  4. [gelöst] backitup /bin/sh: 1: influx: not found
    2.9k
    5.0k
55 Beiträge 7 Kommentatoren 6.3k Aufrufe 6 Beobachtet
  • A Alero
    den habe ich jetzt auch installiert.
    juergen@iobroker-prod-12:~$ sudo apt install influxdb2-client
    Reading package lists... Done
    The following packages were automatically installed and are no longer required:
      ntpsec-ntpdate ntpsec-ntpdig
    Use 'sudo apt autoremove' to remove them.
    The following NEW packages will be installed:
      influxdb2-client
    0 upgraded, 1 newly installed, 0 to remove and 6 not upgraded.
    Need to get 11.3 MB of archives.
    After this operation, 25.0 MB of additional disk space will be used.
    Get:1 https://repos.influxdata.com/debian stable/main amd64 influxdb2-client amd64 2.7.1-1 [11.3 MB]
    Fetched 11.3 MB in 1s (11.2 MB/s)
    Selecting previously unselected package influxdb2-client.
    (Reading database ... 37821 files and directories currently installed.)
    beim Backitup bekomme ich aber noch eine FM:
    [DEBUG] [influxDB] - InfluxDB-Backup started ...
    [DEBUG] [influxDB] - Start InfluxDB Backup ...
    [DEBUG] [influxDB] - InfluxDB Backup tmp directory created
    [DEBUG] [influxDB] - Try deleting the InfluxDB tmp directory: "/opt/iobroker/backups/influxDB_2023_10_05-10_54_33_backupiobroker"
    [DEBUG] [influxDB] - InfluxDB tmp directory "/opt/iobroker/backups/influxDB_2023_10_05-10_54_33_backupiobroker" successfully deleted
    [ERROR] [influxDB] - Error: Command failed: influx backup --bucket iobroker --host http://192.168.42.69:8086 -t CiOIz_JIz-0T_u2EkcBIkHEUTV5jbpm5WgaWhLmVbFEuk0ac3i5PwYW-ogS7eLA8I9V97Ft9H1hnDs_5== "/opt/iobroker/backups/influxDB_2023_10_05-10_54_33_backupiobroker"
    2023/10/05 10:54:33 INFO: Downloading metadata snapshot
    Error: failed to backup metadata: failed to download metadata snapshot: 401 Unauthorized: read:authorizations is unauthorized
    @alero sagte in backitup /bin/sh: 1: influx: not found:
    401 Unauthorized
    Da fehlen die Rechte auf die db zuzugreifen. Kann ich dir aber nix zu sagen, hab kein influxdb2 im Einsatz.
    Aber schmeiß die "and 6 not upgraded" Pakete auf das System. Da dürfte ein wichtiges Update der libc dabei sein.
      401 Unauthorized
      Alero
      wie bekomme ich die 6 fehlenden Pakete heraus die ich installieren muss?
      • A Alero
        @alero
        Mit der üblichen Systempflege:
        sudo apt update
        sudo apt full-upgrade
          @alero
          sudo apt update
          Alero
          hi, danke
          hab den Befehl gerade gegoogelt.
          sudo sudo apt list --upgradable
          Listing... Done
          libc-bin/stable-security 2.36-9+deb12u3 amd64 [upgradable from: 2.36-9+deb12u1]
          libc-dev-bin/stable-security 2.36-9+deb12u3 amd64 [upgradable from: 2.36-9+deb12u1]
          libc-l10n/stable-security 2.36-9+deb12u3 all [upgradable from: 2.36-9+deb12u1]
          libc6-dev/stable-security 2.36-9+deb12u3 amd64 [upgradable from: 2.36-9+deb12u1]
          libc6/stable-security 2.36-9+deb12u3 amd64 [upgradable from: 2.36-9+deb12u1]
          locales/stable-security 2.36-9+deb12u3 all [upgradable from: 2.36-9+deb12u1]
          werde ich nach installieren.
          • A Alero
            hi, danke
            Listing... Done
            Dringend. Wie erwartet die libc.
              Alero
              so den Fehler auch beseitigt.
              mit dem Befehl :
              influx auth list --user admin
              auf dem influxdb server zeigt er mir die ganzen Token an. ich brauchte das erswte welches beim Erstellen des influxdb sevrers erstellt wurde. mit dem Token hat die Sicherung dann geklappt.
              Muss ich die repositories auch für Grafana auf dem iobroker installieren? (dein Link https://forum.iobroker.net/topic/59231/phantastische-repositories-und-wo-sie-zu-finden-sind)
              • A Alero
                mit dem Befehl :
                Auf dem Host, wo grafana laufen soll. Da gibt es keine client-Version, falls du das meinen solltest.
                A 2 Antworten Letzte Antwort
                  Alero
                  auch hier habe ich zur Zeit einen eigenen Grafanaserver.
                  In Zukunft soll es einen "Integra server" geben der Influxdb, telegraf und grafana beinhaltet.
                  Daher will ich jetzt meine Sicherungen machen damit ich sie dann auf das neue System restoren kann.
                  Der neue Server mit debian 12 ist soweit schon fertig.
                  Also muss ich auf iobroker jetzt auch die repositories für grafana installieren
                  • A Alero
                    simatecS Offline
                    simatecS Offline
                    simatec
                    @alero Installiere mal die cli ... Client macht öfter Probleme
                    • Besuche meine Github Seite
                    • HowTo Restore ioBroker
                      Alero
                      hi,
                      nochmals vielen Dank für deine Hilfe. ich hoffe das ich irgendwann auch mal helfen kann.
                      O 1 Antwort Letzte Antwort
                      • A Alero
                        hi,
                        O Offline
                        O Offline
                        oranggila
                        @alero Hi, ich könnte Hilfe gebrauchen. Kannst du etwas genauer erklären, wie/wo du den "unauthorized" Fehler behoben hast?
                        Ich komme bis hier hin:
                        	[iobroker] Error: Command failed: influx backup --bucket iobroker --host http://192.168.0.4:8086 -t Oah3oseBs6s55usyLS_wZ4i27WH1uyimLBQ_snm48q9vkAWKB_nNgIThFxxxxx53ye43O5ZRex4sNQ== "/opt/iobroker/backups/influxDB_2023_10_20-17_52_44_Regular_backupiobroker"2023/10/20 17:52:44 INFO: Downloading metadata snapshotError: failed to backup metadata: failed to download metadata snapshot: 401 Unauthorized: read:authorizations is unauthorized
                        Intel NUC - ioBroker in Proxmox-VM, Zigbee TCP CC2652P2, MG4 Trophy (e-Auto)
                        R 1 Antwort Letzte Antwort
                        • O oranggila
                          R Online
                          R Online
                          reutli
                          @Thomas-Braun
                          Habe gerade nach den Vorgaben in diesem thread versucht auf meinem neuen iobroker-master (bookworm auf Proxmox-VM) die influx2-cli zu installieren.
                          Leider habe ich aber ein paar "nette" Fehler:
                          Zuerst habe ich die Repos aktualisiert:
                          admin@iobroker-master:~$ wget -q https://repos.influxdata.com/influxdata-archive_compat.key
                          admin@iobroker-master:~$ echo '393e8779c89ac8d958f81f942f9ad7fb82a25e133faddaf92e15b16e6ac9ce4c influxdata-archive_compat.key' | sha256sum -c && cat influxdata-archive_compat.key | gpg --dearmor | sudo tee /usr/share/keyrings/influxdata-archive_compat.gpg > /dev/null
                          influxdata-archive_compat.key: OK
                          admin@iobroker-master:~$ echo 'deb [signed-by=/usr/share/keyrings/influxdata-archive_compat.gpg] https://repos.influxdata.com/debian stable main' | sudo tee /etc/apt/sources.list.d/influxdata.list
                          apt update gefahren und Client versucht zu installieren:
                          admin@iobroker-master:~$ sudo apt install influxdb2-client
                          Die folgenden NEUEN Pakete werden installiert:
                            influxdb2-client
                          0 aktualisiert, 1 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
                          Es müssen 11,3 MB an Archiven heruntergeladen werden.
                          Nach dieser Operation werden 25,0 MB Plattenplatz zusätzlich benutzt.
                          Holen:1 https://repos.influxdata.com/debian stable/main amd64 influxdb2-client amd64 2.7.1-1 [11,3 MB]
                          Es wurden 11,3 MB in 1 s geholt (21,0 MB/s).
                          Vormals nicht ausgewähltes Paket influxdb2-client wird gewählt.
                          (Lese Datenbank ... 47670 Dateien und Verzeichnisse sind derzeit installiert.)
                          Vorbereitung zum Entpacken von .../influxdb2-client_2.7.1-1_amd64.deb ...
                          Entpacken von influxdb2-client (2.7.1-1) ...
                          dpkg: Fehler beim Bearbeiten des Archivs /var/cache/apt/archives/influxdb2-client_2.7.1-1_amd64.deb (--unpack):
                           Versuch, »/usr/bin/influx« zu überschreiben, welches auch in Paket influxdb-client 1.6.7~rc0-1+b13 ist
                          dpkg-deb: Fehler: »einfügen«-Unterprozess wurde durch Signal (Datenübergabe unterbrochen (broken pipe)) getötet
                          Fehler traten auf beim Bearbeiten von:
                          E: Sub-process /usr/bin/dpkg returned an error code (1)
                          auch CLI als solche ging nicht:
                            influxdb2-cli
                          Es müssen 11,5 MB an Archiven heruntergeladen werden.
                          Nach dieser Operation werden 25,2 MB Plattenplatz zusätzlich benutzt.
                          Holen:1 https://repos.influxdata.com/debian stable/main amd64 influxdb2-cli amd64 2.7.3-1 [11,5 MB]
                          Es wurden 11,5 MB in 1 s geholt (21,0 MB/s).
                          Vormals nicht ausgewähltes Paket influxdb2-cli wird gewählt.
                          Vorbereitung zum Entpacken von .../influxdb2-cli_2.7.3-1_amd64.deb ...
                          Entpacken von influxdb2-cli (2.7.3-1) ...
                          dpkg: Fehler beim Bearbeiten des Archivs /var/cache/apt/archives/influxdb2-cli_2.7.3-1_amd64.deb (--unpack):
                          Was mache ich falsch?
                          Ohne die Config bekomme ich Backitup nicht dazu die remote InfluxDB zu sichern...
                          iobroker in Debian-VM auf Proxmox Server (Ryzen 7 / 32GB / 1TB NVMe SSD) als Master - mehrere Raspberry Pis (3+4) als Slaves. InfluxDB V2 und Grafana auf LXC.
                          *Wer freundlich ist, dem wird freundlich geholfen *
                          DJMarc75D Thomas BraunT 2 Antworten Letzte Antwort
                          • R reutli
                            @Thomas-Braun
                              influxdb2-client
                              influxdb2-cli
                            DJMarc75D Offline
                            DJMarc75D Offline
                            DJMarc75
                            @reutli ob Du mal so prinzipiell das "Übersetzertool" deaktivieren würdest damit man die Originalmeldungen aus der Konsole lesen kann ? Das könnte vieles einfacher machen für Helfende.
                            Lehrling seit 1975 !!!
                            • R reutli
                              @Thomas-Braun
                                influxdb2-client
                                influxdb2-cli
                              @reutli
                              sudo apt remove influxdb-client
                              Danach sollte es funktionieren.
                              • DJMarc75D DJMarc75
                                R Online
                                R Online
                                reutli
                                @djmarc75 sagte in [gelöst] backitup /bin/sh: 1: influx: not found:
                                Hab ich nicht. Aber wenn Du mir sagst wo, dann mache ich das gerne
                                  @reutli
                                  R Online
                                  R Online
                                  reutli
                                  @thomas-braun sagte in [gelöst] backitup /bin/sh: 1: influx: not found:
                                  das war's, DANKE
                                  danach
                                  [sudo] Passwort für admin:
                                    influxdb2-cli
                                  Es müssen noch 0 B von 11,5 MB an Archiven heruntergeladen werden.
                                  (Lese Datenbank ... 47662 Dateien und Verzeichnisse sind derzeit installiert.)
                                  influxdb2-cli (2.7.3-1) wird eingerichtet ...
                                  und schon fliegt es...
                                  • R reutli
                                    @reutli
                                    Du hast das System offenbar in den LOCALES auf Deutsch eingestellt. Dann kommen auch diese Systemmeldungen auf (teilweise holprigem) Deutsch.
                                    Man kann auch schlechter danach googlen, weil der Rest der Welt halt Englisch eingestellt hat.
                                    Deswegen stellt man das eigentlich nie für das Grundsystem anders ein.
                                      @reutli
                                      R Online
                                      R Online
                                      reutli
                                      jupp, kann mich erinnern. Ich hatte "irgendein" Problem (sorry) und deshalb auf deutsch installiert.
                                      Kann ich das gefahrlos zurückdrehen und wenn ja, wie?
                                      Danke im Voraus.
                                      • R reutli
                                        Danke im Voraus.
                                        @reutli
                                        Hier ist das erklärt:
                                        https://www.thomas-krenn.com/de/wiki/Locales_unter_Ubuntu_konfigurieren
                                          @reutli
                                          R Online
                                          R Online
                                          reutli
                                          ok, danke.
                                          Da steht aber m.E. nicht,
                                          • welches locale sinnvoll ist (en-GB, en-US, ...) und Standard ist
                                          • ob ich das einfach so im laufenden Betrieb umstellen kann
                                          • was das für Auswirkungen z.B. für Proxmox hat
                                          Habe ja gerade erst alles neu aufgesetzt und migriert, will ja nicht alles kaputt machen...
