  4. Test Adapter Weather-Warnings
1.1k Beiträge 36 Kommentatoren 496.5k Aufrufe 41 Beobachtet
  • sigi234S sigi234
    @ticaki sagte in Test Adapter Weather-Warnings:
    v0.2.2
    host.SmartHome
    2023-09-26 20:48:36.235	info	Restart adapter system.adapter.weather-warnings.0 because enabled
    host.SmartHome
    2023-09-26 20:48:36.235	error	instance system.adapter.weather-warnings.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    weather-warnings.0
    2023-09-26 20:48:35.687	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
    weather-warnings.0
    2023-09-26 20:48:35.687	info	terminating
    weather-warnings.0
    2023-09-26 20:48:35.684	error	that2.sendNoMessages is not a function
    weather-warnings.0
    2023-09-26 20:48:35.684	error	TypeError: that2.sendNoMessages is not a function at updater (C:\SmartHome\node_modules\iobroker.weather-warnings\src\lib\provider.ts:483:26) at Timeout._onTimeout (C:\SmartHome\node_modules\@iobroker\js-controller-adapter\src\lib\adapter\adapter.ts:2574:17) at listOnTimeout (node:internal/timers:569:17) at processTimers (node:internal/timers:512:7)
    weather-warnings.0
    2023-09-26 20:48:35.607	error	unhandled promise rejection: that2.sendNoMessages is not a function
    weather-warnings.0
    2023-09-26 20:48:35.607	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    weather-warnings.0
    2023-09-26 20:48:34.310	info	UWZ activated. Retrieve data.
    weather-warnings.0
    2023-09-26 20:48:34.307	info	ZAMG activated. Retrieve data.
    weather-warnings.0
    2023-09-26 20:48:30.284	info	Refresh Interval: 58 minutes
    weather-warnings.0
    2023-09-26 20:48:30.275	info	starting. Version 0.2.2-alpha1.0 (non-npm: ticaki/ioBroker.weather-warnings#5dd28a383cdfce93b49c2d24877fb993e899eb49) in C:/SmartHome/node_modules/iobroker.weather-warnings, node: v18.18.0, js-controller: 5.0.12
    T Nicht stören
    T Nicht stören
    ticaki
    @sigi234
    Ja da hat der Iobroker recht, da war ich dran als ich dann was anderes gemacht habe... Merci.. dann gibts die korrigierten Deutschen Typen heute noch. :) Hab vergessen die leere Funktion hinzuschreiben und nicht ohne Warnungen getestet.
    Spenden
    • sigi234S sigi234
      v0.2.2
      host.SmartHome
      host.SmartHome
      weather-warnings.0
      weather-warnings.0
      weather-warnings.0
      weather-warnings.0
      weather-warnings.0
      weather-warnings.0
      weather-warnings.0
      weather-warnings.0
      weather-warnings.0
      weather-warnings.0
      T Nicht stören
      T Nicht stören
      ticaki
      @sigi234
      Nochmals Danke, ich hatte die Funktion da hingeschrieben als Platzhalter für keine Nachricht und dann den Weg mit Nachrichten fertiggestellt. Und dabei vergessen den Platzhalter zu entfernen oder zu füllen.
      Nun darüber hab ich aber noch 2 weitere Fehler gefunden und behoben. Die Intervalzeit wurde nicht übernommen, war immer 10 Minuten und das Aufräumen der States hat bei 0 Warnungen auch nicht funktioniert.
      Anmerkungen zum Aufräumen der States, die werden aufgeräumt wenn nach einem Update ein State in den letzten paar Minuten nicht intern aktualisiert wurde. Heißt beim Neustart wird das mit dem 1. Datenabruf häufig nicht zurück gesetzt, sondern i.d.R. mit dem 2. Datenabruf. Im Laufenden Betrieb verhält es sich immer so wie es soll.
      Wenn der Server offline sind, können states noch genullt werden - das muß ich mal demnächst checken.
      Github ist aktualisiert
      Spenden
      LatziL sigi234S 2 Antworten Letzte Antwort
      • T ticaki
        @sigi234
        LatziL Online
        LatziL Online
        Latzi
        @ticaki
        Läuft 👍
        • T ticaki
          @sigi234
          sigi234S Online
          sigi234S Online
          läuft 👍
          • T Nicht stören
            T Nicht stören
            ticaki
            Ein stilles Update:
            • Testwarnungen werden in größerem Zeitraum erneuert, nach dem ablaufen
            • Sprachunterstützung für alle Dienste hinzugefügt - DWD 20 oder mehr, UWZ und bei Zamg hab ich französich und englisch eingefügt, weiß aber nicht ob das geht.
            • einen Fehler in dem Löschen der Warnungen behoben
            • Neuer Datenpunkt "name den ihr vergebt"+ "_array" enhält alle aktiven Warnungen als '["warnung", "warnung", ...]'
            • Warnungen sollten überall nach Startzeit sortiert sein.
            Spenden
            • T Nicht stören
              T Nicht stören
              ticaki
              v.0.2.3-alpha.0
              • besser Tests, wenn in Github die letzte Action mit einem grünen Haken versehen ist, ist schon mal kein Fehler im Code der nach 3 Minuten Ausführung und 2 Daten abrufen zu einem Fehler führt.
              • weitere Übersetzungen
              • Filter für jeden Provider um unliebsame Warnarten auszuschließen.
              • Definition von _array Datenpunkten verändert, die löschen (oder einfach alles)
              Als nächstes:
              • intern verwendete Datenpunkte woanders speichern, das sie nicht in formatedKeys auftauchen.
              • Wochentage in eingestellter Sprache.
              • Filter nach level und Startzeit .
              • Telegram oder Mail integration. eMail ist aufwendiger, daher würde ich es lieber erst später machen.
              Anmerkungen:
              Das Admininterface wird erstmal zugemüllt, wenn ich dann alles drin habe was ich möchte, wird das mit eurem Feedback aufgeräumt.
              Spenden
              • T ticaki
                v.0.2.3-alpha.0
                Als nächstes:
                Anmerkungen:
                sigi234S Online
                sigi234S Online
                **dwd**Typfilter
                • sigi234S sigi234
                  **dwd**Typfilter
                  T Nicht stören
                  T Nicht stören
                  ticaki
                  @sigi234
                  Auch wenns falsch aussieht ist es dahinter richtig :) Das ist ein überbleibsel vom Copy Paste. Fand ich auch unschön als ich das nochmal genauer angesehen habe, geht leider nicht das alles mit gleichem LAabel auch die gleiche Überssetzung bekommt.
                  Spenden
                  • T ticaki
                    @sigi234
                    sigi234S Online
                    sigi234S Online
                    @ticaki
                    Beim speichern und schließen geht der TAB ins leere!
                    • T ticaki
                      Aktuelle Test Version NPM version
                      Veröffentlichungsdatum 11.2025
                      Github Link https://github.com/ticaki/ioBroker.weather-warnings
                      Paypal Donation
                      Vor dem Download beachten: Test and Release
                      Hilfe bei Übersetzungen: Das hier hängt stark daran das die Übersetzungen was taugen, wenn ihr dabei helfen wollt:
                      Übersetzungsstatus
                      Ersetzt dieses Skript (ca. 70% des Umfangs erreicht) https://forum.iobroker.net/post/385276
                      Aktueller Funktionsumfang:
                      • Abruf von Wetterdaten folgender Dienste:
                        • DWD Ort und Kreis
                        • UWZ Postleitzahlengebiet
                        • ZAMG (Österreich) Koordinaten
                      • Unbearbeitete Daten werden in States hinterlegt
                      • formatierte Daten werden in States hinterlegt
                      • eine Vorlagenerstellung eigenen Nachrichten ist implementiert (noch keine gute Ausgabe)
                      • Es gibt States in denen dies Nachrichten angezeigt werden, aber die zappen da durch und die letzte bleibt. Der Code dahinter versenden später die Pushnachrichten.
                      • Testmodus steht zur Verfügung, beim Nutzen dieser ist der Adapter offline und gelb.
                      • States die es erlauben bei aktiver Warnung und innerhalb des Warnzeitraums automatisch Maßnahmen zu ergreifen (ich schließe den Balkonrollladen, bei Warnungen für Starkregen, Gewitter und Sturm wenn ich nicht da bin)
                      • Abruf von Warnungen in den von den Diensten zur Verfügung gestellten Sprachen.
                      • Filtern von Warnungen nach Typ und Level
                      • löschen von abgelaufenen Warnungen
                      • Vereinheitlichung der Warnungen, so das sie über die Dienste vergleichbar werden.
                      • Versand der Warnungen per Mail, telegram, pushover, whatsapp
                      • Unterstützung von mehr als einem Warngebiet.
                      • manuelles Auslösen von Pushnachrichten
                      • Bereitstellung von Nutzer formatierbarem Text für die Gestaltung von z.B. Html Tabellen
                      • Unterstützung von Alexa
                      Todo:
                      • Unterstützung von Sayit
                      • siehe Github Feature Request
                      Feedback gerne hier.
                      Verbesserungvorschläge/Feature Requests bitte als Github Issue in deutsch oder englisch.
                      Logo schwarz/weiß https://forum.iobroker.net/post/1061841
                      sigi234S Online
                      sigi234S Online
                      Ein sehr Wichtiger Punkt wie ich meine.😏
                      • sigi234S sigi234
                        @ticaki
                        T Nicht stören
                        T Nicht stören
                        ticaki
                        @sigi234
                        Das hab ich auf meinem richtigen iobroker auch mit dem aktuellen Admin, dachte das käme daher. Zumindest beim Sonoff hab ich beobachtet, auf dem entwicklungsserver ist eh alle anders :)
                        Spenden
                        • sigi234S sigi234
                          T Nicht stören
                          T Nicht stören
                          ticaki
                          @sigi234 sagte in Test Adapter Weather-Warnings:
                          Dann ziehe ich das vor.
                          Spenden
                          • T ticaki
                            Paypal Donation
                            Übersetzungsstatus
                              • DWD Ort und Kreis
                            Todo:
                            sigi234S Online
                            sigi234S Online
                            @ticaki
                            T 2 Antworten Letzte Antwort
                            • sigi234S sigi234
                              @ticaki
                              T Nicht stören
                              T Nicht stören
                              ticaki
                              @sigi234
                              korrigiere ich. warnlevelcolor kannst du löschen, das hab ich durch die beiden hex/name ersetzt.
                              Spenden
                              • sigi234S sigi234
                                @ticaki
                                T Nicht stören
                                T Nicht stören
                                ticaki
                                @sigi234
                                Der State müsste schon aktualisiert sein, lösche ihn man.
                                Spenden
                                • T ticaki
                                  @sigi234
                                  sigi234S Online
                                  sigi234S Online
                                  • sigi234S sigi234
                                    T Nicht stören
                                    T Nicht stören
                                    ticaki
                                    @sigi234
                                    Der fehlerhafte Text war bei mir schon behoben, der wird aber nur beim erstellen des States geschrieben.
                                    Spenden
                                    • T Nicht stören
                                      T Nicht stören
                                      ticaki
                                      v.0.2.4-alpha.0
                                      • Benachrichtungsstates die sich füllen wenn zu einem bestimmten Warnungstyp eine Warnung aktiv und Jetzt zwischen start und ende liegt - immer die mit dem höchsten Level. Nicht alle Typen für alle Provider (funktioniert, aber nicht durchgetestet)
                                      • filtern nach level und typ je Provider
                                      • Unnötige ${} umgelegt
                                      • Im Admin kann man sich ansehen wie ich mir telegram, pushover, whatsapp und template vorgestellt habe, abgesehen vom konfigurieren ist noch kein code dahinter.
                                      Am besten den vorherigen Adapter deinstallieren, damit meine default vorgaben nicht von eurer Konfiguration überschrieben sind oder eine neue Instanz. Dann versteht man es besser.
                                      und falls nicht hier Bilder:
                                      EDIT: Das wird aber nur konfigurierbar, wenn die Adapterinstanz oben ausgewählt wird und das wiederrum geht nur mit installiertem Adapter.
                                      EDIT2: und wäre nett wenn ein ZAMG nutzer bei einer echten Warnung mal die Sprachen durchschalten würde, ob die gehen.
                                      Spenden
                                      • rtwlR Offline
                                        rtwlR Offline
                                        rtwl
                                        Ich würde gerne testen, hab aber keine Ahnung wie ich den Adapter installieren muss. Kann mir das jemand kurz erklären?
                                        -Peter
                                        • rtwlR rtwl
                                          T Nicht stören
                                          T Nicht stören
                                          ticaki
                                          @rtwl
                                          Expert aktivieren, dann auf die Katze, dann benutzerdefiniert und den Link oben einfügen. Aber nur wenn das Symbol oben in diesem Topic neben Test and Release grün ist. Wenn das rot ist, hab ich was hochgeladen, was nicht geht.
                                          Geht aber nur mit js-controller 5 und node 18 - hab keinen 4er im Einsatz und will da auch nicht Fehler suchen ohne System mit 4. selbiges für nodejs 16
                                          Spenden
                                          rtwlR 1 Antwort Letzte Antwort
