  4. Nach Update läuft nichts mehr!
    6.7k
iobroker updatenpmjs controller updatejsonhelp wanted
416 Beiträge 18 Kommentatoren 96.7k Aufrufe 9 Beobachtet
  • S SpeedyBlade
    perfekt....jetzt geht gar nichts mehr 😣
    Ps.: nein, sitze nicht in UK
      Operating System: Raspbian GNU/Linux 10 (buster)
                Kernel: Linux 5.10.103-v7l+
          Architecture: arm
    Model           : Raspberry Pi 4 Model B Rev 1.4
    Docker          : false
    Virtualization  : none
    Kernel          : armv7l
    Userland        : armhf
    Systemuptime and Load:
     08:27:55 up 6 min,  1 user,  load average: 0.21, 0.25, 0.11
    CPU threads: 4
    Raspberry only:
    throttled=0x0
    Other values than 0x0 hint to temperature/voltage problems
    temp=47.2'C
    volt=0.8700V
    *** Time and Time Zones ***
                   Local time: Fri 2023-09-29 08:27:55 BST
               Universal time: Fri 2023-09-29 07:27:55 UTC
                     RTC time: n/a
                    Time zone: Europe/London (BST, +0100)
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:           7.8G         55M        7.4G         16M        373M        7.5G
    Swap:           99M          0B         99M
    Total:         7.9G         55M        7.5G
             7846 M total memory
               55 M used memory
              187 M active memory
              180 M inactive memory
             7416 M free memory
               35 M buffer memory
              338 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    Raspberry only:
    oom events: 0
    *** FILESYSTEM ***
    /dev/root      ext4      916G  3.1G  866G   1% /
    devtmpfs       devtmpfs  3.7G     0  3.7G   0% /dev
    tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
    tmpfs          tmpfs     3.9G   17M  3.9G   1% /run
    tmpfs          tmpfs     3.9G     0  3.9G   0% /sys/fs/cgroup
    /dev/sda1      vfat      253M   49M  204M  20% /boot
    tmpfs          tmpfs     785M     0  785M   0% /run/user/1000
    [Fri Sep 29 08:21:40 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:D6:FD:D6 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=206cf84d-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
    [Fri Sep 29 08:21:43 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
    [Fri Sep 29 08:21:43 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
    [Fri Sep 29 08:21:47 2023] EXT4-fs (sda2): re-mounted. Opts: (null)
    TARGET        SOURCE    FSTYPE OPTIONS
    /             /dev/sda2 ext4   rw,noatime,stripe=8191
    |-/sys/fs/bpf none      bpf    rw,nosuid,nodev,noexec,relatime,mode=700
    `-/boot       /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    368M    /var/
    169M    /var/cache
    163M    /var/cache/apt
    104M    /var/cache/apt/archives
    93M     /var/lib
    Archived and active journals take up 16.0M in the file system.
    /opt/iobroker/backups:
    17M     /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    122M    /opt/iobroker/iobroker-data/
    59M     /opt/iobroker/iobroker-data/backup-objects
    25M     /opt/iobroker/iobroker-data/files
    23M     /opt/iobroker/iobroker-data/node-red/node_modules
    6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
    5.2M    /opt/iobroker/iobroker-data/files/knx.admin/static/js/main.fcc1088d.js.map
    5.1M    /opt/iobroker/iobroker-data/objects.json.migrated
    5.1M    /opt/iobroker/iobroker-data/objects.json.bak.migrated
    4.5M    /opt/iobroker/iobroker-data/objects.jsonl
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.18.0
    /usr/bin/node           v18.18.0
    /usr/bin/npm            9.8.1
    /usr/bin/npx            9.8.1
    nodejs:
      Installed: 18.18.0-1nodesource1
      Candidate: 18.17.1-deb-1nodesource1
      Version table:
     *** 18.18.0-1nodesource1 100
         18.17.1-deb-1nodesource1 1001
            500 https://deb.nodesource.com/node_18.x buster/main armhf Packages
         10.24.0~dfsg-1~deb10u3 500
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    node:internal/modules/cjs/loader:1080
      throw err;
    Error: Cannot find module 'tar'
    Require stack:
    - /opt/iobroker/node_modules/@iobroker/js-controller-cli/build/lib/setup/setupBackup.js
    - /opt/iobroker/node_modules/@iobroker/js-controller-cli/build/index.js
    - /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js
        at Module._resolveFilename (node:internal/modules/cjs/loader:1077:15)
        at Module._load (node:internal/modules/cjs/loader:922:27)
        at Module.require (node:internal/modules/cjs/loader:1143:19)
        at require (node:internal/modules/cjs/helpers:119:18)
        at Object.<anonymous> (/opt/iobroker/node_modules/@iobroker/js-controller-cli/build/lib/setup/setupBackup.js:12:31)
        at Module._compile (node:internal/modules/cjs/loader:1256:14)
        at Module._extensions..js (node:internal/modules/cjs/loader:1310:10)
        at Module.load (node:internal/modules/cjs/loader:1119:32)
        at Module._load (node:internal/modules/cjs/loader:960:12)
        at Module.require (node:internal/modules/cjs/loader:1143:19) {
      code: 'MODULE_NOT_FOUND',
      requireStack: [
        '/opt/iobroker/node_modules/@iobroker/js-controller-cli/build/lib/setup/setupBackup.js',
        '/opt/iobroker/node_modules/@iobroker/js-controller-cli/build/index.js',
        '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
    Node.js v18.18.0
      throw err;
    Require stack:
      requireStack: [
    Node.js v18.18.0
    Core adapters versions
      throw err;
    Require stack:
      requireStack: [
    Node.js v18.18.0
    js-controller:
      throw err;
    Require stack:
      requireStack: [
    Node.js v18.18.0
    admin:
      throw err;
    Require stack:
      requireStack: [
    Node.js v18.18.0
    javascript:
    Adapters from github:   0
    Adapter State
      throw err;
    Require stack:
      requireStack: [
    Node.js v18.18.0
      throw err;
    Require stack:
      requireStack: [
    Node.js v18.18.0
    ioBroker-Repositories
      throw err;
    Require stack:
      requireStack: [
    Node.js v18.18.0
    Installed ioBroker-Instances
      throw err;
    Require stack:
      requireStack: [
    Node.js v18.18.0
    Objects and States
    Objects:        0
    States:         0
    Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
    Hit:2 http://archive.raspberrypi.org/debian buster InRelease
    Hit:3 https://deb.nodesource.com/node_18.x buster InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          16156      624/sshd
    tcp6       0      0 :::22                   :::*                    LISTEN      0          16158      624/sshd
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          17451      615/dhcpcd
    udp        0      0 0.0.0.0:45185           0.0.0.0:*                           108        15399      387/avahi-daemon: r
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        15397      387/avahi-daemon: r
    udp6       0      0 :::43947                :::*                                108        15400      387/avahi-daemon: r
    udp6       0      0 :::546                  :::*                                0          15573      615/dhcpcd
    udp6       0      0 :::5353                 :::*                                108        15398      387/avahi-daemon: r
    2023-09-29 08:20:45.300  - error: host.RaspberryPi4 Caught by controller[6]: sh: 0: getcwd() failed: No such file or directory
    2023-09-29 08:20:45.300  - error: host.RaspberryPi4 Caught by controller[7]: sh: 0: getcwd() failed: No such file or directory
    2023-09-29 08:20:45.301  - error: host.RaspberryPi4 Caught by controller[8]: sh: 0: getcwd() failed: No such file or directory
    2023-09-29 08:20:45.301  - error: host.RaspberryPi4 Caught by controller[9]: sh: 0: getcwd() failed: No such file or directory
    2023-09-29 08:20:45.301  - error: host.RaspberryPi4 Caught by controller[10]: sh: 0: getcwd() failed: No such file or directory
    2023-09-29 08:20:45.301  - error: host.RaspberryPi4 Caught by controller[11]: sh: 0: getcwd() failed: No such file or directory
    2023-09-29 08:20:45.305  - error: host.RaspberryPi4 Caught by controller[12]: sh: 0: getcwd() failed: No such file or directory
    2023-09-29 08:20:45.306  - error: host.RaspberryPi4 Caught by controller[13]: sh: 0: getcwd() failed: No such file or directory
    2023-09-29 08:20:45.306  - error: host.RaspberryPi4 Caught by controller[14]: sh: 0: getcwd() failed: No such file or directory
    2023-09-29 08:20:45.306  - error: host.RaspberryPi4 Caught by controller[15]: sh: 0: getcwd() failed: No such file or directory
    2023-09-29 08:20:45.306  - error: host.RaspberryPi4 Caught by controller[16]: sh: 0: getcwd() failed: No such file or directory
    2023-09-29 08:20:45.306  - error: host.RaspberryPi4 Caught by controller[17]: sh: 0: getcwd() failed: No such file or directory
    2023-09-29 08:20:45.307  - error: host.RaspberryPi4 Caught by controller[18]: sh: 0: getcwd() failed: No such file or directory
    2023-09-29 08:20:45.307  - error: host.RaspberryPi4 Caught by controller[19]: sh: 0: getcwd() failed: No such file or directory
    2023-09-29 08:20:45.307  - error: host.RaspberryPi4 Caught by controller[20]: sh: 0: getcwd() failed: No such file or directory
    2023-09-29 08:20:45.307  - error: host.RaspberryPi4 Caught by controller[21]: sh: 0: getcwd() failed: No such file or directory
    2023-09-29 08:20:45.308  - info: host.RaspberryPi4 instance system.adapter.rpi2.0 terminated with code 0 (NO_ERROR)
    2023-09-29 08:20:45.309  - info: host.RaspberryPi4 instance system.adapter.info.0 terminated with code 0 (NO_ERROR)
    2023-09-29 08:20:45.408  - info: host.RaspberryPi4 instance system.adapter.admin.0 terminated with code 0 (NO_ERROR)
    2023-09-29 08:20:45.409  - info: host.RaspberryPi4 instance system.adapter.discovery.0 terminated with code 0 (NO_ERROR)
    2023-09-29 08:20:45.470  - info: host.RaspberryPi4 instance system.adapter.knx.0 terminated with code 0 (NO_ERROR)
    2023-09-29 08:20:45.687  - info: host.RaspberryPi4 instance system.adapter.node-red.0 terminated with code 0 (NO_ERROR)
    2023-09-29 08:20:45.687  - info: host.RaspberryPi4 instance system.adapter.mqtt.0 terminated with code 0 (NO_ERROR)
    2023-09-29 08:20:45.688  - info: host.RaspberryPi4 All instances are stopped.
    2023-09-29 08:20:45.862  - info: host.RaspberryPi4 terminated
    #299
    @speedyblade
    Und warum hast du es nicht mit meinem Skript gemacht?
    Das hätte dir nämlich das richtige Repository eingespielt.
      @speedyblade
      SpeedyBlade
      #300
      was für einem Skript?
      Wenn ich die Dinge nach Anleitung aufspiele und dann doch nicht funktionieren, muss ich einfach die Anleitungen hinterfragen.
      Bei 5 Geräten funktioniert alles einwandfrei und dann auf einmal nicht mehr, das versteht kein Mensch
      • S SpeedyBlade
        #301
        @speedyblade sagte in Nach Update läuft nichts mehr!:
        Welche?
        Wenn da offenbar falsche Versionen über einen falschen Weg ins das System geprügelt werden muss man da gar nichts verstehen. Da ist einfach Murks gemacht worden.
        Das von @Homoran verlinkte und auch in meiner Signatur zu findende 'node-fix-Skript'.
          Welche?
          SpeedyBlade
          #302
          ich bin eigentlich genau nach der Anleitung vor gegangen:
          https://github.com/nodesource/distributions#nodejs
          • S SpeedyBlade
            #303
            @speedyblade
            Für die v20 passte das ja auch. Die v16 hast du da mal schräg reingedonnert.
            S 2 Antworten Letzte Antwort
              @speedyblade
              SpeedyBlade
              schrieb am zuletzt editiert von SpeedyBlade
              #304
              ioBroker nodejs fixer 2023-09-29
              No recommendation for a nodejs version found on your system. We recommend to install latest version from nodejs v18 tree.
              Your current setup is:
              /usr/bin/npm            9.8.1
              /usr/bin/npx            9.8.1
              /usr/bin/corepack       0.19.0
              We found these nodejs versions available for installation:
              nodejs:
                Version table:
              Nothing to do - Your installation is using the correct paths.
              You are running nodejs v18.18.0. Do you want to install recommended version from nodejs v.18 tree?
              Press <y> to continue or any other key to quit
              Trying to fix your installation now. Please be patient.
              rm: cannot remove '/etc/apt/keyrings/nodesource.gpg'$'\n''/usr/share/keyrings/nodesource.gpg': No such file or directory
              Waiting for ioBroker to shut down - Give me a minute...
              *** These repos are active on your system:
              Reading package lists... Done
              *** Installing ca-certificates, curl and gnupg, just in case they are missing.
              *** Creating new /etc/apt/sources.list.d/nodesource.list and pinning source
              deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_18.x nodistro main
              Package: nodejs
              Pin: origin deb.nodesource.com
              Pin-Priority: 1001
              *** These repos are active after the adjustments:
              Get:3 https://deb.nodesource.com/node_18.x nodistro InRelease [12.1 kB]
              Get:4 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages [5267 B]
              Fetched 17.4 kB in 1s (15.7 kB/s)
              Installing the recommended nodejs version now!
              Exact recommended version unknown, installing a fallback!
              Building dependency tree
              The following packages will be DOWNGRADED:
                nodejs
              0 upgraded, 0 newly installed, 1 downgraded, 0 to remove and 0 not upgraded.
              Need to get 25.4 MB of archives.
              After this operation, 2314 kB disk space will be freed.
              Get:1 https://deb.nodesource.com/node_18.x nodistro/main armhf nodejs armhf 18.0.0-1nodesource1 [25.4 MB]
              Fetched 25.4 MB in 4s (6639 kB/s)
              dpkg: warning: downgrading nodejs from 18.18.0-1nodesource1 to 18.0.0-1nodesource1
              (Reading database ... 53807 files and directories currently installed.)
              Preparing to unpack .../nodejs_18.0.0-1nodesource1_armhf.deb ...
              Detected old npm client, removing...
              Unpacking nodejs (18.0.0-1nodesource1) over (18.18.0-1nodesource1) ...
              Setting up nodejs (18.0.0-1nodesource1) ...
              Processing triggers for man-db (2.8.5-2) ...
              Updating fallback to latest nodejs v18 release
              (Reading database ... 53908 files and directories currently installed.)
              Preparing to unpack .../nodejs_18.18.0-1nodesource1_armhf.deb ...
              Unpacking nodejs (18.18.0-1nodesource1) over (18.0.0-1nodesource1) ...
              Setting up nodejs (18.18.0-1nodesource1) ...
              v18.18.0 has been installed! You are using the latest version now!
              Installing the recommended nodejs version and other updates now!
              We tried our best to fix your nodejs. Please run iob diag again to verify.
              *** RESTARTING ioBroker NOW! ***
               Please refresh or restart your browser in a few moments.
              pi@RaspberryPi4:~ $ sudo iobroker start
              pi@RaspberryPi4:~ $ iob_diag: curl -sLf -o diag.sh https://iobroker.net/diag.sh && bash diag.sh
              -bash: iob_diag:: Kommando nicht gefunden.
              • S SpeedyBlade
                /usr/bin/npm            9.8.1
                /usr/bin/npx            9.8.1
                nodejs:
                  Version table:
                Package: nodejs
                Pin-Priority: 1001
                  nodejs
                #305
                @speedyblade
                Das Skript funktioniert und zaubert dir eine senkrechte Installation von nodejs 18 und Konsorten hin.
                iob diag
                sagt nun?
                  @speedyblade
                  SpeedyBlade
                  #306
                  @thomas-braun sagte in Nach Update läuft nichts mehr!:
                  eigentlich soll die runter und v20 drauf
                  CodierknechtC Thomas BraunT 3 Antworten Letzte Antwort
                  • S SpeedyBlade
                    CodierknechtC Offline
                    Codierknecht
                    #307
                    Wozu?
                    Die ist zu neu und wird für ioBroker nicht empfohlen.
                    HmIP|ZigBee|Tasmota|Unifi
                    Zabbix Certified Specialist
                    • S SpeedyBlade
                      #308
                      @speedyblade
                      Und NIE NIE NIE NIEMALS iobroker mittels sudo anpacken. NIE!
                      iob stop
                      iob fix
                      • S SpeedyBlade
                        #309
                        Die 16 ist runter und die vorgesehene v18 ist drauf. Das passt.
                        • CodierknechtC Codierknecht
                          Wozu?
                          SpeedyBlade
                          #310
                          @codierknecht
                          wo steht dies?
                          Thomas BraunT CodierknechtC 2 Antworten Letzte Antwort
                            @speedyblade
                            iob diag
                            sagt nun?
                            SpeedyBlade
                            #311
                                  Architecture: arm
                            Docker          : false
                            Kernel          : armv7l
                            Userland        : armhf
                             09:44:56 up 23 min,  1 user,  load average: 1.22, 0.89, 0.49
                            CPU threads: 4
                            Raspberry only:
                            throttled=0x0
                            temp=48.7'C
                            volt=0.8700V
                                           Local time: Fri 2023-09-29 09:44:56 CEST
                                       Universal time: Fri 2023-09-29 07:44:56 UTC
                                             RTC time: n/a
                                            Time zone: Europe/Vienna (CEST, +0200)
                                          NTP service: active
                                      RTC in local TZ: no
                            pi
                            /home/pi
                            X-Server:       false
                            Desktop:
                            Terminal:       tty
                            *** MEMORY ***
                            Mem:           7.8G         58M        7.1G         16M        673M        7.5G
                            Swap:           99M          0B         99M
                            Total:         7.9G         58M        7.2G
                                     7846 M total memory
                                       58 M used memory
                                      280 M active memory
                                      345 M inactive memory
                                     7113 M free memory
                                      115 M buffer memory
                                      557 M swap cache
                                       99 M total swap
                                        0 M used swap
                                       99 M free swap
                            Raspberry only:
                            oom events: 0
                            *** FILESYSTEM ***
                            /dev/root      ext4      916G  3.2G  866G   1% /
                            [Fri Sep 29 09:21:40 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:D6:FD:D6 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=206cf84d-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
                            [Fri Sep 29 09:21:43 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
                            [Fri Sep 29 09:21:43 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
                            [Fri Sep 29 09:21:47 2023] EXT4-fs (sda2): re-mounted. Opts: (null)
                            /var:
                            393M    /var/
                            193M    /var/cache
                            188M    /var/cache/apt
                            128M    /var/cache/apt/archives
                            93M     /var/lib
                            /usr/bin/npm            9.8.1
                            /usr/bin/npx            9.8.1
                            nodejs:
                              Candidate: 18.18.0-1nodesource1
                              Version table:
                             *** 18.18.0-1nodesource1 1001
                                    500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
                                 18.17.1-1nodesource1 1001
                                 18.17.0-1nodesource1 1001
                                 18.16.1-1nodesource1 1001
                                 18.16.0-1nodesource1 1001
                                 18.15.0-1nodesource1 1001
                                 18.14.2-1nodesource1 1001
                                 18.14.1-1nodesource1 1001
                                 18.14.0-1nodesource1 1001
                                 18.13.0-1nodesource1 1001
                                 18.12.0-1nodesource1 1001
                                 18.11.0-1nodesource1 1001
                                 18.10.0-1nodesource1 1001
                                 18.9.1-1nodesource1 1001
                                 18.9.0-1nodesource1 1001
                                 18.8.0-1nodesource1 1001
                                 18.7.0-1nodesource1 1001
                                 18.6.0-1nodesource1 1001
                                 18.5.0-1nodesource1 1001
                                 18.4.0-1nodesource1 1001
                                 18.3.0-1nodesource1 1001
                                 18.2.0-1nodesource1 1001
                                 18.1.0-1nodesource1 1001
                                 18.0.0-1nodesource1 1001
                            ioBroker Status
                              throw err;
                            Require stack:
                              requireStack: [
                            Node.js v18.18.0
                              throw err;
                            Require stack:
                              requireStack: [
                            Node.js v18.18.0
                              throw err;
                            Require stack:
                              requireStack: [
                            Node.js v18.18.0
                            js-controller:
                              throw err;
                            Require stack:
                              requireStack: [
                            Node.js v18.18.0
                            admin:
                              throw err;
                            Require stack:
                              requireStack: [
                            Node.js v18.18.0
                            javascript:
                            Adapter State
                              throw err;
                            Require stack:
                              requireStack: [
                            Node.js v18.18.0
                              throw err;
                            Require stack:
                              requireStack: [
                            Node.js v18.18.0
                              throw err;
                            Require stack:
                              requireStack: [
                            Node.js v18.18.0
                              throw err;
                            Require stack:
                              requireStack: [
                            Node.js v18.18.0
                            Objects and States
                            Objects:        0
                            States:         0
                            Hit:3 https://deb.nodesource.com/node_18.x nodistro InRelease
                            Pending Updates: 0
                            • S SpeedyBlade
                              @codierknecht
                              wo steht dies?
                              #312
                              @speedyblade
                              Das sind die Releases von nodejs.
                              Das heißt aber noch lange nicht, das die neueste Version auch für den ioBroker empfohlen wird.
                              Davon abgesehen stehst du auf 'Buster'.
                              • S SpeedyBlade
                                @codierknecht
                                wo steht dies?
                                Codierknecht
                                #313
                                wo steht dies?
                                Recommended versions are nodejs 18.x.y and npm 9.x.y
                                  @speedyblade
                                  SpeedyBlade
                                  #314
                                  => das heißt?
                                    wo steht dies?
                                    SpeedyBlade
                                    #315
                                    @codierknecht
                                    wo oder wie holst du dir diese Info her?
                                    • S SpeedyBlade
                                      @codierknecht
                                      #316
                                      Er kennt den ioBroker.
                                      Die Empfehlung steht im Admin und auch im diag-Skript drin.
                                      • S SpeedyBlade
                                        => das heißt?
                                        #317
                                        => das heißt?
                                        Das heißt, das du Debian 10 'Buster' fährst und nicht 'Bullseye'.
                                        Und das solltest du auch schleunigst updaten, besser als 64Bit-Version neuinstallieren.
                                        cd /opt/iobroker
                                        sudo -H -u iobroker npm install iobroker.js-controller
                                        ausführen.
                                        • S SpeedyBlade
                                          => das heißt?
                                          Codierknecht
                                          #318
                                          @speedyblade
                                          Davon abgesehen stehst du auf 'Buster'. => das heißt?
                                          Dass Du ein totes Pferd reitest.
                                          "Buster" (Debian 10) ist abgekündigt. Du kannst "Bullseye" (Debian 11) nehmen oder gleich auf "Bookworm" (Debian 12) gehen.
                                          Sagt Dir u.a. iob diag. Quasi das "Swiss-Army-Knife" für den ioBroker ;-)
