  4. Wert aus Modbus lesen und bei änderung größer als…..auf KNX Objekt senden
61 Beiträge 4 Kommentatoren 11.8k Aufrufe 1 Beobachtet
    alexmosel
    ` > 13:42:48.281 [warn] javascript.0 at Object. (script.js.Modbus-WR_Werte_an_KNX_senden:16:7)
    13:42:48.281 [info] javascript.0 script.js.Modbus-WR_Werte_an_KNX_senden: 0231 W _
    13:42:48.582 [warn] javascript.0 at Object. (script.js.Modbus-WR_Werte_an_KNX_senden:20:18)
    13:42:48.582 [error] javascript.0 at Object. (script.js.Modbus-WR_Werte_an_KNX_senden:21:19)
    13:42:49.472 [warn] javascript.0 at Object. (script.js.Modbus-WR_Werte_an_KNX_senden:16:7)
    13:42:49.472 [info] javascript.0 script.js.Modbus-WR_Werte_an_KNX_senden: 0252 W _
    13:42:49.773 [warn] javascript.0 at Object. (script.js.Modbus-WR_Werte_an_KNX_senden:20:18)
    13:42:49.773 [error] javascript.0 at Object. (script.js.Modbus-WR_Werte_an_KNX_senden:21:19)
    13:42:50.577 [warn] javascript.0 at Object. (script.js.Modbus-WR_Werte_an_KNX_senden:16:7)
    13:42:50.577 [info] javascript.0 script.js.Modbus-WR_Werte_an_KNX_senden: 0230 W _
    13:42:50.879 [warn] javascript.0 at Object. (script.js.Modbus-WR_Werte_an_KNX_senden:20:18)
    13:42:50.879 [error] javascript.0 at Object. (script.js.Modbus-WR_Werte_an_KNX_senden:21:19)
    13:42:51.752 [warn] javascript.0 at Object. (script.js.Modbus-WR_Werte_an_KNX_senden:16:7)
    13:42:51.752 [info] javascript.0 script.js.Modbus-WR_Werte_an_KNX_senden: 0228 W _
    13:42:52.053 [warn] javascript.0 at Object. (script.js.Modbus-WR_Werte_an_KNX_senden:20:18)
    13:42:52.053 [error] javascript.0 at Object. (script.js.Modbus-WR_Werte_an_KNX_senden:21:19)
    13:42:52.874 [warn] javascript.0 at Object. (script.js.Modbus-WR_Werte_an_KNX_senden:16:7)
    13:42:52.874 [info] javascript.0 script.js.Modbus-WR_Werte_an_KNX_senden: 0317 W _
    13:42:53.175 [warn] javascript.0 at Object. (script.js.Modbus-WR_Werte_an_KNX_senden:20:18)
    13:42:53.175 [error] javascript.0 at Object. (script.js.Modbus-WR_Werte_an_KNX_senden:21:19)
    13:42:53.954 [warn] javascript.0 at Object. (script.js.Modbus-WR_Werte_an_KNX_senden:16:7) `
    sieht jetzt so aus…wird aber immernoch nix geschrieben
    Skript sieht aktuell so aus:
    const idModbusDP = 'modbus.0.inputRegisters.30865_Netz-Bezug';
    const idKNXDP = 'knx.0.Visu_Werte.Synohr.Display_Text';
    const delta = 1.0;  // Mindest-Änderung für KNX-Aktualisierung
    var lastKNX = getState(idKNXDP).val;
    on(idModbusDP, function(dp) {
       if(Math.abs(dp.state.val - lastKNX) >= delta) {
          lastKNX = dp.state.val;
          var unit = ' W        ';  // 10 Zeichen Länge
          var text;
          if(lastKNX >= 1000) text = lastKNX.toFixed() + unit;
          if(lastKNX < 1000) text = '0' + lastKNX.toFixed() + unit;
          if(lastKNX < 100) text = '00' + lastKNX.toFixed() + unit;
          if(lastKNX < 10) text = '000' + lastKNX.toFixed() + unit;
          setState(idKNXDP, text);
          // zusätzlich für Test
          log(text + '_');
          setTimeout(function() {
             var x = getState(idKNXDP).val;
             log(x + x.length);
          }, 300);
    • paul53P Offline
      Erste Feststellung: log(text + '_') zeigt, dass der Text verkürzt wird: Es werden nicht mehr als 1 Leerzeichen hintereinander akzeptiert !
      Zweite Feststellung: Bei Zugriff auf den Datenpunkt 'knx.0.Visu_Werte.Synohr.Display_Text' wird gewarnt. Das muss eine Ursache haben. Poste bitte mal die Objekteigenschalten (Reiter "Objekte", Beistift rechts, dann Reiter "raw(nur Experten)" copy & paste) in Code-Tags.
        alexmosel
        Hier einmal von Modbus (Quelle)
          "common": {
            "name": "",
            "type": "number",
            "role": "value",
            "unit": "W",
            "def": 0,
            "read": true,
            "write": false
          "native": {
            "regType": "inputRegs",
            "type": "int32be",
            "address": 30865,
            "len": 2,
            "offset": 0,
            "factor": 1
          "acl": {
            "object": 1638,
            "owner": "system.user.admin",
            "state": 1638
          "_id": "modbus.0.inputRegisters.30865_Netz-Bezug",
          "type": "state"
        und vom KNX Objekt (ZIEL)
          "_id": "knx.0.Zentralbefehle_u_Visu.Visualisierung.Synohr_Text",
          "type": "state",
          "common": {
            "name": "Synohr Text",
            "type": "string",
            "role": "text.string",
            "min": "",
            "max": "",
            "read": false,
            "write": true
          "native": {
            "dpt": "DPT16.000",
            "address": "0/7/0",
            "addressRefId": "P-057F-0_GA-385",
            "statusGARefId": "",
            "actGARefId": ""
          "acl": {
            "object": 1638,
            "state": 1638
        • paul53P Offline
          Die Ziel-ID stimmt nicht überein ! Ändere im Skript
          const idKNXDP = 'knx.0.Zentralbefehle_u_Visu.Visualisierung.Synohr_Text';
          und lösche den Testteil wieder (der Datenpunkt ist write-only).
          Zur Verkürzung mit mehr als einem Leerzeichen hintereinander: Es wird wohl nicht tatsächlich in Javascript verkürzt, sondern sieht nur im Log so aus, da hier die Darstellung über HTML erfolgt. HTML verkürzt mehrere Leerzeichen hintereinander auf 1 Leerzeichen.
            alexmosel
            Okay, Cool, das läuft wohl Tatsächlich….
            Wie kann ich noch was davor schreiben ?
            ...und leider Scrollt das Display immernoch die ganze Zeit, wenns das nicht tut wäre es perfekt...
            • paul53P Offline
              @alexmosel:
              Wie kann ich noch was davor schreiben ? `
              Siehe Aufruf knxText() (nimm besser das Skript mit der Mittelwertbildung).
              const werte = 10;  // Anzahl der Messwerte für Mittelwertbildung
              var cnt = 0;  // Zähler
              var sum = 0;  // Summe der Messwerte
              function knxText(id, text) {
                  var txt = text;
                  for(var i = 0; i < 14 - text.length; i++) {
                      txt = txt + ' ';
                  setState(id, txt);;
                 cnt++;
                 sum = sum + dp.state.val;
                 if(cnt >= werte) {
                    var power = sum / cnt;
                    knxText(idKNXDP, 'PV ' + power.toFixed() + ' W');
                    cnt = 0;
                    sum = 0;
              • paul53P Offline
                @alexmosel:
                …und leider Scrollt das Display immernoch die ganze Zeit, wenns das nicht tut wäre es perfekt... `
                Das widerspricht der Aussage in der Doku. Bei angehängten Leerzeichen dürfte es nicht scrollen, es sei denn, der Text (ohne die Leerzeichen) ist für das Display schon zu lang.
                  alexmosel
                  Super, habe das andere SCript schon genommen , klappt so, ne Idee wie ich das Scrollen noch los werde ?
                  Wenn ich in der ETS Direkt Hallo sende, bleibt das ohen Scrollen einfach stehen, bis es nen neuen Wert bekommt…so sollte das auch sein
                    alexmosel
                    tja….was ich nicht verstehe, ist dass ich mit der ETS kurzen Text senden kann, kein Quark angezeigt wird und es nicht scrollt.
                    Das problem scheint ja also doch beim Iobroker zu liegen oder am script.
                    Woher kommt denn der Müll, den er sonst anzeigt..?
                    • paul53P Offline
                      @alexmosel:
                      was ich nicht verstehe, ist dass ich mit der ETS kurzen Text senden kann, kein Quark angezeigt wird und es nicht scrollt. `
                      ETS ist intern.
                      @alexmosel:
                      Woher kommt denn der Müll, den er sonst anzeigt..? `
                      Keine Ahnung. Wie Du per Handeingabe ermittelt hast, müssen mind. 14 Zeichen gesendet werden, damit kein Müll angezeigt wird. Optimal sollte dies schon der KNX-Adapter ergänzen (vielleicht in einer künftigen Version ?).
                        alexmosel
                        hm…ich kann den Datentyp verändern, das Display würde woh auch 16.001 nehmen.
                        Ich probier mal...
                        Ein Problem sehe ich allerdigns noch beim Mittelwert...Nachts zeigt er dann immer noch den letzten wert an, der aber nicht mehr stimmt, oder ?
                        • paul53P Offline
                          @alexmosel:
                          Ein Problem sehe ich allerdigns noch beim Mittelwert…Nachts zeigt er dann immer noch den letzten wert an, der aber nicht mehr stimmt, oder ? `
                          Stimmt, denn wenn der Wert konstant auf 0 bleibt, wird nicht mehr getriggert. Wenn das vermieden werden soll, muss das Skript ergänzt werden.
                          var timer = null;
                              var txt = text;
                                  txt = txt + ' ';
                              setState(id, txt);;
                             cnt++;
                             if(timer) clearTimeout(timer)
                             if(dp.state.val === 0) {
                                timer = setTimeout(function()  {
                                    sum = 0;
                                    cnt = 0;
                                    knxText(idKNXDP, 'PV 0 W');
                                 }, 15000);  // 15 s
                             if(cnt >= werte) {
                                cnt = 0;
                                sum = 0;
                            alexmosel
                            Du bist Super, Vielen Vielen Dank
                            Mein Held :D
                              alexmosel
                              Hallo nochmal,
                              habe mit Enertext Kontakt gehabt, die sagen folgendeS:
                              Das Format hat tatsächlich 14 Zeichen. Auch Leerzeichen werden dargestellt. Um den Text auf weniger als 14 Zeichen zu begrenzen, muss am gewünschten Textende mindestens ein Nullzeichen stehen, also ein Zeichen mit dem Wert "00". Z. B. im Gruppenmonitor der ETS können Sie einen Text an diese Gruppenadresse senden, der aus bis zu 14 Zeichen besteht. Wenn Sie weniger als 14 Zeichen eingeben, füllt die ETS den Rest automatisch mit Nullzeichen auf.
                              Davon abgesehen würde ich jetzt noch gerne an ein weiteres Objekt übermitteln ob ich Beziehe oder Einspeise.
                              Beide Werte gibts als Objekt in IO, jedoch ist immer nur eines Positiv.
                              Das was Positiv ist müsste dann mit dem entsprechenden Test davor an die GA, also z.b. Einspeisung 500 W oder eben Bezug 500 W.
                              Man könnte ja generell das Mittelwertscript verwenden, es müsste nur differenzieren was gerade ausgegeben wird…
                              • paul53P Offline
                                @alexmosel:
                                Wenn Sie weniger als 14 Zeichen eingeben, füllt die ETS den Rest automatisch mit Nullzeichen auf. `
                                Dann ändere mal die Funktion knxText()
                                    var txt = text;
                                        txt = txt + String.fromCharCode(0);
                                    setState(id, txt);;
                                • paul53P Offline
                                  @alexmosel:
                                  würde ich jetzt noch gerne an ein weiteres Objekt übermitteln ob ich Beziehe oder Einspeise. `
                                  Was ist das für ein Objekt ?
                                  @alexmosel:
                                  Beide Werte gibts als Objekt in IO, jedoch ist immer nur eines Positiv. `
                                  Für Bezug und Einspeisung gibt es jeweils einen Datenpunkt, deren Wert negativ werden kann ?
                                    alexmosel
                                    Es gibt jeweils einen Datenpunkt, allerdings nur Positive Werte oder eben 0
                                    Einer hat somit immer 0
                                      alexmosel
                                      Mit dem Display kann ich erst morgen wieder probieren, da jetzt nurnoch 0 ankommt und somit das Script nix mehr sendet…
                                      • paul53P Offline
                                        Dann vielleicht so ?
                                        const idEinspeis = '...';
                                        const idBezug = '...';
                                        const idAnz = '...';  // Anzeige-DP
                                        function anzeige(dir, val) {
                                           setState(idAnz, dir + ': ' + val.toFixed() + ' W');
                                        on({id: idEinspeis, valGt: 0}, function(dp) {
                                           anzeige('Einspeisung', dp.state.val)
                                        on({id: idBezug, valGt: 0}, function(dp) {
                                           anzeige('Bezug', dp.state.val)
                                        • paul53P Offline
                                          @alexmosel:
                                          Mit dem Display kann ich erst morgen wieder probieren, da jetzt nurnoch 0 ankommt und somit das Script nix mehr sendet… `
                                          Zum Testen kannst Du am Skriptende ergänzen
                                          knxText(idKNXDP, 'PV 500 W');
                                          dann das Skript starten und nach dem Test die Zeile am Ende wieder löschen.
