB in 3s (5230 B/s)
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    2023-10-07 21:49:27.501  - info: host.Marek2 instance system.adapter.kodi.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-10-07 21:49:27.502  - info: host.Marek2 instance system.adapter.tr-064.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-10-07 21:49:27.502  - info: host.Marek2 instance system.adapter.shelly.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-10-07 21:49:27.502  - info: host.Marek2 stopInstance system.adapter.pushover.0 killing pid 9396
    2023-10-07 21:49:27.537  - info: host.Marek2 instance system.adapter.discovery.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-10-07 21:49:27.538  - info: host.Marek2 instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-10-07 21:49:27.539  - info: host.Marek2 instance system.adapter.javascript.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-10-07 21:49:27.634  - info: host.Marek2 stopInstance system.adapter.web.0 killing pid 10344
    2023-10-07 21:49:27.635  - info: host.Marek2 stopInstance system.adapter.philips-tv.0 killing pid 10481
    2023-10-07 21:49:27.647  - info: host.Marek2 instance system.adapter.sonoff.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-10-07 21:49:27.668  - info: host.Marek2 instance system.adapter.iot.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-10-07 21:49:27.668  - info: host.Marek2 instance system.adapter.broadlink2.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-10-07 21:49:27.730  - info: host.Marek2 instance system.adapter.info.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-10-07 21:49:27.730  - info: host.Marek2 instance system.adapter.yahka.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-10-07 21:49:27.730  - info: host.Marek2 instance system.adapter.tankerkoenig.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-10-07 21:49:27.765  - info: host.Marek2 instance system.adapter.firetv.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-10-07 21:49:27.765  - info: host.Marek2 instance system.adapter.parcel.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-10-07 21:49:27.839  - info: host.Marek2 instance system.adapter.web.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-10-07 21:49:27.840  - info: host.Marek2 instance system.adapter.philips-tv.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-10-07 21:49:27.901  - info: host.Marek2 instance system.adapter.pushover.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-10-07 21:49:29.473  - info: tuya.0 (9456) terminating
    2023-10-07 21:49:29.475  - info: tuya.0 (9456) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2023-10-07 21:49:30.080  - info: host.Marek2 instance system.adapter.tuya.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-10-07 21:49:30.081  - info: host.Marek2 All instances are stopped.
    2023-10-07 21:49:30.150  - info: host.Marek2 terminated
    Kann mir da jemand helfen oder ist das schon ein hofnungsose Fahl?
    GlasfaserG Offline
    GlasfaserG Offline
    @krisiun sagte in iobroker zeschossen:
    eine Normal Abfrage funktioniert ja noch nicht mal.
    Ich denke mal da ist Linux zerschossen
    • KrisiunK Krisiun
      Ich habe schon verstanden. Macht mich nicht noch mehr fertig als ich schon bin.
      Die istallation auf Windows rechner war für mich für Testzwecke. Ich wollte nicht riskieren aufm rassby zu experimentieren.
      Eins möchte ich von Euch wissen? Kann man die installation noch retten oder nicht?
      Keine Ahnung. Du kannst ja nicht sagen, was du da wo mit root-Rechten herumgefummelt hast.
      Ich würde zuerstmal ordentliche user anlegen, den root dann in Ruh' lassen und ordentlich das nodesource-Repo anlegen.
      • KrisiunK Krisiun
        bahnuhrB Online
        bahnuhrB Online
        bahnuhr
        Hab ich alles hinter mir.
        Kauf dir ein ordentliches System (z.B. nuc) und mach proxmox drauf. Dann kannst du ganz schnell ein backup machen; und dies evtl. wieder zurück spielen.
        Fazit:
        nuc kaufen
        proxmox drauf
        backup von deinem backitup einspielen.
        Fertig.
        P.S.
        was ist ein rassby ?
        Danke.
        • GlasfaserG Glasfaser
          @glasfaser sagte in iobroker zeschossen:
          Ich vermute, das wsl bootet nicht per systemd.
          Edit:
          Näheres hier
          https://devblogs.microsoft.com/commandline/systemd-support-is-now-available-in-wsl/
          KrisiunK 1 Antwort Letzte Antwort
            Edit:
            Näheres hier
            KrisiunK Offline
            KrisiunK Offline
            Krisiun
            @thomas-braun sagte in iobroker zeschossen:
            Nein leider nicht
            • bahnuhrB bahnuhr
              Fazit:
              nuc kaufen
              proxmox drauf
              Fertig.
              P.S.
              GlasfaserG Offline
              GlasfaserG Offline
              @bahnuhr sagte in iobroker zeschossen:
              KrisiunK bahnuhrB 2 Antworten Letzte Antwort
                KrisiunK Offline
                KrisiunK Offline
                Krisiun
                Raspberry Pi
                  bahnuhrB Online
                  bahnuhrB Online
                  bahnuhr
                  @glasfaser
                  Das ist cool.
                  Bild bitte per Link ;-)
                  Danke.
                  • KrisiunK Offline
                    KrisiunK Offline
                    Krisiun
                    Danke Euch trotzdem. Dann muss ich wohl wieder von vorne anfangen 😧
                    Thomas BraunT GlasfaserG 2 Antworten Letzte Antwort
                    • KrisiunK Krisiun
                      Was hast du denn jetzt von den bisherigen Ansätzen umgesetzt?
                      User angelegt?
                      Diesem die Gruppenzugehörigkeit zu adm,sudo,iobroker gegeben?
                      nodesource-Repo hinzugefügt?
                      nodejs aus diesem dann installiert?
                        User angelegt?
                        KrisiunK Offline
                        KrisiunK Offline
                        Krisiun
                        https://forum.iobroker.net/topic/35090/howto-nodejs-installation-und-upgrades-unter-debian
                        Die Anleitung probiert
                        • KrisiunK Krisiun
                          GlasfaserG Offline
                          GlasfaserG Offline
                          Bei 0 .. nicht , du hast doch Backups !
                          • KrisiunK Krisiun
                            Mit welchem Resultat?
                              KrisiunK Offline
                              KrisiunK Offline
                              Krisiun
                              @glasfaser
                              ja habe ich ist zwar schon alt aber egal
                                KrisiunK Offline
                                KrisiunK Offline
                                Krisiun
                                Kein Erfolg
                                • KrisiunK Krisiun
                                  Kein Erfolg
                                  Kein Erfolg
                                  Konkreter?
                                  iob diag
                                  sagt nun?
                                  • KrisiunK Krisiun
                                    @glasfaser
                                    GlasfaserG Offline
                                    GlasfaserG Offline
                                    Mhh ...
                                    ich wollte jetzt nicht in eine offene Wunde rumbohren .
                                    Aber ein Backup ist das A und O und auch vor Veränderungen an ioBroker / System
                                      Kein Erfolg
                                      Konkreter?
                                      iob diag
                                      sagt nun?
                                      KrisiunK Offline
                                      KrisiunK Offline
                                      Krisiun
                                      Skript v.2023-06-20
                                      *** BASE SYSTEM ***
                                      Docker          : false
                                      Kernel          : x86_64
                                      Userland        : amd64
                                       20:04:03 up  1:45,  0 users,  load average: 0.52, 0.58, 0.59
                                      CPU threads: 8
                                      root
                                      /root
                                      root
                                      X-Server:       false
                                      Desktop:
                                      Terminal:
                                      *** MEMORY ***
                                      Mem:             16G        7.6G        8.5G         17M        223M        8.6G
                                      Swap:            30G         11M         30G
                                      Total:           46G        7.6G         38G
                                      *** FILESYSTEM ***
                                      /var:
                                      457M    /var/
                                      329M    /var/lib
                                      157M    /var/lib/snapd
                                      /usr/bin/nodejs
                                      /usr/bin/node
                                      E: Malformed line 1 in source list /etc/apt/sources.list.d/nodesource.list (type)
                                      E: The list of sources could not be read.
                                      ioBroker Status
                                      js-controller:
                                      admin:
                                      javascript:
                                      Adapter State
                                      Objects and States
                                      Objects:        0
                                      States:         0
                                      Pending Updates:
                                      • KrisiunK Offline
                                        KrisiunK Offline
                                        Krisiun
                                                             v.2023-06-20
                                        Installation:           wsl
                                        Kernel:                 x86_64
                                        Userland:               amd64
                                        Timezone:
                                        User-ID:                0
                                        X-Server:               false
                                        Pending OS-Updates:
                                        Pending iob updates:    0
                                        /home/iobroker/.diag.sh: line 374: /usr/bin/nodejs: cannot execute binary file: Exec format error
                                        Nodejs-Installation:    /usr/bin/nodejs
                                        /home/iobroker/.diag.sh: line 375: /usr/bin/node: cannot execute binary file: Exec format error
        /usr/bin/node
                                        Recommended versions are nodejs 18.x.y and npm 9.x.y
                                        MEMORY:
                                        Mem:             16G        7.6G        8.4G         17M        223M        8.5G
                                        Swap:            30G         11M         30G
                                        Total:           46G        7.6G         38G
                                        Active iob-Instances:   0
                                        ioBroker Core:          js-controller
        admin
                                        ioBroker Status:
                                        Objects:                0
                                        States:                 0
                                        Size of iob-Database:
                                        5.6M    /opt/iobroker/iobroker-data/objects.json.migrated
                                        5.6M    /opt/iobroker/iobroker-data/objects.json.bak.migrated
                                        2.3M    /opt/iobroker/iobroker-data/states.jsonl
                                        808K    /opt/iobroker/iobroker-data/states.json.migrated
                                        808K    /opt/iobroker/iobroker-data/states.json.bak.migrated
                                          Mhh ...
                                          KrisiunK Offline
                                          KrisiunK Offline
                                          Krisiun
                                          Mhh ...
                                          Ich weiß. Wenn wir das mal wieder zum laufen bringen sollten dann werde ich bestimmt als erstes ein Backup machen
